moab::FindVolumeIntRegCtxt Class Reference
+ Inheritance diagram for moab::FindVolumeIntRegCtxt:
+ Collaboration diagram for moab::FindVolumeIntRegCtxt:
Public Member Functions
 FindVolumeIntRegCtxt ()
ErrorCode register_intersection (EntityHandle set, EntityHandle tri, double dist, OrientedBoxTreeTool::IntersectSearchWindow &search_win, GeomUtil::intersection_type)
Public Attributes
double pos
double neg
Detailed Description
Definition at line 46 of file GeomQueryTool.cpp.
Definition at line 51 of file GeomQueryTool.cpp.
References moab::OrientedBoxTreeTool::IntRegCtxt::facets, moab::OrientedBoxTreeTool::IntRegCtxt::intersections, and moab::OrientedBoxTreeTool::IntRegCtxt::sets.
        // initialize return vectors
        // only one hit is returned in this context
        intersections.push_back( std::numeric_limits< double >::max() );
        sets.push_back( 0 );
        facets.push_back( 0 );
Member Function Documentation
Reimplemented from moab::OrientedBoxTreeTool::IntRegCtxt.
Definition at line 60 of file GeomQueryTool.cpp.
References moab::OrientedBoxTreeTool::IntRegCtxt::facets, moab::OrientedBoxTreeTool::IntRegCtxt::intersections, MB_SUCCESS, neg, pos, and moab::OrientedBoxTreeTool::IntRegCtxt::sets.
        // update dist, set, and triangle hit if
        // we found a new minimum distance
        double abs_dist = fabs( dist );
        if( abs_dist < fabs( intersections[0] ) )
            intersections[0] = dist;
            sets[0]          = set;
            facets[0]        = tri;
            // narrow search window based on the hit distance
            pos               = abs_dist;
            neg               = -abs_dist;
            search_win.first  = &pos;
            search_win.second = &neg;
        return MB_SUCCESS;
Member Data Documentation
Definition at line 87 of file GeomQueryTool.cpp.
Referenced by register_intersection().
Definition at line 86 of file GeomQueryTool.cpp.
List of all members.
