moab::NestedRefine::refPatterns Struct Reference
refPatterns More...
#include <NestedRefine.hpp>
Public Attributes
short int nv_edge
 Number of new vertices on edge.
short int nv_face
 Number of new vertices on face, does not include those on edge.
short int nv_cell
 Number of new vertices in cell.
short int total_new_verts
 Total number of new vertices per entity.
short int total_new_ents
 Total number of new child entities.
int vert_index_bnds [2]
 Lower and upper indices of the new vertices.
double vert_nat_coord [MAX_VERTS][3]
 Natural coordinates of the new vertices w.r.t reference.
int ents_conn [MAX_CHILDRENS][MAX_CONN]
 Connectivity of the new entities.
int v2hf [MAX_VERTS][2]
 Vertex to half-facet map of the new vertices.
int ents_opphfs [MAX_CHILDRENS][2 *MAX_CONN]
 Opposite half-facet map of the new entities.
int vert_on_edges [MAX_HE][MAX_VHF]
 Helper: storing the local ids of vertices on each local edge.
int vert_on_faces [MAX_HF][MAX_VHF]
 Helper: storing local ids of verts on each local face, doesnt include those on edges of the face.
int ents_on_pent [MAX_HF][MAX_CHILDRENS]
 Helper: stores child half-facets incident on parent half-facet. First column contain the number of such children.
int ents_on_vedge [MAX_HE][MAX_VHF *3]
 Helper: stores child ents incident on new verts on edge.
Detailed Description
refPatterns
Refinement patterns w.r.t the reference element. It consists of a locally indexed vertex list along with their natural coordinates, the connectivity of the subdivided entities with local indices, their local AHF maps along with other helper fields to aid in general book keeping such as avoiding vertex duplication during refinement. The entity and degree specific values are stored in the Templates.hpp.
See also:
Templates.hpp
Definition at line 192 of file NestedRefine.hpp.
Member Data Documentation
Definition at line 227 of file NestedRefine.hpp.
Referenced by moab::NestedRefine::update_global_ahf_3D().
Definition at line 213 of file NestedRefine.hpp.
Referenced by moab::NestedRefine::update_local_ahf().
Definition at line 199 of file NestedRefine.hpp.
Referenced by moab::NestedRefine::estimate_hm_storage().
Definition at line 205 of file NestedRefine.hpp.
Definition at line 207 of file NestedRefine.hpp.
Referenced by moab::NestedRefine::compute_coordinates(), and moab::NestedRefine::construct_hm_1D().
Definition at line 218 of file NestedRefine.hpp.
Referenced by moab::NestedRefine::construct_hm_2D(), moab::NestedRefine::subdivide_cells(), moab::NestedRefine::subdivide_tets(), and moab::NestedRefine::update_tracking_verts().
List of all members.
The documentation for this struct was generated from the following file:
