MOAB: Mesh Oriented datABase
(version 5.4.0)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2007 Sandia National Laboratories. Developed at the 00005 University of Wisconsin--Madison under SNL contract number 00006 624796. The U.S. Government and the University of Wisconsin 00007 retain certain rights to this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 (2007) kraftche@cae.wisc.edu 00024 00025 ***************************************************************** */ 00026 00027 /** \file MsqIMesh.hpp 00028 * \brief Adaptor for ITAPS iMesh interface 00029 * \author Jason Kraftcheck 00030 */ 00031 00032 #ifndef MSQ_MOAB_HPP 00033 #define MSQ_MOAB_HPP 00034 00035 #include "MeshInterface.hpp" 00036 #include "moab/Core.hpp" 00037 00038 namespace MBMesquite 00039 { 00040 00041 /** The name of the tag (integer) that Mesquite will use 00042 * to store internal data 00043 */ 00044 const char* const VERTEX_BYTE_TAG_NAME = "MesquiteVertexByte"; 00045 00046 /**\class MsqIMesh 00047 *\brief Mesquite iMesh Adapter 00048 * 00049 * Adpater for interfacing Mesquite with an application that provides 00050 * the ITAPS iMesh interface for interacting with mesh data. 00051 */ 00052 class MsqMOAB : virtual public MBMesquite::Mesh 00053 { 00054 public: 00055 //********* Functions that are NOT inherited ************ 00056 00057 MsqMOAB(); 00058 virtual ~MsqMOAB(); 00059 00060 /**\brief Create iMesh adaptor instance 00061 *\param imesh The iMesh instance to interact with 00062 *\param meshset The set of elements for which to optimize the quality 00063 * 00064 *\param element_dimension Optimize the subset of the elements in 00065 * 'meshset' with this dimension. Pass iBase_ALL_TYPES 00066 * for both iBase_FACE and iBase_REGION elements. 00067 * If 'meshset' is the root set, then this argument is 00068 * typically either iBase_FACE or iBase_REGION. 00069 * 00070 *\param fixed_tag A pointer to the tag handle designating a tag 00071 * containing fixed flags for vertices. The tag must 00072 * have size==1 and type==iBase_INTEGER or iBase_BYTES. 00073 * A value of one for a vertex indicates that the vertex 00074 * position is fixed. A value of zero indicates a free 00075 * vertex (a vertex that Mesquite may move to improve 00076 * mesh quality.) If this tag is not specified, then 00077 * the boundary constraints of the optimization must be 00078 * specified using an MsqIRel instance. 00079 * 00080 *\param slaved_tag A pointer to the tag handle designating a tag 00081 * containing slaved flags for vertices. The tag must 00082 * have size==1 and type==iBase_INTEGER or iBase_BYTES. 00083 * This tag value is ignored for corner vertices of 00084 * elements. The concept of 'slaved' is applicable only 00085 * to non-corner vertices in higher-order elements. A 00086 * value of one for a vertex indicates that the vertex 00087 * position should is a fucntion of the element shape 00088 * function, while a zero value indicates that the 00089 * element shape function is a function of the vertex 00090 * position. 00091 */ 00092 MsqMOAB( moab::Core* imesh, 00093 moab::EntityHandle meshset, 00094 moab::EntityType element_dimension, 00095 MsqError& err, 00096 const moab::Tag* fixed_tag = 0, 00097 const moab::Tag* slaved_tag = 0 ); 00098 00099 /**\brief Create iMesh adaptor instance 00100 * 00101 * This constructor is provided for the creation of an MsqIMesh instance 00102 * that is to be re-used for multiple optimization calls for different 00103 * sets of elements. set_active_set must be called to define the 00104 * subset of the mesh to optimize before an instance constructed with 00105 * this constructor may be used in an optimization. 00106 * 00107 *\param imesh The iMesh instance to interact with 00108 * 00109 *\param element_dimension Optimize the subset of the elements in 00110 * root set with this dimension. Pass iBase_ALL_TYPES 00111 * for both iBase_FACE and iBase_REGION elements. 00112 * If 'meshset' is the root set, then this argument is 00113 * typically either iBase_FACE or iBase_REGION. 00114 * 00115 *\param fixed_tag A pointer to the tag handle designating a tag 00116 * containing fixed flags for vertices. The tag must 00117 * have size==1 and type==iBase_INTEGER or iBase_BYTES. 00118 * A value of one for a vertex indicates that the vertex 00119 * position is fixed. A value of zero indicates a free 00120 * vertex (a vertex that Mesquite may move to improve 00121 * mesh quality.) If this tag is not specified, then 00122 * the boundary constraints of the optimization must be 00123 * specified using an MsqIRel instance. 00124 * 00125 *\param slaved_tag A pointer to the tag handle designating a tag 00126 * containing slaved flags for vertices. The tag must 00127 * have size==1 and type==iBase_INTEGER or iBase_BYTES. 00128 * This tag value is ignored for corner vertices of 00129 * elements. The concept of 'slaved' is applicable only 00130 * to non-corner vertices in higher-order elements. A 00131 * value of one for a vertex indicates that the vertex 00132 * position should is a fucntion of the element shape 00133 * function, while a zero value indicates that the 00134 * element shape function is a function of the vertex 00135 * position. 00136 */ 00137 MsqMOAB( moab::Core* imesh, 00138 moab::EntityType element_dimension, 00139 MsqError& err, 00140 const moab::Tag* fixed_tag = 0, 00141 const moab::Tag* slaved_tag = 0 ); 00142 00143 /** \brief set mesh to be smoothed. 00144 * 00145 * Set the mesh which Mesquite is to smooth. Optionally 00146 * specify fixed vertices. 00147 * NOTE: If an active set is not specified, the default 00148 * is to use the global set (the ENTIRE mesh.) 00149 * 00150 *\param element_set ITAPS entity set handle for set containing 00151 * mesh elements and vertices for which quality 00152 * is to be improved. 00153 */ 00154 void set_active_set( moab::EntityHandle meshset, moab::EntityType element_dimension, MsqError& err ); 00155 00156 void set_fixed_tag( moab::Tag tag, MsqError& err ); //!< Set tag for vertex fixed flag 00157 void set_slaved_tag( moab::Tag tag, MsqError& err ); //!< Set tag for vertex slaved flag 00158 void clear_fixed_tag(); //!< No tag for vertex fixed flag 00159 void clear_slaved_tag(); //!< No tag for vertex fixed flag 00160 const moab::Tag* get_fixed_tag() const; //!< Get tag for vertex fixed flag 00161 const moab::Tag* get_slaved_tag() const; //!< Get tag for vertex slaved flag 00162 00163 virtual moab::Core* get_interface() const; 00164 virtual moab::EntityHandle get_entity_set() const; 00165 00166 //********* Functions that ARE inherited ************ 00167 00168 /**\brief Get dimension of vertex coordinates (2D vs. 3D). */ 00169 virtual int get_geometric_dimension( MBMesquite::MsqError& /*err*/ ); 00170 00171 /** \brief Get handles for all elemnents */ 00172 virtual void get_all_elements( std::vector< ElementHandle >& elements, MsqError& err ); 00173 00174 /** \brief Get handles for all vertices */ 00175 virtual void get_all_vertices( std::vector< VertexHandle >& vertices, MsqError& err ); 00176 00177 /**\brief Query "fixed" flag for a vertex */ 00178 virtual void vertices_get_fixed_flag( const VertexHandle vert_array[], 00179 std::vector< bool >& fixed_flag_array, 00180 size_t num_vtx, 00181 MsqError& err ); 00182 00183 virtual void vertices_get_slaved_flag( const VertexHandle vert_array[], 00184 std::vector< bool >& slaved_flag_array, 00185 size_t num_vtx, 00186 MsqError& err ); 00187 00188 /**\brief Get vertex coordinates */ 00189 virtual void vertices_get_coordinates( const VertexHandle vert_array[], 00190 MsqVertex* coordinates, 00191 size_t num_vtx, 00192 MsqError& err ); 00193 /**\brief Set vertex coordinates */ 00194 virtual void vertex_set_coordinates( VertexHandle vertex, const Vector3D& coordinates, MsqError& err ); 00195 00196 /**\brief Set vertex mark */ 00197 virtual void vertex_set_byte( VertexHandle vertex, unsigned char byte, MsqError& err ); 00198 /**\brief Set vertex mark */ 00199 virtual void vertices_set_byte( const VertexHandle* vert_array, 00200 const unsigned char* byte_array, 00201 size_t array_size, 00202 MsqError& err ); 00203 00204 /**\brief Get vertex mark */ 00205 virtual void vertex_get_byte( VertexHandle vertex, unsigned char* byte, MsqError& err ); 00206 /**\brief Get vertex mark */ 00207 virtual void vertices_get_byte( const VertexHandle* vert_array, 00208 unsigned char* byte_array, 00209 size_t array_size, 00210 MsqError& err ); 00211 00212 /**\brief Get vertex-to-element adjacencies */ 00213 virtual void vertices_get_attached_elements( const VertexHandle* vertex_array, 00214 size_t num_vertices, 00215 std::vector< ElementHandle >& elements, 00216 std::vector< size_t >& offsets, 00217 MsqError& err ); 00218 00219 /**\brief Get element connectivity */ 00220 virtual void elements_get_attached_vertices( const ElementHandle* elem_handles, 00221 size_t num_elems, 00222 std::vector< VertexHandle >& vertices, 00223 std::vector< size_t >& offsets, 00224 MsqError& err ); 00225 00226 /**\brief Return topology type enum for an array of elements */ 00227 virtual void elements_get_topologies( const ElementHandle* element_handle_array, 00228 EntityTopology* element_topologies, 00229 size_t num_elements, 00230 MsqError& err ); 00231 00232 //**************** Memory Management **************** 00233 /**\brief no-op */ 00234 virtual void release_entity_handles( const EntityHandle* handle_array, size_t num_handles, MsqError& err ); 00235 00236 // Instead of deleting a Mesh when you think you are done, 00237 // call release(). In simple cases, the implementation could 00238 // just call the destructor. More sophisticated implementations 00239 // may want to keep the Mesh object to live longer than Mesquite 00240 // is using it. 00241 virtual void release(); 00242 00243 //*************** Tags *********** 00244 00245 /** \brief Create a tag 00246 * 00247 * Create a user-defined data type that can be attached 00248 * to any element or vertex in the mesh. For an opaque or 00249 * undefined type, use type=BYTE and length=sizeof(..). 00250 * 00251 * \param tag_name A unique name for the data object 00252 * \param type The type of the data 00253 * \param length Number of values per entity (1->scalar, >1 ->vector) 00254 * \param default_value Default value to assign to all entities - may be NULL 00255 * \return - Handle for tag definition 00256 */ 00257 virtual TagHandle tag_create( const std::string& tag_name, 00258 TagType type, 00259 unsigned length, 00260 const void* default_value, 00261 MsqError& err ); 00262 00263 /** \brief Remove a tag and all corresponding data 00264 * 00265 * Delete a tag. 00266 */ 00267 virtual void tag_delete( TagHandle handle, MsqError& err ); 00268 00269 /** \brief Get handle for existing tag, by name. */ 00270 virtual TagHandle tag_get( const std::string& name, MsqError& err ); 00271 00272 /** \brief Get properites of tag 00273 * 00274 * Get data type and number of values per entity for tag. 00275 * \param handle moab::Tag to get properties of. 00276 * \param name_out Passed back tag name. 00277 * \param type_out Passed back tag type. 00278 * \param length_out Passed back number of values per entity. 00279 */ 00280 virtual void tag_properties( TagHandle handle, 00281 std::string& name_out, 00282 TagType& type_out, 00283 unsigned& length_out, 00284 MsqError& err ); 00285 00286 /** \brief Set tag values on elements 00287 * 00288 * Set the value of a tag for a list of mesh elements. 00289 * \param handle The tag 00290 * \param num_elems Length of elem_array 00291 * \param elem_array Array of elements for which to set the tag value. 00292 * \param tag_data moab::Tag data for each element, contiguous in memory. 00293 * This data is expected to be 00294 00295 * num_elems*tag_length*sizeof(tag_type) bytes. 00296 */ 00297 virtual void tag_set_element_data( TagHandle handle, 00298 size_t num_elems, 00299 const ElementHandle* elem_array, 00300 const void* tag_data, 00301 MsqError& err ); 00302 00303 /** \brief Set tag values on vertices 00304 * 00305 * Set the value of a tag for a list of mesh vertices. 00306 * \param handle The tag 00307 * \param num_elems Length of node_array 00308 * \param node_array Array of vertices for which to set the tag value. 00309 * \param tag_data moab::Tag data for each element, contiguous in memory. 00310 * This data is expected to be 00311 * num_elems*tag_length*sizeof(tag_type) bytes. 00312 */ 00313 virtual void tag_set_vertex_data( TagHandle handle, 00314 size_t num_elems, 00315 const VertexHandle* node_array, 00316 const void* tag_data, 00317 MsqError& err ); 00318 00319 /** \brief Get tag values on elements 00320 * 00321 * Get the value of a tag for a list of mesh elements. 00322 * \param handle The tag 00323 * \param num_elems Length of elem_array 00324 * \param elem_array Array of elements for which to get the tag value. 00325 * \param tag_data Return buffer in which to copy tag data, contiguous 00326 * in memory. This data is expected to be 00327 * num_elems*tag_length*sizeof(tag_type) bytes. 00328 */ 00329 virtual void tag_get_element_data( TagHandle handle, 00330 size_t num_elems, 00331 const ElementHandle* elem_array, 00332 void* tag_data, 00333 MsqError& err ); 00334 00335 /** \brief Get tag values on vertices. 00336 * 00337 * Get the value of a tag for a list of mesh vertices. 00338 * \param handle The tag 00339 * \param num_elems Length of elem_array 00340 * \param elem_array Array of vertices for which to get the tag value. 00341 * \param tag_data Return buffer in which to copy tag data, contiguous 00342 * in memory. This data is expected to be 00343 * num_elems*tag_length*sizeof(tag_type) bytes. 00344 */ 00345 virtual void tag_get_vertex_data( TagHandle handle, 00346 size_t num_elems, 00347 const VertexHandle* node_array, 00348 void* tag_data, 00349 MsqError& err ); 00350 00351 protected: 00352 moab::DataType check_valid_flag_tag( moab::Tag tag, const char* which_flag, MsqError& err ); 00353 00354 void set_int_tag( void* tag, void* meshset, int value, MsqError& err ); 00355 00356 /** \brief Call TSTTM::Arr::getEntArrAdj 00357 * 00358 * Common code for \ref vertices_get_attached_elements and 00359 * \ref elements_get_attached_vertices 00360 * 00361 *\param source Array of handles of source entities to query from 00362 *\param num_source The length of \ref source 00363 *\param target_type The type of entity to query for 00364 *\param target The output list of adjacent entities 00365 *\param offsets For each entity in \ref source, the offset in 00366 * \ref target at which the corresponding adjacent 00367 * entities are stored. (output) 00368 */ 00369 void get_adjacent_entities( const moab::EntityHandle* source, 00370 size_t num_source, 00371 moab::EntityType target_type, 00372 std::vector< EntityHandle >& target, 00373 std::vector< size_t >& offsets, 00374 MsqError& err ); 00375 00376 /** The IMesh instance */ 00377 moab::Core* meshInstance; 00378 00379 private: 00380 void init_active_mesh( moab::Core* mesh, MsqError& err, const moab::Tag* fixed_tag, const moab::Tag* slaved_tag ); 00381 00382 void get_flag_data( moab::Tag tag, 00383 bool have_tag, 00384 moab::DataType type, 00385 const VertexHandle vert_array[], 00386 std::vector< bool >& flag_array, 00387 size_t num_vtx, 00388 MsqError& err ); 00389 00390 /** \brief Set tag values */ 00391 void tag_set_data( TagHandle handle, 00392 size_t num_elems, 00393 const EntityHandle* handle_array, 00394 const void* tag_data, 00395 MsqError& err ); 00396 00397 /** \brief Get tag values */ 00398 void tag_get_data( TagHandle handle, 00399 size_t num_elems, 00400 const EntityHandle* handle_array, 00401 void* tag_data, 00402 MsqError& err ); 00403 00404 /** Have mesh */ 00405 bool haveMesh; 00406 /** ITAPS entity set handle for elements to improve */ 00407 // moab::EntityHandle elementSet; 00408 /** ITAPS entity set handle for nodes to move */ 00409 // moab::EntityHandle nodeSet; 00410 /** std::set containing elements in elementSet, used 00411 * to constrain vertex->element adjaceny queries to 00412 * only those elements that are in the input element set. 00413 */ 00414 // std::vector<moab::EntityHandle> inputElements; 00415 00416 /** The type of elements contained in the input element set. 00417 * Should be one of: 00418 * - iBase_REGION - volume elements 00419 * - iBase_FACE - face/2d elements 00420 * - iBase_ALL_TYPES - mixed volume and face elements 00421 */ 00422 moab::EntityType inputSetType; 00423 /** The meshset containing the elements to optimize */ 00424 moab::EntityHandle inputSet; 00425 00426 /** Handle for tag used to hold vertex byte */ 00427 moab::Tag byteTag; 00428 /** moab::Tag was created in constructor */ 00429 bool createdByteTag; 00430 /** Handle for tag used to hold vertex-fixed flag */ 00431 moab::Tag fixedTag; 00432 /** fixedTag handle is valid */ 00433 bool haveFixedTag; 00434 /** iBase_TYPE for fixed tag */ 00435 moab::DataType fixedTagType; 00436 /** Handle for tag used to hold vertex-slaved flag */ 00437 moab::Tag slavedTag; 00438 /** slavedTag handle is valid */ 00439 bool haveSlavedTag; 00440 /** iBase_TYPE for slaved tag */ 00441 moab::DataType slavedTagType; 00442 /** Dimension is queried once during create and cached */ 00443 int geometricDimension; 00444 /** Map iMesh_EntityTopology to MBMesquite::EntityTopology */ 00445 EntityTopology topologyMap[moab::MBMAXTYPE + 1]; 00446 }; 00447 00448 } // namespace MBMesquite 00449 00450 #endif // MSQ_MOAB_HPP
