umr.cpp File Reference
#include <iostream>
#include <vector>
#include <string>
#include <iomanip>
#include <fstream>
#include <ctime>
#include <cmath>
#include <cassert>
#include <cfloat>
#include "moab/Core.hpp"
#include "moab/Interface.hpp"
#include "moab/verdict/VerdictWrapper.hpp"
#include "moab/NestedRefine.hpp"
+ Include dependency graph for umr.cpp:
Defines
#define SUCCESS   0
#define USAGE_ERROR   1
#define NOT_IMPLEMENTED   2
Functions
static void print_usage (const char *name, std::ostream &stream)
static void usage_error (const char *name)
bool parse_id_list (const char *string, int dim, int nval, std::vector< int > &results)
bool make_opts_string (std::vector< std::string > options, std::string &opts)
ErrorCode get_degree_seq (Core &mb, EntityHandle fileset, int dim, double desired_vol, int &num_levels, std::vector< int > &level_degs)
ErrorCode get_max_volume (Core &mb, EntityHandle fileset, int dim, double &vmax)
int main (int argc, char *argv[])
Define Documentation
Definition at line 31 of file umr.cpp.
#define SUCCESS   0
Definition at line 29 of file umr.cpp.
Referenced by main().
Definition at line 30 of file umr.cpp.
Referenced by main(), print_usage(), and usage_error().
Function Documentation
ErrorCode get_degree_seq ( Core mb,
int  dim,
double  desired_vol,
int &  num_levels,
std::vector< int > &  level_degs
Definition at line 411 of file umr.cpp.
References moab::error(), ErrorCode, get_max_volume(), MB_CHK_ERR, and MB_SUCCESS.
    // Find max volume
    double vmax_global;
    ErrorCode error = get_max_volume( mb, fileset, dim, vmax_global );MB_CHK_ERR( error );
    int init_nl = num_levels;
    num_levels  = 0;
    level_degs.clear();
    // Find a sequence that reduces the maximum volume to desired.
    // desired_vol should be a fraction or absolute value ?
    // double remV = vmax_global*desired_vol/dim;
    double Vdesired = desired_vol;
    double try_x;
    double remV    = vmax_global;
    int degs[3][3] = { { 5, 3, 2 }, { 25, 9, 4 }, { 0, 27, 8 } };
    if( dim == 1 || dim == 2 )
        while( remV - Vdesired >= 0 )
            try_x = degs[dim - 1][0];
            if( ( remV / try_x - Vdesired ) >= 0 )
                level_degs.push_back( 5 );
                num_levels += 1;
                remV /= try_x;
            else
                try_x = degs[dim - 1][1];
                    level_degs.push_back( 3 );
                    num_levels += 1;
                    remV /= try_x;
                else
                    try_x = degs[dim - 1][2];
                        level_degs.push_back( 2 );
                        num_levels += 1;
                        remV /= try_x;
                    else
                        break;
    else
                num_levels += 1;
                remV /= try_x;
            else
                    num_levels += 1;
                    remV /= try_x;
                else
                    break;
    if( init_nl != 0 && init_nl < num_levels )
        for( int i = level_degs.size(); i >= init_nl; i-- )
            level_degs.pop_back();
        num_levels = init_nl;
    return MB_SUCCESS;
ErrorCode get_max_volume ( Core mb,
int  dim,
double &  vmax
Definition at line 506 of file umr.cpp.
References moab::Range::begin(), moab::Range::clear(), moab::Range::end(), moab::error(), ErrorCode, moab::ParallelComm::filter_pstatus(), moab::Core::get_entities_by_handle(), moab::ParallelComm::get_pcomm(), moab::MB_AREA, MB_CHK_ERR, moab::MB_LENGTH, MB_SUCCESS, moab::MB_VOLUME, PSTATUS_NOT, PSTATUS_NOT_OWNED, moab::VerdictWrapper::quality_measure(), size, and moab::Range::subset_by_dimension().
Referenced by get_degree_seq(), and main().
    ErrorCode error;
    VerdictWrapper vw( &mb );
    QualityType q;
    switch( dim )
        case 1:
            q = MB_LENGTH;
            break;
        case 2:
            q = MB_AREA;
            break;
        case 3:
            q = MB_VOLUME;
            break;
        default:
            return MB_FAILURE;
            break;
    // Get all entities of the highest dimension which is passed as a command line argument.
    Range allents, owned;
    error = mb.get_entities_by_handle( fileset, allents );MB_CHK_ERR( error );
    owned = allents.subset_by_dimension( dim );MB_CHK_ERR( error );
    // Get all owned entities
#ifdef MOAB_HAVE_MPI
    int size = 1;
    MPI_Comm_size( MPI_COMM_WORLD, &size );
    int mpi_err;
    if( size > 1 )
        // filter the entities not owned, so we do not process them more than once
        ParallelComm* pcomm = moab::ParallelComm::get_pcomm( &mb, 0 );
        Range current       = owned;
        owned.clear();
        error = pcomm->filter_pstatus( current, PSTATUS_NOT_OWNED, PSTATUS_NOT, -1, &owned );
        if( error != MB_SUCCESS )
            MPI_Finalize();
            return MB_FAILURE;
#endif
    double vmax_local = 0;
    // Find the maximum volume of an entity in the owned mesh
    for( Range::iterator it = owned.begin(); it != owned.end(); it++ )
        double volume;
        error = vw.quality_measure( *it, q, volume );MB_CHK_ERR( error );
        if( volume > vmax_local ) vmax_local = volume;
    // Get the global maximum
    double vmax_global = vmax_local;
    mpi_err = MPI_Reduce( &vmax_local, &vmax_global, 1, MPI_DOUBLE, MPI_MAX, 0, MPI_COMM_WORLD );
    if( mpi_err )
        MPI_Finalize();
        return MB_FAILURE;
#endif
    vmax = vmax_global;
    return MB_SUCCESS;
int main ( int  argc,
char *  argv[]
Definition at line 89 of file umr.cpp.
References moab::Range::clear(), moab::Interface::create_meshset(), dim, moab::error(), ErrorCode, moab::NestedRefine::generate_mesh_hierarchy(), get_degree_seq(), moab::Interface::get_entities_by_handle(), get_max_volume(), moab::Interface::load_file(), make_opts_string(), mb, MB_CHK_ERR, MESHSET_SET, output, parse_id_list(), print_usage(), size, moab::Range::size(), moab::Range::subset_by_dimension(), SUCCESS, moab::NestedRefine::timeall, moab::NestedRefine::codeperf::tm_refine, moab::NestedRefine::codeperf::tm_resolve, moab::NestedRefine::codeperf::tm_total, USAGE_ERROR, usage_error(), and moab::Interface::write_file().
    int proc_id = 0, size = 1;
    MPI_Init( &argc, &argv );
    MPI_Comm_rank( MPI_COMM_WORLD, &proc_id );
#endif
    int num_levels = 0, dim = 0;
    std::vector< int > level_degrees;
    bool optimize    = false;
    bool do_flag     = true;
    bool print_times = false, print_size = false, output = false;
    bool parallel = false, resolve_shared = false, exchange_ghosts = false;
    bool printusage = false, parselevels = true;
    bool qc_vol = false, only_quality = false;
    double cvol = 0;
    std::string infile;
    int i = 1;
    while( i < argc )
        if( !argv[i][0] && 0 == proc_id )
            usage_error( argv[0] );
            MPI_Finalize();
#endif
        if( do_flag && argv[i][0] == '-' )
            switch( argv[i][1] )
                    // do flag arguments:
                case '-':
                    do_flag = false;
                    break;
                case 't':
                    print_times = true;
                    break;
                case 's':
                    print_size = true;
                    break;
                case 'h':
                case 'H':
                    print_usage( argv[0], std::cerr );
                    printusage = true;
                    break;
                case 'd':
                    dim = atol( argv[i + 1] );
                    ++i;
                    break;
                case 'n':
                    num_levels = atol( argv[i + 1] );
                    ++i;
                    break;
                case 'L':
                    if( dim != 0 && num_levels != 0 )
                        parselevels = parse_id_list( argv[i + 1], dim, num_levels, level_degrees );
                        ++i;
                    else
                        printusage = true;
                    break;
                case 'V':
                    qc_vol = true;
                    cvol   = strtod( argv[i + 1], NULL );
                    ++i;
                    break;
                case 'q':
                    only_quality = true;
                    break;
                case 'o':
                    output = true;
                    break;
                case 'O':
                    optimize = true;
                    break;
                case 'p':
                    parallel       = true;
                    resolve_shared = true;
                    if( argv[i][1] == '1' ) exchange_ghosts = true;
                    break;
#endif
                default:
                    ++i;
                    switch( argv[i - 1][1] )
                            // case 'O':  read_opts.push_back(argv[i]); break;
                        default:
                            std::cerr << "Invalid option: " << argv[i] << std::endl;
            ++i;
        // do file names
        else
            infile = argv[i];
            ++i;
    if( infile.empty() && !printusage ) print_usage( argv[0], std::cerr );
    if( !parselevels ) exit( USAGE_ERROR );
    parallel       = true;
#endif
    ErrorCode error;
    Core* moab    = new Core;
    Interface* mb = (Interface*)moab;
    EntityHandle fileset;
    // Create a fileset
    error = mb->create_meshset( MESHSET_SET, fileset );MB_CHK_ERR( error );
    // Set the read options for parallel file loading
    std::vector< std::string > read_opts, write_opts;
    std::string read_options, write_options;
    if( parallel && size > 1 )
        read_opts.push_back( "PARALLEL=READ_PART" );
        read_opts.push_back( "PARTITION=PARALLEL_PARTITION" );
        if( resolve_shared ) read_opts.push_back( "PARALLEL_RESOLVE_SHARED_ENTS" );
        if( exchange_ghosts ) read_opts.push_back( "PARALLEL_GHOSTS=3.0.1" );
        /*  if (output)
              write_opts.push_back(";;PARALLEL=WRITE_PART");
              std::cout<<"Here"<<std::endl;
    if( !make_opts_string( read_opts, read_options ) || !make_opts_string( write_opts, write_options ) )
        MPI_Finalize();
#endif
        return USAGE_ERROR;
    // Load file
    std::cout << "READ OPTS=" << (char*)read_options.c_str() << std::endl;
    error = mb->load_file( infile.c_str(), &fileset, read_options.c_str() );MB_CHK_ERR( error );
    // Create the nestedrefine instance
    ParallelComm* pc   = new ParallelComm( mb, MPI_COMM_WORLD );
    NestedRefine* uref = new NestedRefine( moab, pc, fileset );
#else
    NestedRefine* uref = new NestedRefine( moab );
#endif
    std::vector< EntityHandle > lsets;
    // std::cout<<"Read input file"<<std::endl;
    if( only_quality )
        double vmax;
        error = get_max_volume( *moab, fileset, dim, vmax );MB_CHK_ERR( error );
        int rank = 0;
        MPI_Comm_rank( MPI_COMM_WORLD, &rank );
        if( rank == 0 ) std::cout << "Maximum global volume = " << vmax << std::endl;
#else
        std::cout << "Maximum volume = " << vmax << std::endl;
#endif
        exit( SUCCESS );
    // If a volume constraint is given, find an optimal degree sequence to reach the desired volume
    // constraint.
    if( qc_vol )
        error = get_degree_seq( *moab, fileset, dim, cvol, num_levels, level_degrees );MB_CHK_ERR( error );
        if( dim == 0 ) print_usage( argv[0], std::cerr );
    if( num_levels == 0 ) num_levels = 1;
    int* ldeg = new int[num_levels];
    // std::cout<<"level_degrees.size = "<<level_degrees.size()<<std::endl;
    if( level_degrees.empty() )
        for( int l = 0; l < num_levels; l++ )
            ldeg[l] = 2;
    else
            ldeg[l] = level_degrees[l];
    std::cout << "Starting hierarchy generation" << std::endl;
    std::cout << "opt = " << optimize << std::endl;
    error = uref->generate_mesh_hierarchy( num_levels, ldeg, lsets, optimize );MB_CHK_ERR( error );
    if( print_times )
        std::cout << "Finished hierarchy generation in " << uref->timeall.tm_total << "  secs" << std::endl;
        if( parallel )
            std::cout << "Time taken for refinement " << uref->timeall.tm_refine << "  secs" << std::endl;
            std::cout << "Time taken for resolving shared interface " << uref->timeall.tm_resolve << "  secs"
                      << std::endl;
    else
        std::cout << "Finished hierarchy generation " << std::endl;
    if( print_size )
        Range all_ents, ents[4];
        error = mb->get_entities_by_handle( fileset, all_ents );MB_CHK_ERR( error );
        for( int k = 0; k < 4; k++ )
            ents[k] = all_ents.subset_by_dimension( k );
        std::cout << std::endl;
        if( qc_vol )
            double volume;
            error = get_max_volume( *moab, fileset, dim, volume );MB_CHK_ERR( error );
            std::cout << "Mesh size for level 0"
                      << "  :: nverts = " << ents[0].size() << ", nedges = " << ents[1].size()
                      << ", nfaces = " << ents[2].size() << ", ncells = " << ents[3].size() << " :: Vmax = " << volume
                      << std::endl;
        else
                      << ", nfaces = " << ents[2].size() << ", ncells = " << ents[3].size() << std::endl;
            all_ents.clear();
            ents[0].clear();
            ents[1].clear();
            ents[2].clear();
            ents[3].clear();
            error = mb->get_entities_by_handle( lsets[l + 1], all_ents );MB_CHK_ERR( error );
            // std::cout<<std::endl;
            if( qc_vol )
                double volume;
                error = get_max_volume( *moab, lsets[l + 1], dim, volume );MB_CHK_ERR( error );
                std::cout << "Mesh size for level " << l + 1 << "  :: nverts = " << ents[0].size()
                          << ", nedges = " << ents[1].size() << ", nfaces = " << ents[2].size()
                          << ", ncells = " << ents[3].size() << " :: Vmax = " << volume << std::endl;
            else
    if( output )
            std::string::size_type idx1 = infile.find_last_of( "\\/" );
            std::string::size_type idx2 = infile.find_last_of( "." );
            std::string file            = infile.substr( idx1 + 1, idx2 - idx1 - 1 );
            std::stringstream out;
            if( parallel )
                out << "_ML_" << l + 1 << ".h5m";
            else
                out << "_ML_" << l + 1 << ".vtk";
            file                    = file + out.str();
            const char* output_file = file.c_str();
            error = mb->write_file( output_file, 0, ";;PARALLEL=WRITE_PART", &lsets[l + 1], 1 );MB_CHK_ERR( error );
#else
            error = mb->write_file( output_file, 0, NULL, &lsets[l + 1], 1 );MB_CHK_ERR( error );
#endif
            //   const char* output_file = file.c_str();
            //   error =  mb->write_file(output_file, 0, write_options.c_str(), &lsets[l+1],
            //   1);MB_CHK_ERR(error);
            //    mb->list_entity(lsets[l+1]);
            //   mb->write_file(output_file, 0, "PARALLEL=WRITE_PART", &lsets[l+1], 1);
    delete uref;
    delete pc;
#endif
    delete[] ldeg;
    delete moab;
    MPI_Finalize();
#endif
    exit( SUCCESS );
bool make_opts_string ( std::vector< std::string >  options,
std::string &  opts
bool parse_id_list ( const char *  string,
int  dim,
int  nval,
std::vector< int > &  results
Definition at line 578 of file umr.cpp.
    bool okay   = true;
    char* mystr = strdup( string );
    for( const char* ptr = strtok( mystr, "," ); ptr; ptr = strtok( 0, "," ) )
        char* endptr;
        int val = strtol( ptr, &endptr, 0 );
            if( val != 2 && val != 3 && val != 5 )
                std::cerr << "Not a valid degree for the passed dimension" << std::endl;
                okay = false;
                break;
        else if( dim == 3 )
            if( val != 2 && val != 3 )
                okay = false;
                break;
        if( endptr == ptr || val <= 0 )
            std::cerr << "Not a valid id: " << ptr << std::endl;
            okay = false;
            break;
        results.push_back( val );
    if( (int)results.size() < nval )
        for( int i = results.size(); i <= nval - 1; i++ )
            results.push_back( results[0] );
    else if( (int)results.size() > nval )
        for( int i = results.size(); i > nval; i-- )
            results.pop_back();
    free( mystr );
    return okay;
static void print_usage ( const char *  name,
std::ostream &  stream
) [static]
Definition at line 35 of file umr.cpp.
References USAGE_ERROR.
    stream << "Usage: " << name << " <options> <input_file> [<input_file2> ...]" << std::endl
           << "Options: " << std::endl
           << "\t-h             - Print this help text and exit." << std::endl
           << "\t-d             - Dimension of the mesh." << std::endl
           << "\t-n             - Exact or a maximum number of levels for the hierarchy. Default 1." << std::endl
           << "\t-L             - Degree of refinement for each level. Pass an array or a number. It "
              "is mandatory to pass dimension and num_levels before to use this option. If this flag "
              "is not used, a default of deg 2 refinement is used. "
           << std::endl
           << "\t-V             - Pass a desired volume (absolute) . This will generate a hierarchy "
              "such that the maximum volume is reduced to the given amount approximately. The length "
              "of the hierarchy can be constrained further if a maximum number of levels is passed. "
              "It is mandatory to pass the dimension for this option. "
           << std::endl
           << "\t-q             - Prints out the maximum volume of the mesh and exits the program. "
              "This option can be used as a guide to volume constrainted mesh hierarchy later. "
           << std::endl
           << "\t-t             - Print out the time taken to generate hierarchy." << std::endl
           << "\t-s             - Print out the mesh sizes of each level of the generated hierarchy." << std::endl
           << "\t-o             - Specify true for output files for the mesh levels of the hierarchy." << std::endl
    //<< "\t-O option      - Specify read option." << std::endl
           << "\t-p[0|1|2]      - Read in parallel[0], optionally also doing resolve_shared_ents (1) "
              "and exchange_ghosts (2)"
           << std::endl
#endif
static void usage_error ( const char *  name) [static]
Definition at line 67 of file umr.cpp.
References print_usage(), and USAGE_ERROR.
    print_usage( name, std::cerr );
    MPI_Finalize();
#endif
