Mesh Oriented datABase
(version 5.4.1)
00001 #ifndef READ_TET_GEN_HPP 00002 #define READ_TET_GEN_HPP 00003 00004 #include <iosfwd> 00005 #include "moab/Forward.hpp" 00006 #include "moab/ReaderIface.hpp" 00007 #include <string> 00008 00009 namespace moab 00010 { 00011 00012 class ReadUtilIface; 00013 00014 /* TetGen mesh data is typically split into two or three files: 00015 * name.node : node data 00016 * name.ele : tet data 00017 * name.face : tri data 00018 * The reader will attempt to guess the correct file names from 00019 * the single input file name unless explicit file names are 00020 * specified using file options as described below. 00021 * 00022 * File options: 00023 * NODE_FILE=filename : node file name 00024 * ELE_FILE[=filename] : require tet file and optionally specify file name 00025 * FACE_FILE[=filename] : reequire tri file and optionally specify file name 00026 * EDGE_FILE[=filename] : reequire edge file and optionally specify file name 00027 * NODE_ATTR_LIST=name[,name[,...]] : List of tag names in which to store 00028 * attribute values. If the same name 00029 * is repeated multiple times, multiple 00030 * attribute values will be stored in the 00031 * same tag as array values in the order 00032 * they are read from the file. If a 00033 * name is zero-length, the attribute data 00034 * will be disgarded. 00035 */ 00036 class ReadTetGen : public ReaderIface 00037 { 00038 00039 public: 00040 static ReaderIface* factory( Interface* ); 00041 00042 //! load a file 00043 ErrorCode load_file( const char* file_name, 00044 const EntityHandle* file_set, 00045 const FileOptions& opts, 00046 const SubsetList* subset_list = 0, 00047 const Tag* file_id_tag = 0 ); 00048 00049 ErrorCode read_tag_values( const char* file_name, 00050 const char* tag_name, 00051 const FileOptions& opts, 00052 std::vector< int >& tag_values_out, 00053 const SubsetList* subset_list = 0 ); 00054 00055 //! Constructor 00056 ReadTetGen( Interface* impl = NULL ); 00057 00058 //! Destructor 00059 virtual ~ReadTetGen(); 00060 00061 private: 00062 Interface* mbIface; 00063 ReadUtilIface* readTool; 00064 00065 /**\brief Try to open one of several input files 00066 * 00067 *\param input_file_name The file name as passed in by the application 00068 *\param input_name_base If the input file name ends with a known suffix, 00069 * the portition of the input file without the suffix. 00070 * Otherwise equal to input_file_name. 00071 *\param input_file_suffix If the input file name ends with a known suffix, 00072 * the suffix. Otherwise empty. 00073 *\param file_type_suffix The suffix for the file type that is to be opened. 00074 *\param file_name_option The FileOptions option name specifying the file 00075 * name to open. 00076 *\param opts Input options list. 00077 *\param file_stream The stream to open for the file. 00078 */ 00079 ErrorCode open_file( const std::string& input_file_name, 00080 const std::string& input_name_base, 00081 const std::string& input_name_suffix, 00082 const char* file_type_suffix, 00083 const char* file_name_option, 00084 const FileOptions& opts, 00085 std::ifstream& file_stream, 00086 bool file_required = false ); 00087 00088 /**\brief Read a line from a file 00089 * 00090 * Read the next non-empty line. Strips comments. 00091 *\param file The stream to read from 00092 *\param line Output: the line read from the stream 00093 *\param lineno Incremented for each real line read from the stream 00094 * (including disgarded empty and comment lines.) 00095 */ 00096 ErrorCode read_line( std::istream& file, std::string& line, int& lineno ); 00097 00098 /**\brief Read a line of double values from a file. 00099 */ 00100 ErrorCode read_line( std::istream& file, double* values_out, int num_values, int& lineno ); 00101 00102 /**\brief Parse option string specifying mapping from 00103 * attributes to tags. 00104 * 00105 * Given a file option string describing the mapping from tetgen 00106 * attributes to MOAB tags, parse it and populate the passed vectors. 00107 * \param option_str Input: The option string to parse. 00108 * \param tag_list Output: A list tag handles, one for each attribute. 00109 * Tag handle value will be zero if the attribute 00110 * is to be interpreted as a group id. 00111 * \param index_list Output: Which array index to store the attribute 00112 * value at for a multi-valued tag. Zero for single- 00113 * valued tags. -1 if the corresponding attribute value 00114 * is to be interpreted as a group ID. 00115 * \param group_designator Input: special tag name used to designate an 00116 * attribute as the group (surface or volume) ID. 00117 */ 00118 ErrorCode parse_attr_list( const std::string& option_str, 00119 std::vector< Tag >& tag_list, 00120 std::vector< int >& index_list, 00121 const char* group_designator = 0 ); 00122 00123 ErrorCode read_node_file( std::istream& file, 00124 const Tag* attr_tag_list, 00125 const int* attr_tag_index, 00126 int attr_tag_list_len, 00127 std::vector< EntityHandle >& nodes ); 00128 00129 ErrorCode read_elem_file( EntityType type, 00130 std::istream& file, 00131 const std::vector< EntityHandle >& nodes, 00132 Range& elems ); 00133 }; 00134 00135 } // namespace moab 00136 00137 #endif // defined(READ_TET_GEN_HPP)
