cgma
GeometryQueryTool Class Reference
Interface class for querying geometry. More...
#include <GeometryQueryTool.hpp>
List of all members.
Classes
struct  IGEComp
Public Member Functions
bool ige_is_composite (TBOwner *bridge_owner)
bool ige_is_composite (TopologyBridge *bridge)
bool ige_is_partition (TBOwner *bridge_owner)
void ige_remove_modified (DLIList< Surface * > &all_surfs, DLIList< Curve * > &all_curves, DLIList< TBPoint * > &all_points)
 ~GeometryQueryTool ()
 Destructor.
double estimate_merge_tolerance (DLIList< RefVolume * > &vol_list, bool accurate_in=false, bool report_in=false, double lo_val_in=-1.0, double hi_val_in=-1.0, int num_calculations_in=10, bool return_calculations_in=false, DLIList< double > *merge_tols=NULL, DLIList< int > *num_proximities=NULL)
 Estimates a good merge tolerance for the volumes passed in.
void find_floating_volumes (DLIList< RefVolume * > &vol_list, DLIList< RefVolume * > &floating_list)
 Find all of the volumes that do not contain any merged entities.
void find_nonmanifold_curves (DLIList< RefVolume * > &vol_list, DLIList< RefEdge * > &curve_list)
 Find the nonmanifold curves in the passed-in volumes based on what is merged.
void find_nonmanifold_vertices (DLIList< RefVolume * > &vol_list, DLIList< RefVertex * > &vertex_list)
 Find the nonmanifold vertices in the passed-in volumes based on what is merged.
CubitStatus register_intermediate_engine (IntermediateGeomEngine *engine)
void unregister_intermediate_engine (IntermediateGeomEngine *engine)
void ige_remove_imprint_attributes_after_modify (DLIList< BodySM * > &old_sms, DLIList< BodySM * > &new_sms)
void ige_push_imprint_attributes_before_modify (DLIList< BodySM * > &geom_list)
void ige_push_named_attributes_to_curves_and_points (DLIList< TopologyBridge * > &tb_list, const char *name_in)
void ige_export_geom (DLIList< TopologyBridge * > &geom_list)
void ige_import_geom (DLIList< TopologyBridge * > &geom_list)
void ige_remove_attributes (DLIList< TopologyBridge * > &geom_list)
void ige_attribute_after_imprinting (DLIList< TopologyBridge * > &tb_list, DLIList< Body * > &old_bodies)
void ige_remove_attributes_from_unmodifed_virtual (DLIList< TopologyBridge * > &bridges)
void get_tbs_with_bridge_manager_as_owner (TopologyBridge *source_bridge, DLIList< TopologyBridge * > &tbs)
CubitStatus ref_entity_list (char const *keyword, DLIList< RefEntity * > &entity_list, const CubitBoolean print_errors=CUBIT_TRUE)
 Return ref entities in entity_list (overwrites list). returns CUBIT_FAILURE if keyword is not a ref entity name, and optionally prints error message.
CubitBox model_bounding_box ()
 Returns the bounding box of the model. Include free entities.
CubitBox bounding_box_of_bodies ()
 Returns the bounding box of all bodies in the model.
void bodies (DLIList< Body * > &bodies)
 Returns all the bodies in the current session.
void ref_volumes (DLIList< RefVolume * > &ref_volumes)
 Returns all volumes in the current session.
void ref_groups (DLIList< RefGroup * > &ref_groups)
 Returns all groups in the current session.
void ref_faces (DLIList< RefFace * > &ref_faces)
 Returns all surfaces in the current session.
void ref_edges (DLIList< RefEdge * > &ref_edges)
 Returns all curves in the current session.
void ref_vertices (DLIList< RefVertex * > &ref_vertices)
 Returns all the vertices in the current session.
void get_ordered_loops (RefFace *face, DLIList< Loop * > &loop_list)
int num_bodies () const
 < Append global lists to arguments
int num_ref_volumes () const
 Number of volumes in current session.
int num_ref_groups () const
 Number of groups in current session.
int num_ref_faces () const
 Number of surfaces in current session.
int num_ref_edges () const
 Number of curves in current session.
int num_ref_vertices () const
 Number of vertices in current session.
RefEntityget_ref_entity (const char *type, int id)
 Get RefEntity by type name and id.
RefEntityget_ref_entity (const std::type_info &type, int id)
 Get a RefEntity of the specified type and id.
Bodyget_body (int id)
 Get entity by id.
RefVolumeget_ref_volume (int id)
 Get entity by id.
RefGroupget_ref_group (int id)
 Get entity by id.
RefFaceget_ref_face (int id)
 Get entity by id.
RefEdgeget_ref_edge (int id)
 Get entity by id.
RefVertexget_ref_vertex (int id)
 Get entity by id.
Bodyget_first_body ()
 Get the first entity in the global list of the specified type.
RefVolumeget_first_ref_volume ()
RefGroupget_first_ref_group ()
RefFaceget_first_ref_face ()
RefEdgeget_first_ref_edge ()
RefVertexget_first_ref_vertex ()
Bodyget_next_body ()
 Get the next entity in the global list of the specified type.
RefVolumeget_next_ref_volume ()
RefGroupget_next_ref_group ()
RefFaceget_next_ref_face ()
RefEdgeget_next_ref_edge ()
RefVertexget_next_ref_vertex ()
Bodyget_last_body ()
RefVolumeget_last_ref_volume ()
RefGroupget_last_ref_group ()
RefFaceget_last_ref_face ()
RefEdgeget_last_ref_edge ()
RefVertexget_last_ref_vertex ()
CubitStatus get_free_ref_entities (DLIList< RefEntity * > &free_entities)
 Get all free surfaces, curves, and vertices.
void get_connected_free_ref_entities (RefEntity *entity, const int merge_option, DLIList< Body * > &body_list, DLIList< RefFace * > &ref_face_list, DLIList< RefEdge * > &ref_edge_list, DLIList< RefVertex * > &ref_vertex_list)
 Get the free entities connected to, but not necessarily vertically related to, the entity. - If merge_option, then take into account the fact that the model may be merged (it's slower that way).
void validate_geometry_database ()
CubitStatus save_temp_geom_files (DLIList< RefEntity * > &ref_entity_list, const char *filename, const CubitString &cubit_version, std::list< CubitString > &files_written, std::list< CubitString > &types_written)
 Saves out a temporary geometry file containing specified entities that are of the same geometry engine.
CubitStatus export_solid_model (DLIList< RefEntity * > &ref_entity_list, const char *filename, Model_File_Type filetype, int &num_ents_exported, const CubitString &cubit_version, ModelExportOptions &export_options)
 Save a geometry file containing specified entities that are of the same geometry engine.
CubitStatus export_solid_model (DLIList< RefEntity * > &ref_entity_list, char *&p_buffer, int &n_buffer_size, bool b_export_buffer)
CubitStatus import_solid_model (const char *file_name, Model_File_Type file_type, ModelImportOptions &import_options, DLIList< RefEntity * > *imported_entities=NULL)
 Import a geometry file.
CubitStatus import_solid_model (DLIList< RefEntity * > *imported_entities, const char *pBuffer, const int n_buffer_size)
CubitStatus fire_ray (CubitVector &origin, CubitVector &direction, DLIList< RefEntity * > &at_entity_list, DLIList< double > &ray_params, int max_hits=0, double ray_radius=0.0, DLIList< RefEntity * > *hit_entity_list_ptr=0)
 Fire a ray at entities, passing back distances of hits and entities hit.
CubitStatus fire_ray (CubitVector &origin, CubitVector &direction, DLIList< TopologyEntity * > &at_entity_list, DLIList< double > &ray_params, int max_hits=0, double ray_radius=0.0, DLIList< TopologyEntity * > *hit_entity_list_ptr=0)
CubitString get_engine_version_string ()
 Calls engine version of the active geometry engine.
CubitStatus set_export_allint_version (int version)
 Set the major/minor version of the active geometry engine.
int get_allint_version ()
 Get the major/minor version of the active geometry engine.
CubitStatus list_engine_versions (CubitString &versions)
 Returns a string with the versions of the active geometry engine.
double get_sme_resabs_tolerance ()
 Gets solid modeler's resolution absolute tolerance.
double set_sme_resabs_tolerance (double new_resabs)
 Sets solid modeler's resolution absolute tolerance.
CubitStatus set_sme_int_option (const char *opt_name, int val)
 Set solid modeler integer option.
CubitStatus set_sme_dbl_option (const char *opt_name, double val)
 Set solid modeler double option.
CubitStatus set_sme_str_option (const char *opt_name, const char *val)
 Set solid modeler string option.
Bodymake_Body (BodySM *bodysm_ptr) const
RefFacemake_RefFace (Surface *surface_ptr) const
RefEdgemake_RefEdge (Curve *curve_ptr) const
RefVertexmake_RefVertex (TBPoint *point_ptr) const
RefFacemake_free_RefFace (Surface *surface_ptr, bool is_free_surface) const
RefEdgemake_free_RefEdge (Curve *curve_ptr) const
RefVertexmake_free_RefVertex (TBPoint *point_ptr) const
 HR>
void delete_Body (DLIList< Body * > &body_list)
 Deletes all Bodies in the input list from the model. Their associated Solid Model entities are deleted as well, if they exist, and if remove_solid_model_entities is CUBIT_TRUE.
CubitStatus delete_Body (Body *body_ptr)
 Deletes a body.
CubitStatus delete_single_Body (Body *body_ptr)
 Deletes a body.
CubitStatus delete_RefEntity (RefEntity *ref_entity_ptr)
 Deletes free RefEnties.
CubitStatus delete_RefFace (RefFace *ref_face_ptr)
 Deletes the RefFace if it is free.
CubitStatus delete_RefEdge (RefEdge *ref_edge_ptr)
 Deletes the RefEdge if it is free.
CubitStatus delete_RefVertex (RefVertex *ref_vertex_ptr)
 Deletes the RefVertex if it is free.
void cleanout_deactivated_geometry ()
void cleanout_temporary_geometry ()
void delete_geometry ()
 Deletes all geometry.
CubitStatus interpolate_along_surface (CubitVector *vector_1, CubitVector *vector_2, DLIList< CubitVector * > &vector_list, RefFace *ref_face_ptr, int number_points) const
 Creates a list of vectors the length of the number_points that interpolate between vector_1 and vector_2. All of the points will lie on the underlying equation of the refface.
CubitBoolean about_spatially_equal (const CubitVector &Vec1, const CubitVector &Vec2, double tolerance_factor=1.0)
 Compares two positions for coincidence.
CubitBoolean about_spatially_equal (RefVertex *refVertex1, RefVertex *refVertex2, double tolerance_factor=1.0)
 Compares two vertices for coincidence.
double geometric_angle (RefEdge *ref_edge_1, RefEdge *ref_edge_2, RefFace *ref_face)
 Calculates internal surface angles given 2 refedges on the surface. CoEdge version correctly handles curves in a surface twice.
double geometric_angle (CoEdge *co_edge_1, CoEdge *co_edge_2)
 Calculates internal surface angles given 2 refedges on the surface. This version correctly handles curves in a surface twice.
double surface_angle (RefFace *ref_face_1, RefFace *ref_face_2, RefEdge *ref_edge=NULL, RefVolume *ref_volume=NULL, double frac=0.5)
 Calculate dihedral angle at curve between two surfaces of the volume.
CubitStatus get_intersections (RefEdge *ref_edge1, CubitVector &point1, CubitVector &point2, DLIList< CubitVector > &intersection_list, CubitBoolean bounded=CUBIT_FALSE, CubitBoolean closest=CUBIT_FALSE)
 Finds the intersections of a straight line and a curve.
CubitStatus get_intersections (RefEdge *ref_edge1, RefEdge *ref_edge2, DLIList< CubitVector > &intersection_list, CubitBoolean bounded=CUBIT_FALSE, CubitBoolean closest=CUBIT_FALSE)
 Finds the intersections of two curves.
CubitStatus get_intersections (RefEdge *ref_edge, RefFace *ref_face, DLIList< CubitVector > &intersection_list, CubitBoolean bounded=CUBIT_FALSE)
 Finds the intersections of the curve and surface.
CubitStatus get_intersections (RefEdge *ref_edge, CubitPlane plane, DLIList< CubitVector > &intersection_list, CubitBoolean bounded=CUBIT_FALSE, double extended_percent=0.0)
CubitStatus entity_extrema (RefEntity *ref_entity_ptr, const CubitVector *dir1, const CubitVector *dir2, const CubitVector *dir3, CubitVector &extrema, RefEntity *&extrema_entity_ptr)
 Gets extrema position on an entity.
CubitStatus entity_extrema (DLIList< RefEntity * > &ref_entity_list, const CubitVector *dir1, const CubitVector *dir2, const CubitVector *dir3, CubitVector &extrema, RefEntity *&extrema_entity_ptr)
 Gets extrema position on a list of entities.
CubitStatus entity_entity_distance (GeometryEntity *ge1, GeometryEntity *ge2, CubitVector &pos1, CubitVector &pos2, double &distance)
 Get the minimum distance between two entities.
CubitStatus entity_entity_distance (RefEntity *ref_entity_ptr1, RefEntity *ref_entity_ptr2, CubitVector &pos1, CubitVector &pos2, double &distance)
 Get the minimum distance between two entities. (CGM internal use)
CubitBoolean same_query_engine (DLIList< TopologyEntity * > &topo_list) const
 Returns CUBIT_TRUE if all the entities have the same geometric query engine and if that is the same one as the default.
GeometryQueryEnginecommon_query_engine (DLIList< TopologyEntity * > &topology_list, DLIList< TopologyBridge * > &engine_bridges, CubitBoolean allow_default_engine=CUBIT_FALSE) const
 Gets geometry beloning to a common modeling engine.
CubitBoolean does_geom_contain_query_engine (DLIList< TopologyEntity * > &topo_list, GeometryQueryEngine *engine) const
 Determine if any of the input entities contain the given query engine.
CubitBoolean does_geom_contain_query_engine (DLIList< RefEntity * > &ref_entity_list, GeometryQueryEngine *engine, CubitBoolean children_too=CUBIT_FALSE) const
TopologyEntityentity_from_bridge (TopologyBridge *bridge_ptr) const
 Retrieves the TopologyEntity from the underlying TopologyBridge.
void add_gqe (GeometryQueryEngine *gqe_ptr)
 Adds a geometry query engine to the list.
CubitStatus remove_gqe (GeometryQueryEngine *gqe_ptr)
 Removes a geometry query engine from the list. Returns CUBIT_FAILURE if it wasn't in the list.
void get_gqe_list (DLIList< GeometryQueryEngine * > &gqe_list)
 Return the list of GeometryQureyEngines.
GeometryQueryEngineget_gqe ()
 Returns the first gqe on the list.
CubitStatus set_default_gqe (GeometryQueryEngine *gqe)
 Set the default GeometryQueryEngine.
bool contains_intermediate_geometry (RefEntity *) const
bool contains_intermediate_geometry (DLIList< RefEntity * > &ref_entitylist) const
bool is_intermediate_geometry (RefEntity *) const
bool is_intermediate_geometry (TopologyBridge *) const
CubitStatus destroy_dead_entity (TopologyEntity *topo_ent, bool top=true) const
CubitStatus translate (DLIList< Body * > &bodies, const CubitVector &delta, DLIList< Body * > *bodies_translated=NULL, bool check_to_transform=true, bool preview=false)
 Translate a Body some delta.
CubitStatus translate (DLIList< BasicTopologyEntity * > &btes, const CubitVector &delta, DLIList< BasicTopologyEntity * > *btes_translated=NULL, bool check_to_transform=true, bool preview=false)
 Translate a BasicTopologyEntity some delta.
void translate (DLIList< RefEntity * > &entities_to_transform, double x, double y, double z, bool check_before_transforming, DLIList< RefEntity * > &entities_transformed, bool preview=false)
CubitStatus rotate (DLIList< Body * > &bodies, const CubitVector &axis, double degrees, DLIList< Body * > *bodies_rotated=NULL, bool check_to_transform=true, bool preview=false)
 Rotate a Body an angle about an axis.
CubitStatus rotate (DLIList< Body * > &bodies, const CubitVector &point, const CubitVector &normal, double degrees, DLIList< Body * > *bodies_rotated=NULL, bool check_to_transform=true, bool preview=false)
 Rotate a Body an angle about an axis, defined by a point and a direction.
CubitStatus rotate (DLIList< RefEntity * > &entities_to_transform, const CubitVector &point, const CubitVector &normal, double degrees, bool check_to_transform, DLIList< RefEntity * > &entities_transformed, bool preview=false)
CubitStatus rotate (DLIList< BasicTopologyEntity * > &btes, const CubitVector &axis, double degrees, DLIList< BasicTopologyEntity * > *btes_rotated=NULL, bool check_to_transform=true, bool preview=false)
 Rotate a BacisTopologyEntity an angle about an axis.
CubitStatus rotate (DLIList< BasicTopologyEntity * > &btes, const CubitVector &point, const CubitVector &normal, double degrees, DLIList< BasicTopologyEntity * > *btes_rotated=NULL, bool check_to_transform=true, bool preview=false)
CubitStatus scale (Body *entity, const CubitVector &point, double factor, bool check_to_transform=true, bool preview=false)
 Scale a Body.
CubitStatus scale (Body *entity, const CubitVector &point, const CubitVector &factors, bool check_to_transform=true, bool preview=false)
 Scale a Body different factors in x, y, and z.
CubitStatus scale (BasicTopologyEntity *entity, const CubitVector &point, double factor, bool check_to_transform=true, bool preview=false)
 Scale a BasicTopologyEntity.
CubitStatus scale (BasicTopologyEntity *entity, const CubitVector &point, const CubitVector &factors, bool check_to_transform=true, bool preview=false)
 Scale a BasicTopologyEntity different factors in x, y, and z.
void scale (DLIList< RefEntity * > &entities_to_transform, const CubitVector &point, double scale_x, double scale_y, double scale_z, bool check_to_transform, DLIList< RefEntity * > &entities_scaled, bool preview=false)
CubitStatus reflect (DLIList< Body * > &bodies, const CubitVector &point, const CubitVector &axis, DLIList< Body * > *bodies_reflected=NULL, bool preview=false)
 Reflect a list of bodies about a plane defined by an axis.
CubitStatus reflect (DLIList< BasicTopologyEntity * > &btes, const CubitVector &point, const CubitVector &axis, DLIList< BasicTopologyEntity * > *btes_reflected=NULL, bool check_to_transform=true, bool preview=false)
 Reflect a BasicTopologyEntity about a plane defined by an axis.
void reflect (DLIList< RefEntity * > &entities_to_transform, const CubitVector &point, const CubitVector &axis, bool check_before_transforming, DLIList< RefEntity * > &entities_transformed, bool preview=false)
CubitStatus restore_transform (Body *body)
 Need to deprecate.
CubitBoolean volumes_overlap (RefVolume *volume_1, RefVolume *volume_2)
 Query to determine if volumes intersect, share common volume.
CubitBoolean bodies_overlap (Body *body_ptr_1, Body *body_ptr_2)
 Query to determine if bodies intersect, share common volume.
CubitStatus construct_refentities (DLIList< TopologyBridge * > &topology_bridges, DLIList< RefEntity * > *imported_entities=NULL)
CGMHistoryhistory ()
CubitStatus get_graphics (Body *body, GMem *g_mem, std::vector< RefFace * > &face_to_facet_vector, std::vector< RefEntity * > &facet_point_ownership_vector, std::vector< std::pair< RefEntity *, std::pair< int, int > > > &facetedges_on_refedges, unsigned short normal_tolerance, double distance_tolerance, double max_edge_length)
CubitStatus get_graphics (RefFace *ref_face, GMem *gmem, std::vector< RefEntity * > &facet_point_ownership_vector, std::vector< std::pair< RefEntity *, std::pair< int, int > > > &facetedges_on_refedges, unsigned short normal_tolerance=15, double distance_tolerance=0.0, double max_edge_length=0.0)
CubitStatus get_point_containment (DLIList< Body * > &body_list, DLIList< CubitVector > &point_list, double tolerance, bool allow_pts_in_multiple_bodies, std::vector< std::pair< Body *, std::vector< int > > > &body_to_pt_indices)
Static Public Member Functions
static GeometryQueryToolinstance (GeometryQueryEngine *gqePtr=NULL)
static void delete_instance ()
static void geom_debug (DLIList< TopologyEntity * >)
 Debugging function.
static void set_facet_bbox (CubitBoolean pass_flag)
 Set facet box flag.
static CubitBoolean get_facet_bbox ()
 Get facet box flag.
static CubitSense relative_sense (Surface *surface1, Surface *surface2)
static void reset_geometry_factor ()
 Resets geometry factor back to 500.0.
static void set_geometry_factor (double fac)
 Sets geometry factor.
static double get_geometry_factor ()
 Gets geometry factor.
static void set_merge_test_bbox (CubitBoolean tof)
 Sets bboxMergeTest variable.
static CubitBoolean get_merge_test_bbox ()
 Gets bboxMergeTest variable.
static void set_merge_test_internal (int tof)
static int get_merge_test_internal ()
static void set_sliver_curve_cleanup_tolerance (double tol)
static void set_sliver_surface_cleanup_tolerance (double tol)
static double get_sliver_curve_cleanup_tolerance ()
static double get_sliver_surface_cleanup_tolerance ()
static void initialize_settings ()
 Initializes all settings of this class.
static CubitStatus import_actuate (DLIList< RefEntity * > &entity_list)
 Causes attributes hanging on entities to be applied.
Static Public Attributes
static CubitBoolean trackMergedAwayEnts = CUBIT_FALSE
 Variable needed when importing geometry that will be merged-away with already existing geometry in the session.
static CubitBoolean importingSolidModel = CUBIT_FALSE
static CubitBoolean clearUidMapBeforeImport = CUBIT_TRUE
static CubitBoolean mergeGloballyOnImport = CUBIT_TRUE
static DLIList< int > uidsOfImportingEnts
static int entitiesMergedAway = 0
Protected Member Functions
 GeometryQueryTool (GeometryQueryEngine *GQEPtr)
Private Types
typedef std::set
< IntermediateGeomEngine
*, IGEComp
IGESet
Private Member Functions
CubitBoolean okay_to_transform (Body *body) const
CubitBoolean okay_to_transform (BasicTopologyEntity *bte) const
void notify_observers_of_transform (RefEntity *ref_entity, const CubitTransformMatrix *transform=NULL) const
void notify_observers_of_transform (DLIList< RefEntity * > &ref_ents, const CubitTransformMatrix *xform=NULL) const
CubitStatus notify_intermediate_of_transform (TopologyEntity *bte, const CubitTransformMatrix &xform) const
Shellmake_Shell (ShellSM *shellsm_ptr, bool &shell_modified) const
RefVolumemake_RefVolume (Lump *lump_ptr, bool &vol_modified) const
CubitStatus make_merged_RefFace (Surface *surface_ptr) const
RefEntitycheck_mergeable_refentity (GeometryEntity *bridge) const
CoEdgeSMfind_merged_coedgesm (Surface *on_this_surface, CoEdgeSM *merged_with_this) const
void get_merged_away_free_entities (DLIList< RefEntity * > &ref_ents, DLIList< TopologyBridge * > &free_ents)
CubitStatus straightline_intersections (RefEdge *ref_edge1, CubitVector &origin2, CubitVector &dir2, DLIList< CubitVector > &intersection_list, CubitBoolean bounded=CUBIT_FALSE, CubitBoolean closest=CUBIT_FALSE)
Private Attributes
DLIList< GeometryQueryEngine * > gqeList
 The list of geometry query engines.
IGESet igeSet
GeometryQueryEnginedefault_gqe
 The default geometry query engine.
int maxPersistentBodyId
int maxPersistentRefVolumeId
int maxPersistentRefGroupId
int maxPersistentRefFaceId
int maxPersistentRefEdgeId
int maxPersistentRefVertexId
CGMHistory mHistory
Static Private Attributes
static GeometryQueryToolinstance_ = 0
 static pointer to the unique instance of this class.
static CubitBoolean useFacetBBox = CUBIT_FALSE
static double curveSliverCleanUpTolerance = geometryToleranceFactor*GEOMETRY_RESABS
static double surfaceSliverCleanUpTolerance = -1.0
static double geometryToleranceFactor = DEFAULT_GEOM_FACTOR
static CubitBoolean bboxMergeTest = CUBIT_TRUE
static int internalSurfaceMergeTest = 2
Friends
class GeometryModifyTool
Detailed Description
Definition at line 82 of file GeometryQueryTool.hpp.
Member Typedef Documentation
Definition at line 1108 of file GeometryQueryTool.hpp.
Destructor.
Definition at line 166 of file GeometryQueryTool.cpp.
  //Kill the geometry query engine(s).
   int i;
   for (i = gqeList.size(); i > 0; i--)
     delete gqeList.get_and_step();
   gqeList.clean_out();
   instance_ = NULL;
Constructor for the (singleton) GeometryQueryTool object
Definition at line 3125 of file GeometryQueryTool.cpp.
  if (gqe_ptr != NULL) add_gqe(gqe_ptr);
Member Function Documentation
CubitBoolean GeometryQueryTool::about_spatially_equal ( const CubitVector Vec1,
const CubitVector Vec2,
double  tolerance_factor = 1.0
Returns:
CubitBoolean
- CUBIT_TRUE/CUBIT_FALSE
  • Vec1 A reference to the first vector.
  • Vec2 A reference to the second vector.
  • tolerance_factor Factor by which the absolute internal tolerance shall be multiplied. Returns CUBIT_TRUE if the input Vec1 and Vec2 are spatially equivalent within a tolerance. The internal spatial tolerance value is multiplied by tolerance_factor before the (spatial) test is done. Else, returns CUBIT_FALSE.
Definition at line 3307 of file GeometryQueryTool.cpp.
  double tol = GEOMETRY_RESABS * tolerance_factor;
  tol *= tol;
  double dist_sq = vector1.distance_between_squared(vector2);
  return !(dist_sq > tol);
  // within_tolerance() just checks coordinate aligned distances, not the actual distance.
//   return (vector1.within_tolerance( vector2, GEOMETRY_RESABS * tolerance_factor ));
CubitBoolean GeometryQueryTool::about_spatially_equal ( RefVertex refVertex1,
RefVertex refVertex2,
Definition at line 3300 of file GeometryQueryTool.cpp.
   return ( refVertex1->about_spatially_equal( refVertex2, tolerance_factor));
void GeometryQueryTool::add_gqe ( GeometryQueryEngine gqe_ptr) [inline]
add a geometry query engine to the list
Definition at line 1190 of file GeometryQueryTool.hpp.
void GeometryQueryTool::bodies ( DLIList< Body * > &  bodies)
Definition at line 4362 of file GeometryQueryTool.cpp.
CubitBoolean GeometryQueryTool::bodies_overlap ( Body body_ptr_1,
Body body_ptr_2
Query to determine if bodies intersect, share common volume. Returns CUBIT_TRUE if the two bodies overlap, CUBIT_FALSE if they don't overlap. If the bodies are touching the function should return CUBIT_FALSE. body_ptr_1, body_ptr_2 The two body pointers that are being tested for overlap. The function uses the intersect call to test if the bodies are overlaping. The full intersect Boolean is needed to see if the bodies actually overlap and don't just touch.
Definition at line 7594 of file GeometryQueryTool.cpp.
  BodySM *body1 = body_ptr_1->get_body_sm_ptr();
  BodySM *body2 = body_ptr_2->get_body_sm_ptr();
  if( is_intermediate_geometry( body_ptr_1 ) )
    return body_ptr_1->get_geometry_query_engine()->bodies_overlap( body1, body2 );
  else if( is_intermediate_geometry( body_ptr_2 ) )
    return body_ptr_2->get_geometry_query_engine()->bodies_overlap( body2, body1 );
  else if( body_ptr_1->get_geometry_query_engine() !=
           body_ptr_2->get_geometry_query_engine() )
    PRINT_ERROR("Volumes must be of the same type ( SolidWorks, etc) to\n"
                "find if they overlap.\n");
    return CUBIT_FALSE;
  else
Returns the bounding box of all bodies in the model. Excludes free entities.
Definition at line 4143 of file GeometryQueryTool.cpp.
   CubitBox total_bound;
   int i;
   if(GeometryQueryTool::instance()->num_bodies() > 0)
     GeometryQueryTool::instance()->get_last_body();
        // Assign the first body's bounding box to total_bound
     total_bound = GeometryQueryTool::instance()->get_last_body()->bounding_box();
        // Create union of all remaining bounding boxes
      for (i = GeometryQueryTool::instance()->num_bodies(); --i; )
          total_bound |= GeometryQueryTool::instance()->get_next_body()->bounding_box();
   else
        // Set the box to [(0,0,0)(0,0,0)]
      CubitVector temp(0,0,0);
      total_bound.reset(temp);
     // Return the box
   return total_bound;
Definition at line 2468 of file GeometryQueryTool.cpp.
    // Disable for surfaces until we can correctly handle
    // surfaces that have virtual curves.
    // J.Kraftcheck  Apr.29,2002
//  if( dynamic_cast<Surface*>(bridge) )
//    return 0;
  if (CUBIT_FALSE == CGMApp::instance()->attrib_manager()->auto_actuate_flag(CA_MERGE_PARTNER))
    return NULL;
    // checks the topology bridge for a merge attribute, which might lead to another
    // refentity
  DLIList<CubitSimpleAttrib> csa_list;
  const char* name = CGMApp::instance()->attrib_manager()->att_internal_name(CA_MERGE_PARTNER);
  bridge->get_simple_attribute(name, csa_list);
  RefEntity *re_ptr = NULL;
  if(csa_list.size() > 0)
    const CubitSimpleAttrib &csa_ptr = csa_list.size() ? csa_list.get() : CubitSimpleAttrib();
      // from the csa, call CAMP to get the partner, if one exists
      // (and return it)
    int merge_id = csa_ptr.int_data_list()[0];
    if( importingSolidModel && CUBIT_FALSE == GSaveOpen::performingUndo &&
        !mergeGloballyOnImport )
      //if the merge id isn't already on some other entity already imported,
      //this entity doesn't have anybody to merge with...return NULL
      if( !uidsOfImportingEnts.is_in_list( merge_id) )
        GeometryQueryTool::uidsOfImportingEnts.append( merge_id );
        return NULL;
    bool unique_append = false;
    if( GeometryQueryTool::trackMergedAwayEnts )
      unique_append = GeometryQueryTool::uidsOfImportingEnts.append_unique( merge_id );
    ToolDataUser *tdu = TDUniqueId::find_td_unique_id(merge_id);
    TopologyEntity *te = dynamic_cast<TopologyEntity*>(tdu);
    CubitSense sense = CAMergePartner::get_bridge_sense( csa_ptr );
    //We found the merge partner.....
    if (te != NULL)
      //it's the first time you found this uid and you found an entity
      if(GeometryQueryTool::trackMergedAwayEnts && unique_append )
        GeometryQueryTool::entitiesMergedAway++;
        // assume this merge attrib will be actuated, so remove the csa
      bridge->remove_simple_attribute_virt(csa_ptr);
        // now do the actual merge
      re_ptr = dynamic_cast<RefEntity*> (te);
      //compare relative sense.....reverse bridges as necessary
      Surface *surface = CAST_TO( bridge, Surface );
      Curve *curve= CAST_TO( bridge, Curve );
      CubitSense rel_sense = CUBIT_FORWARD;
      CubitBoolean is_survivor = CAMergePartner::is_survivor( csa_ptr );
      if( surface )
        TopologyBridge *other_bridge = te->bridge_manager()->topology_bridge();
        Surface *other_surface = CAST_TO( other_bridge, Surface );
        rel_sense = relative_sense( surface, other_surface );
      else if( curve )
        Curve *other_curve = CAST_TO( other_bridge, Curve );
        rel_sense = curve->relative_sense( other_curve );
      //non-surviving merged entity is here....reverse
      //its bridge sense so that it will merge
      if( !is_survivor && sense != CUBIT_UNKNOWN && rel_sense == CUBIT_REVERSED )
        bridge->reverse_bridge_sense();
      //surviving merged entity is now being restored....
      //reverse the ref entity and make this entity the primary one
      if( is_survivor )
        //If the passed in new bridge is the real survivor of the merge,
        //it should be the first bridge in the bridge manager.  The first
        //bridge in the bridge manager is always FORWARD wrt the TE.
        // If this new bridge is reversed wrt the current first bridge,
        // reverse all the other bridges so that they will all merge
        //successfully with this new first bridge.  Also add this new bridge
        //as the first bridge, since it was the original survivor.
        if( rel_sense == CUBIT_REVERSED )
          te->reverse_topology();
          //reverse the sense of the bridges of this refentity
          DLIList<TopologyBridge*> bridge_list;
          te->bridge_manager()->get_bridge_list( bridge_list );
          int kk;
          for( kk=bridge_list.size(); kk--; )
            TopologyBridge *tmp_bridge = bridge_list.get_and_step();
            tmp_bridge->reverse_bridge_sense();
        //add this bridge as the primary bridge
        te->bridge_manager()->add_bridge_as_representation(bridge);
      else
        te->bridge_manager()->add_bridge(bridge);
      // Set the merge sense of the bridge, if it is saved in the
      // attribute.
    if( re_ptr && sense == CUBIT_UNKNOWN )
      TopologyBridge* first = te->bridge_manager()->topology_bridge();
      Curve* curve;
      Surface* surface;
      if( (curve = dynamic_cast<Curve*>(bridge) ) != NULL )
        Curve* first_curve = dynamic_cast<Curve*>(first);
        assert(first_curve != NULL);
        sense = first_curve->bridge_sense();
        if( first_curve->relative_sense(curve) == CUBIT_REVERSED )
          sense = CubitUtil::opposite_sense(sense);
      else if( (surface = dynamic_cast<Surface*>(bridge) ) != NULL )
        Surface* first_surf = dynamic_cast<Surface*>(first);
        assert(first_surf != NULL);
        sense = first_surf->bridge_sense();
        if( relative_sense( first_surf, surface ) == CUBIT_REVERSED )
    int id = CAMergePartner::get_saved_id( csa_ptr );
    if (id)
      bridge->set_saved_id( id );
  return re_ptr;
Definition at line 4168 of file GeometryQueryTool.cpp.
     // This routine removes from the model all RefEntities that have been
     // deactivated
   PRINT_DEBUG_17("\n\n...Cleaning out deactivated RefEntities "
               "and asociated Mesh Entities from the model\n");
     // First delete the meshes associated with the deactivated RefEntities
     // delete_meshes_of_deactivated_refEntities();
     // Now delete the deactivated RefEntities and remove all traces
     // of them from the DAG
   DAG::instance()->cleanout_deactivated_DAG_nodes();
     // Leave gracefully :-)
   PRINT_DEBUG_17(
               "Successfully cleaned out all deactivated RefEntities "
               "and associated Mesh Entities from the model.\n");
   return;
GeometryQueryEngine * GeometryQueryTool::common_query_engine ( DLIList< TopologyEntity * > &  topology_list,
DLIList< TopologyBridge * > &  engine_bridges,
CubitBoolean  allow_default_engine = CUBIT_FALSE
) const
Returns:
GeometryQueryEngine* A GeometryQueryEngine common at least one TopologyBridge of each of the passed TopologyEntities, or NULL if no common geometry engine is found.
  • topology_list The input list of TopologyEntities
  • engine_bridges Pass back the list of TopolgyBridges associated with each of the passed TopologyEntities (topology_list) and owned by the returned geometry engine.
  • allow_virtual_engine Return VirtualGeometryEngine::instance() if no common geometry enginge can be found.
Look for a common geometry engine other than the VirtualGeometryEngine. If no common geometry engine other than VGE can be found and allow_virtual_engine is FALSE, NULL is returned. If allow_virtual_engine is TRUE, and no common geometry engine is found, VGE will be returned, and engine_bridges will be populated with any virtual geometry if possible, otherwise with the first topology bridge attached to each of the passed TopologyEntities.
Definition at line 5047 of file GeometryQueryTool.cpp.
  topology_list.reset();
  TopologyEntity* topo_ptr = topology_list.get_and_step();
  DLIList<TopologyBridge*> first_bridge_list;
  topo_ptr->bridge_manager()->get_bridge_list( first_bridge_list );
  first_bridge_list.reset();
  GeometryQueryEngine* gqe_ptr = 0;
  for( int i = first_bridge_list.size(); i > 0; i-- )
    TopologyBridge* bridge_ptr = first_bridge_list.get_and_step();
    engine_bridges.clean_out();
    engine_bridges.append( bridge_ptr );
    gqe_ptr = bridge_ptr->get_geometry_query_engine();
    topology_list.step(); //skip first entry
    for( int j = topology_list.size(); j > 1; j-- )
      bridge_ptr = topo_ptr->bridge_manager()->topology_bridge(gqe_ptr);
      if( bridge_ptr ) engine_bridges.append( bridge_ptr );
      else break;
    if( engine_bridges.size() == topology_list.size() )
      break;
    gqe_ptr = 0;
  if( !gqe_ptr )
    if( allow_default_engine )
      PRINT_WARNING("Entities do not belong to the same geometry "
        "engine.  Using the default  geometry engine.\n");
      gqe_ptr = default_gqe;
      for( int j = topology_list.size(); j > 0; j-- )
          topo_ptr->bridge_manager()->topology_bridge( gqe_ptr );
        if( ! bridge_ptr )
          bridge_ptr = topo_ptr->bridge_manager()->topology_bridge();
  return gqe_ptr;
CubitStatus GeometryQueryTool::construct_refentities ( DLIList< TopologyBridge * > &  topology_bridges,
DLIList< RefEntity * > *  imported_entities = NULL
Given a list of TB's, construct ref entities for them; if the 2nd list pointer is non-NULL, pass back the list of ref entities in that list
Definition at line 1114 of file GeometryQueryTool.cpp.
    // Construct VGI Topology from the TopologyBridges.
  DLIList<Body*> body_list;
  DLIList<RefFace*> face_list;
  DLIList<RefEdge*> edge_list;
  DLIList<RefVertex*> vtx_list;
    // We are going to pop entities from bridge_list,
    // so reverse the list so that the entities get
    // created in the old order and the IDs remain
    // the same.
  bridge_list.reverse();
  CubitStatus status = CUBIT_SUCCESS;
  bool do_progress = bridge_list.size() > 2 ? true : false;
  if(do_progress)
    char message[128];
    sprintf(message, "Building %d CUBIT Entities", bridge_list.size() );
    AppUtil::instance()->progress_tool()->start(0, bridge_list.size(), "Progress",
        message, TRUE, TRUE);
  while( bridge_list.size() && !AppUtil::instance()->interrupt() )
    BodySM* bodysm_ptr;
    Surface* surface_ptr;
    Curve* curve_ptr;
    TBPoint* point_ptr;
    TopologyBridge* bridge_ptr = bridge_list.pop();
    if( (bodysm_ptr = dynamic_cast<BodySM*>(bridge_ptr) ) != NULL )
      Body* body_ptr = make_Body( bodysm_ptr );
      if( body_ptr )
        body_list.append( body_ptr );
      else
        PRINT_ERROR("\nError constructing VGI Body.\n");
        status = CUBIT_FAILURE;
    else if( (surface_ptr = dynamic_cast<Surface*>(bridge_ptr) ) != NULL )
      bool is_free_face = true;
      RefFace* face_ptr = make_free_RefFace( surface_ptr, is_free_face );
      if( face_ptr )
        face_list.append( face_ptr );
      else
        PRINT_ERROR("\nError constructing free VGI Surface.\n");
    else if( (curve_ptr = dynamic_cast<Curve*>(bridge_ptr) ) != NULL )
      RefEdge* edge_ptr = make_free_RefEdge( curve_ptr );
      if( edge_ptr )
        edge_list.append( edge_ptr );
      else
        PRINT_ERROR("\nError constructing free VGI Curve.\n");
    else if( (point_ptr = dynamic_cast<TBPoint*>(bridge_ptr) ) != NULL )
      RefVertex* vtx_ptr = make_free_RefVertex( point_ptr );
      if( vtx_ptr )
        vtx_list.append( vtx_ptr );
      else
        PRINT_ERROR("\nError constructing free VGI Vertex.\n");
    else
      PRINT_ERROR("Unknown entity type imported by solid modeler.  Ignored.\n");
    if(do_progress)
        AppUtil::instance()->progress_tool()->step();
  if(do_progress)
    AppUtil::instance()->progress_tool()->end();
  PRINT_INFO("\n");
    // If the above loop was interrupted, bridge_list will not be
    // empty.  Free any bridges we did not make topology for.
  if( AppUtil::instance()->interrupt() )
    PRINT_WARNING("Aborted construction of %d entities.\n", bridge_list.size());
  while( bridge_list.size() )
    GeometryQueryEngine* gqe = bridge_ptr->get_geometry_query_engine();
    BodySM* body_ptr;
    Curve* curve_ptr;
    TBPoint* point_ptr;
    if( (body_ptr = dynamic_cast<BodySM*>(bridge_ptr) ) != NULL )
      gqe->delete_solid_model_entities( body_ptr );
      gqe->delete_solid_model_entities( surface_ptr );
      gqe->delete_solid_model_entities( curve_ptr );
      gqe->delete_solid_model_entities( point_ptr );
    // If any geometry was pre-merged during the
    // RefEntity construction, adjust the sense of
    // the entities to match what it was originally.
  DLIList<BasicTopologyEntity*> bte_list;
  DLIList<RefFace*> child_face_list;
  DLIList<RefEdge*> child_edge_list;
  for( int b = body_list.size(); b--; )
    body_list.get()->ref_faces( child_face_list );
    CAST_LIST_TO_PARENT( child_face_list, bte_list );
    adjust_merge_sense( bte_list );
    body_list.get()->ref_edges( child_edge_list );
    CAST_LIST_TO_PARENT( child_edge_list, bte_list );
    body_list.step();
  CAST_LIST_TO_PARENT( face_list, bte_list );
  for( int f = face_list.size(); f--; )
    face_list.get_and_step()->ref_edges( child_edge_list );
  CAST_LIST_TO_PARENT( edge_list, bte_list );
    // Actuate Attributes
  DLIList<RefEntity*> ref_entity_list, temp_ref_list;
  CAST_LIST_TO_PARENT( body_list, temp_ref_list );
  ref_entity_list += temp_ref_list;
  CAST_LIST_TO_PARENT( face_list, temp_ref_list );
  CAST_LIST_TO_PARENT( edge_list, temp_ref_list );
  CAST_LIST_TO_PARENT(  vtx_list, temp_ref_list );
  import_actuate( ref_entity_list );
    // Pass back imported entities
  if( imported_entities )
    *imported_entities = ref_entity_list;
  char pre[100];
  if( body_list.size() )
    DLIList<RefVolume*> temp_vols;
    for( int nv = body_list.size(); nv > 0; nv-- )
      DLIList<RefVolume*> t2;
      body_list.get_and_step()->ref_volumes( t2 );
      temp_vols += t2;
    DLIList<CubitEntity*> temp_list;
    if( DEBUG_FLAG( 153 ) )
      CAST_LIST_TO_PARENT(body_list, temp_list);
      if( temp_list.size() == 1 )
         CubitUtil::list_entity_ids( "Constructed 1 Body: ", temp_list);
      else
        sprintf( pre, "Constructed %d Bodies: ", temp_list.size() );
        CubitUtil::list_entity_ids( pre, temp_list );
    temp_list.clean_out();
    CAST_LIST_TO_PARENT( temp_vols, temp_list );
       CubitUtil::list_entity_ids( "Constructed 1 Volume: ", temp_list);
    else
      sprintf( pre, "Constructed %d Volumes: ", temp_list.size() );
  if( face_list.size() )
    CAST_LIST_TO_PARENT(face_list, temp_list);
      CubitUtil::list_entity_ids( "Constructed 1 Free Surface: ", temp_list );
    else
      sprintf( pre, "Constructed %d Free Surfaces: ", temp_list.size() );
  if( edge_list.size() )
    CAST_LIST_TO_PARENT(edge_list, temp_list);
      CubitUtil::list_entity_ids( "Constructed 1 Free Curve: ", temp_list );
    else
      sprintf( pre, "Constructed %d Free Curves: ", temp_list.size() );
  if( vtx_list.size() )
    CAST_LIST_TO_PARENT(vtx_list, temp_list);
      CubitUtil::list_entity_ids( "Constructed 1 Free Vertex: ", temp_list );
    else
      sprintf( pre, "Constructed %d Free Vertices: ", temp_list.size() );
  return status;
Definition at line 5415 of file GeometryQueryTool.cpp.
  if (igeSet.empty())
    return false;
  DLIList<RefEntity*> children;
  entity_ptr->get_all_child_ref_entities(children);
  children.append(entity_ptr);
  while(children.size())
    if (is_intermediate_geometry(children.pop()))
      return true;
  return false;
Definition at line 5387 of file GeometryQueryTool.cpp.
  // Unfortunately, the current implementation of partition creates virtual
  // bodies as well as virtual subentities.  Thus, we have to go up the tree
  // as well as down it.
  // TODO: Partitioning HAS got to change.  KGM 2/9/06
  //get the owning bodies
  int j;
  for(j=ref_entity_list.size(); j--;)
    TopologyEntity* te = dynamic_cast<TopologyEntity*>( ref_entity_list.get_and_step());
    te->bodies( body_list );
  int i;
  for ( i = 0; i < body_list.size(); i++)
    if (GeometryQueryTool::instance()->
        is_intermediate_geometry(body_list.next(i)))
      return true;
  for ( i = 0; i < ref_entity_list.size(); i++)
        contains_intermediate_geometry(ref_entity_list.next(i)))
      return true;
  return false;
void GeometryQueryTool::delete_Body ( DLIList< Body * > &  body_list)
Deletes the input Body from the model. Its associated Solid Model entities are deleted as well, if they exist, and if remove_solid_model_entities is CUBIT_TRUE. If all went well, the input Body* reference will be set to NULL as the Body itself has been deleted. Returns CUBIT_SUCCESS if all went well, otherwise, CUBIT_FAILURE.
Definition at line 2767 of file GeometryQueryTool.cpp.
  body_list.reset();
  for (int i = body_list.size(); i--; )
    delete_Body(body_list.get_and_step());
Deletes a body.
Definition at line 2783 of file GeometryQueryTool.cpp.
  BodySM* bodysm = body_ptr->get_body_sm_ptr();
  if (!bodysm)
    PRINT_ERROR("Body %d is invalid -- no attached BodySM.\n",body_ptr->id());
  else
      // Ask owning model engine to delete the TopologyBridges
    GeometryQueryEngine* gqe = bodysm->get_geometry_query_engine();
    gqe->delete_solid_model_entities(bodysm);
      // Clean up any virtual geometry that was on the body
    for (IGESet::iterator itor = igeSet.begin(); itor != igeSet.end(); ++itor)
      (*itor)->clean_out_deactivated_geometry();
     // Check if body actually got deleted.
  return destroy_dead_entity( body_ptr );
Definition at line 4192 of file GeometryQueryTool.cpp.
   CubitStatus status = CUBIT_FAILURE;
     // Delete all RefGroups
   RefGroup::delete_all_groups();
   Body* bodyPtr = NULL;
   //DLIList<Body*> bodyList;
   //GeometryQueryTool::instance()->bodies(bodyList);
   //bodyList.reset();
   //for ( i = bodyList.size(); i > 0; i--)
   //   bodyPtr = bodyList.get_and_step();
   while( (bodyPtr = GeometryQueryTool::instance()->get_last_body() ) != NULL )
        // Now delete this Body and its underlying solid model entities
      status = GeometryQueryTool::instance()->delete_Body( bodyPtr );
      if (status == CUBIT_FAILURE)
         PRINT_ERROR("In GeometryQueryTool::delete_geometry\n"
                     "       Could not delete Body %d.\n"
                     "       The Model database is likely corrupted due"
                     " to\n       this unsuccessful deletion.\n",
                     bodyPtr->id() );
         assert( status != CUBIT_FAILURE) ;
         break;
     // Remove free-floating RefFaces
   RefFace* refFacePtr = NULL;
   //DLIList<RefFace*> refFaceList;
   //GeometryQueryTool::instance()->ref_faces(refFaceList);
   //refFaceList.reset();
   //for ( i = refFaceList.size(); i > 0; i--)
   //   refFacePtr = refFaceList.get_and_step();
   while( (refFacePtr = GeometryQueryTool::instance()->get_last_ref_face() ) != NULL )
        // NOTE-
        //   The following GeometryQueryTool call results in a call to
        //   the RefFace destructor which notifies the Model of
        //   the destruction event. Model, in turn, removes the RefFace
        //   pointer from refFaceList. Hence, the size of this list
        //   changes inside this "while" loop.
      status = GeometryQueryTool::instance()->delete_RefFace( refFacePtr );
                     "       Could not delete RefFace %d.\n"
                     "       The Model database is likely corrupted "
                     "due to\n       this unsuccessful deletion.\n",
                     refFacePtr->id());
         break;
     // Remove free-floating RefEdges
   RefEdge* refEdgePtr = NULL;
   //DLIList<RefEdge*> refEdgeList;
   //GeometryQueryTool::instance()->ref_edges(refEdgeList);
   //refEdgeList.reset();
   //for ( i = refEdgeList.size(); i > 0; i--)
     //   refEdgePtr = refEdgeList.get_and_step();
   while( (refEdgePtr = GeometryQueryTool::instance()->get_last_ref_edge() ) != NULL )
        // NOTE-
        //   the RefEdge destructor which notifies the Model of
        //   the destruction event. Model, in turn, removes the RefEdge
        //   pointer from refEdgeList. Hence, the size of this list
      status = GeometryQueryTool::instance()->delete_RefEdge( refEdgePtr );
                     "       Could not delete RefEdge %d.\n"
                     refEdgePtr->id());
         break;
     // Remove free-floating RefVertex'es
   RefVertex* refVertexPtr = NULL;
   //DLIList<RefVertex*> refVertexList;
   //GeometryQueryTool::instance()->ref_vertices(refVertexList);
   //refVertexList.reset();
   //for ( i = refVertexList.size(); i > 0; i--)
   //   refVertexPtr = refVertexList.get_and_step();
   while( (refVertexPtr = GeometryQueryTool::instance()->get_last_ref_vertex() ) != NULL )
        // NOTE-
        //   the RefVertex destructor which notifies the Model of
        //   the destruction event. Model, in turn, removes the RefVertex
        //   pointer from refVertexList. Hence, the size of this list
      status = GeometryQueryTool::instance()->delete_RefVertex( refVertexPtr );
                     "       Could not delete RefVertex %d.\n"
                     refVertexPtr->id());
         break;
     // reset counters
   RefEntityFactory::instance()->reset_ids();
Definition at line 189 of file GeometryQueryTool.cpp.
  if( NULL != instance_ )
    delete instance_;
    instance_ = NULL;
Definition at line 3024 of file GeometryQueryTool.cpp.
    // Get the list of Curves owned by the RefEdge
  BridgeManager* manager = ref_edge->bridge_manager();
  DLIList<TopologyBridge*> bridge_list(manager->number_of_bridges());
  manager->get_bridge_list(bridge_list);
    // Ask each Curve's owning engine to destroy the surface.
    TopologyBridge* bridge = bridge_list.pop();
    Curve* curve = dynamic_cast<Curve*>(bridge);
    if (!curve)
      PRINT_ERROR("RefEdge %d is invalid -- attached TopologyBridge "
                  "is not a Curve.\n", ref_edge->id());
      continue;
    curve->get_geometry_query_engine()->
      delete_solid_model_entities( curve );
    // Clean up any virtual geometry that was on the curve
    // Check if all the curves got deleted.
  return destroy_dead_entity( ref_edge );
Definition at line 2958 of file GeometryQueryTool.cpp.
  if (Body* body = dynamic_cast<Body*>(ref_entity_ptr))
    return delete_Body(body);
  if(RefFace* face = dynamic_cast<RefFace*>(ref_entity_ptr))
    return delete_RefFace(face);
  if(RefEdge* edge = dynamic_cast<RefEdge*>(ref_entity_ptr))
    return delete_RefEdge(edge);
  if(RefVertex* vtx = dynamic_cast<RefVertex*>(ref_entity_ptr))
    return delete_RefVertex(vtx);
  PRINT_ERROR("Cannot delete entity of type '%s'\n", ref_entity_ptr->class_name());
  return CUBIT_FAILURE;
Definition at line 2984 of file GeometryQueryTool.cpp.
    // Get the list of Surfaces owned by the RefFace
  BridgeManager* manager = ref_face->bridge_manager();
    // Ask each Surface's owning engine to destroy the surface.
    Surface* surface = dynamic_cast<Surface*>(bridge);
    if (!surface)
      PRINT_ERROR("RefFace %d is invalid -- attached TopologyBridge "
                  "is not a Surface.\n", ref_face->id());
      continue;
    surface->get_geometry_query_engine()->
      delete_solid_model_entities( surface );
    // Clean up any virtual geometry that was on the surface
    // Check if all the Surfaces got deleted.
  return destroy_dead_entity( ref_face );
Definition at line 3064 of file GeometryQueryTool.cpp.
    // Get the list of Points owned by the RefVertex
  BridgeManager* manager = ref_vertex->bridge_manager();
    TBPoint* point = dynamic_cast<TBPoint*>(bridge);
    if (!point)
      PRINT_ERROR("RefVertex %d is invalid -- attached TopologyBridge "
                  "is not a Point.\n", ref_vertex->id());
      continue;
    point->get_geometry_query_engine()->
      delete_solid_model_entities( point );
    // Clean up any virtual geometry that was on the Point
    // Check if all the Points got deleted.
  return destroy_dead_entity( ref_vertex );
Deletes a body.
Behaves exactly as delete_Body, but in addition checks to see if children of Body are merged. In some cases, 2 entities can be forced-merged, where they are not spatially equal. This regenerates the graphics on merged entities so they look correct after a partner has been deleted.
Definition at line 2817 of file GeometryQueryTool.cpp.
  DLIList<RefEntity*> merged_children;
  DLIList<RefFace*> faces_to_reverse;
  DLIList<RefEdge*> edges_to_reverse;
  if (!bodysm)
  else
    //get all the child entities that have been merged
    DLIList<RefEntity*> tmp_merged_children;
    MergeTool::instance()->contains_merged_children( body_ptr, tmp_merged_children );
    //get the owning bodies for each entity
    int i;
    for(i=tmp_merged_children.size(); i--;)
      RefEntity *ref_ent = tmp_merged_children.get_and_step();
      TopologyEntity *tmp_entity = CAST_TO( ref_ent, TopologyEntity);
      tmp_entity->bodies( body_list );
      //if 2 bodies own it, get body that is not "body_ptr"
      //for later graphics regeneration
      if( body_list.size() > 1 )
        if( body_list.get() != body_ptr )
          merged_children.append( ref_ent );
        else if( body_list.step_and_get() != body_ptr )
//    if( tmp_merged_children.size() )
//      MergeTool::instance()->unmerge( body_ptr );
    //fix up merged children -- some might need to be reversed
    for(i=merged_children.size(); i--; )
      RefEntity *merged_child = merged_children.get_and_step();
      BasicTopologyEntity *bte = static_cast<BasicTopologyEntity*>(merged_child);
      //get the first bridge of the entity
      DLIList<TopologyBridge*> child_bridge_list;
      bte->bridge_manager()->get_bridge_list( child_bridge_list );
      child_bridge_list.reset();
      TopologyBridge *first_bridge = child_bridge_list.get_and_step();
      //if it is not the body we're deleting just continue
      BodySM *owning_body = first_bridge->bodysm();
      if( owning_body != bodysm )
        continue;
      RefFace *ref_face = CAST_TO( merged_child, RefFace );
      if( ref_face )
        TopologyBridge *second_bridge = child_bridge_list.get_and_step();
        if( first_bridge->bridge_sense() != second_bridge->bridge_sense() )
          faces_to_reverse.append( ref_face );
        continue;
      RefEdge *ref_edge = CAST_TO( merged_child, RefEdge );
      if( ref_edge )
        //get merged_child's first topology bridge
        Curve *first_curve = CAST_TO( first_bridge, Curve );
        Curve *second_curve = CAST_TO( second_bridge, Curve );
        CubitSense relative_sense = first_curve->relative_sense( second_curve );
        if( relative_sense == CUBIT_REVERSED )
          edges_to_reverse.append( ref_edge );
        continue;
  int i;
  for( i=faces_to_reverse.size(); i--; )
    faces_to_reverse.get_and_step()->reverse_normal();
  for( i=edges_to_reverse.size(); i--; )
    edges_to_reverse.get_and_step()->reverse_tangent();
    //regenerate graphics of merged entities
  for( i=merged_children.size(); i--; )
    RefEntity* child = merged_children.get_and_step();
    AppUtil::instance()->send_event(GeometryEvent(GeometryEvent::GEOMETRY_TOPOLOGY_MODIFIED, child));
    CGMHistory::Event evt2(CGMHistory::TOPOLOGY_CHANGED, child);
    const_cast<CGMHistory&>(mHistory).add_event(evt2);
    CGMHistory::Event evt(CGMHistory::GEOMETRY_CHANGED, child);
    const_cast<CGMHistory&>(mHistory).add_event(evt);
  CubitStatus ret = destroy_dead_entity( body_ptr );
  // Send an unmerge event out for surfaces that were a part
  // of the body that was deleted.  Do this after the above
  // call to destroy_dead_entity() so that the Body
  // pointer associated with the deleted volume will no
  // longer be referenced by the merged surface.  This code
  // was added so that sidesets which are watching surface
  // modifications will know to update their data when
  // the body is deleted.
    RefFace* child = CAST_TO(merged_children.get_and_step(), RefFace);
    if(child)
      UnMergeEvent unmerge_event( child, child );
      AppUtil::instance()->send_event(unmerge_event );
  return ret;
CubitStatus GeometryQueryTool::destroy_dead_entity ( TopologyEntity topo_ent,
bool  top = true
) const
  • Remove this entity and any dead children where a dead child a) has no parent entities and b) has no topology_bridges.
Definition at line 5464 of file GeometryQueryTool.cpp.
  if (topo_ent->get_parents() || topo_ent->bridge_manager()->topology_bridge())
  topo_ent->deactivated(CUBIT_TRUE);
  CubitObservable* ob = dynamic_cast<CubitObservable*>(topo_ent);
  if (ob)
    if (dynamic_cast<RefEntity*>(topo_ent))
        // "top" indicates if this call is the topmost call to this
        // recursive function.  It should be the case that if it is
        // the topmost call and the passed entity is a RefEntity, then
        // the entity was top-level (had no parent entities in the
        // topology graph.)  For cases where dead topology is cleaned
        // out and a dead RefEntity is not-top-most, it will have some
        // parent sense entity which this function will be called on and
        // that call will be the top-most one.
      if (top)
        AppUtil::instance()->send_event(GeometryEvent(GeometryEvent::TOP_LEVEL_ENTITY_DESTRUCTED, static_cast<RefEntity*>(ob)));
        CGMHistory::Event evt(CGMHistory::TOP_LEVEL_ENTITY_DELETED, static_cast<RefEntity*>(ob));
      AppUtil::instance()->send_event(GeometryEvent(GeometryEvent::TOPOLOGY_ENTITY_DESTRUCTED, static_cast<RefEntity*>(ob)));
    else
      AppUtil::instance()->send_event(TopologyEvent(TopologyEvent::TOPOLOGY_ENTITY_DESTRUCTED, topo_ent));
  DLIList<TopologyEntity*> child_list;
  topo_ent->disconnect_all_children(&child_list);
  child_list.reset();
  for (int i = child_list.size(); i--; )
    TopologyEntity* child = child_list.get_and_step();
    TopologyEntity* child_topo_ent = dynamic_cast<TopologyEntity*>(child);
    if (child_topo_ent)
      destroy_dead_entity(child_topo_ent, false);
      if (!child_topo_ent->deactivated() &&
           child_topo_ent->bridge_manager()->number_of_bridges() > 0 &&
           child_topo_ent->get_parents() == 0 &&
           NULL != (ob = dynamic_cast<CubitObservable*>(child_topo_ent)))
        DLIList<TopologyBridge*> list1, list2;
        bool has_parents = false;
        child_topo_ent->bridge_manager()->get_bridge_list(list1);
        while (list1.size())
          list2.clean_out();
          list1.pop()->get_parents(list2);
          if (list2.size())
            has_parents = true;
        if (!has_parents)
          AppUtil::instance()->send_event(GeometryEvent(GeometryEvent::FREE_REF_ENTITY_GENERATED, static_cast<RefEntity*>(ob)));
          CGMHistory::Event evt(CGMHistory::TOP_LEVEL_ENTITY_CREATED, static_cast<RefEntity*>(ob));
  if (top)
    GeometryQueryTool::instance()->cleanout_deactivated_geometry();
  return CUBIT_SUCCESS;
Definition at line 3438 of file GeometryQueryTool.cpp.
  GeometryQueryEngine *ge_ptr;
  for( int i=topo_list.size(); i--; )
    ge_ptr = topo_list.get_and_step()->get_geometry_query_engine();
    if( ge_ptr == engine )
      return CUBIT_TRUE;
  return CUBIT_FALSE;
Definition at line 3455 of file GeometryQueryTool.cpp.
  DLIList<RefEntity*> complete_entity_list;
  // Check the check_children option and check all the children if necessary
  if (children_too)
    //Make a complete list of all the RefEntitys and their children
    DLIList<RefEntity*> temp = ref_entity_list;
    RefEntity* ref_entity_ptr;
    int i;
    for( i=ref_entity_list.size(); i--; )
      ref_entity_ptr = ref_entity_list.get_and_step();
      complete_entity_list.clean_out();
      ref_entity_ptr->get_all_child_ref_entities(complete_entity_list);
      temp += complete_entity_list;
    complete_entity_list.merge_unique(temp);
  // Now check the RefEntities for the given geometry engine
  DLIList<TopologyEntity*> te_list;
  CAST_LIST(complete_entity_list, te_list, TopologyEntity);
  return does_geom_contain_query_engine(te_list, engine);
CubitStatus GeometryQueryTool::entity_entity_distance ( GeometryEntity ge1,
GeometryEntity ge2,
CubitVector pos1,
CubitVector pos2,
double &  distance
Gets the minimum distance between two entities and the closest positions on those entities. Supports vertices, curves, surfaces, volumes and bodies.
Definition at line 4116 of file GeometryQueryTool.cpp.
  GeometryQueryEngine *gqe1 = ge1->get_geometry_query_engine();
  GeometryQueryEngine *gqe2 = ge2->get_geometry_query_engine();
  if(gqe1 != gqe2)
    if(gqe1->is_intermediate_engine())
      return gqe1->entity_entity_distance(ge1, ge2, pos1, pos2, distance);
    else if(gqe2->is_intermediate_engine())
      return gqe2->entity_entity_distance(ge1, ge2, pos1, pos2, distance);
    else
      PRINT_ERROR( "Entities do not have the same underlying geometry query engine.\n"
        "       For distance calculations, they must be the same.\n" );
  else
CubitStatus GeometryQueryTool::entity_entity_distance ( RefEntity ref_entity_ptr1,
RefEntity ref_entity_ptr2,
CubitVector pos1,
CubitVector pos2,
double &  distance
Definition at line 4081 of file GeometryQueryTool.cpp.
  DLIList<TopologyEntity*> entity_list(2);
  DLIList<TopologyBridge*> bridge_list(2);
  BasicTopologyEntity* bte1 = dynamic_cast<BasicTopologyEntity*>(ref_entity_ptr1);
  BasicTopologyEntity* bte2 = dynamic_cast<BasicTopologyEntity*>(ref_entity_ptr2);
  if (!bte1 || !bte2)
    const char* name = bte2 ? ref_entity_ptr1->class_name() : ref_entity_ptr2->class_name();
    PRINT_ERROR("Cannot calculate entity distance for entity of type '%s'\n", name);
  entity_list.append(bte1);
  entity_list.append(bte2);
  GeometryQueryEngine* gqe = common_query_engine(entity_list, bridge_list);
  if( gqe == NULL )
    PRINT_ERROR( "%s and %s do not have the same underlying geometry query engine.\n"
      "       For distance calculations, they must be the same.\n",
      ref_entity_ptr1->entity_name().c_str(), ref_entity_ptr2->entity_name().c_str() );
  GeometryEntity* geom1 = dynamic_cast<GeometryEntity*>(bridge_list.next(0));
  GeometryEntity* geom2 = dynamic_cast<GeometryEntity*>(bridge_list.next(1));
  return gqe->entity_entity_distance( geom1, geom2, pos1, pos2, distance );
CubitStatus GeometryQueryTool::entity_extrema ( RefEntity ref_entity_ptr,
const CubitVector dir1,
const CubitVector dir2,
const CubitVector dir3,
CubitVector extrema,
RefEntity *&  extrema_entity_ptr
Gets the extrema position along the first given direction. If there is more than one extrema position, the other directions will be used to determine a unique position. Directions 2 and 3 can be NULL. Entities supported include bodies, volumes, surfaces, curves and vertices.
Definition at line 3982 of file GeometryQueryTool.cpp.
  DLIList<RefEntity*> ref_entity_list;
  ref_entity_list.append( ref_entity_ptr );
  return entity_extrema( ref_entity_list, dir1, dir2, dir3, extrema,
                         extrema_entity_ptr );
CubitStatus GeometryQueryTool::entity_extrema ( DLIList< RefEntity * > &  ref_entity_list,
Gets the extrema position along the first given direction. If there is more than one extrema position, the other directions will be used to determine a unique position. Directions 2 and 3 can be NULL. Entities supported include bodies, volumes, surfaces, curves and vertices. The entity the extrema is found on is also returned.
Definition at line 4004 of file GeometryQueryTool.cpp.
  if( ref_entity_list.size() == 0 )
    PRINT_ERROR( "No entities found for extrema calculation.\n" );
  DLIList<TopologyEntity*> entity_list(ref_entity_list.size());
  DLIList<TopologyBridge*> bridge_list(ref_entity_list.size());
  DLIList<RefVolume*> ref_vols;
    // Can only do BasicTopologyEntitys.  Relace Bodys with RefVolumes.
  ref_entity_list.reset();
  for (int i = ref_entity_list.size(); i--; )
    RefEntity* entity = ref_entity_list.get_and_step();
    if (BasicTopologyEntity* bte = dynamic_cast<BasicTopologyEntity*>(entity))
      entity_list.append(bte);
      continue;
    if (Body* body = dynamic_cast<Body*>(entity))
      ref_vols.clean_out();
      body->ref_volumes(ref_vols);
      ref_vols.reset();
      for (int j = ref_vols.size(); j--;)
        entity_list.append(ref_vols.get_and_step());
      continue;
    PRINT_ERROR("Don't know how to handle entity of type '%s' in "
                "GQT::entity_extrema.\n", entity->class_name());
  if( gqe == NULL )
    PRINT_ERROR( "Entities specified for extrema do not have the same\n"
      "       underlying geometry query engine.\n"
      "       For extrema calculations, they must be the same.\n" );
    // Need GeometryEntities.
  DLIList<GeometryEntity*> geom_list(bridge_list.size());
  CAST_LIST(bridge_list, geom_list, GeometryEntity);
  // Check direction inputs
  if( dir1 == NULL )
    PRINT_ERROR( "Direction not found for extrema calculation - it is required.\n" );
  if( dir2 == NULL && dir3 )
    PRINT_ERROR( "Second direction not specified but last direction\n"
    "       was - this is not allowed for extrema calculation.\n" );
  GeometryEntity* extrema_geom = 0;
  CubitStatus status = gqe->entity_extrema( geom_list, dir1, dir2, dir3,
                                           extrema, extrema_geom );
  extrema_entity_ptr = dynamic_cast<RefEntity*>(entity_from_bridge(extrema_geom));
  return status;
Definition at line 3485 of file GeometryQueryTool.cpp.
  if( !bridge_ptr )
    return NULL;
  TBOwner* owner = bridge_ptr->owner();
  BridgeManager* bridge_manager;
  while (!(bridge_manager = dynamic_cast<BridgeManager*>(owner)))
    if (TopologyBridge* bridge = dynamic_cast<TopologyBridge*>(owner))
      owner = bridge->owner();
    else if(TBOwnerSet* set = dynamic_cast<TBOwnerSet*>(owner))
      DLIList<TopologyBridge*> list;
      set->get_owners(list);
      list.reset();
      owner = list.get()->owner();
    else
      break;
  return bridge_manager ? bridge_manager->topology_entity() : 0;
double GeometryQueryTool::estimate_merge_tolerance ( DLIList< RefVolume * > &  vol_list,
bool  accurate_in = false,
bool  report_in = false,
double  lo_val_in = -1.0,
double  hi_val_in = -1.0,
int  num_calculations_in = 10,
bool  return_calculations_in = false,
DLIList< double > *  merge_tols = NULL,
DLIList< int > *  num_proximities = NULL
Definition at line 7668 of file GeometryQueryTool.cpp.
  double return_merge_tol = -1.0;  // return value of < 0.0 will mean failure
                                   // to find a merge tolerance
  DLIList<double> local_merge_tols;
  DLIList<int> local_num_proximities;
  bool report = report_in;
  double lo_val = 0.0;
  double hi_val = get_geometry_factor()*GEOMETRY_RESABS*10.0;  // 10 * merge tol -- arbitrary
  int num_calculations = num_calculations_in;
  if(lo_val_in != -1.0)
    lo_val = lo_val_in;
  if(hi_val_in != -1.0)
    hi_val = hi_val_in;
  if(hi_val > lo_val)
    double cur_val = lo_val;
    double step = (hi_val - lo_val)/(double)num_calculations;
    int i;
    if(report)
      PRINT_INFO("\n\nLooking for merge toleance...\n\n");
      PRINT_INFO("  Possible range: %f, %f\n", lo_val, hi_val);
      PRINT_INFO("  Number of steps: %d\n\n", num_calculations+1);
    std::map <RefVertex*, DLIList<dist_vert_struct*>*> vert_dist_map;
    GeomMeasureTool::find_near_coincident_vertices_unique(vol_list, hi_val, vert_dist_map);
    int total_num_proximities = 0;
    for(i=0; i<=num_calculations; i++)
      int cur_num_proximities = 0;
      local_merge_tols.append(cur_val);
      std::map <RefVertex*, DLIList<dist_vert_struct*>*>::iterator iter;
      for(iter=vert_dist_map.begin(); iter != vert_dist_map.end(); iter++ )
        //RefVertex *vert = iter->first;
        DLIList<dist_vert_struct*> *struct_list = iter->second;
        int m;
        for(m=struct_list->size(); m>0; m--)
          dist_vert_struct *dvs = struct_list->get();
          if(dvs->dist <= cur_val)
  //          PRINT_INFO("Vertices %d and %d, distance: %.10lf\n", vert->id(), dvs->v2->id(), dvs->dist);
            struct_list->change_to(NULL);
            delete dvs;
            cur_num_proximities++;
          struct_list->step();
        struct_list->remove_all_with_value(NULL);
      total_num_proximities += cur_num_proximities;
      local_num_proximities.append(total_num_proximities);
      if(report)
        PRINT_INFO("  At merge tolerance = %f number of proximities = %d.\n", cur_val, total_num_proximities);
      cur_val += step;
      // I think all of the items in the lists should be gone
      // by now but just in case...
      while(struct_list->size())
        delete struct_list->pop();
      delete struct_list;
    local_num_proximities.reset();
    local_merge_tols.reset();
    int num_total = local_merge_tols.size();
    if(num_total > 2)
      int num_triplets = num_total - 2;
      int h, min_index, min_diff;
      DLIList<int> diffs;
      for(h=0; h<num_triplets; h++)
        int num_begin = local_num_proximities.get();
        local_num_proximities.step(2);
        int num_end = local_num_proximities.get();
        local_num_proximities.back();
        int cur_diff = num_end - num_begin;
        if(h==0)
          min_index = h;
          min_diff = cur_diff;
        else
          if(cur_diff < min_diff)
            min_index = h;
      local_merge_tols.step(min_index+1);
      return_merge_tol = local_merge_tols.get();
    else
      PRINT_ERROR("Unable to estimate merge tolerance.\n");
    // Pick off a merge tolerance.
    DLIList<int> unique_num_proximities;
    DLIList<int> unique_counts;
    DLIList<double> tmp_merge_tol_list;
    int tmp_num_proximities;
    double tmp_merge_tol;
    double cur_merge_tol = local_merge_tols.get_and_step();
    int cur_num_prox = local_num_proximities.get_and_step();
    int cur_unique_counts = 1;
    // Loop over the whole size even though we have processed the
    // first entry because we need to record the results after the
    // last entry.
    for(i=local_num_proximities.size(); i>0; i--)
      if(i>1)
        tmp_num_proximities = local_num_proximities.get_and_step();
        tmp_merge_tol = local_merge_tols.get_and_step();
      else
        // On the last time in just give it a dummy value so we
        // can record the results from the last real entry.
        tmp_num_proximities = -1;
      if(cur_num_prox == tmp_num_proximities)
        cur_unique_counts++;
      else
        tmp_merge_tol_list.append(cur_merge_tol);
        unique_counts.append(cur_unique_counts);
        unique_num_proximities.append(cur_num_prox);
        cur_num_prox = tmp_num_proximities;
        cur_merge_tol = tmp_merge_tol;
    int max_index = -1;
    int cur_max_num_counts = 0;
    unique_counts.reset();
    unique_num_proximities.reset();
    tmp_merge_tol_list.reset();
    for(i=unique_counts.size(); i>0; i--)
      int cur_num_counts = unique_counts.get();
      if(cur_num_counts > cur_max_num_counts)
        cur_max_num_counts = cur_num_counts;
        max_index = unique_counts.get_index();
      unique_counts.step();
    if(max_index > -1)
      tmp_merge_tol_list.step(max_index);
      return_merge_tol = tmp_merge_tol_list.get();
    else
    if(report)
      PRINT_INFO("\nEstimated merge tolerance: %f\n", return_merge_tol);
  else
    PRINT_ERROR("Range low value is larger than range high value.\n");
  return return_merge_tol;
CubitStatus GeometryQueryTool::export_solid_model ( DLIList< RefEntity * > &  ref_entity_list,
const char *  filename,
int &  num_ents_exported,
const CubitString cubit_version,
ModelExportOptions export_options
Export entities to a solid model file.
  • ref_entity_list A list of RefEntities to be exported or saved to a file.
  • file_name The name of the file to write to.
  • file_type An optional type of file.
  • logfile_name Optional - name of logfile.
    Returns:
    CubitStatus - success/failure
    Export the current CUBIT geometry (everything in the Model) to a solid model format. Valid file types are:
"IGES" -- IGES file "STEP" -- STEP file No logfile gets created for SAB/SAT files, but for IGES and STEP file a logfile always gets created. Default filenames are assigned if one is not given (iges_export.log, step_export.log).
The function returns CUBIT_FAILURE if anything goes wrong with export - improper file type, inaccessible file, mismatch between the underlying representation and file type. It returns CUBIT_SUCCESS if everything goes well.
NOTE: if the ref_entity_list is empty, GeometryQueryTool gets the list of all entities in the current model, including free ref entities
Definition at line 329 of file GeometryQueryTool.cpp.
  if (0 == gqeList.size())
    PRINT_WARNING("No active geometry engine.\n");
  int i;
  if (ref_entity_list.size() == 0) {
      // All bodies are to be exported
    RefEntityFactory::instance()->ref_entity_list("Body",
                                                  ref_entity_list);
      // add free ref entities
    get_free_ref_entities(ref_entity_list);
    // Get TopologyBridges from RefEntities.
  DLIList<TopologyBridge*> bridge_list(ref_entity_list.size()),
                           parent_bridges, ref_ent_bridges;
  for( i = ref_entity_list.size(); i--; )
    ref_ent_bridges.clean_out();
    TopologyEntity* topo_ptr = dynamic_cast<TopologyEntity*>(ref_entity_list.get_and_step());
    if( topo_ptr )
      topo_ptr->bridge_manager()->get_bridge_list( ref_ent_bridges );
    bridge_list += ref_ent_bridges;
    // Get all child RefEntities
  DLIList<RefEntity*> child_list;
  RefEntity::get_all_child_ref_entities( ref_entity_list, child_list );
    // Scan for free-but-merged entities in child list.
  child_list.reset();
  for (i = child_list.size(); i--; )
    TopologyEntity* topo_ptr = dynamic_cast<TopologyEntity*>(child_list.get_and_step());
    assert(!!topo_ptr);
    ref_ent_bridges.reset();
    for (int j = ref_ent_bridges.size(); j--; )
      TopologyBridge* bridge = ref_ent_bridges.get_and_step();
      parent_bridges.clean_out();
      bridge->get_parents(parent_bridges);
      if (parent_bridges.size() == 0)
        bridge_list.append_unique(bridge);
    // Merge lists so we have one big list of every
    // RefEntity to be saved.
  for(i = ref_entity_list.size(); i--; )
    ref_entity_list.get_and_step()->marked(1);
  for(i = child_list.size(); i--; )
    child_list.get_and_step()->marked(0);
    RefEntity* ent = ref_entity_list.get_and_step();
    if( ent->marked() )
      ent->marked(0);
      child_list.append(ent);
  // Make a copy of the bridge list to be used below in
  // removing the virtual geometry attributes.  We can't
  // use the original bridge list because it gets emptied.
  DLIList<TopologyBridge*> copy_of_bridge_list = bridge_list;
  int num_input_entities = bridge_list.size();
    // now call auto update on this combined list; this will update both visible
    // and hidden entities; the combined list should be used here, but only the
    // export list should be exported (some of the hidden entities might be directly
    // related to other entities on the export list, and we want to avoid exporting
    // those entities twice)
  CubitAttribUser::auto_update_cubit_attrib(child_list);
    // Save virtual.
  IGESet::reverse_iterator itor;
  for (itor = igeSet.rbegin(); itor != igeSet.rend(); ++itor)
    (*itor)->export_geometry(bridge_list);
  CubitStatus result = CUBIT_SUCCESS, temp_result;
  if( !bridge_list.size() )
//   GeometryQueryEngine* gqe = NULL;
  //we're just going to mess with MBG stuff right now
  gqeList.reset();
  int num_ents_before = bridge_list.size();
  temp_result = gqeList.get()->export_solid_model(bridge_list, filename, filetype,
                                        cubit_version, export_options );
  if (temp_result == CUBIT_SUCCESS )
    result = temp_result;
  //if all geometry wasn't exported, warn user and print out
  //what wasn't
  if( bridge_list.size() != 0 )
    if( bridge_list.size() == num_ents_before )
      PRINT_ERROR("No geometry exported.  Must set geometry engine to another type.\n");
    else
      PRINT_WARNING("Not all geometry could be handled for save.\n");
    PRINT_INFO("Set the geometry engine appropriately to export the following geometry:\n");
    int k;
    for(k=bridge_list.size(); k--; )
      TopologyEntity *te = bridge_list.get()->topology_entity();
      if( te )
        RefEntity *ref_ent = CAST_TO( te, RefEntity );
        if( ref_ent )
          GeometryQueryEngine *gqe = bridge_list.get()->get_geometry_query_engine();
          PRINT_INFO("%s is of Geometry Engine type %s\n",
          ref_ent->entity_name().c_str(), gqe->modeler_type() );
      bridge_list.step();
    // clean off attributes off of underyling virtual geometry
    (*itor)->remove_attributes(copy_of_bridge_list);
  CubitAttribUser::clear_all_simple_attrib(child_list);
  num_ents_exported = num_input_entities - bridge_list.size();
  gqeList.reset();
  return result;
char *&  p_buffer,
int &  n_buffer_size,
bool  b_export_buffer
Import all or specified entities in a solid model file.
  • file_ptr A pointer to the file to read (can be NULL for IGES and STEP files).
  • file_type Type of file.
  • heal_step - auto-healing of step bodies on import. This is recommended because they always need it.
  • import_bodies (etc...) Should bodies be import.
    Returns:
    Reads in geometry and creates the necessary Reference entities associated with the input geometry. Valid file types are:
Function can selectively import solid bodies, free surfaces, free curves, or free vertices. For example, the user may not want to import any free entities.
The function returns CUBIT_FAILURE if anything goes wrong with import - improper file type, inaccessible file, mismatch between the underlying representation and file type. It returns CUBIT_SUCCESS if everything goes well. Import all or specified entities in a solid model file.
    Returns:
Definition at line 483 of file GeometryQueryTool.cpp.
  int i;
                                                  ref_entity_list);
  for( i = ref_entity_list.size(); i--; ) {
    if( topo_ptr )
  child_list.reset();
    assert(!!topo_ptr);
    if( ent->marked() )
      ent->marked(0);
  /*int num_input_entities =*/ bridge_list.size();
    // Save virtual.
  gqeList.reset();
  temp_result = gqeList.get()->export_solid_model(bridge_list, p_buffer,
                                                  n_buffer_size, b_export_buffer);
  //what wasn't
    else
    int k;
      if( te )
        if( ref_ent )
      bridge_list.step();
  //num_ents_exported = num_input_entities - bridge_list.size();
  gqeList.reset();
  return result;
void GeometryQueryTool::find_floating_volumes ( DLIList< RefVolume * > &  vol_list,
DLIList< RefVolume * > &  floating_list
Find all of the volumes that do not contain any merged entities.
Definition at line 7872 of file GeometryQueryTool.cpp.
  int i;
  for(i=vol_list.size(); i>0; i--)
    bool floating = true;
    RefVolume *vol = vol_list.get_and_step();
    DLIList<RefEdge*> vol_curves;
    DLIList<RefVertex*> vol_verts;
    DLIList<RefFace*> vol_surfs;
    vol->ref_edges(vol_curves);
    vol->ref_faces(vol_surfs);
    vol->ref_vertices(vol_verts);
    int j;
    for(j=vol_surfs.size(); j>0 && floating; j--)
      RefFace *cur_surf = vol_surfs.get_and_step();
      if(cur_surf->is_merged())
        floating = false;
    for(j=vol_curves.size(); j>0 && floating; j--)
      RefEdge *cur_curve = vol_curves.get_and_step();
      if(cur_curve->is_merged())
        floating = false;
    for(j=vol_verts.size(); j>0 && floating; j--)
      RefVertex *cur_vert = vol_verts.get_and_step();
      if(cur_vert->is_merged())
        floating = false;
    if(floating)
      floating_list.append(vol);
  floating_list.uniquify_ordered();
CoEdgeSM * GeometryQueryTool::find_merged_coedgesm ( Surface on_this_surface,
CoEdgeSM merged_with_this
) const [private]
Definition at line 1669 of file GeometryQueryTool.cpp.
    // Get the relative sense of the merged surfaces
  DLIList<Surface*> coedge_surfaces(1);
  merged_with_this->surfaces( coedge_surfaces );
  if( coedge_surfaces.size() != 1 )
    return 0;
  bool surfaces_reversed =
    (coedge_surfaces.get()->bridge_sense() != on_this_surf->bridge_sense());
    // Get the Curve merge partner from the CoEdgeSM merge partner
  DLIList<Curve*> coedge_curves(1);
  merged_with_this->curves( coedge_curves );
  if( coedge_curves.size() != 1 )
    assert(coedge_curves.size() == 1);
    return 0;
  Curve* merged_curve = coedge_curves.get();
    // If the curve doesn't have a bridge manager, it is
    // not merged.
  if (!merged_curve->bridge_manager())
    return 0;
    // Get all curves merged with the merged_curve
  int num_bridges = merged_curve->bridge_manager()->number_of_bridges();
  DLIList<TopologyBridge*> curve_bridges( num_bridges );
  merged_curve->bridge_manager()->get_bridge_list( curve_bridges );
    // Loop through Curves, looking for the Curve with the
    // parent CoEdgeSM we want.  This loop should be
    // roughly O(1) for manifold geometry (and most non-
    // manifold geometry), where n is the number of curves
    // merged together in the RefEdge.  For manifold
    // geometry, there are never more than 2 CoEdgeSMs per
    // Curve.  For most models, n is <= 4, so this entire
    // function can be considered O(1) for most models.
  DLIList<CoEdgeSM*> curve_coedges(2);
  curve_bridges.reset();
  for( int i = curve_bridges.size(); i--; )
    TopologyBridge* curve = curve_bridges.get_and_step();
    curve_coedges.clean_out();
    curve->coedgesms( curve_coedges );
    curve_coedges.reset();
    for( int j = curve_coedges.size(); j--; )
      CoEdgeSM* coedgesm = curve_coedges.get_and_step();
        // Get parent Surface of CoEdgeSM
      coedge_surfaces.clean_out();
      coedgesm->surfaces( coedge_surfaces );
      assert( coedge_surfaces.size() == 1 );
        // Is the parent Surface the one we are looking for?
      if( coedge_surfaces.get() == on_this_surf )
          // Curve may occur in surface twice for non-manifold
          // topology.  We need to make sure we have the CoEdgeSM
          // with the correct sense.
          // Are the curves reversed wrt to each other?
        bool curves_reversed =
          (merged_curve->bridge_sense() != curve->bridge_sense());
          // Should this coedgesm be reversed wrt to the merge partner?
        bool should_be_reversed = (curves_reversed != surfaces_reversed);
          // Are the coedgesm actually reversed wrt to each other?
        bool are_reversed = (merged_with_this->sense() != coedgesm->sense());
          // Do the coedges have the appropriate senses
        if( should_be_reversed == are_reversed )
          return  coedgesm;
    } // for(j = curve_coedgesms)
  } // for(i = curve_coedges)
  return 0;
void GeometryQueryTool::find_nonmanifold_curves ( DLIList< RefVolume * > &  vol_list,
DLIList< RefEdge * > &  curve_list
Find the nonmanifold curves in the passed-in volumes based on what is merged.
Definition at line 7636 of file GeometryQueryTool.cpp.
  int i;
    int j;
    for(j=vol_curves.size(); j>0; j--)
        DLIList<RefFace*> curve_faces;
        cur_curve->ref_faces(curve_faces);
        bool merged_face_exists = false;
        while(curve_faces.size() && !merged_face_exists)
          RefFace *cur_face = curve_faces.pop();
          if(cur_face->is_merged())
            merged_face_exists = true;
        if(!merged_face_exists)
          curve_list.append(cur_curve);
  curve_list.uniquify_ordered();
void GeometryQueryTool::find_nonmanifold_vertices ( DLIList< RefVolume * > &  vol_list,
DLIList< RefVertex * > &  vertex_list
Find the nonmanifold vertices in the passed-in volumes based on what is merged.
Definition at line 7911 of file GeometryQueryTool.cpp.
  int i;
    int j;
    for(j=vol_verts.size(); j>0; j--)
        DLIList<RefEdge*> vert_edges;
        cur_vert->ref_edges(vert_edges);
        bool merged_edge_exists = false;
        while(vert_edges.size() && !merged_edge_exists)
          RefEdge *cur_edge = vert_edges.pop();
          if(cur_edge->is_merged())
            merged_edge_exists = true;
        if(!merged_edge_exists)
          vertex_list.append(cur_vert);
  vertex_list.uniquify_ordered();
CubitStatus GeometryQueryTool::fire_ray ( CubitVector origin,
CubitVector direction,
DLIList< RefEntity * > &  at_entity_list,
DLIList< double > &  ray_params,
int  max_hits = 0,
double  ray_radius = 0.0,
DLIList< RefEntity * > *  hit_entity_list_ptr = 0
Fire a ray at entities, passing back distances of hits and entities hit.
  • origin origin of ray
  • direction direction of ray
  • at_entity_list entities to fire ray at
  • ray_params returned array of parameters (distances) along ray at which entities were hit
  • max_hits maximum number of hits to return, 0 = unlimited (default)
  • ray_radius radius of ray to use for intersecting entities, 0 = use engine default
  • hit_entity_list (pointer) entities hit by ray (list length same as ray_params), default NULL
    Returns:
    - error flag
    Fire a ray at specified entities, returning the parameters (distances) along the ray and optionally the entities hit; return CUBIT_FAILURE if error. Returned lists are appended to.
Definition at line 643 of file GeometryQueryTool.cpp.
  int i;
  // Do this in a way to account for the case if they happen to be from
  // different geometry engines (could easily occur with virtual geometry)
  DLIList<TopologyEntity*> te_fire_at_list;
  DLIList<TopologyEntity*> te_hit_entity_list;
  DLIList<TopologyEntity*> *te_hit_entity_list_ptr = 0;
  if( hit_entity_list_ptr )
    te_hit_entity_list_ptr = &te_hit_entity_list;
  GeometryQueryEngine *gqe = 0;
  GeometryQueryEngine *gqe_last = 0;
  RefEntity *ref_entity_ptr;
  TopologyEntity *topo_ptr;
  int loc_max_hits = max_hits;
  CubitBoolean hits_limited = CUBIT_FALSE;
  if( max_hits > 0 )
    hits_limited = CUBIT_TRUE;
  // Note we care about order
  at_entity_list.reset();
  for( i=at_entity_list.size(); i--; )
    ref_entity_ptr = at_entity_list.get_and_step();
    topo_ptr = CAST_TO( ref_entity_ptr, TopologyEntity );
    if( !topo_ptr )
      PRINT_ERROR( "Couldnt get topo_ptr\n" );
      continue;
    gqe = topo_ptr->get_geometry_query_engine();
    if( !gqe )
      PRINT_ERROR( "Unable to find geometry engine associated with an entity!\n" );
    if( !gqe_last )
      gqe_last = gqe;
    if( gqe != gqe_last )
      if( hits_limited == CUBIT_TRUE )
        loc_max_hits = max_hits - ray_params.size();
        if( loc_max_hits <= 0 )
          break;
      if( fire_ray( origin, direction, te_fire_at_list, ray_params,
        loc_max_hits, ray_radius, te_hit_entity_list_ptr ) == CUBIT_FAILURE )
      // Reset
      gqe_last = gqe;
      te_fire_at_list.clean_out();
    te_fire_at_list.append( topo_ptr );
  // Do the last ray fire, if necessary
  if( hits_limited==CUBIT_FALSE || loc_max_hits>0 )
    // Find RefEntities from TopologyEntities
    te_hit_entity_list.reset();
    for( i=te_hit_entity_list.size(); i--; )
      topo_ptr = te_hit_entity_list.get_and_step();
      if( !topo_ptr )
        hit_entity_list_ptr->append( 0 );
        continue;
      ref_entity_ptr = CAST_TO( topo_ptr, RefEntity );
      hit_entity_list_ptr->append( ref_entity_ptr );
  // Now, make sure we don't have more hits than asked for
    if( ray_params.size() <= max_hits )
    for( i=ray_params.size()-max_hits; i--; )
      ray_params.last();
      ray_params.remove();
        hit_entity_list_ptr->last();
        hit_entity_list_ptr->remove();
DLIList< TopologyEntity * > &  at_entity_list,
int  max_hits = 0,
DLIList< TopologyEntity * > *  hit_entity_list_ptr = 0
    Returns:
    - error flag
    Fire a ray at specified entities, returning the parameters (distances) along the ray and optionally the entities hit; return CUBIT_FAILURE if error. Returned lists are appended to. NOTE: ALL ENTITIES MUST BE FROM THE SAME GEOMETRY ENGINE.
Definition at line 776 of file GeometryQueryTool.cpp.
  if( !at_entity_list.size() )
  TopologyEntity *topo_ptr = at_entity_list.get();
  GeometryQueryEngine *gqe = topo_ptr->get_geometry_query_engine();
  if( !gqe )
  DLIList<TopologyBridge*> tb_list;
  int i;
    topo_ptr = at_entity_list.get_and_step();
    topo_ptr->bridge_manager()->get_bridge_list( bridge_list );
    tb_list.append( bridge_list.get() );
  // Setup temporary variables to pass
  DLIList<double> tmp_ray_params;
  DLIList<TopologyBridge*> tb_hit_list;
  DLIList<TopologyBridge*> *tb_hit_list_ptr = NULL;
    tb_hit_list_ptr = &tb_hit_list;
  // Do the ray fire.  Note we will sort the hits by distance and append to the output lists.
  if( gqe->fire_ray( origin, direction, tb_list, tmp_ray_params,
    max_hits, ray_radius, tb_hit_list_ptr ) == CUBIT_FAILURE )
  tmp_ray_params.reset();
  if( tb_hit_list_ptr) tb_hit_list_ptr->reset();
  // Append to output lists
  ray_params += tmp_ray_params;
  // Get the TE's from the TopologyBridges
      // First need to make sure that the entities hit are visible...entities hit
      // may be hidden under virtual entities....we need to get the visible
      // entities.
      DLIList<TopologyBridge*> vis_tb_hit_list;
      DLIList<CubitVector*> cv_list;
      CubitVector *loc_ptr;
      double param;
      for( i=tmp_ray_params.size(); i--; )
          param = tmp_ray_params.get_and_step();
          loc_ptr = new CubitVector;
          origin.next_point( direction, param, *loc_ptr );
          cv_list.append( loc_ptr );
      TopologyBridge *bridge_ptr;
      for( i=0; i<tb_hit_list_ptr->size(); i++ )
          bridge_ptr = tb_hit_list_ptr->get_and_step();
          TopologyBridge *visible_tb = NULL;
          TBOwner* o2 = bridge_ptr->owner();
          bool broke_early = false;
          BridgeManager* bridge_manager2;
          while (!(bridge_manager2 = dynamic_cast<BridgeManager*>(o2)))
              if (TopologyBridge* bridge2 = dynamic_cast<TopologyBridge*>(o2))
                  GeometryQueryEngine* gqe2 = bridge2->get_geometry_query_engine();
                  //Let the VQE handle the work
                  visible_tb = gqe2->get_visible_entity_at_point(bridge_ptr, cv_list[i]);
                  if (visible_tb)
                      o2 = visible_tb->owner();
                  else
                      o2 = bridge2->owner();
              else if(TBOwnerSet* set = dynamic_cast<TBOwnerSet*>(o2))
                  DLIList<TopologyBridge*> list2;
                  set->get_owners(list2);
                  list2.reset();
                  // This had better be the Virtual QE.
                  GeometryQueryEngine* gqe2 = list2.get()->get_geometry_query_engine();
                  if (visible_tb)
                  else
                      broke_early = true;
                      break;
              else
                  broke_early = true;
                  break;
          if (!broke_early)
              visible_tb = bridge_manager2->topology_bridge();
          if( visible_tb )
              topo_ptr = visible_tb->topology_entity();
              hit_entity_list_ptr->append( topo_ptr );
          else
      // Free memory
      while( cv_list.size() ) delete cv_list.pop();
  // Sort ray_params (low to high) and sort hit_entity_list_ptr to match
  //  This will ensure entities are in order of who got hit first
  //  Do the sort by adding to a map (should auto-sort)
  std::map<double, TopologyEntity*> temp_map;
  for (i=0; i<ray_params.size(); i++)
      temp_map.insert(std::map<double,
    TopologyEntity*>::value_type( ray_params.get_and_step(),
    hit_entity_list_ptr ? hit_entity_list_ptr->get_and_step() : 0 ) );
  // The map should be sorted, so iterate through it and add to the official lists
  ray_params.clean_out();
  if( hit_entity_list_ptr) hit_entity_list_ptr->clean_out();
  std::map<double, TopologyEntity*>::iterator iter;
  for (iter=temp_map.begin(); iter != temp_map.end(); iter++)
      ray_params.append(iter->first);
      if( hit_entity_list_ptr) hit_entity_list_ptr->append(iter->second);
void GeometryQueryTool::geom_debug ( DLIList< TopologyEntity * >  topo_list) [static]
Debugging function.
Definition at line 3135 of file GeometryQueryTool.cpp.
     //This function was created March 1998 to assist in debugging
     //the unmerge command.  When sufficient time has passed and
     //it is no longer needed, this function can be deleted.
     //SR Jankovich
   for( int i = topo_list.size(); i > 0; i-- )
      TopologyEntity *topo_entity = topo_list.get_and_step();
      if( !topo_entity )
          return;
      RefEntity *ref_entity = CAST_TO( topo_entity, RefEntity );
      if( !ref_entity )
          return;
      PRINT_INFO( "%s\n", ref_entity->entity_name().c_str() );
      DLIList<TopologyEntity*> next_topo_list;
      next_topo_list.clean_out();
      if( CAST_TO( ref_entity, Body ) )
        DLIList<CoVolume*> co_vol_list;
        if( !topo_entity->co_volumes( co_vol_list ) )
           return;
        for( int j = co_vol_list.size(); j > 0; j-- )
          CoVolume *co_vol = co_vol_list.get_and_step();
          PRINT_INFO( "   CoVolume %d (not id)\n",
                      co_vol_list.size() - j );
          TopologyEntity *temp_topo = CAST_TO( co_vol, TopologyEntity );
          if( !temp_topo )
             return;
          DLIList<RefVolume*> vol_list;
          if( !temp_topo->ref_volumes( vol_list ) )
             return;
          for( int k = vol_list.size(); k > 0; k-- )
            PRINT_INFO( "      %s\n", vol->entity_name().c_str() );
            TopologyEntity *next_topo = CAST_TO( vol, TopologyEntity );
            next_topo_list.append( next_topo );
        GeometryQueryTool::geom_debug( next_topo_list );
      else if( CAST_TO( ref_entity, RefVolume ) )
        DLIList<Shell*> shell_list;
        if( !topo_entity->shells( shell_list ) )
           return;
        for( int m = shell_list.size(); m > 0; m-- )
          Shell *shell = shell_list.get_and_step();
          PRINT_INFO( "   Shell %d (not id)\n", shell_list.size() - m );
          TopologyEntity *group_topo = CAST_TO( shell, TopologyEntity );
          if( !group_topo )
             return;
          DLIList<CoFace*> co_face_list;
          if( !group_topo->co_faces( co_face_list ) )
             return;
          for( int j = co_face_list.size(); j > 0; j-- )
            CoFace *co_face = co_face_list.get_and_step();
            PRINT_INFO( "      CoFace %d (not id)\n",
                        co_face_list.size() - j );
            TopologyEntity *temp_topo = CAST_TO( co_face, TopologyEntity );
            if( !temp_topo )
               return;
            if( !temp_topo->ref_faces( face_list ) )
               return;
            for( int k = face_list.size(); k > 0; k-- )
              RefFace *face = face_list.get_and_step();
              PRINT_INFO( "         %s\n", face->entity_name().c_str() );
              TopologyEntity *next_topo = CAST_TO( face, TopologyEntity );
      else if( CAST_TO( ref_entity, RefFace ) )
        DLIList<Loop*> loop_list;
        if( !topo_entity->loops( loop_list ) )
           return;
        for( int m = loop_list.size(); m > 0; m-- )
          Loop *loop = loop_list.get_and_step();
          PRINT_INFO( "   Loop %d (not id)\n", loop_list.size() - m );
          TopologyEntity *group_topo = CAST_TO( loop, TopologyEntity );
          if( !group_topo )
             return;
          DLIList<CoEdge*> co_edge_list;
          if( !group_topo->co_edges( co_edge_list ) )
             return;
          for( int j = co_edge_list.size(); j > 0; j-- )
            CoEdge *co_edge = co_edge_list.get_and_step();
            PRINT_INFO( "      CoEdge %d (not id)\n",
                        co_edge_list.size() - j );
            TopologyEntity *temp_topo = CAST_TO( co_edge, TopologyEntity );
            if( !temp_topo )
               return;
            if( !temp_topo->ref_edges( edge_list ) )
               return;
            for( int k = edge_list.size(); k > 0; k-- )
              RefEdge *edge = edge_list.get_and_step();
              PRINT_INFO( "         %s\n", edge->entity_name().c_str() );
              TopologyEntity *next_topo = CAST_TO( edge, TopologyEntity );
      else if( CAST_TO( ref_entity, RefEdge ) )
        DLIList<Chain*> chain_list;
        if( !topo_entity->chains( chain_list ) )
           return;
        for( int m = chain_list.size(); m > 0; m-- )
          Chain *chain = chain_list.get_and_step();
          PRINT_INFO( "   Chain %d (not id)\n", chain_list.size() - m );
          TopologyEntity *group_topo = CAST_TO( chain, TopologyEntity );
          if( !group_topo )
             return;
          DLIList<CoVertex*> co_vertex_list;
          if( !group_topo->co_vertices( co_vertex_list ) )
             return;
          for( int j = co_vertex_list.size(); j > 0; j-- )
            CoVertex *co_vertex = co_vertex_list.get_and_step();
            PRINT_INFO( "      CoVertex %d (not id)\n",
                        co_vertex_list.size() - j );
            TopologyEntity *temp_topo = CAST_TO( co_vertex, TopologyEntity );
            if( !temp_topo )
               return;
            DLIList<RefVertex*> vertex_list;
            if( !temp_topo->ref_vertices( vertex_list ) )
               return;
            for( int k = vertex_list.size(); k > 0; k-- )
              RefVertex *vertex = vertex_list.get_and_step();
                          vertex->entity_name().c_str() );
              TopologyEntity *next_topo = CAST_TO( vertex, TopologyEntity );
      else if( CAST_TO( ref_entity, RefVertex ) )
         ;//Do nothing
      else
         PRINT_INFO( "UNKNOWN ENTITY TYPE!!!\n" );
double GeometryQueryTool::geometric_angle ( RefEdge ref_edge_1,
RefEdge ref_edge_2,
RefFace ref_face
Calculates internal surface angles given 2 refedges on the surface. CoEdge version correctly handles curves in a surface twice.
Definition at line 3319 of file GeometryQueryTool.cpp.
     // calculates internal surface angles given 2 refedges on the surface
   CoEdge *co_edge_1, *co_edge_2;
     //First get the two coedges that corrispond to the edges sent into
     //this function.  The two coedges are found from the ref_face's loop
     //where co_edge_1 is followed by co_edge_2 in the loop and co_edge_1 is
     //associated with ref_edge_1 while co_edge_2 is associated with
     //ref_edge_2.
   ref_edge_1->get_two_co_edges( ref_edge_2, ref_face, co_edge_1,
                                 co_edge_2 );
   return geometric_angle( co_edge_1, co_edge_2 );
double GeometryQueryTool::geometric_angle ( CoEdge co_edge_1,
CoEdge co_edge_2
Calculates internal surface angles given 2 refedges on the surface. This version correctly handles curves in a surface twice.
Definition at line 3336 of file GeometryQueryTool.cpp.
  RefEdge *ref_edge_1 = co_edge_1->get_ref_edge_ptr();
  RefEdge *ref_edge_2 = co_edge_2->get_ref_edge_ptr();
    // return 2 pi for the tip of a hard line.
  if ( co_edge_1 != co_edge_2 && ref_edge_1 == ref_edge_2 )
    return 2.0 * CUBIT_PI;
  RefVertex *ref_vertex =
    co_edge_1->get_sense() == CUBIT_FORWARD ?
    ref_edge_1->end_vertex() :
    ref_edge_1->start_vertex();
  //RefVertex *junk_vertex1 = ref_edge_2->start_vertex();
  //RefVertex *junk_vertex2 = ref_edge_2->end_vertex();
  //CubitSense junk_sense = co_edge_2->get_sense();
  assert( ref_vertex ==
          ( co_edge_2->get_sense() == CUBIT_FORWARD ?
            ref_edge_2->start_vertex() :
            ref_edge_2->end_vertex() ) );
     // coordinates of common point
  CubitVector vertex_point = ref_vertex->coordinates();
    // Find normal to the the face at the common vertex of
    // the refedges. Use loop sense to artificially switch inner loops.
    // Use intrinsic normal.
  RefFace *ref_face = co_edge_1->get_ref_face();
  CubitVector normal = ref_face->normal_at(vertex_point, NULL);
    // Find directed tangents to determine interior angle
    // Use sense of edge with respect to this face's loop.
  CubitVector tangent_1, tangent_2;
  ref_edge_1->tangent( vertex_point, tangent_1 );
  ref_edge_2->tangent( vertex_point, tangent_2 );
  if ( co_edge_1->get_sense() == CUBIT_REVERSED )
    tangent_1 = -tangent_1;
  if ( co_edge_2->get_sense() == CUBIT_REVERSED )
    tangent_2 = -tangent_2;
    //  At this point we have the tangents going in the correct loop
    //  sense.
    //  Now get tangent pointing away from the center for the correct
    //  angle
    // Return angle from given tangents and normal to face
  double angle = normal.vector_angle( tangent_2, tangent_1 );
  if ( angle*180.0/CUBIT_PI >  360.0 - GEOMETRY_RESABS )
      //try other points to make sure this is going the right way.
    CubitVector new_loc_1, new_loc_2;
    if ( ref_edge_1->start_vertex() == ref_vertex )
      ref_edge_1->position_from_fraction(0.01,
                                    new_loc_1);
    else
      ref_edge_1->position_from_fraction(0.99,
                                    new_loc_1);
    if ( ref_edge_2->start_vertex() == ref_vertex )
      ref_edge_2->position_from_fraction(0.01,
                                    new_loc_2);
    else
      ref_edge_2->position_from_fraction(0.99,
                                    new_loc_2);
      //Now just do the exact same thing as above but
      //use these new points...
    ref_edge_1->tangent( new_loc_1, tangent_1 );
    ref_edge_2->tangent( new_loc_2, tangent_2 );
    if ( angle < CUBIT_PI )
      angle = 0.0;
    else
      angle = 2.0*CUBIT_PI;
  return angle;
Get the major/minor version of the active geometry engine.
Definition at line 3544 of file GeometryQueryTool.cpp.
  if (gqeList.size())
    gqeList.reset();
    return gqeList.get()->get_allint_version();
  else
    PRINT_WARNING("No active geometry engine.");
    return 0;
Get entity by id.
Definition at line 4450 of file GeometryQueryTool.cpp.
void GeometryQueryTool::get_connected_free_ref_entities ( RefEntity entity,
const int  merge_option,
DLIList< Body * > &  body_list,
DLIList< RefFace * > &  ref_face_list,
DLIList< RefEdge * > &  ref_edge_list,
DLIList< RefVertex * > &  ref_vertex_list
Get the free entities connected to, but not necessarily vertically related to, the entity. - If merge_option, then take into account the fact that the model may be merged (it's slower that way).
Definition at line 5109 of file GeometryQueryTool.cpp.
  body_list.clean_out();
  ref_face_list.clean_out();
  ref_edge_list.clean_out();
  ref_vertex_list.clean_out();
  if ( !entity )
    return;
   // cases are different enough, just do something totally different
  if ( !merge_option  )
      // get top level entities
    TopologyEntity *source_entity = CAST_TO(entity, TopologyEntity);
    Body *body = CAST_TO( source_entity, Body );
    if( body )
      body_list.append( body );
    else
        //  get attached bodies, if any
      source_entity->bodies( body_list );
    if(body_list.size() == 0)
      RefEdge* ref_edge = CAST_TO(source_entity, RefEdge);
      if ( ref_edge )
        ref_edge_list.append( ref_edge );
      else
        source_entity->ref_edges( ref_edge_list );
      if ( ref_edge_list.size() == 0 )
        RefVertex *vert = CAST_TO( source_entity, RefVertex );
        if ( vert )
          ref_vertex_list.append( vert );
    // this is the easy case, we're all done
    return;
    // merge_option == 1
  DLIList <TopologyEntity*> source_list;
  DLIList <RefEntity*> source_entity_list;
  int i;
  DLIList <RefEntity*> free_list;
  DLIList<TopologyBridge*> bridge_list;
  TopologyEntity *topo_entity = CAST_TO( entity, TopologyEntity );
  source_list.append( topo_entity );
  DLIList<RefEntity*> entity_list;
  do
      // get vertices (bottom level ref entities)
    source_entity_list.clean_out();
    for (i = source_list.size(); i--; )
      TopologyEntity *source_entity = source_list.get_and_step();
      DLIList<RefVertex*> local_vert_list;
      DLIList<RefEntity*> tmp_source_entity_list;
      source_entity->ref_vertices( local_vert_list );
      if(local_vert_list.size() == 0)
        DLIList<RefEdge*> local_edge_list;
        source_entity->ref_edges(local_edge_list);
        if(local_edge_list.size() == 0)
          DLIList<RefFace*> local_face_list;
          source_entity->ref_faces(local_face_list);
          if(local_face_list.size() > 0)
            CAST_LIST( local_face_list, tmp_source_entity_list, RefEntity);
            source_entity_list += tmp_source_entity_list;
        else
          CAST_LIST( local_edge_list, tmp_source_entity_list, RefEntity);
      else
        CAST_LIST( local_vert_list, tmp_source_entity_list, RefEntity);
    source_list.clean_out();
    for ( i = source_entity_list.size(); i--; )
      RefEntity *source_entity = source_entity_list.get_and_step();
        // get all upwards related ref entities
        // get the bodies, too!
      source_entity->get_all_parent_ref_entities( entity_list, CUBIT_TRUE );
      entity_list.append( source_entity );
        // check each one to see if it is a new top level in the solid
        // modeller
      int j;
      for ( j = entity_list.size(); j--; )
        // entity is top level if it has a topology bridge that has a bodysm
        RefEntity *ref_entity = entity_list.get_and_step();
        if ( !ref_entity->marked() )
          bridge_list.clean_out();
          topo_entity = CAST_TO( ref_entity, TopologyEntity );
          topo_entity->bridge_manager()->get_bridge_list(bridge_list);
          int k;
          bool no_parents = true;
          for ( k = bridge_list.size(); k--; )
            TopologyBridge* bridge = bridge_list.get_and_step();
            DLIList<TopologyBridge*> parents;
            bridge->get_parents( parents );
            if( parents.size() )
              no_parents = false;
              break;
          if( no_parents )
            ref_entity->marked( 1 );
            free_list.append( ref_entity );
            continue;
  } while( source_list.size() );
    // xfer data, clean up marks
  for ( i = free_list.size(); i--; )
    RefEntity *ref_entity = free_list.get_and_step();
    ref_entity->marked(0);
  CAST_LIST( free_list, body_list, Body );
  CAST_LIST( free_list, ref_face_list, RefFace);
  CAST_LIST( free_list, ref_edge_list, RefEdge);
  CAST_LIST( free_list, ref_vertex_list, RefVertex);
Calls engine version of the active geometry engine.
Definition at line 3424 of file GeometryQueryTool.cpp.
  if (gqeList.size())
    gqeList.reset();
    return gqeList.get()->get_engine_version_string();
  else
    return CubitString("No Active GeometryEngine");
static CubitBoolean GeometryQueryTool::get_facet_bbox ( ) [inline, static]
Get facet box flag.
Definition at line 517 of file GeometryQueryTool.hpp.
      {return useFacetBBox;}
Get the first entity in the global list of the specified type.
Definition at line 4480 of file GeometryQueryTool.cpp.
Definition at line 4500 of file GeometryQueryTool.cpp.
Definition at line 4495 of file GeometryQueryTool.cpp.
Definition at line 4490 of file GeometryQueryTool.cpp.
Definition at line 4505 of file GeometryQueryTool.cpp.
Definition at line 4485 of file GeometryQueryTool.cpp.
Get all free surfaces, curves, and vertices.
Definition at line 4571 of file GeometryQueryTool.cpp.
    // go through the global entity lists looking for free entities
    // this algorithm works as follows: start by marking all entities in the model;
    // - bodies that don't have virtual children are NOT free, along with their children;
    //   unmark them all
    // - for all remaining entities:
    // . entities that are unmarked are not free since they were unmarked during the
    //   body check
    // . entities that are virtual are not free, but their underlying entities may be;
    //     check this, and unmark the underlying non-free entities, but not their children
    // . entities that don't have a TopologyBridge connected to a bodysm are free
    // - Removed virtual stuff - no longer required - J.Kraftcheck 10-8-2003
  int i, j;
  RefEntityFactory *REF = RefEntityFactory::instance();
    // define a macro to mark all the children
#define MARK_CHILDREN(entity, index) \
   {ref_list.clean_out(); entity->get_all_child_ref_entities(ref_list); \
   for (index=ref_list.size(); index>0; index--) ref_list.get_and_step()->marked(0);}
    // mark all entities first
  for (i = REF->num_ref_volumes(); i > 0; i--)
    REF->get_next_ref_volume()->marked(1);
  for (i = REF->num_ref_faces(); i > 0; i--)
    REF->get_next_ref_face()->marked(1);
  for (i = REF->num_ref_edges(); i > 0; i--)
    REF->get_next_ref_edge()->marked(1);
  for (i = REF->num_ref_vertices(); i > 0; i--)
    REF->get_next_ref_vertex()->marked(1);
  DLIList<RefEntity*> ref_list;
    // first, mark all the children of bodies
  Body *body;
  for (i = REF->num_bodies(); i > 0; i--) {
    body = REF->get_next_body();
    MARK_CHILDREN(body, j);
    // now go through them, checking for VG and free entities
  RefVolume *volume;
  for (i = REF->num_ref_volumes(); i > 0; i--) {
    volume = REF->get_next_ref_volume();
    if (volume->marked()) {
        // go through volume's children & unmark
      MARK_CHILDREN(volume, j);
      free_entities.append(volume);
      volume->marked(0);
  RefFace *face;
  for (i = REF->num_ref_faces(); i > 0; i--) {
    face = REF->get_next_ref_face();
    if (face->marked()) {
      MARK_CHILDREN(face, j);
      free_entities.append(face);
      face->marked(0);
  RefEdge *edge;
  for (i = REF->num_ref_edges(); i > 0; i--) {
    edge = REF->get_next_ref_edge();
    if (edge->marked()) {
      MARK_CHILDREN(edge, j);
      free_entities.append(edge);
      edge->marked(0);
  RefVertex *vertex;
  for (i = REF->num_ref_vertices(); i > 0; i--) {
    vertex = REF->get_next_ref_vertex();
    if (vertex->marked()) {
      free_entities.append(vertex);
      vertex->marked(0);
double GeometryQueryTool::get_geometry_factor ( ) [inline, static]
Gets geometry factor.
Definition at line 1156 of file GeometryQueryTool.hpp.
Returns the first gqe on the list.
Return the VirtualGeometryEngine if it exists. Otherwise return null.
Definition at line 1216 of file GeometryQueryTool.hpp.
void GeometryQueryTool::get_gqe_list ( DLIList< GeometryQueryEngine * > &  gqe_list) [inline]
Return the list of GeometryQureyEngines.
return the list of gqe's
Definition at line 1209 of file GeometryQueryTool.hpp.
CubitStatus GeometryQueryTool::get_graphics ( Body body,
GMem g_mem,
std::vector< RefFace * > &  face_to_facet_vector,
std::vector< RefEntity * > &  facet_point_ownership_vector,
std::vector< std::pair< RefEntity *, std::pair< int, int > > > &  facetedges_on_refedges,
unsigned short  normal_tolerance,
double  distance_tolerance,
double  max_edge_length
Definition at line 8142 of file GeometryQueryTool.cpp.
  //get all the RefFaces from
  DLIList<RefFace*> all_ref_faces;
  body->ref_faces( all_ref_faces );
  BodySM *body_sm = NULL;
  //get the underlying body in partition bodies
  if( GeometryQueryTool::instance()->is_intermediate_geometry( body ) )
    DLIList<TopologyBridge*> partition_body(1);
    body->get_body_sm_ptr()->get_geometry_query_engine()->get_underlying_bridges( body->get_body_sm_ptr(), partition_body );
    if( partition_body.size() == 1 )
      body_sm = static_cast<BodySM*>(partition_body.get());
  else
    body_sm = body->get_body_sm_ptr();
  //make sure everything belongs to the same GQE
  GeometryQueryEngine* gqe = body_sm->get_geometry_query_engine();
  //get the graphics
  std::vector<Surface*> surfaces_to_facet_vector;
  std::vector<TopologyBridge*> tmp_facet_point_ownership_vector;
  std::vector<std::pair<TopologyBridge*, std::pair<int,int> > > facetedges_on_curve;
  CubitStatus stat = gqe->get_graphics( body_sm, g_mem, surfaces_to_facet_vector, tmp_facet_point_ownership_vector,
    facetedges_on_curve, normal_tolerance, distance_tolerance, max_edge_length );
  if( CUBIT_FAILURE == stat )
  //map Surfaces to MRefFaces
  Surface *current_surf = NULL;
  RefFace *current_ref_face = NULL;
  bool ignore_facets = false;
  unsigned int i;
  for( i=0; i<surfaces_to_facet_vector.size(); i++ )
    Surface *tmp_surf = surfaces_to_facet_vector[i];
    if( tmp_surf != current_surf )
      current_surf = tmp_surf;
      if( tmp_surf->topology_entity() )
        current_ref_face = CAST_TO( tmp_surf->topology_entity(), RefFace );
        if( current_ref_face )
          ref_face_to_facet_vector.push_back( current_ref_face );
      else
        int times_through = 0;
          times_through++;
          (*itor)->get_tbs_with_bridge_manager_as_owner(tmp_surf, bridge_list);
          if( bridge_list.size() == 0 )
            if( times_through == 2 )
              assert(0);
            continue;
          if( bridge_list.size() == 1 )
            current_ref_face = CAST_TO( bridge_list.get()->topology_entity(), RefFace );
            else
              PRINT_INFO("Having trouble finding the top-level RefFace\n");
              assert(0);
            break;
          else if( bridge_list.size() > 1 ) // it is a partition...we'll ignore the facets
            ref_face_to_facet_vector.push_back( NULL );
            ignore_facets = true;
            break;
    else
      if( ignore_facets )
      else
  facet_point_ownership_vector.resize( tmp_facet_point_ownership_vector.size(), NULL );
  RefEntity *ref_ent = NULL;
  for( i=0; i<tmp_facet_point_ownership_vector.size(); i++ )
    TopologyBridge *tb = tmp_facet_point_ownership_vector[i];
    if( NULL == tb )
      continue;
    if( tb->topology_entity() )
      ref_ent = CAST_TO( tb->topology_entity(), RefEntity );
      facet_point_ownership_vector[i] = ref_ent;
    else
      for (IGESet::iterator itor = igeSet.begin(); itor != igeSet.end(); ++itor)
        times_through++;
        (*itor)->get_tbs_with_bridge_manager_as_owner(tb, bridge_list);
            assert(0);
          continue;
        //composites
          ref_ent = CAST_TO( bridge_list.get()->topology_entity(), RefEntity );
          if( ref_ent )
          else
            PRINT_INFO("Having trouble finding the top-level RefEdge or RefVertex\n");
            assert(0);
          break;
          facet_point_ownership_vector[i] = NULL;
          break;
  for( i=0; i<facetedges_on_curve.size(); i++ )
    std::pair<TopologyBridge*, std::pair<int,int> > tmp_pair = facetedges_on_curve[i];
    TopologyBridge *tb = tmp_pair.first;
      facetedges_on_refedges.push_back( std::make_pair( ref_ent, tmp_pair.second ) );
    else
        times_through++;
          //if( times_through == 2 )
          //  assert(0);
          continue;
        //composites
          if( ref_ent )
          else
            assert(0);
          break;
          break;
  bool debug = false;
  if( debug )
    //GfxDebug::clear();
    GPoint *pt_list = g_mem->point_list();
    for( unsigned int i = 0; i < facet_point_ownership_vector.size(); i++ )
      RefEntity *ref_ent = facet_point_ownership_vector[i];
      int color = 3;
      if( ref_ent->dimension() == 1 )
        color = 4;
      else if( ref_ent->dimension() == 2 )
        color = 5;
      GfxDebug::draw_point( pt_list[i].x, pt_list[i].y, pt_list[i].z, color );
    GfxDebug::flush();
    GfxDebug::mouse_xforms();
    GfxDebug::clear();
    //draw the curves
    for( int i=0; i<facetedges_on_refedges.size(); i++ )
      std::pair<RefEntity*, std::pair<int,int> > tmp_pair;
      tmp_pair = facetedges_on_refedges[i];
      RefEntity* ref_ent = tmp_pair.first;
      std::pair<int,int> int_pair = tmp_pair.second;
      CubitVector pt0( g_mem->point_list()[int_pair.first].x,
        g_mem->point_list()[int_pair.first].y,
        g_mem->point_list()[int_pair.first].z );
      CubitVector pt1( g_mem->point_list()[int_pair.second].x,
        g_mem->point_list()[int_pair.second].y,
        g_mem->point_list()[int_pair.second].z );
      GfxDebug::draw_point(pt0, (ref_ent->id()%10) + 3  );
      GfxDebug::draw_point(pt1, (ref_ent->id()%10) + 3  );
      GfxDebug::draw_line( pt0, pt1, (ref_ent->id()%10) + 3 );
    GfxDebug::flush();
    int index = 0;
    int color;
    index = 0;
    GfxDebug::clear();
    for( int i=0; i<g_mem->fListCount; i++ )
      int step = g_mem->facet_list()[index++];
      //create pts
      RefEntity *ref_ent = facet_point_ownership_vector[ g_mem->facet_list()[index] ];
        color = ref_ent->id() + 3 ;
       CubitVector pt0( g_mem->point_list()[ g_mem->facet_list()[index] ].x,
         g_mem->point_list()[ g_mem->facet_list()[index] ].y,
         g_mem->point_list()[ g_mem->facet_list()[index] ].z );
       index++;
       CubitVector pt1( g_mem->point_list()[ g_mem->facet_list()[index] ].x,
       index++;
       CubitVector pt2( g_mem->point_list()[ g_mem->facet_list()[index] ].x,
       index++;
       //draw lines
       GPoint three_pts[3];
       three_pts[0].x = pt0.x();
       three_pts[0].y = pt0.y();
       three_pts[0].z = pt0.z();
       three_pts[1].x = pt1.x();
       three_pts[1].y = pt1.y();
       three_pts[1].z = pt1.z();
       three_pts[2].x = pt2.x();
       three_pts[2].y = pt2.y();
       three_pts[2].z = pt2.z();
       GfxDebug::draw_polygon( three_pts, 3, i%20, i%20, true );
       GfxDebug::draw_line( pt0, pt1, color );
       GfxDebug::draw_line( pt1, pt2, color );
       GfxDebug::draw_line( pt0, pt2, color );
       i+=step;
    GfxDebug::flush();
CubitStatus GeometryQueryTool::get_graphics ( RefFace ref_face,
GMem gmem,
unsigned short  normal_tolerance = 15,
double  distance_tolerance = 0.0,
double  max_edge_length = 0.0
Definition at line 7984 of file GeometryQueryTool.cpp.
  Surface* surf_ptr = ref_face->get_surface_ptr();
  if (!surf_ptr)
    PRINT_ERROR("RefFace %d is invalid -- no attached Surface.\n",ref_face->id());
  std::vector<TopologyBridge*> vertex_edge_to_point_vector;
  CubitStatus rv = surf_ptr->get_geometry_query_engine()->
    get_graphics(surf_ptr, gmem, vertex_edge_to_point_vector, facetedges_on_curve,
  if (CUBIT_SUCCESS != rv) {
    PRINT_ERROR("GeometryQueryEngine::get_graphics failed.\n");
    return rv;
  facet_point_ownership_vector.resize( vertex_edge_to_point_vector.size(), NULL );
  for( unsigned int i = 0; i < vertex_edge_to_point_vector.size(); i++ )
    TopologyBridge *tb = vertex_edge_to_point_vector[i];
    if( NULL == tb )
      continue;
    else
      assert(0);
  for( unsigned int i = 0; i < facetedges_on_curve.size(); i++ )
    else
      assert(0);
  bool debug = false;
  if( debug )
    //GPoint *pt_list = gmem->point_list();
      //RefEntity *ref_ent = facet_point_ownership_vector[i];
      //int color = 3;
      //if( ref_ent->dimension() == 1 )
        //color = 4;
      //else if( ref_ent->dimension() == 2 )
        //color = 5;
    GfxDebug::flush();
    GfxDebug::clear();
    //draw the curves
    for( unsigned int i=0; i<facetedges_on_refedges.size(); i++ )
      CubitVector pt0( gmem->point_list()[int_pair.first].x,
        gmem->point_list()[int_pair.first].y,
        gmem->point_list()[int_pair.first].z );
      CubitVector pt1( gmem->point_list()[int_pair.second].x,
        gmem->point_list()[int_pair.second].y,
        gmem->point_list()[int_pair.second].z );
    GfxDebug::flush();
    int index = 0;
    GfxDebug::clear();
    for( int i=0; i<gmem->fListCount; i++ )
      int step = gmem->facet_list()[index++];
      //create pts
      CubitVector pt0( gmem->point_list()[ gmem->facet_list()[index] ].x,
        gmem->point_list()[ gmem->facet_list()[index] ].y,
        gmem->point_list()[ gmem->facet_list()[index] ].z );
      index++;
      CubitVector pt1( gmem->point_list()[ gmem->facet_list()[index] ].x,
      index++;
      CubitVector pt2( gmem->point_list()[ gmem->facet_list()[index] ].x,
      index++;
       //draw lines
       GfxDebug::draw_line( pt0, pt1, i%20 );
       GfxDebug::draw_line( pt1, pt2, i%20 );
       GfxDebug::draw_line( pt0, pt2, i%20 );
       i+=step;
    GfxDebug::flush();
CubitStatus GeometryQueryTool::get_intersections ( RefEdge ref_edge1,
CubitVector point1,
CubitVector point2,
DLIList< CubitVector > &  intersection_list,
CubitBoolean  bounded = CUBIT_FALSE,
CubitBoolean  closest = CUBIT_FALSE
Finds the intersections of a straight line and a curve.
Finds the intersections between a curve and a line If the bounded flag is true, it finds only those intersections within the parameter range of the curve; otherwise it uses the extensions of the curve. The closest option is currently valid only if the curve is straight, in which case it will return the 2 closest intersection locations, if the straight lines don't actually intersect. The function allocates allocates the CubitVectors in the returned list, so be sure to free them.
Definition at line 3642 of file GeometryQueryTool.cpp.
  Curve* curve_ptr1 = ref_edge1->get_curve_ptr();
  if( curve_ptr1 == NULL )
      PRINT_ERROR("Unable to retrieve underlying geometric entity of Curve %d\n"      "       This is a bug - please report it\n", ref_edge1->id() );
    return CUBIT_FAILURE;
  if ( curve_ptr1->geometry_type() == STRAIGHT_CURVE_TYPE )
    CubitVector dir = point2 - point1;
    return straightline_intersections(ref_edge1, point1, dir,
                             intersection_list, bounded, closest);
  GeometryQueryEngine* GQE_ptr =
      curve_ptr1->get_geometry_query_engine();
  return GQE_ptr->get_intersections( curve_ptr1, point1, point2,
RefEdge ref_edge2,
Finds the intersections of two curves.
Finds the intersections of the two curves. If the bounded flag is true, it finds only those intersections within the parameter range of both curves; otherwise it uses the extensions of the curves. The closest option is currently valid only if both curves are straight, in which case it will return the 2 closest intersection locations, if the straight lines don't actually intersect. So far, other than for straight lines, this function only works if both curves are curves, unless both curves are linear. The function allocates the CubitVectors in the returned list, so be sure to free them.
Definition at line 3783 of file GeometryQueryTool.cpp.
  // If both curves are straight, compute their intersection; otherwise
  // use the geometry engine to do it.
  CubitStatus status = CUBIT_FAILURE;
  Curve* curve_ptr2 = ref_edge2->get_curve_ptr();
  if( curve_ptr1 == NULL || curve_ptr2 == NULL )
    if( curve_ptr2 == NULL )
      PRINT_ERROR("Unable to retrieve underlying geometry entity of Curve %d\n"
      "       This is a bug - please report it\n", ref_edge2->id() );
  if( curve_ptr1->geometry_type() == STRAIGHT_CURVE_TYPE &&
    curve_ptr2->geometry_type() == STRAIGHT_CURVE_TYPE )
    // Proceed with the intersection calculation
    CubitVector origin2, dir2;
    if( ref_edge2->get_point_direction( origin2, dir2 ) == CUBIT_FAILURE )
      PRINT_ERROR( "Unable to get straight line information for Curve %d; aborting\n",
        ref_edge2->id() );
    if (bounded)
       origin2 = ref_edge2->start_vertex()->coordinates();
       dir2 = ref_edge2->end_vertex()->coordinates() - origin2;
    return straightline_intersections(ref_edge1, origin2, dir2,
  if( closest == CUBIT_TRUE )
    PRINT_ERROR( "'Near' option only works for straight lines\n" );
  // Use geometry engine to find intersections
  DLIList<TopologyBridge*> curve_list1, curve_list2;
  entity_list.append(ref_edge1);
  entity_list.append(ref_edge2);
  //if there's virtual edge, find the underlying real curve.
  if (ref_edge1->get_geometry_query_engine())
    ref_edge1->get_geometry_query_engine()->get_underlying_curves(curve_ptr1, curve_list1);
  if (ref_edge2->get_geometry_query_engine())
    ref_edge2->get_geometry_query_engine()->get_underlying_curves(curve_ptr2, curve_list2);
  GeometryQueryEngine* gqe = common_query_engine( entity_list, bridge_list );
  //if they are both virtual...set gqe to NULL
  if( is_intermediate_geometry(curve_ptr1) && is_intermediate_geometry( curve_ptr2 ) )
    gqe = NULL;
  if( gqe == NULL && (curve_list1.size() > 0 || curve_list2.size() > 0) )
    if (curve_list1.size() == 0)
      curve_list1.append (CAST_TO(curve_ptr1, TopologyBridge));
    if (curve_list2.size() == 0)
      curve_list2.append (CAST_TO(curve_ptr2, TopologyBridge));
    int i, j;
    for (i = 0; i <curve_list1.size(); i++)
      TopologyBridge * tb1 = curve_list1.get_and_step();
      GeometryQueryEngine *gqe_ptr1 = tb1->get_geometry_query_engine();
      curve_ptr1 = CAST_TO(tb1, Curve);
      for(j = 0; j< curve_list2.size(); j++)
        TopologyBridge * tb2 = curve_list2.get_and_step();
        GeometryQueryEngine *gqe_ptr2 = tb2->get_geometry_query_engine();
        if (gqe_ptr1 && gqe_ptr1 == gqe_ptr2 )
          curve_ptr2 = CAST_TO(tb2, Curve);
          status = gqe_ptr1->get_intersections(curve_ptr1, curve_ptr2,
            intersection_list, bounded, closest );
    //remove duplicate intersections
    for( int k=0; k<intersection_list.size(); k++ )
      intersection_list.reset();
      intersection_list.step(k+1);
      for( int s=k+1; s<intersection_list.size();)
        if( intersection_list[k].distance_between( intersection_list[s] ) < GEOMETRY_RESABS )
          intersection_list.remove();
        else
          s++;
          intersection_list.step();
    return status;
  else if (gqe == NULL)
    PRINT_ERROR( "Curves %d and %d do not have the same underlying geometry modeling engine\n"
      "       For intersection calculations, they must be the same\n",
      ref_edge1->id(), ref_edge2->id() );
  bridge_list.reset();
  curve_ptr1 = dynamic_cast<Curve*>(bridge_list.next(0));
  curve_ptr2 = dynamic_cast<Curve*>(bridge_list.next(1));
  return gqe->get_intersections( curve_ptr1, curve_ptr2,
CubitStatus GeometryQueryTool::get_intersections ( RefEdge ref_edge,
RefFace ref_face,
Finds the intersections of the curve and surface.
Finds the intersections of the curve and surface. The curve is extended if the bounded flag is not false. The function allocates the CubitVectors in the returned list, so be sure to free them.
Definition at line 3917 of file GeometryQueryTool.cpp.
  entity_list.append(ref_edge);
  entity_list.append(ref_face);
  if( gqe == NULL )
    PRINT_ERROR( "Curve %d and Surface %d do not have the same underlying geometry query engine\n"
      ref_edge->id(), ref_face->id() );
  Curve* curve = dynamic_cast<Curve*>(bridge_list.next(0));
  Surface* surf = dynamic_cast<Surface*>(bridge_list.next(1));
  return gqe->get_intersections( curve, surf, intersection_list, bounded );
CubitPlane  plane,
double  extended_percent = 0.0
Gets the intersection of a curve a plane. The extended_percent extends the plane by a percentage value.
Definition at line 3943 of file GeometryQueryTool.cpp.
  CubitBox box = ref_edge->bounding_box();
  // create a Surface from the plane
  CubitVector p1, p2, p3, p4;
  AnalyticGeometryTool::instance()->min_pln_box_int_corners(plane, box, 1, extended_percent, p1, p2, p3, p4, true );
  TopologyBridge* bridge = 0;
  GeometryModifyEngine* gme = GeometryModifyTool::instance()->get_engine( ref_edge, &bridge );
  BodySM* sheet = gme->planar_sheet(p1, p2, p3, p4);
  if (!sheet)
    PRINT_INFO("%s", "Unable to test for planar intersections\n");
  DLIList<Surface*> surfaces;
  sheet->surfaces( surfaces );
  Curve* curve = ref_edge->get_curve_ptr();
  GeometryQueryEngine* gqe = ref_edge->get_geometry_query_engine();
  CubitStatus status = gqe->get_intersections( curve, surfaces[0], intersection_list, bounded );
  gqe->delete_solid_model_entities(sheet);
  return status;
Get the last entity in the global list of the specified type
Definition at line 4541 of file GeometryQueryTool.cpp.
Definition at line 4561 of file GeometryQueryTool.cpp.
Definition at line 4556 of file GeometryQueryTool.cpp.
Definition at line 4551 of file GeometryQueryTool.cpp.
Definition at line 4566 of file GeometryQueryTool.cpp.
Definition at line 4546 of file GeometryQueryTool.cpp.
Gets bboxMergeTest variable.
Definition at line 1181 of file GeometryQueryTool.hpp.
{return bboxMergeTest;}
Definition at line 1183 of file GeometryQueryTool.hpp.
void GeometryQueryTool::get_merged_away_free_entities ( DLIList< RefEntity * > &  ref_ents,
DLIList< TopologyBridge * > &  free_ents
) [private]
Definition at line 7948 of file GeometryQueryTool.cpp.
  //determine if you have any free entities that were merged away
  DLIList<RefEntity*> merged_ref_ents;
  MergeTool::instance()->contains_merged_entities( ref_ents, &merged_ref_ents );
  int i;
  for( i=merged_ref_ents.size(); i--; )
    RefEntity *tmp_ent = merged_ref_ents.get_and_step();
    TopologyEntity *te = CAST_TO(tmp_ent, TopologyEntity );
    te->bridge_manager()->get_bridge_list( bridge_list );
    //bridge_list.reset();
    //bridge_list.step(); //don't want to first bridge...that's the real thing
    //check for free entities...
    int j;
    for( j=0; j<bridge_list.size(); j++ )
      TopologyBridge *tmp_bridge = bridge_list.get_and_step();
      //ignore the representation bridge if it's a free vertex
      if( j==0 )
        if( tmp_ent->num_parent_ref_entities() == 0 )
          continue;
      tmp_bridge->get_parents( parents );
      if( parents.size() == 0 )
        free_ents.append( tmp_bridge );
Get the next entity in the global list of the specified type.
Definition at line 4510 of file GeometryQueryTool.cpp.
Definition at line 4530 of file GeometryQueryTool.cpp.
Definition at line 4525 of file GeometryQueryTool.cpp.
Definition at line 4520 of file GeometryQueryTool.cpp.
Definition at line 4535 of file GeometryQueryTool.cpp.
Definition at line 4515 of file GeometryQueryTool.cpp.
void GeometryQueryTool::get_ordered_loops ( RefFace face,
DLIList< Loop * > &  loop_list
Definition at line 4392 of file GeometryQueryTool.cpp.
  GeometryQueryEngine *gqe = face->get_geometry_query_engine();
  gqe->get_ordered_loops(face, loop_list);
CubitStatus GeometryQueryTool::get_point_containment ( DLIList< Body * > &  body_list,
DLIList< CubitVector > &  point_list,
double  tolerance,
bool  allow_pts_in_multiple_bodies,
std::vector< std::pair< Body *, std::vector< int > > > &  body_to_pt_indices
Definition at line 8455 of file GeometryQueryTool.cpp.
  DLIList<TopologyEntity*> entity_list( body_list.size() );
  for( int i=body_list.size(); i--; )
    entity_list.append( body_list.get_and_step() );
  //map for associating PartitionBody back to Body
  std::map<BodySM*, Body*> partition_body_map;
  //there is a slim chance that all bodies are ParititonBodies.  If so,
  //the gqe will be non-NULL...let's check if the first one is
  if( gqe && GeometryModifyTool::instance()->contains_partitions( body_list ) )
    gqe = NULL;
  //if the engine is still NULL, we could just have a partition body in there...
  if( gqe == NULL )
    for( int k=0; k<body_list.size(); k++ )
      DLIList<TopologyBridge*> underlying_body;
      //if it is virtual
      if( body_list[k]->get_geometry_query_engine()->is_intermediate_engine() )
        //get the underlying Body...in PartitionBody case, it should be a Body
        underlying_body.append( body_list[k]->bridge_manager()->topology_bridge() );
          (*itor)->export_geometry(underlying_body);
        //if it is different than the original Body TopologyBridge, we found it
        if( underlying_body.size() && body_list[k]->bridge_manager()->topology_bridge() != underlying_body.get() )
          partition_body_map.insert( std::make_pair( (BodySM*)underlying_body.get(), body_list[k] ) );
          bridge_list.append( underlying_body.get() );
      else
        bridge_list.append( body_list[k]->bridge_manager()->topology_bridge() );
    gqe = bridge_list.get_and_step()->get_geometry_query_engine();
    for( int i=1; i<bridge_list.size(); i++ )
      if( gqe != tmp_bridge->get_geometry_query_engine() )
        gqe = NULL;
        break;
  if( gqe == NULL )
    PRINT_ERROR("Input geometry does not have the same geometry engine.\n");
  DLIList<BodySM*> body_sm_list;
  CAST_LIST(bridge_list, body_sm_list, BodySM);
  std::vector< std::pair<BodySM*, std::vector<int> > > bodysm_to_pt_indices;
  gqe->get_point_containment( body_sm_list, point_list, tolerance, allow_pts_in_multiple_bodies, bodysm_to_pt_indices );
  //convert the BodySMs back to BODYs
  for( unsigned int i=0; i<bodysm_to_pt_indices.size(); i++ )
    std::pair<BodySM*, std::vector<int> > tmp_pair = bodysm_to_pt_indices[i];
    BodySM *body_sm = tmp_pair.first;
    Body *tmp_body = dynamic_cast<Body*>( body_sm->topology_entity() );
    if( !tmp_body )
      //PartitionBody case...look it up in the map
      std::map<BodySM*, Body*>::iterator tmp_iter = partition_body_map.find( body_sm );
      if( partition_body_map.end() != tmp_iter  )
        body_to_pt_indices.push_back( std::make_pair( tmp_iter->second,  tmp_pair.second) );
    else
      body_to_pt_indices.push_back( std::make_pair( tmp_body, tmp_pair.second) );
  return CUBIT_SUCCESS;
Get entity by id.
Definition at line 4470 of file GeometryQueryTool.cpp.
RefEntity * GeometryQueryTool::get_ref_entity ( const char *  type,
int  id
Get RefEntity by type name and id.
Definition at line 4440 of file GeometryQueryTool.cpp.
  return RefEntityFactory::instance()->get_ref_entity(type, id);
RefEntity * GeometryQueryTool::get_ref_entity ( const std::type_info &  type,
int  id
Get a RefEntity of the specified type and id.
Definition at line 4445 of file GeometryQueryTool.cpp.
Get entity by id.
Definition at line 4465 of file GeometryQueryTool.cpp.
Get entity by id.
Definition at line 4460 of file GeometryQueryTool.cpp.
Get entity by id.
Definition at line 4475 of file GeometryQueryTool.cpp.
Get entity by id.
Definition at line 4455 of file GeometryQueryTool.cpp.
Definition at line 1171 of file GeometryQueryTool.hpp.
Definition at line 1176 of file GeometryQueryTool.hpp.
Gets solid modeler's resolution absolute tolerance.
Definition at line 3572 of file GeometryQueryTool.cpp.
  if (gqeList.size())
    gqeList.reset();
    return gqeList.get()->get_sme_resabs_tolerance();
  else
    return 0.0;
Definition at line 5361 of file GeometryQueryTool.cpp.
    (*itor)->get_tbs_with_bridge_manager_as_owner( source_bridge, tbs );
Definition at line 7943 of file GeometryQueryTool.cpp.
  return mHistory;
void GeometryQueryTool::ige_attribute_after_imprinting ( DLIList< TopologyBridge * > &  tb_list,
DLIList< Body * > &  old_bodies
Definition at line 5368 of file GeometryQueryTool.cpp.
    (*itor)->attribute_after_imprinting(tb_list, old_bodies);
Definition at line 5287 of file GeometryQueryTool.cpp.
  for (IGESet::reverse_iterator itor = igeSet.rbegin(); itor != igeSet.rend(); ++itor)
    (*itor)->export_geometry(geom_list);
Definition at line 5355 of file GeometryQueryTool.cpp.
    (*itor)->import_geometry(geom_list);
bool GeometryQueryTool::ige_is_composite ( TBOwner bridge_owner)
Definition at line 5315 of file GeometryQueryTool.cpp.
  bool ret = false;
  for (IGESet::iterator itor = igeSet.begin(); itor != igeSet.end() && ret != true; ++itor)
    if((*itor)->is_composite(bridge_owner))
      ret = true;
  return ret;
Definition at line 5328 of file GeometryQueryTool.cpp.
  bool ret = false;
    if((*itor)->is_composite(bridge))
      ret = true;
  return ret;
bool GeometryQueryTool::ige_is_partition ( TBOwner bridge_owner)
Definition at line 5342 of file GeometryQueryTool.cpp.
  bool ret = false;
    if((*itor)->is_partition(bridge_owner))
      ret = true;
  return ret;
Definition at line 5294 of file GeometryQueryTool.cpp.
    (*itor)->push_imprint_attributes_before_modify(geom_list);
Definition at line 5301 of file GeometryQueryTool.cpp.
    (*itor)->push_named_attributes_to_curves_and_points(tb_list, name_in);
Definition at line 5375 of file GeometryQueryTool.cpp.
    (*itor)->remove_attributes(geom_list);
Definition at line 5381 of file GeometryQueryTool.cpp.
    (*itor)->remove_attributes_from_unmodifed_virtual(bridges);
Definition at line 5308 of file GeometryQueryTool.cpp.
    (*itor)->remove_imprint_attributes_after_modify(old_sms, new_sms);
void GeometryQueryTool::ige_remove_modified ( DLIList< Surface * > &  all_surfs,
DLIList< Curve * > &  all_curves,
DLIList< TBPoint * > &  all_points
Definition at line 7581 of file GeometryQueryTool.cpp.
  IGESet::iterator itor;
  for (itor = igeSet.begin(); itor != igeSet.end(); ++itor)
    (*itor)->remove_modified(all_surfs, all_curves, all_points);
    (*itor)->clean_out_deactivated_geometry();
Causes attributes hanging on entities to be applied.
Definition at line 5540 of file GeometryQueryTool.cpp.
  int i;
    // given a Body list, actuates first the merge partner attribute
    // on all entities in the list, then actuates all other types of
    // attributes
  DLIList<TopologyEntity*> temp_list;
  DLIList<RefEntity*> refent_list;
  CubitBoolean auto_actuate_merge;
  auto_actuate_merge = CGMApp::instance()->attrib_manager()->auto_actuate_flag(CA_MERGE_PARTNER);
  if (auto_actuate_merge) {
      // Prevent MergeTool from destroying dead entities
      // after merging.  Otherwise we get stale pointers
      // in our lists.
      // Don't forget to turn this back on later!
    MergeTool::destroy_dead_geometry( false );
    DLIList<TopologyEntity*> me_list;
    CAST_LIST(entity_list, me_list, TopologyEntity);
    ModelQueryEngine *const mqe = ModelQueryEngine::instance();
    // vertices
    mqe->query_model(me_list, DagType::ref_vertex_type(), temp_list);
    CAST_LIST(temp_list, refent_list, RefEntity);
      // actuate merge attribute for vertices
    if (refent_list.size() > 0)
      refent_list.get()->actuate_cubit_attrib(refent_list, CA_MERGE_PARTNER);
    // edges
    temp_list.clean_out();
    refent_list.clean_out();
    mqe->query_model(me_list, DagType::ref_edge_type(), temp_list);
      // actuate merge attribute for edges
    // faces
    mqe->query_model(me_list, DagType::ref_face_type(), temp_list);
      // actuate merge attribute for faces
      // clean out entities destroyed during merge
    for( i = entity_list.size(); i--; )
      TopologyEntity* me_ptr = dynamic_cast<TopologyEntity*>(entity_list.get());
      if( me_ptr && me_ptr->deactivated() )
        entity_list.extract();
      else
        entity_list.step();
      // Restore merge tool setting, and clean up dead geometry
    MergeTool::destroy_dead_geometry( true );
    GeometryQueryTool::instance()->cleanout_deactivated_geometry();
    // now actuate other attributes
  RefEntity* entity_ptr;
  CAActuateSet actuate_set( entity_list );
    // actuate in increasing dimension
    // (vtx = 0, ..., volume = 3, body = 4)
  for( i = 0; i < 5; i++ )
    actuate_set.set_current_dimension( i );
    while( (entity_ptr = actuate_set.remove_next() ) != NULL )
      entity_ptr->auto_actuate_cubit_attrib(CUBIT_FALSE);
    // actuate deferred attribs
  CADeferredAttrib::cleanup_cadas(CUBIT_TRUE, CUBIT_TRUE);
    // finally, actuate the attributes that go after all other geometry changes
  for( i = 0; i < 4; i++ )
      entity_ptr->auto_actuate_cubit_attrib(CUBIT_FALSE, CUBIT_TRUE);
CubitStatus GeometryQueryTool::import_solid_model ( const char *  file_name,
Model_File_Type  file_type,
ModelImportOptions &  import_options,
DLIList< RefEntity * > *  imported_entities = NULL
Import a geometry file.
Definition at line 960 of file GeometryQueryTool.cpp.
  importingSolidModel = CUBIT_TRUE;
  uidsOfImportingEnts.clean_out();
  mergeGloballyOnImport = import_options.merge_globally;
 if( clearUidMapBeforeImport )
    CAUniqueId::clear_out_old_to_new_map();
  if( GSaveOpen::performingUndo )
    mergeGloballyOnImport = CUBIT_TRUE;
  if( CubitUndo::get_undo_enabled() )
    CubitUndo::save_state();
    // reset the attribImporteds flags to facilitate attribute reporting
//  CubitAttrib::clear_attrib_importeds();
    // Use the default MQE to import a list of ToplogyBridges from the file.
  gqeList.reset();
  import_options.print_results = CUBIT_TRUE;
  // We will turn off the printing of name change warnings during import and just
  // keep track of how many happened.
  bool prev_print_warning_flag = RefEntityName::instance()->print_name_change_warnings();
  RefEntityName::instance()->print_name_change_warnings(false);
  RefEntityName::instance()->num_name_change_warnings(0);
  CubitStatus status = gqeList.get()->import_solid_model( file_name,
      file_type, bridge_list, import_options );
    importingSolidModel = CUBIT_FALSE;
    mergeGloballyOnImport = CUBIT_FALSE;
    return status;
    (*itor)->import_geometry(bridge_list);
  DLIList<RefEntity*> tmp_ent_list;
  status = construct_refentities(bridge_list, &tmp_ent_list);
  // Print out a summary warning message if names were changed.
  RefEntityName::instance()->print_name_change_warnings(prev_print_warning_flag);
  if(RefEntityName::instance()->num_name_change_warnings() > 0)
    PRINT_WARNING("%d invalid names were found during import.\n\n",
            RefEntityName::instance()->num_name_change_warnings());
  if( imported_entities )
    (*imported_entities) += tmp_ent_list;
    if( tmp_ent_list.size() && status == CUBIT_SUCCESS )
      CubitUndo::note_result_entities( tmp_ent_list );
    else
      CubitUndo::remove_last_undo();
  //clear out all attributes that were set to actuate
  DLIList<RefEntity*> all_ents;
  RefEntity::get_all_child_ref_entities( tmp_ent_list, all_ents );
  all_ents += tmp_ent_list;
  CubitAttribUser::clear_all_simple_attrib_set_to_actuate( all_ents );
    // report attribs imported
//  CubitAttrib::report_attrib_importeds();
    // now return
  return status;
CubitStatus GeometryQueryTool::import_solid_model ( DLIList< RefEntity * > *  imported_entities,
const char *  pBuffer,
const int  n_buffer_size
Definition at line 1051 of file GeometryQueryTool.cpp.
  if (0 == gqeList.size())
    PRINT_WARNING("No active geometry engine.\n");
  gqeList.reset();
  CubitStatus status = CUBIT_SUCCESS;
  for(int i = 0; i < gqeList.size(); i++)
    status = gqeList.get_and_step()->import_solid_model( bridge_list, pBuffer, n_buffer_size );
    if( bridge_list.size() > 0 )
      break;
  if(bridge_list.size() == 0)
    return status;
    else
//  DLIList<RefEntity*> all_ents;
//  RefEntity::get_all_child_ref_entities( tmp_ent_list, all_ents );
//  all_ents += tmp_ent_list;
//  CubitAttribUser::clear_all_simple_attrib_set_to_actuate( all_ents );
    // now return
  return status;
Returns:
GeometryQueryTool* - Pointer to the singleton GeometryQueryTool object Return a pointer to the only instance of the class with the default geometric query engine set to the argument, if it is not NULL. If the argument is NULL, return the pointer to the existing instance without modifying the default SME. A valid GQEPtr *must* be supplied at the time of the first call to this function. Hence, this instance function should specifically be called at startup with a valid non-NULL input GQEPtr.
Definition at line 125 of file GeometryQueryTool.cpp.
     // Check to see if we have created an instance of the class
     // If proceed to create one.
   if (instance_ == 0)
        // When creating the instance, we should always have a valid
        // GQEPtr. If not, complain.
     instance_ = new GeometryQueryTool (GQEPtr) ;
        // check to make sure there's a ref entity factory extant
     //RefEntityFactory *factory =
     // If there is an existing instance of the class, check if there
     // was a request to set default solid modeling engine. If so, be nice
     // to the calling routine :) :) and kindly set the default solid
     // modeling engine.
   else if ( GQEPtr != NULL && !instance_->gqeList.move_to(GQEPtr)) {
       delete instance_->gqeList.remove();
       instance_->gqeList.insert(GQEPtr);
     // Return the a pointer to the instance of the class.
   return instance_ ;
CubitStatus GeometryQueryTool::interpolate_along_surface ( CubitVector vector_1,
CubitVector vector_2,
DLIList< CubitVector * > &  vector_list,
RefFace ref_face_ptr,
int  number_points
) const
Creates a list of vectors the length of the number_points that interpolate between vector_1 and vector_2. All of the points will lie on the underlying equation of the refface.
Definition at line 5431 of file GeometryQueryTool.cpp.
  TopologyEntity* topo_ptr = CAST_TO(entity_ptr, TopologyEntity);
  if (!topo_ptr)
    return false;
  topo_ptr->bridge_manager()->get_bridge_list(bridge_list);
  while(bridge_list.size())
    if (is_intermediate_geometry(bridge_list.pop()))
      return true;
  return false;
Definition at line 5446 of file GeometryQueryTool.cpp.
  if (bridge->get_geometry_query_engine() == NULL )
    return true;
  else
    return bridge->get_geometry_query_engine()->is_intermediate_engine();
Returns a string with the versions of the active geometry engine.
Definition at line 3558 of file GeometryQueryTool.cpp.
  if (gqeList.size())
    gqeList.reset();
    return gqeList.get()->list_engine_versions(versions);
  else
Body * GeometryQueryTool::make_Body ( BodySM bodysm_ptr) const
Definition at line 1372 of file GeometryQueryTool.cpp.
  int i;
  CpuTimer timer;
  bool body_created = false;
  bool body_modified = false;
  bool vol_modified = false, tmp_vol_modified;
  Body* body = CAST_TO( bodysm_ptr->topology_entity(), Body );
  if( ! body )
    body = RefEntityFactory::instance()->construct_Body(bodysm_ptr);
    body_created = true;
  if( ! body )
    PRINT_ERROR("Body creation failed in GeometryQueryTool::make_Body\n");
    assert( !!body );
    return 0;
  DLIList<Lump*> lumps;
  bodysm_ptr->lumps( lumps );
  DLIList<SenseEntity*> dead_covols, new_covols(lumps.size());
  lumps.reset();
  for( i = lumps.size(); i--; )
    RefVolume* vol = make_RefVolume( lumps.get_and_step(), tmp_vol_modified );
    if( !vol )
      PRINT_ERROR("RefVolume creation failed in GeometryQueryTool::make_Body\n");
      PRINT_ERROR("Aborting construction of Body %d\n", body->id() );
      assert( !!vol );
    if (tmp_vol_modified)
      vol_modified = true;
    SenseEntity* covol = vol->find_sense_entity( body );
    if (!covol)
      covol = new CoVolume( vol );
      body_modified = true;
    new_covols.append(covol);
  body->set_sense_entity_list( new_covols, dead_covols );
  while (dead_covols.size())
    destroy_dead_entity(dead_covols.pop());
  PRINT_DEBUG_3("Constructed Body %d from BodySM in %f seconds.\n",
    body->id(), timer.cpu_secs() );
  if( body_created )
    AppUtil::instance()->send_event(GeometryEvent(GeometryEvent::FREE_REF_ENTITY_GENERATED, body));
    CGMHistory::Event evt(CGMHistory::TOP_LEVEL_ENTITY_CREATED, body);
    const_cast<CGMHistory&>(mHistory).add_event(evt);
  else if( body_modified )
    AppUtil::instance()->send_event(GeometryEvent(GeometryEvent::TOPOLOGY_MODIFIED, body));
    CGMHistory::Event evt(CGMHistory::TOPOLOGY_CHANGED, body);
  else if( vol_modified )
    AppUtil::instance()->send_event(GeometryEvent(GeometryEvent::GEOMETRY_MODIFIED, body));
    CGMHistory::Event evt(CGMHistory::GEOMETRY_CHANGED, body);
  PRINT_DEBUG_3("Updated graphics for Body %d in %f seconds.\n",
  return body;
Definition at line 2720 of file GeometryQueryTool.cpp.
   RefEdge* ref_edge_ptr = make_RefEdge(curve_ptr);
   if( !ref_edge_ptr )
     PRINT_ERROR("Failed to construct free RefEdge.\n");
     assert(!!ref_edge_ptr);
     return 0;
   AppUtil::instance()->send_event(GeometryEvent(GeometryEvent::FREE_REF_ENTITY_GENERATED, ref_edge_ptr));
   CGMHistory::Event evt(CGMHistory::TOP_LEVEL_ENTITY_CREATED, ref_edge_ptr);
   return ref_edge_ptr;
RefFace * GeometryQueryTool::make_free_RefFace ( Surface surface_ptr,
bool  is_free_surface
) const
Definition at line 2687 of file GeometryQueryTool.cpp.
   RefFace* ref_face_ptr = make_RefFace( surface_ptr );
   if( !ref_face_ptr )
     PRINT_ERROR("Failed to construct free RefFace.\n");
     assert(!!ref_face_ptr);
     return 0;
   // Add the new ref_face to the graphics
   if( is_free_face )
     AppUtil::instance()->send_event(GeometryEvent(GeometryEvent::FREE_REF_ENTITY_GENERATED, ref_face_ptr));
     CGMHistory::Event evt(CGMHistory::TOP_LEVEL_ENTITY_CREATED, ref_face_ptr);
   return ref_face_ptr;
HR>
These functions can be used to create free ref-entities from a geometry engine. Just call populate_topology_ bridges to create the sm_ptr of the desired type, then pass that to the appropriate function here.
Topology and geometry deletion
Definition at line 2748 of file GeometryQueryTool.cpp.
   RefVertex* ref_vertex_ptr = make_RefVertex( point_ptr );
   if( !ref_vertex_ptr )
     PRINT_ERROR("Failed to construct free RefVertex.\n");
     assert(!!ref_vertex_ptr);
     return 0;
   // Add the new ref_vertex to the graphics
   AppUtil::instance()->send_event(GeometryEvent(GeometryEvent::FREE_REF_ENTITY_GENERATED, ref_vertex_ptr));
   CGMHistory::Event evt(CGMHistory::TOP_LEVEL_ENTITY_CREATED, ref_vertex_ptr);
   return ref_vertex_ptr;
CubitStatus GeometryQueryTool::make_merged_RefFace ( Surface surface_ptr) const [private]
Definition at line 2041 of file GeometryQueryTool.cpp.
    // Get the RefFace
  RefFace* face = dynamic_cast<RefFace*>(surface_ptr->topology_entity());
  if (!face)  // isn't merged
    // Get a Surface to compare to.
  int num_bridges = face->bridge_manager()->number_of_bridges();
  if (num_bridges < 2) // isn't merged
  // Get some other Surface in merged RefFace to compare
  // topology with.
  DLIList<TopologyBridge*> bridge_list(num_bridges);
  face->bridge_manager()->get_bridge_list(bridge_list);
  if (bridge_list.get() == surface_ptr)
    bridge_list.step();
  TopologyBridge* merged_bridge = bridge_list.get();
  Surface* merged_surface = dynamic_cast<Surface*>(merged_bridge);
  assert(merged_surface && merged_surface != surface_ptr);
    // Get the relative sense of the Surfaces
  bool surfaces_reversed =
    (surface_ptr->bridge_sense() != merged_surface->bridge_sense());
    // Get LoopSMs for both surfaces
  DLIList<LoopSM*> merged_loops, loopsms;
  surface_ptr->loopsms(loopsms);
  merged_surface->loopsms(merged_loops);
  if( merged_loops.size() != loopsms.size() )
    // For each LoopSM on the merged Surface, find the
    // corresponding LoopSM on this Surface and merge.
  DLIList<CoEdgeSM*> merged_coedges, coedgesms;
  DLIList<LoopSM*> coedge_loops(1);
  DLIList<Curve*> curves(1);
  merged_loops.reset();
  for( int i = merged_loops.size(); i--; )
    LoopSM* merged_loop = merged_loops.get_and_step();
      // Find the LoopSM by choosing a CoEdgeSM from the
      // merged LoopSM, and finding corresponding CoEdgeSM
      // on the Surface we are building.
    merged_coedges.clean_out();
    merged_loop->coedgesms( merged_coedges );
    merged_coedges.reset();
    CoEdgeSM* merged_coedge = merged_coedges.get();
    CoEdgeSM* coedgesm = find_merged_coedgesm( surface_ptr, merged_coedge );
    if( !coedgesm )
     // Get the LoopSM in surface_ptr from the CoEdgeSM
    coedge_loops.clean_out();
    coedgesm->loopsms( coedge_loops );
    assert( coedge_loops.size() == 1 );
    LoopSM* loopsm = coedge_loops.get();
      // Get all the CoEdgeSMs on the LoopSM we are going to merge.
    coedgesms.clean_out();
    loopsm->coedgesms( coedgesms );
    if( coedgesms.size() != merged_coedges.size() )
      // Get the CoEdge list in the appropriate order and position
    if( surfaces_reversed )
      coedgesms.reverse();
    coedgesms.move_to(coedgesm);
    assert( coedgesms.get() == coedgesm );
      // Now check and merge CoEdgeSM pairs
    for( int j = coedgesms.size(); j--; )
      coedgesm = coedgesms.get_and_step();
      merged_coedge = merged_coedges.get_and_step();
        // Get Curve in surface_ptr
      curves.clean_out();
      coedgesm->curves(curves);
      if( curves.size() != 1 )
        PRINT_ERROR("Invalid SolidModel topology encountered in "
                    "GeometryQueryTool::make_RefFace.  CoEdgeSM in "
                    "has %d curves.\n", curves.size());
      Curve* curve = curves.get();
        // Get Curve in merged_surface
      curves.clean_out();
      merged_coedge->curves(curves);
      Curve* merged_curve = curves.get_and_step();
        // Check if curves are merged
      if( merged_curve->bridge_manager() != curve->bridge_manager() )
        // Check that relative sense of CoEdgeSMs is correct
      bool curves_reversed =
        (merged_curve->bridge_sense() != curve->bridge_sense());
        // Should this coedgesm be reversed wrt to the merge partner?
      bool should_be_reversed = (curves_reversed != surfaces_reversed);
        // Are the coedgesm actually reversed wrt to each other?
      bool are_reversed = (merged_coedge->sense() != coedgesm->sense());
      if( should_be_reversed != are_reversed )
        // Merge the CoEdgeSMs
      CoEdge* coedge = dynamic_cast<CoEdge*>(coedgesm->topology_entity());
      CoEdge* merge  = dynamic_cast<CoEdge*>(merged_coedge->topology_entity());
        // If this coedgesm is not the primary coedgesm in the
        // CoEdge, check to make sure the primary CoEdgeSM's curve
        // is merged with our curve.
      if (coedge && coedge->bridge_manager()->number_of_bridges() > 1
           && coedge->bridge_manager()->topology_bridge() != coedgesm
           && coedge->bridge_manager()->topology_bridge() != merged_coedge )
        curves.clean_out();
        coedge->bridge_manager()->topology_bridge()->curves(curves);
        assert(curves.size() == 1);
        if (curves.get()->owner() != curve->owner())
          coedge->bridge_manager()->remove_bridge(coedgesm);
          assert(coedge->get_parents());
          coedge = 0;
      if (merge && merge->bridge_manager()->number_of_bridges() > 1
           && merge->bridge_manager()->topology_bridge() != coedgesm
           && merge->bridge_manager()->topology_bridge() != merged_coedge )
        curves.clean_out();
        merge->bridge_manager()->topology_bridge()->curves(curves);
          merge->bridge_manager()->remove_bridge(merged_coedge);
          assert(merge->get_parents());
          merge = 0;
        // If the two CoEdgeSM's aren't in the same CoEdge,
        // merge them.
      if (merge && merge != coedge)
        if (coedge)
          destroy_dead_entity(coedge);
        merge->bridge_manager()->add_bridge(coedgesm);
        // If for some reason (Composite curve creatation does
        // this) neither CoEdgeSM has a CoEdge, create one and
        // re-merge them.
      else if (!coedge && !merge)
        coedge = new CoEdge(coedgesm);
        coedge->bridge_manager()->add_bridge(merged_coedge);
      else if(!coedge)
      else if(!merge)
    } // for( j = coedgesms )
    Loop* loop = dynamic_cast<Loop*>(loopsm->topology_entity());
    Loop* merged = dynamic_cast<Loop*>(merged_loop->topology_entity());
      // If the two LoopSMs aren't in the same Loop, merge them
    if( merged != 0 && merged != loop )
      if( loop )
        loop->bridge_manager()->remove_bridge(loopsm);
      merged->bridge_manager()->add_bridge(loopsm);
    else if( !loop && !merged )
      loop = new Loop;
      loop->bridge_manager()->add_bridge(merged_loop);
    else if( !loop )
    else if( !merged )
  } // for( i = merged_loops )
RefEdge * GeometryQueryTool::make_RefEdge ( Curve curve_ptr) const
Definition at line 2262 of file GeometryQueryTool.cpp.
  int i;
    // Get/construct RefEdge
  bool edge_created = false;
  bool edge_modified = false;
  RefEdge* edge = dynamic_cast<RefEdge*>(curve_ptr->topology_entity());
  if( !edge )
    edge = dynamic_cast<RefEdge*>(check_mergeable_refentity(curve_ptr));
  if( !edge )
    edge = RefEntityFactory::instance()->construct_RefEdge(curve_ptr);
    edge_created = true;
  assert(edge != NULL);
  bool reversed = (CUBIT_REVERSED == curve_ptr->bridge_sense());
  bool merged = edge->bridge_manager()->number_of_bridges() > 1;
    // Construct RefVertices
  DLIList<TBPoint*> points(2);
  curve_ptr->points( points );
  if( reversed )
    points.reverse();
  if( points.size() > 2 || points.size() < 1 )
                "GeometryQueryTool::make_RefEdge.  Curve %d "
                "has %d vertices.\n", edge->id(), points.size() );
    assert( points.size() == 1 || points.size() == 2 );
    if( points.size() == 0 )
      return edge;
  points.reset();
  RefVertex* start_vertex = make_RefVertex( points.get() );
  points.last();
  RefVertex* end_vertex = make_RefVertex( points.get() );
    // If curves are merged, make sure vertices are merged.
  if( merged )
    int num_bridges = edge->bridge_manager()->number_of_bridges();
    DLIList<TopologyBridge*> bridge_list( num_bridges );
    edge->bridge_manager()->get_bridge_list( bridge_list );
    for( i = bridge_list.size(); i--; )
      if( bridge_list.get() != curve_ptr )
        break;
      else
        bridge_list.step();
      // Get points on some other Curve that this curve is merged with.
    Curve* other_curve = dynamic_cast<Curve*>(bridge_list.get());
    assert( other_curve != curve_ptr) ;
    points.clean_out();
    other_curve->points(points);
    if( other_curve->bridge_sense() == CUBIT_REVERSED )
      points.reverse();
      // Check that points merged.
    points.reset();
    if( points.get()->topology_entity() != start_vertex )
      merged = false;
    points.last();
    if( points.get()->topology_entity() != end_vertex )
      merged = false;
    //perhaps the bridge sense just needs to be swapped
    if( merged == false )
      points.reverse();
      points.reset();
      TBPoint *point1 = points.get_and_step();
      TBPoint *point2 = points.get_and_step();
      if( point1->topology_entity() == start_vertex &&
          point2->topology_entity() == end_vertex )
        merged = true;
        curve_ptr->reverse_bridge_sense();
    // Unmerge the curve, if necessary.
  if( !merged && edge->bridge_manager()->number_of_bridges() > 1 )
    PRINT_WARNING("Unmerging Curve %d\n", edge->id() );
      // unmerge
    edge->bridge_manager()->remove_bridge( curve_ptr );
      // reset bridge sense on un-merged curve
    if (curve_ptr->bridge_sense() == CUBIT_REVERSED)
      // if first curve in old edge now has reversed sense,
      // reverse the old edge also.
    //if (edge->get_curve_ptr()->bridge_sense() == CUBIT_REVERSED)
    //  edge->bridge_manager()->reverse_bridge_senses();
    //  edge->reverse_topology();
      // Create new RefEdge for un-merged curve
    edge = RefEntityFactory::instance()->construct_RefEdge( curve_ptr );
    PRINT_WARNING("Creating edge %d that was supposed to be merged\n", edge->id() );
      // If we had swapped the vertex order because the curve
      // was reversed, switch them back because we unmerged so
      // we're going to create the new curve with a forward sense.
    if( reversed )
      std::swap(start_vertex,end_vertex);
    // Get/construct Chain
  Chain* chain = edge->get_chain_ptr();
  if( !chain )
    chain = new Chain();
    edge->add_grouping_entity( chain );
    // Get any existing CoVertices
  DLIList<CoVertex*> co_vertices(2);
  chain->co_vertices( co_vertices );
  if( co_vertices.size() > 2 )
    PRINT_ERROR("In GeometryQueryTool::make_RefEdge, encountered "
                "a Chain with %d CoVertices on Curve %d\n",
                co_vertices.size(), edge->id());
    assert( co_vertices.size() <= 2 );
    // Now construct CoVertices if necessary, and attach
    // RefVertices.
  DLIList<RefVertex*> vertices(1);
  CoVertex* prev = 0;
    // First iteration is for start RefVertex
  RefVertex* vertex = start_vertex;
  co_vertices.reset();
    // Loop twice, once for each CoVertex.
  for( i = 0; i < 2; i++ )
      // Construct CoVertex if one does not already exist
    CoVertex* cvtx = 0;
    if( co_vertices.size() > i )
      cvtx = co_vertices.get_and_step();
    else
      cvtx = new CoVertex();
      chain->add_sense_entity( cvtx , prev );
    prev = cvtx;
      // Get existing RefVertex from CoVertex, if it has one.
    vertices.clean_out();
    cvtx->ref_vertices( vertices );
    if( vertices.size() > 1 )
                  "a CoVertex with %d Vertices on Curve %d\n",
      assert( vertices.size() <= 1 );
      vertices.reset();
    RefVertex* cvtx_vertex = vertices.size() ? vertices.get() : 0;
      // Attach RefVertex to CoVertex if necessary
    if( cvtx_vertex != vertex )
        // Wrong RefVertex.  Unhook from that one.
      if( cvtx_vertex )
        cvtx_vertex->remove_sense_entity(cvtx);
        if (NULL == cvtx_vertex->get_point_ptr())
          destroy_dead_entity( cvtx_vertex );
      cvtx->attach_basic_topology_entity( vertex );
      edge_modified = true;
      // Second iteration is for end RefVertex
    vertex = end_vertex;
  if( !edge_created && edge_modified && !edge->deactivated() )
    AppUtil::instance()->send_event(GeometryEvent(GeometryEvent::GEOMETRY_TOPOLOGY_MODIFIED, edge));
    CGMHistory::Event evt2(CGMHistory::TOPOLOGY_CHANGED, edge);
    const_cast<CGMHistory&>(mHistory).add_event(evt2);
    CGMHistory::Event evt(CGMHistory::GEOMETRY_CHANGED, edge);
  return edge;
RefFace * GeometryQueryTool::make_RefFace ( Surface surface_ptr) const
Definition at line 1762 of file GeometryQueryTool.cpp.
  int i;
  DLIList<LoopSM*> loopsms;
  DLIList<CoEdgeSM*> coedgesms;
    // Get/construct RefFace for surface.
  bool face_created = false;
  bool face_modified = false;
  bool face_modified2 = false;
  RefFace* face = CAST_TO( surface_ptr->topology_entity(), RefFace );
  if( !face )
    face = dynamic_cast<RefFace*>(check_mergeable_refentity(surface_ptr));
    //Including this call in here in case the surface a composite and
    //hidden curves need to be removed in the graphics.
    if( face )
      face_modified2 = true;
  if( !face )
    face = RefEntityFactory::instance()->construct_RefFace(surface_ptr);
    face_created = true;
  assert(!!face);
  bool merged = face->bridge_manager()->number_of_bridges() > 1;
    // First construct all the RefEdges.  If the Curves
    // were merged, the RefEdges will be constructed merged.
    // We need the merged RefEdges to determined which
    // CoEdges and Loops need to be merged.  We could do this
    // with one loop by getting the curves directly from the
    // surface.  However, that might result in different
    // RefEdge IDs, so do it with nested loops like the old code.
  loopsms.clean_out();
  surface_ptr->loopsms( loopsms );
  loopsms.reset();
  for( i = loopsms.size(); i--; )
    LoopSM* loopsm = loopsms.get_and_step();
    loopsm->coedgesms(coedgesms);
    coedgesms.reset();
      CoEdgeSM* coedgesm = coedgesms.get_and_step();
      curves.clean_out();
                    "Surface %d has %d curves.\n", face->id(), curves.size());
        if( curves.size() == 0 )
          continue;
      RefEdge* edge = make_RefEdge( curves.get() );
      if( !edge )
        PRINT_ERROR("Failed to construct RefEdge in Surface %d\n",face->id());
    // If the Surface was merged, make sure it can remain merged
  if (merged && !make_merged_RefFace(surface_ptr))
    merged = false;
    // If !merged, then if necessary unmerge the RefFace
  if( !merged && face->bridge_manager()->number_of_bridges() > 1 )
    PRINT_WARNING("Unmerging Surface %d.\n", face->id() );
      // unmerge
    face->bridge_manager()->remove_bridge(surface_ptr);
      // reset bridge sense on unmerged surface
    if (surface_ptr->bridge_sense() == CUBIT_REVERSED)
      surface_ptr->reverse_bridge_sense();
      // if the first bridge in the old refface is now reversed,
      // flip the refface.
    if (face->get_surface_ptr()->bridge_sense() == CUBIT_REVERSED)
      face->bridge_manager()->reverse_bridge_senses();
      face->reverse_topology();
      // construct new refface for unmerged surface.
    // If the sense of the Surface with respect to the RefFace is
    // reversed, need to construct Loops and CoEdges reversed.
  bool need_to_reverse = (surface_ptr->bridge_sense() == CUBIT_REVERSED);
    // Construct LoopSMs and CoEdgeSMs, and attach
  loopsms.reset();
  DLIList<SenseEntity*> coedges, old_coedges;
  DLIList<GroupingEntity*> loops(loopsms.size()), dead_loops;
      // Get/construct Loop
    if( loop && !merged && loop->bridge_manager()->number_of_bridges() > 1 )
      loop->bridge_manager()->remove_bridge( loopsm );
      loop = new Loop( loopsm );
      face_modified = true;
    else if( !loop )
      // If loop is already attached to some other RefFace
      // we cannot use it.  NOTE:  Removing the Loop from
      // the other RefFace is NOT an option, even if the
      // loop has only our loopsm.  If we were to remove it
      // we could potentially miss the fact that the other
      // RefFace was modified when doing make_RefFace for
      // RefFace.
    RefFace* loop_face = loop->get_ref_face_ptr();
    if( loop_face && loop_face != face )
    loops.append(loop);
      // Get CoEdges in the appropriate order
    if( coedgesms.size() == 0 )
      PRINT_ERROR("Encountered Loop with no CoEdges in Surface %d.\n",
        face->id() );
      continue;
    if( need_to_reverse )
    coedgesms.reset();
      // Consturct/update each CoEdge
    int j;
    for( j = coedgesms.size(); j--; )
        // If the CoEdge is merged but the surface isn't, unmerge
        // the CoEdge
      if( coedge && !merged && coedge->bridge_manager()->number_of_bridges() > 1 )
        coedge->bridge_manager()->remove_bridge( coedgesm );
        coedge = 0;
        // If CoEdge belongs to a loop in some other face, don't
        // use it.
      if( coedge && coedge->get_loop_ptr() && coedge->get_loop_ptr() != loop )
        coedge = 0;
        // If the CoEdgeSM doesn't already have an owning CoEdge
        // (or we unmerged) create a new CoEdge
      if( !coedge )
        coedge = new CoEdge();
        coedge->bridge_manager()->add_bridge( coedgesm );
      coedges.append( coedge );
        // Find the RefEdge to attach to
      curves.clean_out();
      coedgesm->curves( curves );
        continue; // error message should have been printed already
      RefEdge* edge = dynamic_cast<RefEdge*>(curve->topology_entity());
      assert( edge != NULL );
        // Figure out what the CoEdge sense should be.
        // The CoEdge sense should be the product ("product"
        // as in multiply) of three
        // senses: 1) the sense of the surface wrt its RefFace,
        // 2) the sense of the curve wrt its RefEdge, and 3)
        // the sense of the CoEdgeSM.
      bool curve_reversed = (CUBIT_REVERSED == curve->bridge_sense());
      bool reverse = (curve_reversed != need_to_reverse);
      CubitSense sense = coedgesm->sense();
      if( reverse )
        sense = CubitUtil::opposite_sense(sense);
      if( coedge->get_sense() != sense )
        coedge->set_sense( sense );
        // Attach RefEdge to CoEdge (if it isn't already)
      RefEdge* coedge_edge = coedge->get_ref_edge_ptr();
      if (coedge_edge != edge)
        if (coedge_edge)
          coedge_edge->remove_sense_entity(coedge);
          destroy_dead_entity(coedge_edge);
        coedge->attach_basic_topology_entity(edge);
      // Attach CoEdges to Loop
    old_coedges.clean_out();
    loop->set_sense_entity_list(coedges, old_coedges);
      // Clean up dead coedges
    while (old_coedges.size())
      CoEdge* dead_coedge = dynamic_cast<CoEdge*>(old_coedges.pop());
      assert(!dead_coedge->get_loop_ptr());
      destroy_dead_entity(dead_coedge);
  } // end for( i == loopsms )
    // Attach loops
  face->set_grouping_entity_list( loops, dead_loops );
    // Remove any dead loops
  while (dead_loops.size())
    GroupingEntity* loop = dead_loops.pop();
    destroy_dead_entity(loop);
  if( !face_created && face_modified && !face->deactivated() )
    AppUtil::instance()->send_event(GeometryEvent(GeometryEvent::GEOMETRY_TOPOLOGY_MODIFIED, face));
    CGMHistory::Event evt2(CGMHistory::TOPOLOGY_CHANGED, face);
    CGMHistory::Event evt(CGMHistory::GEOMETRY_CHANGED, face);
  else if(face_modified2)
    AppUtil::instance()->send_event(GeometryEvent(GeometryEvent::TOPOLOGY_MODIFIED, face));
    CGMHistory::Event evt(CGMHistory::TOPOLOGY_CHANGED, face);
  return face;
Definition at line 2644 of file GeometryQueryTool.cpp.
     // first, handle making the new RefVertex's; check for
     // existing chain afterwards
   RefVertex* vertex = 0;
     // First check to make sure we haven't already created a RefVertex
     // from this point
   TopologyEntity* topo = point->topology_entity();
   vertex = CAST_TO(topo, RefVertex);
   if ( vertex == NULL)
     assert( topo == NULL );
     RefEntity *re_ptr = check_mergeable_refentity(point);
     if (re_ptr != NULL)
       vertex = dynamic_cast<RefVertex*>(re_ptr);
   if (vertex == NULL)
       // Create a RefVertex from this TBPoint.
     vertex = RefEntityFactory::instance()->construct_RefVertex(point);
   assert(vertex != NULL);
   return vertex;
RefVolume * GeometryQueryTool::make_RefVolume ( Lump lump_ptr,
bool &  vol_modified
) const [private]
Definition at line 1466 of file GeometryQueryTool.cpp.
  int i;
  DLIList<ShellSM*> shellsms;
  DLIList<GroupingEntity*> old_shells, new_shells;
  bool volume_created = false;
  volume_modified = false;
  RefVolume* volume = CAST_TO( lump_ptr->topology_entity(), RefVolume );
  if( ! volume )
    volume = RefEntityFactory::instance()->construct_RefVolume(lump_ptr);
    volume_created = true;
  if( ! volume )
    PRINT_ERROR("Volume creation failed in GeometryQueryTool::make_RefVolume\n");
    assert( !!volume );
    return 0;
  lump_ptr->shellsms( shellsms );
  shellsms.reset();
  for( i = shellsms.size(); i--; )
    bool shell_modified;
      // Don't use a shell if it is in a different RefVolume.
      // Can't move shells or other RefVolume may appear  unmodified
      // in later call to make_RefVolume.
// This breaks things -- live without it for now
//    ShellSM* shellsm = shellsms.get_and_step();
//    Shell* shell = dynamic_cast<Shell*>(shellsm->topology_entity());
//    if (shell && shell->get_basic_topology_entity_ptr() &&
//                 shell->get_basic_topology_entity_ptr() != volume)
//      shell->bridge_manager()->remove_bridge(shellsm);
      // Build/update Shell
    Shell* shell = make_Shell( shellsms.get_and_step(), shell_modified );
    if( !shell )
      PRINT_ERROR("Shell creation failed in GeometryQueryTool::make_RefVolume\n");
      PRINT_ERROR("Aborting construction of Volume %d\n", volume->id() );
      assert( !!shell );
      return 0;
    if( shell_modified )
      volume_modified = true;
      // If the shell is new (not already part of RefVolume) then
      // we will be modifying the RefVolume when we add it later.
    BasicTopologyEntity* parent = shell->get_basic_topology_entity_ptr();
    if (parent != volume)
      if (parent)
        parent->remove_grouping_entity(shell);
    new_shells.append( shell );
  volume->set_grouping_entity_list( new_shells, old_shells );
  while( old_shells.size() )
    GroupingEntity* shell = old_shells.pop();
    destroy_dead_entity( shell );
  if (volume->deactivated())
  else if(!volume_created && volume_modified )
#ifndef ALPHA_LAYTRACKS3D
    AppUtil::instance()->send_event(GeometryEvent(GeometryEvent::TOPOLOGY_MODIFIED, volume));
    CGMHistory::Event evt(CGMHistory::TOPOLOGY_CHANGED, volume);
#endif
  return volume;
Shell * GeometryQueryTool::make_Shell ( ShellSM shellsm_ptr,
bool &  shell_modified
) const [private]
Definition at line 1563 of file GeometryQueryTool.cpp.
  Shell* shell = CAST_TO( shellsm_ptr->topology_entity(), Shell );
  shell_modified = false;
  if( !shell )
    shell = new Shell(shellsm_ptr);
  assert( shell != NULL );
  DLIList<CoFace*> face_cofaces(2);
  //shell->co_faces( old_cofaces );
  DLIList<SenseEntity*> new_cofaces, old_cofaces;
  shellsm_ptr->surfaces( surfaces );
  int i;
  surfaces.reset();
  for( i = surfaces.size(); i--; )
    Surface* surface = surfaces.get_and_step();
    RefFace* face = make_RefFace(surface);
    if( !face )
      PRINT_ERROR("Surface creation failed in GeometryQueryTool::make_Shell\n");
      assert( !!face );
      return 0;
    CubitSense sense = surface->get_shell_sense( shellsm_ptr );
    if( surface->bridge_sense() == CUBIT_REVERSED )
      sense = CubitUtil::opposite_sense( sense );
      // If sense is CUBIT_UNKNOWN, we have a two-sided
      // face and need to make two CoFaces.
    int num_cofaces = 1;
    if( sense == CUBIT_UNKNOWN )
      DLIList<ShellSM*> surf_shells(2);
      surface->shellsms( surf_shells );
      assert( surf_shells.is_in_list(shellsm_ptr) );
      num_cofaces = 2;
      sense = CUBIT_FORWARD;
      // If two CoFaces, loop once for each
    face_cofaces.clean_out();
    face->co_faces(face_cofaces);
    for( int k = 0; k < num_cofaces; k++ )
      CoFace* coface = 0;
      for( int j = face_cofaces.size(); j--; )
        CoFace* tmp_coface = face_cofaces.get();
        if( tmp_coface->get_sense() == sense &&
            tmp_coface->get_shell_ptr() == shell )
          coface = tmp_coface;
          break;
      if (!coface)
        coface = new CoFace();
        coface->attach_basic_topology_entity( face );
        shell_modified = true;
        if( coface->get_sense() != sense )
          coface->set_sense( sense );
      new_cofaces.append(coface);
        // If we loop to create a second CoFace between
        // the same Surface-Shell pair, create it with
        // the opposite sense.
  shell->set_sense_entity_list( new_cofaces, old_cofaces );
    // Destroy any unwanted CoFaces (those remaining
    // in old_cofaces)
  while( old_cofaces.size() )
    CoFace* dead_coface = dynamic_cast<CoFace*>(old_cofaces.pop());
    assert(!dead_coface->get_shell_ptr());
    destroy_dead_entity(dead_coface);
  return shell;
Returns the bounding box of the model. Include free entities.
Definition at line 4327 of file GeometryQueryTool.cpp.
  int i;
  CubitBox result;
  DLIList<Body*> bodies;
  this->bodies(bodies);
  DLIList<RefEntity*> free_entity_list;
  this->get_free_ref_entities(free_entity_list);
  if (!(bodies.size() + free_entity_list.size()))
    return result;
  bodies.reset();
  free_entity_list.reset();
  if( bodies.size() )
    result = bodies.get_and_step()->bounding_box();
    for ( i = bodies.size()-1; i--; )
      result |= bodies.get_and_step()->bounding_box();
    i = free_entity_list.size();
  else
    result = free_entity_list.get_and_step()->bounding_box();
    i = free_entity_list.size()-1;
  for ( ; i>0 ; i-- )
    result |= free_entity_list.get_and_step()->bounding_box();
  return result;
Definition at line 6838 of file GeometryQueryTool.cpp.
  for (IGESet::const_iterator iter = igeSet.begin(); iter != igeSet.end(); ++iter)
    (*iter)->notify_transform( entity->bridge_manager()->topology_bridge(), xform );
void GeometryQueryTool::notify_observers_of_transform ( RefEntity ref_entity,
const CubitTransformMatrix transform = NULL
) const [private]
Definition at line 6878 of file GeometryQueryTool.cpp.
  ref_entity->notify_sub_all_observers( GeometryEvent::GEOMETRY_MODIFIED );
  //CGMHistory::Event evt(CGMHistory::GEOMETRY_TRANSFORMED, ref_entity);
  //const_cast<CGMHistory&>(mHistory).add_event(evt);
void GeometryQueryTool::notify_observers_of_transform ( DLIList< RefEntity * > &  ref_ents,
const CubitTransformMatrix xform = NULL
) const [private]
Definition at line 6847 of file GeometryQueryTool.cpp.
  if( xform )
    //gather all the children
    DLIList<RefEntity*> all_ref_ents;
    RefEntity::get_all_child_ref_entities( ref_ents, all_ref_ents );
    all_ref_ents.uniquify_ordered();
    all_ref_ents += ref_ents;
    for(int i=0; i<all_ref_ents.size(); i++)
      GeometryEvent evt(GeometryEvent::GEOMETRY_TRANSFORMED, all_ref_ents[i]);
      all_ref_ents[i]->notify_observers(&evt);
    AppUtil::instance()->send_event(TransformEvent(*xform, all_ref_ents.as_vector() ));
  else
    for( int i=0; i<ref_ents.size(); i++ )
      RefEntity *ent = ref_ents[i];
      ent->notify_sub_all_observers( GeometryEvent::GEOMETRY_MODIFIED );
< Append global lists to arguments
Number of bodies in current session.
Definition at line 4410 of file GeometryQueryTool.cpp.
Number of curves in current session.
Definition at line 4430 of file GeometryQueryTool.cpp.
Number of surfaces in current session.
Definition at line 4425 of file GeometryQueryTool.cpp.
Number of groups in current session.
Definition at line 4420 of file GeometryQueryTool.cpp.
Number of vertices in current session.
Definition at line 4435 of file GeometryQueryTool.cpp.
Number of volumes in current session.
Definition at line 4415 of file GeometryQueryTool.cpp.
Definition at line 5636 of file GeometryQueryTool.cpp.
  MergeTool* mt = MergeTool::instance();
  int i;
    // Check for merged vertices
  DLIList<RefVertex*> vertices;
  body->ref_vertices( vertices );
  for (i = vertices.size(); i--; )
    if ( mt->entity_merged( vertices.get_and_step() ) )
      PRINT_ERROR("Cannot transform %s (Body %d) with merged geomtery.\n",
          body->entity_name().c_str(), body->id() );
      return CUBIT_FALSE;
    // Need to check for merged surfaces because can have surfaces
    // w/out vertices.
  DLIList<RefFace*> surfaces;
  body->ref_faces( surfaces );
  for (i = surfaces.size(); i--; )
    if ( mt->entity_merged( surfaces.get_and_step() ) )
      return CUBIT_FALSE;
  return CUBIT_TRUE;
Definition at line 6888 of file GeometryQueryTool.cpp.
  if (bte->get_parents() > 0)
    PRINT_ERROR("Cannot transform %s (%s %d) : not a free %s\n",
      bte->entity_name().c_str(), bte->class_name(), bte->id(), bte->class_name() );
    return CUBIT_FALSE;
  DLIList<RefEntity*> list(1);
  list.append( bte );
  if (MergeTool::instance()->contains_merged_entities( list ))
    PRINT_ERROR("Cannot tranmform %s (%s %d) : "
                "%s is merged or contains merged geomtry.\n",
    return CUBIT_FALSE;
  return CUBIT_TRUE;
void GeometryQueryTool::ref_edges ( DLIList< RefEdge * > &  ref_edges)
Returns all curves in the current session.
Definition at line 4382 of file GeometryQueryTool.cpp.
CubitStatus GeometryQueryTool::ref_entity_list ( char const *  keyword,
DLIList< RefEntity * > &  entity_list,
const CubitBoolean  print_errors = CUBIT_TRUE
Return ref entities in entity_list (overwrites list). returns CUBIT_FAILURE if keyword is not a ref entity name, and optionally prints error message.
global-list-functions Global entity list functions
Definition at line 4319 of file GeometryQueryTool.cpp.
  return RefEntityFactory::instance()->ref_entity_list(keyword, entity_list,
                                                       print_errors);
void GeometryQueryTool::ref_faces ( DLIList< RefFace * > &  ref_faces)
Returns all surfaces in the current session.
Definition at line 4377 of file GeometryQueryTool.cpp.
void GeometryQueryTool::ref_groups ( DLIList< RefGroup * > &  ref_groups)
Returns all groups in the current session.
Definition at line 4372 of file GeometryQueryTool.cpp.
void GeometryQueryTool::ref_vertices ( DLIList< RefVertex * > &  ref_vertices)
Returns all the vertices in the current session.
Definition at line 4387 of file GeometryQueryTool.cpp.
void GeometryQueryTool::ref_volumes ( DLIList< RefVolume * > &  ref_volumes)
Returns all volumes in the current session.
Definition at line 4367 of file GeometryQueryTool.cpp.
CubitStatus GeometryQueryTool::reflect ( DLIList< Body * > &  bodies,
const CubitVector point,
const CubitVector axis,
DLIList< Body * > *  bodies_reflected = NULL,
bool  preview = false
Reflect a list of bodies about a plane defined by an axis.
Definition at line 6679 of file GeometryQueryTool.cpp.
  Body *tmp_body;
  CubitStatus result = CUBIT_FAILURE;
  CubitTransformMatrix prev_xform;
  prev_xform.translate(-point);
  CubitTransformMatrix ref_mat;
  ref_mat.reflect(normal );
  CubitTransformMatrix mov_mat;
  mov_mat.translate( point );
  CubitTransformMatrix total_transform;
  total_transform = mov_mat*ref_mat*prev_xform;
  DLIList<RefEntity*> ents_transformed;
  if (preview)
    for (int i = 0; i < bodies.size(); i++)
      DLIList<RefEdge*> edges;
      bodies[i]->ref_edges(edges);
      if( edges.size() )
        for (int i = 0; i < edges.size(); i++)
          GMem poly;
          if( CUBIT_SUCCESS == edges[i]->get_graphics(poly) )
            poly.transform( total_transform );
            GfxPreview::draw_polyline(poly.point_list(), poly.point_list_size(), CUBIT_BLUE_INDEX);
          else if( edges[i]->start_vertex() == edges[i]->end_vertex() )
            CubitVector tmp_pt = edges[i]->start_vertex()->coordinates();
            tmp_pt = total_transform*tmp_pt;
            GfxPreview::draw_point( tmp_pt, CUBIT_BLUE_INDEX);
      else
        //just draw the surfaces
        DLIList<RefFace*> faces;
        bodies[i]->ref_faces( faces );
        for( int i=0; i<faces.size(); i-- )
          GMem poly;
          faces.get_and_step()->get_graphics( poly );
          int* facet_list = poly.facet_list();
          GPoint* plist = poly.point_list();
          GPoint p[3];
          for (i = 0; i < poly.fListCount; )
            int sides = facet_list[i++];
            if (sides != 3)
              i += sides;
              continue;
            else
              p[0] = plist[facet_list[i++]];
              p[1] = plist[facet_list[i++]];
              p[2] = plist[facet_list[i++]];
              GfxPreview::draw_polygon(p, 3, CUBIT_BLUE_INDEX, CUBIT_BLUE_INDEX, false);
      GfxPreview::flush();
  //first, reflect the underlying geometry
  int i;
  for( i=bodies.size(); i--;)
    tmp_body = bodies.get_and_step();
    BodySM* bodysm = tmp_body->get_body_sm_ptr();
    GeometryQueryEngine* engine = bodysm->get_geometry_query_engine();
    // Move to origin
    result = engine->translate( bodysm, -point );
    if (result)
      CubitTransformMatrix xform;
      xform.translate( -point );
      notify_intermediate_of_transform( tmp_body, xform );
    else
      PRINT_ERROR("Reflect of %s (%s %d) failed.\n",
        tmp_body->entity_name().c_str(), tmp_body->class_name(), tmp_body->id() );
      return result;
    result = engine->reflect( bodysm, normal );
    if (result)
      xform.reflect( normal);
    else
      return result;
    result = engine->translate( bodysm, point );
    if (result)
      xform.translate( point );
      if( bodies_reflected )
        bodies_reflected->append( tmp_body );
      ents_transformed.append( tmp_body );
    else
      return result;
  for( i=0; i<ents_transformed.size(); i++)
    tmp_body = (Body*)ents_transformed[i];
    tmp_body = make_Body( tmp_body->get_body_sm_ptr() );
    if( tmp_body != ents_transformed[i] )
      ents_transformed[i] = tmp_body;
  if( ents_transformed.size() )
    notify_observers_of_transform( ents_transformed, &total_transform );
  else if( preview )
  else
CubitStatus GeometryQueryTool::reflect ( DLIList< BasicTopologyEntity * > &  btes,
DLIList< BasicTopologyEntity * > *  btes_reflected = NULL,
bool  check_to_transform = true,
Reflect a BasicTopologyEntity about a plane defined by an axis.
Definition at line 7451 of file GeometryQueryTool.cpp.
  DLIList<RefEntity*> transformed_ents;
  for( int k=0; k<btes.size(); k++ )
    BasicTopologyEntity *bte = btes[k];
    if( check_to_transform )
      if (!okay_to_transform( bte ))
    if (preview)
      if(bte->dimension()==0)
        DLIList<RefVertex*> points;
        bte->ref_vertices(points);
        for (int i = 0; i < points.size(); i++)
          CubitVector temp(points[i]->center_point());
          temp = total_transform*temp;
          GfxPreview::draw_point(temp, CUBIT_BLUE_INDEX);
      else
        bte->ref_edges(edges);
        for (int j = 0; j < edges.size(); j++)
          GMem poly;
          if( CUBIT_SUCCESS == edges[j]->get_graphics(poly) )
          else if( edges[j]->start_vertex() == edges[j]->end_vertex() )
            CubitVector tmp_pt = edges[j]->start_vertex()->coordinates();
      continue;
    GeometryEntity* geom = bte->get_geometry_entity_ptr();
    GeometryQueryEngine* engine = geom->get_geometry_query_engine();
    CubitStatus result;
    // Move to origin
    result = engine->translate( geom, -point );
    if (result)
      notify_intermediate_of_transform( bte, xform );
    else
        bte->entity_name().c_str(), bte->class_name(), bte->id() );
      return result;
    result = engine->reflect( geom, normal );
    if (result)
    else
      return result;
    result = engine->translate( geom, point );
    if (result)
      if( btes_reflected )
        btes_reflected->append( bte );
      transformed_ents.append( bte );
    else
      return result;
  if( transformed_ents.size() )
    notify_observers_of_transform( transformed_ents, &total_transform );
  else if( preview )
  else
void GeometryQueryTool::reflect ( DLIList< RefEntity * > &  entities_to_transform,
bool  check_before_transforming,
DLIList< RefEntity * > &  entities_transformed,
Definition at line 6579 of file GeometryQueryTool.cpp.
  //reflect free, merged-away entities
  DLIList<TopologyBridge*> free_ents;
  get_merged_away_free_entities( entities_to_reflect, free_ents );
  int i;
  if (!preview)
    for( i=free_ents.size(); i--; )
      TopologyBridge *bridge = free_ents.get_and_step();
      Curve *curve= CAST_TO( bridge, Curve );
      TBPoint *tmp_point = CAST_TO( bridge, TBPoint );
      if( curve || tmp_point )
        GeometryEntity *geom = CAST_TO( bridge, GeometryEntity );
        CubitStatus result = engine->translate( geom, -point );
        if (CUBIT_SUCCESS != result) {
          PRINT_ERROR("GeometryQueryEngine::translate failed.\n");
          return;
          PRINT_ERROR("GeometryQueryEngine::reflect failed.\n");
          return;
          return;
  RefFace *tmp_face;
  RefEdge *tmp_curve;
  RefVertex *tmp_vertex;
  CubitStatus result;
  DLIList<Body*> bodies_to_reflect;
  DLIList<BasicTopologyEntity*> ents_to_reflect;
  CAST_LIST( entities_to_reflect, bodies_to_reflect, Body);
  if( bodies_to_reflect.size() != entities_to_reflect.size() )
    for( int k=0; k<entities_to_reflect.size(); k++ )
      RefEntity *ent = entities_to_reflect[k];
      if( ( tmp_face = CAST_TO( ent, RefFace ) ) != NULL )
        ents_to_reflect.append( tmp_face );
      else if( (tmp_curve = CAST_TO( ent, RefEdge ) ) != NULL )
        ents_to_reflect.append( tmp_curve );
      else if( (tmp_vertex = CAST_TO( ent, RefVertex ) ) != NULL )
        ents_to_reflect.append( tmp_vertex );
  if( bodies_to_reflect.size() )
    DLIList<Body*> bodies_reflected;
    result = reflect( bodies_to_reflect,
      point, normal,
      &bodies_reflected,
      preview );
    if( result )
      for( int k=0; k<bodies_reflected.size(); k++ )
        entities_transformed.append( bodies_reflected[k] );
  if( ents_to_reflect.size() )
    DLIList<BasicTopologyEntity*> btes_reflected;
     result = reflect( ents_to_reflect,
      point,
      normal,
      &btes_reflected,
      preview );
    if( result )
      for( int k=0; k<btes_reflected.size(); k++ )
        entities_transformed.append( btes_reflected[k] );
Definition at line 5275 of file GeometryQueryTool.cpp.
  return (CubitStatus)igeSet.insert(engine_ptr).second;
CubitSense GeometryQueryTool::relative_sense ( Surface surface1,
Surface surface2
) [static]
Definition at line 2630 of file GeometryQueryTool.cpp.
  CubitVector point1 = surf1->bounding_box().center();
  CubitVector point2 = surf2->bounding_box().center();
  CubitVector point = 0.5 * (point1 + point2);
  CubitVector closest1, closest2, normal1, normal2;
  surf1->closest_point_trimmed( point, closest1 );
  surf2->closest_point( closest1, &closest2, &normal2 );
  surf1->closest_point( closest2, &closest1, &normal1 );
  return normal1 % normal2 < 0 ? CUBIT_REVERSED : CUBIT_FORWARD;
Removes a geometry query engine from the list. Returns CUBIT_FAILURE if it wasn't in the list.
Definition at line 1198 of file GeometryQueryTool.hpp.
  assert(gqe_ptr != 0);
  if (gqeList.move_to(gqe_ptr)) {
    gqeList.remove();
  return status;
void GeometryQueryTool::reset_geometry_factor ( ) [inline, static]
Resets geometry factor back to 500.0.
Definition at line 1144 of file GeometryQueryTool.hpp.
Need to deprecate.
CubitStatus GeometryQueryTool::rotate ( DLIList< Body * > &  bodies,
double  degrees,
DLIList< Body * > *  bodies_rotated = NULL,
Rotate a Body an angle about an axis.
Definition at line 5974 of file GeometryQueryTool.cpp.
  xform.rotate( angle, axis );
  for( int k=0; k<bodies.size(); k++ )
    Body *body = bodies[k];
      if (!okay_to_transform( body ))
        continue;
    if (preview)
      body->ref_edges(edges);
      if( edges.size() )
          GMem poly;
            poly.transform(xform);
            tmp_pt = xform*tmp_pt;
      else
        body->ref_faces( faces );
          GMem poly;
          GPoint p[3];
            if (sides != 3)
              i += sides;
              continue;
            else
      continue;
    BodySM* bodysm = body->get_body_sm_ptr();
    CubitStatus result = engine->rotate( bodysm, axis, angle );
    if (result)
      notify_intermediate_of_transform( body, xform );
      if( bodies_rotated )
        bodies_rotated->append( body );
      ents_transformed.append( body );
    else
      PRINT_ERROR("Rotate of %s (%s %d) failed.\n",
      body->entity_name().c_str(), body->class_name(), body->id() );
    notify_observers_of_transform( ents_transformed, &xform );
  else if( preview )
  else
    return CUBIT_FAILURE;
const CubitVector normal,
double  degrees,
Rotate a Body an angle about an axis, defined by a point and a direction.
Definition at line 6081 of file GeometryQueryTool.cpp.
  CubitTransformMatrix rot_mat;
  rot_mat.rotate( degrees, direction );
  total_transform = mov_mat*rot_mat*prev_xform;
        continue;
    if (preview)
      if( edges.size() )
          GMem poly;
      else
          GMem poly;
          GPoint p[3];
            if (sides != 3)
              i += sides;
              continue;
            else
      continue;
    // Move to origin
    if (result)
    else
      continue;
    // Rotate about direction vector
    result = engine->rotate( bodysm, direction, degrees );
    if (result)
      notify_intermediate_of_transform( body, rot_mat );
    else
      continue;
    result= engine->translate( bodysm, point );
    if (result)
    else
      continue;
  else if( preview )
  else
CubitStatus GeometryQueryTool::rotate ( DLIList< RefEntity * > &  entities_to_transform,
double  degrees,
bool  check_to_transform,
Definition at line 5864 of file GeometryQueryTool.cpp.
  //rotate free, merged-away entities first
  get_merged_away_free_entities( entities_to_transform, free_ents );
  int i;
  if (!preview)
          return result;
        result = engine->rotate( geom, direction, angle );
          PRINT_ERROR("GeometryQueryEngine::rotate failed.\n");
          return result;
          return result;
  RefFace *tmp_face;
  RefEdge *tmp_curve;
  CubitStatus result = CUBIT_SUCCESS;
  DLIList<Body*> bodies_to_rotate;
  DLIList<BasicTopologyEntity*> ents_to_rotate;
  CAST_LIST( entities_to_transform, bodies_to_rotate, Body);
  if( bodies_to_rotate.size() != entities_to_transform.size() )
    for( int k=0; k<entities_to_transform.size(); k++ )
      RefEntity *ent = entities_to_transform[k];
        ents_to_rotate.append( tmp_face );
        ents_to_rotate.append( tmp_curve );
        ents_to_rotate.append( tmp_vertex );
  if( bodies_to_rotate.size() )
    DLIList<Body*> bodies_rotated;
    result = rotate( bodies_to_rotate,
      point, direction, angle,
      &bodies_rotated,
      check_before_transforming, preview);
    if( result )
      for( int k=0; k<bodies_rotated.size(); k++ )
        entities_transformed.append( bodies_rotated[k] );
  if( ents_to_rotate.size() )
    DLIList<BasicTopologyEntity*> btes_rotated;
     result = rotate( ents_to_rotate,
      point,
      direction,
      angle,
      &btes_rotated,
      preview );
    if( result )
      for( int k=0; k<btes_rotated.size(); k++ )
        entities_transformed.append( btes_rotated[k] );
  if( entities_transformed.size() )
  else
CubitStatus GeometryQueryTool::rotate ( DLIList< BasicTopologyEntity * > &  btes,
double  degrees,
DLIList< BasicTopologyEntity * > *  btes_rotated = NULL,
Rotate a BacisTopologyEntity an angle about an axis.
Definition at line 7147 of file GeometryQueryTool.cpp.
        continue;
    if (preview)
          temp = xform*temp;
      else
          GMem poly;
        if (edges.size() == 0)
            CubitVector p(points[i]->center_point());
            CubitVector q =xform*p;
            GfxPreview::draw_point(q, CUBIT_BLUE_INDEX);
      continue;
    CubitStatus result = engine->rotate( geom, axis, angle );
    if (result)
      if( btes_rotated )
        btes_rotated->append( bte );
      ents_transformed.append( bte );
    else
   else if( preview )
  else
double  degrees,
Definition at line 7004 of file GeometryQueryTool.cpp.
  rot_mat.rotate( angle, direction );
        continue;
    if (preview)
      else
          GMem poly;
            poly.transform(total_transform);
            p = total_transform*p;
            GfxPreview::draw_point(p, CUBIT_BLUE_INDEX);
      continue;
    CubitStatus result;
    // Move to origin
    if (result)
    else
      continue;
    if (result)
      notify_intermediate_of_transform( bte, rot_mat );
    else
      continue;
    result=engine->translate( geom, point );
    if (result)
      notify_intermediate_of_transform( bte, mov_mat );
      if( btes_rotated )
    else
      continue;
   else if( preview )
  else
Returns CUBIT_TRUE if all the entities have the same geometric query engine and if that is the same one as the default.
CubitStatus GeometryQueryTool::save_temp_geom_files ( DLIList< RefEntity * > &  ref_entity_list,
const char *  filename,
const CubitString cubit_version,
std::list< CubitString > &  files_written,
std::list< CubitString > &  types_written
Saves out a temporary geometry file containing specified entities that are of the same geometry engine.
Definition at line 208 of file GeometryQueryTool.cpp.
  int i;
// clear all attributes
  if (ref_entity_list.size() == 0) {
      // All bodies are to be exported
    RefEntityFactory::instance()->ref_entity_list("Body",
                                                  ref_entity_list);
      // add free ref entities
    get_free_ref_entities(ref_entity_list);
    // get all child entities
  DLIList<RefEntity*> child_list;
  RefEntity::get_all_child_ref_entities( ref_entity_list, child_list );
    // merge lists
  for(i = ref_entity_list.size(); i--; )
    ref_entity_list.get_and_step()->marked(1);
  for(i = child_list.size(); i--; )
    child_list.get_and_step()->marked(0);
    RefEntity* ent = ref_entity_list.get_and_step();
    if( ent->marked() )
      ent->marked(0);
      child_list.append(ent);
    // now call auto update on this combined list; this will update both visible
    // and hidden entities; the combined list should be used here, but only the
    // export list should be exported (some of the hidden entities might be directly
    // related to other entities on the export list, and we want to avoid exporting
    // those entities twice)
  CubitAttribUser::auto_update_cubit_attrib(child_list);
    // Get list of TopologyBridges to save
  DLIList<TopologyBridge*> geometry_list(ref_entity_list.size()), ref_ent_bridges;
  ref_entity_list.reset();
  for ( i = ref_entity_list.size(); i--; )
    RefEntity* ref_ent = ref_entity_list.get_and_step();
    TopologyEntity* topo_ent = dynamic_cast<TopologyEntity*>(ref_ent);
    if ( !topo_ent )
      PRINT_ERROR("Attempt to save %s (%s %d) as geometry.\n",
        ref_ent->entity_name().c_str(), ref_ent->class_name(), ref_ent->id());
      continue;
    ref_ent_bridges.clean_out();
    topo_ent->bridge_manager()->get_bridge_list(ref_ent_bridges);
    geometry_list += ref_ent_bridges;
    // Save virtual.
    (*itor)->export_geometry(geometry_list);
  //we need this list around so that we can remove the CSAs off
  // the entities under the virtual entities
  DLIList<TopologyBridge*> geometry_list2 = geometry_list;
  CubitStatus result = CUBIT_SUCCESS, temp_result;
  GeometryQueryEngine* gqe = NULL;
  //we're just going to mess with MBG stuff right now
  gqeList.reset();
  for( int k=0; k<gqeList.size(); k++)
    gqe = gqeList.get_and_step();
    CubitString file_written;
    CubitString type_written;
    temp_result = gqe->save_temp_geom_file(geometry_list, base_filename,
                                           cubit_version, file_written,
                                           type_written );
    if( file_written.length() )
      files_written.push_back( file_written );
      types_written.push_back( type_written );
    if (CUBIT_SUCCESS == temp_result) result = temp_result;
  //if there is still geometry left over....could not be handled
  if( geometry_list.size() )
    PRINT_ERROR("Not all geometry could be handled for save.\n");
  CubitAttribUser::clear_all_simple_attrib(child_list);
  //remove attributes off underlying entities of virtual geometry
  if( geometry_list2.size() )
    GeometryQueryTool::instance()->ige_remove_attributes( geometry_list2 );
  gqeList.reset();
  return result;
CubitStatus GeometryQueryTool::scale ( Body entity,
double  factor,
Scale a Body.
Definition at line 6324 of file GeometryQueryTool.cpp.
  CubitTransformMatrix pre_form;
  pre_form.translate( -point );
  xform.scale_about_origin( factor );
  CubitTransformMatrix post_form;
  post_form.translate( point );
 if (preview)
    if( edges.size() )
        GMem poly;
          poly.transform(pre_form);
          poly.transform(post_form);
          tmp_pt = pre_form*tmp_pt;
          tmp_pt = post_form*tmp_pt;
    else
        GMem poly;
        GPoint p[3];
          if (sides != 3)
            i += sides;
            continue;
          else
  //if (preview)
  //  DLIList<RefEdge*> edges;
  //  body->ref_edges(edges);
  //  for (int i = 0; i < edges.size(); i++)
  //    GMem poly;
  //    edges[i]->get_graphics(poly);
  //    poly.transform(pre_form);
  //    poly.transform(xform);
  //    poly.transform(post_form);
  //    GfxPreview::draw_polyline(poly.point_list(), poly.point_list_size(), CUBIT_BLUE_INDEX);
  //  GfxPreview::flush();
  //  return CUBIT_SUCCESS;
  CubitStatus result = engine->translate( bodysm, -point );
  if (result)
    notify_intermediate_of_transform( body, pre_form );
  else
    PRINT_ERROR("Scale of %s (%s %d) failed.\n",
  result = engine->scale( bodysm, factor );
  if (result)
  else
  if (result)
    notify_intermediate_of_transform( body, post_form );
  else
  notify_observers_of_transform( body );
  return result;
const CubitVector factors,
Scale a Body different factors in x, y, and z.
Definition at line 6458 of file GeometryQueryTool.cpp.
  xform.scale_about_origin( factors );
  if (preview)
    if( edges.size() )
        GMem poly;
    else
        GMem poly;
        GPoint p[3];
          if (sides != 3)
            i += sides;
            continue;
          else
  if (result)
  else
  result = engine->scale( bodysm, factors );
  if (result)
  else
  if (result)
  else
  return result;
CubitStatus GeometryQueryTool::scale ( BasicTopologyEntity entity,
double  factor,
Scale a BasicTopologyEntity.
Definition at line 7244 of file GeometryQueryTool.cpp.
  if (preview)
        temp = prev_xform*temp;
        temp = xform*temp;
        temp = mov_mat*temp;
    else
        GMem poly;
          poly.transform(prev_xform);
          poly.transform(mov_mat);
          tmp_pt = prev_xform*tmp_pt;
          tmp_pt = mov_mat*tmp_pt;
  if (result)
    notify_intermediate_of_transform( bte, prev_xform );
  else
    return result;
  result = engine->scale( geom, factor );
  if (result)
  else
    PRINT_ERROR("Scvale of %s (%s %d) failed.\n",
    return result;
  if (result)
    notify_observers_of_transform( bte );
  else
  return result;
Scale a BasicTopologyEntity different factors in x, y, and z.
Definition at line 7351 of file GeometryQueryTool.cpp.
  if (preview)
        temp = xform*temp;
    else
        GMem poly;
  if (result)
  else
  result = engine->scale( geom, factors );
  if (result)
  else
  if (result)
  else
  return result;
void GeometryQueryTool::scale ( DLIList< RefEntity * > &  entities_to_transform,
double  scale_x,
double  scale_y,
double  scale_z,
DLIList< RefEntity * > &  entities_scaled,
Definition at line 6229 of file GeometryQueryTool.cpp.
  CubitVector factors(scale_x, scale_y, scale_z);
  //scale free, merged-away entities first
  int i;
  if (!preview)
          TBPoint *tbpoint = CAST_TO( bridge, TBPoint );
          if( curve || tbpoint )
                return;
                PRINT_ERROR("GeometryQueryEngine::scale failed.\n");
                return;
                return;
  for(i=entities_to_transform.size(); i--; )
    RefEntity *tmp_ent = entities_to_transform.get_and_step();
    Body *tmp_body;
    RefFace* tmp_face;
    RefEdge *tmp_curve;
    if( ( tmp_body = CAST_TO( tmp_ent, Body ) ) != NULL )
      //non-uniform scaling
      if( scale_x != scale_y ||
          scale_x != scale_z ||
          scale_y != scale_z )
        // use GMT version for non-uniform scaling b/c it updates topology if it changes
        result = GeometryModifyTool::instance()->scale(tmp_body,point, factors,
                                                  check_before_transforming, preview,false);
        tmp_ent = tmp_body;
      else
        result = scale( tmp_body,point, CubitVector(scale_x, scale_y, scale_z),
    else if( ( tmp_face = CAST_TO( tmp_ent, RefFace ) ) != NULL )
     // only allow scaling of RefFaces if preview is on
     if (!preview)
         continue;
     result = scale( tmp_face,point, CubitVector(scale_x, scale_y, scale_z),
    else if( ( tmp_curve = CAST_TO( tmp_ent, RefEdge ) ) != NULL )
     result = scale( tmp_curve,point, CubitVector(scale_x, scale_y, scale_z),
    else if( ( tmp_vertex = CAST_TO( tmp_ent, RefVertex ) ) != NULL )
     result = scale( tmp_vertex,point, CubitVector(scale_x, scale_y, scale_z),
    if(result)
      entities_scaled.append( tmp_ent );
Set the default GeometryQueryEngine.
Definition at line 3510 of file GeometryQueryTool.cpp.
  int i;
  for (i = 0; i < gqeList.size(); i++)
    if(gqe == gqeList.get())
      break;
    gqeList.step();
  if(i == gqeList.size()) return CUBIT_FAILURE;
  GeometryQueryEngine* temp_ptr = gqeList.get();
  gqeList.remove();
  gqeList.insert_first(temp_ptr);
  PRINT_INFO("Geometry engine set to: %s\n", gqe->get_engine_version_string().c_str() );
Set the major/minor version of the active geometry engine.
Definition at line 3530 of file GeometryQueryTool.cpp.
  if (gqeList.size())
    gqeList.reset();
    return gqeList.get()->set_export_allint_version(version);
  else
    PRINT_WARNING("No active geometry engine.");
static void GeometryQueryTool::set_facet_bbox ( CubitBoolean  pass_flag) [inline, static]
Set facet box flag.
Definition at line 513 of file GeometryQueryTool.hpp.
      {useFacetBBox = pass_flag;}
void GeometryQueryTool::set_geometry_factor ( double  fac) [inline, static]
Sets geometry factor.
Definition at line 1149 of file GeometryQueryTool.hpp.
  if ( factor < .0099999999999 )
    return;
  else
    geometryToleranceFactor = factor;
void GeometryQueryTool::set_merge_test_bbox ( CubitBoolean  tof) [inline, static]
Sets bboxMergeTest variable.
Definition at line 1185 of file GeometryQueryTool.hpp.
{bboxMergeTest = tof;}
void GeometryQueryTool::set_merge_test_internal ( int  tof) [inline, static]
Definition at line 1187 of file GeometryQueryTool.hpp.
void GeometryQueryTool::set_sliver_curve_cleanup_tolerance ( double  tol) [inline, static]
Definition at line 1166 of file GeometryQueryTool.hpp.
void GeometryQueryTool::set_sliver_surface_cleanup_tolerance ( double  tol) [inline, static]
Definition at line 1161 of file GeometryQueryTool.hpp.
CubitStatus GeometryQueryTool::set_sme_dbl_option ( const char *  opt_name,
double  val
Set solid modeler double option.
Definition at line 3614 of file GeometryQueryTool.cpp.
  if (gqeList.size())
    gqeList.reset();
    return gqeList.get()->set_dbl_option( opt_name, val );
  else
CubitStatus GeometryQueryTool::set_sme_int_option ( const char *  opt_name,
int  val
Set solid modeler integer option.
Definition at line 3600 of file GeometryQueryTool.cpp.
  if (gqeList.size())
    gqeList.reset();
    return gqeList.get()->set_int_option( opt_name, val );
  else
double GeometryQueryTool::set_sme_resabs_tolerance ( double  new_resabs)
Sets solid modeler's resolution absolute tolerance.
Definition at line 3586 of file GeometryQueryTool.cpp.
  if (gqeList.size())
    gqeList.reset();
    return gqeList.get()->set_sme_resabs_tolerance( new_resabs );
  else
    return 0.0;
CubitStatus GeometryQueryTool::set_sme_str_option ( const char *  opt_name,
const char *  val
Set solid modeler string option.
Topology/geometry creation functions
Definition at line 3628 of file GeometryQueryTool.cpp.
  if (gqeList.size())
    gqeList.reset();
    return gqeList.get()->set_str_option( opt_name, val );
  else
CubitStatus GeometryQueryTool::straightline_intersections ( RefEdge ref_edge1,
CubitVector origin2,
CubitVector dir2,
DLIList< CubitVector > &  intersection_list,
CubitBoolean  bounded = CUBIT_FALSE,
CubitBoolean  closest = CUBIT_FALSE
) [private]
Definition at line 3670 of file GeometryQueryTool.cpp.
  Curve* curve_ptr1 = ref_edge1->get_curve_ptr();
  if( curve_ptr1 == NULL )
      PRINT_ERROR("Unable to retrieve underlying geometric entity of Curve %d\n"      "       This is a bug - please report it\n", ref_edge1->id() );
  CubitVector dir2 = dir;
  dir2.normalize();
  assert( curve_ptr1->geometry_type() == STRAIGHT_CURVE_TYPE );
  // Proceed with the intersection calculation
  CubitVector origin1, dir1;
  double origin_pnt1[3], dir_vec1[3], origin_pnt2[3], dir_vec2[3];
  if( ref_edge1->get_point_direction( origin1, dir1 ) == CUBIT_FAILURE )
    PRINT_ERROR( "Unable to get straight line information for Curve %d; aborting\n",
      ref_edge1->id() );
  origin1.get_xyz( origin_pnt1 ); origin2.get_xyz( origin_pnt2 );
  dir1.get_xyz( dir_vec1 ); dir2.get_xyz( dir_vec2 );
  AnalyticGeometryTool* agt = AnalyticGeometryTool::instance();
  int num_int;
  double int_pnt1[3], int_pnt2[3];
  num_int = agt->int_ln_ln( origin_pnt1, dir_vec1, origin_pnt2, dir_vec2,
    int_pnt1, int_pnt2 );
  if( num_int == 0 || (closest == CUBIT_FALSE && num_int == 2) )
    if( num_int == 0 )
      PRINT_ERROR( "Curves %d and the straight line defined by position %g, %g, %g, and direction %g, %g, %g are parallel - no intersection exists\n",
 ref_edge1->id(),  origin2.x(), origin2.y(), origin2.z(), dir2.x(), dir2.y(), dir2.z());
    else
      PRINT_ERROR( "Curves %d and the straight line defined by position %g, %g, %g, and direction %g, %g, %g do not intersect\n", ref_edge1->id(),
  if( bounded == CUBIT_TRUE )
    CubitVector start1 = ref_edge1->start_vertex()->coordinates();
    CubitVector end1 = ref_edge1->end_vertex()->coordinates();
    CubitVector start2 = origin2;
    CubitVector end2 = origin2 + dir;
    double start_pnt1[3], end_pnt1[3], start_pnt2[3], end_pnt2[3];
    start1.get_xyz( start_pnt1 ); start2.get_xyz( start_pnt2 );
    end1.get_xyz( end_pnt1 ); end2.get_xyz( end_pnt2 );
    if( num_int == 1 )
      // Vertex must be on both curves
      if( agt->is_pnt_on_ln_seg( int_pnt1, start_pnt1, end_pnt1 ) &&
        agt->is_pnt_on_ln_seg( int_pnt2, start_pnt2, end_pnt2 ) )
        intersection_list.append( CubitVector(int_pnt1) );
      else
        PRINT_WARNING( "intersection point of Curves was not within bounds of both curves\n");
    else
      // Only keep the vertices that are on the curve bounds
      if( agt->is_pnt_on_ln_seg( int_pnt1, start_pnt1, end_pnt1 ) )
      else
        PRINT_WARNING( "intersection point on Curve %d was not within it's bounds\n",
          ref_edge1->id() );
      if( agt->is_pnt_on_ln_seg( int_pnt2, start_pnt2, end_pnt2 ) )
        intersection_list.append( CubitVector(int_pnt2) );
      else
        PRINT_WARNING( "intersection point on the straight line defined by position %g, %g, %g, and direction %g, %g, %g  was not within it's bounds\n",
        origin2.x(), origin2.y(), origin2.z(), dir2.x(), dir2.y(), dir2.z() );
    if( intersection_list.size() == 0 )
  else // Not bounded
    if( num_int == 2 )
double GeometryQueryTool::surface_angle ( RefFace ref_face_1,
RefFace ref_face_2,
RefEdge ref_edge = NULL,
RefVolume ref_volume = NULL,
double  frac = 0.5
Calculate dihedral angle at curve between two surfaces of the volume.
Definition at line 4659 of file GeometryQueryTool.cpp.
    // check for and supply missing ref edge if necessary
  if (ref_edge == NULL) {
    ref_edge = ref_face_1->common_ref_edge(ref_face_2);
    assert (ref_edge != NULL);
  if (ref_volume == NULL) {
    ref_volume = ref_face_1->common_ref_volume(ref_face_2);
    assert(ref_volume != NULL);
     //Find the dihedral angle for the ref_edge
   CubitVector mid_point;
   if ( frac != .5 )
     ref_edge->position_from_fraction(frac, mid_point);
   else
     mid_point = ref_edge->center_point();
     //Now find the normals of the surfaces at this point, wrt volume
   CubitVector surf_1_norm = ref_face_1->normal_at( mid_point, ref_volume );
   CubitVector surf_2_norm = ref_face_2->normal_at( mid_point, ref_volume );
     //Now we need to get the correct normal
   CubitVector tangent_vector;
     //This gets the correct tangent with respect for to the
     //ref_face_ptr.  Do the following check for non-manifold volumes.
     //This function will assert if the ref_edge has more than
     //one co_edge for the two_faces.  But this should be okay
     //since up above this function, that should be traped for...
    //Weed-out case where one edge is shared between more
    //than 2 surfaces of the same volume
    DLIList<RefFace*> tmp_faces;
    ref_edge->ref_faces( tmp_faces );
    if( tmp_faces.size() > 2 )
      int kk;
      for(kk=tmp_faces.size(); kk--;)
        if( !tmp_faces.get()->is_child( ref_volume ) )
          tmp_faces.change_to(NULL);
        tmp_faces.step();
      tmp_faces.remove_all_with_value( NULL );
        //this isn't the type of surface we are looking for...
        return 0.0;
   ref_edge->tangent( mid_point, tangent_vector, ref_face_1 );
   CubitSense face_1_sense = ref_face_1->sense( ref_volume );
   if( CUBIT_REVERSED != face_1_sense && CUBIT_FORWARD != face_1_sense )
      if(!(ref_volume->is_sheet()))
         return 0.0;
   if ( face_1_sense == CUBIT_REVERSED )
     tangent_vector = -tangent_vector;
   double angle = CUBIT_PI +
     tangent_vector.vector_angle(surf_2_norm, surf_1_norm );
     // note 1 and 2 switched.
     // tangent is cw, opposite of rhr
     // Range of above is pi/2 to 5pi/2, shift to 0 to 2pi.
   if ( angle >= 2.0* CUBIT_PI )
     angle -= 2.0 * CUBIT_PI;
     // if the angle is close to 0 or 2pi, use a center point check
     // to figure out if the interior angle is zero or 2pi
   const double min_tol = 0.1; // CUBIT_RESABS*100. too small
     // We could have a real overlap in some models, so keep
     // min_tol fairly big.
   const double max_tol = 2.0*CUBIT_PI - min_tol;
     // angle near zero - 2pi, make some checks at nearby locations
   if (angle <= min_tol || angle >= max_tol )
       // try to get the inside-outness where the surfaces have a gap
       // between them
       // get a non-shared edge with a shared vertex between the surfaces
     int i;
       // get the next edge in the loop
     DLIList<DLIList<RefEdge*> > loops_1;
     DLIList<RefEdge*> *loop_1 = NULL;
     ref_face_1->ref_edge_loops( loops_1 );
     for ( i = loops_1.size(); i--; )
       loop_1 = &loops_1.get_and_step();
       if ( loop_1->move_to( ref_edge ) )
         break;
     assert( loop_1->get() == ref_edge );
     DLIList<DLIList<RefEdge*> > loops_2;
     DLIList<RefEdge*> *loop_2 = NULL;
     ref_face_2->ref_edge_loops( loops_2 );
     for ( i = loops_2.size(); i--; )
       loop_2 = &loops_2.get_and_step();
       if ( loop_2->move_to( ref_edge ) )
         break;
     assert( loop_2->get() == ref_edge );
     RefEdge *common_edge = ref_edge, *next_edge,
       *uncommon_edge_1 = NULL, *uncommon_edge_2 = NULL;
     RefVertex *common_vertex = NULL;
     for ( i = loop_1->size(); !common_vertex && i--; )
       next_edge = loop_1->step_and_get();
       if ( loop_2->prev() == next_edge )
         loop_2->back();
         common_edge = next_edge;
       else if ( loop_2->next() == next_edge )
         loop_2->step();
       else
         uncommon_edge_1 = next_edge;
           // if both vertices are shared, it doesn't matter which we chose.
         common_vertex = common_edge->common_ref_vertex( uncommon_edge_1 );
         if ( loop_2->next()->is_parent( common_vertex ) )
           uncommon_edge_2 = loop_2->next();
         else
           assert( loop_2->prev()->is_parent( common_vertex ) );
           uncommon_edge_2 = loop_2->prev();
     int too_far;
     CubitVector center_1, center_2, center_norm_1, center_norm_2;
       // we've found non-common edges with a common vertex
     int bad_angle = CUBIT_TRUE;
     if ( common_vertex )
         // These two curves are only good geometrically if they
         // have a small angle between them: If the angle is too big,
         // then the closest pt will be the vertex, and we'll have to
         // start over with the surfaces or something.
         // reset midpoint and normals to common vertex...
       CubitVector vertex_coord = common_vertex->coordinates();
         // get a pair of close points on each surface
       center_1 = uncommon_edge_1->center_point();
       center_2 = uncommon_edge_2->center_point();
       double d_1 = (center_1 - vertex_coord).length_squared();
       double d_2 = (center_2 - vertex_coord).length_squared();
       int give_up = 0;
       i = 0;
       if ( d_1 <= d_2 )
         do
           center_2 = center_1;
           uncommon_edge_2->move_to_curve( center_2 );
           bad_angle =  d_2 < d_1 * 0.2;
           give_up = ( d_1 < GEOMETRY_RESABS*10 || i++ > 10 );
           if ( give_up )
             break;
           if ( bad_angle )
             center_1 += vertex_coord;
             center_1 /= 2.0;
             uncommon_edge_1->move_to_curve( center_1 );
         } while ( bad_angle );
       else
         do
           center_1 = center_2;
           bad_angle =  d_1 < d_2 * 0.2;
           give_up = ( d_2 < GEOMETRY_RESABS*10 || i++ > 10 );
           if ( give_up )
             break;
           if ( bad_angle )
             center_2 += vertex_coord;
             center_2 /= 2.0;
       if ( !bad_angle )
         mid_point = vertex_coord;
         double best_d_1 = CUBIT_DBL_MAX;
         CubitVector test_center_1 = center_1;
         CubitVector test_center_norm_1;
         // may be too far away - make sure normal is roughly the same
         //  as at the midpoint
         too_far = CUBIT_TRUE;
         for ( i = 12; i-- && too_far; )
           test_center_norm_1 =
             ref_face_1->normal_at( test_center_1, ref_volume );
           d_1 = test_center_norm_1 % surf_1_norm;
           if ( d_1 < best_d_1 )
             center_1 = test_center_1;
             center_norm_1 = test_center_norm_1;
           too_far =  d_1 < 0.2;
           if ( too_far && i )  // skip last time
             test_center_1 += mid_point;
             test_center_1 /= 2.0;
             uncommon_edge_1->move_to_curve( test_center_1 );
         double best_d_2 = CUBIT_DBL_MAX;
         CubitVector test_center_2 = center_2;
         CubitVector test_center_norm_2;
           //  as at the surface midpoint
           test_center_norm_2 =
             ref_face_2->normal_at( test_center_2, ref_volume );
           d_2 = test_center_norm_2 % surf_2_norm;
           if ( d_2 < best_d_2 )
             center_2 = test_center_2;
             center_norm_2 = test_center_norm_2;
           too_far =  d_2 < 0.2;
             test_center_2 += mid_point;
             test_center_2 /= 2.0;
             uncommon_edge_2->move_to_curve( test_center_2 );
       // surfaces share all edges! try the face center point
     if ( !common_vertex || bad_angle )
       center_1 = ref_face_1->center_point();
       center_2 = ref_face_2->center_point();
       double d_1 = (center_1 - mid_point).length_squared();
       double d_2 = (center_2 - mid_point).length_squared();
       if ( d_1 <= d_2 )
         ref_face_2->move_to_surface( center_2 );
       else
         ref_face_1->move_to_surface( center_1 );
         //  as at the curve midpoint
           ref_face_1->move_to_surface( test_center_1 );
         // surfaces share all edge! try the center point
           ref_face_2->move_to_surface( test_center_2 );
       // gap vector from center_1 to center_2
     CubitVector gap_vector = center_2;
     gap_vector -= center_1;
     double gap_d = gap_vector % center_norm_1;
     gap_d += -gap_vector % center_norm_2;
     if ( gap_d >= 0 )
       if ( angle < max_tol )
         angle =
