MOAB
4.9.3pre
#include <MetisSupport.h>
Public Types | |
| typedef PermutationMatrix < Dynamic, Dynamic, StorageIndex > | PermutationType |
| typedef Matrix< StorageIndex, Dynamic, 1 > | IndexVector |
Public Member Functions | |
| template<typename MatrixType > | |
| void | get_symmetrized_graph (const MatrixType &A) |
| void | operator() (const MatrixType &A, PermutationType &matperm) |
Protected Attributes | |
| IndexVector | m_indexPtr |
| IndexVector | m_innerIndices |
Get the fill-reducing ordering from the METIS package
If A is the original matrix and Ap is the permuted matrix, the fill-reducing permutation is defined as follows : Row (column) i of A is the matperm(i) row (column) of Ap. WARNING: As computed by METIS, this corresponds to the vector iperm (instead of perm)
Definition at line 22 of file MetisSupport.h.
| typedef Matrix<StorageIndex,Dynamic,1> Eigen::MetisOrdering< StorageIndex >::IndexVector |
Definition at line 26 of file MetisSupport.h.
| typedef PermutationMatrix<Dynamic,Dynamic,StorageIndex> Eigen::MetisOrdering< StorageIndex >::PermutationType |
Definition at line 25 of file MetisSupport.h.
| void Eigen::MetisOrdering< StorageIndex >::get_symmetrized_graph | ( | const MatrixType & | A | ) | [inline] |
Definition at line 29 of file MetisSupport.h.
Index m = A.cols();
eigen_assert((A.rows() == A.cols()) && "ONLY FOR SQUARED MATRICES");
// Get the transpose of the input matrix
MatrixType At = A.transpose();
// Get the number of nonzeros elements in each row/col of At+A
Index TotNz = 0;
IndexVector visited(m);
visited.setConstant(-1);
for (StorageIndex j = 0; j < m; j++)
// Compute the union structure of of A(j,:) and At(j,:)
visited(j) = j; // Do not include the diagonal element
// Get the nonzeros in row/column j of A
for (typename MatrixType::InnerIterator it(A, j); it; ++it)
Index idx = it.index(); // Get the row index (for column major) or column index (for row major)
if (visited(idx) != j )
visited(idx) = j;
++TotNz;
//Get the nonzeros in row/column j of At
for (typename MatrixType::InnerIterator it(At, j); it; ++it)
if(visited(idx) != j)
visited(idx) = j;
++TotNz;
// Reserve place for A + At
m_indexPtr.resize(m+1);
m_innerIndices.resize(TotNz);
// Now compute the real adjacency list of each column/row
StorageIndex CurNz = 0;
m_indexPtr(j) = CurNz;
// Add the pattern of row/column j of A to A+At
for (typename MatrixType::InnerIterator it(A,j); it; ++it)
StorageIndex idx = it.index(); // Get the row index (for column major) or column index (for row major)
visited(idx) = j;
m_innerIndices(CurNz) = idx;
CurNz++;
//Add the pattern of row/column j of At to A+At
visited(idx) = j;
++CurNz;
m_indexPtr(m) = CurNz;
| void Eigen::MetisOrdering< StorageIndex >::operator() | ( | const MatrixType & | A, |
| PermutationType & | matperm | ||
| ) | [inline] |
Definition at line 103 of file MetisSupport.h.
StorageIndex m = internal::convert_index<StorageIndex>(A.cols()); // must be StorageIndex, because it is passed by address to METIS
IndexVector perm(m),iperm(m);
// First, symmetrize the matrix graph.
get_symmetrized_graph(A);
int output_error;
// Call the fill-reducing routine from METIS
output_error = METIS_NodeND(&m, m_indexPtr.data(), m_innerIndices.data(), NULL, NULL, perm.data(), iperm.data());
if(output_error != METIS_OK)
//FIXME The ordering interface should define a class of possible errors
std::cerr << "ERROR WHILE CALLING THE METIS PACKAGE \n";
return;
// Get the fill-reducing permutation
//NOTE: If Ap is the permuted matrix then perm and iperm vectors are defined as follows
// Row (column) i of Ap is the perm(i) row(column) of A, and row (column) i of A is the iperm(i) row(column) of Ap
matperm.resize(m);
for (int j = 0; j < m; j++)
matperm.indices()(iperm(j)) = j;
IndexVector Eigen::MetisOrdering< StorageIndex >::m_indexPtr [protected] |
Definition at line 132 of file MetisSupport.h.
IndexVector Eigen::MetisOrdering< StorageIndex >::m_innerIndices [protected] |
Definition at line 133 of file MetisSupport.h.
