WriteCGNS.cpp
00001 #include "WriteCGNS.hpp"
00002 #include "moab/CN.hpp"
00003 #include "MBTagConventions.hpp"
00004 #include "MBParallelConventions.h"
00005 #include "moab/Interface.hpp"
00006 #include "moab/Range.hpp"
00007 #include "moab/WriteUtilIface.hpp"
00008 #include "moab/FileOptions.hpp"
00009 #include "GmshUtil.hpp"
00010
00011 #include <fstream>
00012 #include <map>
00013 #include <set>
00014
00015 #include <iostream>
00016
00017 namespace moab
00018 {
00019
00020 WriterIface* WriteCGNS::factory( Interface* iface )
00021 {
00022     return new WriteCGNS( iface );
00023 }
00024
00025 WriteCGNS::WriteCGNS( Interface* impl )
00026     : mbImpl( impl ), fileName( NULL ), IndexFile( 0 ), BaseName( NULL ), IndexBase( 0 ), ZoneName( NULL ),
00027       IndexZone( 0 ), IndexSection( 0 ), celldim( 0 ), physdim( 0 ), VrtSize( 0 ), EdgeSize( 0 ), FaceSize( 0 ),
00028       CellSize( 0 )
00029 {
00030     impl->query_interface( mWriteIface );
00031     IndexCoord[0] = IndexCoord[1] = IndexCoord[2] = 0;
00032     isize[0] = isize[1] = isize[2] = 0;
00033 }
00034
00035 WriteCGNS::~WriteCGNS()
00036 {
00037     mbImpl->release_interface( mWriteIface );
00038 }
00039
00040 //! writes out a file
00041 ErrorCode WriteCGNS::write_file( const char* file_name,
00042                                  const bool overwrite,
00043                                  const FileOptions& /*options*/,
00044                                  const EntityHandle* /*output_list*/,
00045                                  const int /*num_sets*/,
00046                                  const std::vector< std::string >&,
00047                                  const Tag*,
00048                                  int,
00049                                  int )
00050 {
00051     ErrorCode rval;
00052
00053     if( !overwrite )
00054     {
00055         rval = mWriteIface->check_doesnt_exist( file_name );
00056         if( MB_SUCCESS != rval ) return rval;
00057     }
00058     std::cout << "THE CGNS CONVERSION ONLY WORKS FOR ENTITIES CITED BELOW:";
00059     std::cout << "\n   -MBVERTEX\n   -MBEDGE\n   -MBTRI\n   -MBQUAD";
00060     std::cout << "\n   -MBTET\n   -MBPYRAMID\n   -MBHEX\n";
00061
00062     // Get entities to write
00063     // Get and count vertex entities
00064     rval = get_vertex_entities( VrtSize, Nodes );
00065     if( rval != MB_SUCCESS )
00066     {
00067         return rval;
00068     }
00069     // Get and count edge entities
00070     rval = get_edge_entities( EdgeSize, Edges );
00071     if( rval != MB_SUCCESS )
00072     {
00073         return rval;
00074     }
00075     // Get and count face entities
00076     rval = get_face_entities( FaceSize, Faces );
00077     if( rval != MB_SUCCESS )
00078     {
00079         return rval;
00080     }
00081     // Get and count cell entities
00082     rval = get_cell_entities( CellSize, Cells );
00083     if( rval != MB_SUCCESS )
00084     {
00085         return rval;
00086     }
00087     std::cout << "\nThe Number of Vertex is " << VrtSize << ".\n";
00088     std::cout << "The Number of Edges is " << EdgeSize << ".\n";
00089     std::cout << "The Number of Faces is " << FaceSize << ".\n";
00090     std::cout << "The Number of Cells is " << CellSize << ".\n\n";
00091
00092     // save filename to member variable so we don't need to pass as an argument
00093     // to called functions
00094     fileName = file_name;
00095     std::cout << fileName << " file is a " << physdim << "-D mesh.\n";
00096
00097     // Open file
00098     IndexFile = 0;
00099
00100     // open the cgns file
00101     // filename:      (input) Name of the CGNS file, including path name if necessary. There is no
00102     // limit on the
00103     //                length of this character variable.
00104     // CG_MODE_WRITE: (input) Mode used for opening the file. The modes currently supported are
00105     // CG_MODE_READ,
00106     //                CG_MODE_WRITE, and CG_MODE_MODIFY.
00107     // filePtr:       (output) CGNS file index number.
00108     if( cg_open( fileName, CG_MODE_WRITE, &IndexFile ) )
00109     {
00110         std::cout << "Error opening file\n";
00111         cg_error_exit();
00112     }
00113     // Give a base name
00114     BaseName = "Cgns Base";
00115     if( cg_base_write( IndexFile, BaseName, celldim, physdim, &IndexBase ) )
00116     {
00117         std::cout << "Error creating CGNS base";
00118     }
00119     // Give a zone name
00120     ZoneName = "Cgns Zone";
00121     // isize array contains the total vertex size, cell size, and boundary
00122     // vertex size for the zone
00123     // Note that for unstructured zones, the index dimension is always 1
00124     isize[0] = VrtSize;   // isize[0] contains the total vertex size
00125     isize[1] = CellSize;  // isize[1] contains the total cell size
00126     isize[2] = 0;         // isize[2] = 0 for unsorted elements
00127     // Create zone */
00128     // ZoneType_t: Unstructured
00129     if( cg_zone_write( IndexFile, IndexBase, ZoneName, isize, Unstructured, &IndexZone ) )
00130     {
00131         std::cout << "Error creating CGNS zone\n";
00132         cg_error_exit();
00133     }
00134     // Write the vertex coordinates
00135     rval = write_coord_cgns( Nodes );
00136     if( rval != MB_SUCCESS )
00137     {
00138         return rval;
00139     }
00140
00141     // Create a vector to hold the Tags
00142     std::vector< moab::Tag > TagHandles;
00143     // Get Tags
00144     rval = mbImpl->tag_get_tags( TagHandles );
00145     if( rval != MB_SUCCESS )
00146     {
00147         return rval;
00148     }
00149     // Get the number of Tags in the mesh
00150     int NbTags = TagHandles.size();
00151     std::cout << "\nThe mesh has " << NbTags << " Tags.\n";
00152
00153     // Create a vector of size NbTags
00154     // Sets have informations about the entity set
00155     std::vector< SetStruct > Sets;
00156     Sets.reserve( NbTags );
00157     // Fill Sets with all information needed
00158     rval = set_tag_values( TagHandles, Edges, Faces, Cells, Sets );
00159     if( rval != MB_SUCCESS )
00160     {
00161         std::cout << "Problem to set tag values\n";
00162         return rval;
00163     }
00164
00165     // Create a matrix to hold connectivity
00166     std::vector< std::vector< cgsize_t > > ConnTable;
00167     ConnTable.resize( NbTags );
00168
00169     std::vector< int > Begin( NbTags, 0 );
00170     std::vector< int > End( NbTags, 0 );
00171
00172     // Take the connectivity of higher dimension entities
00173     cgsize_t BeginSetsIndex = 1;
00174     cgsize_t EndSetsIndex;
00175     switch( physdim )
00176     {
00177         case 1:
00178             rval = get_conn_table( Edges, Begin, End, TagHandles, Sets, ConnTable );
00179             if( rval != MB_SUCCESS )
00180             {
00181                 std::cout << "Problem to fill the connectivity table for 1-D entities\n";
00182                 return rval;
00183             }
00184             for( int i = 0; i < NbTags; ++i )
00185             {
00186                 if( Sets[i].IdSet != -1 )
00187                 {
00188                     const char* SectionName = Sets[i].TagName.c_str();
00189                     EndSetsIndex            = BeginSetsIndex + Sets[i].NbEdges - 1;
00190                     // Write the section in CGNS file
00191                     if( cg_section_write( IndexFile, IndexBase, IndexBase, SectionName, Sets[i].CGNSType,
00192                                           BeginSetsIndex, EndSetsIndex, 0, &ConnTable[i][0], &IndexSection ) )
00193                     {
00194                         std::cout << "Issue on writing connectivity - 3-D\n";
00195                         cg_error_exit();
00196                     }
00197                     BeginSetsIndex = EndSetsIndex + 1;
00198                 }
00199             }
00200             break;
00201         case 2:
00202             rval = get_conn_table( Edges, Begin, End, TagHandles, Sets, ConnTable );
00203             if( rval != MB_SUCCESS )
00204             {
00205                 std::cout << "Problem to fill the connectivity table for 1-D entities\n";
00206                 return rval;
00207             }
00208             rval = get_conn_table( Faces, Begin, End, TagHandles, Sets, ConnTable );
00209             if( rval != MB_SUCCESS )
00210             {
00211                 std::cout << "Problem to fill the connectivity table for 2-D entities\n";
00212                 return rval;
00213             }
00214             for( int i = 0; i < NbTags; ++i )
00215             {
00216                 if( Sets[i].IdSet != -1 )
00217                 {
00218                     const char* SectionName = Sets[i].TagName.c_str();
00219                     EndSetsIndex            = BeginSetsIndex + Sets[i].NbEdges + Sets[i].NbFaces - 1;
00220                     // Write the section in CGNS file
00221                     if( cg_section_write( IndexFile, IndexBase, IndexBase, SectionName, Sets[i].CGNSType,
00222                                           BeginSetsIndex, EndSetsIndex, 0, &ConnTable[i][0], &IndexSection ) )
00223                     {
00224                         std::cout << "Issue on writing connectivity -- 2-D\n";
00225                         cg_error_exit();
00226                     }
00227                     BeginSetsIndex = EndSetsIndex + 1;
00228                 }
00229             }
00230             break;
00231         case 3:
00232             rval = get_conn_table( Faces, Begin, End, TagHandles, Sets, ConnTable );
00233             if( rval != MB_SUCCESS )
00234             {
00235                 std::cout << "Problem to fill the connectivity table for 2-D entities\n";
00236                 return rval;
00237             }
00238             rval = get_conn_table( Cells, Begin, End, TagHandles, Sets, ConnTable );
00239             if( rval != MB_SUCCESS )
00240             {
00241                 std::cout << "Problem to fill the connectivity table for 3-D entities\n";
00242                 return rval;
00243             }
00244             for( int i = 0; i < NbTags; ++i )
00245             {
00246                 if( Sets[i].IdSet != -1 )
00247                 {
00248                     const char* SectionName = Sets[i].TagName.c_str();
00249                     EndSetsIndex            = BeginSetsIndex + Sets[i].NbFaces + Sets[i].NbCells - 1;
00250                     std::cout << "BeginSetsIndex = " << BeginSetsIndex << "\tEndSetsIndex = " << EndSetsIndex << "\n";
00251                     // Write the section in CGNS file
00252                     if( cg_section_write( IndexFile, IndexBase, IndexBase, SectionName, Sets[i].CGNSType,
00253                                           BeginSetsIndex, EndSetsIndex, 0, &ConnTable[i][0], &IndexSection ) )
00254                     {
00255                         std::cout << "Issue on writing connectivity -- 3-D\n";
00256                         cg_error_exit();
00257                     }
00258                     BeginSetsIndex = EndSetsIndex + 1;
00259                 }
00260             }
00261             break;
00262         default:
00263             std::cout << "Issue on Physical dimension\n";
00264             return MB_FAILURE;
00265     }
00266
00267     // Close the CGNS mesh file
00268     if( cg_close( IndexFile ) )
00269     {
00270         std::cout << "Error closing file\n";
00271         cg_error_exit();
00272     }
00273     // done
00274     return MB_SUCCESS;
00275 }
00276
00277 // Get and count vertex entities
00278 ErrorCode WriteCGNS::get_vertex_entities( cgsize_t& VrtSize_, std::vector< moab::EntityHandle >& Nodes_ )
00279 {
00280     ErrorCode rval;
00281     // Get vertex entities
00282     // The first input is 0 because one queries the entire mesh.
00283     // Retrieves all entities of dimension = 0 in "Nodes"
00284     rval = mbImpl->get_entities_by_dimension( 0, 0, Nodes_, false );
00285     if( Nodes.size() > 0 )
00286     {
00287         celldim = 0;
00288         physdim = 0;
00289         // get the amout of vertex
00290         VrtSize_ = Nodes_.size();
00291     }
00292     else
00293     {
00294         std::cout << "The mesh has not node points.\n";
00295     }
00296     // done
00297     return rval;
00298 }
00299
00300 // Get and count edge entities
00301 ErrorCode WriteCGNS::get_edge_entities( cgsize_t& EdgeSize_, std::vector< moab::EntityHandle >& Edges_ )
00302 {
00303     ErrorCode rval;
00304     // The first input is 0 because one queries the entire mesh.
00305     // Get all entities of dimension = 1 in Edges
00306     rval = mbImpl->get_entities_by_dimension( 0, 1, Edges_, false );
00307     if( Edges_.size() > 0 )
00308     {
00309         celldim = 1;
00310         physdim = 1;
00311         // get the amout of edges
00312         EdgeSize_ = Edges_.size();
00313     }
00314     // done
00315     return rval;
00316 }
00317
00318 // Get and count face entities
00319 ErrorCode WriteCGNS::get_face_entities( cgsize_t& FaceSize_, std::vector< moab::EntityHandle >& Faces_ )
00320 {
00321     ErrorCode rval;
00322     // The first input is 0 because one queries the entire mesh.
00323     // Get all entities of dimension = 2 in Faces
00324     rval = mbImpl->get_entities_by_dimension( 0, 2, Faces_, false );
00325     if( Faces_.size() )
00326     {
00327         celldim = 2;
00328         physdim = 2;
00329         // get the amout of faces
00330         FaceSize_ = Faces_.size();
00331     }
00332     // done
00333     return rval;
00334 }
00335
00336 // Get and count cell entities
00337 ErrorCode WriteCGNS::get_cell_entities( cgsize_t& CellSize_, std::vector< moab::EntityHandle >& Cells_ )
00338 {
00339     ErrorCode rval;
00340     // The first input is 0 because one queries the entire mesh.
00341     // Get all entities of dimension = 3 in Cell
00342     rval = mbImpl->get_entities_by_dimension( 0, 3, Cells_, false );
00343     if( Cells_.size() )
00344     {
00345         celldim = 3;
00346         physdim = 3;
00347         // get the amout of volumes
00348         CellSize_ = Cells_.size();
00349     }
00350     // done
00351     return rval;
00352 }
00353
00354 ErrorCode WriteCGNS::write_coord_cgns( std::vector< moab::EntityHandle >& Nodes_ )
00355 {
00356     ErrorCode rval;
00357
00358     const int num_entities = (int)Nodes_.size();
00359
00360     // Moab works with one vector for the threee coordinates
00361     std::vector< double > Coords( 3 * num_entities );
00362     std::vector< double >::iterator c = Coords.begin();
00363
00364     // CGNS uses one vector for each coordinate
00365     std::vector< double > CoordX;
00366     std::vector< double > CoordY;
00367     std::vector< double > CoordZ;
00368
00369     // Summ the values of all coordinates to be sure if it is not zero
00370     double SumX = 0;
00371     double SumY = 0;
00372     double SumZ = 0;
00373
00374     // Get the moab coordinates - Coords is the output
00375     rval = mbImpl->get_coords( &Nodes_[0], num_entities, &Coords[0] );
00376     if( MB_SUCCESS != rval )
00377     {
00378         std::cout << "Error getting coordinates from nodes.\n";
00379         return rval;
00380     }
00381
00382     // Reserve the size of nodes
00383     CoordX.reserve( Nodes_.size() );
00384     CoordY.reserve( Nodes_.size() );
00385     CoordZ.reserve( Nodes_.size() );
00386
00387     for( std::vector< moab::EntityHandle >::iterator i = Nodes_.begin(); i != Nodes_.end(); ++i )
00388     {
00389         CoordX.push_back( *c );  // Put the X coordinate in CoordX vector
00390         SumX += abs( *c );       // Sum all X coordinates
00391         ++c;                     // Move to Y coordinate
00392         CoordY.push_back( *c );  // Put the Y coordinate in CoordY vector
00393         SumY += abs( *c );       // Sum all Y coordinates
00394         ++c;                     // Move to Z coordinate
00395         CoordZ.push_back( *c );  // Put the Z coordinate in CoordZ vector
00396         SumZ += abs( *c );       // Sum all Z coordinates
00397         ++c;                     // Move to X coordinate
00398     }
00399
00400     // If X coordinate is not empty then write CoordX (user must use SIDS-standard names here)
00401     if( SumX != 0 )
00402     {
00403         if( cg_coord_write( IndexFile, IndexBase, IndexZone, RealDouble, "CoordinateX", &CoordX[0], &IndexCoord[0] ) )
00404         {
00405             std::cout << " Error writing X coordinates.\n";
00406             cg_error_exit();
00407         }
00408     }
00409     // If Y coordinate is not empty then write CoordY (user must use SIDS-standard names here)
00410     if( SumY != 0 )
00411     {
00412         if( cg_coord_write( IndexFile, IndexBase, IndexZone, RealDouble, "CoordinateY", &CoordY[0], &IndexCoord[1] ) )
00413         {
00414             std::cout << " Error writing Y coordinates.\n";
00415             cg_error_exit();
00416         }
00417     }
00418     // If Z coordinate is not empty then write CoordZ (user must use SIDS-standard names here)
00419     if( SumZ != 0 )
00420     {
00421         if( cg_coord_write( IndexFile, IndexBase, IndexZone, RealDouble, "CoordinateZ", &CoordZ[0], &IndexCoord[2] ) )
00422         {
00423             std::cout << " Error writing Z coordinates.\n";
00424             cg_error_exit();
00425         }
00426     }
00427
00428     // Clear vectors
00429     Coords.clear();
00430     CoordX.clear();
00431     CoordY.clear();
00432     CoordZ.clear();
00433
00434     // done
00435     return MB_SUCCESS;
00436 }
00437
00438 ErrorCode WriteCGNS::set_tag_values( std::vector< Tag >& TagHandles,
00439                                      std::vector< moab::EntityHandle >& Edges_,
00440                                      std::vector< moab::EntityHandle >& Faces_,
00441                                      std::vector< moab::EntityHandle >& Cells_,
00442                                      std::vector< WriteCGNS::SetStruct >& Sets )
00443 {
00444     ErrorCode rval;
00445
00446     // Get the number of Tags in the mesh
00447     int NbTags = TagHandles.size();
00448
00449     // Loop over all Tags
00450     for( int i = 0; i < NbTags; ++i )
00451     {
00452
00453         // Allocate another position in the vector of SetStruct using a default constructor
00454         Sets.push_back( SetStruct() );
00455
00456         // Get the Tag name
00457         rval = mbImpl->tag_get_name( TagHandles[i], Sets[i].TagName );
00458         if( rval != MB_SUCCESS )
00459         {
00460             std::cout << "Problem to get Tag Name\n";
00461             return rval;
00462         }
00463         std::cout << "Tag name= " << Sets[i].TagName << "\n";
00464
00465         // Count all entities by type and put in Sets[i].NbEntities vector
00466         rval = get_set_entities( i, TagHandles, Sets );
00467         if( rval != MB_SUCCESS )
00468         {
00469             std::cout << "Problem to get Set entities\n";
00470             return rval;
00471         }
00472
00473         // Get the CGNSTYpe of the Set
00474         rval = get_cgns_type( i, Sets );
00475         if( rval != MB_SUCCESS )
00476         {
00477             std::cout << "Problem to get CGNSType\n";
00478             return rval;
00479         }
00480         std::cout << "\tSets[" << i << "].CGNSType= " << Sets[i].CGNSType << "\n";
00481
00482         // int Number;
00483
00484         // Set a data index for Edges and TagHandles[i]
00485         if( Sets[i].CGNSType == BAR_2 || Sets[i].CGNSType == TRI_3 || Sets[i].CGNSType == QUAD_4 ||
00486             Sets[i].CGNSType == TETRA_4 || Sets[i].CGNSType == PYRA_5 || Sets[i].CGNSType == PENTA_6 ||
00487             Sets[i].CGNSType == HEXA_8 || Sets[i].CGNSType == MIXED )
00488         {
00489
00490             if( Sets[i].NbEdges > 0 && physdim < 3 )
00491             {
00492                 // Set a data index for Edges and TagHandles[i]
00493                 const std::vector< int > tag_values( Edges_.size(), i );
00494                 rval = mbImpl->tag_set_data( TagHandles[i], &Edges_[0], Edges_.size(), &tag_values[0] );
00495                 if( rval != MB_SUCCESS )
00496                 {
00497                     std::cout << "Problem to set data for 1-D entities\n";
00498                     return rval;
00499                 }
00500             }
00501             if( Sets[i].NbFaces > 0 && physdim > 1 )
00502             {
00503                 // Set a data index for Faces and TagHandles[i]
00504                 const std::vector< int > tag_values( Faces.size(), i );
00505                 rval = mbImpl->tag_set_data( TagHandles[i], &Faces_[0], Faces_.size(), &tag_values[0] );
00506                 if( rval != MB_SUCCESS )
00507                 {
00508                     std::cout << "Problem to set data for 2-D entities\n";
00509                     return rval;
00510                 }
00511             }
00512             if( Sets[i].NbCells > 0 && physdim > 2 )
00513             {
00514                 // Set a data index for Cells and TagHandles[i]
00515                 const std::vector< int > tag_values( Cells.size(), i );
00516                 rval = mbImpl->tag_set_data( TagHandles[i], &Cells_[0], Cells_.size(), &tag_values[0] );
00517                 if( rval != MB_SUCCESS )
00518                 {
00519                     std::cout << "Problem to set data for 3-D entities\n";
00520                     return rval;
00521                 }
00522             }
00523             // IdSet gets the Set Index indicating that it is not empty
00524             Sets[i].IdSet = i;
00525         }
00526         std::cout << "\tSets[" << i << "].IdSet = " << Sets[i].IdSet << "\n\n";
00527     }
00528     return MB_SUCCESS;
00529 }
00530
00531 // Get Entities in the set
00532 ErrorCode WriteCGNS::get_set_entities( int i,
00533                                        std::vector< Tag >& TagHandles,
00534                                        std::vector< WriteCGNS::SetStruct >& Sets )
00535 {
00536     ErrorCode rval;
00537
00538     // Get the number of MBEDGE entities
00539     // NbEntities[0] holds the number of MBEDGE in the "Sets"
00540     int Number = 0;
00541     rval       = mbImpl->get_number_entities_by_type_and_tag( 0, MBEDGE, &TagHandles[i], 0, 1, Number );
00542     if( rval != MB_SUCCESS )
00543     {
00544         std::cout << "Problem to get the number of entities by type and tag\n";
00545         return rval;
00546     }
00547     Sets[i].NbEntities.push_back( Number );  // MBEDGE == Sets[i].NbEntities[0]
00548     Sets[i].NbEdges += Number;
00549     std::cout << "\tNumber of MBEDGE = " << Number << "\n";
00550
00551     // Get the number of MBTRI entities
00552     // NbEntities[1] holds the number of MBTRI in the "Sets"
00553     Number = 0;
00554     rval   = mbImpl->get_number_entities_by_type_and_tag( 0, MBTRI, &TagHandles[i], 0, 1, Number );
00555     if( rval != MB_SUCCESS )
00556     {
00557         std::cout << "Problem to get the number of entities by type and tag\n";
00558         return rval;
00559     }
00560     Sets[i].NbEntities.push_back( Number );  // MBTRI == Sets[i].NbEntities[1]
00561     Sets[i].NbFaces += Number;
00562     std::cout << "\tNumber of MBTRI = " << Number << "\n";
00563
00564     // Get the number of MBQUAD entities
00565     // NbEntities[2] holds the number of MBQUAD in the "Sets"
00566     Number = 0;
00567     rval   = mbImpl->get_number_entities_by_type_and_tag( 0, MBQUAD, &TagHandles[i], 0, 1, Number );
00568     if( rval != MB_SUCCESS )
00569     {
00570         std::cout << "Problem to get the number of entities by type and tag\n";
00571         return rval;
00572     }
00573     Sets[i].NbEntities.push_back( Number );  // MBQUAD == Sets[i].NbEntities[2]
00574     Sets[i].NbFaces += Number;
00575     std::cout << "\tNumber of MBQUAD = " << Number << "\n";
00576
00577     // Get the number of MBTET entities
00578     // NbEntities[3] holds the number of MBTET in the "Sets"
00579     Number = 0;
00580     rval   = mbImpl->get_number_entities_by_type_and_tag( 0, MBTET, &TagHandles[i], 0, 1, Number );
00581     if( rval != MB_SUCCESS )
00582     {
00583         std::cout << "Problem to get the number of entities by type and tag\n";
00584         return rval;
00585     }
00586     Sets[i].NbEntities.push_back( Number );  // MBTET == Sets[i].NbEntities[3]
00587     Sets[i].NbCells += Number;
00588     std::cout << "\tNumber of MBTET = " << Number << "\n";
00589
00590     // Get the number of MBPYRAMID entities
00591     // NbEntities[4] holds the number of MBPYRAMID in the "Sets"
00592     Number = 0;
00593     rval   = mbImpl->get_number_entities_by_type_and_tag( 0, MBPYRAMID, &TagHandles[i], 0, 1, Number );
00594     if( rval != MB_SUCCESS )
00595     {
00596         std::cout << "Problem to get the number of entities by type and tag\n";
00597         return rval;
00598     }
00599     Sets[i].NbEntities.push_back( Number );  // MBPYRAMID == Sets[i].NbEntities[4]
00600     Sets[i].NbCells += Number;
00601     std::cout << "\tNumber of MBPYRAMID = " << Number << "\n";
00602
00603     // Get the number of MBPRISM entities - MBPRISM == PENTA_6
00604     // NbEntities[5] holds the number of MBPRISM in the "Sets"
00605     Number = 0;
00606     rval   = mbImpl->get_number_entities_by_type_and_tag( 0, MBPRISM, &TagHandles[i], 0, 1, Number );
00607     if( rval != MB_SUCCESS )
00608     {
00609         std::cout << "Problem to get the number of entities by type and tag\n";
00610         return rval;
00611     }
00612     Sets[i].NbEntities.push_back( Number );  // MBPRISM == Sets[i].NbEntities[5]
00613     Sets[i].NbCells += Number;
00614     std::cout << "\tNumber of MBPRISM = " << Number << "\n";
00615
00616     // Get the number of MBHEX entities
00617     // NbEntities[6] holds the number of MBHEX in the "Sets"
00618     Number = 0;
00619     rval   = mbImpl->get_number_entities_by_type_and_tag( 0, MBHEX, &TagHandles[i], 0, 1, Number );
00620     if( rval != MB_SUCCESS )
00621     {
00622         std::cout << "Problem to get the number of entities by type and tag\n";
00623         return rval;
00624     }
00625     Sets[i].NbEntities.push_back( Number );  // MBHEX == Sets[i].NbEntities[6]
00626     Sets[i].NbCells += Number;
00627     std::cout << "\tNumber of MBHEX = " << Number << "\n";
00628
00629     std::cout << "\tTotal number of Edges = " << Sets[i].NbEdges << "\n";
00630     std::cout << "\tTotal number of Faces = " << Sets[i].NbFaces << "\n";
00631     std::cout << "\tTotal number of Cells = " << Sets[i].NbCells << "\n";
00632
00633     return MB_SUCCESS;
00634 }
00635
00636 // Get CGNSType
00637 ErrorCode WriteCGNS::get_cgns_type( int i, std::vector< WriteCGNS::SetStruct >& Sets )
00638 {
00639     std::vector< int > Test;
00640     int Sum = 0;
00641
00642     // NbEntities is a vector which has the number of entities of each type
00643     // 0-MBEDGE | 1-MBTRI | 2-MBQUAD | 3-MBTET | 4-MBPYRAMID | 5-MBPRISM | 6-MBHEX
00644     // if NbEntities[i]>0 then Test[i]=1
00645     // else then Test[i]=0
00646     for( int j = 0; j < (int)Sets[i].NbEntities.size(); ++j )
00647     {
00648         if( Sets[i].NbEntities[j] > 0 )
00649         {
00650             Test.push_back( 1 );
00651             Sum++;
00652         }
00653         else
00654         {
00655             Test.push_back( 0 );
00656         }
00657     }
00658
00659     // Test the Sum
00660     // if Sum > 1 then the Set is MIXED
00661     // if Sum = 0 then the Set is Homogeneous
00662     // else then the Set is empty
00663     if( Sum > 1 )
00664     {
00665         Sets[i].CGNSType = MIXED;
00666     }
00667     else if( Sum == 1 )
00668     {
00669         int j = 0;
00670         std::cout << "Homogeneous Type\n";
00671         while( j < (int)Sets[i].NbEntities.size() && Sets[i].NbEntities[j] != 1 )
00672         {
00673             ++j;
00674         }
00675         switch( j )
00676         {
00677             case 0:
00678                 Sets[i].CGNSType = BAR_2;
00679                 break;
00680             case 1:
00681                 Sets[i].CGNSType = TRI_3;
00682                 break;
00683             case 2:
00684                 Sets[i].CGNSType = QUAD_4;
00685                 break;
00686             case 3:
00687                 Sets[i].CGNSType = TETRA_4;
00688                 break;
00689             case 4:
00690                 Sets[i].CGNSType = PYRA_5;
00691                 break;
00692             case 5:
00693                 Sets[i].CGNSType = PENTA_6;
00694                 break;
00695             case 6:
00696                 Sets[i].CGNSType = HEXA_8;
00697                 break;
00698             default:
00699                 std::cout << "It was not possible to identify the CGNSType\n";
00700                 return MB_FAILURE;
00701         }
00702     }
00703     else
00704     {
00705         Sets[i].CGNSType = ElementTypeNull;
00706     }  // NOT SURE IF THAT'S THE RIGHT WAY.......
00707
00708     // Clear the test vector
00709     Test.clear();
00710
00711     return MB_SUCCESS;
00712 }
00713
00714 // Fill the connectivity table
00715 ErrorCode WriteCGNS::get_conn_table( std::vector< moab::EntityHandle >& Elements,
00716                                      std::vector< int >& Begin,
00717                                      std::vector< int >& End,
00718                                      std::vector< moab::Tag >& TagHandles,
00719                                      std::vector< WriteCGNS::SetStruct >& Sets,
00720                                      std::vector< std::vector< cgsize_t > >& ConnTable )
00721 {
00722     ErrorCode rval;
00723
00724     //   int Begin = 0; // GOT TO WORK ON THIS
00725     //   int End;
00726
00727     // Get the number of Tags in the mesh
00728     int NbTags = TagHandles.size();
00729
00730     // Test all Elements, get their ids and connectivity
00731     // to fill ConnTable
00732     for( std::vector< moab::EntityHandle >::iterator i = Elements.begin(); i != Elements.end(); ++i )
00733     {
00734         int id;
00735         // Test all Tags
00736         for( int j = 0; j < NbTags; ++j )
00737         {
00738             // Test if the Tag has data
00739             if( Sets[j].IdSet != -1 )
00740             {
00741                 // Try to get data from entity
00742                 rval = mbImpl->tag_get_data( TagHandles[j], &*i, 1, &id );
00743                 if( MB_SUCCESS != rval )
00744                 {
00745                     return rval;
00746                 }
00747                 // If successful id==j
00748                 if( id == j )
00749                 {
00750                     // Get the entity type of the EntityHandle wich points to Cells
00751                     int num_vtx;               // Number of MeshVertices in array connectivity.
00752                     const EntityHandle* conn;  // Array in which connectivity of entity_handle is returned.
00753                     // Gets a pointer to constant connectivity data of entity_handle
00754                     rval = mbImpl->get_connectivity( *i, conn, num_vtx );
00755                     if( MB_SUCCESS != rval )
00756                     {
00757                         return rval;
00758                     }
00759                     // If the Set is MIXED type
00760                     // push CGNS ENUM type of the entity
00761                     // before the connectivity
00762                     if( Sets[j].CGNSType == MIXED )
00763                     {
00764                         ConnTable[j].push_back( moab_cgns_conv( *i ) );  // moab_cgns_conv return an int which
00765        // represents the CGNS type
00766                         Begin[j]++;
00767                     }
00768                     End[j] = Begin[j] + num_vtx;
00769                     // Push conn in ConnTable in which "j" is the Set Index
00770                     for( int k = Begin[j]; k < End[j]; ++k )
00771                     {
00772                         ConnTable[j].push_back( (cgsize_t)conn[k - Begin[j]] );
00773                     }
00774                     Begin[j] = End[j];
00775                 }
00776             }
00777         }
00778     }
00779     return MB_SUCCESS;
00780 }
00781
00782 // Read the Moab type and return CGNS type
00783 int WriteCGNS::moab_cgns_conv( const EntityHandle handle )
00784 {
00785     EntityType MoabType = mbImpl->type_from_handle( handle );
00786     switch( MoabType )
00787     {
00788         case MBEDGE: /**< Mesh Edge */
00789             return BAR_2;
00790         case MBTRI: /**< Triangular element (including shells) */
00791             return TRI_3;
00792         case MBQUAD: /**< Quadrilateral element (including shells) */
00793             return QUAD_4;
00794         case MBTET: /**< Tetrahedral element */
00795             return TETRA_4;
00796         case MBPYRAMID: /**< Pyramid element */
00797             return PYRA_5;
00798         case MBPRISM: /**< Wedge element */
00799             return PENTA_6;
00800         case MBHEX: /**< Hexahedral element */
00801             return HEXA_8;
00802         default:
00803             std::cout << "It was not possible to identify the CGNSType\n";
00804             return 0;
00805     }
00806 }
00807
00808 }  // namespace moab
