MOAB
4.9.3pre
#include <LDLT.h>
Static Public Member Functions | |
| template<typename MatrixType , typename TranspositionType , typename Workspace > | |
| static bool | unblocked (MatrixType &mat, TranspositionType &transpositions, Workspace &temp, SignMatrix &sign) |
| template<typename MatrixType , typename WDerived > | |
| static bool | updateInPlace (MatrixType &mat, MatrixBase< WDerived > &w, const typename MatrixType::RealScalar &sigma=1) |
| template<typename MatrixType , typename TranspositionType , typename Workspace , typename WType > | |
| static bool | update (MatrixType &mat, const TranspositionType &transpositions, Workspace &tmp, const WType &w, const typename MatrixType::RealScalar &sigma=1) |
| static bool Eigen::internal::ldlt_inplace< Lower >::unblocked | ( | MatrixType & | mat, |
| TranspositionType & | transpositions, | ||
| Workspace & | temp, | ||
| SignMatrix & | sign | ||
| ) | [inline, static] |
Definition at line 257 of file LDLT.h.
using std::abs;
typedef typename MatrixType::Scalar Scalar;
typedef typename MatrixType::RealScalar RealScalar;
typedef typename TranspositionType::StorageIndex IndexType;
eigen_assert(mat.rows()==mat.cols());
const Index size = mat.rows();
if (size <= 1)
transpositions.setIdentity();
if (numext::real(mat.coeff(0,0)) > 0) sign = PositiveSemiDef;
else if (numext::real(mat.coeff(0,0)) < 0) sign = NegativeSemiDef;
else sign = ZeroSign;
return true;
for (Index k = 0; k < size; ++k)
// Find largest diagonal element
Index index_of_biggest_in_corner;
mat.diagonal().tail(size-k).cwiseAbs().maxCoeff(&index_of_biggest_in_corner);
index_of_biggest_in_corner += k;
transpositions.coeffRef(k) = IndexType(index_of_biggest_in_corner);
if(k != index_of_biggest_in_corner)
// apply the transposition while taking care to consider only
// the lower triangular part
Index s = size-index_of_biggest_in_corner-1; // trailing size after the biggest element
mat.row(k).head(k).swap(mat.row(index_of_biggest_in_corner).head(k));
mat.col(k).tail(s).swap(mat.col(index_of_biggest_in_corner).tail(s));
std::swap(mat.coeffRef(k,k),mat.coeffRef(index_of_biggest_in_corner,index_of_biggest_in_corner));
for(Index i=k+1;i<index_of_biggest_in_corner;++i)
Scalar tmp = mat.coeffRef(i,k);
mat.coeffRef(i,k) = numext::conj(mat.coeffRef(index_of_biggest_in_corner,i));
mat.coeffRef(index_of_biggest_in_corner,i) = numext::conj(tmp);
if(NumTraits<Scalar>::IsComplex)
mat.coeffRef(index_of_biggest_in_corner,k) = numext::conj(mat.coeff(index_of_biggest_in_corner,k));
// partition the matrix:
// A00 | - | -
// lu = A10 | A11 | -
// A20 | A21 | A22
Index rs = size - k - 1;
Block<MatrixType,Dynamic,1> A21(mat,k+1,k,rs,1);
Block<MatrixType,1,Dynamic> A10(mat,k,0,1,k);
Block<MatrixType,Dynamic,Dynamic> A20(mat,k+1,0,rs,k);
if(k>0)
temp.head(k) = mat.diagonal().real().head(k).asDiagonal() * A10.adjoint();
mat.coeffRef(k,k) -= (A10 * temp.head(k)).value();
if(rs>0)
A21.noalias() -= A20 * temp.head(k);
// In some previous versions of Eigen (e.g., 3.2.1), the scaling was omitted if the pivot
// was smaller than the cutoff value. However, since LDLT is not rank-revealing
// we should only make sure that we do not introduce INF or NaN values.
// Remark that LAPACK also uses 0 as the cutoff value.
RealScalar realAkk = numext::real(mat.coeffRef(k,k));
if((rs>0) && (abs(realAkk) > RealScalar(0)))
A21 /= realAkk;
if (sign == PositiveSemiDef) {
if (realAkk < 0) sign = Indefinite;
} else if (sign == NegativeSemiDef) {
if (realAkk > 0) sign = Indefinite;
} else if (sign == ZeroSign) {
if (realAkk > 0) sign = PositiveSemiDef;
else if (realAkk < 0) sign = NegativeSemiDef;
return true;
| static bool Eigen::internal::ldlt_inplace< Lower >::update | ( | MatrixType & | mat, |
| const TranspositionType & | transpositions, | ||
| Workspace & | tmp, | ||
| const WType & | w, | ||
| const typename MatrixType::RealScalar & | sigma = 1 |
Definition at line 385 of file LDLT.h.
// Apply the permutation to the input w
tmp = transpositions * w;
return ldlt_inplace<Lower>::updateInPlace(mat,tmp,sigma);
| static bool Eigen::internal::ldlt_inplace< Lower >::updateInPlace | ( | MatrixType & | mat, |
| MatrixBase< WDerived > & | w, | ||
Definition at line 347 of file LDLT.h.
using numext::isfinite;
eigen_assert(mat.cols() == size && w.size()==size);
RealScalar alpha = 1;
// Apply the update
for (Index j = 0; j < size; j++)
// Check for termination due to an original decomposition of low-rank
if (!(isfinite)(alpha))
break;
// Update the diagonal terms
RealScalar dj = numext::real(mat.coeff(j,j));
Scalar wj = w.coeff(j);
RealScalar swj2 = sigma*numext::abs2(wj);
RealScalar gamma = dj*alpha + swj2;
mat.coeffRef(j,j) += swj2/alpha;
alpha += swj2/dj;
// Update the terms of L
Index rs = size-j-1;
w.tail(rs) -= wj * mat.col(j).tail(rs);
if(gamma != 0)
mat.col(j).tail(rs) += (sigma*numext::conj(wj)/gamma)*w.tail(rs);
return true;
