moab::Element::LinearTet Class Reference
Shape function space for a linear tetrahedron, obtained by a pushforward of the canonical affine shape functions. More...
#include <ElemUtil.hpp>
+ Inheritance diagram for moab::Element::LinearTet:
+ Collaboration diagram for moab::Element::LinearTet:
Public Member Functions
 LinearTet (const std::vector< CartVect > &vertices)
 LinearTet ()
virtual ~LinearTet ()
virtual CartVect evaluate (const CartVect &xi) const
 Evaluate the map on \(x_i\) (calculate \(\vec x = F($\vec \xi)\) )
virtual CartVect ievaluate (const CartVect &x, double tol=1e-6, const CartVect &x0=CartVect(0.0)) const
 Evaluate the inverse map (calculate \(\vec \xi = F^-1($\vec x)\) to given tolerance)
virtual Matrix3 jacobian (const CartVect &) const
 Evaluate the map's Jacobi matrix.
virtual Matrix3 ijacobian (const CartVect &) const
 Evaluate the inverse of the Jacobi matrix.
virtual double det_jacobian (const CartVect &) const
 Evaluate the determinate of the Jacobi matrix.
virtual double det_ijacobian (const CartVect &) const
 Evaluate the determinate of the inverse Jacobi matrix.
virtual double evaluate_scalar_field (const CartVect &xi, const double *field_vertex_values) const
 Evaluate a scalar field at a point given field values at the vertices.
virtual double integrate_scalar_field (const double *field_vertex_values) const
 Integrate a scalar field over the element given field values at the vertices.
virtual void set_vertices (const std::vector< CartVect > &v)
 Set vertices.
virtual bool inside_nat_space (const CartVect &xi, double &tol) const
 decide if within the natural param space, with a tolerance
Protected Attributes
Matrix3 T
Matrix3 T_inverse
double det_T
double det_T_inverse
Static Protected Attributes
static const double corner [4][3] = { { 0, 0, 0 }, { 1, 0, 0 }, { 0, 1, 0 }, { 0, 0, 1 } }
Detailed Description
Definition at line 197 of file ElemUtil.hpp.
moab::Element::LinearTet::LinearTet ( const std::vector< CartVect > &  vertices) [inline]
Definition at line 200 of file ElemUtil.hpp.
References set_vertices().
                                                           : Map( vertices )
            set_vertices( vertex );
Definition at line 892 of file ElemUtil.cpp.
: Map( 0 ), det_T( 0.0 ), det_T_inverse( 0.0 ) {}  // LinearTet::LinearTet()
Definition at line 894 of file ElemUtil.cpp.
Member Function Documentation
virtual double moab::Element::LinearTet::det_ijacobian ( const CartVect xi) const [inline, virtual]
Reimplemented from moab::Element::Map.
Definition at line 224 of file ElemUtil.hpp.
References det_T_inverse.
            return this->det_T_inverse;
virtual double moab::Element::LinearTet::det_jacobian ( const CartVect xi) const [inline, virtual]
Definition at line 220 of file ElemUtil.hpp.
References det_T.
            return this->det_T;
virtual CartVect moab::Element::LinearTet::evaluate ( const CartVect xi) const [inline, virtual]
Implements moab::Element::Map.
Definition at line 207 of file ElemUtil.hpp.
References T.
            return this->vertex[0] + this->T * xi;
double moab::Element::LinearTet::evaluate_scalar_field ( const CartVect xi,
const double *  field_vertex_values
) const [virtual]
Definition at line 907 of file ElemUtil.cpp.
        double f0 = field_vertex_value[0];
        double f  = f0;
        for( unsigned i = 1; i < 4; ++i )
            f += ( field_vertex_value[i] - f0 ) * xi[i - 1];
        return f;
    }  // LinearTet::evaluate_scalar_field()
CartVect moab::Element::LinearTet::ievaluate ( const CartVect x,
double  tol = 1e-6,
const CartVect x0 = CartVect( 0.0 )
) const [virtual]
Definition at line 918 of file ElemUtil.cpp.
References T_inverse.
Referenced by moab::Coupler::nat_param().
        return this->T_inverse * ( x - this->vertex[0] );
    }  // LinearTet::ievaluate
virtual Matrix3 moab::Element::LinearTet::ijacobian ( const CartVect xi) const [inline, virtual]
Definition at line 216 of file ElemUtil.hpp.
            return this->T_inverse;
bool moab::Element::LinearTet::inside_nat_space ( const CartVect xi,
double &  tol
) const [virtual]
Definition at line 933 of file ElemUtil.cpp.
        // linear tet space is a tetra with vertices (0,0,0), (1,0,0), (0,1,0), (0, 0, 1)
        // first check if outside bigger box, then below the plane x+y+z=1
        return ( xi[0] >= -tol ) && ( xi[1] >= -tol ) && ( xi[2] >= -tol ) && ( xi[0] + xi[1] + xi[2] < 1.0 + tol );
double moab::Element::LinearTet::integrate_scalar_field ( const double *  field_vertex_values) const [virtual]
Definition at line 923 of file ElemUtil.cpp.
References det_T.
        double I( 0.0 );
        for( unsigned int i = 0; i < 4; ++i )
            I += field_vertex_values[i];
        I *= this->det_T / 24.0;
        return I;
    }  // LinearTet::integrate_scalar_field()
virtual Matrix3 moab::Element::LinearTet::jacobian ( const CartVect xi) const [inline, virtual]
Definition at line 212 of file ElemUtil.hpp.
References T.
            return this->T;
void moab::Element::LinearTet::set_vertices ( const std::vector< CartVect > &  v) [virtual]
Set vertices.
Definition at line 896 of file ElemUtil.cpp.
References det_T, det_T_inverse, moab::Matrix3::determinant(), moab::Matrix3::inverse(), T, and T_inverse.
Referenced by LinearTet().
        this->Map::set_vertices( v );
        this->T =
            Matrix3( v[1][0] - v[0][0], v[2][0] - v[0][0], v[3][0] - v[0][0], v[1][1] - v[0][1], v[2][1] - v[0][1],
                     v[3][1] - v[0][1], v[1][2] - v[0][2], v[2][2] - v[0][2], v[3][2] - v[0][2] );
        this->T_inverse     = this->T.inverse();
        this->det_T         = this->T.determinant();
        this->det_T_inverse = ( this->det_T < 1e-12 ? std::numeric_limits< double >::max() : 1.0 / this->det_T );
    }  // LinearTet::set_vertices()
Member Data Documentation
const double moab::Element::LinearTet::corner = { { 0, 0, 0 }, { 1, 0, 0 }, { 0, 1, 0 }, { 0, 0, 1 } } [static, protected]
Definition at line 238 of file ElemUtil.hpp.
double moab::Element::LinearTet::det_T [protected]
Definition at line 240 of file ElemUtil.hpp.
Referenced by det_jacobian(), integrate_scalar_field(), and set_vertices().
Referenced by det_ijacobian(), and set_vertices().
Definition at line 239 of file ElemUtil.hpp.
Referenced by evaluate(), jacobian(), and set_vertices().
Referenced by ievaluate(), ijacobian(), and set_vertices().
List of all members.
