moab::OrientedBox Class Reference
Oriented bounding box. More...
#include <OrientedBox.hpp>
+ Collaboration diagram for moab::OrientedBox:
Classes
struct  CovarienceData
Public Member Functions
 OrientedBox ()
 OrientedBox (const Matrix3 &axes_mat, const CartVect &center)
 OrientedBox (const CartVect axes_in[3], const CartVect &center)
double inner_radius () const
 radius of inscribed sphere
double outer_radius () const
 radius of circumscribed sphere
double outer_radius_squared (const double reps) const
 square of (radius+at least epsilon) of circumsphere
double inner_radius_squared (const double reps) const
 square of (radius-epsilon) of inscribed sphere
double volume () const
 volume of box
CartVect dimensions () const
 number of dimensions for which box is not flat
double area () const
 largest side area
CartVect axis (int index) const
 get unit vector in direction of axis
CartVect scaled_axis (int index) const
 get vector in direction of axis, scaled to its true length
bool contained (const CartVect &point, double tolerance) const
bool intersect_ray (const CartVect &ray_start_point, const CartVect &ray_unit_direction, const double distance_tolerance, const double *nonnegatve_ray_len=0, const double *negative_ray_len=0) const
void closest_location_in_box (const CartVect &input_position, CartVect &output_position) const
 Find closest position on/within box to input position.
ErrorCode make_hex (EntityHandle &hex, Interface *instance)
 Construct a hexahedral element with the same shape as this box.
Static Public Member Functions
static ErrorCode tag_handle (Tag &handle_out, Interface *instance, const char *name)
 get tag handle for storing oriented box
static ErrorCode compute_from_vertices (OrientedBox &result, Interface *instance, const Range &vertices)
 Calculate an oriented box from a set of vertices.
static ErrorCode compute_from_2d_cells (OrientedBox &result, Interface *instance, const Range &elements)
 Calculate an oriented box from a set of 2D elements.
static ErrorCode covariance_data_from_tris (CovarienceData &result, Interface *moab_instance, const Range &elements)
static ErrorCode compute_from_covariance_data (OrientedBox &result, Interface *moab_instance, const CovarienceData *orient_array, unsigned orient_array_length, const Range &vertices)
static ErrorCode compute_from_covariance_data (OrientedBox &result, Interface *moab_instance, CovarienceData &orientation_data, const Range &vertices)
Public Attributes
CartVect center
 Box center.
Matrix3 axes
 Box axes, unit vectors sorted by extent of box along axis.
CartVect length
 distance from center to plane along each axis
double radius
 outer radius (1/2 diagonal length) of box
Private Member Functions
void order_axes_by_length (double ax1_len, double ax2_len, double ax3_len)
 orders the box axes by the given lengths for each axis
Detailed Description
Definition at line 40 of file OrientedBox.hpp.
Definition at line 57 of file OrientedBox.hpp.
Referenced by compute_from_covariance_data().
: radius( 0.0 ) {}
moab::OrientedBox::OrientedBox ( const Matrix3 axes_mat,
const CartVect center
Definition at line 129 of file OrientedBox.cpp.
References axes, moab::Matrix3::col(), moab::CartVect::length(), and order_axes_by_length().
        : center( mid ), axes( axes_mat )
    order_axes_by_length( axes.col( 0 ).length(), axes.col( 1 ).length(), axes.col( 2 ).length() );
moab::OrientedBox::OrientedBox ( const CartVect  axes_in[3],
Definition at line 121 of file OrientedBox.cpp.
References axes, length, and order_axes_by_length().
        : center( mid )
    axes = Matrix3( axes_in[0], axes_in[1], axes_in[2], false );
    order_axes_by_length( axes_in[0].length(), axes_in[1].length(), axes_in[2].length() );
Member Function Documentation
double moab::OrientedBox::area ( ) const [inline]
largest side area
Definition at line 228 of file OrientedBox.hpp.
References axes, moab::Matrix3::col(), and length.
Referenced by moab::OrientedBoxTreeTool::recursive_stats().
#if MB_ORIENTED_BOX_UNIT_VECTORS
    return 4 * length[1] * length[2];
#else
    return 4 * ( axes.col( 1 ) * axes.col( 2 ) ).length();
#endif
CartVect moab::OrientedBox::axis ( int  index) const [inline]
Definition at line 237 of file OrientedBox.hpp.
References axes, and moab::Matrix3::col().
Referenced by moab::TreeNodePrinter::print_geometry(), moab::split_box(), and moab::split_sets().
    return axes.col( index );
void moab::OrientedBox::closest_location_in_box ( const CartVect input_position,
CartVect output_position
) const
Find the closest position in the solid box to the input position. If the input position is on or within the box, then the output position will be the same as the input position. If the input position is outside the box, the outside position will be the closest point on the box boundary to the input position.
Definition at line 658 of file OrientedBox.cpp.
References axes, center, moab::Matrix3::col(), and length.
Referenced by moab::OrientedBoxTreeTool::closest_to_location(), and moab::OrientedBoxTreeTool::sphere_intersect_triangles().
    // get coordinates on box axes
    const CartVect from_center = input_position - center;
    CartVect local( from_center % axes.col( 0 ), from_center % axes.col( 1 ), from_center % axes.col( 2 ) );
    for( int i = 0; i < 3; ++i )
        if( local[i] < -length[i] )
            local[i] = -length[i];
        else if( local[i] > length[i] )
            local[i] = length[i];
#else
    CartVect local( ( from_center % axes.col( 0 ) ) / ( axes.col( 0 ) % axes.col( 0 ) ),
                    ( from_center % axes.col( 1 ) ) / ( axes.col( 1 ) % axes.col( 1 ) ),
                    ( from_center % axes.col( 2 ) ) / ( axes.col( 2 ) % axes.col( 2 ) ) );
        if( local[i] < -1.0 )
            local[i] = -1.0;
        else if( local[i] > 1.0 )
            local[i] = 1.0;
#endif
    output_position = center + local[0] * axes.col( 0 ) + local[1] * axes.col( 1 ) + local[2] * axes.col( 2 );
ErrorCode moab::OrientedBox::compute_from_2d_cells ( OrientedBox result,
Interface instance,
const Range elements
) [static]
Definition at line 311 of file OrientedBox.cpp.
References compute_from_covariance_data(), covariance_data_from_tris(), ErrorCode, moab::Interface::get_adjacencies(), MB_SUCCESS, and moab::Interface::UNION.
Referenced by moab::OrientedBoxTreeTool::build_tree().
    // Get orientation data from elements
    CovarienceData data;
    ErrorCode rval = covariance_data_from_tris( data, instance, elements );
    if( MB_SUCCESS != rval ) return rval;
    // get vertices from elements
    Range points;
    rval = instance->get_adjacencies( elements, 0, false, points, Interface::UNION );
    // Calculate box given points and orientation data
    return compute_from_covariance_data( result, instance, data, points );
ErrorCode moab::OrientedBox::compute_from_covariance_data ( OrientedBox result,
Interface moab_instance,
const CovarienceData orient_array,
const Range vertices
) [static]
Calculate an OrientedBox given an array of CovarienceData and the list of vertices the box is to bound.
Definition at line 372 of file OrientedBox.cpp.
References moab::OrientedBox::CovarienceData::area, moab::OrientedBox::CovarienceData::center, and moab::OrientedBox::CovarienceData::matrix.
Referenced by moab::OrientedBoxTreeTool::build_sets(), and compute_from_2d_cells().
    // Sum input CovarienceData structures
    CovarienceData data_sum( Matrix3( 0.0 ), CartVect( 0.0 ), 0.0 );
    for( const CovarienceData* const end = data + data_length; data != end; ++data )
        data_sum.matrix += data->matrix;
        data_sum.center += data->center;
        data_sum.area += data->area;
    // Compute box from sum of structs
    return compute_from_covariance_data( result, moab_instance, data_sum, vertices );
CovarienceData orientation_data,
) [static]
Calculate an OrientedBox given a CovarienceData struct and the list of points the box is to bound.
Definition at line 327 of file OrientedBox.cpp.
References moab::OrientedBox::CovarienceData::area, axes, moab::box_from_axes(), center, moab::OrientedBox::CovarienceData::center, moab::Matrix3::eigen_decomposition(), moab::OrientedBox::CovarienceData::matrix, MB_SUCCESS, OrientedBox(), and moab::outer_product().
    if( data.area <= 0.0 )
        Matrix3 empty_axes( 0.0 );
        result = OrientedBox( empty_axes, CartVect( 0. ) );
        return MB_SUCCESS;
    // get center from sum
    result.center = data.center / data.area;
    // get covariance matrix from moments
    data.matrix /= 12 * data.area;
    data.matrix -= outer_product( result.center, result.center );
    // get axes (Eigenvectors) from covariance matrix
    CartVect lambda;
    data.matrix.eigen_decomposition( lambda, result.axes );
    // We now have only the axes.  Calculate proper center
    // and extents for enclosed points.
    return box_from_axes( result, instance, vertices );
ErrorCode moab::OrientedBox::compute_from_vertices ( OrientedBox result,
Interface instance,
) [static]
Definition at line 231 of file OrientedBox.cpp.
References moab::CartVect::array(), axes, moab::box_from_axes(), center, moab::Matrix3::eigen_decomposition(), ErrorCode, moab::Interface::get_coords(), moab::Range::lower_bound(), MB_SUCCESS, MBVERTEX, moab::outer_product(), and moab::Range::upper_bound().
    const Range::iterator begin = vertices.lower_bound( MBVERTEX );
    const Range::iterator end   = vertices.upper_bound( MBVERTEX );
    size_t count                = 0;
    // compute mean
    CartVect v;
    result.center = CartVect( 0, 0, 0 );
    for( Range::iterator i = begin; i != end; ++i )
        ErrorCode rval = instance->get_coords( &*i, 1, v.array() );
        result.center += v;
        ++count;
    result.center /= count;
    // compute covariance matrix
    Matrix3 a( 0.0 );
        v -= result.center;
        a += outer_product( v, v );
    a /= count;
    // Get axes (Eigenvectors) from covariance matrix
    CartVect lambda;
    a.eigen_decomposition( lambda, result.axes );
    // Calculate center and extents of box given orientation defined by axes
bool moab::OrientedBox::contained ( const CartVect point,
double  tolerance
) const
Test if point is contained in box
Definition at line 355 of file OrientedBox.cpp.
References axes, center, moab::Matrix3::col(), length, and moab::CartVect::length().
Referenced by TriCounter::visit().
    CartVect from_center = point - center;
    return fabs( from_center % axes.col( 0 ) ) - length[0] <= tol &&
           fabs( from_center % axes.col( 1 ) ) - length[1] <= tol &&
           fabs( from_center % axes.col( 2 ) ) - length[2] <= tol;
#else
        double length = axes.col( i ).length();
        if( fabs( from_center % axes.col( i ) ) - length * length > length * tol ) return false;
    return true;
#endif
ErrorCode moab::OrientedBox::covariance_data_from_tris ( CovarienceData result,
) [static]
Calculate a CovarienceData struct from a list of triangles
Definition at line 269 of file OrientedBox.cpp.
References moab::OrientedBox::CovarienceData::area, moab::OrientedBox::CovarienceData::center, ErrorCode, moab::GeomUtil::first(), moab::Interface::get_connectivity(), moab::Interface::get_coords(), length, moab::Range::lower_bound(), moab::OrientedBox::CovarienceData::matrix, MB_SUCCESS, moab::outer_product(), and moab::CN::TypeDimensionMap.
Referenced by compute_from_2d_cells(), and moab::OrientedBoxTreeTool::join_trees().
    ErrorCode rval;
    const Range::iterator begin = elements.lower_bound( CN::TypeDimensionMap[2].first );
    const Range::iterator end   = elements.lower_bound( CN::TypeDimensionMap[3].first );
    // compute mean and moments
    result.matrix = Matrix3( 0.0 );
    result.center = CartVect( 0.0 );
    result.area   = 0.0;
        const EntityHandle* conn = NULL;
        int conn_len             = 0;
        rval                     = instance->get_connectivity( *i, conn, conn_len );
        // for each triangle in the 2-D cell
        for( int j = 2; j < conn_len; ++j )
            EntityHandle vertices[3] = { conn[0], conn[j - 1], conn[j] };
            CartVect coords[3];
            rval = instance->get_coords( vertices, 3, coords[0].array() );
            // edge vectors
            const CartVect edge0    = coords[1] - coords[0];
            const CartVect edge1    = coords[2] - coords[0];
            const CartVect centroid = ( coords[0] + coords[1] + coords[2] ) / 3;
            const double tri_area2  = ( edge0 * edge1 ).length();
            result.area += tri_area2;
            result.center += tri_area2 * centroid;
            result.matrix +=
                tri_area2 * ( 9 * outer_product( centroid, centroid ) + outer_product( coords[0], coords[0] ) +
                              outer_product( coords[1], coords[1] ) + outer_product( coords[2], coords[2] ) );
        }  // for each triangle
    }      // for each element
    return MB_SUCCESS;
Definition at line 219 of file OrientedBox.hpp.
References axes, moab::Matrix3::col(), length, and moab::CartVect::length().
Referenced by moab::TreeNodePrinter::print_geometry(), and moab::OrientedBoxTreeTool::recursive_stats().
    return 2.0 * length;
#else
    return 2.0 * CartVect( axes.col( 0 ).length(), axes.col( 1 ).length(), axes.col( 2 ).length() );
#endif
double moab::OrientedBox::inner_radius ( ) const [inline]
Definition at line 163 of file OrientedBox.hpp.
    return length[0];
#else
    return axes.col( 0 ).length();
#endif
double moab::OrientedBox::inner_radius_squared ( const double  reps) const [inline]
Definition at line 199 of file OrientedBox.hpp.
Referenced by intersect_ray().
    return ( length[0] - reps ) * ( length[0] - reps );
#else
    CartVect tmp = axes.col( 0 );
    tmp -= CartVect( reps, reps, reps );
    return ( tmp % tmp );
#endif
bool moab::OrientedBox::intersect_ray ( const CartVect ray_start_point,
const CartVect ray_unit_direction,
const double *  nonnegatve_ray_len = 0,
const double *  negative_ray_len = 0
) const
Test for intersection of a ray (or line segment) with this box. Ray length limits are used to optimize Monte Carlo particle tracking.
Parameters:
ray_start_pointThe base point of the ray
ray_unit_directionThe direction of the ray (must be unit length)
distance_toleranceTolerance to use in intersection checks
nonnegative_ray_lenOptional length of ray in forward direction
negative_ray_lenOptional length of ray in reverse direction
Definition at line 498 of file OrientedBox.cpp.
References axes, center, moab::check_ray_limits(), inner_radius_squared(), length, outer_radius_squared(), and moab::Matrix3::transpose().
Referenced by moab::RayIntersector::visit(), and moab::RayIntersectSets::visit().
    // test distance from box center to line
    const CartVect cx       = center - ray_origin;
    const double dist_s     = cx % ray_direction;
    const double dist_sq    = cx % cx - ( dist_s * dist_s );
    const double max_diagsq = outer_radius_squared( reps );
    // For the largest sphere, no intersections exist if discriminant is negative.
    // Geometrically, if distance from box center to line is greater than the
    // longest diagonal, there is no intersection.
    // manipulate the discriminant: 0 > dist_s*dist_s - cx%cx + max_diagsq
    if( dist_sq > max_diagsq ) return false;
    // If the closest possible intersection must be closer than nonneg_ray_len. Be
    // careful with absolute value, squaring distances, and subtracting squared
    // distances.
    if( nonneg_ray_len )
        assert( 0 <= *nonneg_ray_len );
        double max_len;
        if( neg_ray_len )
            assert( 0 >= *neg_ray_len );
            max_len = std::max( *nonneg_ray_len, -( *neg_ray_len ) );
        else
            max_len = *nonneg_ray_len;
        const double temp = fabs( dist_s ) - max_len;
        if( 0.0 < temp && temp * temp > max_diagsq ) return false;
    // if smaller than shortest diagonal, we do hit
    if( dist_sq < inner_radius_squared( reps ) )
        // nonnegative direction
        if( dist_s >= 0.0 )
                if( *nonneg_ray_len > dist_s ) return true;
            else
                return true;
            // negative direction
        else
            if( neg_ray_len && *neg_ray_len < dist_s ) return true;
    // get transpose of axes
    Matrix3 B = axes.transpose();
    // transform ray to box coordintae system
    CartVect par_pos = B * ( ray_origin - center );
    CartVect par_dir = B * ray_direction;
    // Fast Rejection Test: Ray will not intersect if it is going away from the box.
    // This will not work for rays with neg_ray_len. length[0] is half of box width
    // along axes.col(0).
    const double half_x = length[0] + reps;
    const double half_y = length[1] + reps;
    const double half_z = length[2] + reps;
    if( !neg_ray_len )
        if( ( par_pos[0] > half_x && par_dir[0] >= 0 ) || ( par_pos[0] < -half_x && par_dir[0] <= 0 ) ) return false;
        if( ( par_pos[1] > half_y && par_dir[1] >= 0 ) || ( par_pos[1] < -half_y && par_dir[1] <= 0 ) ) return false;
        if( ( par_pos[2] > half_z && par_dir[2] >= 0 ) || ( par_pos[2] < -half_z && par_dir[2] <= 0 ) ) return false;
    // test if ray_origin is inside box
    if( par_pos[0] <= half_x && par_pos[0] >= -half_x && par_pos[1] <= half_y && par_pos[1] >= -half_y &&
        par_pos[2] <= half_z && par_pos[2] >= -half_z )
        return true;
    // test two xy plane
    if( fabs( par_dir[0] * ( half_z - par_pos[2] ) + par_dir[2] * par_pos[0] ) <=
            fabs( par_dir[2] * half_x ) &&  // test against x extents using z
        fabs( par_dir[1] * ( half_z - par_pos[2] ) + par_dir[2] * par_pos[1] ) <=
            fabs( par_dir[2] * half_y ) &&  // test against y extents using z
        check_ray_limits( par_pos[2], par_dir[2], half_z, nonneg_ray_len, neg_ray_len ) )
        return true;
    if( fabs( par_dir[0] * ( -half_z - par_pos[2] ) + par_dir[2] * par_pos[0] ) <= fabs( par_dir[2] * half_x ) &&
        fabs( par_dir[1] * ( -half_z - par_pos[2] ) + par_dir[2] * par_pos[1] ) <= fabs( par_dir[2] * half_y ) &&
        check_ray_limits( par_pos[2], par_dir[2], -half_z, nonneg_ray_len, neg_ray_len ) )
        return true;
    // test two xz plane
    if( fabs( par_dir[0] * ( half_y - par_pos[1] ) + par_dir[1] * par_pos[0] ) <= fabs( par_dir[1] * half_x ) &&
        fabs( par_dir[2] * ( half_y - par_pos[1] ) + par_dir[1] * par_pos[2] ) <= fabs( par_dir[1] * half_z ) &&
        check_ray_limits( par_pos[1], par_dir[1], half_y, nonneg_ray_len, neg_ray_len ) )
        return true;
    if( fabs( par_dir[0] * ( -half_y - par_pos[1] ) + par_dir[1] * par_pos[0] ) <= fabs( par_dir[1] * half_x ) &&
        fabs( par_dir[2] * ( -half_y - par_pos[1] ) + par_dir[1] * par_pos[2] ) <= fabs( par_dir[1] * half_z ) &&
        check_ray_limits( par_pos[1], par_dir[1], -half_y, nonneg_ray_len, neg_ray_len ) )
        return true;
    // test two yz plane
    if( fabs( par_dir[1] * ( half_x - par_pos[0] ) + par_dir[0] * par_pos[1] ) <= fabs( par_dir[0] * half_y ) &&
        fabs( par_dir[2] * ( half_x - par_pos[0] ) + par_dir[0] * par_pos[2] ) <= fabs( par_dir[0] * half_z ) &&
        check_ray_limits( par_pos[0], par_dir[0], half_x, nonneg_ray_len, neg_ray_len ) )
        return true;
    if( fabs( par_dir[1] * ( -half_x - par_pos[0] ) + par_dir[0] * par_pos[1] ) <= fabs( par_dir[0] * half_y ) &&
        fabs( par_dir[2] * ( -half_x - par_pos[0] ) + par_dir[0] * par_pos[2] ) <= fabs( par_dir[0] * half_z ) &&
        check_ray_limits( par_pos[0], par_dir[0], -half_x, nonneg_ray_len, neg_ray_len ) )
        return true;
    return false;
Definition at line 620 of file OrientedBox.cpp.
References moab::CartVect::array(), axes, center, moab::Matrix3::col(), moab::Interface::create_element(), moab::Interface::create_vertex(), moab::Interface::delete_entities(), ErrorCode, length, MB_SUCCESS, and MBHEX.
    ErrorCode rval;
    int signs[8][3] = { { -1, -1, -1 }, { 1, -1, -1 }, { 1, 1, -1 }, { -1, 1, -1 },
                        { -1, -1, 1 },  { 1, -1, 1 },  { 1, 1, 1 },  { -1, 1, 1 } };
    std::vector< EntityHandle > vertices;
    for( int i = 0; i < 8; ++i )
        CartVect coords( center );
        for( int j = 0; j < 3; ++j )
            coords += signs[i][j] * ( axes.col( j ) * length[j] );
#else
            coords += signs[i][j] * axes.col( j );
#endif
        EntityHandle handle;
        rval = instance->create_vertex( coords.array(), handle );
            instance->delete_entities( &vertices[0], vertices.size() );
            return rval;
        vertices.push_back( handle );
    rval = instance->create_element( MBHEX, &vertices[0], vertices.size(), hex );
        return rval;
    return MB_SUCCESS;
void moab::OrientedBox::order_axes_by_length ( double  ax1_len,
double  ax2_len,
double  ax3_len
) [private]
Definition at line 85 of file OrientedBox.cpp.
References axes, moab::Matrix3::colscale(), length, moab::CartVect::length(), radius, and moab::Matrix3::swapcol().
Referenced by OrientedBox().
    CartVect len( ax1_len, ax2_len, ax3_len );
    if( len[2] < len[1] )
        if( len[2] < len[0] )
            std::swap( len[0], len[2] );
            axes.swapcol( 0, 2 );
    else if( len[1] < len[0] )
        std::swap( len[0], len[1] );
        axes.swapcol( 0, 1 );
    if( len[1] > len[2] )
        std::swap( len[1], len[2] );
        axes.swapcol( 1, 2 );
    length = len;
    if( len[0] > 0.0 ) axes.colscale( 0, 1.0 / len[0] );
    if( len[1] > 0.0 ) axes.colscale( 1, 1.0 / len[1] );
    if( len[2] > 0.0 ) axes.colscale( 2, 1.0 / len[2] );
#endif
#if MB_ORIENTED_BOX_OUTER_RADIUS
    radius = len.length();
#endif
double moab::OrientedBox::outer_radius ( ) const [inline]
Definition at line 172 of file OrientedBox.hpp.
References axes, moab::Matrix3::col(), length, moab::CartVect::length(), and radius.
    return radius;
#elif MB_ORIENTED_BOX_UNIT_VECTORS
    return length.length();
#else
    return ( axes.col( 0 ) + axes.col( 1 ) + axes.col( 2 ) ).length();
#endif
double moab::OrientedBox::outer_radius_squared ( const double  reps) const [inline]
Definition at line 184 of file OrientedBox.hpp.
References axes, moab::Matrix3::col(), length, and radius.
    return ( radius + reps ) * ( radius + reps );
    CartVect tmp( length[0] + reps, length[1] + reps, length[2] + reps );
    return tmp % tmp;
#else
    CartVect half_diag = axes.col( 0 ) + axes.col( 1 ) + axes.col( 2 );
    half_diag += CartVect( reps, reps, reps );
    return half_diag % half_diag;
#endif
CartVect moab::OrientedBox::scaled_axis ( int  index) const [inline]
Definition at line 242 of file OrientedBox.hpp.
Referenced by moab::OrientedBoxTreeTool::box().
    return length[index] * axes.col( index );
#else
#endif
ErrorCode moab::OrientedBox::tag_handle ( Tag handle_out,
Interface instance,
const char *  name
) [static]
Get the handle for the tag with the specified name and check that the tag is appropriate for storing instances of OrientedBox. The resulting tag may be used to store instances of OrientedBox directly.
Parameters:
handle_outThe TagHandle, passed back to caller
nameThe tag name
createIf true, tag will be created if it does not exist
Definition at line 134 of file OrientedBox.cpp.
References MB_TAG_CREAT, MB_TAG_DENSE, MB_TYPE_DOUBLE, and moab::Interface::tag_get_handle().
Referenced by moab::OrientedBoxTreeTool::OrientedBoxTreeTool().
    // We're going to assume this when mapping the OrientedBox
    // to tag data, so assert it.
    const int rad_size = 1;
#else
    const int rad_size = 0;
#endif
    const int SIZE = rad_size + 15;
#else
    const int SIZE     = rad_size + 12;
#endif
    assert( sizeof( OrientedBox ) == SIZE * sizeof( double ) );
    return instance->tag_get_handle( name, SIZE, MB_TYPE_DOUBLE, handle_out, MB_TAG_DENSE | MB_TAG_CREAT );
double moab::OrientedBox::volume ( ) const [inline]
volume of box
Definition at line 210 of file OrientedBox.hpp.
Referenced by TriStats::leaf(), moab::OrientedBoxTreeTool::recursive_stats(), and TriStats::TriStats().
    return 8 * length[0] * length[1] * length[2];
#else
    return fabs( 8 * axes.col( 0 ) % ( axes.col( 1 ) * axes.col( 2 ) ) );
#endif
Member Data Documentation
Definition at line 54 of file OrientedBox.hpp.
Referenced by moab::box_from_axes(), order_axes_by_length(), outer_radius(), and outer_radius_squared().
List of all members.
