MOAB: Mesh Oriented datABase
(version 5.4.1)
#include "moab/Core.hpp"
#include "moab_mpi.h"
#include "moab/ParallelComm.hpp"
#include "MBParallelConventions.h"
#include "moab/iMOAB.h"
#include "TestUtil.hpp"
#include "moab/CpuTimer.hpp"
#include "moab/ProgOptions.hpp"
#include <iostream>
#include <sstream>
#include "imoab_coupler_utils.hpp"
Defines | |
#define | ENABLE_ATMOCN_COUPLING |
#define | ENABLE_ATMLND_COUPLING |
Functions | |
int | main (int argc, char *argv[]) |
#define ENABLE_ATMLND_COUPLING |
Definition at line 42 of file imoab_coupler.cpp.
#define ENABLE_ATMOCN_COUPLING |
Definition at line 41 of file imoab_coupler.cpp.
int main | ( | int | argc, |
char * | argv[] | ||
we will use the element global id, which should uniquely identify the element
Definition at line 48 of file imoab_coupler.cpp.
References ProgOptions::addOpt(), atmFilename, CHECKIERR, cmpatm, context, create_group_and_comm(), create_joint_comm_group(), DENSE_DOUBLE, DENSE_INTEGER, endG1, endG2, fileWriteOptions(), groupTasks, ierr, iMOAB_AppID, iMOAB_DefineTagStorage(), iMOAB_DeregisterApplication(), iMOAB_Finalize(), iMOAB_GetDoubleTagStorage(), iMOAB_GetIntTagStorage(), iMOAB_GetMeshInfo(), iMOAB_Initialize(), iMOAB_RegisterApplication(), iMOAB_SetDoubleTagStorage(), iMOAB_WriteLocalMesh(), iMOAB_WriteMesh(), jgroup, MPI_COMM_WORLD, n, nghlay, numProcesses, ProgOptions::parseCommandLine(), POP_TIMER, PUSH_TIMER, rankInAtmComm, rankInGlobalComm, readopts(), setup_component_coupler_meshes(), startG1, and startG2.
{ int ierr; int rankInGlobalComm, numProcesses; MPI_Group jgroup; std::string readopts( "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION;PARALLEL_RESOLVE_SHARED_ENTS" ); std::string readoptsLnd( "PARALLEL=READ_PART;PARTITION=PARALLEL_PARTITION" ); // Timer data moab::CpuTimer timer; double timer_ops; std::string opName; int repartitioner_scheme = 0; #ifdef MOAB_HAVE_ZOLTAN repartitioner_scheme = 2; // use the graph partitioner in that caseS #endif MPI_Init( &argc, &argv ); MPI_Comm_rank( MPI_COMM_WORLD, &rankInGlobalComm ); MPI_Comm_size( MPI_COMM_WORLD, &numProcesses ); MPI_Comm_group( MPI_COMM_WORLD, &jgroup ); // all processes in jgroup std::string atmFilename = TestDir + "unittest/wholeATM_T.h5m"; // on a regular case, 5 ATM, 6 CPLATM (ATMX), 17 OCN , 18 CPLOCN (OCNX) ; // intx atm/ocn is not in e3sm yet, give a number // 6 * 100+ 18 = 618 : atmocnid // 9 LND, 10 CPLLND // 6 * 100 + 10 = 610 atmlndid: // cmpatm is for atm on atm pes // cmpocn is for ocean, on ocean pe // cplatm is for atm on coupler pes // cplocn is for ocean on coupelr pes // atmocnid is for intx atm / ocn on coupler pes // int rankInAtmComm = -1; int cmpatm = 5, cplatm = 6; // component ids are unique over all pes, and established in advance; #ifdef ENABLE_ATMOCN_COUPLING std::string ocnFilename = TestDir + "unittest/recMeshOcn.h5m"; std::string baseline = TestDir + "unittest/baseline1.txt"; int rankInOcnComm = -1; int cmpocn = 17, cplocn = 18, atmocnid = 618; // component ids are unique over all pes, and established in advance; #endif #ifdef ENABLE_ATMLND_COUPLING std::string lndFilename = TestDir + "unittest/wholeLnd.h5m"; int cpllnd = 10, cmplnd = 9, atmlndid = 610; // component ids are unique over all pes, and established in advance; #endif int rankInCouComm = -1; int nghlay = 0; // number of ghost layers for loading the file std::vector< int > groupTasks; int startG1 = 0, startG2 = 0, endG1 = numProcesses - 1, endG2 = numProcesses - 1, startG3 = startG1, endG3 = endG1; // Support launch of imoab_coupler test on any combo of 2*x processes int startG4 = startG1, endG4 = endG1; // these are for coupler layout int context_id = -1; // used now for freeing buffers // default: load atm on 2 proc, ocean on 2, land on 2; migrate to 2 procs, then compute intx // later, we need to compute weight matrix with tempestremap ProgOptions opts; opts.addOpt< std::string >( "atmosphere,t", "atm mesh filename (source)", &atmFilename ); #ifdef ENABLE_ATMOCN_COUPLING opts.addOpt< std::string >( "ocean,m", "ocean mesh filename (target)", &ocnFilename ); #endif #ifdef ENABLE_ATMLND_COUPLING opts.addOpt< std::string >( "land,l", "land mesh filename (target)", &lndFilename ); #endif opts.addOpt< int >( "startAtm,a", "start task for atmosphere layout", &startG1 ); opts.addOpt< int >( "endAtm,b", "end task for atmosphere layout", &endG1 ); #ifdef ENABLE_ATMOCN_COUPLING opts.addOpt< int >( "startOcn,c", "start task for ocean layout", &startG2 ); opts.addOpt< int >( "endOcn,d", "end task for ocean layout", &endG2 ); #endif #ifdef ENABLE_ATMLND_COUPLING opts.addOpt< int >( "startLnd,e", "start task for land layout", &startG3 ); opts.addOpt< int >( "endLnd,f", "end task for land layout", &endG3 ); #endif opts.addOpt< int >( "startCoupler,g", "start task for coupler layout", &startG4 ); opts.addOpt< int >( "endCoupler,j", "end task for coupler layout", &endG4 ); opts.addOpt< int >( "partitioning,p", "partitioning option for migration", &repartitioner_scheme ); int n = 1; // number of send/receive / project / send back cycles opts.addOpt< int >( "iterations,n", "number of iterations for coupler", &n ); bool no_regression_test = false; opts.addOpt< void >( "no_regression,r", "do not do regression test against baseline 1", &no_regression_test ); opts.parseCommandLine( argc, argv ); char fileWriteOptions[] = "PARALLEL=WRITE_PART"; if( !rankInGlobalComm ) { std::cout << " atm file: " << atmFilename << "\n on tasks : " << startG1 << ":" << endG1 << #ifdef ENABLE_ATMOCN_COUPLING "\n ocn file: " << ocnFilename << "\n on tasks : " << startG2 << ":" << endG2 << #endif #ifdef ENABLE_ATMLND_COUPLING "\n lnd file: " << lndFilename << "\n on tasks : " << startG3 << ":" << endG3 << #endif "\n partitioning (0 trivial, 1 graph, 2 geometry) " << repartitioner_scheme << "\n "; } // load files on 3 different communicators, groups // first groups has task 0, second group tasks 0 and 1 // coupler will be on joint tasks, will be on a third group (0 and 1, again) // first groups has task 0, second group tasks 0 and 1 // coupler will be on joint tasks, will be on a third group (0 and 1, again) MPI_Group atmPEGroup; MPI_Comm atmComm; ierr = create_group_and_comm( startG1, endG1, jgroup, &atmPEGroup, &atmComm ); CHECKIERR( ierr, "Cannot create atm MPI group and communicator " ) #ifdef ENABLE_ATMOCN_COUPLING MPI_Group ocnPEGroup; MPI_Comm ocnComm; ierr = create_group_and_comm( startG2, endG2, jgroup, &ocnPEGroup, &ocnComm ); CHECKIERR( ierr, "Cannot create ocn MPI group and communicator " ) #endif #ifdef ENABLE_ATMLND_COUPLING MPI_Group lndPEGroup; MPI_Comm lndComm; ierr = create_group_and_comm( startG3, endG3, jgroup, &lndPEGroup, &lndComm ); CHECKIERR( ierr, "Cannot create lnd MPI group and communicator " ) #endif // we will always have a coupler MPI_Group couPEGroup; MPI_Comm couComm; ierr = create_group_and_comm( startG4, endG4, jgroup, &couPEGroup, &couComm ); CHECKIERR( ierr, "Cannot create cpl MPI group and communicator " ) // atm_coupler MPI_Group joinAtmCouGroup; MPI_Comm atmCouComm; ierr = create_joint_comm_group( atmPEGroup, couPEGroup, &joinAtmCouGroup, &atmCouComm ); CHECKIERR( ierr, "Cannot create joint atm cou communicator" ) #ifdef ENABLE_ATMOCN_COUPLING // ocn_coupler MPI_Group joinOcnCouGroup; MPI_Comm ocnCouComm; ierr = create_joint_comm_group( ocnPEGroup, couPEGroup, &joinOcnCouGroup, &ocnCouComm ); CHECKIERR( ierr, "Cannot create joint ocn cou communicator" ) #endif #ifdef ENABLE_ATMLND_COUPLING // lnd_coupler MPI_Group joinLndCouGroup; MPI_Comm lndCouComm; ierr = create_joint_comm_group( lndPEGroup, couPEGroup, &joinLndCouGroup, &lndCouComm ); CHECKIERR( ierr, "Cannot create joint ocn cou communicator" ) #endif ierr = iMOAB_Initialize( argc, argv ); // not really needed anything from argc, argv, yet; maybe we should CHECKIERR( ierr, "Cannot initialize iMOAB" ) int cmpAtmAppID = -1; iMOAB_AppID cmpAtmPID = &cmpAtmAppID; // atm int cplAtmAppID = -1; // -1 means it is not initialized iMOAB_AppID cplAtmPID = &cplAtmAppID; // atm on coupler PEs #ifdef ENABLE_ATMOCN_COUPLING int cmpOcnAppID = -1; iMOAB_AppID cmpOcnPID = &cmpOcnAppID; // ocn int cplOcnAppID = -1, cplAtmOcnAppID = -1; // -1 means it is not initialized iMOAB_AppID cplOcnPID = &cplOcnAppID; // ocn on coupler PEs iMOAB_AppID cplAtmOcnPID = &cplAtmOcnAppID; // intx atm -ocn on coupler PEs #endif #ifdef ENABLE_ATMLND_COUPLING int cmpLndAppID = -1; iMOAB_AppID cmpLndPID = &cmpLndAppID; // lnd int cplLndAppID = -1, cplAtmLndAppID = -1; // -1 means it is not initialized iMOAB_AppID cplLndPID = &cplLndAppID; // land on coupler PEs iMOAB_AppID cplAtmLndPID = &cplAtmLndAppID; // intx atm - lnd on coupler PEs #endif if( couComm != MPI_COMM_NULL ) { MPI_Comm_rank( couComm, &rankInCouComm ); // Register all the applications on the coupler PEs ierr = iMOAB_RegisterApplication( "ATMX", &couComm, &cplatm, cplAtmPID ); // atm on coupler pes CHECKIERR( ierr, "Cannot register ATM over coupler PEs" ) #ifdef ENABLE_ATMOCN_COUPLING ierr = iMOAB_RegisterApplication( "OCNX", &couComm, &cplocn, cplOcnPID ); // ocn on coupler pes CHECKIERR( ierr, "Cannot register OCN over coupler PEs" ) #endif #ifdef ENABLE_ATMLND_COUPLING ierr = iMOAB_RegisterApplication( "LNDX", &couComm, &cpllnd, cplLndPID ); // lnd on coupler pes CHECKIERR( ierr, "Cannot register LND over coupler PEs" ) #endif } if( atmComm != MPI_COMM_NULL ) { MPI_Comm_rank( atmComm, &rankInAtmComm ); ierr = iMOAB_RegisterApplication( "ATM1", &atmComm, &cmpatm, cmpAtmPID ); CHECKIERR( ierr, "Cannot register ATM App" ) } #ifdef ENABLE_ATMOCN_COUPLING if( ocnComm != MPI_COMM_NULL ) { MPI_Comm_rank( ocnComm, &rankInOcnComm ); ierr = iMOAB_RegisterApplication( "OCN1", &ocnComm, &cmpocn, cmpOcnPID ); CHECKIERR( ierr, "Cannot register OCN App" ) } #endif // atm ierr = setup_component_coupler_meshes( cmpAtmPID, cmpatm, cplAtmPID, cplatm, &atmComm, &atmPEGroup, &couComm, &couPEGroup, &atmCouComm, atmFilename, readopts, nghlay, repartitioner_scheme ); CHECKIERR( ierr, "Cannot load and migrate atm mesh" ) #ifdef VERBOSE if( couComm != MPI_COMM_NULL && 1 == n ) { // write only for n==1 case char outputFileTgt3[] = "recvAtm.h5m"; ierr = iMOAB_WriteMesh( cplAtmPID, outputFileTgt3, fileWriteOptions, strlen( outputFileTgt3 ), strlen( fileWriteOptions ) ); CHECKIERR( ierr, "cannot write atm mesh after receiving" ) } #endif #ifdef GRAPH_INFO if( atmComm != MPI_COMM_NULL ) { int is_sender = 1; int context = -1; iMOAB_DumpCommGraph( cmpAtmPID, &context, &is_sender, "AtmMigS" ); } if( couComm != MPI_COMM_NULL ) { int is_sender = 0; int context = -1; iMOAB_DumpCommGraph( cplAtmPID, &context, &is_sender, "AtmMigR" ); } #endif MPI_Barrier( MPI_COMM_WORLD ); #ifdef ENABLE_ATMOCN_COUPLING // ocean ierr = setup_component_coupler_meshes( cmpOcnPID, cmpocn, cplOcnPID, cplocn, &ocnComm, &ocnPEGroup, &couComm, &couPEGroup, &ocnCouComm, ocnFilename, readopts, nghlay, repartitioner_scheme ); CHECKIERR( ierr, "Cannot load and migrate ocn mesh" ) MPI_Barrier( MPI_COMM_WORLD ); #ifdef VERBOSE if( couComm != MPI_COMM_NULL && 1 == n ) { // write only for n==1 case char outputFileTgt3[] = "recvOcn.h5m"; ierr = iMOAB_WriteMesh( cplOcnPID, outputFileTgt3, fileWriteOptions ); CHECKIERR( ierr, "cannot write ocn mesh after receiving" ) } #endif #endif // #ifdef ENABLE_ATMOCN_COUPLING #ifdef ENABLE_ATMLND_COUPLING // land if( lndComm != MPI_COMM_NULL ) { ierr = iMOAB_RegisterApplication( "LND1", &lndComm, &cmplnd, cmpLndPID ); CHECKIERR( ierr, "Cannot register LND App " ) } ierr = setup_component_coupler_meshes( cmpLndPID, cmplnd, cplLndPID, cpllnd, &lndComm, &lndPEGroup, &couComm, &couPEGroup, &lndCouComm, lndFilename, readoptsLnd, nghlay, repartitioner_scheme ); if( couComm != MPI_COMM_NULL && 1 == n ) { // write only for n==1 case char outputFileLnd[] = "recvLnd.h5m"; ierr = iMOAB_WriteMesh( cplLndPID, outputFileLnd, fileWriteOptions ); CHECKIERR( ierr, "cannot write lnd mesh after receiving" ) } #endif // #ifdef ENABLE_ATMLND_COUPLING MPI_Barrier( MPI_COMM_WORLD ); #ifdef ENABLE_ATMOCN_COUPLING if( couComm != MPI_COMM_NULL ) { // now compute intersection between OCNx and ATMx on coupler PEs ierr = iMOAB_RegisterApplication( "ATMOCN", &couComm, &atmocnid, cplAtmOcnPID ); CHECKIERR( ierr, "Cannot register ocn_atm intx over coupler pes " ) } #endif #ifdef ENABLE_ATMLND_COUPLING if( couComm != MPI_COMM_NULL ) { // now compute intersection between LNDx and ATMx on coupler PEs ierr = iMOAB_RegisterApplication( "ATMLND", &couComm, &atmlndid, cplAtmLndPID ); CHECKIERR( ierr, "Cannot register ocn_atm intx over coupler pes " ) } #endif int disc_orders[3] = { 4, 1, 1 }; const std::string weights_identifiers[2] = { "scalar", "scalar-pc" }; const std::string disc_methods[3] = { "cgll", "fv", "pcloud" }; const std::string dof_tag_names[3] = { "GLOBAL_DOFS", "GLOBAL_ID", "GLOBAL_ID" }; #ifdef ENABLE_ATMOCN_COUPLING if( couComm != MPI_COMM_NULL ) { PUSH_TIMER( "Compute ATM-OCN mesh intersection" ) ierr = iMOAB_ComputeMeshIntersectionOnSphere( cplAtmPID, cplOcnPID, cplAtmOcnPID ); // coverage mesh was computed here, for cplAtmPID, atm on coupler pes // basically, atm was redistributed according to target (ocean) partition, to "cover" the // ocean partitions check if intx valid, write some h5m intx file CHECKIERR( ierr, "cannot compute intersection" ) POP_TIMER( couComm, rankInCouComm ) #ifdef VERBOSE char prefix[] = "intx_atmocn"; ierr = iMOAB_WriteLocalMesh( cplAtmOcnPID, prefix, strlen( prefix ) ); CHECKIERR( ierr, "failed to write local intx mesh" ); #endif } if( atmCouComm != MPI_COMM_NULL ) { // the new graph will be for sending data from atm comp to coverage mesh; // it involves initial atm app; cmpAtmPID; also migrate atm mesh on coupler pes, cplAtmPID // results are in cplAtmOcnPID, intx mesh; remapper also has some info about coverage mesh // after this, the sending of tags from atm pes to coupler pes will use the new par comm // graph, that has more precise info about what to send for ocean cover ; every time, we // will // use the element global id, which should uniquely identify the element PUSH_TIMER( "Compute OCN coverage graph for ATM mesh" ) ierr = iMOAB_CoverageGraph( &atmCouComm, cmpAtmPID, cplAtmPID, cplAtmOcnPID, &cmpatm, &cplatm, &cplocn ); // it happens over joint communicator CHECKIERR( ierr, "cannot recompute direct coverage graph for ocean" ) POP_TIMER( atmCouComm, rankInAtmComm ) // hijack this rank } #endif #ifdef ENABLE_ATMLND_COUPLING if( couComm != MPI_COMM_NULL ) { PUSH_TIMER( "Compute ATM-LND mesh intersection" ) ierr = iMOAB_ComputePointDoFIntersection( cplAtmPID, cplLndPID, cplAtmLndPID ); CHECKIERR( ierr, "failed to compute point-cloud mapping" ); POP_TIMER( couComm, rankInCouComm ) } if( atmCouComm != MPI_COMM_NULL ) { // the new graph will be for sending data from atm comp to coverage mesh for land mesh; // it involves initial atm app; cmpAtmPID; also migrate atm mesh on coupler pes, cplAtmPID // results are in cplAtmLndPID, intx mesh; remapper also has some info about coverage mesh // after this, the sending of tags from atm pes to coupler pes will use the new par comm // graph, that has more precise info about what to send (specifically for land cover); every // time, /// we will use the element global id, which should uniquely identify the element PUSH_TIMER( "Compute LND coverage graph for ATM mesh" ) ierr = iMOAB_CoverageGraph( &atmCouComm, cmpAtmPID, cplAtmPID, cplAtmLndPID, &cmpatm, &cplatm, &cpllnd ); // it happens over joint communicator CHECKIERR( ierr, "cannot recompute direct coverage graph for land" ) POP_TIMER( atmCouComm, rankInAtmComm ) // hijack this rank } #endif MPI_Barrier( MPI_COMM_WORLD ); int fMonotoneTypeID = 0, fVolumetric = 0, fValidate = 1, fNoConserve = 0, fNoBubble = 1, fInverseDistanceMap = 0; #ifdef ENABLE_ATMOCN_COUPLING #ifdef VERBOSE if( couComm != MPI_COMM_NULL && 1 == n ) { // write only for n==1 case char serialWriteOptions[] = ""; // for writing in serial std::stringstream outf; outf << "intxAtmOcn_" << rankInCouComm << ".h5m"; std::string intxfile = outf.str(); // write in serial the intx file, for debugging ierr = iMOAB_WriteMesh( cplAtmOcnPID, intxfile.c_str(), serialWriteOptions ); CHECKIERR( ierr, "cannot write intx file result" ) } #endif if( couComm != MPI_COMM_NULL ) { PUSH_TIMER( "Compute the projection weights with TempestRemap" ) ierr = iMOAB_ComputeScalarProjectionWeights( cplAtmOcnPID, weights_identifiers[0].c_str(), disc_methods[0].c_str(), &disc_orders[0], disc_methods[1].c_str(), &disc_orders[1], &fNoBubble, &fMonotoneTypeID, &fVolumetric, &fInverseDistanceMap, &fNoConserve, &fValidate, dof_tag_names[0].c_str(), dof_tag_names[1].c_str() ); CHECKIERR( ierr, "cannot compute scalar projection weights" ) POP_TIMER( couComm, rankInCouComm ) // Let us now write the map file to disk and then read it back to test the I/O API in iMOAB #ifdef MOAB_HAVE_NETCDF { const std::string atmocn_map_file_name = "atm_ocn_map.nc"; ierr = iMOAB_WriteMappingWeightsToFile( cplAtmOcnPID, weights_identifiers[0].c_str(), atmocn_map_file_name.c_str() ); CHECKIERR( ierr, "failed to write map file to disk" ); const std::string intx_from_file_identifier = "map-from-file"; int dummyCpl = -1; int dummy_rowcol = -1; int dummyType = 0; ierr = iMOAB_LoadMappingWeightsFromFile( cplAtmOcnPID, &dummyCpl, &dummy_rowcol, &dummyType, intx_from_file_identifier.c_str(), atmocn_map_file_name.c_str() ); CHECKIERR( ierr, "failed to load map file from disk" ); } #endif } #endif MPI_Barrier( MPI_COMM_WORLD ); #ifdef ENABLE_ATMLND_COUPLING if( couComm != MPI_COMM_NULL ) { fValidate = 0; /* Compute the weights to preoject the solution from ATM component to LND compoenent */ PUSH_TIMER( "Compute ATM-LND remapping weights" ) ierr = iMOAB_ComputeScalarProjectionWeights( cplAtmLndPID, weights_identifiers[1].c_str(), disc_methods[0].c_str(), &disc_orders[0], disc_methods[2].c_str(), &disc_orders[2], &fNoBubble, &fMonotoneTypeID, &fVolumetric, &fInverseDistanceMap, &fNoConserve, &fValidate, dof_tag_names[0].c_str(), dof_tag_names[2].c_str() ); CHECKIERR( ierr, "failed to compute remapping projection weights for ATM-LND scalar " "non-conservative field" ); POP_TIMER( couComm, rankInCouComm ) // Let us now write the map file to disk and then read it back to test the I/O API in iMOAB // VSM: TODO: This does not work since the LND model is a point cloud and we do not initilize // data correctly in TempestOnlineMap::WriteParallelWeightsToFile routine. // { // const char* atmlnd_map_file_name = "atm_lnd_map.nc"; // ierr = iMOAB_WriteMappingWeightsToFile( cplAtmLndPID, weights_identifiers[1], atmlnd_map_file_name ); // CHECKIERR( ierr, "failed to write map file to disk" ); // const char* intx_from_file_identifier = "map-from-file"; // ierr = iMOAB_LoadMappingWeightsFromFile( cplAtmLndPID, intx_from_file_identifier, atmlnd_map_file_name, // NULL, NULL, NULL, // ); // CHECKIERR( ierr, "failed to load map file from disk" ); // } } #endif int tagIndex[2]; int tagTypes[2] = { DENSE_DOUBLE, DENSE_DOUBLE }; int atmCompNDoFs = disc_orders[0] * disc_orders[0], ocnCompNDoFs = 1 /*FV*/; const char* bottomFields = "a2oTbot:a2oUbot:a2oVbot"; const char* bottomProjectedFields = "a2oTbot_proj:a2oUbot_proj:a2oVbot_proj"; if( couComm != MPI_COMM_NULL ) { ierr = iMOAB_DefineTagStorage( cplAtmPID, bottomFields, &tagTypes[0], &atmCompNDoFs, &tagIndex[0] ); CHECKIERR( ierr, "failed to define the field tag a2oTbot" ); #ifdef ENABLE_ATMOCN_COUPLING ierr = iMOAB_DefineTagStorage( cplOcnPID, bottomProjectedFields, &tagTypes[1], &ocnCompNDoFs, &tagIndex[1] ); CHECKIERR( ierr, "failed to define the field tag a2oTbot_proj" ); #endif } // need to make sure that the coverage mesh (created during intx method) received the tag that // need to be projected to target so far, the coverage mesh has only the ids and global dofs; // need to change the migrate method to accommodate any GLL tag // now send a tag from original atmosphere (cmpAtmPID) towards migrated coverage mesh // (cplAtmPID), using the new coverage graph communicator // make the tag 0, to check we are actually sending needed data { if( cplAtmAppID >= 0 ) { int nverts[3], nelem[3], nblocks[3], nsbc[3], ndbc[3]; /* * Each process in the communicator will have access to a local mesh instance, which * will contain the original cells in the local partition and ghost entities. Number of * vertices, primary cells, visible blocks, number of sidesets and nodesets boundary * conditions will be returned in numProcesses 3 arrays, for local, ghost and total * numbers. */ ierr = iMOAB_GetMeshInfo( cplAtmPID, nverts, nelem, nblocks, nsbc, ndbc ); CHECKIERR( ierr, "failed to get num primary elems" ); int numAllElem = nelem[2]; std::vector< double > vals; int storLeng = atmCompNDoFs * numAllElem * 3; // 3 tags int eetype = 1; vals.resize( storLeng ); for( int k = 0; k < storLeng; k++ ) vals[k] = 0.; ierr = iMOAB_SetDoubleTagStorage( cplAtmPID, bottomFields, &storLeng, &eetype, &vals[0] ); CHECKIERR( ierr, "cannot make tag nul" ) // set the tag to 0 } } const char* concat_fieldname = "a2oTbot:a2oUbot:a2oVbot"; const char* concat_fieldnameT = "a2oTbot_proj:a2oUbot_proj:a2oVbot_proj"; // start a virtual loop for number of iterations for( int iters = 0; iters < n; iters++ ) { #ifdef ENABLE_ATMOCN_COUPLING PUSH_TIMER( "Send/receive data from atm component to coupler in ocn context" ) if( atmComm != MPI_COMM_NULL ) { // as always, use nonblocking sends // this is for projection to ocean: ierr = iMOAB_SendElementTag( cmpAtmPID, "a2oTbot:a2oUbot:a2oVbot", &atmCouComm, &cplocn ); CHECKIERR( ierr, "cannot send tag values" ) #ifdef GRAPH_INFO int is_sender = 1; int context = cplocn; iMOAB_DumpCommGraph( cmpAtmPID, &context, &is_sender, "AtmCovOcnS" ); #endif } if( couComm != MPI_COMM_NULL ) { // receive on atm on coupler pes, that was redistributed according to coverage ierr = iMOAB_ReceiveElementTag( cplAtmPID, "a2oTbot:a2oUbot:a2oVbot", &atmCouComm, &cplocn ); CHECKIERR( ierr, "cannot receive tag values" ) #ifdef GRAPH_INFO int is_sender = 0; int context = cplocn; // the same context, cplocn iMOAB_DumpCommGraph( cmpAtmPID, &context, &is_sender, "AtmCovOcnR" ); #endif } POP_TIMER( MPI_COMM_WORLD, rankInGlobalComm ) // we can now free the sender buffers if( atmComm != MPI_COMM_NULL ) { ierr = iMOAB_FreeSenderBuffers( cmpAtmPID, &cplocn ); // context is for ocean CHECKIERR( ierr, "cannot free buffers used to resend atm tag towards the coverage mesh" ) } #ifdef VERBOSE if( couComm != MPI_COMM_NULL && 1 == n ) { // write only for n==1 case char outputFileRecvd[] = "recvAtmCoupOcn.h5m"; ierr = iMOAB_WriteMesh( cplAtmPID, outputFileRecvd, fileWriteOptions ); CHECKIERR( ierr, "could not write recvAtmCoupOcn.h5m to disk" ) } #endif if( couComm != MPI_COMM_NULL ) { /* We have the remapping weights now. Let us apply the weights onto the tag we defined on the source mesh and get the projection on the target mesh */ PUSH_TIMER( "Apply Scalar projection weights" ) ierr = iMOAB_ApplyScalarProjectionWeights( cplAtmOcnPID, weights_identifiers[0].c_str(), concat_fieldname, concat_fieldnameT ); CHECKIERR( ierr, "failed to compute projection weight application" ); POP_TIMER( couComm, rankInCouComm ) if( 1 == n ) // write only for n==1 case { char outputFileTgt[] = "fOcnOnCpl.h5m"; ierr = iMOAB_WriteMesh( cplOcnPID, outputFileTgt, fileWriteOptions ); CHECKIERR( ierr, "could not write fOcnOnCpl.h5m to disk" ) } } // send the projected tag back to ocean pes, with send/receive tag if( ocnComm != MPI_COMM_NULL ) { int tagIndexIn2; ierr = iMOAB_DefineTagStorage( cmpOcnPID, bottomProjectedFields, &tagTypes[1], &ocnCompNDoFs, &tagIndexIn2 ); CHECKIERR( ierr, "failed to define the field tag for receiving back the tags " "a2oTbot_proj, a2oUbot_proj, a2oVbot_proj on ocn pes" ); } // send the tag to ocean pes, from ocean mesh on coupler pes // from couComm, using common joint comm ocn_coupler // as always, use nonblocking sends // original graph (context is -1_ if( couComm != MPI_COMM_NULL ) { // need to use ocean comp id for context context_id = cmpocn; // id for ocean on comp ierr = iMOAB_SendElementTag( cplOcnPID, "a2oTbot_proj:a2oUbot_proj:a2oVbot_proj", &ocnCouComm, &context_id ); CHECKIERR( ierr, "cannot send tag values back to ocean pes" ) } // receive on component 2, ocean if( ocnComm != MPI_COMM_NULL ) { context_id = cplocn; // id for ocean on coupler ierr = iMOAB_ReceiveElementTag( cmpOcnPID, "a2oTbot_proj:a2oUbot_proj:a2oVbot_proj", &ocnCouComm, &context_id ); CHECKIERR( ierr, "cannot receive tag values from ocean mesh on coupler pes" ) } MPI_Barrier( MPI_COMM_WORLD ); if( couComm != MPI_COMM_NULL ) { context_id = cmpocn; ierr = iMOAB_FreeSenderBuffers( cplOcnPID, &context_id ); CHECKIERR( ierr, "cannot free send/receive buffers for OCN context" ) } if( ocnComm != MPI_COMM_NULL && 1 == n ) // write only for n==1 case { char outputFileOcn[] = "OcnWithProj.h5m"; ierr = iMOAB_WriteMesh( cmpOcnPID, outputFileOcn, fileWriteOptions ); CHECKIERR( ierr, "could not write OcnWithProj.h5m to disk" ) // test results only for n == 1, for bottomTempProjectedField if( !no_regression_test ) { // the same as remap test // get temp field on ocean, from conservative, the global ids, and dump to the baseline file // first get GlobalIds from ocn, and fields: int nverts[3], nelem[3]; ierr = iMOAB_GetMeshInfo( cmpOcnPID, nverts, nelem, 0, 0, 0 ); CHECKIERR( ierr, "failed to get ocn mesh info" ); std::vector< int > gidElems; gidElems.resize( nelem[2] ); std::vector< double > tempElems; tempElems.resize( nelem[2] ); // get global id storage const std::string GidStr = "GLOBAL_ID"; // hard coded too int tag_type = DENSE_INTEGER, ncomp = 1, tagInd = 0; ierr = iMOAB_DefineTagStorage( cmpOcnPID, GidStr.c_str(), &tag_type, &ncomp, &tagInd ); CHECKIERR( ierr, "failed to define global id tag" ); int ent_type = 1; ierr = iMOAB_GetIntTagStorage( cmpOcnPID, GidStr.c_str(), &nelem[2], &ent_type, &gidElems[0] ); CHECKIERR( ierr, "failed to get global ids" ); ierr = iMOAB_GetDoubleTagStorage( cmpOcnPID, "a2oTbot_proj", &nelem[2], &ent_type, &tempElems[0] ); CHECKIERR( ierr, "failed to get temperature field" ); int err_code = 1; check_baseline_file( baseline, gidElems, tempElems, 1.e-9, err_code ); if( 0 == err_code ) std::cout << " passed baseline test atm2ocn on ocean task " << rankInOcnComm << "\n"; } } #endif #ifdef ENABLE_ATMLND_COUPLING // start land proj: PUSH_TIMER( "Send/receive data from component atm to coupler, in land context" ) if( atmComm != MPI_COMM_NULL ) { // as always, use nonblocking sends // this is for projection to land: ierr = iMOAB_SendElementTag( cmpAtmPID, "a2oTbot:a2oUbot:a2oVbot", &atmCouComm, &cpllnd ); CHECKIERR( ierr, "cannot send tag values" ) } if( couComm != MPI_COMM_NULL ) { // receive on atm on coupler pes, that was redistributed according to coverage, for land // context ierr = iMOAB_ReceiveElementTag( cplAtmPID, "a2oTbot:a2oUbot:a2oVbot", &atmCouComm, &cpllnd ); CHECKIERR( ierr, "cannot receive tag values" ) } POP_TIMER( MPI_COMM_WORLD, rankInGlobalComm ) // we can now free the sender buffers if( atmComm != MPI_COMM_NULL ) { ierr = iMOAB_FreeSenderBuffers( cmpAtmPID, &cpllnd ); CHECKIERR( ierr, "cannot free buffers used to resend atm tag towards the coverage mesh " "for land context" ) } #ifdef VERBOSE if( couComm != MPI_COMM_NULL && 1 == n ) { // write only for n==1 case char outputFileRecvd[] = "recvAtmCoupLnd.h5m"; ierr = iMOAB_WriteMesh( cplAtmPID, outputFileRecvd, fileWriteOptions ); CHECKIERR( ierr, "could not write recvAtmCoupLnd.h5m to disk" ) } #endif /* We have the remapping weights now. Let us apply the weights onto the tag we defined on the source mesh and get the projection on the target mesh */ if( couComm != MPI_COMM_NULL ) { PUSH_TIMER( "Apply Scalar projection weights for land" ) ierr = iMOAB_ApplyScalarProjectionWeights( cplAtmLndPID, weights_identifiers[1].c_str(), concat_fieldname, concat_fieldnameT ); CHECKIERR( ierr, "failed to compute projection weight application" ); POP_TIMER( couComm, rankInCouComm ) } #ifdef VERBOSE if( couComm != MPI_COMM_NULL && 1 == n ) { // write only for n==1 case char outputFileTgtLnd[] = "fLndOnCpl.h5m"; ierr = iMOAB_WriteMesh( cplLndPID, outputFileTgtLnd, fileWriteOptions ); CHECKIERR( ierr, "could not write fLndOnCpl.h5m to disk" ) } #endif // end land proj // send the tags back to land pes, from land mesh on coupler pes // send from cplLndPID to cmpLndPID, using common joint comm // as always, use nonblocking sends // original graph // int context_id = -1; // the land might not have these tags yet; it should be a different name for land // in e3sm we do have different names if( lndComm != MPI_COMM_NULL ) { int tagIndexIn2; ierr = iMOAB_DefineTagStorage( cmpLndPID, bottomProjectedFields, &tagTypes[1], &ocnCompNDoFs, &tagIndexIn2 ); CHECKIERR( ierr, "failed to define the field tag for receiving back the tag " "a2oTbot_proj, a2oUbot_proj, a2oVbot_proj on lnd pes" ); } if( couComm != MPI_COMM_NULL ) { context_id = cmplnd; // land comp id ierr = iMOAB_SendElementTag( cplLndPID, "a2oTbot_proj:a2oUbot_proj:a2oVbot_proj", &lndCouComm, &context_id ); CHECKIERR( ierr, "cannot send tag values back to land pes" ) } // receive on component 3, land if( lndComm != MPI_COMM_NULL ) { context_id = cpllnd; // land on coupler id ierr = iMOAB_ReceiveElementTag( cmpLndPID, "a2oTbot_proj:a2oUbot_proj:a2oVbot_proj", &lndCouComm, &context_id ); CHECKIERR( ierr, "cannot receive tag values from land mesh on coupler pes" ) } MPI_Barrier( MPI_COMM_WORLD ); if( couComm != MPI_COMM_NULL ) { context_id = cmplnd; ierr = iMOAB_FreeSenderBuffers( cplLndPID, &context_id ); CHECKIERR( ierr, "cannot free buffers used to resend land tag towards the coverage mesh " "for atm context" ) } if( lndComm != MPI_COMM_NULL && 1 == n ) // write only for n==1 case { char outputFileLnd[] = "LndWithProj.h5m"; ierr = iMOAB_WriteMesh( cmpLndPID, outputFileLnd, fileWriteOptions ); CHECKIERR( ierr, "could not write LndWithProj.h5m to disk" ) } #endif // ENABLE_ATMLND_COUPLING } // end loop iterations n #ifdef ENABLE_ATMLND_COUPLING if( lndComm != MPI_COMM_NULL ) { ierr = iMOAB_DeregisterApplication( cmpLndPID ); CHECKIERR( ierr, "cannot deregister app LND1" ) } #endif // ENABLE_ATMLND_COUPLING #ifdef ENABLE_ATMOCN_COUPLING if( couComm != MPI_COMM_NULL ) { ierr = iMOAB_DeregisterApplication( cplAtmOcnPID ); CHECKIERR( ierr, "cannot deregister app intx AO" ) } if( ocnComm != MPI_COMM_NULL ) { ierr = iMOAB_DeregisterApplication( cmpOcnPID ); CHECKIERR( ierr, "cannot deregister app OCN1" ) } #endif // ENABLE_ATMOCN_COUPLING if( atmComm != MPI_COMM_NULL ) { ierr = iMOAB_DeregisterApplication( cmpAtmPID ); CHECKIERR( ierr, "cannot deregister app ATM1" ) } #ifdef ENABLE_ATMLND_COUPLING if( couComm != MPI_COMM_NULL ) { ierr = iMOAB_DeregisterApplication( cplLndPID ); CHECKIERR( ierr, "cannot deregister app LNDX" ) } #endif // ENABLE_ATMLND_COUPLING #ifdef ENABLE_ATMOCN_COUPLING if( couComm != MPI_COMM_NULL ) { ierr = iMOAB_DeregisterApplication( cplOcnPID ); CHECKIERR( ierr, "cannot deregister app OCNX" ) } #endif // ENABLE_ATMOCN_COUPLING if( couComm != MPI_COMM_NULL ) { ierr = iMOAB_DeregisterApplication( cplAtmPID ); CHECKIERR( ierr, "cannot deregister app ATMX" ) } //#endif ierr = iMOAB_Finalize(); CHECKIERR( ierr, "did not finalize iMOAB" ) // free atm coupler group and comm if( MPI_COMM_NULL != atmCouComm ) MPI_Comm_free( &atmCouComm ); MPI_Group_free( &joinAtmCouGroup ); if( MPI_COMM_NULL != atmComm ) MPI_Comm_free( &atmComm ); #ifdef ENABLE_ATMOCN_COUPLING if( MPI_COMM_NULL != ocnComm ) MPI_Comm_free( &ocnComm ); // free ocn - coupler group and comm if( MPI_COMM_NULL != ocnCouComm ) MPI_Comm_free( &ocnCouComm ); MPI_Group_free( &joinOcnCouGroup ); #endif #ifdef ENABLE_ATMLND_COUPLING if( MPI_COMM_NULL != lndComm ) MPI_Comm_free( &lndComm ); // free land - coupler group and comm if( MPI_COMM_NULL != lndCouComm ) MPI_Comm_free( &lndCouComm ); MPI_Group_free( &joinLndCouGroup ); #endif if( MPI_COMM_NULL != couComm ) MPI_Comm_free( &couComm ); MPI_Group_free( &atmPEGroup ); #ifdef ENABLE_ATMOCN_COUPLING MPI_Group_free( &ocnPEGroup ); #endif #ifdef ENABLE_ATMLND_COUPLING MPI_Group_free( &lndPEGroup ); #endif MPI_Group_free( &couPEGroup ); MPI_Group_free( &jgroup ); MPI_Finalize(); return 0; }
