measure.cpp File Reference
#include "moab/CartVect.hpp"
#include "measure.hpp"
+ Include dependency graph for measure.cpp:
Functions
static double tet_volume (const CartVect &v0, const CartVect &v1, const CartVect &v2, const CartVect &v3)
double edge_length (const double *start_vtx_coords, const double *end_vtx_coords)
double measure (moab::EntityType type, int num_vertices, const double *vertex_coordinates)
Function Documentation
double edge_length ( const double *  start_vtx_coords,
const double *  end_vtx_coords
Definition at line 35 of file measure.cpp.
References moab::CartVect::length().
Referenced by gather_set_stats().
    const CartVect* start = reinterpret_cast< const CartVect* >( start_vtx_coords );
    const CartVect* end   = reinterpret_cast< const CartVect* >( end_vtx_coords );
    return ( *start - *end ).length();
double measure ( moab::EntityType  type,
int  num_vertices,
const double *  vertex_coordinates
Definition at line 42 of file measure.cpp.
References length(), MBEDGE, MBHEX, MBPOLYGON, MBPRISM, MBPYRAMID, MBQUAD, MBTET, MBTRI, moab::sum(), and tet_volume().
    const CartVect* coords = reinterpret_cast< const CartVect* >( vertex_coordinates );
    switch( type )
        case moab::MBEDGE:
            return ( coords[0] - coords[1] ).length();
        case moab::MBTRI:
            return 0.5 * ( ( coords[1] - coords[0] ) * ( coords[2] - coords[0] ) ).length();
        case moab::MBQUAD:
            num_vertices = 4;
            // fall through
        case moab::MBPOLYGON: {
            CartVect mid( 0, 0, 0 );
            for( int i = 0; i < num_vertices; ++i )
                mid += coords[i];
            mid /= num_vertices;
            double sum = 0.0;
                int j = ( i + 1 ) % num_vertices;
                sum += ( ( mid - coords[i] ) * ( mid - coords[j] ) ).length();
            return 0.5 * sum;
        case moab::MBTET:
            return tet_volume( coords[0], coords[1], coords[2], coords[3] );
        case moab::MBPYRAMID:
            return tet_volume( coords[0], coords[1], coords[2], coords[4] ) +
                   tet_volume( coords[0], coords[2], coords[3], coords[4] );
        case moab::MBPRISM:
            return tet_volume( coords[0], coords[1], coords[2], coords[5] ) +
                   tet_volume( coords[3], coords[5], coords[4], coords[0] ) +
                   tet_volume( coords[1], coords[4], coords[5], coords[0] );
        case moab::MBHEX:
            return tet_volume( coords[0], coords[1], coords[3], coords[4] ) +
                   tet_volume( coords[7], coords[3], coords[6], coords[4] ) +
                   tet_volume( coords[4], coords[5], coords[1], coords[6] ) +
                   tet_volume( coords[1], coords[6], coords[3], coords[4] ) +
                   tet_volume( coords[2], coords[6], coords[3], coords[1] );
        default:
            return 0.0;
static double tet_volume ( const CartVect v0,
const CartVect v1,
const CartVect v2,
const CartVect v3
) [inline, static]
Definition at line 30 of file measure.cpp.
Referenced by measure().
    return 1. / 6. * ( ( ( v1 - v0 ) * ( v2 - v0 ) ) % ( v3 - v0 ) );
