MOAB: Mesh Oriented datABase
(version 5.4.0)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2009 Sandia National Laboratories. Developed at the 00005 University of Wisconsin--Madison under SNL contract number 00006 624796. The U.S. Government and the University of Wisconsin 00007 retain certain rights to this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 (2009) kraftche@cae.wisc.edu 00024 00025 ***************************************************************** */ 00026 00027 /** \file TMPDerivs.hpp 00028 * \brief Utility methods for calculating derivatives of TMP metrics 00029 * \author Jason Kraftcheck 00030 */ 00031 00032 #ifndef MSQ_TMP_DERIVS_HPP 00033 #define MSQ_TMP_DERIVS_HPP 00034 00035 #include "Mesquite.hpp" 00036 #include "MsqMatrix.hpp" 00037 00038 /** If defined, then \f$ (A \otimes B)_{i,j} = row(A,i)^t \otimes row(B,j) \f$ 00039 otherwise \f$ (A \otimes B)_{i,j} = column(A,i) \otimes column(B,j)^t \f$ 00040 */ 00041 #define MSQ_ROW_BASED_OUTER_PRODUCT 00042 00043 namespace MBMesquite 00044 { 00045 00046 /**\brief \f$ R *= s \f$ */ 00047 template < unsigned D > 00048 inline void hess_scale_t( MsqMatrix< D, D > R[D * ( D + 1 ) / 2], double alpha ); 00049 00050 inline void hess_scale( MsqMatrix< 3, 3 > R[6], double alpha ) 00051 { 00052 hess_scale_t< 3 >( R, alpha ); 00053 } 00054 00055 inline void hess_scale( MsqMatrix< 2, 2 > R[3], double alpha ) 00056 { 00057 hess_scale_t< 2 >( R, alpha ); 00058 } 00059 00060 /**\brief \f$ R = \alpha I_9 \f$ 00061 * 00062 *\param R The 6 blocks of the upper triangular portion of a 9x9 00063 * symmetric matrix. 00064 */ 00065 inline void set_scaled_I( MsqMatrix< 3, 3 > R[6], double alpha ); 00066 00067 /**\brief \f$ R += \alpha I_9 \f$ 00068 * 00069 *\param R The 6 blocks of the upper triangular portion of a 9x9 00070 * symmetric matrix. 00071 */ 00072 inline void pluseq_scaled_I( MsqMatrix< 3, 3 > R[6], double alpha ); 00073 00074 /**\brief \f$ R += \alpha I_9 \f$ 00075 * 00076 *\param R The 6 blocks of the upper triangular portion of a 9x9 00077 * symmetric matrix. 00078 */ 00079 inline void pluseq_scaled_I( MsqMatrix< 3, 3 >& R, double alpha ); 00080 00081 /**\brief \f$ R = \alpha I_4 \f$ 00082 * 00083 *\param R The 3 blocks of the upper triangular portion of a 4x4 00084 * symmetric matrix. 00085 */ 00086 inline void set_scaled_I( MsqMatrix< 2, 2 > R[3], double alpha ); 00087 00088 /**\brief \f$ R += \alpha I_4 \f$ 00089 * 00090 *\param R The 3 blocks of the upper triangular portion of a 4x4 00091 * symmetric matrix. 00092 */ 00093 inline void pluseq_scaled_I( MsqMatrix< 2, 2 > R[3], double alpha ); 00094 00095 /**\brief \f$ R += \alpha I_4 \f$ 00096 * 00097 *\param R The 3 blocks of the upper triangular portion of a 4x4 00098 * symmetric matrix. 00099 */ 00100 inline void pluseq_scaled_I( MsqMatrix< 2, 2 >& R, double alpha ); 00101 00102 /**\brief \f$ R += \alpha \frac{\partial}{\partial T}det(T) \f$ 00103 * 00104 *\param R The 6 blocks of the upper triangular portion of a 9x9 00105 * symmetric matrix. 00106 */ 00107 inline void pluseq_scaled_2nd_deriv_of_det( MsqMatrix< 3, 3 > R[6], double alpha, const MsqMatrix< 3, 3 >& T ); 00108 00109 /**\brief \f$ R += \alpha \frac{\partial}{\partial T}det(T) \f$ 00110 * 00111 *\param R The 3 blocks of the upper triangular portion of a 4x4 00112 * symmetric matrix. 00113 */ 00114 inline void pluseq_scaled_2nd_deriv_of_det( MsqMatrix< 2, 2 > R[3], double alpha ); 00115 inline void pluseq_scaled_2nd_deriv_of_det( MsqMatrix< 2, 2 > R[3], double alpha, const MsqMatrix< 2, 2 >& ) 00116 { 00117 pluseq_scaled_2nd_deriv_of_det( R, alpha ); 00118 } 00119 00120 /**\brief \f$ R = \alpha \frac{\partial}{\partial T}det(T) \f$ 00121 * 00122 *\param R The 6 blocks of the upper triangular portion of a 9x9 00123 * symmetric matrix. 00124 */ 00125 inline void set_scaled_2nd_deriv_of_det( MsqMatrix< 3, 3 > R[6], double alpha, const MsqMatrix< 3, 3 >& T ); 00126 00127 /**\brief \f$ R = \alpha \frac{\partial}{\partial T}det(T) \f$ 00128 * 00129 *\param R The 3 blocks of the upper triangular portion of a 4x4 00130 * symmetric matrix. 00131 */ 00132 inline void set_scaled_2nd_deriv_of_det( MsqMatrix< 2, 2 > R[3], double alpha ); 00133 inline void set_scaled_2nd_deriv_of_det( MsqMatrix< 2, 2 > R[3], double alpha, const MsqMatrix< 2, 2 >& ) 00134 { 00135 set_scaled_2nd_deriv_of_det( R, alpha ); 00136 } 00137 00138 /**\brief \f$ R += \alpha \frac{\partial^2}{\partial T^2}tr(adj T) \f$ 00139 * 00140 * Note: 2nd deriv is a constant, so T is not passed as an argument. 00141 */ 00142 inline void pluseq_scaled_2nd_deriv_tr_adj( MsqMatrix< 2, 2 > R[3], double alpha ); 00143 00144 /**\brief \f$ R += \alpha \frac{\partial^2}{\partial T^2}tr(adj T) \f$ 00145 * 00146 * Note: 2nd deriv is a constant, so T is not passed as an argument. 00147 */ 00148 inline void pluseq_scaled_2nd_deriv_tr_adj( MsqMatrix< 3, 3 > R[6], double alpha ); 00149 00150 /**\brief \f$ R += \alpha \frac{\partial^2}{\partial T^2}|adj T|^2 \f$ 00151 */ 00152 inline void set_scaled_2nd_deriv_norm_sqr_adj( MsqMatrix< 2, 2 > R[3], double alpha, const MsqMatrix< 2, 2 >& T ); 00153 00154 /**\brief \f$ R += \alpha \frac{\partial^2}{\partial T^2}|adj T|^2 \f$ 00155 */ 00156 inline void set_scaled_2nd_deriv_norm_sqr_adj( MsqMatrix< 3, 3 > R[6], double alpha, const MsqMatrix< 3, 3 >& T ); 00157 00158 /**\brief \f$ R += \alpha \left( M \otimes M \right) \f$ 00159 * 00160 *\param R The 6 blocks of the upper triangular portion of a 9x9 00161 * symmetric matrix. 00162 */ 00163 template < unsigned D > 00164 inline void pluseq_scaled_outer_product_t( MsqMatrix< D, D > R[D * ( D + 1 ) / 2], 00165 double alpha, 00166 const MsqMatrix< D, D >& M ); 00167 inline void pluseq_scaled_outer_product( MsqMatrix< 3, 3 > R[6], double alpha, const MsqMatrix< 3, 3 >& M ) 00168 { 00169 pluseq_scaled_outer_product_t< 3 >( R, alpha, M ); 00170 } 00171 00172 inline void pluseq_scaled_outer_product( MsqMatrix< 2, 2 > R[3], double alpha, const MsqMatrix< 2, 2 >& M ) 00173 { 00174 pluseq_scaled_outer_product_t< 2 >( R, alpha, M ); 00175 } 00176 00177 /**\brief \f$ R = \alpha \left( M \otimes M \right) \f$ 00178 * 00179 *\param R The 6 blocks of the upper triangular portion of a 9x9 00180 * symmetric matrix. 00181 */ 00182 template < unsigned D > 00183 inline void set_scaled_outer_product_t( MsqMatrix< D, D > R[D * ( D + 1 ) / 2], 00184 double alpha, 00185 const MsqMatrix< D, D >& M ); 00186 00187 inline void set_scaled_outer_product( MsqMatrix< 3, 3 > R[6], double alpha, const MsqMatrix< 3, 3 >& M ) 00188 { 00189 set_scaled_outer_product_t< 3 >( R, alpha, M ); 00190 } 00191 00192 inline void set_scaled_outer_product( MsqMatrix< 2, 2 > R[3], double alpha, const MsqMatrix< 2, 2 >& M ) 00193 { 00194 set_scaled_outer_product_t< 2 >( R, alpha, M ); 00195 } 00196 00197 /**\brief \f$ R += \alpha \left( A \otimes B + B \otimes A \right) \f$ 00198 * 00199 *\param R The 6 blocks of the upper triangular portion of a 9x9 00200 * symmetric matrix. 00201 */ 00202 inline void pluseq_scaled_sum_outer_product( MsqMatrix< 3, 3 > R[6], 00203 double alpha, 00204 const MsqMatrix< 3, 3 >& A, 00205 const MsqMatrix< 3, 3 >& B ); 00206 00207 /**\brief \f$ R += \alpha \left( A \otimes B + B \otimes A \right) \f$ 00208 * 00209 *\param R The 3 blocks of the upper triangular portion of a 4x4 00210 * symmetric matrix. 00211 */ 00212 inline void pluseq_scaled_sum_outer_product( MsqMatrix< 2, 2 > R[3], 00213 double alpha, 00214 const MsqMatrix< 2, 2 >& A, 00215 const MsqMatrix< 2, 2 >& B ); 00216 00217 /**\brief \f$ R = \alpha \left( A \otimes B + B \otimes A \right) \f$ 00218 * 00219 *\param R The 6 blocks of the upper triangular portion of a 9x9 00220 * symmetric matrix. 00221 */ 00222 inline void set_scaled_sum_outer_product( MsqMatrix< 3, 3 > R[6], 00223 double alpha, 00224 const MsqMatrix< 3, 3 >& A, 00225 const MsqMatrix< 3, 3 >& B ); 00226 00227 /**\brief \f$ R = \alpha \left( A \otimes B + B \otimes A \right) \f$ 00228 * 00229 *\param R The 3 blocks of the upper triangular portion of a 4x4 00230 * symmetric matrix. 00231 */ 00232 inline void set_scaled_sum_outer_product( MsqMatrix< 2, 2 > R[3], 00233 double alpha, 00234 const MsqMatrix< 2, 2 >& A, 00235 const MsqMatrix< 2, 2 >& B ); 00236 00237 /**\brief \f$ R += \alpha (I \otimes I) \f$ 00238 * 00239 *\param R The 6 blocks of the upper triangular portion of a 9x9 00240 * symmetric matrix. 00241 */ 00242 inline void pluseq_scaled_outer_product_I_I( MsqMatrix< 3, 3 > R[6], double alpha ); 00243 00244 /**\brief \f$ R += \alpha (I \otimes I) \f$ 00245 * 00246 *\param R The 3 blocks of the upper triangular portion of a 4x4 00247 * symmetric matrix. 00248 */ 00249 inline void pluseq_scaled_outer_product_I_I( MsqMatrix< 2, 2 > R[3], double alpha ); 00250 00251 /**\brief \f$ R += I \otimes A \f$ 00252 * 00253 *\param R The 6 blocks of the upper triangular portion of a 9x9 00254 * symmetric matrix. 00255 */ 00256 inline void pluseq_I_outer_product( MsqMatrix< 3, 3 > R[6], const MsqMatrix< 3, 3 >& A ); 00257 00258 /**\brief \f$ R += A \otimes I \f$ 00259 * 00260 *\param R The 6 blocks of the upper triangular portion of a 9x9 00261 * symmetric matrix. 00262 */ 00263 inline void pluseq_outer_product_I( MsqMatrix< 3, 3 > R[6], const MsqMatrix< 3, 3 >& A ); 00264 00265 /**\brief \f$ R += \alpha \left( I \otimes A + A \otimes I \right) \f$ 00266 * 00267 *\param R The 6 blocks of the upper triangular portion of a 9x9 00268 * symmetric matrix. 00269 */ 00270 template < unsigned D > 00271 inline void pluseq_scaled_sum_outer_product_I_t( MsqMatrix< D, D > R[D * ( D + 1 ) / 2], 00272 double alpha, 00273 const MsqMatrix< D, D >& A ); 00274 inline void pluseq_scaled_sum_outer_product_I( MsqMatrix< 3, 3 > R[6], double alpha, const MsqMatrix< 3, 3 >& A_in ) 00275 { 00276 pluseq_scaled_sum_outer_product_I_t< 3 >( R, alpha, A_in ); 00277 } 00278 00279 inline void pluseq_scaled_sum_outer_product_I( MsqMatrix< 2, 2 > R[2], double alpha, const MsqMatrix< 2, 2 >& A_in ) 00280 { 00281 pluseq_scaled_sum_outer_product_I_t< 2 >( R, alpha, A_in ); 00282 } 00283 00284 /**\brief \f$ \frac{\partial^2 f}{\partial (AZ)^2} \Rightarrow \frac{\partial^2 f}{\partial A^2} \f$ 00285 * 00286 * Given the second derivatives of a function with respect to 00287 * a matrix product, calculate the derivatives of the function 00288 * with respect to the first matrix in the product. 00289 */ 00290 template < unsigned D > 00291 inline void second_deriv_wrt_product_factor_t( MsqMatrix< D, D > R[D * ( D + 1 ) / 2], const MsqMatrix< D, D >& Z ); 00292 00293 inline void second_deriv_wrt_product_factor( MsqMatrix< 3, 3 > R[6], const MsqMatrix< 3, 3 >& Z ) 00294 { 00295 second_deriv_wrt_product_factor_t< 3 >( R, Z ); 00296 } 00297 00298 inline void second_deriv_wrt_product_factor( MsqMatrix< 2, 2 > R[3], const MsqMatrix< 2, 2 >& Z ) 00299 { 00300 second_deriv_wrt_product_factor_t< 2 >( R, Z ); 00301 } 00302 00303 /**\brief \f$ R = \alpha * \frac{\partial^2 \psi(T)}{\partial T^2} \f$ 00304 * 00305 * \f$ \psi(T) = \sqrt{ |T|^2 + 2 \tau } \f$ 00306 */ 00307 inline void set_scaled_2nd_deriv_wrt_psi( MsqMatrix< 2, 2 > R[3], 00308 const double alpha, 00309 const double psi, 00310 const MsqMatrix< 2, 2 >& T ); 00311 00312 /**\brief \f$ R = R + \alpha * Z \f$ 00313 */ 00314 template < unsigned D > 00315 inline void pluseq_scaled_t( MsqMatrix< D, D > R[D * ( D + 1 ) / 2], 00316 double alpha, 00317 const MsqMatrix< D, D > Z[D * ( D + 1 ) / 2] ); 00318 00319 void set_scaled_I( MsqMatrix< 3, 3 > R[6], double alpha ) 00320 { 00321 R[0] = R[3] = R[5] = MsqMatrix< 3, 3 >( alpha ); 00322 R[1] = R[2] = R[4] = MsqMatrix< 3, 3 >( 0.0 ); 00323 } 00324 00325 void pluseq_scaled_I( MsqMatrix< 3, 3 >& R, double alpha ) 00326 { 00327 R( 0, 0 ) += alpha; 00328 R( 1, 1 ) += alpha; 00329 R( 2, 2 ) += alpha; 00330 } 00331 00332 void pluseq_scaled_I( MsqMatrix< 2, 2 >& R, double alpha ) 00333 { 00334 R( 0, 0 ) += alpha; 00335 R( 1, 1 ) += alpha; 00336 } 00337 00338 void pluseq_scaled_I( MsqMatrix< 3, 3 > R[6], double alpha ) 00339 { 00340 pluseq_scaled_I( R[0], alpha ); 00341 pluseq_scaled_I( R[3], alpha ); 00342 pluseq_scaled_I( R[5], alpha ); 00343 } 00344 00345 void set_scaled_I( MsqMatrix< 2, 2 > R[3], double alpha ) 00346 { 00347 R[0] = R[2] = MsqMatrix< 2, 2 >( alpha ); 00348 R[1] = MsqMatrix< 2, 2 >( 0.0 ); 00349 } 00350 00351 void pluseq_scaled_I( MsqMatrix< 2, 2 > R[3], double alpha ) 00352 { 00353 pluseq_scaled_I( R[0], alpha ); 00354 pluseq_scaled_I( R[2], alpha ); 00355 } 00356 00357 void pluseq_scaled_2nd_deriv_of_det( MsqMatrix< 3, 3 > R[6], double alpha, const MsqMatrix< 3, 3 >& T ) 00358 { 00359 MsqMatrix< 3, 3 > A( T ); 00360 A *= alpha; 00361 00362 R[1]( 0, 1 ) += A( 2, 2 ); 00363 R[1]( 1, 0 ) -= A( 2, 2 ); 00364 R[1]( 0, 2 ) -= A( 2, 1 ); 00365 R[1]( 2, 0 ) += A( 2, 1 ); 00366 R[1]( 1, 2 ) += A( 2, 0 ); 00367 R[1]( 2, 1 ) -= A( 2, 0 ); 00368 00369 R[2]( 0, 1 ) -= A( 1, 2 ); 00370 R[2]( 1, 0 ) += A( 1, 2 ); 00371 R[2]( 0, 2 ) += A( 1, 1 ); 00372 R[2]( 2, 0 ) -= A( 1, 1 ); 00373 R[2]( 1, 2 ) -= A( 1, 0 ); 00374 R[2]( 2, 1 ) += A( 1, 0 ); 00375 00376 R[4]( 0, 1 ) += A( 0, 2 ); 00377 R[4]( 1, 0 ) -= A( 0, 2 ); 00378 R[4]( 0, 2 ) -= A( 0, 1 ); 00379 R[4]( 2, 0 ) += A( 0, 1 ); 00380 R[4]( 1, 2 ) += A( 0, 0 ); 00381 R[4]( 2, 1 ) -= A( 0, 0 ); 00382 } 00383 00384 void set_scaled_2nd_deriv_of_det( MsqMatrix< 3, 3 > R[6], double alpha, const MsqMatrix< 3, 3 >& T ) 00385 { 00386 MsqMatrix< 3, 3 > A( T ); 00387 A *= alpha; 00388 00389 R[0] = R[3] = R[5] = MsqMatrix< 3, 3 >( 0.0 ); 00390 00391 R[1]( 0, 0 ) = R[1]( 1, 1 ) = R[1]( 2, 2 ) = 0; 00392 R[1]( 0, 1 ) = A( 2, 2 ); 00393 R[1]( 1, 0 ) = -A( 2, 2 ); 00394 R[1]( 0, 2 ) = -A( 2, 1 ); 00395 R[1]( 2, 0 ) = A( 2, 1 ); 00396 R[1]( 1, 2 ) = A( 2, 0 ); 00397 R[1]( 2, 1 ) = -A( 2, 0 ); 00398 00399 R[2]( 0, 0 ) = R[2]( 1, 1 ) = R[2]( 2, 2 ) = 0; 00400 R[2]( 0, 1 ) = -A( 1, 2 ); 00401 R[2]( 1, 0 ) = A( 1, 2 ); 00402 R[2]( 0, 2 ) = A( 1, 1 ); 00403 R[2]( 2, 0 ) = -A( 1, 1 ); 00404 R[2]( 1, 2 ) = -A( 1, 0 ); 00405 R[2]( 2, 1 ) = A( 1, 0 ); 00406 00407 R[4]( 0, 0 ) = R[4]( 1, 1 ) = R[4]( 2, 2 ) = 0; 00408 R[4]( 0, 1 ) = A( 0, 2 ); 00409 R[4]( 1, 0 ) = -A( 0, 2 ); 00410 R[4]( 0, 2 ) = -A( 0, 1 ); 00411 R[4]( 2, 0 ) = A( 0, 1 ); 00412 R[4]( 1, 2 ) = A( 0, 0 ); 00413 R[4]( 2, 1 ) = -A( 0, 0 ); 00414 } 00415 00416 void pluseq_scaled_2nd_deriv_of_det( MsqMatrix< 2, 2 > R[3], double alpha ) 00417 { 00418 R[1]( 0, 1 ) += alpha; 00419 R[1]( 1, 0 ) -= alpha; 00420 } 00421 00422 void set_scaled_2nd_deriv_of_det( MsqMatrix< 2, 2 > R[3], double alpha ) 00423 { 00424 R[0] = R[2] = MsqMatrix< 2, 2 >( 0.0 ); 00425 R[1]( 0, 0 ) = 0.0; 00426 R[1]( 0, 1 ) = alpha; 00427 R[1]( 1, 0 ) = -alpha; 00428 R[1]( 1, 1 ) = 0.0; 00429 } 00430 00431 void pluseq_scaled_2nd_deriv_tr_adj( MsqMatrix< 2, 2 >*, double ) 00432 { 00433 // 2nd derivative is zero 00434 } 00435 00436 void pluseq_scaled_2nd_deriv_tr_adj( MsqMatrix< 3, 3 > R[6], double alpha ) 00437 { 00438 R[1]( 0, 1 ) += alpha; 00439 R[1]( 1, 0 ) -= alpha; 00440 R[2]( 0, 2 ) += alpha; 00441 R[2]( 2, 0 ) -= alpha; 00442 R[4]( 1, 2 ) += alpha; 00443 R[4]( 2, 1 ) -= alpha; 00444 } 00445 00446 void set_scaled_2nd_deriv_norm_sqr_adj( MsqMatrix< 2, 2 > R[3], double alpha, const MsqMatrix< 2, 2 >& ) 00447 { 00448 set_scaled_I( R, 2 * alpha ); 00449 } 00450 00451 void set_scaled_2nd_deriv_norm_sqr_adj( MsqMatrix< 3, 3 > R[6], double alpha, const MsqMatrix< 3, 3 >& T ) 00452 { 00453 set_scaled_outer_product( R, 1, T ); 00454 double tmp01, tmp02, tmp12; 00455 // R[1] = 2*R[1] - transpose(R[1]); 00456 tmp01 = R[1]( 0, 1 ); 00457 tmp02 = R[1]( 0, 2 ); 00458 tmp12 = R[1]( 1, 2 ); 00459 R[1]( 0, 1 ) = 2 * R[1]( 0, 1 ) - R[1]( 1, 0 ); 00460 R[1]( 0, 2 ) = 2 * R[1]( 0, 2 ) - R[1]( 2, 0 ); 00461 R[1]( 1, 2 ) = 2 * R[1]( 1, 2 ) - R[1]( 2, 1 ); 00462 R[1]( 1, 0 ) = 2 * R[1]( 1, 0 ) - tmp01; 00463 R[1]( 2, 0 ) = 2 * R[1]( 2, 0 ) - tmp02; 00464 R[1]( 2, 1 ) = 2 * R[1]( 2, 1 ) - tmp12; 00465 // R[2] = 2*R[2] - transpose(R[1]); 00466 tmp01 = R[2]( 0, 1 ); 00467 tmp02 = R[2]( 0, 2 ); 00468 tmp12 = R[2]( 1, 2 ); 00469 R[2]( 0, 1 ) = 2 * R[2]( 0, 1 ) - R[2]( 1, 0 ); 00470 R[2]( 0, 2 ) = 2 * R[2]( 0, 2 ) - R[2]( 2, 0 ); 00471 R[2]( 1, 2 ) = 2 * R[2]( 1, 2 ) - R[2]( 2, 1 ); 00472 R[2]( 1, 0 ) = 2 * R[2]( 1, 0 ) - tmp01; 00473 R[2]( 2, 0 ) = 2 * R[2]( 2, 0 ) - tmp02; 00474 R[2]( 2, 1 ) = 2 * R[2]( 2, 1 ) - tmp12; 00475 // R[4] = 2*R[4] - transpose(R[1]); 00476 tmp01 = R[4]( 0, 1 ); 00477 tmp02 = R[4]( 0, 2 ); 00478 tmp12 = R[4]( 1, 2 ); 00479 R[4]( 0, 1 ) = 2 * R[4]( 0, 1 ) - R[4]( 1, 0 ); 00480 R[4]( 0, 2 ) = 2 * R[4]( 0, 2 ) - R[4]( 2, 0 ); 00481 R[4]( 1, 2 ) = 2 * R[4]( 1, 2 ) - R[4]( 2, 1 ); 00482 R[4]( 1, 0 ) = 2 * R[4]( 1, 0 ) - tmp01; 00483 R[4]( 2, 0 ) = 2 * R[4]( 2, 0 ) - tmp02; 00484 R[4]( 2, 1 ) = 2 * R[4]( 2, 1 ) - tmp12; 00485 00486 const MsqMatrix< 3, 3 > TpT = transpose( T ) * T; 00487 R[0] -= TpT; 00488 R[3] -= TpT; 00489 R[5] -= TpT; 00490 00491 const MsqMatrix< 3, 3 > TTp = T * transpose( T ); 00492 const double ns = sqr_Frobenius( T ); 00493 R[0]( 0, 0 ) += ns - TTp( 0, 0 ); 00494 R[0]( 1, 1 ) += ns - TTp( 0, 0 ); 00495 R[0]( 2, 2 ) += ns - TTp( 0, 0 ); 00496 R[1]( 0, 0 ) += -TTp( 0, 1 ); 00497 R[1]( 1, 1 ) += -TTp( 0, 1 ); 00498 R[1]( 2, 2 ) += -TTp( 0, 1 ); 00499 R[2]( 0, 0 ) += -TTp( 0, 2 ); 00500 R[2]( 1, 1 ) += -TTp( 0, 2 ); 00501 R[2]( 2, 2 ) += -TTp( 0, 2 ); 00502 R[3]( 0, 0 ) += ns - TTp( 1, 1 ); 00503 R[3]( 1, 1 ) += ns - TTp( 1, 1 ); 00504 R[3]( 2, 2 ) += ns - TTp( 1, 1 ); 00505 R[4]( 0, 0 ) += -TTp( 1, 2 ); 00506 R[4]( 1, 1 ) += -TTp( 1, 2 ); 00507 R[4]( 2, 2 ) += -TTp( 1, 2 ); 00508 R[5]( 0, 0 ) += ns - TTp( 2, 2 ); 00509 R[5]( 1, 1 ) += ns - TTp( 2, 2 ); 00510 R[5]( 2, 2 ) += ns - TTp( 2, 2 ); 00511 00512 alpha *= 2; 00513 R[0] *= alpha; 00514 R[1] *= alpha; 00515 R[2] *= alpha; 00516 R[3] *= alpha; 00517 R[4] *= alpha; 00518 R[5] *= alpha; 00519 } 00520 00521 #ifdef MSQ_ROW_BASED_OUTER_PRODUCT 00522 template < unsigned D > 00523 void pluseq_scaled_outer_product_t( MsqMatrix< D, D > R[D * ( D + 1 ) / 2], double alpha, const MsqMatrix< D, D >& M ) 00524 { 00525 MsqMatrix< D, D > aM( M ); 00526 aM *= alpha; 00527 unsigned h = 0; 00528 for( unsigned i = 0; i < D; ++i ) 00529 for( unsigned j = i; j < D; ++j ) 00530 R[h++] += transpose( aM.row( i ) ) * M.row( j ); 00531 } 00532 #else 00533 template < unsigned D > 00534 void pluseq_scaled_outer_product_t( MsqMatrix< D, D > R[D * ( D + 1 ) / 2], double alpha, const MsqMatrix< D, D >& M ) 00535 { 00536 MsqMatrix< D, D > aM( transpose( M ) ); 00537 aM *= alpha; 00538 unsigned h = 0; 00539 for( unsigned i = 0; i < D; ++i ) 00540 for( unsigned j = i; j < D; ++j ) 00541 R[h++] += M.column( i ) * aM.row( 0 ); 00542 } 00543 #endif 00544 00545 #ifdef MSQ_ROW_BASED_OUTER_PRODUCT 00546 template < unsigned D > 00547 void set_scaled_outer_product_t( MsqMatrix< D, D > R[D * ( D + 1 ) / 2], double alpha, const MsqMatrix< D, D >& M ) 00548 { 00549 MsqMatrix< D, D > aM( M ); 00550 aM *= alpha; 00551 unsigned h = 0; 00552 for( unsigned i = 0; i < D; ++i ) 00553 for( unsigned j = i; j < D; ++j ) 00554 R[h++] = transpose( aM.row( i ) ) * M.row( j ); 00555 } 00556 #else 00557 template < unsigned D > 00558 void set_scaled_outer_product_t( MsqMatrix< D, D > R[D * ( D + 1 ) / 2], double alpha, const MsqMatrix< D, D >& M ) 00559 { 00560 MsqMatrix< D, D > aM( transpose( M ) ); 00561 aM *= alpha; 00562 unsigned h = 0; 00563 for( unsigned i = 0; i < D; ++i ) 00564 for( unsigned j = i; j < D; ++j ) 00565 R[h++] = M.column( i ) * aM.row( j ); 00566 } 00567 #endif 00568 00569 #ifdef MSQ_ROW_BASED_OUTER_PRODUCT 00570 void pluseq_scaled_sum_outer_product( MsqMatrix< 3, 3 > R[6], 00571 double alpha, 00572 const MsqMatrix< 3, 3 >& A_in, 00573 const MsqMatrix< 3, 3 >& B ) 00574 { 00575 // apply scalar first 00576 MsqMatrix< 3, 3 > A( A_in ), tmp; 00577 A *= alpha; 00578 00579 // block 0,0 00580 tmp = transpose( A.row( 0 ) ) * B.row( 0 ); 00581 R[0] += tmp; 00582 R[0] += transpose( tmp ); 00583 00584 // block 1,1 00585 tmp = transpose( A.row( 1 ) ) * B.row( 1 ); 00586 R[3] += tmp; 00587 R[3] += transpose( tmp ); 00588 00589 // block 2,2 00590 tmp = transpose( A.row( 2 ) ) * B.row( 2 ); 00591 R[5] += tmp; 00592 R[5] += transpose( tmp ); 00593 00594 // block 0,1 00595 R[1] += transpose( A.row( 0 ) ) * B.row( 1 ) + transpose( B.row( 0 ) ) * A.row( 1 ); 00596 00597 // block 0,2 00598 R[2] += transpose( A.row( 0 ) ) * B.row( 2 ) + transpose( B.row( 0 ) ) * A.row( 2 ); 00599 00600 // block 1,2 00601 R[4] += transpose( A.row( 1 ) ) * B.row( 2 ) + transpose( B.row( 1 ) ) * A.row( 2 ); 00602 } 00603 void set_scaled_sum_outer_product( MsqMatrix< 3, 3 > R[6], 00604 double alpha, 00605 const MsqMatrix< 3, 3 >& A_in, 00606 const MsqMatrix< 3, 3 >& B ) 00607 { 00608 // apply scalar first 00609 MsqMatrix< 3, 3 > A( A_in ); 00610 A *= alpha; 00611 00612 // block 0,0 00613 R[0] = transpose( A.row( 0 ) ) * B.row( 0 ); 00614 R[0] += transpose( R[0] ); 00615 00616 // block 1,1 00617 R[3] = transpose( A.row( 1 ) ) * B.row( 1 ); 00618 R[3] += transpose( R[3] ); 00619 00620 // block 2,2 00621 R[5] = transpose( A.row( 2 ) ) * B.row( 2 ); 00622 R[5] += transpose( R[5] ); 00623 00624 // block 0,1 00625 R[1] = transpose( A.row( 0 ) ) * B.row( 1 ); 00626 R[1] += transpose( B.row( 0 ) ) * A.row( 1 ); 00627 00628 // block 0,2 00629 R[2] = transpose( A.row( 0 ) ) * B.row( 2 ); 00630 R[2] += transpose( B.row( 0 ) ) * A.row( 2 ); 00631 00632 // block 1,2 00633 R[4] = transpose( A.row( 1 ) ) * B.row( 2 ); 00634 R[4] += transpose( B.row( 1 ) ) * A.row( 2 ); 00635 } 00636 #else 00637 void pluseq_scaled_sum_outer_product( MsqMatrix< 3, 3 > R[6], 00638 double alpha, 00639 const MsqMatrix< 3, 3 >& A_in, 00640 const MsqMatrix< 3, 3 >& B ) 00641 { 00642 // apply scalar first 00643 MsqMatrix< 3, 3 > A( A_in ), tmp; 00644 A *= alpha; 00645 00646 // block 0,0 00647 tmp = A.column( 0 ) * transpose( B.column( 0 ) ); 00648 R[0] += tmp; 00649 R[0] += transpose( tmp ); 00650 00651 // block 1,1 00652 tmp = A.column( 1 ) * transpose( B.column( 1 ) ); 00653 R[3] += tmp; 00654 R[3] += transpose( tmp ); 00655 00656 // block 2,2 00657 tmp = A.column( 2 ) * transpose( B.column( 2 ) ); 00658 R[5] += tmp; 00659 R[5] += transpose( tmp ); 00660 00661 // block 0,1 00662 R[1] += A.column( 0 ) * transpose( B.column( 1 ) ) + B.column( 0 ) * transpose( A.column( 1 ) ); 00663 00664 // block 0,2 00665 R[2] += A.column( 0 ) * transpose( B.column( 2 ) ) + B.column( 0 ) * transpose( A.column( 2 ) ); 00666 00667 // block 1,2 00668 R[4] += A.column( 1 ) * transpose( B.column( 2 ) ) + B.column( 1 ) * transpose( A.column( 2 ) ); 00669 } 00670 void set_scaled_sum_outer_product( MsqMatrix< 3, 3 > R[6], 00671 double alpha, 00672 const MsqMatrix< 3, 3 >& A_in, 00673 const MsqMatrix< 3, 3 >& B ) 00674 { 00675 // apply scalar first 00676 MsqMatrix< 3, 3 > A( A_in ); 00677 A *= alpha; 00678 00679 // block 0,0 00680 R[0] = A.column( 0 ) * transpose( B.column( 0 ) ); 00681 R[0] += transpose( R[0] ); 00682 00683 // block 1,1 00684 R[3] = A.column( 1 ) * transpose( B.column( 1 ) ); 00685 R[3] += transpose( R[3] ); 00686 00687 // block 2,2 00688 R[5] = A.column( 2 ) * transpose( B.column( 2 ) ); 00689 R[5] += transpose( R[5] ); 00690 00691 // block 0,1 00692 R[1] = A.column( 0 ) * transpose( B.column( 1 ) ); 00693 R[1] += B.column( 0 ) * transpose( A.column( 1 ) ); 00694 00695 // block 0,2 00696 R[2] = A.column( 0 ) * transpose( B.column( 2 ) ); 00697 R[2] += B.column( 0 ) * transpose( A.column( 2 ) ); 00698 00699 // block 1,2 00700 R[4] = A.column( 1 ) * transpose( B.column( 2 ) ); 00701 R[4] += B.column( 1 ) * transpose( A.column( 2 ) ); 00702 } 00703 #endif 00704 00705 #ifdef MSQ_ROW_BASED_OUTER_PRODUCT 00706 void pluseq_scaled_sum_outer_product( MsqMatrix< 2, 2 > R[3], 00707 double alpha, 00708 const MsqMatrix< 2, 2 >& A_in, 00709 const MsqMatrix< 2, 2 >& B ) 00710 { 00711 // apply scalar first 00712 MsqMatrix< 2, 2 > A( A_in ), tmp; 00713 A *= alpha; 00714 00715 // block 0,0 00716 tmp = transpose( A.row( 0 ) ) * B.row( 0 ); 00717 R[0] += tmp; 00718 R[0] += transpose( tmp ); 00719 00720 // block 1,1 00721 tmp = transpose( A.row( 1 ) ) * B.row( 1 ); 00722 R[2] += tmp; 00723 R[2] += transpose( tmp ); 00724 00725 // block 0,1 00726 R[1] += transpose( A.row( 0 ) ) * B.row( 1 ) + transpose( B.row( 0 ) ) * A.row( 1 ); 00727 } 00728 void set_scaled_sum_outer_product( MsqMatrix< 2, 2 > R[3], 00729 double alpha, 00730 const MsqMatrix< 2, 2 >& A_in, 00731 const MsqMatrix< 2, 2 >& B ) 00732 { 00733 // apply scalar first 00734 MsqMatrix< 2, 2 > A( A_in ); 00735 A *= alpha; 00736 00737 // block 0,0 00738 R[0] = transpose( A.row( 0 ) ) * B.row( 0 ); 00739 R[0] += transpose( R[0] ); 00740 00741 // block 1,1 00742 R[2] = transpose( A.row( 1 ) ) * B.row( 1 ); 00743 R[2] += transpose( R[2] ); 00744 00745 // block 0,1 00746 R[1] = transpose( A.row( 0 ) ) * B.row( 1 ); 00747 R[1] += transpose( B.row( 0 ) ) * A.row( 1 ); 00748 } 00749 #else 00750 void pluseq_scaled_sum_outer_product( MsqMatrix< 2, 2 > R[3], 00751 double alpha, 00752 const MsqMatrix< 2, 2 >& A_in, 00753 const MsqMatrix< 2, 2 >& B ) 00754 { 00755 // apply scalar first 00756 MsqMatrix< 2, 2 > A( A_in ), tmp; 00757 A *= alpha; 00758 00759 // block 0,0 00760 tmp = A.column( 0 ) * transpose( B.column( 0 ) ); 00761 R[0] += tmp; 00762 R[0] += transpose( tmp ); 00763 00764 // block 1,1 00765 tmp = A.column( 1 ) * transpose( B.column( 1 ) ); 00766 R[2] += tmp; 00767 R[2] += transpose( tmp ); 00768 00769 // block 0,1 00770 R[1] += A.column( 0 ) * transpose( B.column( 1 ) ) + B.column( 0 ) * transpose( A.column( 1 ) ); 00771 } 00772 void set_scaled_sum_outer_product( MsqMatrix< 2, 2 > R[3], 00773 double alpha, 00774 const MsqMatrix< 2, 2 >& A_in, 00775 const MsqMatrix< 2, 2 >& B ) 00776 { 00777 // apply scalar first 00778 MsqMatrix< 2, 2 > A( A_in ); 00779 A *= alpha; 00780 00781 // block 0,0 00782 R[0] = A.column( 0 ) * transpose( B.column( 0 ) ); 00783 R[0] += transpose( R[0] ); 00784 00785 // block 1,1 00786 R[2] = A.column( 1 ) * transpose( B.column( 1 ) ); 00787 R[2] += transpose( R[2] ); 00788 00789 // block 0,1 00790 R[1] = A.column( 0 ) * transpose( B.column( 1 ) ); 00791 R[1] += B.column( 0 ) * transpose( A.column( 1 ) ); 00792 } 00793 #endif 00794 00795 void pluseq_scaled_outer_product_I_I( MsqMatrix< 3, 3 > R[6], double alpha ) 00796 { 00797 R[0]( 0, 0 ) += alpha; 00798 R[1]( 0, 1 ) += alpha; 00799 R[2]( 0, 2 ) += alpha; 00800 R[3]( 1, 1 ) += alpha; 00801 R[4]( 1, 2 ) += alpha; 00802 R[5]( 2, 2 ) += alpha; 00803 } 00804 00805 void pluseq_scaled_outer_product_I_I( MsqMatrix< 2, 2 > R[3], double alpha ) 00806 { 00807 R[0]( 0, 0 ) += alpha; 00808 R[1]( 0, 1 ) += alpha; 00809 R[2]( 1, 1 ) += alpha; 00810 } 00811 00812 #ifdef MSQ_ROW_BASED_OUTER_PRODUCT 00813 inline void pluseq_I_outer_product( MsqMatrix< 3, 3 > R[6], const MsqMatrix< 3, 3 >& A ) 00814 { 00815 R[0].add_row( 0, A.row( 0 ) ); 00816 R[1].add_row( 0, A.row( 1 ) ); 00817 R[2].add_row( 0, A.row( 2 ) ); 00818 R[3].add_row( 1, A.row( 1 ) ); 00819 R[4].add_row( 1, A.row( 2 ) ); 00820 R[5].add_row( 2, A.row( 2 ) ); 00821 } 00822 inline void pluseq_I_outer_product( MsqMatrix< 2, 2 > R[3], const MsqMatrix< 2, 2 >& A ) 00823 { 00824 R[0].add_row( 0, A.row( 0 ) ); 00825 R[1].add_row( 0, A.row( 1 ) ); 00826 R[2].add_row( 1, A.row( 1 ) ); 00827 } 00828 #else 00829 inline void pluseq_I_outer_product( MsqMatrix< 3, 3 > R[6], const MsqMatrix< 3, 3 >& A ) 00830 { 00831 R[0].add_row( 0, transpose( A.column( 0 ) ) ); 00832 R[1].add_row( 0, transpose( A.column( 1 ) ) ); 00833 R[2].add_row( 0, transpose( A.column( 2 ) ) ); 00834 R[3].add_row( 1, transpose( A.column( 1 ) ) ); 00835 R[4].add_row( 1, transpose( A.column( 2 ) ) ); 00836 R[5].add_row( 2, transpose( A.column( 2 ) ) ); 00837 } 00838 inline void pluseq_I_outer_product( MsqMatrix< 2, 2 > R[3], const MsqMatrix< 2, 2 >& A ) 00839 { 00840 R[0].add_row( 0, transpose( A.column( 0 ) ) ); 00841 R[1].add_row( 0, transpose( A.column( 1 ) ) ); 00842 R[2].add_row( 1, transpose( A.column( 1 ) ) ); 00843 } 00844 #endif 00845 00846 #ifdef MSQ_ROW_BASED_OUTER_PRODUCT 00847 inline void pluseq_outer_product_I( MsqMatrix< 3, 3 > R[6], const MsqMatrix< 3, 3 >& A ) 00848 { 00849 R[0].add_column( 0, transpose( A.row( 0 ) ) ); 00850 R[1].add_column( 1, transpose( A.row( 0 ) ) ); 00851 R[2].add_column( 2, transpose( A.row( 0 ) ) ); 00852 R[3].add_column( 1, transpose( A.row( 1 ) ) ); 00853 R[4].add_column( 2, transpose( A.row( 1 ) ) ); 00854 R[5].add_column( 2, transpose( A.row( 2 ) ) ); 00855 } 00856 inline void pluseq_outer_product_I( MsqMatrix< 2, 2 > R[3], const MsqMatrix< 2, 2 >& A ) 00857 { 00858 R[0].add_column( 0, transpose( A.row( 0 ) ) ); 00859 R[1].add_column( 1, transpose( A.row( 0 ) ) ); 00860 R[2].add_column( 1, transpose( A.row( 1 ) ) ); 00861 } 00862 #else 00863 inline void pluseq_outer_product_I( MsqMatrix< 3, 3 > R[6], const MsqMatrix< 3, 3 >& A ) 00864 { 00865 R[0].add_column( 0, A.column( 0 ) ); 00866 R[1].add_column( 1, A.column( 0 ) ); 00867 R[2].add_column( 2, A.column( 0 ) ); 00868 R[3].add_column( 1, A.column( 1 ) ); 00869 R[4].add_column( 2, A.column( 1 ) ); 00870 R[5].add_column( 2, A.column( 2 ) ); 00871 } 00872 inline void pluseq_outer_product_I( MsqMatrix< 2, 2 > R[3], const MsqMatrix< 2, 2 >& A ) 00873 { 00874 R[0].add_column( 0, A.column( 0 ) ); 00875 R[1].add_column( 1, A.column( 0 ) ); 00876 R[2].add_column( 1, A.column( 1 ) ); 00877 } 00878 #endif 00879 00880 template < unsigned D > 00881 void pluseq_scaled_sum_outer_product_I_t( MsqMatrix< D, D > R[D * ( D + 1 ) / 2], 00882 double alpha, 00883 const MsqMatrix< D, D >& A_in ) 00884 { 00885 // apply scalar first 00886 MsqMatrix< D, D > A( A_in ); 00887 A *= alpha; 00888 pluseq_I_outer_product( R, A ); 00889 pluseq_outer_product_I( R, A ); 00890 } 00891 00892 template < unsigned D > 00893 void second_deriv_wrt_product_factor_t( MsqMatrix< D, D > R[D * ( D + 1 ) / 2], const MsqMatrix< D, D >& Z ) 00894 { 00895 const MsqMatrix< D, D > Zt = transpose( Z ); 00896 for( unsigned i = 0; i < D * ( D + 1 ) / 2; ++i ) 00897 R[i] = ( Z * R[i] ) * Zt; 00898 } 00899 00900 void set_scaled_2nd_deriv_wrt_psi( MsqMatrix< 2, 2 > R[3], 00901 const double alpha, 00902 const double psi, 00903 const MsqMatrix< 2, 2 >& T ) 00904 { 00905 const double t = trace( T ); 00906 const double f = alpha / ( psi * psi * psi ); 00907 const double s = T( 0, 1 ) - T( 1, 0 ); 00908 R[0]( 0, 0 ) = R[1]( 0, 1 ) = R[2]( 1, 1 ) = f * s * s; 00909 R[0]( 0, 1 ) = R[0]( 1, 0 ) = R[1]( 1, 1 ) = -f * s * t; 00910 R[1]( 0, 0 ) = R[2]( 0, 1 ) = R[2]( 1, 0 ) = f * s * t; 00911 R[0]( 1, 1 ) = R[2]( 0, 0 ) = -( R[1]( 1, 0 ) = -f * t * t ); 00912 } 00913 00914 template < unsigned D > 00915 inline void pluseq_scaled( MsqMatrix< D, D > R[D * ( D + 1 ) / 2], 00916 double alpha, 00917 const MsqMatrix< D, D > Z[D * ( D + 1 ) / 2] ) 00918 { 00919 for( unsigned i = 0; i < D * ( D + 1 ) / 2; ++i ) 00920 R[i] += alpha * Z[i]; 00921 } 00922 00923 /**\brief \f$ R *= s */ 00924 template < unsigned D > 00925 inline void hess_scale_t( MsqMatrix< D, D > R[D * ( D + 1 ) / 2], double alpha ) 00926 { 00927 for( unsigned i = 0; i < D * ( D + 1 ) / 2; ++i ) 00928 R[i] *= alpha; 00929 } 00930 00931 } // namespace MBMesquite 00932 00933 #endif
