proj1.cpp File Reference
#include "moab/Core.hpp"
#include "moab/Interface.hpp"
#include <iostream>
#include <cmath>
#include "moab/IntxMesh/IntxUtils.hpp"
#include <cassert>
+ Include dependency graph for proj1.cpp:
Functions
int main (int argc, char **argv)
Variables
double radius = 1.
Function Documentation
int main ( int  argc,
char **  argv
Definition at line 19 of file proj1.cpp.
References moab::Interface::add_entities(), moab::Range::begin(), moab::Interface::coords_iterate(), moab::Interface::create_meshset(), moab::Interface::delete_entities(), moab::Range::empty(), moab::Range::end(), ErrorCode, moab::Interface::get_entities_by_dimension(), moab::Interface::get_entities_by_type_and_tag(), moab::CartVect::length(), moab::Interface::load_mesh(), mb, MB_SUCCESS, MBENTITYSET, MESHSET_SET, output, radius, moab::Range::size(), moab::Interface::tag_delete(), moab::Interface::tag_get_handle(), moab::Interface::UNION, moab::Interface::write_file(), and moab::Interface::write_mesh().
    bool delete_partition_sets = false;
    if( argc < 3 ) return 1;
    int index         = 1;
    char* input_mesh1 = argv[1];
    char* output      = argv[2];
    while( index < argc )
        if( !strcmp( argv[index], "-R" ) )  // this is for radius to project
            radius = atof( argv[++index] );
        if( !strcmp( argv[index], "-DS" ) )  // delete partition sets
            delete_partition_sets = true;
        if( !strcmp( argv[index], "-h" ) )
            std::cout << " usage: proj1 <input> <output> -R <value>  -DS (delete partition sets)\n";
            return 1;
        index++;
    Core moab;
    Interface& mb = moab;
    ErrorCode rval = mb.load_mesh( input_mesh1 );
    std::cout << " -R " << radius << " input: " << input_mesh1 << "  output: " << output << "\n";
    Range verts;
    rval = mb.get_entities_by_dimension( 0, 0, verts );
    if( MB_SUCCESS != rval ) return 1;
    double *x_ptr, *y_ptr, *z_ptr;
    int count;
    rval = mb.coords_iterate( verts.begin(), verts.end(), x_ptr, y_ptr, z_ptr, count );
    assert( count == (int)verts.size() );  // should end up with just one contiguous chunk of vertices
    for( int v = 0; v < count; v++ )
        // EntityHandle v = verts[v];
        CartVect pos( x_ptr[v], y_ptr[v], z_ptr[v] );
        pos      = pos / pos.length();
        pos      = radius * pos;
        x_ptr[v] = pos[0];
        y_ptr[v] = pos[1];
        z_ptr[v] = pos[2];
    Range edges;
    rval = mb.get_entities_by_dimension( 0, 1, edges );
    // write edges to a new set, and after that, write the set, delete the edges and the set
    EntityHandle sf1;
    rval = mb.create_meshset( MESHSET_SET, sf1 );
    rval = mb.add_entities( sf1, edges );
    rval = mb.write_mesh( "edgesOnly.h5m", &sf1, 1 );
    rval = mb.delete_entities( &sf1, 1 );
    mb.delete_entities( edges );
    if( delete_partition_sets )
        Tag par_tag;
        rval = mb.tag_get_handle( "PARALLEL_PARTITION", par_tag );
        if( MB_SUCCESS == rval )
            Range par_sets;
            rval =
                mb.get_entities_by_type_and_tag( 0, MBENTITYSET, &par_tag, NULL, 1, par_sets, moab::Interface::UNION );
            if( !par_sets.empty() ) mb.delete_entities( par_sets );
            mb.tag_delete( par_tag );
    mb.write_file( output );
    return 0;
Variable Documentation
double radius = 1.
Definition at line 17 of file proj1.cpp.
