MOAB
4.9.3pre
00001 // This file is part of Eigen, a lightweight C++ template library 00002 // for linear algebra. 00003 // 00004 // Copyright (C) 2008-2009 Gael Guennebaud <[email protected]> 00005 // 00006 // This Source Code Form is subject to the terms of the Mozilla 00007 // Public License v. 2.0. If a copy of the MPL was not distributed 00008 // with this file, You can obtain one at http://mozilla.org/MPL/2.0/. 00009 00010 #ifndef EIGEN_PACKET_MATH_SSE_H 00011 #define EIGEN_PACKET_MATH_SSE_H 00012 00013 namespace Eigen { 00014 00015 namespace internal { 00016 00017 #ifndef EIGEN_CACHEFRIENDLY_PRODUCT_THRESHOLD 00018 #define EIGEN_CACHEFRIENDLY_PRODUCT_THRESHOLD 8 00019 #endif 00020 00021 #ifndef EIGEN_ARCH_DEFAULT_NUMBER_OF_REGISTERS 00022 #define EIGEN_ARCH_DEFAULT_NUMBER_OF_REGISTERS (2*sizeof(void*)) 00023 #endif 00024 00025 #ifdef __FMA__ 00026 #ifndef EIGEN_HAS_SINGLE_INSTRUCTION_MADD 00027 #define EIGEN_HAS_SINGLE_INSTRUCTION_MADD 1 00028 #endif 00029 #endif 00030 00031 #if (defined EIGEN_VECTORIZE_AVX) && EIGEN_COMP_GNUC_STRICT && (__GXX_ABI_VERSION < 1004) 00032 // With GCC's default ABI version, a __m128 or __m256 are the same types and therefore we cannot 00033 // have overloads for both types without linking error. 00034 // One solution is to increase ABI version using -fabi-version=4 (or greater). 00035 // Otherwise, we workaround this inconvenience by wrapping 128bit types into the following helper 00036 // structure: 00037 template<typename T> 00038 struct eigen_packet_wrapper 00039 { 00040 EIGEN_ALWAYS_INLINE operator T&() { return m_val; } 00041 EIGEN_ALWAYS_INLINE operator const T&() const { return m_val; } 00042 EIGEN_ALWAYS_INLINE eigen_packet_wrapper() {} 00043 EIGEN_ALWAYS_INLINE eigen_packet_wrapper(const T &v) : m_val(v) {} 00044 EIGEN_ALWAYS_INLINE eigen_packet_wrapper& operator=(const T &v) { 00045 m_val = v; 00046 return *this; 00047 } 00048 00049 T m_val; 00050 }; 00051 typedef eigen_packet_wrapper<__m128> Packet4f; 00052 typedef eigen_packet_wrapper<__m128i> Packet4i; 00053 typedef eigen_packet_wrapper<__m128d> Packet2d; 00054 #else 00055 typedef __m128 Packet4f; 00056 typedef __m128i Packet4i; 00057 typedef __m128d Packet2d; 00058 #endif 00059 00060 template<> struct is_arithmetic<__m128> { enum { value = true }; }; 00061 template<> struct is_arithmetic<__m128i> { enum { value = true }; }; 00062 template<> struct is_arithmetic<__m128d> { enum { value = true }; }; 00063 00064 #define vec4f_swizzle1(v,p,q,r,s) \ 00065 (_mm_castsi128_ps(_mm_shuffle_epi32( _mm_castps_si128(v), ((s)<<6|(r)<<4|(q)<<2|(p))))) 00066 00067 #define vec4i_swizzle1(v,p,q,r,s) \ 00068 (_mm_shuffle_epi32( v, ((s)<<6|(r)<<4|(q)<<2|(p)))) 00069 00070 #define vec2d_swizzle1(v,p,q) \ 00071 (_mm_castsi128_pd(_mm_shuffle_epi32( _mm_castpd_si128(v), ((q*2+1)<<6|(q*2)<<4|(p*2+1)<<2|(p*2))))) 00072 00073 #define vec4f_swizzle2(a,b,p,q,r,s) \ 00074 (_mm_shuffle_ps( (a), (b), ((s)<<6|(r)<<4|(q)<<2|(p)))) 00075 00076 #define vec4i_swizzle2(a,b,p,q,r,s) \ 00077 (_mm_castps_si128( (_mm_shuffle_ps( _mm_castsi128_ps(a), _mm_castsi128_ps(b), ((s)<<6|(r)<<4|(q)<<2|(p)))))) 00078 00079 #define _EIGEN_DECLARE_CONST_Packet4f(NAME,X) \ 00080 const Packet4f p4f_##NAME = pset1<Packet4f>(X) 00081 00082 #define _EIGEN_DECLARE_CONST_Packet2d(NAME,X) \ 00083 const Packet2d p2d_##NAME = pset1<Packet2d>(X) 00084 00085 #define _EIGEN_DECLARE_CONST_Packet4f_FROM_INT(NAME,X) \ 00086 const Packet4f p4f_##NAME = _mm_castsi128_ps(pset1<Packet4i>(X)) 00087 00088 #define _EIGEN_DECLARE_CONST_Packet4i(NAME,X) \ 00089 const Packet4i p4i_##NAME = pset1<Packet4i>(X) 00090 00091 00092 // Use the packet_traits defined in AVX/PacketMath.h instead if we're going 00093 // to leverage AVX instructions. 00094 #ifndef EIGEN_VECTORIZE_AVX 00095 template<> struct packet_traits<float> : default_packet_traits 00096 { 00097 typedef Packet4f type; 00098 typedef Packet4f half; 00099 enum { 00100 Vectorizable = 1, 00101 AlignedOnScalar = 1, 00102 size=4, 00103 HasHalfPacket = 0, 00104 00105 HasDiv = 1, 00106 HasSin = EIGEN_FAST_MATH, 00107 HasCos = EIGEN_FAST_MATH, 00108 HasLog = 1, 00109 HasExp = 1, 00110 HasSqrt = 1, 00111 HasRsqrt = 1, 00112 HasTanh = EIGEN_FAST_MATH, 00113 HasBlend = 1 00114 00115 #ifdef EIGEN_VECTORIZE_SSE4_1 00116 , 00117 HasRound = 1, 00118 HasFloor = 1, 00119 HasCeil = 1 00120 #endif 00121 }; 00122 }; 00123 template<> struct packet_traits<double> : default_packet_traits 00124 { 00125 typedef Packet2d type; 00126 typedef Packet2d half; 00127 enum { 00128 Vectorizable = 1, 00129 AlignedOnScalar = 1, 00130 size=2, 00131 HasHalfPacket = 0, 00132 00133 HasDiv = 1, 00134 HasExp = 1, 00135 HasSqrt = 1, 00136 HasRsqrt = 1, 00137 HasBlend = 1 00138 00139 #ifdef EIGEN_VECTORIZE_SSE4_1 00140 , 00141 HasRound = 1, 00142 HasFloor = 1, 00143 HasCeil = 1 00144 #endif 00145 }; 00146 }; 00147 #endif 00148 template<> struct packet_traits<int> : default_packet_traits 00149 { 00150 typedef Packet4i type; 00151 typedef Packet4i half; 00152 enum { 00153 Vectorizable = 1, 00154 AlignedOnScalar = 1, 00155 size=4, 00156 00157 HasBlend = 1 00158 }; 00159 }; 00160 00161 template<> struct unpacket_traits<Packet4f> { typedef float type; enum {size=4, alignment=Aligned16}; typedef Packet4f half; }; 00162 template<> struct unpacket_traits<Packet2d> { typedef double type; enum {size=2, alignment=Aligned16}; typedef Packet2d half; }; 00163 template<> struct unpacket_traits<Packet4i> { typedef int type; enum {size=4, alignment=Aligned16}; typedef Packet4i half; }; 00164 00165 #if EIGEN_COMP_MSVC==1500 00166 // Workaround MSVC 9 internal compiler error. 00167 // TODO: It has been detected with win64 builds (amd64), so let's check whether it also happens in 32bits+SSE mode 00168 // TODO: let's check whether there does not exist a better fix, like adding a pset0() function. (it crashed on pset1(0)). 00169 template<> EIGEN_STRONG_INLINE Packet4f pset1<Packet4f>(const float& from) { return _mm_set_ps(from,from,from,from); } 00170 template<> EIGEN_STRONG_INLINE Packet2d pset1<Packet2d>(const double& from) { return _mm_set_pd(from,from); } 00171 template<> EIGEN_STRONG_INLINE Packet4i pset1<Packet4i>(const int& from) { return _mm_set_epi32(from,from,from,from); } 00172 #else 00173 template<> EIGEN_STRONG_INLINE Packet4f pset1<Packet4f>(const float& from) { return _mm_set_ps1(from); } 00174 template<> EIGEN_STRONG_INLINE Packet2d pset1<Packet2d>(const double& from) { return _mm_set1_pd(from); } 00175 template<> EIGEN_STRONG_INLINE Packet4i pset1<Packet4i>(const int& from) { return _mm_set1_epi32(from); } 00176 #endif 00177 00178 // GCC generates a shufps instruction for _mm_set1_ps/_mm_load1_ps instead of the more efficient pshufd instruction. 00179 // However, using inrinsics for pset1 makes gcc to generate crappy code in some cases (see bug 203) 00180 // Using inline assembly is also not an option because then gcc fails to reorder properly the instructions. 00181 // Therefore, we introduced the pload1 functions to be used in product kernels for which bug 203 does not apply. 00182 // Also note that with AVX, we want it to generate a vbroadcastss. 00183 #if EIGEN_COMP_GNUC_STRICT && (!defined __AVX__) 00184 template<> EIGEN_STRONG_INLINE Packet4f pload1<Packet4f>(const float *from) { 00185 return vec4f_swizzle1(_mm_load_ss(from),0,0,0,0); 00186 } 00187 #endif 00188 00189 template<> EIGEN_STRONG_INLINE Packet4f plset<Packet4f>(const float& a) { return _mm_add_ps(pset1<Packet4f>(a), _mm_set_ps(3,2,1,0)); } 00190 template<> EIGEN_STRONG_INLINE Packet2d plset<Packet2d>(const double& a) { return _mm_add_pd(pset1<Packet2d>(a),_mm_set_pd(1,0)); } 00191 template<> EIGEN_STRONG_INLINE Packet4i plset<Packet4i>(const int& a) { return _mm_add_epi32(pset1<Packet4i>(a),_mm_set_epi32(3,2,1,0)); } 00192 00193 template<> EIGEN_STRONG_INLINE Packet4f padd<Packet4f>(const Packet4f& a, const Packet4f& b) { return _mm_add_ps(a,b); } 00194 template<> EIGEN_STRONG_INLINE Packet2d padd<Packet2d>(const Packet2d& a, const Packet2d& b) { return _mm_add_pd(a,b); } 00195 template<> EIGEN_STRONG_INLINE Packet4i padd<Packet4i>(const Packet4i& a, const Packet4i& b) { return _mm_add_epi32(a,b); } 00196 00197 template<> EIGEN_STRONG_INLINE Packet4f psub<Packet4f>(const Packet4f& a, const Packet4f& b) { return _mm_sub_ps(a,b); } 00198 template<> EIGEN_STRONG_INLINE Packet2d psub<Packet2d>(const Packet2d& a, const Packet2d& b) { return _mm_sub_pd(a,b); } 00199 template<> EIGEN_STRONG_INLINE Packet4i psub<Packet4i>(const Packet4i& a, const Packet4i& b) { return _mm_sub_epi32(a,b); } 00200 00201 template<> EIGEN_STRONG_INLINE Packet4f pnegate(const Packet4f& a) 00202 { 00203 const Packet4f mask = _mm_castsi128_ps(_mm_setr_epi32(0x80000000,0x80000000,0x80000000,0x80000000)); 00204 return _mm_xor_ps(a,mask); 00205 } 00206 template<> EIGEN_STRONG_INLINE Packet2d pnegate(const Packet2d& a) 00207 { 00208 const Packet2d mask = _mm_castsi128_pd(_mm_setr_epi32(0x0,0x80000000,0x0,0x80000000)); 00209 return _mm_xor_pd(a,mask); 00210 } 00211 template<> EIGEN_STRONG_INLINE Packet4i pnegate(const Packet4i& a) 00212 { 00213 return psub(Packet4i(_mm_setr_epi32(0,0,0,0)), a); 00214 } 00215 00216 template<> EIGEN_STRONG_INLINE Packet4f pconj(const Packet4f& a) { return a; } 00217 template<> EIGEN_STRONG_INLINE Packet2d pconj(const Packet2d& a) { return a; } 00218 template<> EIGEN_STRONG_INLINE Packet4i pconj(const Packet4i& a) { return a; } 00219 00220 template<> EIGEN_STRONG_INLINE Packet4f pmul<Packet4f>(const Packet4f& a, const Packet4f& b) { return _mm_mul_ps(a,b); } 00221 template<> EIGEN_STRONG_INLINE Packet2d pmul<Packet2d>(const Packet2d& a, const Packet2d& b) { return _mm_mul_pd(a,b); } 00222 template<> EIGEN_STRONG_INLINE Packet4i pmul<Packet4i>(const Packet4i& a, const Packet4i& b) 00223 { 00224 #ifdef EIGEN_VECTORIZE_SSE4_1 00225 return _mm_mullo_epi32(a,b); 00226 #else 00227 // this version is slightly faster than 4 scalar products 00228 return vec4i_swizzle1( 00229 vec4i_swizzle2( 00230 _mm_mul_epu32(a,b), 00231 _mm_mul_epu32(vec4i_swizzle1(a,1,0,3,2), 00232 vec4i_swizzle1(b,1,0,3,2)), 00233 0,2,0,2), 00234 0,2,1,3); 00235 #endif 00236 } 00237 00238 template<> EIGEN_STRONG_INLINE Packet4f pdiv<Packet4f>(const Packet4f& a, const Packet4f& b) { return _mm_div_ps(a,b); } 00239 template<> EIGEN_STRONG_INLINE Packet2d pdiv<Packet2d>(const Packet2d& a, const Packet2d& b) { return _mm_div_pd(a,b); } 00240 00241 // for some weird raisons, it has to be overloaded for packet of integers 00242 template<> EIGEN_STRONG_INLINE Packet4i pmadd(const Packet4i& a, const Packet4i& b, const Packet4i& c) { return padd(pmul(a,b), c); } 00243 #ifdef __FMA__ 00244 template<> EIGEN_STRONG_INLINE Packet4f pmadd(const Packet4f& a, const Packet4f& b, const Packet4f& c) { return _mm_fmadd_ps(a,b,c); } 00245 template<> EIGEN_STRONG_INLINE Packet2d pmadd(const Packet2d& a, const Packet2d& b, const Packet2d& c) { return _mm_fmadd_pd(a,b,c); } 00246 #endif 00247 00248 template<> EIGEN_STRONG_INLINE Packet4f pmin<Packet4f>(const Packet4f& a, const Packet4f& b) { return _mm_min_ps(a,b); } 00249 template<> EIGEN_STRONG_INLINE Packet2d pmin<Packet2d>(const Packet2d& a, const Packet2d& b) { return _mm_min_pd(a,b); } 00250 template<> EIGEN_STRONG_INLINE Packet4i pmin<Packet4i>(const Packet4i& a, const Packet4i& b) 00251 { 00252 #ifdef EIGEN_VECTORIZE_SSE4_1 00253 return _mm_min_epi32(a,b); 00254 #else 00255 // after some bench, this version *is* faster than a scalar implementation 00256 Packet4i mask = _mm_cmplt_epi32(a,b); 00257 return _mm_or_si128(_mm_and_si128(mask,a),_mm_andnot_si128(mask,b)); 00258 #endif 00259 } 00260 00261 template<> EIGEN_STRONG_INLINE Packet4f pmax<Packet4f>(const Packet4f& a, const Packet4f& b) { return _mm_max_ps(a,b); } 00262 template<> EIGEN_STRONG_INLINE Packet2d pmax<Packet2d>(const Packet2d& a, const Packet2d& b) { return _mm_max_pd(a,b); } 00263 template<> EIGEN_STRONG_INLINE Packet4i pmax<Packet4i>(const Packet4i& a, const Packet4i& b) 00264 { 00265 #ifdef EIGEN_VECTORIZE_SSE4_1 00266 return _mm_max_epi32(a,b); 00267 #else 00268 // after some bench, this version *is* faster than a scalar implementation 00269 Packet4i mask = _mm_cmpgt_epi32(a,b); 00270 return _mm_or_si128(_mm_and_si128(mask,a),_mm_andnot_si128(mask,b)); 00271 #endif 00272 } 00273 00274 #ifdef EIGEN_VECTORIZE_SSE4_1 00275 template<> EIGEN_STRONG_INLINE Packet4f pround<Packet4f>(const Packet4f& a) { return _mm_round_ps(a, 0); } 00276 template<> EIGEN_STRONG_INLINE Packet2d pround<Packet2d>(const Packet2d& a) { return _mm_round_pd(a, 0); } 00277 00278 template<> EIGEN_STRONG_INLINE Packet4f pceil<Packet4f>(const Packet4f& a) { return _mm_ceil_ps(a); } 00279 template<> EIGEN_STRONG_INLINE Packet2d pceil<Packet2d>(const Packet2d& a) { return _mm_ceil_pd(a); } 00280 00281 template<> EIGEN_STRONG_INLINE Packet4f pfloor<Packet4f>(const Packet4f& a) { return _mm_floor_ps(a); } 00282 template<> EIGEN_STRONG_INLINE Packet2d pfloor<Packet2d>(const Packet2d& a) { return _mm_floor_pd(a); } 00283 #endif 00284 00285 template<> EIGEN_STRONG_INLINE Packet4f pand<Packet4f>(const Packet4f& a, const Packet4f& b) { return _mm_and_ps(a,b); } 00286 template<> EIGEN_STRONG_INLINE Packet2d pand<Packet2d>(const Packet2d& a, const Packet2d& b) { return _mm_and_pd(a,b); } 00287 template<> EIGEN_STRONG_INLINE Packet4i pand<Packet4i>(const Packet4i& a, const Packet4i& b) { return _mm_and_si128(a,b); } 00288 00289 template<> EIGEN_STRONG_INLINE Packet4f por<Packet4f>(const Packet4f& a, const Packet4f& b) { return _mm_or_ps(a,b); } 00290 template<> EIGEN_STRONG_INLINE Packet2d por<Packet2d>(const Packet2d& a, const Packet2d& b) { return _mm_or_pd(a,b); } 00291 template<> EIGEN_STRONG_INLINE Packet4i por<Packet4i>(const Packet4i& a, const Packet4i& b) { return _mm_or_si128(a,b); } 00292 00293 template<> EIGEN_STRONG_INLINE Packet4f pxor<Packet4f>(const Packet4f& a, const Packet4f& b) { return _mm_xor_ps(a,b); } 00294 template<> EIGEN_STRONG_INLINE Packet2d pxor<Packet2d>(const Packet2d& a, const Packet2d& b) { return _mm_xor_pd(a,b); } 00295 template<> EIGEN_STRONG_INLINE Packet4i pxor<Packet4i>(const Packet4i& a, const Packet4i& b) { return _mm_xor_si128(a,b); } 00296 00297 template<> EIGEN_STRONG_INLINE Packet4f pandnot<Packet4f>(const Packet4f& a, const Packet4f& b) { return _mm_andnot_ps(a,b); } 00298 template<> EIGEN_STRONG_INLINE Packet2d pandnot<Packet2d>(const Packet2d& a, const Packet2d& b) { return _mm_andnot_pd(a,b); } 00299 template<> EIGEN_STRONG_INLINE Packet4i pandnot<Packet4i>(const Packet4i& a, const Packet4i& b) { return _mm_andnot_si128(a,b); } 00300 00301 template<> EIGEN_STRONG_INLINE Packet4f pload<Packet4f>(const float* from) { EIGEN_DEBUG_ALIGNED_LOAD return _mm_load_ps(from); } 00302 template<> EIGEN_STRONG_INLINE Packet2d pload<Packet2d>(const double* from) { EIGEN_DEBUG_ALIGNED_LOAD return _mm_load_pd(from); } 00303 template<> EIGEN_STRONG_INLINE Packet4i pload<Packet4i>(const int* from) { EIGEN_DEBUG_ALIGNED_LOAD return _mm_load_si128(reinterpret_cast<const __m128i*>(from)); } 00304 00305 #if EIGEN_COMP_MSVC 00306 template<> EIGEN_STRONG_INLINE Packet4f ploadu<Packet4f>(const float* from) { 00307 EIGEN_DEBUG_UNALIGNED_LOAD 00308 #if (EIGEN_COMP_MSVC==1600) 00309 // NOTE Some version of MSVC10 generates bad code when using _mm_loadu_ps 00310 // (i.e., it does not generate an unaligned load!! 00311 __m128 res = _mm_loadl_pi(_mm_set1_ps(0.0f), (const __m64*)(from)); 00312 res = _mm_loadh_pi(res, (const __m64*)(from+2)); 00313 return res; 00314 #else 00315 return _mm_loadu_ps(from); 00316 #endif 00317 } 00318 #else 00319 // NOTE: with the code below, MSVC's compiler crashes! 00320 00321 template<> EIGEN_STRONG_INLINE Packet4f ploadu<Packet4f>(const float* from) 00322 { 00323 EIGEN_DEBUG_UNALIGNED_LOAD 00324 return _mm_loadu_ps(from); 00325 } 00326 #endif 00327 00328 template<> EIGEN_STRONG_INLINE Packet2d ploadu<Packet2d>(const double* from) 00329 { 00330 EIGEN_DEBUG_UNALIGNED_LOAD 00331 return _mm_loadu_pd(from); 00332 } 00333 template<> EIGEN_STRONG_INLINE Packet4i ploadu<Packet4i>(const int* from) 00334 { 00335 EIGEN_DEBUG_UNALIGNED_LOAD 00336 return _mm_loadu_si128(reinterpret_cast<const __m128i*>(from)); 00337 } 00338 00339 00340 template<> EIGEN_STRONG_INLINE Packet4f ploaddup<Packet4f>(const float* from) 00341 { 00342 return vec4f_swizzle1(_mm_castpd_ps(_mm_load_sd(reinterpret_cast<const double*>(from))), 0, 0, 1, 1); 00343 } 00344 template<> EIGEN_STRONG_INLINE Packet2d ploaddup<Packet2d>(const double* from) 00345 { return pset1<Packet2d>(from[0]); } 00346 template<> EIGEN_STRONG_INLINE Packet4i ploaddup<Packet4i>(const int* from) 00347 { 00348 Packet4i tmp; 00349 tmp = _mm_loadl_epi64(reinterpret_cast<const __m128i*>(from)); 00350 return vec4i_swizzle1(tmp, 0, 0, 1, 1); 00351 } 00352 00353 template<> EIGEN_STRONG_INLINE void pstore<float>(float* to, const Packet4f& from) { EIGEN_DEBUG_ALIGNED_STORE _mm_store_ps(to, from); } 00354 template<> EIGEN_STRONG_INLINE void pstore<double>(double* to, const Packet2d& from) { EIGEN_DEBUG_ALIGNED_STORE _mm_store_pd(to, from); } 00355 template<> EIGEN_STRONG_INLINE void pstore<int>(int* to, const Packet4i& from) { EIGEN_DEBUG_ALIGNED_STORE _mm_store_si128(reinterpret_cast<__m128i*>(to), from); } 00356 00357 template<> EIGEN_STRONG_INLINE void pstoreu<double>(double* to, const Packet2d& from) { EIGEN_DEBUG_UNALIGNED_STORE _mm_storeu_pd(to, from); } 00358 template<> EIGEN_STRONG_INLINE void pstoreu<float>(float* to, const Packet4f& from) { EIGEN_DEBUG_UNALIGNED_STORE _mm_storeu_ps(to, from); } 00359 template<> EIGEN_STRONG_INLINE void pstoreu<int>(int* to, const Packet4i& from) { EIGEN_DEBUG_UNALIGNED_STORE _mm_storeu_si128(reinterpret_cast<__m128i*>(to), from); } 00360 00361 template<> EIGEN_DEVICE_FUNC inline Packet4f pgather<float, Packet4f>(const float* from, Index stride) 00362 { 00363 return _mm_set_ps(from[3*stride], from[2*stride], from[1*stride], from[0*stride]); 00364 } 00365 template<> EIGEN_DEVICE_FUNC inline Packet2d pgather<double, Packet2d>(const double* from, Index stride) 00366 { 00367 return _mm_set_pd(from[1*stride], from[0*stride]); 00368 } 00369 template<> EIGEN_DEVICE_FUNC inline Packet4i pgather<int, Packet4i>(const int* from, Index stride) 00370 { 00371 return _mm_set_epi32(from[3*stride], from[2*stride], from[1*stride], from[0*stride]); 00372 } 00373 00374 template<> EIGEN_DEVICE_FUNC inline void pscatter<float, Packet4f>(float* to, const Packet4f& from, Index stride) 00375 { 00376 to[stride*0] = _mm_cvtss_f32(from); 00377 to[stride*1] = _mm_cvtss_f32(_mm_shuffle_ps(from, from, 1)); 00378 to[stride*2] = _mm_cvtss_f32(_mm_shuffle_ps(from, from, 2)); 00379 to[stride*3] = _mm_cvtss_f32(_mm_shuffle_ps(from, from, 3)); 00380 } 00381 template<> EIGEN_DEVICE_FUNC inline void pscatter<double, Packet2d>(double* to, const Packet2d& from, Index stride) 00382 { 00383 to[stride*0] = _mm_cvtsd_f64(from); 00384 to[stride*1] = _mm_cvtsd_f64(_mm_shuffle_pd(from, from, 1)); 00385 } 00386 template<> EIGEN_DEVICE_FUNC inline void pscatter<int, Packet4i>(int* to, const Packet4i& from, Index stride) 00387 { 00388 to[stride*0] = _mm_cvtsi128_si32(from); 00389 to[stride*1] = _mm_cvtsi128_si32(_mm_shuffle_epi32(from, 1)); 00390 to[stride*2] = _mm_cvtsi128_si32(_mm_shuffle_epi32(from, 2)); 00391 to[stride*3] = _mm_cvtsi128_si32(_mm_shuffle_epi32(from, 3)); 00392 } 00393 00394 // some compilers might be tempted to perform multiple moves instead of using a vector path. 00395 template<> EIGEN_STRONG_INLINE void pstore1<Packet4f>(float* to, const float& a) 00396 { 00397 Packet4f pa = _mm_set_ss(a); 00398 pstore(to, Packet4f(vec4f_swizzle1(pa,0,0,0,0))); 00399 } 00400 // some compilers might be tempted to perform multiple moves instead of using a vector path. 00401 template<> EIGEN_STRONG_INLINE void pstore1<Packet2d>(double* to, const double& a) 00402 { 00403 Packet2d pa = _mm_set_sd(a); 00404 pstore(to, Packet2d(vec2d_swizzle1(pa,0,0))); 00405 } 00406 00407 #ifndef EIGEN_VECTORIZE_AVX 00408 template<> EIGEN_STRONG_INLINE void prefetch<float>(const float* addr) { _mm_prefetch((const char*)(addr), _MM_HINT_T0); } 00409 template<> EIGEN_STRONG_INLINE void prefetch<double>(const double* addr) { _mm_prefetch((const char*)(addr), _MM_HINT_T0); } 00410 template<> EIGEN_STRONG_INLINE void prefetch<int>(const int* addr) { _mm_prefetch((const char*)(addr), _MM_HINT_T0); } 00411 #endif 00412 00413 #if EIGEN_COMP_MSVC_STRICT && EIGEN_OS_WIN64 00414 // The temporary variable fixes an internal compilation error in vs <= 2008 and a wrong-result bug in vs 2010 00415 // Direct of the struct members fixed bug #62. 00416 template<> EIGEN_STRONG_INLINE float pfirst<Packet4f>(const Packet4f& a) { return a.m128_f32[0]; } 00417 template<> EIGEN_STRONG_INLINE double pfirst<Packet2d>(const Packet2d& a) { return a.m128d_f64[0]; } 00418 template<> EIGEN_STRONG_INLINE int pfirst<Packet4i>(const Packet4i& a) { int x = _mm_cvtsi128_si32(a); return x; } 00419 #elif EIGEN_COMP_MSVC_STRICT 00420 // The temporary variable fixes an internal compilation error in vs <= 2008 and a wrong-result bug in vs 2010 00421 template<> EIGEN_STRONG_INLINE float pfirst<Packet4f>(const Packet4f& a) { float x = _mm_cvtss_f32(a); return x; } 00422 template<> EIGEN_STRONG_INLINE double pfirst<Packet2d>(const Packet2d& a) { double x = _mm_cvtsd_f64(a); return x; } 00423 template<> EIGEN_STRONG_INLINE int pfirst<Packet4i>(const Packet4i& a) { int x = _mm_cvtsi128_si32(a); return x; } 00424 #else 00425 template<> EIGEN_STRONG_INLINE float pfirst<Packet4f>(const Packet4f& a) { return _mm_cvtss_f32(a); } 00426 template<> EIGEN_STRONG_INLINE double pfirst<Packet2d>(const Packet2d& a) { return _mm_cvtsd_f64(a); } 00427 template<> EIGEN_STRONG_INLINE int pfirst<Packet4i>(const Packet4i& a) { return _mm_cvtsi128_si32(a); } 00428 #endif 00429 00430 template<> EIGEN_STRONG_INLINE Packet4f preverse(const Packet4f& a) 00431 { return _mm_shuffle_ps(a,a,0x1B); } 00432 template<> EIGEN_STRONG_INLINE Packet2d preverse(const Packet2d& a) 00433 { return _mm_shuffle_pd(a,a,0x1); } 00434 template<> EIGEN_STRONG_INLINE Packet4i preverse(const Packet4i& a) 00435 { return _mm_shuffle_epi32(a,0x1B); } 00436 00437 template<size_t offset> 00438 struct protate_impl<offset, Packet4f> 00439 { 00440 static Packet4f run(const Packet4f& a) { 00441 return vec4f_swizzle1(a, offset, (offset + 1) % 4, (offset + 2) % 4, (offset + 3) % 4); 00442 } 00443 }; 00444 00445 template<size_t offset> 00446 struct protate_impl<offset, Packet4i> 00447 { 00448 static Packet4i run(const Packet4i& a) { 00449 return vec4i_swizzle1(a, offset, (offset + 1) % 4, (offset + 2) % 4, (offset + 3) % 4); 00450 } 00451 }; 00452 00453 template<size_t offset> 00454 struct protate_impl<offset, Packet2d> 00455 { 00456 static Packet2d run(const Packet2d& a) { 00457 return vec2d_swizzle1(a, offset, (offset + 1) % 2); 00458 } 00459 }; 00460 00461 template<> EIGEN_STRONG_INLINE Packet4f pabs(const Packet4f& a) 00462 { 00463 const Packet4f mask = _mm_castsi128_ps(_mm_setr_epi32(0x7FFFFFFF,0x7FFFFFFF,0x7FFFFFFF,0x7FFFFFFF)); 00464 return _mm_and_ps(a,mask); 00465 } 00466 template<> EIGEN_STRONG_INLINE Packet2d pabs(const Packet2d& a) 00467 { 00468 const Packet2d mask = _mm_castsi128_pd(_mm_setr_epi32(0xFFFFFFFF,0x7FFFFFFF,0xFFFFFFFF,0x7FFFFFFF)); 00469 return _mm_and_pd(a,mask); 00470 } 00471 template<> EIGEN_STRONG_INLINE Packet4i pabs(const Packet4i& a) 00472 { 00473 #ifdef EIGEN_VECTORIZE_SSSE3 00474 return _mm_abs_epi32(a); 00475 #else 00476 Packet4i aux = _mm_srai_epi32(a,31); 00477 return _mm_sub_epi32(_mm_xor_si128(a,aux),aux); 00478 #endif 00479 } 00480 00481 // with AVX, the default implementations based on pload1 are faster 00482 #ifndef __AVX__ 00483 template<> EIGEN_STRONG_INLINE void 00484 pbroadcast4<Packet4f>(const float *a, 00485 Packet4f& a0, Packet4f& a1, Packet4f& a2, Packet4f& a3) 00486 { 00487 a3 = pload<Packet4f>(a); 00488 a0 = vec4f_swizzle1(a3, 0,0,0,0); 00489 a1 = vec4f_swizzle1(a3, 1,1,1,1); 00490 a2 = vec4f_swizzle1(a3, 2,2,2,2); 00491 a3 = vec4f_swizzle1(a3, 3,3,3,3); 00492 } 00493 template<> EIGEN_STRONG_INLINE void 00494 pbroadcast4<Packet2d>(const double *a, 00495 Packet2d& a0, Packet2d& a1, Packet2d& a2, Packet2d& a3) 00496 { 00497 #ifdef EIGEN_VECTORIZE_SSE3 00498 a0 = _mm_loaddup_pd(a+0); 00499 a1 = _mm_loaddup_pd(a+1); 00500 a2 = _mm_loaddup_pd(a+2); 00501 a3 = _mm_loaddup_pd(a+3); 00502 #else 00503 a1 = pload<Packet2d>(a); 00504 a0 = vec2d_swizzle1(a1, 0,0); 00505 a1 = vec2d_swizzle1(a1, 1,1); 00506 a3 = pload<Packet2d>(a+2); 00507 a2 = vec2d_swizzle1(a3, 0,0); 00508 a3 = vec2d_swizzle1(a3, 1,1); 00509 #endif 00510 } 00511 #endif 00512 00513 EIGEN_STRONG_INLINE void punpackp(Packet4f* vecs) 00514 { 00515 vecs[1] = _mm_castsi128_ps(_mm_shuffle_epi32(_mm_castps_si128(vecs[0]), 0x55)); 00516 vecs[2] = _mm_castsi128_ps(_mm_shuffle_epi32(_mm_castps_si128(vecs[0]), 0xAA)); 00517 vecs[3] = _mm_castsi128_ps(_mm_shuffle_epi32(_mm_castps_si128(vecs[0]), 0xFF)); 00518 vecs[0] = _mm_castsi128_ps(_mm_shuffle_epi32(_mm_castps_si128(vecs[0]), 0x00)); 00519 } 00520 00521 #ifdef EIGEN_VECTORIZE_SSE3 00522 template<> EIGEN_STRONG_INLINE Packet4f preduxp<Packet4f>(const Packet4f* vecs) 00523 { 00524 return _mm_hadd_ps(_mm_hadd_ps(vecs[0], vecs[1]),_mm_hadd_ps(vecs[2], vecs[3])); 00525 } 00526 template<> EIGEN_STRONG_INLINE Packet2d preduxp<Packet2d>(const Packet2d* vecs) 00527 { 00528 return _mm_hadd_pd(vecs[0], vecs[1]); 00529 } 00530 00531 template<> EIGEN_STRONG_INLINE float predux<Packet4f>(const Packet4f& a) 00532 { 00533 Packet4f tmp0 = _mm_hadd_ps(a,a); 00534 return pfirst<Packet4f>(_mm_hadd_ps(tmp0, tmp0)); 00535 } 00536 00537 template<> EIGEN_STRONG_INLINE double predux<Packet2d>(const Packet2d& a) { return pfirst<Packet2d>(_mm_hadd_pd(a, a)); } 00538 #else 00539 // SSE2 versions 00540 template<> EIGEN_STRONG_INLINE float predux<Packet4f>(const Packet4f& a) 00541 { 00542 Packet4f tmp = _mm_add_ps(a, _mm_movehl_ps(a,a)); 00543 return pfirst<Packet4f>(_mm_add_ss(tmp, _mm_shuffle_ps(tmp,tmp, 1))); 00544 } 00545 template<> EIGEN_STRONG_INLINE double predux<Packet2d>(const Packet2d& a) 00546 { 00547 return pfirst<Packet2d>(_mm_add_sd(a, _mm_unpackhi_pd(a,a))); 00548 } 00549 00550 template<> EIGEN_STRONG_INLINE Packet4f preduxp<Packet4f>(const Packet4f* vecs) 00551 { 00552 Packet4f tmp0, tmp1, tmp2; 00553 tmp0 = _mm_unpacklo_ps(vecs[0], vecs[1]); 00554 tmp1 = _mm_unpackhi_ps(vecs[0], vecs[1]); 00555 tmp2 = _mm_unpackhi_ps(vecs[2], vecs[3]); 00556 tmp0 = _mm_add_ps(tmp0, tmp1); 00557 tmp1 = _mm_unpacklo_ps(vecs[2], vecs[3]); 00558 tmp1 = _mm_add_ps(tmp1, tmp2); 00559 tmp2 = _mm_movehl_ps(tmp1, tmp0); 00560 tmp0 = _mm_movelh_ps(tmp0, tmp1); 00561 return _mm_add_ps(tmp0, tmp2); 00562 } 00563 00564 template<> EIGEN_STRONG_INLINE Packet2d preduxp<Packet2d>(const Packet2d* vecs) 00565 { 00566 return _mm_add_pd(_mm_unpacklo_pd(vecs[0], vecs[1]), _mm_unpackhi_pd(vecs[0], vecs[1])); 00567 } 00568 #endif // SSE3 00569 00570 00571 #ifdef EIGEN_VECTORIZE_SSSE3 00572 template<> EIGEN_STRONG_INLINE Packet4i preduxp<Packet4i>(const Packet4i* vecs) 00573 { 00574 return _mm_hadd_epi32(_mm_hadd_epi32(vecs[0], vecs[1]),_mm_hadd_epi32(vecs[2], vecs[3])); 00575 } 00576 template<> EIGEN_STRONG_INLINE int predux<Packet4i>(const Packet4i& a) 00577 { 00578 Packet4i tmp0 = _mm_hadd_epi32(a,a); 00579 return pfirst<Packet4i>(_mm_hadd_epi32(tmp0,tmp0)); 00580 } 00581 #else 00582 template<> EIGEN_STRONG_INLINE int predux<Packet4i>(const Packet4i& a) 00583 { 00584 Packet4i tmp = _mm_add_epi32(a, _mm_unpackhi_epi64(a,a)); 00585 return pfirst(tmp) + pfirst<Packet4i>(_mm_shuffle_epi32(tmp, 1)); 00586 } 00587 00588 template<> EIGEN_STRONG_INLINE Packet4i preduxp<Packet4i>(const Packet4i* vecs) 00589 { 00590 Packet4i tmp0, tmp1, tmp2; 00591 tmp0 = _mm_unpacklo_epi32(vecs[0], vecs[1]); 00592 tmp1 = _mm_unpackhi_epi32(vecs[0], vecs[1]); 00593 tmp2 = _mm_unpackhi_epi32(vecs[2], vecs[3]); 00594 tmp0 = _mm_add_epi32(tmp0, tmp1); 00595 tmp1 = _mm_unpacklo_epi32(vecs[2], vecs[3]); 00596 tmp1 = _mm_add_epi32(tmp1, tmp2); 00597 tmp2 = _mm_unpacklo_epi64(tmp0, tmp1); 00598 tmp0 = _mm_unpackhi_epi64(tmp0, tmp1); 00599 return _mm_add_epi32(tmp0, tmp2); 00600 } 00601 #endif 00602 // Other reduction functions: 00603 00604 // mul 00605 template<> EIGEN_STRONG_INLINE float predux_mul<Packet4f>(const Packet4f& a) 00606 { 00607 Packet4f tmp = _mm_mul_ps(a, _mm_movehl_ps(a,a)); 00608 return pfirst<Packet4f>(_mm_mul_ss(tmp, _mm_shuffle_ps(tmp,tmp, 1))); 00609 } 00610 template<> EIGEN_STRONG_INLINE double predux_mul<Packet2d>(const Packet2d& a) 00611 { 00612 return pfirst<Packet2d>(_mm_mul_sd(a, _mm_unpackhi_pd(a,a))); 00613 } 00614 template<> EIGEN_STRONG_INLINE int predux_mul<Packet4i>(const Packet4i& a) 00615 { 00616 // after some experiments, it is seems this is the fastest way to implement it 00617 // for GCC (eg., reusing pmul is very slow !) 00618 // TODO try to call _mm_mul_epu32 directly 00619 EIGEN_ALIGN16 int aux[4]; 00620 pstore(aux, a); 00621 return (aux[0] * aux[1]) * (aux[2] * aux[3]);; 00622 } 00623 00624 // min 00625 template<> EIGEN_STRONG_INLINE float predux_min<Packet4f>(const Packet4f& a) 00626 { 00627 Packet4f tmp = _mm_min_ps(a, _mm_movehl_ps(a,a)); 00628 return pfirst<Packet4f>(_mm_min_ss(tmp, _mm_shuffle_ps(tmp,tmp, 1))); 00629 } 00630 template<> EIGEN_STRONG_INLINE double predux_min<Packet2d>(const Packet2d& a) 00631 { 00632 return pfirst<Packet2d>(_mm_min_sd(a, _mm_unpackhi_pd(a,a))); 00633 } 00634 template<> EIGEN_STRONG_INLINE int predux_min<Packet4i>(const Packet4i& a) 00635 { 00636 #ifdef EIGEN_VECTORIZE_SSE4_1 00637 Packet4i tmp = _mm_min_epi32(a, _mm_shuffle_epi32(a, _MM_SHUFFLE(0,0,3,2))); 00638 return pfirst<Packet4i>(_mm_min_epi32(tmp,_mm_shuffle_epi32(tmp, 1))); 00639 #else 00640 // after some experiments, it is seems this is the fastest way to implement it 00641 // for GCC (eg., it does not like using std::min after the pstore !!) 00642 EIGEN_ALIGN16 int aux[4]; 00643 pstore(aux, a); 00644 int aux0 = aux[0]<aux[1] ? aux[0] : aux[1]; 00645 int aux2 = aux[2]<aux[3] ? aux[2] : aux[3]; 00646 return aux0<aux2 ? aux0 : aux2; 00647 #endif // EIGEN_VECTORIZE_SSE4_1 00648 } 00649 00650 // max 00651 template<> EIGEN_STRONG_INLINE float predux_max<Packet4f>(const Packet4f& a) 00652 { 00653 Packet4f tmp = _mm_max_ps(a, _mm_movehl_ps(a,a)); 00654 return pfirst<Packet4f>(_mm_max_ss(tmp, _mm_shuffle_ps(tmp,tmp, 1))); 00655 } 00656 template<> EIGEN_STRONG_INLINE double predux_max<Packet2d>(const Packet2d& a) 00657 { 00658 return pfirst<Packet2d>(_mm_max_sd(a, _mm_unpackhi_pd(a,a))); 00659 } 00660 template<> EIGEN_STRONG_INLINE int predux_max<Packet4i>(const Packet4i& a) 00661 { 00662 #ifdef EIGEN_VECTORIZE_SSE4_1 00663 Packet4i tmp = _mm_max_epi32(a, _mm_shuffle_epi32(a, _MM_SHUFFLE(0,0,3,2))); 00664 return pfirst<Packet4i>(_mm_max_epi32(tmp,_mm_shuffle_epi32(tmp, 1))); 00665 #else 00666 // after some experiments, it is seems this is the fastest way to implement it 00667 // for GCC (eg., it does not like using std::min after the pstore !!) 00668 EIGEN_ALIGN16 int aux[4]; 00669 pstore(aux, a); 00670 int aux0 = aux[0]>aux[1] ? aux[0] : aux[1]; 00671 int aux2 = aux[2]>aux[3] ? aux[2] : aux[3]; 00672 return aux0>aux2 ? aux0 : aux2; 00673 #endif // EIGEN_VECTORIZE_SSE4_1 00674 } 00675 00676 #if EIGEN_COMP_GNUC 00677 // template <> EIGEN_STRONG_INLINE Packet4f pmadd(const Packet4f& a, const Packet4f& b, const Packet4f& c) 00678 // { 00679 // Packet4f res = b; 00680 // asm("mulps %[a], %[b] \n\taddps %[c], %[b]" : [b] "+x" (res) : [a] "x" (a), [c] "x" (c)); 00681 // return res; 00682 // } 00683 // EIGEN_STRONG_INLINE Packet4i _mm_alignr_epi8(const Packet4i& a, const Packet4i& b, const int i) 00684 // { 00685 // Packet4i res = a; 00686 // asm("palignr %[i], %[a], %[b] " : [b] "+x" (res) : [a] "x" (a), [i] "i" (i)); 00687 // return res; 00688 // } 00689 #endif 00690 00691 #ifdef EIGEN_VECTORIZE_SSSE3 00692 // SSSE3 versions 00693 template<int Offset> 00694 struct palign_impl<Offset,Packet4f> 00695 { 00696 static EIGEN_STRONG_INLINE void run(Packet4f& first, const Packet4f& second) 00697 { 00698 if (Offset!=0) 00699 first = _mm_castsi128_ps(_mm_alignr_epi8(_mm_castps_si128(second), _mm_castps_si128(first), Offset*4)); 00700 } 00701 }; 00702 00703 template<int Offset> 00704 struct palign_impl<Offset,Packet4i> 00705 { 00706 static EIGEN_STRONG_INLINE void run(Packet4i& first, const Packet4i& second) 00707 { 00708 if (Offset!=0) 00709 first = _mm_alignr_epi8(second,first, Offset*4); 00710 } 00711 }; 00712 00713 template<int Offset> 00714 struct palign_impl<Offset,Packet2d> 00715 { 00716 static EIGEN_STRONG_INLINE void run(Packet2d& first, const Packet2d& second) 00717 { 00718 if (Offset==1) 00719 first = _mm_castsi128_pd(_mm_alignr_epi8(_mm_castpd_si128(second), _mm_castpd_si128(first), 8)); 00720 } 00721 }; 00722 #else 00723 // SSE2 versions 00724 template<int Offset> 00725 struct palign_impl<Offset,Packet4f> 00726 { 00727 static EIGEN_STRONG_INLINE void run(Packet4f& first, const Packet4f& second) 00728 { 00729 if (Offset==1) 00730 { 00731 first = _mm_move_ss(first,second); 00732 first = _mm_castsi128_ps(_mm_shuffle_epi32(_mm_castps_si128(first),0x39)); 00733 } 00734 else if (Offset==2) 00735 { 00736 first = _mm_movehl_ps(first,first); 00737 first = _mm_movelh_ps(first,second); 00738 } 00739 else if (Offset==3) 00740 { 00741 first = _mm_move_ss(first,second); 00742 first = _mm_shuffle_ps(first,second,0x93); 00743 } 00744 } 00745 }; 00746 00747 template<int Offset> 00748 struct palign_impl<Offset,Packet4i> 00749 { 00750 static EIGEN_STRONG_INLINE void run(Packet4i& first, const Packet4i& second) 00751 { 00752 if (Offset==1) 00753 { 00754 first = _mm_castps_si128(_mm_move_ss(_mm_castsi128_ps(first),_mm_castsi128_ps(second))); 00755 first = _mm_shuffle_epi32(first,0x39); 00756 } 00757 else if (Offset==2) 00758 { 00759 first = _mm_castps_si128(_mm_movehl_ps(_mm_castsi128_ps(first),_mm_castsi128_ps(first))); 00760 first = _mm_castps_si128(_mm_movelh_ps(_mm_castsi128_ps(first),_mm_castsi128_ps(second))); 00761 } 00762 else if (Offset==3) 00763 { 00764 first = _mm_castps_si128(_mm_move_ss(_mm_castsi128_ps(first),_mm_castsi128_ps(second))); 00765 first = _mm_castps_si128(_mm_shuffle_ps(_mm_castsi128_ps(first),_mm_castsi128_ps(second),0x93)); 00766 } 00767 } 00768 }; 00769 00770 template<int Offset> 00771 struct palign_impl<Offset,Packet2d> 00772 { 00773 static EIGEN_STRONG_INLINE void run(Packet2d& first, const Packet2d& second) 00774 { 00775 if (Offset==1) 00776 { 00777 first = _mm_castps_pd(_mm_movehl_ps(_mm_castpd_ps(first),_mm_castpd_ps(first))); 00778 first = _mm_castps_pd(_mm_movelh_ps(_mm_castpd_ps(first),_mm_castpd_ps(second))); 00779 } 00780 } 00781 }; 00782 #endif 00783 00784 EIGEN_DEVICE_FUNC inline void 00785 ptranspose(PacketBlock<Packet4f,4>& kernel) { 00786 _MM_TRANSPOSE4_PS(kernel.packet[0], kernel.packet[1], kernel.packet[2], kernel.packet[3]); 00787 } 00788 00789 EIGEN_DEVICE_FUNC inline void 00790 ptranspose(PacketBlock<Packet2d,2>& kernel) { 00791 __m128d tmp = _mm_unpackhi_pd(kernel.packet[0], kernel.packet[1]); 00792 kernel.packet[0] = _mm_unpacklo_pd(kernel.packet[0], kernel.packet[1]); 00793 kernel.packet[1] = tmp; 00794 } 00795 00796 EIGEN_DEVICE_FUNC inline void 00797 ptranspose(PacketBlock<Packet4i,4>& kernel) { 00798 __m128i T0 = _mm_unpacklo_epi32(kernel.packet[0], kernel.packet[1]); 00799 __m128i T1 = _mm_unpacklo_epi32(kernel.packet[2], kernel.packet[3]); 00800 __m128i T2 = _mm_unpackhi_epi32(kernel.packet[0], kernel.packet[1]); 00801 __m128i T3 = _mm_unpackhi_epi32(kernel.packet[2], kernel.packet[3]); 00802 00803 kernel.packet[0] = _mm_unpacklo_epi64(T0, T1); 00804 kernel.packet[1] = _mm_unpackhi_epi64(T0, T1); 00805 kernel.packet[2] = _mm_unpacklo_epi64(T2, T3); 00806 kernel.packet[3] = _mm_unpackhi_epi64(T2, T3); 00807 } 00808 00809 template<> EIGEN_STRONG_INLINE Packet4i pblend(const Selector<4>& ifPacket, const Packet4i& thenPacket, const Packet4i& elsePacket) { 00810 const __m128i zero = _mm_setzero_si128(); 00811 const __m128i select = _mm_set_epi32(ifPacket.select[3], ifPacket.select[2], ifPacket.select[1], ifPacket.select[0]); 00812 __m128i false_mask = _mm_cmpeq_epi32(select, zero); 00813 #ifdef EIGEN_VECTORIZE_SSE4_1 00814 return _mm_blendv_epi8(thenPacket, elsePacket, false_mask); 00815 #else 00816 return _mm_or_si128(_mm_andnot_si128(false_mask, thenPacket), _mm_and_si128(false_mask, elsePacket)); 00817 #endif 00818 } 00819 template<> EIGEN_STRONG_INLINE Packet4f pblend(const Selector<4>& ifPacket, const Packet4f& thenPacket, const Packet4f& elsePacket) { 00820 const __m128 zero = _mm_setzero_ps(); 00821 const __m128 select = _mm_set_ps(ifPacket.select[3], ifPacket.select[2], ifPacket.select[1], ifPacket.select[0]); 00822 __m128 false_mask = _mm_cmpeq_ps(select, zero); 00823 #ifdef EIGEN_VECTORIZE_SSE4_1 00824 return _mm_blendv_ps(thenPacket, elsePacket, false_mask); 00825 #else 00826 return _mm_or_ps(_mm_andnot_ps(false_mask, thenPacket), _mm_and_ps(false_mask, elsePacket)); 00827 #endif 00828 } 00829 template<> EIGEN_STRONG_INLINE Packet2d pblend(const Selector<2>& ifPacket, const Packet2d& thenPacket, const Packet2d& elsePacket) { 00830 const __m128d zero = _mm_setzero_pd(); 00831 const __m128d select = _mm_set_pd(ifPacket.select[1], ifPacket.select[0]); 00832 __m128d false_mask = _mm_cmpeq_pd(select, zero); 00833 #ifdef EIGEN_VECTORIZE_SSE4_1 00834 return _mm_blendv_pd(thenPacket, elsePacket, false_mask); 00835 #else 00836 return _mm_or_pd(_mm_andnot_pd(false_mask, thenPacket), _mm_and_pd(false_mask, elsePacket)); 00837 #endif 00838 } 00839 00840 } // end namespace internal 00841 00842 } // end namespace Eigen 00843 00844 #endif // EIGEN_PACKET_MATH_SSE_H
