moab::Element Namespace Reference
Classes
class  Map
 Class representing a map (diffeomorphism) F parameterizing a 3D element by its canonical preimage. More...
class  LinearHex
 Shape function space for trilinear hexahedron, obtained by a pushforward of the canonical linear (affine) functions. More...
class  QuadraticHex
class  LinearTet
 Shape function space for a linear tetrahedron, obtained by a pushforward of the canonical affine shape functions. More...
class  SpectralHex
class  LinearQuad
 Shape function space for bilinear quadrilateral, obtained from the canonical linear (affine) functions. More...
class  SphericalQuad
 Shape function space for bilinear quadrilateral on sphere, obtained from the canonical linear (affine) functions. It is mapped using gnomonic projection to a plane tangent at the first vertex It works well for edges that are great circle arcs; RLL meshes do not have this property, but HOMME or MPAS meshes do have it. More...
class  LinearTri
 Shape function space for linear triangle, similar to linear tet. More...
class  SphericalTri
 Shape function space for linear triangle on sphere, obtained from the canonical linear (affine) functions. It is mapped using gnomonic projection to a plane tangent at the first vertex It works well for edges that are great circle arcs; RLL meshes do not have this property, but HOMME or MPAS meshes do have it. More...
class  LinearEdge
class  SpectralQuad
Functions
double SH (const int i, const double xi)
double DSH (const int i, const double xi)
Function Documentation
double moab::Element::DSH ( const int  i,
const double  xi
Definition at line 821 of file ElemUtil.cpp.
Referenced by moab::Element::QuadraticHex::jacobian(), and moab::element_utility::Quadratic_hex_map< moab::Matrix3 >::jacobian().
        switch( i )
            case -1:
                return xi - 0.5;
            case 0:
                return -2 * xi;
            case 1:
                return xi + 0.5;
            default:
                return 0.;
