MOAB
4.9.3pre
A general Cholesky factorization and solver based on Cholmod. More...
#include <CholmodSupport.h>
Public Types | |
| typedef _MatrixType | MatrixType |
Public Member Functions | |
| CholmodDecomposition () | |
| CholmodDecomposition (const MatrixType &matrix) | |
| ~CholmodDecomposition () | |
| void | setMode (CholmodMode mode) |
Protected Member Functions | |
| void | init () |
Private Types | |
| typedef CholmodBase < _MatrixType, _UpLo, CholmodDecomposition > | Base |
This class allows to solve for A.X = B sparse linear problems via a LL^T or LDL^T Cholesky factorization using the Cholmod library. The sparse matrix A must be selfadjoint and positive definite. The vectors or matrices X and B can be either dense or sparse.
This variant permits to change the underlying Cholesky method at runtime. On the other hand, it does not provide access to the result of the factorization. The default is to let Cholmod automatically choose between a simplicial and supernodal factorization.
| _MatrixType | the type of the sparse matrix A, it must be a SparseMatrix<> |
| _UpLo | the triangular part that will be used for the computations. It can be Lower or Upper. Default is Lower. |
This class supports all kind of SparseMatrix<>: row or column major; upper, lower, or both; compressed or non compressed.
Definition at line 561 of file CholmodSupport.h.
typedef CholmodBase<_MatrixType, _UpLo, CholmodDecomposition> Eigen::CholmodDecomposition< _MatrixType, _UpLo >::Base [private] |
Reimplemented from Eigen::CholmodBase< _MatrixType, _UpLo, CholmodDecomposition< _MatrixType, _UpLo > >.
Definition at line 563 of file CholmodSupport.h.
| typedef _MatrixType Eigen::CholmodDecomposition< _MatrixType, _UpLo >::MatrixType |
Definition at line 568 of file CholmodSupport.h.
| Eigen::CholmodDecomposition< _MatrixType, _UpLo >::CholmodDecomposition | ( | ) | [inline] |
Definition at line 570 of file CholmodSupport.h.
| Eigen::CholmodDecomposition< _MatrixType, _UpLo >::CholmodDecomposition | ( | const MatrixType & | matrix | ) | [inline] |
Definition at line 572 of file CholmodSupport.h.
| Eigen::CholmodDecomposition< _MatrixType, _UpLo >::~CholmodDecomposition | ( | ) | [inline] |
Definition at line 578 of file CholmodSupport.h.
| void Eigen::CholmodDecomposition< _MatrixType, _UpLo >::init | ( | ) | [inline, protected] |
Definition at line 606 of file CholmodSupport.h.
| void Eigen::CholmodDecomposition< _MatrixType, _UpLo >::setMode | ( | CholmodMode | mode | ) | [inline] |
Definition at line 580 of file CholmodSupport.h.
switch(mode)
case CholmodAuto:
m_cholmod.final_asis = 1;
m_cholmod.supernodal = CHOLMOD_AUTO;
break;
case CholmodSimplicialLLt:
m_cholmod.final_asis = 0;
m_cholmod.supernodal = CHOLMOD_SIMPLICIAL;
m_cholmod.final_ll = 1;
break;
case CholmodSupernodalLLt:
m_cholmod.supernodal = CHOLMOD_SUPERNODAL;
break;
case CholmodLDLt:
break;
default:
break;
