moab::OrientedBoxTreeTool Class Reference
Class for constructing and querying Hierarchical Oriented Bounding Box trees. More...
#include <OrientedBoxTreeTool.hpp>
+ Collaboration diagram for moab::OrientedBoxTreeTool:
Classes
class  IntRegCtxt
 Default/Base class to provide a context for registering intersections. More...
class  Op
 Implement this and pass instance to preorder_traverse. More...
struct  SetData
struct  Settings
 Misc. knobs controlling tree subdivision. More...
class  TrvStats
 Traversal statistics structure. More...
Public Types
typedef std::pair< const
double *, const double * >
IntersectSearchWindow
 This provides the search range for ray intersections, measured relative to the origin of the ray.
Public Member Functions
 OrientedBoxTreeTool (Interface *i, const char *tag_name=0, bool destroy_created_trees=false)
 ~OrientedBoxTreeTool ()
ErrorCode build (const Range &entities, EntityHandle &set_handle_out, const Settings *settings=0)
 Build oriented bounding box tree.
ErrorCode join_trees (const Range &tree_roots, EntityHandle &root_set_out, const Settings *settings=0)
 Build a tree of sets, where each set contains triangles.
ErrorCode ray_intersect_triangles (std::vector< double > &distances_out, std::vector< EntityHandle > &facets_out, EntityHandle root_set, double tolerance, const double ray_point[3], const double unit_ray_dir[3], const double *ray_length=0, TrvStats *accum=0)
 Intersect a ray with the triangles contained within the tree.
ErrorCode ray_intersect_boxes (Range &boxes_out, EntityHandle root_set, double tolerance, const double ray_point[3], const double unit_ray_dir[3], const double *ray_length=0, TrvStats *accum=0)
 Intersect ray with tree.
ErrorCode ray_intersect_triangles (std::vector< double > &intersection_distances_out, std::vector< EntityHandle > &intersection_facets_out, const Range &leaf_boxes_containing_tris, double tolerance, const double ray_point[3], const double unit_ray_dir[3], const double *ray_length=0, unsigned int *raytri_test_count=0)
 Intersect ray with triangles contained in passed MBENTITYSETs.
ErrorCode ray_intersect_sets (std::vector< double > &distances_out, std::vector< EntityHandle > &sets_out, std::vector< EntityHandle > &facets_out, EntityHandle root_set, double tolerance, const double ray_point[3], const double unit_ray_dir[3], IntersectSearchWindow &search_win, IntRegCtxt &register_intersection, TrvStats *accum=0)
ErrorCode ray_intersect_sets (std::vector< double > &distances_out, std::vector< EntityHandle > &sets_out, std::vector< EntityHandle > &facets_out, EntityHandle root_set, double tolerance, const double ray_point[3], const double unit_ray_dir[3], const double *ray_length=0, TrvStats *accum=0)
ErrorCode ray_intersect_sets (EntityHandle root_set, double tolerance, const double ray_point[3], const double unit_ray_dir[3], IntersectSearchWindow &search_win, IntRegCtxt &register_intersection, TrvStats *accum=0)
ErrorCode closest_to_location (const double *point, EntityHandle tree_root, double *point_out, EntityHandle &facet_out, EntityHandle *set_out=0, TrvStats *accum=0)
 Find closest surface, facet in surface, and location on facet.
ErrorCode closest_to_location (const double *point, EntityHandle tree_root, double tolerance, std::vector< EntityHandle > &facets_out, std::vector< EntityHandle > *sets_out=0, TrvStats *accum=0)
 Find closest facet(s) to input position.
ErrorCode sphere_intersect_triangles (const double *center, double radius, EntityHandle tree_root, std::vector< EntityHandle > &facets_out, std::vector< EntityHandle > *sets_out=0, TrvStats *accum=0)
 Find facets intersected by a sphere.
ErrorCode get_close_tris (CartVect int_pt, double tol, const EntityHandle *rootSet, const EntityHandle *geomVol, const Tag *senseTag, std::vector< EntityHandle > &close_tris, std::vector< int > &close_senses)
ErrorCode box (EntityHandle node_set, double center[3], double axis1[3], double axis2[3], double axis3[3])
 Get oriented box at node in tree.
ErrorCode delete_tree (EntityHandle root_set)
ErrorCode remove_root (EntityHandle root_set)
 Remove obb tree root from the Oriented Box Tree Tool data structure.
void print (EntityHandle tree_root_set, std::ostream &stream, bool list_contents=false, const char *id_tag_name=0)
 Print out tree.
ErrorCode stats (EntityHandle tree_root_set, std::ostream &stream)
 Print tree statistics.
ErrorCode stats (EntityHandle set, unsigned &entities_in_tree, double &root_volume, double &tot_node_volume, double &tot_to_root_volume, unsigned &tree_height, unsigned &node_count, unsigned &num_leaves)
 Get tree statistics.
ErrorCode preorder_traverse (EntityHandle root_set, Op &operation, TrvStats *accum=0)
 Visitor pattern - do operation for each tree node.
Interfaceget_moab_instance () const
ErrorCode box (EntityHandle node_set, OrientedBox &box)
Private Member Functions
ErrorCode build_tree (const Range &entities, EntityHandle &set, int depth, const Settings &settings)
ErrorCode build_sets (std::list< SetData > &sets, EntityHandle &node_set, int depth, const Settings &settings)
ErrorCode recursive_stats (OrientedBoxTreeTool *tool, Interface *instance, EntityHandle set, int depth, StatData &data, unsigned &count_out, CartVect &dimensions_out)
Private Attributes
Interfaceinstance
Tag tagHandle
bool cleanUpTrees
std::vector< EntityHandlecreatedTrees
Detailed Description
Definition at line 42 of file OrientedBoxTreeTool.hpp.
Member Typedef Documentation
typedef std::pair< const double*, const double* > moab::OrientedBoxTreeTool::IntersectSearchWindow
first: nonnegative limit for search second: negative limit for search
These are const double* so that the window is always defined by pointing to other quantities, but it is not posible to change those quantities via the window.
Definition at line 55 of file OrientedBoxTreeTool.hpp.
moab::OrientedBoxTreeTool::OrientedBoxTreeTool ( Interface i,
const char *  tag_name = 0,
bool  destroy_created_trees = false
Definition at line 49 of file OrientedBoxTreeTool.cpp.
References moab::DEFAULT_TAG_NAME, ErrorCode, instance, MB_SUCCESS, moab::OrientedBox::tag_handle(), and tagHandle.
    : instance( i ), cleanUpTrees( destroy_created_trees )
    if( !tag_name ) tag_name = DEFAULT_TAG_NAME;
    ErrorCode rval = OrientedBox::tag_handle( tagHandle, instance, tag_name );
    if( MB_SUCCESS != rval ) tagHandle = 0;
Definition at line 57 of file OrientedBoxTreeTool.cpp.
References cleanUpTrees, createdTrees, delete_tree(), ErrorCode, instance, MB_SUCCESS, moab::Interface::tag_get_by_ptr(), and tagHandle.
    if( !cleanUpTrees ) return;
    while( !createdTrees.empty() )
        EntityHandle tree = createdTrees.back();
        // make sure this is a tree (rather than some other, stale handle)
        const void* data_ptr = 0;
        ErrorCode rval       = instance->tag_get_by_ptr( tagHandle, &tree, 1, &data_ptr );
        if( MB_SUCCESS == rval ) rval = delete_tree( tree );
        if( MB_SUCCESS != rval ) createdTrees.pop_back();
Member Function Documentation
ErrorCode moab::OrientedBoxTreeTool::box ( EntityHandle  node_set,
double  center[3],
double  axis1[3],
double  axis2[3],
double  axis3[3]
Get the oriented box for a node in an oriented bounding box tree.
Definition at line 91 of file OrientedBoxTreeTool.cpp.
References moab::OrientedBox::center, ErrorCode, moab::CartVect::get(), and moab::OrientedBox::scaled_axis().
Referenced by closest_to_location(), FBiGeom_getEntBoundBox(), moab::GeomTopoTool::get_obb(), moab::FBEngine::getEntBoundBox(), main(), moab::TreeNodePrinter::print_geometry(), recursive_stats(), sphere_intersect_triangles(), moab::RayIntersector::visit(), and moab::RayIntersectSets::visit().
    OrientedBox obb;
    ErrorCode rval = this->box( set, obb );
    obb.center.get( center );
    obb.scaled_axis( 0 ).get( axis1 );
    obb.scaled_axis( 1 ).get( axis2 );
    obb.scaled_axis( 2 ).get( axis3 );
    return rval;
NOTE: This function is provided for internal MOAB use only. The definition of OrientedBox is not available as a part of the MOAB API
Definition at line 86 of file OrientedBoxTreeTool.cpp.
References instance, moab::Interface::tag_get_data(), and tagHandle.
    return instance->tag_get_data( tagHandle, &set, 1, &obb );
ErrorCode moab::OrientedBoxTreeTool::build ( const Range entities,
EntityHandle set_handle_out,
const Settings settings = 0
Build an oriented bounding box tree.
Parameters:
entitiesA list of either vertices or 2-D elements (not both) for which to build a tree.
set_handle_outA handle for the entity set representing the root of the tree.
Definition at line 115 of file OrientedBoxTreeTool.cpp.
References moab::Range::all_of_dimension(), build_tree(), MB_TYPE_OUT_OF_RANGE, and moab::OrientedBoxTreeTool::Settings::valid().
Referenced by moab::GeomTopoTool::construct_obb_tree(), and main().
    if( !entities.all_of_dimension( 2 ) ) return MB_TYPE_OUT_OF_RANGE;
    if( settings && !settings->valid() ) return MB_FAILURE;
    return build_tree( entities, set_handle_out, 0, settings ? *settings : Settings() );
ErrorCode moab::OrientedBoxTreeTool::build_sets ( std::list< SetData > &  sets,
int  depth,
) [private]
Definition at line 340 of file OrientedBoxTreeTool.cpp.
References moab::Interface::add_child_meshset(), child, moab::Range::clear(), moab::OrientedBox::compute_from_covariance_data(), moab::Interface::create_meshset(), delete_tree(), ErrorCode, moab::Interface::get_adjacencies(), moab::Interface::get_entities_by_dimension(), instance, MB_SUCCESS, moab::OrientedBoxTreeTool::Settings::set_options, moab::split_sets(), moab::Interface::tag_set_data(), tagHandle, and moab::Interface::UNION.
Referenced by join_trees().
    ErrorCode rval;
    int count = sets.size();
    if( 0 == count ) return MB_FAILURE;
    // calculate box
    OrientedBox obox;
    // make vector go out of scope when done, so memory is released
        Range elems;
        std::vector< OrientedBox::CovarienceData > data( sets.size() );
        data.clear();
        for( std::list< SetData >::iterator i = sets.begin(); i != sets.end(); ++i )
            data.push_back( i->box_data );
            rval = instance->get_entities_by_dimension( i->handle, 2, elems, true );
            if( MB_SUCCESS != rval ) return rval;
        Range points;
        rval = instance->get_adjacencies( elems, 0, false, points, Interface::UNION );
        rval = OrientedBox::compute_from_covariance_data( obox, instance, &data[0], data.size(), points );
    // If only one set in list...
    if( count == 1 )
        node_set = sets.front().handle;
        return instance->tag_set_data( tagHandle, &node_set, 1, &obox );
    // create an entity set for the tree node
    rval = instance->create_meshset( settings.set_options, node_set );
    rval = instance->tag_set_data( tagHandle, &node_set, 1, &obox );
        delete_tree( node_set );
        return rval;
    double best_ratio = 2.0;
    std::list< SetData > best_left_list, best_right_list;
    for( int axis = 0; axis < 2; ++axis )
        std::list< SetData > left_list, right_list;
        rval = split_sets( instance, obox, axis, sets, left_list, right_list );
            return rval;
        double ratio = fabs( (double)right_list.size() - left_list.size() ) / sets.size();
        if( ratio < best_ratio )
            best_ratio = ratio;
            best_left_list.swap( left_list );
            best_right_list.swap( right_list );
    // We must subdivide the list of sets, because we want to guarantee that
    // there is a node in the tree corresponding to each of the sets.  So if
    // we couldn't find a usable split plane, just split them in an arbitrary
    // manner.
    if( best_left_list.empty() || best_right_list.empty() )
        best_left_list.clear();
        best_right_list.clear();
        std::list< SetData >* lists[2] = { &best_left_list, &best_right_list };
        int i                          = 0;
        while( !sets.empty() )
            lists[i]->push_back( sets.front() );
            sets.pop_front();
            i = 1 - i;
    else
        sets.clear();  // release memory before recursion
    // Create child sets
    EntityHandle child = 0;
    rval = build_sets( best_left_list, child, depth + 1, settings );
        return rval;
    rval = instance->add_child_meshset( node_set, child );
        delete_tree( child );
        return rval;
    rval = build_sets( best_right_list, child, depth + 1, settings );
        return rval;
        return rval;
    return MB_SUCCESS;
ErrorCode moab::OrientedBoxTreeTool::build_tree ( const Range entities,
EntityHandle set,
int  depth,
) [private]
Definition at line 204 of file OrientedBoxTreeTool.cpp.
References moab::Interface::add_child_meshset(), moab::Interface::add_entities(), moab::OrientedBoxTreeTool::Settings::best_split_ratio, child, moab::OrientedBox::compute_from_2d_cells(), moab::Interface::create_meshset(), createdTrees, delete_tree(), moab::Range::empty(), ErrorCode, instance, moab::OrientedBoxTreeTool::Settings::max_depth, moab::OrientedBoxTreeTool::Settings::max_leaf_entities, MB_SUCCESS, moab::OrientedBoxTreeTool::Settings::set_options, moab::Range::size(), moab::split_box(), moab::Range::swap(), moab::Interface::tag_set_data(), tagHandle, and moab::OrientedBoxTreeTool::Settings::worst_split_ratio.
Referenced by build().
    OrientedBox tmp_box;
    ErrorCode rval;
    if( entities.empty() )
        Matrix3 axis;
        tmp_box = OrientedBox( axis, CartVect( 0. ) );
    else
        rval = OrientedBox::compute_from_2d_cells( tmp_box, instance, entities );
    rval = instance->create_meshset( settings.set_options, set );
    rval = instance->tag_set_data( tagHandle, &set, 1, &tmp_box );
        delete_tree( set );
        return rval;
    // check if should create children
    bool leaf = true;
    ++depth;
    if( ( !settings.max_depth || depth < settings.max_depth ) &&
        entities.size() > (unsigned)settings.max_leaf_entities )
        // try splitting with planes normal to each axis of the box
        // until we find an acceptable split
        double best_ratio = settings.worst_split_ratio;  // worst case ratio
        Range best_left_list, best_right_list;
        // Axes are sorted from shortest to longest, so search backwards
        for( int axis = 2; best_ratio > settings.best_split_ratio && axis >= 0; --axis )
            Range left_list, right_list;
            rval = split_box( instance, tmp_box, axis, entities, left_list, right_list );
                delete_tree( set );
                return rval;
            double ratio = fabs( (double)right_list.size() - left_list.size() ) / entities.size();
                best_ratio = ratio;
        // create children
        if( !best_left_list.empty() )
            rval = build_tree( best_left_list, child, depth, settings );
                delete_tree( set );
                return rval;
            rval = instance->add_child_meshset( set, child );
                delete_tree( set );
                return rval;
            rval = build_tree( best_right_list, child, depth, settings );
                delete_tree( set );
                return rval;
                delete_tree( set );
                return rval;
            leaf = false;
    if( leaf )
        rval = instance->add_entities( set, entities );
            delete_tree( set );
            return rval;
    createdTrees.push_back( set );
    return MB_SUCCESS;
ErrorCode moab::OrientedBoxTreeTool::closest_to_location ( const double *  point,
double *  point_out,
EntityHandle facet_out,
EntityHandle set_out = 0,
TrvStats accum = 0
Find the closest location in the tree to the specified location.
Parameters:
pointLocation to search from
point_outClosest location on closest facet
facet_outClosest 2D element to input position
set_outSet containing closest facet. 0 if tree was not constructed using 'set_build'
Definition at line 1118 of file OrientedBoxTreeTool.cpp.
References moab::Range::begin(), box(), children, moab::Range::clear(), moab::OrientedBox::closest_location_in_box(), moab::GeomUtil::closest_location_on_polygon(), moab::GeomUtil::closest_location_on_tri(), moab::Range::empty(), moab::Range::end(), moab::OrientedBoxTreeTool::TrvStats::end_traversal(), ErrorCode, moab::Range::front(), moab::CartVect::get(), moab::Interface::get_child_meshsets(), moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::Interface::get_entities_by_dimension(), moab::Interface::get_entities_by_type(), moab::OrientedBoxTreeTool::TrvStats::increment(), moab::OrientedBoxTreeTool::TrvStats::increment_leaf(), instance, MB_MULTIPLE_ENTITIES_FOUND, MB_SUCCESS, MBENTITYSET, and moab::Range::size().
Referenced by moab::GeomQueryTool::closest_to_location(), moab::GeomQueryTool::get_normal(), moab::FBEngine::getEntClosestPt(), moab::FBEngine::getEntNrmlXYZ(), moab::SmoothFace::project_to_facets_main(), and moab::GeomQueryTool::test_volume_boundary().
    ErrorCode rval;
    const CartVect loc( point );
    double smallest_dist_sqr = std::numeric_limits< double >::max();
    EntityHandle current_set = 0;
    Range sets;
    std::vector< EntityHandle > children( 2 );
    std::vector< double > coords;
    std::vector< OBBTreeCPFrame > stack;
    int max_depth = -1;
    stack.push_back( OBBTreeCPFrame( 0.0, root, current_set, 0 ) );
    while( !stack.empty() )
        // pop from top of stack
        EntityHandle node = stack.back().node;
        double dist_sqr   = stack.back().dist_sqr;
        current_set       = stack.back().mset;
        int current_depth = stack.back().depth;
        stack.pop_back();
        // If current best result is closer than the box, skip this tree node.
        if( dist_sqr > smallest_dist_sqr ) continue;
        // increment traversal statistics.
        if( accum )
            accum->increment( current_depth );
            max_depth = std::max( max_depth, current_depth );
        // Check if this node has a set associated with it
        if( set_out && !current_set )
            sets.clear();
            rval = instance->get_entities_by_type( node, MBENTITYSET, sets );
            if( !sets.empty() )
                if( sets.size() != 1 ) return MB_MULTIPLE_ENTITIES_FOUND;
                current_set = sets.front();
        // Get child boxes
        children.clear();
        rval = instance->get_child_meshsets( node, children );
        // if not a leaf node
        if( !children.empty() )
            if( children.size() != 2 ) return MB_MULTIPLE_ENTITIES_FOUND;
            // get boxes
            OrientedBox box1, box2;
            rval = box( children[0], box1 );
            rval = box( children[1], box2 );
            // get distance from each box
            CartVect pt1, pt2;
            box1.closest_location_in_box( loc, pt1 );
            box2.closest_location_in_box( loc, pt2 );
            pt1 -= loc;
            pt2 -= loc;
            const double dsqr1 = pt1 % pt1;
            const double dsqr2 = pt2 % pt2;
            // push children on tree such that closer one is on top
            if( dsqr1 < dsqr2 )
                stack.push_back( OBBTreeCPFrame( dsqr2, children[1], current_set, current_depth + 1 ) );
                stack.push_back( OBBTreeCPFrame( dsqr1, children[0], current_set, current_depth + 1 ) );
            else
        else
        {  // LEAF NODE
            if( accum )
                accum->increment_leaf( current_depth );
            Range facets;
            rval = instance->get_entities_by_dimension( node, 2, facets );
            const EntityHandle* conn = NULL;
            int len                  = 0;
            CartVect tmp, diff;
            for( Range::iterator i = facets.begin(); i != facets.end(); ++i )
                rval = instance->get_connectivity( *i, conn, len, true );
                coords.resize( 3 * len );
                rval = instance->get_coords( conn, len, &coords[0] );
                if( len == 3 )
                    GeomUtil::closest_location_on_tri( loc, (CartVect*)( &coords[0] ), tmp );
                else
                    GeomUtil::closest_location_on_polygon( loc, (CartVect*)( &coords[0] ), len, tmp );
                diff     = tmp - loc;
                dist_sqr = diff % diff;
                if( dist_sqr < smallest_dist_sqr )
                    smallest_dist_sqr = dist_sqr;
                    facet_out         = *i;
                    tmp.get( point_out );
                    if( set_out ) *set_out = current_set;
        }  // LEAF NODE
    if( accum )
        accum->end_traversal( max_depth );
    return MB_SUCCESS;
double  tolerance,
std::vector< EntityHandle > &  facets_out,
std::vector< EntityHandle > *  sets_out = 0,
TrvStats accum = 0
Find the closest location(s) in the tree to the specified location.
Parameters:
facets_outClosest 2D elements to input position are appended to this list
sets_outIf non-null, sets owning facets are appended to this list.
Definition at line 1258 of file OrientedBoxTreeTool.cpp.
References moab::Range::begin(), box(), children, moab::Range::clear(), moab::OrientedBox::closest_location_in_box(), moab::GeomUtil::closest_location_on_polygon(), moab::GeomUtil::closest_location_on_tri(), moab::Range::empty(), moab::Range::end(), moab::OrientedBoxTreeTool::TrvStats::end_traversal(), ErrorCode, moab::Interface::get_child_meshsets(), moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::Interface::get_entities_by_dimension(), moab::Interface::get_entities_by_type(), moab::OrientedBoxTreeTool::TrvStats::increment(), moab::OrientedBoxTreeTool::TrvStats::increment_leaf(), instance, MB_MULTIPLE_ENTITIES_FOUND, MB_SUCCESS, MBENTITYSET, and moab::Range::size().
    ErrorCode rval;
    double smallest_dist     = smallest_dist_sqr;
    Range sets;
    int max_depth = -1;
        stack.pop_back();
        if( dist_sqr > smallest_dist_sqr + tolerance ) continue;
        if( accum )
        if( sets_out && !current_set )
            sets.clear();
            if( !sets.empty() )
                current_set = *sets.begin();
        // Get child boxes
        children.clear();
            // get boxes
            CartVect pt1, pt2;
            pt1 -= loc;
            pt2 -= loc;
            if( dsqr1 < dsqr2 )
            else
        else
        {  // LEAF NODE
            if( accum )
            Range facets;
            int len                  = 0;
            CartVect tmp, diff;
                if( len == 3 )
                else
                diff     = tmp - loc;
                    if( 0.5 * dist_sqr < 0.5 * smallest_dist_sqr + tolerance * ( 0.5 * tolerance - smallest_dist ) )
                        facets_out.clear();
                        if( sets_out ) sets_out->clear();
                    smallest_dist     = sqrt( smallest_dist_sqr );
                    // put closest result at start of lists
                    facets_out.push_back( *i );
                    std::swap( facets_out.front(), facets_out.back() );
                    if( sets_out )
                        sets_out->push_back( current_set );
                        std::swap( sets_out->front(), sets_out->back() );
                else if( dist_sqr <= smallest_dist_sqr + tolerance * ( tolerance + 2 * smallest_dist ) )
                    if( sets_out ) sets_out->push_back( current_set );
        }  // LEAF NODE
    if( accum )
    return MB_SUCCESS;
Definition at line 469 of file OrientedBoxTreeTool.cpp.
References children, createdTrees, moab::Interface::delete_entities(), ErrorCode, moab::Interface::get_child_meshsets(), instance, and MB_SUCCESS.
Referenced by build_sets(), build_tree(), and ~OrientedBoxTreeTool().
    std::vector< EntityHandle > children;
    ErrorCode rval = instance->get_child_meshsets( set, children, 0 );
    createdTrees.erase( std::remove( createdTrees.begin(), createdTrees.end(), set ), createdTrees.end() );
    children.insert( children.begin(), set );
    return instance->delete_entities( &children[0], children.size() );
ErrorCode moab::OrientedBoxTreeTool::get_close_tris ( CartVect  int_pt,
double  tol,
const EntityHandle rootSet,
const EntityHandle geomVol,
const Tag senseTag,
std::vector< EntityHandle > &  close_tris,
std::vector< int > &  close_senses
Definition at line 845 of file OrientedBoxTreeTool.cpp.
References moab::CartVect::array(), ErrorCode, get_moab_instance(), MB_SUCCESS, sphere_intersect_triangles(), and moab::Interface::tag_get_data().
Referenced by moab::GQT_IntRegCtxt::register_intersection().
    std::vector< EntityHandle > close_surfs;
    ErrorCode rval = sphere_intersect_triangles( int_pt.array(), tol, *rootSet, close_tris, &close_surfs );
    assert( MB_SUCCESS == rval );
    // for each surface, get the surf sense wrt parent volume
    close_senses.resize( close_surfs.size() );
    for( unsigned i = 0; i < close_surfs.size(); ++i )
        EntityHandle vols[2];
        rval = get_moab_instance()->tag_get_data( *senseTag, &( close_surfs[i] ), 1, vols );
        if( vols[0] == vols[1] )
            std::cerr << "error: surf has positive and negative sense wrt same volume" << std::endl;
            return MB_FAILURE;
        if( *geomVol == vols[0] )
            close_senses[i] = 1;
        else if( *geomVol == vols[1] )
            close_senses[i] = -1;
        else
            return MB_FAILURE;
    return MB_SUCCESS;
ErrorCode moab::OrientedBoxTreeTool::join_trees ( const Range tree_roots,
EntityHandle root_set_out,
Build a tree of sets. Each set must contain at least one triangle to define its geometry. Each passed set will become a leaf of the OBB tree. Settings controlling tree depth are ignored by this method. The tree will be as deep as it needs to be for each input set to be a leaf.
To build a tree representing the surfaces of a geometric volume, 1) Build an OBB tree for each surface using the 'build' method 2) Add each surface to the contents of the resulting OBB tree root set 3) Build a tree from all the surface OBB tree root sets using this method to get a combined tree for the volume.
Definition at line 123 of file OrientedBoxTreeTool.cpp.
References moab::Range::all_of_type(), moab::Range::begin(), moab::OrientedBoxTreeTool::SetData::box_data, build_sets(), moab::OrientedBox::covariance_data_from_tris(), createdTrees, moab::Range::empty(), moab::Range::end(), ErrorCode, moab::Interface::get_entities_by_dimension(), moab::OrientedBoxTreeTool::SetData::handle, instance, MB_SUCCESS, MB_TYPE_OUT_OF_RANGE, MBENTITYSET, moab::Range::rbegin(), moab::Range::rend(), and moab::OrientedBoxTreeTool::Settings::valid().
Referenced by moab::GeomTopoTool::construct_obb_tree(), and moab::GeomTopoTool::construct_obb_trees().
    if( !sets.all_of_type( MBENTITYSET ) ) return MB_TYPE_OUT_OF_RANGE;
    // Build initial set data list.
    std::list< SetData > data;
    for( Range::const_iterator i = sets.begin(); i != sets.end(); ++i )
        Range elements;
        ErrorCode rval = instance->get_entities_by_dimension( *i, 2, elements, true );
        if( elements.empty() ) continue;
        data.push_back( SetData() );
        SetData& set_data = data.back();
        set_data.handle   = *i;
        rval              = OrientedBox::covariance_data_from_tris( set_data.box_data, instance, elements );
    ErrorCode result = build_sets( data, set_handle_out, 0, settings ? *settings : Settings() );
    if( MB_SUCCESS != result ) return result;
    for( Range::reverse_iterator i = sets.rbegin(); i != sets.rend(); ++i )
        createdTrees.erase( std::remove( createdTrees.begin(), createdTrees.end(), *i ), createdTrees.end() );
    createdTrees.push_back( set_handle_out );
    return MB_SUCCESS;
ErrorCode moab::OrientedBoxTreeTool::preorder_traverse ( EntityHandle  root_set,
Op operation,
TrvStats accum = 0
Do a preorder traversal of the tree, calling the method in the passed operation instance for each node in the tree. Parent node is visited before either child (pre-order traversal). If operator method passes back the 'descend' argument as false, traversal will not descend to the children of the current node.
Definition at line 498 of file OrientedBoxTreeTool.cpp.
References children, moab::Data::depth, moab::OrientedBoxTreeTool::TrvStats::end_traversal(), ErrorCode, moab::Interface::get_child_meshsets(), moab::OrientedBoxTreeTool::TrvStats::increment(), moab::OrientedBoxTreeTool::TrvStats::increment_leaf(), instance, moab::OrientedBoxTreeTool::Op::leaf(), MB_MULTIPLE_ENTITIES_FOUND, MB_SUCCESS, moab::Data::set, and moab::OrientedBoxTreeTool::Op::visit().
Referenced by obbstat_write(), obbvis_create(), print(), ray_intersect_boxes(), and ray_intersect_sets().
    ErrorCode rval;
    std::vector< Data > the_stack;
    Data data = { set, 0 };
    the_stack.push_back( data );
    int max_depth = -1;
    while( !the_stack.empty() )
        data = the_stack.back();
        the_stack.pop_back();
        if( accum )
            accum->increment( data.depth );
            max_depth = std::max( max_depth, data.depth );
        bool descend = true;
        rval         = operation.visit( data.set, data.depth, descend );
        if( !descend ) continue;
        children.clear();
        rval = instance->get_child_meshsets( data.set, children );
        if( children.empty() )
            if( accum )
                accum->increment_leaf( data.depth );
            rval = operation.leaf( data.set );
        else if( children.size() == 2 )
            data.depth++;
            data.set = children[0];
            data.set = children[1];
        else
    if( accum )
    return MB_SUCCESS;
void moab::OrientedBoxTreeTool::print ( EntityHandle  tree_root_set,
std::ostream &  stream,
bool  list_contents = false,
const char *  id_tag_name = 0
Print out tree.
Print the tree to an output stream in a human-readable form.
Parameters:
tree_root_setEntity set representing tree root.
list_contentsIf true, list entities in each tree node, If false, just list number of entities.
id_tag_nameIf specified, must be the name of an existing integer tag containing an ID for the entities. Not used if list_contents is false.
Definition at line 1653 of file OrientedBoxTreeTool.cpp.
References ErrorCode, instance, MB_SUCCESS, and preorder_traverse().
    TreeLayoutPrinter op1( str, instance );
    TreeNodePrinter op2( str, list, true, tag, this );
    ErrorCode r1 = preorder_traverse( set, op1 );
    str << std::endl;
    ErrorCode r2 = preorder_traverse( set, op2 );
    if( r1 != MB_SUCCESS || r2 != MB_SUCCESS )
        std::cerr << "Errors encountered while printing tree\n";
        str << "Errors encountered while printing tree\n";
ErrorCode moab::OrientedBoxTreeTool::ray_intersect_boxes ( Range boxes_out,
double  tolerance,
const double *  ray_length = 0,
TrvStats accum = 0
Return the tree nodes (as MBENTITYSET handles) for the leaf boxes of the tree intersected by a ray.
Parameters:
boxes_outThe boxes intersected by the ray.
toleranceThe tolerance to use in intersection checks.
ray_pointThe base point of the ray.
unit_ray_dirThe ray direction vector (must be unit length)
ray_lengthOptional ray length (intersect segment instead of ray.)
Definition at line 815 of file OrientedBoxTreeTool.cpp.
References preorder_traverse().
Referenced by ray_intersect_triangles().
    RayIntersector op( this, ray_point, unit_ray_dir, ray_length, tolerance, boxes_out );
    return preorder_traverse( root_set, op, accum );
ErrorCode moab::OrientedBoxTreeTool::ray_intersect_sets ( std::vector< double > &  distances_out,
std::vector< EntityHandle > &  sets_out,
double  tolerance,
IntersectSearchWindow search_win,
IntRegCtxt register_intersection,
TrvStats accum = 0
Intersect a ray with the triangles contained in the tree and return the distance at which the intersection occured.
Parameters:
distances_outThe output list of intersection points on the ray.
sets_outThe contained set encountered during the tree traversal (see 'set_build'). For the most common use, this is the set corresponding to the geometric surface containing the intersected triangle.
facets_outHandles of intersected triangles corresponding to distances_out
root_setThe MBENTITYSET representing the root of the tree.
search_winAn interval that defines the current window in which the an intersection is being sought: (nonnegative, negative)
register_intersectionA context for assessing and registering intersections derived from IntRegCtxt
accumOptional class for tree traversal statistics.
Definition at line 1036 of file OrientedBoxTreeTool.cpp.
References ErrorCode, moab::OrientedBoxTreeTool::IntRegCtxt::get_facets(), moab::OrientedBoxTreeTool::IntRegCtxt::get_intersections(), moab::OrientedBoxTreeTool::IntRegCtxt::get_sets(), preorder_traverse(), and moab::OrientedBoxTreeTool::TrvStats::ray_tri_tests_count.
Referenced by moab::GeomQueryTool::find_volume(), moab::FBEngine::getPntRayIntsct(), moab::GeomQueryTool::point_in_volume(), moab::GeomQueryTool::ray_fire(), and moab::FBEngine::split_surface_with_direction().
    RayIntersectSets op( this, ray_point, unit_ray_dir, tolerance, search_win,
                         accum ? &( accum->ray_tri_tests_count ) : NULL, int_reg_callback );
    ErrorCode rval = preorder_traverse( root_set, op, accum );
    distances_out = int_reg_callback.get_intersections();
    sets_out      = int_reg_callback.get_sets();
    facets_out    = int_reg_callback.get_facets();
    return rval;
double  tolerance,
TrvStats accum = 0
Definition at line 1059 of file OrientedBoxTreeTool.cpp.
References ErrorCode, moab::OrientedBoxTreeTool::IntRegCtxt::get_facets(), moab::OrientedBoxTreeTool::IntRegCtxt::get_intersections(), moab::OrientedBoxTreeTool::IntRegCtxt::get_sets(), MB_SUCCESS, preorder_traverse(), and moab::OrientedBoxTreeTool::TrvStats::ray_tri_tests_count.
    IntRegCtxt int_reg_ctxt;
    OrientedBoxTreeTool::IntersectSearchWindow search_win( ray_length, (double*)0 );
                         accum ? &( accum->ray_tri_tests_count ) : NULL, int_reg_ctxt );
        return rval;
    distances_out = int_reg_ctxt.get_intersections();
    sets_out      = int_reg_ctxt.get_sets();
    facets_out    = int_reg_ctxt.get_facets();
    return MB_SUCCESS;
ErrorCode moab::OrientedBoxTreeTool::ray_intersect_sets ( EntityHandle  root_set,
double  tolerance,
TrvStats accum = 0
Definition at line 1090 of file OrientedBoxTreeTool.cpp.
References preorder_traverse(), and moab::OrientedBoxTreeTool::TrvStats::ray_tri_tests_count.
ErrorCode moab::OrientedBoxTreeTool::ray_intersect_triangles ( std::vector< double > &  distances_out,
double  tolerance,
TrvStats accum = 0
Parameters:
Definition at line 796 of file OrientedBoxTreeTool.cpp.
References ErrorCode, MB_SUCCESS, ray_intersect_boxes(), and moab::OrientedBoxTreeTool::TrvStats::ray_tri_tests_count.
Referenced by main().
    Range boxes;
    ErrorCode rval;
    rval = ray_intersect_boxes( boxes, root_set, tolerance, ray_point, unit_ray_dir, ray_length, accum );
    return ray_intersect_triangles( intersection_distances_out, intersection_facets_out, boxes, tolerance, ray_point,
                                    unit_ray_dir, ray_length, accum ? &( accum->ray_tri_tests_count ) : NULL );
ErrorCode moab::OrientedBoxTreeTool::ray_intersect_triangles ( std::vector< double > &  intersection_distances_out,
std::vector< EntityHandle > &  intersection_facets_out,
const Range leaf_boxes_containing_tris,
double  tolerance,
unsigned int *  raytri_test_count = 0
Parameters:
raytri_test_countIf non-NULL, count of ray-triangle intersect tests will be added to the value at which this points.
Definition at line 729 of file OrientedBoxTreeTool.cpp.
References moab::Range::begin(), moab::Range::clear(), moab::Range::end(), ErrorCode, moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::Interface::get_entities_by_handle(), moab::Interface::get_entities_by_type(), instance, MB_SUCCESS, MBTRI, moab::GeomUtil::plucker_ray_tri_intersect(), t, and moab::TYPE_FROM_HANDLE().
    ErrorCode rval;
    intersection_distances_out.clear();
#ifdef MB_OBB_USE_VECTOR_QUERIES
    std::vector< EntityHandle > tris;
#endif
    const CartVect point( ray_point );
    const CartVect dir( unit_ray_dir );
    for( Range::iterator b = boxes.begin(); b != boxes.end(); ++b )
#ifndef MB_OBB_USE_VECTOR_QUERIES
        Range tris;
#ifdef MB_OBB_USE_TYPE_QUERIES
        rval = instance->get_entities_by_type( *b, MBTRI, tris );
#else
        rval = instance->get_entities_by_handle( *b, tris );
#endif
#else
        tris.clear();
#endif
            // dump_fragmentation( tris );
        for( Range::iterator t = tris.begin(); t != tris.end(); ++t )
#else
        for( std::vector< EntityHandle >::iterator t = tris.begin(); t != tris.end(); ++t )
#endif
#ifndef MB_OBB_USE_TYPE_QUERIES
            if( TYPE_FROM_HANDLE( *t ) != MBTRI ) continue;
#endif
            int len                  = 0;
            rval                     = instance->get_connectivity( *t, conn, len, true );
            CartVect coords[3];
            rval = instance->get_coords( conn, 3, coords[0].array() );
            if( raytri_test_count ) *raytri_test_count += 1;
            double td;
            if( GeomUtil::plucker_ray_tri_intersect( coords, point, dir, td, ray_length ) )
                intersection_distances_out.push_back( td );
                intersection_facets_out.push_back( *t );
    return MB_SUCCESS;
ErrorCode moab::OrientedBoxTreeTool::recursive_stats ( OrientedBoxTreeTool tool,
Interface instance,
EntityHandle  set,
int  depth,
StatData data,
unsigned &  count_out,
CartVect dimensions_out
) [private]
Definition at line 1813 of file OrientedBoxTreeTool.cpp.
References moab::StatData::Ratio::accum(), moab::StatData::Stat< T >::accum(), moab::OrientedBox::area(), moab::StatData::area, box(), children, moab::StatData::count, moab::OrientedBox::dimensions(), moab::StatData::entities, ErrorCode, moab::Interface::get_child_meshsets(), moab::Interface::get_number_entities_by_handle(), moab::OrientedBox::inner_radius(), moab::StatData::leaf_depth, moab::StatData::leaf_ent, MB_MULTIPLE_ENTITIES_FOUND, MB_SUCCESS, moab::measure(), moab::OrientedBox::outer_radius(), moab::StatData::radius, moab::StatData::vol, moab::OrientedBox::volume(), and moab::StatData::volume.
Referenced by stats().
    ErrorCode rval;
    unsigned counts[2];
    bool isleaf;
    ++data.count;
    rval = tool->box( set, tmp_box );
    children.clear();
    rval = inst->get_child_meshsets( set, children );
    isleaf = children.empty();
    if( !isleaf && children.size() != 2 ) return MB_MULTIPLE_ENTITIES_FOUND;
    dimensions_out = tmp_box.dimensions();
    data.radius.accum( tmp_box.inner_radius() / tmp_box.outer_radius() );
    data.vol.accum( tmp_box.volume() );
    data.area.accum( tmp_box.area() );
    if( isleaf )
        if( data.leaf_depth.size() <= (unsigned)depth ) data.leaf_depth.resize( depth + 1, 0 );
        ++data.leaf_depth[depth];
        int count;
        rval = inst->get_number_entities_by_handle( set, count );
        count_out = count;
        data.leaf_ent.accum( count_out );
    else
        for( int i = 0; i < 2; ++i )
            CartVect dims;
            rval = recursive_stats( tool, inst, children[i], depth + 1, data, counts[i], dims );
            double this_measure, chld_measure;
            int this_dim = measure( dimensions_out, this_measure );
            int chld_dim = measure( dims, chld_measure );
            double ratio;
            if( chld_dim < this_dim )
                ratio = 0;
            else
                ratio = chld_measure / this_measure;
            data.volume.accum( ratio );
        count_out = counts[0] + counts[1];
        data.entities.accum( (double)counts[0] / count_out );
        data.entities.accum( (double)counts[1] / count_out );
    return MB_SUCCESS;
Remove obb tree root from the Oriented Box Tree Tool data structure (createdTrees)
Definition at line 480 of file OrientedBoxTreeTool.cpp.
References createdTrees, MB_ENTITY_NOT_FOUND, and MB_SUCCESS.
Referenced by moab::GeomTopoTool::remove_root().
    std::vector< EntityHandle >::iterator i = find( createdTrees.begin(), createdTrees.end(), root );
    if( i != createdTrees.end() )
        createdTrees.erase( i );
        return MB_SUCCESS;
    else
        return MB_ENTITY_NOT_FOUND;
ErrorCode moab::OrientedBoxTreeTool::sphere_intersect_triangles ( const double *  center,
double  radius,
TrvStats accum = 0
Find facets intersected by a spherical volume.
Parameters:
centerSphere center
radiusSphere radius
tree_rootRoot of OBB tree
facets_outList of triangles intersecting sphere
sets_outIf not null, sets owning facets are appended to this list in an order corresponding to the entries in facets_out.
Definition at line 570 of file OrientedBoxTreeTool.cpp.
References box(), center(), children, moab::Range::clear(), moab::OrientedBox::closest_location_in_box(), moab::GeomUtil::closest_location_on_tri(), moab::Range::empty(), moab::OrientedBoxTreeTool::TrvStats::end_traversal(), ErrorCode, moab::Range::front(), moab::Interface::get_child_meshsets(), moab::Interface::get_connectivity(), moab::Interface::get_coords(), moab::Interface::get_entities_by_handle(), moab::Interface::get_entities_by_type(), get_moab_instance(), moab::OrientedBoxTreeTool::TrvStats::increment(), moab::OrientedBoxTreeTool::TrvStats::increment_leaf(), instance, MB_SUCCESS, MBENTITYSET, MBTRI, radius, t, and moab::TYPE_FROM_HANDLE().
Referenced by get_close_tris().
    const double radsqr = radius * radius;
    OrientedBox b;
    ErrorCode rval;
    Range sets;
    const CartVect center( center_v );
    CartVect closest, coords[3];
    const EntityHandle* conn;
    int num_conn;
    Range tris;
    Range::const_iterator t;
#else
    std::vector< EntityHandle >::const_iterator t;
#endif
    std::vector< OBBTreeSITFrame > stack;
    stack.reserve( 30 );
    stack.push_back( OBBTreeSITFrame( tree_root, 0, 0 ) );
    int max_depth = -1;
        EntityHandle surf = stack.back().surf;
        stack.pop_back();
        if( accum )
        if( !surf && sets_out )
            rval = get_moab_instance()->get_entities_by_type( node, MBENTITYSET, sets );
            if( !sets.empty() ) surf = sets.front();
            sets.clear();
        // check if sphere intersects box
        rval = box( node, b );
        b.closest_location_in_box( center, closest );
        closest -= center;
        if( ( closest % closest ) > radsqr ) continue;
        // push child boxes on stack
        children.clear();
            assert( children.size() == 2 );
            stack.push_back( OBBTreeSITFrame( children[0], surf, current_depth + 1 ) );
            stack.push_back( OBBTreeSITFrame( children[1], surf, current_depth + 1 ) );
            continue;
        if( accum )
        // if leaf, intersect sphere with triangles
        rval = get_moab_instance()->get_entities_by_type( node, MBTRI, tris );
#else
        rval = get_moab_instance()->get_entities_by_handle( node, tris );
#endif
        t = tris.begin();
#else
        t    = tris.lower_bound( MBTRI );
#endif
        for( t = tris.begin(); t != tris.end(); ++t )
            if( TYPE_FROM_HANDLE( *t ) != MBTRI ) break;
#elif !defined( MB_OBB_USE_TYPE_QUERIES )
#endif
            rval = get_moab_instance()->get_connectivity( *t, conn, num_conn, true );
            if( num_conn != 3 ) continue;
            rval = get_moab_instance()->get_coords( conn, num_conn, coords[0].array() );
            GeomUtil::closest_location_on_tri( center, coords, closest );
            closest -= center;
            if( ( closest % closest ) <= radsqr &&
                std::find( facets_out.begin(), facets_out.end(), *t ) == facets_out.end() )
                if( sets_out ) sets_out->push_back( surf );
    if( accum )
    return MB_SUCCESS;
ErrorCode moab::OrientedBoxTreeTool::stats ( EntityHandle  tree_root_set,
Print misc. stats. describing tree
Definition at line 1927 of file OrientedBoxTreeTool.cpp.
References moab::StatData::area, moab::StatData::count, moab::StatData::entities, ErrorCode, moab::StatData::Ratio::hist, instance, moab::StatData::leaf_depth, moab::StatData::leaf_ent, moab::StatData::Ratio::max, moab::StatData::Stat< T >::max, MB_SUCCESS, moab::StatData::Ratio::min, moab::StatData::Stat< T >::min, moab::StatData::radius, recursive_stats(), moab::StatData::Ratio::sqr, moab::StatData::Stat< T >::sqr, moab::std_dev(), moab::StatData::Ratio::sum, moab::StatData::Stat< T >::sum, moab::StatData::vol, moab::StatData::volume, WE, and WW.
Referenced by obbstat_write(), and moab::SmoothFace::SmoothFace().
    StatData d;
    ErrorCode rval;
    unsigned total_entities, i;
    CartVect total_dim;
    rval = recursive_stats( this, instance, set, 0, d, total_entities, total_dim );
    unsigned tree_height    = d.leaf_depth.size();
    unsigned min_leaf_depth = tree_height, num_leaves = 0;
    unsigned max_leaf_per_depth = 0;
    double sum_leaf_depth = 0, sqr_leaf_depth = 0;
    for( i = 0; i < d.leaf_depth.size(); ++i )
        unsigned val = d.leaf_depth[i];
        num_leaves += val;
        sum_leaf_depth += (double)val * i;
        sqr_leaf_depth += (double)val * i * i;
        if( val && i < min_leaf_depth ) min_leaf_depth = i;
        if( max_leaf_per_depth < val ) max_leaf_per_depth = val;
    unsigned num_non_leaf = d.count - num_leaves;
    double rv = total_dim[0] * total_dim[1] * total_dim[2];
    s << "entities in tree:  " << total_entities << std::endl
      << "root volume:       " << rv << std::endl
      << "total node volume: " << d.vol.sum << std::endl
      << "total/root volume: " << d.vol.sum / rv << std::endl
      << "tree height:       " << tree_height << std::endl
      << "node count:        " << d.count << std::endl
      << "leaf count:        " << num_leaves << std::endl
      << std::endl;
    double avg_leaf_depth = sum_leaf_depth / num_leaves;
    double rms_leaf_depth = sqrt( sqr_leaf_depth / num_leaves );
    double std_leaf_depth = std_dev( sqr_leaf_depth, sum_leaf_depth, num_leaves );
    double avg_leaf_ent = d.leaf_ent.sum / num_leaves;
    double rms_leaf_ent = sqrt( d.leaf_ent.sqr / num_leaves );
    double std_leaf_ent = std_dev( d.leaf_ent.sqr, d.leaf_ent.sum, num_leaves );
    unsigned num_child = 2 * num_non_leaf;
    double avg_vol_ratio = d.volume.sum / num_child;
    double rms_vol_ratio = sqrt( d.volume.sqr / num_child );
    double std_vol_ratio = std_dev( d.volume.sqr, d.volume.sum, num_child );
    double avg_ent_ratio = d.entities.sum / num_child;
    double rms_ent_ratio = sqrt( d.entities.sqr / num_child );
    double std_ent_ratio = std_dev( d.entities.sqr, d.entities.sum, num_child );
    double avg_rad_ratio = d.radius.sum / d.count;
    double rms_rad_ratio = sqrt( d.radius.sqr / d.count );
    double std_rad_ratio = std_dev( d.radius.sqr, d.radius.sum, d.count );
    double avg_vol = d.vol.sum / d.count;
    double rms_vol = sqrt( d.vol.sqr / d.count );
    double std_vol = std_dev( d.vol.sqr, d.vol.sum, d.count );
    double avg_area = d.area.sum / d.count;
    double rms_area = sqrt( d.area.sqr / d.count );
    double std_area = std_dev( d.area.sqr, d.area.sum, d.count );
    int prec = s.precision();
    s << "                   " WW "Minimum" WW "Average" WW "RMS" WW "Maximum" WW "Std.Dev." << std::endl;
    s << std::setprecision( 1 )
      << "Leaf Depth         " WW min_leaf_depth WW avg_leaf_depth WW rms_leaf_depth WW d.leaf_depth.size() -
             1 WW std_leaf_depth
      << std::endl;
    s << std::setprecision( 0 )
      << "Entities/Leaf      " WW d.leaf_ent.min WW avg_leaf_ent WW rms_leaf_ent WW d.leaf_ent.max WW std_leaf_ent
      << std::endl;
    s << std::setprecision( 3 )
      << "Child Volume Ratio " WW d.volume.min WW avg_vol_ratio WW rms_vol_ratio WW d.volume.max WW std_vol_ratio
      << std::endl;
      << "Child Entity Ratio " WW d.entities.min WW avg_ent_ratio WW rms_ent_ratio WW d.entities.max WW std_ent_ratio
      << std::endl;
      << "Box Radius Ratio   " WW d.radius.min WW avg_rad_ratio WW rms_rad_ratio WW d.radius.max WW std_rad_ratio
      << std::endl;
    s << std::setprecision( 0 ) << "Box volume         " WE d.vol.min WE avg_vol WE rms_vol WE d.vol.max WE std_vol
      << std::endl;
    s << std::setprecision( 0 ) << "Largest side area  " WE d.area.min WE avg_area WE rms_area WE d.area.max WE std_area
      << std::endl;
    s << std::setprecision( prec ) << std::endl;
    s << "Leaf Depth Histogram (Root depth is 0)" << std::endl;
    double f = 60.0 / max_leaf_per_depth;
    for( i = min_leaf_depth; i < d.leaf_depth.size(); ++i )
        s << std::setw( 2 ) << i << " " << std::setw( 5 ) << d.leaf_depth[i] << " |" << std::setfill( '*' )
          << std::setw( (int)floor( f * d.leaf_depth[i] + 0.5 ) ) << "" << std::setfill( ' ' ) << std::endl;
    s << std::endl;
    s << "Child/Parent Volume Ratio Histogram" << std::endl;
    f = 60.0 / *( std::max_element( d.volume.hist, d.volume.hist + 10 ) );
    for( i = 0; i < 10u; ++i )
        s << "0." << i << " " << std::setw( 5 ) << d.volume.hist[i] << " |" << std::setfill( '*' )
          << std::setw( (int)floor( f * d.volume.hist[i] + 0.5 ) ) << "" << std::setfill( ' ' ) << std::endl;
    s << std::endl;
    s << "Child/Parent Entity Count Ratio Histogram" << std::endl;
    f = 60.0 / *( std::max_element( d.entities.hist, d.entities.hist + 10 ) );
        s << "0." << i << " " << std::setw( 5 ) << d.entities.hist[i] << " |" << std::setfill( '*' )
          << std::setw( (int)floor( f * d.entities.hist[i] + 0.5 ) ) << "" << std::setfill( ' ' ) << std::endl;
    s << std::endl;
    s << "Inner/Outer Radius Ratio Histogram (~0.70 for cube)" << std::endl;
    // max radius ratio for a box is about 0.7071.  Move any boxes
    // in the .7 bucket into .6 and print .0 to .6.
    d.radius.hist[6] += d.radius.hist[7];
    f = 60.0 / *( std::max_element( d.entities.hist, d.entities.hist + 7 ) );
    for( i = 0; i < 7u; ++i )
    s << std::endl;
    return MB_SUCCESS;
ErrorCode moab::OrientedBoxTreeTool::stats ( EntityHandle  set,
unsigned &  entities_in_tree,
double &  root_volume,
double &  tot_node_volume,
double &  tot_to_root_volume,
unsigned &  tree_height,
unsigned &  node_count,
unsigned &  num_leaves
Get summary stats. describing tree
Parameters:
setRoot of tree for which data is requested
total_entitiesEntities in tree
root_volumeTotal volume of root box
tot_node_volumeTotal volume in all nodes
tot_to_root_volumeRatio of total / root volume
tree_heightMaximum height of tree, from root to leaf
node_countNumber of nodes in tree
num_leavesNumber of leaf nodes in tree
Definition at line 1888 of file OrientedBoxTreeTool.cpp.
References moab::StatData::count, ErrorCode, instance, moab::StatData::leaf_depth, MB_SUCCESS, recursive_stats(), moab::StatData::Stat< T >::sum, and moab::StatData::vol.
    StatData d;
    ErrorCode rval;
    unsigned i;
    CartVect total_dim;
    unsigned min_leaf_depth     = tree_height;
    num_leaves                  = 0;
    // double sum_leaf_depth = 0, sqr_leaf_depth = 0;
        num_leaves += val;
        // sum_leaf_depth += (double)val*i;
        // sqr_leaf_depth += (double)val*i*i;
    tot_node_volume    = d.vol.sum;
    tot_to_root_volume = d.vol.sum / rv;
    node_count         = d.count;
    return MB_SUCCESS;
Member Data Documentation
Definition at line 558 of file OrientedBoxTreeTool.hpp.
Referenced by ~OrientedBoxTreeTool().
List of all members.
