MBMesquite::ElementAvgQM Class Reference
#include <ElementAvgQM.hpp>
+ Inheritance diagram for MBMesquite::ElementAvgQM:
+ Collaboration diagram for MBMesquite::ElementAvgQM:
Public Member Functions
MESQUITE_EXPORT ElementAvgQM (ElemSampleQM *metric)
virtual MESQUITE_EXPORT ~ElementAvgQM ()
MESQUITE_EXPORT ElemSampleQMget_quality_metric () const
virtual MESQUITE_EXPORT std::string get_name () const
virtual MESQUITE_EXPORT int get_negate_flag () const
 1 if metric should be minimized, -1 if metric should be maximized.
virtual MESQUITE_EXPORT bool evaluate (PatchData &pd, size_t handle, double &value, MsqError &err)
 Get metric value at a logical location in the patch.
Private Attributes
ElemSampleQMmMetric
std::vector< size_t > mHandles
Detailed Description
Definition at line 41 of file ElementAvgQM.hpp.
Definition at line 40 of file ElementAvgQM.cpp.
: mMetric( metric ) {}
Definition at line 42 of file ElementAvgQM.cpp.
Member Function Documentation
bool MBMesquite::ElementAvgQM::evaluate ( PatchData pd,
size_t  handle,
double &  value,
MsqError err
) [virtual]
Evaluate the metric at one location in the PatchData.
Parameters:
pdThe patch.
handleThe location in the patch (as passed back from get_evaluations).
valueThe output metric value.
Implements MBMesquite::QualityMetric.
Definition at line 57 of file ElementAvgQM.cpp.
References MBMesquite::QualityMetric::evaluate(), MBMesquite::ElemSampleQM::get_element_evaluations(), get_quality_metric(), mHandles, MSQ_ERRFALSE, and MSQ_ERRZERO.
    ElemSampleQM* qm = get_quality_metric();
    mHandles.clear();
    qm->get_element_evaluations( pd, handle, mHandles, err );
    MSQ_ERRFALSE( err );
    bool valid = true;
    double tmpval;
    double accumulate = 0.0;
    int num_values    = 0;
    bool tmpvalid;
    value = -std::numeric_limits< double >::infinity();
    for( std::vector< size_t >::iterator h = mHandles.begin(); h != mHandles.end(); ++h )
        tmpvalid = qm->evaluate( pd, *h, tmpval, err );
        MSQ_ERRZERO( err );
        if( !tmpvalid )
            valid = false;
            break;
        else
            accumulate += tmpval;
            num_values++;
    if( valid ) value = accumulate / num_values;
    return valid;
std::string MBMesquite::ElementAvgQM::get_name ( ) const [virtual]
Definition at line 44 of file ElementAvgQM.cpp.
References MBMesquite::QualityMetric::get_name(), and mMetric.
    std::string result( "ElementAvgQM(" );
    result += mMetric->get_name();
    result += ")";
    return result;
Definition at line 52 of file ElementAvgQM.cpp.
References MBMesquite::QualityMetric::get_negate_flag(), and get_quality_metric().
Member Data Documentation
std::vector< size_t > MBMesquite::ElementAvgQM::mHandles [mutable, private]
Definition at line 61 of file ElementAvgQM.hpp.
Referenced by evaluate().
Definition at line 60 of file ElementAvgQM.hpp.
Referenced by get_name(), and get_quality_metric().
List of all members.
