MOAB
4.9.3pre
Expression of the multiple replication of a matrix or vector. More...
#include <Replicate.h>
Public Types | |
| typedef internal::dense_xpr_base < Replicate >::type | Base |
| typedef internal::remove_all < MatrixType >::type | NestedExpression |
Public Member Functions | |
| template<typename OriginalMatrixType > | |
| EIGEN_DEVICE_FUNC | Replicate (const OriginalMatrixType &matrix) |
| EIGEN_DEVICE_FUNC | Replicate (const OriginalMatrixType &matrix, Index rowFactor, Index colFactor) |
| EIGEN_DEVICE_FUNC Index | rows () const |
| EIGEN_DEVICE_FUNC Index | cols () const |
| EIGEN_DEVICE_FUNC const _MatrixTypeNested & | nestedExpression () const |
Protected Attributes | |
| MatrixTypeNested | m_matrix |
| const internal::variable_if_dynamic < Index, RowFactor > | m_rowFactor |
| const internal::variable_if_dynamic < Index, ColFactor > | m_colFactor |
Private Types | |
| typedef internal::traits < Replicate > ::MatrixTypeNested | MatrixTypeNested |
| typedef internal::traits < Replicate > ::_MatrixTypeNested | _MatrixTypeNested |
| MatrixType | the type of the object we are replicating |
| RowFactor | number of repetitions at compile time along the vertical direction, can be Dynamic. |
| ColFactor | number of repetitions at compile time along the horizontal direction, can be Dynamic. |
This class represents an expression of the multiple replication of a matrix or vector. It is the return type of DenseBase::replicate() and most of the time this is the only way it is used.
Definition at line 61 of file Replicate.h.
typedef internal::traits<Replicate>::_MatrixTypeNested Eigen::Replicate< MatrixType, RowFactor, ColFactor >::_MatrixTypeNested [private] |
Definition at line 65 of file Replicate.h.
| typedef internal::dense_xpr_base<Replicate>::type Eigen::Replicate< MatrixType, RowFactor, ColFactor >::Base |
Definition at line 68 of file Replicate.h.
typedef internal::traits<Replicate>::MatrixTypeNested Eigen::Replicate< MatrixType, RowFactor, ColFactor >::MatrixTypeNested [private] |
Definition at line 64 of file Replicate.h.
| typedef internal::remove_all<MatrixType>::type Eigen::Replicate< MatrixType, RowFactor, ColFactor >::NestedExpression |
Definition at line 70 of file Replicate.h.
| EIGEN_DEVICE_FUNC Eigen::Replicate< MatrixType, RowFactor, ColFactor >::Replicate | ( | const OriginalMatrixType & | matrix | ) | [inline, explicit] |
Definition at line 74 of file Replicate.h.
: m_matrix(matrix), m_rowFactor(RowFactor), m_colFactor(ColFactor) { EIGEN_STATIC_ASSERT((internal::is_same<typename internal::remove_const<MatrixType>::type,OriginalMatrixType>::value), THE_MATRIX_OR_EXPRESSION_THAT_YOU_PASSED_DOES_NOT_HAVE_THE_EXPECTED_TYPE) eigen_assert(RowFactor!=Dynamic && ColFactor!=Dynamic); }
| EIGEN_DEVICE_FUNC Eigen::Replicate< MatrixType, RowFactor, ColFactor >::Replicate | ( | const OriginalMatrixType & | matrix, |
| Index | rowFactor, | ||
| Index | colFactor | ||
| ) | [inline] |
Definition at line 84 of file Replicate.h.
: m_matrix(matrix), m_rowFactor(rowFactor), m_colFactor(colFactor) { EIGEN_STATIC_ASSERT((internal::is_same<typename internal::remove_const<MatrixType>::type,OriginalMatrixType>::value), THE_MATRIX_OR_EXPRESSION_THAT_YOU_PASSED_DOES_NOT_HAVE_THE_EXPECTED_TYPE) }
| EIGEN_DEVICE_FUNC Index Eigen::Replicate< MatrixType, RowFactor, ColFactor >::cols | ( | void | ) | const [inline] |
Definition at line 94 of file Replicate.h.
{ return m_matrix.cols() * m_colFactor.value(); }
| EIGEN_DEVICE_FUNC const _MatrixTypeNested& Eigen::Replicate< MatrixType, RowFactor, ColFactor >::nestedExpression | ( | ) | const [inline] |
Definition at line 97 of file Replicate.h.
return m_matrix;
| EIGEN_DEVICE_FUNC Index Eigen::Replicate< MatrixType, RowFactor, ColFactor >::rows | ( | void | ) | const [inline] |
Definition at line 92 of file Replicate.h.
{ return m_matrix.rows() * m_rowFactor.value(); }
const internal::variable_if_dynamic<Index, ColFactor> Eigen::Replicate< MatrixType, RowFactor, ColFactor >::m_colFactor [protected] |
Definition at line 105 of file Replicate.h.
MatrixTypeNested Eigen::Replicate< MatrixType, RowFactor, ColFactor >::m_matrix [protected] |
Definition at line 103 of file Replicate.h.
const internal::variable_if_dynamic<Index, RowFactor> Eigen::Replicate< MatrixType, RowFactor, ColFactor >::m_rowFactor [protected] |
Definition at line 104 of file Replicate.h.
