TShapeSize2DB2.cpp
00001 /* *****************************************************************
00002     MESQUITE -- The Mesh Quality Improvement Toolkit
00003
00004     Copyright 2006 Sandia National Laboratories.  Developed at the
00005     University of Wisconsin--Madison under SNL contract number
00006     624796.  The U.S. Government and the University of Wisconsin
00007     retain certain rights to this software.
00008
00009     This library is free software; you can redistribute it and/or
00010     modify it under the terms of the GNU Lesser General Public
00011     License as published by the Free Software Foundation; either
00012     version 2.1 of the License, or (at your option) any later version.
00013
00014     This library is distributed in the hope that it will be useful,
00015     but WITHOUT ANY WARRANTY; without even the implied warranty of
00016     MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00017     Lesser General Public License for more details.
00018
00019     You should have received a copy of the GNU Lesser General Public License
00020     (lgpl.txt) along with this library; if not, write to the Free Software
00021     Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
00022
00023     (2006) kraftche@cae.wisc.edu
00024
00025   ***************************************************************** */
00026
00027 /** \file TShapeSize2DB2.cpp
00028  *  \brief
00029  *  \author Jason Kraftcheck
00030  */
00031
00032 #include "Mesquite.hpp"
00033 #include "TShapeSize2DB2.hpp"
00034 #include "MsqMatrix.hpp"
00035 #include "MsqError.hpp"
00036 #include "TMPDerivs.hpp"
00037
00038 #include <iostream>
00039
00040 namespace MBMesquite
00041 {
00042
00043 std::string TShapeSize2DB2::get_name() const
00044 {
00045     return "TShapeSize2DB2";
00046 }
00047
00048 TShapeSize2DB2::~TShapeSize2DB2() {}
00049
00050 bool TShapeSize2DB2::evaluate( const MsqMatrix< 2, 2 >& T, double& result, MsqError& err )
00051 {
00052     const double two_det = 2.0 * det( T );
00053     if( invalid_determinant( two_det ) )
00054     {  // barrier
00055         MSQ_SETERR( err )( barrier_violated_msg, MsqError::BARRIER_VIOLATED );
00056         return false;
00057     }
00058
00059     const double frob_sqr = sqr_Frobenius( T );
00060     result                = ( frob_sqr - 2.0 * sqrt( frob_sqr + two_det ) + 2.0 ) / two_det;
00061     return true;
00062 }
00063
00064 bool TShapeSize2DB2::evaluate_with_grad( const MsqMatrix< 2, 2 >& T,
00065                                          double& result,
00066                                          MsqMatrix< 2, 2 >& deriv_wrt_T,
00067                                          MsqError& err )
00068 {
00069     const double d = det( T );
00070     if( invalid_determinant( d ) )
00071     {  // barrier
00072         MSQ_SETERR( err )( barrier_violated_msg, MsqError::BARRIER_VIOLATED );
00073         return false;
00074     }
00075     const double frob_sqr = sqr_Frobenius( T );
00076     const double psi      = sqrt( frob_sqr + 2.0 * det( T ) );
00077     const double v        = frob_sqr - 2.0 * psi + 2.0;
00078     result                = v / ( 2 * d );
00079
00080     // deriv of V wrt T
00081     MsqMatrix< 2, 2 > adjt = transpose_adj( T );
00082     MsqMatrix< 2, 2 > v_wrt_T( T );
00083     if( psi > 1e-50 )
00084     {
00085         v_wrt_T *= ( 1.0 - 1.0 / psi );
00086         v_wrt_T -= 1.0 / psi * adjt;
00087         v_wrt_T *= 2;
00088     }
00089     else
00090     {
00091         std::cout << "Warning: Division by zero avoided in TShapeSize2DB2::evaluate_with_grad()" << std::endl;
00092     }
00093
00094     // deriv of mu wrt T
00095     deriv_wrt_T = v_wrt_T;
00096     deriv_wrt_T *= 0.5 / d;
00097     deriv_wrt_T -= v / ( 2 * d * d ) * adjt;
00098
00099     return true;
00100 }
00101
00102 bool TShapeSize2DB2::evaluate_with_hess( const MsqMatrix< 2, 2 >& T,
00103                                          double& result,
00104                                          MsqMatrix< 2, 2 >& deriv_wrt_T,
00105                                          MsqMatrix< 2, 2 > second[3],
00106                                          MsqError& err )
00107 {
00108     const double d = det( T );
00109     if( invalid_determinant( d ) )
00110     {  // barrier
00111         MSQ_SETERR( err )( barrier_violated_msg, MsqError::BARRIER_VIOLATED );
00112         return false;
00113     }
00114     const double frob_sqr = sqr_Frobenius( T );
00115     const double psi      = sqrt( frob_sqr + 2.0 * det( T ) );
00116     const double v        = frob_sqr - 2.0 * psi + 2.0;
00117     result                = v / ( 2 * d );
00118
00119     // deriv of V wrt T
00120     MsqMatrix< 2, 2 > adjt = transpose_adj( T );
00121     MsqMatrix< 2, 2 > v_wrt_T( T );
00122     if( psi > 1e-50 )
00123     {
00124         v_wrt_T *= ( 1.0 - 1.0 / psi );
00125         v_wrt_T -= 1.0 / psi * adjt;
00126         v_wrt_T *= 2;
00127     }
00128     else
00129     {
00130         std::cout << "Warning: Division by zero avoided in TShapeSize2DB2::evaluate_with_hess()" << std::endl;
00131     }
00132
00133     // deriv of mu wrt T
00134     deriv_wrt_T = v_wrt_T;
00135     deriv_wrt_T *= 0.5 / d;
00136     deriv_wrt_T -= v / ( 2 * d * d ) * adjt;
00137
00138     // second of V wrt T
00139     const double s    = T( 0, 1 ) - T( 1, 0 );
00140     const double tr   = trace( T );
00141     const double f    = -2.0 / ( psi * psi * psi );
00142     second[0]( 0, 0 ) = second[1]( 0, 1 ) = second[2]( 1, 1 ) = f * s * s;
00143     second[0]( 0, 1 ) = second[0]( 1, 0 ) = second[1]( 1, 1 ) = -f * s * tr;
00144     second[1]( 0, 0 ) = second[2]( 0, 1 ) = second[2]( 1, 0 ) = f * s * tr;
00145     second[0]( 1, 1 ) = second[2]( 0, 0 ) = -( second[1]( 1, 0 ) = -f * tr * tr );
00146     pluseq_scaled_I( second, 2 );
00147
00148     // second of mu wrt T
00149     const double x = 1.0 / ( 2 * d );
00150     second[0] *= x;
00151     second[1] *= x;
00152     second[2] *= x;
00153     pluseq_scaled_2nd_deriv_of_det( second, v / ( -2 * d * d ) );
00154     pluseq_scaled_outer_product( second, v / ( d * d * d ), adjt );
00155     pluseq_scaled_sum_outer_product( second, -1 / ( 2 * d * d ), v_wrt_T, adjt );
00156
00157     return true;
00158 }
00159
00160 }  // namespace MBMesquite
