MOAB
4.9.3pre
00001 // This file is part of Eigen, a lightweight C++ template library 00002 // for linear algebra. 00003 // 00004 // Copyright (C) 2010 Gael Guennebaud <[email protected]> 00005 // 00006 // This Source Code Form is subject to the terms of the Mozilla 00007 // Public License v. 2.0. If a copy of the MPL was not distributed 00008 // with this file, You can obtain one at http://mozilla.org/MPL/2.0/. 00009 00010 #ifndef EIGEN_PARALLELIZER_H 00011 #define EIGEN_PARALLELIZER_H 00012 00013 namespace Eigen { 00014 00015 namespace internal { 00016 00018 inline void manage_multi_threading(Action action, int* v) 00019 { 00020 static EIGEN_UNUSED int m_maxThreads = -1; 00021 00022 if(action==SetAction) 00023 { 00024 eigen_internal_assert(v!=0); 00025 m_maxThreads = *v; 00026 } 00027 else if(action==GetAction) 00028 { 00029 eigen_internal_assert(v!=0); 00030 #ifdef EIGEN_HAS_OPENMP 00031 if(m_maxThreads>0) 00032 *v = m_maxThreads; 00033 else 00034 *v = omp_get_max_threads(); 00035 #else 00036 *v = 1; 00037 #endif 00038 } 00039 else 00040 { 00041 eigen_internal_assert(false); 00042 } 00043 } 00044 00045 } 00046 00048 inline void initParallel() 00049 { 00050 int nbt; 00051 internal::manage_multi_threading(GetAction, &nbt); 00052 std::ptrdiff_t l1, l2, l3; 00053 internal::manage_caching_sizes(GetAction, &l1, &l2, &l3); 00054 } 00055 00058 inline int nbThreads() 00059 { 00060 int ret; 00061 internal::manage_multi_threading(GetAction, &ret); 00062 return ret; 00063 } 00064 00067 inline void setNbThreads(int v) 00068 { 00069 internal::manage_multi_threading(SetAction, &v); 00070 } 00071 00072 namespace internal { 00073 00074 template<typename Index> struct GemmParallelInfo 00075 { 00076 GemmParallelInfo() : sync(-1), users(0), lhs_start(0), lhs_length(0) {} 00077 00078 int volatile sync; 00079 int volatile users; 00080 00081 Index lhs_start; 00082 Index lhs_length; 00083 }; 00084 00085 template<bool Condition, typename Functor, typename Index> 00086 void parallelize_gemm(const Functor& func, Index rows, Index cols, bool transpose) 00087 { 00088 // TODO when EIGEN_USE_BLAS is defined, 00089 // we should still enable OMP for other scalar types 00090 #if !(defined (EIGEN_HAS_OPENMP)) || defined (EIGEN_USE_BLAS) 00091 // FIXME the transpose variable is only needed to properly split 00092 // the matrix product when multithreading is enabled. This is a temporary 00093 // fix to support row-major destination matrices. This whole 00094 // parallelizer mechanism has to be redisigned anyway. 00095 EIGEN_UNUSED_VARIABLE(transpose); 00096 func(0,rows, 0,cols); 00097 #else 00098 00099 // Dynamically check whether we should enable or disable OpenMP. 00100 // The conditions are: 00101 // - the max number of threads we can create is greater than 1 00102 // - we are not already in a parallel code 00103 // - the sizes are large enough 00104 00105 // compute the maximal number of threads from the size of the product: 00106 // FIXME this has to be fine tuned 00107 Index size = transpose ? rows : cols; 00108 Index pb_max_threads = std::max<Index>(1,size / 32); 00109 // compute the number of threads we are going to use 00110 Index threads = std::min<Index>(nbThreads(), pb_max_threads); 00111 00112 // if multi-threading is explicitely disabled, not useful, or if we already are in a parallel session, 00113 // then abort multi-threading 00114 // FIXME omp_get_num_threads()>1 only works for openmp, what if the user does not use openmp? 00115 if((!Condition) || (threads==1) || (omp_get_num_threads()>1)) 00116 return func(0,rows, 0,cols); 00117 00118 Eigen::initParallel(); 00119 func.initParallelSession(threads); 00120 00121 if(transpose) 00122 std::swap(rows,cols); 00123 00124 ei_declare_aligned_stack_constructed_variable(GemmParallelInfo<Index>,info,threads,0); 00125 00126 #pragma omp parallel num_threads(threads) 00127 { 00128 Index i = omp_get_thread_num(); 00129 // Note that the actual number of threads might be lower than the number of request ones. 00130 Index actual_threads = omp_get_num_threads(); 00131 00132 Index blockCols = (cols / actual_threads) & ~Index(0x3); 00133 Index blockRows = (rows / actual_threads); 00134 blockRows = (blockRows/Functor::Traits::mr)*Functor::Traits::mr; 00135 00136 Index r0 = i*blockRows; 00137 Index actualBlockRows = (i+1==actual_threads) ? rows-r0 : blockRows; 00138 00139 Index c0 = i*blockCols; 00140 Index actualBlockCols = (i+1==actual_threads) ? cols-c0 : blockCols; 00141 00142 info[i].lhs_start = r0; 00143 info[i].lhs_length = actualBlockRows; 00144 00145 if(transpose) func(c0, actualBlockCols, 0, rows, info); 00146 else func(0, rows, c0, actualBlockCols, info); 00147 } 00148 #endif 00149 } 00150 00151 } // end namespace internal 00152 00153 } // end namespace Eigen 00154 00155 #endif // EIGEN_PARALLELIZER_H
