mbcoupler_test.cpp File Reference
#include "moab/ParallelComm.hpp"
#include "MBParallelConventions.h"
#include "moab/Core.hpp"
#include "Coupler.hpp"
#include "moab_mpi.h"
#include "ElemUtil.hpp"
#include "TestUtil.hpp"
#include <iostream>
#include <iomanip>
#include <sstream>
#include <cassert>
+ Include dependency graph for mbcoupler_test.cpp:
Functions
void print_usage ()
int main (int, char **)
Function Documentation
int main ( int  ,
char **
Definition at line 708 of file mbcoupler_test.cpp.
References print_usage().
    print_usage();
    return 0;
void print_usage ( )
Definition at line 33 of file mbcoupler_test.cpp.
    std::cerr << "Usage: ";
    std::cerr << "mbcoupler_test -meshes <source_mesh> <target_mesh> -itag <interp_tag> [-gnorm "
                 "<gnorm_tag>] [-ssnorm <ssnorm_tag> <ssnorm_selection>] [-ropts <roptions>] "
                 "[-outfile <out_file> [-wopts <woptions>]] [-dbgout [<dbg_file>]]"
              << std::endl;
    std::cerr << "    -meshes" << std::endl;
    std::cerr << "        Read in mesh files <source_mesh> and <target_mesh>." << std::endl;
    std::cerr << "    -itag" << std::endl;
    std::cerr << "        Interpolate tag <interp_tag> from source mesh to target mesh." << std::endl;
    std::cerr << "    -gnorm" << std::endl;
    std::cerr << "        Normalize the value of tag <gnorm_tag> over then entire mesh and save to" << std::endl;
    std::cerr << "        tag \"<gnorm_tag>_normf\" on the mesh set.  Do this for all meshes." << std::endl;
    std::cerr << "    -ssnorm" << std::endl;
    std::cerr << "        Normalize the value of tag <ssnorm_tag> over subsets of a mesh and save to" << std::endl;
    std::cerr << "        tag \"<ssnorm_tag>_normf\" on the Entity Set for each subset.  Subsets "
                 "are selected"
              << std::endl;
    std::cerr << "        using criteria in <ssnorm_selection>.  Do this for all meshes." << std::endl;
    std::cerr << "    -ropts" << std::endl;
    std::cerr << "        Read in the mesh files using options in <roptions>." << std::endl;
    std::cerr << "    -outfile" << std::endl;
    std::cerr << "        Write out target mesh to <out_file>." << std::endl;
    std::cerr << "    -wopts" << std::endl;
    std::cerr << "        Write out mesh files using options in <woptions>." << std::endl;
    std::cerr << "    -dbgout" << std::endl;
    std::cerr << "        Write stdout and stderr streams to the file \'<dbg_file>.txt\'." << std::endl;
    std::cerr << "    -eps" << std::endl;
    std::cerr << "        epsilon" << std::endl;
    std::cerr << "    -meth <method> (0=CONSTANT, 1=LINEAR_FE, 2=QUADRATIC_FE, 3=SPECTRAL, 4=SPHERICAL)" << std::endl;
