MOAB: Mesh Oriented datABase
(version 5.4.1)
00001 #ifndef WRITE_HDF5_PARALLEL_HPP 00002 #define WRITE_HDF5_PARALLEL_HPP 00003 00004 #include "WriteHDF5.hpp" 00005 #include <H5Spublic.h> 00006 #include <map> 00007 00008 namespace moab 00009 { 00010 00011 struct RemoteSetData; 00012 class ParallelComm; 00013 class IODebugTrack; 00014 00015 /** 00016 * \brief Write MOAB HDF5 file in parallel. 00017 * \author Jason Kraftcheck 00018 * \data 22 July 2004 00019 */ 00020 class WriteHDF5Parallel : public WriteHDF5 00021 { 00022 public: 00023 static WriterIface* factory( Interface* ); 00024 00025 /** Consturctor 00026 */ 00027 WriteHDF5Parallel( Interface* iface ); 00028 00029 virtual ~WriteHDF5Parallel(); 00030 00031 protected: 00032 virtual void debug_barrier_line( int lineno ); 00033 00034 virtual void print_times( const double* times ) const; 00035 00036 //! Called by normal (non-parallel) writer. Sets up 00037 //! necessary data for parallel write. 00038 virtual ErrorCode parallel_create_file( const char* filename, 00039 bool overwrite, 00040 const std::vector< std::string >& qa_records, 00041 const FileOptions& opts, 00042 const Tag* user_tag_list = 0, 00043 int user_tag_count = 0, 00044 int dimension = 3, 00045 double* times = 0 ); 00046 00047 //! Figure out which mesh local mesh is duplicated on 00048 //! remote processors and which processor will write 00049 //! that mesh. 00050 //!\param non_local_ents Output list of entities that are not to 00051 //! be written by this processor but are 00052 //! referenced by other entities that are 00053 //! to be written. 00054 ErrorCode gather_interface_meshes( Range& non_local_ents ); 00055 00056 //! For entities that will be written by another 00057 //! processor but are referenced by entities on this 00058 //! processor, get the file Ids that will be assigned 00059 //! to those so they can be referenced by 00060 //! entities to be written on this processor. 00061 //!\param non_local_ents List of entities that are not to 00062 //! be written by this processor but are 00063 //! referenced by other entities that are 00064 //! to be written. 00065 ErrorCode exchange_file_ids( const Range& non_local_ents ); 00066 00067 //! Get remote ids for shared sets 00068 ErrorCode communicate_shared_set_ids( const Range& owned, const Range& remote ); 00069 00070 //! Pack set data for communication. 00071 //! 00072 //! If set_data_length is insufficient for the set data, 00073 //! the length entries at indices 1, 2, and 3 of set_data 00074 //! will be set with the necessary lengths, but no data will 00075 //! be written to set_data beyond that. 00076 ErrorCode pack_set( Range::const_iterator set, unsigned long* set_data, size_t set_data_length ); 00077 00078 //! Unpack set data from communication 00079 ErrorCode unpack_set( EntityHandle set, const unsigned long* set_data, size_t set_data_length ); 00080 00081 //! Communicate set contents between processors such that each 00082 //! owner knows the contents, parents, & child lists from all 00083 //! processors that have a copy of the set. 00084 ErrorCode communicate_shared_set_data( const Range& owned, const Range& remote ); 00085 00086 //! Create the node table in the file. 00087 ErrorCode create_node_table( int dimension ); 00088 00089 //! Communicate with other processors to negotiate 00090 //! the types of elements that will be written 00091 //! (the union of the types defined on each proc.) 00092 ErrorCode negotiate_type_list(); 00093 00094 //! Create tables to hold element connectivity 00095 ErrorCode create_element_tables(); 00096 00097 //! Create tables to hold element adjacencies. 00098 ErrorCode create_adjacency_tables(); 00099 00100 //! Create tables for mesh sets 00101 ErrorCode create_meshset_tables( double* times ); 00102 00103 //! Write tag descriptions and create tables to hold tag data. 00104 ErrorCode create_tag_tables(); 00105 00106 //! Remove any remote mesh entities from the passed range. 00107 void remove_remote_entities( EntityHandle relative, Range& range ); 00108 void remove_remote_entities( EntityHandle relative, std::vector< EntityHandle >& vect ); 00109 void remove_remote_sets( EntityHandle relative, Range& range ); 00110 void remove_remote_sets( EntityHandle relative, std::vector< EntityHandle >& vect ); 00111 00112 //! get any existing tags which aren't excluded and add to shared set tags 00113 ErrorCode get_sharedset_tags(); 00114 00115 ErrorCode append_serial_tag_data( std::vector< unsigned char >& buffer, const WriteHDF5::TagDesc& tag ); 00116 00117 //! helper function for create_tag_tables 00118 ErrorCode check_serial_tag_data( const std::vector< unsigned char >& buffer, 00119 std::vector< TagDesc* >* missing = 0, 00120 std::vector< TagDesc* >* newlist = 0 ); 00121 00122 /**\brief Argument ot create_dataset */ 00123 struct DataSetCreator 00124 { 00125 virtual ErrorCode operator()( WriteHDF5* writer, 00126 long data_set_size, 00127 const ExportSet* group, 00128 long& start_id_out ) const = 0; 00129 }; 00130 struct NoopDescCreator : public DataSetCreator 00131 { 00132 ErrorCode operator()( WriteHDF5*, long, const ExportSet*, long& start_id ) const 00133 { 00134 start_id = -1; 00135 return MB_SUCCESS; 00136 } 00137 }; 00138 00139 /**\brief Do typical communication for dataset creation 00140 * 00141 * Given the number of entities each processor intends to write, 00142 * do necessary communication and create dataset on root, passing 00143 * back misc info to each proc. 00144 * 00145 *\param creator Functor to do actual dataset creation. Used 00146 * only on root process. 00147 *\param num_datasets The number of datasets to create. 00148 *\param groups Third argument passed to DataSetCreator. 00149 * Array of length \c num_datasets pr NULL. 00150 *\param num_owned_entities The number of entities this proc will write. 00151 * Array of length \c num_datasets . 00152 *\param offsets_out Output: The offset in the dataset at which 00153 * this process should write. 00154 * Array of length \c num_datasets . 00155 *\param max_proc_ents_out Output: The maximun number of entities that 00156 * any proc will write 00157 * Array of length \c num_datasets . 00158 *\param total_ents_out Output: The size of the created dataset (sum 00159 * of counts over all procs) 00160 * Array of length \c num_datasets . 00161 *\param first_ids_out Output: The first ID of the first entity in the 00162 * data set. First ID for this proc's entities is 00163 * first_id_out+offset_out 00164 * Array of length \c num_datasets or NULL. 00165 */ 00166 ErrorCode create_dataset( int num_datasets, 00167 const long* num_owned_entities, 00168 long* offsets_out, 00169 long* max_proc_ents_out, 00170 long* total_ents_out, 00171 const DataSetCreator& creator = NoopDescCreator(), 00172 ExportSet* groups[] = 0, 00173 wid_t* first_ids_out = NULL ); 00174 00175 void print_shared_sets(); 00176 void print_set_sharing_data( const Range& range, const char* label, Tag idt ); 00177 00178 private: 00179 //! pcomm controlling parallel nature of mesh 00180 ParallelComm* myPcomm; 00181 00182 //! whether this instance allocated (and dtor should delete) the pcomm 00183 bool pcommAllocated; 00184 00185 //! Operation to use to append hyperslab selections 00186 H5S_seloper_t hslabOp; 00187 }; 00188 00189 } // namespace moab 00190 00191 #endif
