moab::Element::SpectralHex Class Reference
#include <ElemUtil.hpp>
+ Inheritance diagram for moab::Element::SpectralHex:
+ Collaboration diagram for moab::Element::SpectralHex:
Public Member Functions
 SpectralHex (const std::vector< CartVect > &vertices)
 SpectralHex (int order, double *x, double *y, double *z)
 SpectralHex (int order)
 SpectralHex ()
virtual ~SpectralHex ()
void set_gl_points (double *x, double *y, double *z)
virtual CartVect evaluate (const CartVect &xi) const
 Evaluate the map on \(x_i\) (calculate \(\vec x = F($\vec \xi)\) )
virtual CartVect ievaluate (const CartVect &x, double tol=1e-6, const CartVect &x0=CartVect(0.0)) const
 Evaluate the inverse map (calculate \(\vec \xi = F^-1($\vec x)\) to given tolerance)
virtual Matrix3 jacobian (const CartVect &xi) const
 Evaluate the map's Jacobi matrix.
double evaluate_scalar_field (const CartVect &xi, const double *field_vertex_values) const
 Evaluate a scalar field at a point given field values at the vertices.
double integrate_scalar_field (const double *field_vertex_values) const
 Integrate a scalar field over the element given field values at the vertices.
bool inside_nat_space (const CartVect &xi, double &tol) const
 decide if within the natural param space, with a tolerance
void Init (int order)
void freedata ()
Protected Attributes
realType_xyz [3]
Static Protected Attributes
static int _n
static realType_z [3]
static lagrange_data _ld [3]
static opt_data_3 _data
static realType_odwork
static bool _init = false
Detailed Description
Definition at line 243 of file ElemUtil.hpp.
moab::Element::SpectralHex::SpectralHex ( const std::vector< CartVect > &  vertices) [inline]
Definition at line 246 of file ElemUtil.hpp.
References _xyz.
                                                             : Map( vertices )
            _xyz[0] = _xyz[1] = _xyz[2] = NULL;
moab::Element::SpectralHex::SpectralHex ( int  order,
double *  x,
double *  y,
double *  z
Definition at line 955 of file ElemUtil.cpp.
References _xyz, and Init().
        : Map( 0 )
        Init( order );
        _xyz[0] = x;
        _xyz[1] = y;
        _xyz[2] = z;
Definition at line 962 of file ElemUtil.cpp.
                                        : Map( 0 )
        Init( order );
Definition at line 950 of file ElemUtil.cpp.
References _xyz.
                             : Map( 0 )
Definition at line 967 of file ElemUtil.cpp.
References _init, and freedata().
        if( _init ) freedata();
        _init = false;
Member Function Documentation
CartVect moab::Element::SpectralHex::evaluate ( const CartVect xi) const [virtual]
Implements moab::Element::Map.
Definition at line 58 of file SpectralHex.cpp.
References moab::SpectralHex::_ld, moab::SpectralHex::_odwork, lagrange_0(), and tensor_i3().
Referenced by test_spectral_hex().
    // piece that we shouldn't want to cache
    int d = 0;
    for( d = 0; d < 3; d++ )
        lagrange_0( &_ld[d], params[d] );
    CartVect result;
        result[d] = tensor_i3( _ld[0].J, _ld[0].n, _ld[1].J, _ld[1].n, _ld[2].J, _ld[2].n,
                               _xyz[d],  // this is the "field"
                               _odwork );
    return result;
double moab::Element::SpectralHex::evaluate_scalar_field ( const CartVect xi,
const double *  field_vertex_values
) const [virtual]
Definition at line 1073 of file ElemUtil.cpp.
References _ld, _odwork, lagrange_0(), and tensor_i3().
Referenced by moab::Coupler::interp_field(), and test_spectral_hex().
        int d;
            lagrange_0( &_ld[d], xi[d] );
        double value = tensor_i3( _ld[0].J, _ld[0].n, _ld[1].J, _ld[1].n, _ld[2].J, _ld[2].n, field, _odwork );
        return value;
Definition at line 41 of file SpectralHex.cpp.
References moab::SpectralHex::_data, moab::SpectralHex::_ld, moab::SpectralHex::_odwork, moab::SpectralHex::_z, lagrange_free(), and opt_free_3().
Referenced by Init(), and ~SpectralHex().
    for( int d = 0; d < 3; d++ )
        free( _z[d] );
        lagrange_free( &_ld[d] );
    opt_free_3( &_data );
    free( _odwork );
CartVect moab::Element::SpectralHex::ievaluate ( const CartVect x,
double  tol = 1e-6,
const CartVect x0 = CartVect( 0.0 )
) const [virtual]
Reimplemented from moab::Element::Map.
Definition at line 1030 of file ElemUtil.cpp.
References _data, _xyz, moab::CartVect::get(), opt_findpt_3(), and opt_no_constraints_3.
Referenced by moab::Coupler::nat_param(), and test_spectral_hex().
        // find nearest point
        realType x_star[3];
        xyz.get( x_star );
        realType r[3] = { 0, 0, 0 };  // initial guess for parametric coords
        x0.get( r );
        unsigned c    = opt_no_constraints_3;
        realType dist = opt_findpt_3( &_data, (const realType**)_xyz, x_star, r, &c );
        // if it did not converge, get out with throw...
        if( dist > 10 * tol )  // outside the element
            std::vector< CartVect > dummy;
            throw Map::EvaluationError( xyz, dummy );
        // c tells us if we landed inside the element or exactly on a face, edge, or node
        // also, dist shows the distance to the computed point.
        // copy parametric coords back
        return CartVect( r );
void moab::Element::SpectralHex::Init ( int  order)
Definition at line 972 of file ElemUtil.cpp.
References _data, _init, _ld, _n, _odwork, _z, freedata(), lagrange_setup(), lobatto_nodes(), opt_alloc_3(), and tmalloc.
Referenced by SpectralHex().
        if( _init && _n == order ) return;
        if( _init && _n != order )
            // TODO: free data cached
            freedata();
        // compute stuff that depends only on order
        _init = true;
        _n    = order;
        // triplicates! n is the same in all directions !!!
            _z[d] = tmalloc( realType, _n );
            lobatto_nodes( _z[d], _n );
            lagrange_setup( &_ld[d], _z[d], _n );
        opt_alloc_3( &_data, _ld );
        unsigned int nf = _n * _n, ne = _n, nw = 2 * _n * _n + 3 * _n;
        _odwork = tmalloc( realType, 6 * nf + 9 * ne + nw );
bool moab::Element::SpectralHex::inside_nat_space ( const CartVect xi,
double &  tol
) const [virtual]
Definition at line 1134 of file ElemUtil.cpp.
Referenced by moab::Coupler::nat_param().
        // just look at the box+tol here
        return ( xi[0] >= -1. - tol ) && ( xi[0] <= 1. + tol ) && ( xi[1] >= -1. - tol ) && ( xi[1] <= 1. + tol ) &&
               ( xi[2] >= -1. - tol ) && ( xi[2] <= 1. + tol );
double moab::Element::SpectralHex::integrate_scalar_field ( const double *  field_vertex_values) const [virtual]
Definition at line 1085 of file ElemUtil.cpp.
References _data, _ld, _n, _xyz, moab::Matrix3::determinant(), opt_data_3::elx, lagrange_data::J, opt_data_3::jac, opt_vol_set_intp_3(), and lagrange_data::z.
        // set the position of GL points
        // set the positions of GL nodes, before evaluations
        _data.elx[0] = _xyz[0];
        _data.elx[1] = _xyz[1];
        _data.elx[2] = _xyz[2];
        double xi[3];
        // triple loop; the most inner loop is in r direction, then s, then t
        double integral = 0.;
        // double volume = 0;
        int index = 0;  // used fr the inner loop
        for( int k = 0; k < _n; k++ )
            xi[2] = _ld[2].z[k];
            // double wk= _ld[2].w[k];
            for( int j = 0; j < _n; j++ )
                xi[1] = _ld[1].z[j];
                // double wj= _ld[1].w[j];
                for( int i = 0; i < _n; i++ )
                    xi[0] = _ld[0].z[i];
                    // double wi= _ld[0].w[i];
                    opt_vol_set_intp_3( &_data, xi );
                    double wk = _ld[2].J[k];
                    double wj = _ld[1].J[j];
                    double wi = _ld[0].J[i];
                    Matrix3 J( 0. );
                    // it is organized differently
                    J( 0, 0 ) = _data.jac[0];  // dx/dr
                    J( 0, 1 ) = _data.jac[1];  // dx/ds
                    J( 0, 2 ) = _data.jac[2];  // dx/dt
                    J( 1, 0 ) = _data.jac[3];  // dy/dr
                    J( 1, 1 ) = _data.jac[4];  // dy/ds
                    J( 1, 2 ) = _data.jac[5];  // dy/dt
                    J( 2, 0 ) = _data.jac[6];  // dz/dr
                    J( 2, 1 ) = _data.jac[7];  // dz/ds
                    J( 2, 2 ) = _data.jac[8];  // dz/dt
                    double bm = wk * wj * wi * J.determinant();
                    integral += bm * field_vertex_values[index++];
                    // volume +=bm;
        // std::cout << "volume: " << volume << "\n";
        return integral;
Matrix3 moab::Element::SpectralHex::jacobian ( const CartVect xi) const [virtual]
Definition at line 100 of file SpectralHex.cpp.
References moab::SpectralHex::_data, opt_data_3::elx, moab::CartVect::get(), opt_data_3::jac, and opt_vol_set_intp_3().
    real x_i[3];
    params.get( x_i );
    opt_vol_set_intp_3( &_data, x_i );
    Matrix3 J( 0. );
    return J;
void moab::Element::SpectralHex::set_gl_points ( double *  x,
double *  y,
double *  z
Definition at line 52 of file SpectralHex.cpp.
    _xyz[0] = x;
    _xyz[1] = y;
    _xyz[2] = z;
Member Data Documentation
Definition at line 272 of file ElemUtil.hpp.
Referenced by ievaluate(), Init(), and integrate_scalar_field().
bool moab::Element::SpectralHex::_init = false [static, protected]
Definition at line 276 of file ElemUtil.hpp.
Definition at line 271 of file ElemUtil.hpp.
Referenced by evaluate_scalar_field(), Init(), and integrate_scalar_field().
int moab::Element::SpectralHex::_n [static, protected]
Definition at line 269 of file ElemUtil.hpp.
Referenced by Init(), and integrate_scalar_field().
Definition at line 273 of file ElemUtil.hpp.
Referenced by evaluate_scalar_field(), and Init().
Definition at line 278 of file ElemUtil.hpp.
Referenced by ievaluate(), integrate_scalar_field(), and SpectralHex().
Definition at line 270 of file ElemUtil.hpp.
Referenced by Init().
List of all members.
