testSmooth2.cpp
00001 /**
00002  * This library is free software; you can redistribute it and/or
00003  * modify it under the terms of the GNU Lesser General Public
00004  * License as published by the Free Software Foundation; either
00005  * version 2.1 of the License, or (at your option) any later version.
00006  *
00007  */
00008 /**
00009  * \file testgeom.cc
00010  *
00011  * \brief testgeom, a unit test for the ITAPS geometry interface
00012  *
00013  */
00014 #include "FBiGeom.h"
00015 #include "FBiGeom_MOAB.hpp"
00016 #include "iMesh.h"
00017 #include <iostream>
00018 #include <set>
00019 #include <algorithm>
00020 #include <vector>
00021 #include <iterator>
00022 #include <algorithm>
00023 #include <iomanip>
00024 #include <cassert>
00025 #include <cstring>
00026 #include <cmath>
00027 #define CHECK( STR ) \
00028     if( err != iBase_SUCCESS ) return print_error( STR, err, geom, __FILE__, __LINE__ )
00029
00030 #define STRINGIFY( S )  XSTRINGIFY( S )
00031 #define XSTRINGIFY( S ) #S
00032
00033 static bool print_error( const char* desc, int err, FBiGeom_Instance geom, const char* file, int line )
00034 {
00035     char buffer[1024];
00036     FBiGeom_getDescription( geom, buffer, sizeof( buffer ) );
00037     buffer[sizeof( buffer ) - 1] = '\0';
00038
00039     std::cerr << "ERROR: " << desc << std::endl
00040               << "  Error code: " << err << std::endl
00041               << "  Error desc: " << buffer << std::endl
00042               << "  At        : " << file << ':' << line << std::endl;
00043
00044     return false;  // must always return false or CHECK macro will break
00045 }
00046
00047 typedef iBase_TagHandle TagHandle;
00048 typedef iBase_EntityHandle GentityHandle;
00049 typedef iBase_EntitySetHandle GentitysetHandle;
00050
00051 extern void FBiGeom_newGeomFromMesh( iMesh_Instance mesh,
00052                                      iBase_EntitySetHandle set,
00053                                      const char* options,
00054                                      FBiGeom_Instance* geom,
00055                                      int* err,
00056                                      int options_len );
00057 // the second destructor
00058 extern void FBiGeom_dtor2( FBiGeom_Instance instance, int* err );
00059 /* Frees allocated arrays for us */
00060 template < typename T >
00061 class SimpleArray
00062 {
00063   private:
00064     T* arr;
00065     int arrSize;
00066     int arrAllocated;
00067
00068   public:
00069     SimpleArray() : arr( 0 ), arrSize( 0 ), arrAllocated( 0 ) {}
00070     SimpleArray( unsigned s ) : arrSize( s ), arrAllocated( s )
00071     {
00072         arr = (T*)malloc( s * sizeof( T ) );
00073         for( unsigned i = 0; i < s; ++i )
00074             new( arr + i ) T();
00075     }
00076
00077     ~SimpleArray()
00078     {
00079         for( int i = 0; i < size(); ++i )
00080             arr[i].~T();
00081         free( arr );
00082     }
00083
00084     T** ptr()
00085     {
00086         return &arr;
00087     }
00088     int& size()
00089     {
00090         return arrSize;
00091     }
00092     int size() const
00093     {
00094         return arrSize;
00095     }
00096     int& capacity()
00097     {
00098         return arrAllocated;
00099     }
00100     int capacity() const
00101     {
00102         return arrAllocated;
00103     }
00104
00105     typedef T* iterator;
00106     typedef const T* const_iterator;
00107     iterator begin()
00108     {
00109         return arr;
00110     }
00111     const_iterator begin() const
00112     {
00113         return arr;
00114     }
00115     iterator end()
00116     {
00117         return arr + arrSize;
00118     }
00119     const_iterator end() const
00120     {
00121         return arr + arrSize;
00122     }
00123
00124     T& operator[]( unsigned idx )
00125     {
00126         return arr[idx];
00127     }
00128     T operator[]( unsigned idx ) const
00129     {
00130         return arr[idx];
00131     }
00132 };
00133
00134 #define ARRAY_INOUT( A ) A.ptr(), &( A ).capacity(), &( A ).size()
00135 #define ARRAY_IN( A )    &( A )[0], ( A ).size()
00136
00137 bool smooth_test( const std::string& filename, FBiGeom_Instance );
00138
00139 bool tags_test( FBiGeom_Instance geom );
00140 bool tag_get_set_test( FBiGeom_Instance geom );
00141 bool tag_info_test( FBiGeom_Instance geom );
00142 bool gentityset_test( FBiGeom_Instance geom, bool /*multiset*/, bool /*ordered*/ );
00143 bool topology_adjacencies_test( FBiGeom_Instance geom );
00144 bool geometry_evaluation_test( FBiGeom_Instance geom );
00145 bool construct_test( FBiGeom_Instance geom );
00146 bool primitives_test( FBiGeom_Instance geom );
00147 bool transforms_test( FBiGeom_Instance geom );
00148 bool booleans_test( FBiGeom_Instance geom );
00149 bool shutdown_test2( FBiGeom_Instance geom, std::string& engine_opt );
00150 bool save_entset_test( FBiGeom_Instance geom );
00151 bool mesh_size_test( FBiGeom_Instance geom );
00152 bool normals_test( FBiGeom_Instance geom );
00153
00154 bool ray_test( FBiGeom_Instance geom );
00155
00156 void handle_error_code( const bool result, int& number_failed, int& /*number_not_implemented*/, int& number_successful )
00157 {
00158     if( result )
00159     {
00160         std::cout << "Success";
00161         number_successful++;
00162     }
00163     else
00164     {
00165         std::cout << "Failure";
00166         number_failed++;
00167     }
00168 }
00169
00170 int main( int argc, char* argv[] )
00171 {
00172     std::string filename = STRINGIFY( MESHDIR ) "/shell.h5m";
00173
00174     if( argc == 1 )
00175     {
00176         std::cout << "Using default input file: " << filename << std::endl;
00177     }
00178     else if( argc == 2 )
00179     {
00180         filename = argv[1];
00181     }
00182     else
00183     {
00184         std::cerr << "Usage: " << argv[0] << " [geom_filename]" << std::endl;
00185         return 1;
00186     }
00187
00188     int err;
00189     int number_tests                 = 0;
00190     int number_tests_successful      = 0;
00191     int number_tests_not_implemented = 0;
00192     int number_tests_failed          = 0;
00193
00194     // initialize the FBiGeom, in a different way
00195     iMesh_Instance mesh = NULL;
00196     FBiGeom_Instance geom;
00197     iMesh_newMesh( NULL, &mesh, &err, 0 );
00198     if( err != iBase_SUCCESS )
00199         std::cerr << " Error code: " << err << "  At        : " << __FILE__ << ':' << __LINE__ << std::endl;
00200
00201     iBase_EntitySetHandle root_set;
00202     iMesh_createEntSet( mesh, 0, &root_set, &err );
00203     if( err != iBase_SUCCESS )
00204         std::cerr << " Error code: " << err << " failed to create a model set"
00205                   << "  At        : " << __FILE__ << ':' << __LINE__ << std::endl;
00206
00207     iMesh_load( mesh, root_set, filename.c_str(), NULL, &err, filename.length(), 0 );
00208     if( err != iBase_SUCCESS )
00209         std::cerr << " Error code: " << err << " failed load the file"
00210                   << "  At        : " << __FILE__ << ':' << __LINE__ << std::endl;
00211
00212     std::string opts( "SMOOTH;" );
00213     // new constructor
00214     FBiGeom_newGeomFromMesh( mesh, root_set, opts.c_str(), &geom, &err, opts.length() );
00215
00216     CHECK( "Interface initialization didn't work properly." );
00217
00218     // Print out Header information
00219     std::cout << "\n\nITAPS GEOMETRY INTERFACE TEST PROGRAM:\n\n";
00220     // gLoad test
00221
00222     bool result;
00223     std::cout << "   Smooth faceting load and initialization: \n";
00224     result = smooth_test( filename, geom );
00225     handle_error_code( result, number_tests_failed, number_tests_not_implemented, number_tests_successful );
00226
00227     number_tests++;
00228     std::cout << "\n";
00229
00230     // tags test
00231     std::cout << "   tags: ";
00232     result = tags_test( geom );
00233     handle_error_code( result, number_tests_failed, number_tests_not_implemented, number_tests_successful );
00234     number_tests++;
00235     std::cout << "\n";
00236     /*
00237      // gentitysets test
00238      std::cout << "   gentity sets: ";
00239      result = gentityset_test(geom, false, false);
00240      handle_error_code(result, number_tests_failed,
00241      number_tests_not_implemented,
00242      number_tests_successful);
00243      number_tests++;
00244      std::cout << "\n";
00245      */
00246     // topology adjacencies test
00247     std::cout << "   topology adjacencies: ";
00248     result = topology_adjacencies_test( geom );
00249     handle_error_code( result, number_tests_failed, number_tests_not_implemented, number_tests_successful );
00250     number_tests++;
00251     std::cout << "\n";
00252
00253     // geometry evaluation test
00254     std::cout << "   geometry evaluation: \n";
00255     result = geometry_evaluation_test( geom );
00256     handle_error_code( result, number_tests_failed, number_tests_not_implemented, number_tests_successful );
00257     number_tests++;
00258     std::cout << "\n";
00259
00260     // normals evaluation test
00261     std::cout << "   normals geometry evaluation: \n";
00262     result = normals_test( geom );
00263     handle_error_code( result, number_tests_failed, number_tests_not_implemented, number_tests_successful );
00264     number_tests++;
00265     std::cout << "\n";
00266
00267     // ray tracing test
00268     std::cout << "   ray intersection test: \n";
00269     result = ray_test( geom );
00270     handle_error_code( result, number_tests_failed, number_tests_not_implemented, number_tests_successful );
00271     number_tests++;
00272     std::cout << "\n";
00273     /*
00274      // construct test
00275      std::cout << "   construct: ";
00276      result = construct_test(geom);
00277      handle_error_code(result, number_tests_failed,
00278      number_tests_not_implemented,
00279      number_tests_successful);
00280      number_tests++;
00281      std::cout << "\n";
00282
00283      // primitives test
00284      std::cout << "   primitives: ";
00285      result = primitives_test(geom);
00286      handle_error_code(result, number_tests_failed,
00287      number_tests_not_implemented,
00288      number_tests_successful);
00289      number_tests++;
00290      std::cout << "\n";
00291
00292      // transforms test
00293      std::cout << "   transforms: ";
00294      result = transforms_test(geom);
00295      handle_error_code(result, number_tests_failed,
00296      number_tests_not_implemented,
00297      number_tests_successful);
00298      number_tests++;
00299      std::cout << "\n";
00300
00301      // booleans test
00302      std::cout << "   booleans: ";
00303      result = booleans_test(geom);
00304      handle_error_code(result, number_tests_failed,
00305      number_tests_not_implemented,
00306      number_tests_successful);
00307      number_tests++;
00308      std::cout << "\n";
00309
00310      #if defined(HAVE_ACIS) && !defined(FORCE_OCC)
00311      std::cout << "   mesh size: ";
00312      result = mesh_size_test(geom);
00313      handle_error_code(result, number_tests_failed,
00314      number_tests_not_implemented,
00315      number_tests_successful);
00316      number_tests++;
00317      std::cout << "\n";
00318
00319      // save entset test
00320      std::cout << "   save entset: ";
00321      result = save_entset_test(geom);
00322      handle_error_code(result, number_tests_failed,
00323      number_tests_not_implemented,
00324      number_tests_successful);
00325      number_tests++;
00326      std::cout << "\n";
00327      #endif
00328      */
00329     // shutdown test
00330     std::cout << "   shutdown: ";
00331     std::string engine_opt;
00332     result = shutdown_test2( geom, engine_opt );
00333     handle_error_code( result, number_tests_failed, number_tests_not_implemented, number_tests_successful );
00334     number_tests++;
00335     std::cout << "\n";
00336
00337     // shutdown imesh instance too
00338     iMesh_dtor( mesh, &err );
00339     CHECK( "shutdown imesh error" );
00340     // summary
00341
00342     std::cout << "\nTSTT TEST SUMMARY: \n"
00343               << "   Number Tests:           " << number_tests << "\n"
00344               << "   Number Successful:      " << number_tests_successful << "\n"
00345               << "   Number Not Implemented: " << number_tests_not_implemented << "\n"
00346               << "   Number Failed:          " << number_tests_failed << "\n\n"
00347               << std::endl;
00348
00349     return number_tests_failed;
00350 }
00351
00352 /*!
00353  @test
00354  Load Mesh
00355  @li Load a mesh file
00356  */
00357
00358 bool smooth_test( const std::string& filename, FBiGeom_Instance geom )
00359 {
00360     int err;
00361     char opts[] = "SMOOTH;";
00362     FBiGeom_load( geom, &filename[0], opts, &err, filename.length(), 8 );
00363     // FBiGeom_load( geom, &filename[0], 0, &err, filename.length(), 0 );
00364     CHECK( "ERROR : can not load a geometry" );
00365
00366     iBase_EntitySetHandle root_set;
00367     FBiGeom_getRootSet( geom, &root_set, &err );
00368     CHECK( "ERROR : getRootSet failed!" );
00369
00370     // print out the number of entities
00371     std::cout << "Model contents: " << std::endl;
00372     const char* gtype[] = { "vertices: ", "edges: ", "faces: ", "regions: " };
00373     for( int i = 0; i <= 3; ++i )
00374     {
00375         int count;
00376         FBiGeom_getNumOfType( geom, root_set, i, &count, &err );
00377         CHECK( "Error: problem getting entities after gLoad." );
00378         std::cout << gtype[i] << count << std::endl;
00379     }
00380
00381     return true;
00382 }
00383 /*!
00384  @test
00385  Test tag creating, reading, writing, deleting
00386  @li Load a mesh file
00387  */
00388 bool tags_test( FBiGeom_Instance geom )
00389 {
00390     bool success = tag_info_test( geom );
00391     if( !success ) return success;
00392
00393     success = tag_get_set_test( geom );
00394     if( !success ) return success;
00395
00396     return true;
00397 }
00398
00399 bool tag_info_test( FBiGeom_Instance geom )
00400 {
00401     int err;
00402
00403     iBase_EntitySetHandle root_set;
00404     FBiGeom_getRootSet( geom, &root_set, &err );
00405     CHECK( "ERROR : getRootSet failed!" );
00406
00407     // create an arbitrary tag, size 4
00408     iBase_TagHandle this_tag, tmp_handle;
00409     std::string tag_name( "tag_info tag" ), tmp_name;
00410     FBiGeom_createTag( geom, &tag_name[0], 4, iBase_BYTES, &this_tag, &err, tag_name.length() );
00411     CHECK( "ERROR : can not create a tag." );
00412
00413     // get information on the tag
00414
00415     char name_buffer[256];
00416     FBiGeom_getTagName( geom, this_tag, name_buffer, &err, sizeof( name_buffer ) );
00417     CHECK( "ERROR : Couldn't get tag name." );
00418     if( tag_name != name_buffer )
00419     {
00420         std::cerr << "ERROR: getTagName returned '" << name_buffer << "' for tag created as '" << tag_name << "'"
00421                   << std::endl;
00422         return false;
00423     }
00424
00425     FBiGeom_getTagHandle( geom, &tag_name[0], &tmp_handle, &err, tag_name.length() );
00426     CHECK( "ERROR : Couldn't get tag handle." );
00427     if( tmp_handle != this_tag )
00428     {
00429         std::cerr << "ERROR: getTagHandle didn't return consistent result." << std::endl;
00430         return false;
00431     }
00432
00433     int tag_size;
00434     FBiGeom_getTagSizeBytes( geom, this_tag, &tag_size, &err );
00435     CHECK( "ERROR : Couldn't get tag size." );
00436     if( tag_size != 4 )
00437     {
00438         std::cerr << "ERROR: getTagSizeBytes: expected 4, got " << tag_size << std::endl;
00439         return false;
00440     }
00441
00442     FBiGeom_getTagSizeValues( geom, this_tag, &tag_size, &err );
00443     CHECK( "ERROR : Couldn't get tag size." );
00444     if( tag_size != 4 )
00445     {
00446         std::cerr << "ERROR: getTagSizeValues: expected 4, got " << tag_size << std::endl;
00447         return false;
00448     }
00449
00450     int tag_type;
00451     FBiGeom_getTagType( geom, this_tag, &tag_type, &err );
00452     CHECK( "ERROR : Couldn't get tag type." );
00453     if( tag_type != iBase_BYTES )
00454     {
00455         std::cerr << "ERROR: getTagType: expected " << iBase_BYTES << ", got " << tag_type << std::endl;
00456         return false;
00457     }
00458
00459     FBiGeom_destroyTag( geom, this_tag, true, &err );
00460     CHECK( "ERROR : Couldn't delete a tag." );
00461
00462     // print information about all the tags in the model
00463
00464     std::set< iBase_TagHandle > tags;
00465     SimpleArray< iBase_EntityHandle > entities;
00466     FBiGeom_getEntities( geom, root_set, iBase_ALL_TYPES, ARRAY_INOUT( entities ), &err );
00467     CHECK( "getEntities( ..., iBase_ALL_TYPES, ... ) failed." );
00468     for( int i = 0; i < entities.size(); ++i )
00469     {
00470         SimpleArray< iBase_TagHandle > tag_arr;
00471         FBiGeom_getAllTags( geom, entities[i], ARRAY_INOUT( tag_arr ), &err );
00472         CHECK( "getAllTags failed." );
00473         std::copy( tag_arr.begin(), tag_arr.end(), std::inserter( tags, tags.begin() ) );
00474     }
00475
00476     std::cout << "Tags defined on model: ";
00477     bool first = true;
00478     for( std::set< iBase_TagHandle >::iterator sit = tags.begin(); sit != tags.end(); ++sit )
00479     {
00480         FBiGeom_getTagName( geom, *sit, name_buffer, &err, sizeof( name_buffer ) );
00481         name_buffer[sizeof( name_buffer ) - 1] = '\0';  // mnake sure of NUL termination
00482         CHECK( "getTagName failed." );
00483
00484         if( !first ) std::cout << ", ";
00485         std::cout << name_buffer;
00486         first = false;
00487     }
00488     if( first ) std::cout << "<none>";
00489     std::cout << std::endl;
00490
00491     return true;
00492 }
00493
00494 bool tag_get_set_test( FBiGeom_Instance geom )
00495 {
00496     int err;
00497
00498     // create an arbitrary tag, size 4
00499     iBase_TagHandle this_tag;
00500     std::string tag_name( "tag_get_set tag" );
00501     FBiGeom_createTag( geom, &tag_name[0], sizeof( int ), iBase_BYTES, &this_tag, &err, tag_name.length() );
00502     CHECK( "ERROR : can not create a tag for get_set test." );
00503
00504     iBase_EntitySetHandle root_set;
00505     FBiGeom_getRootSet( geom, &root_set, &err );
00506     CHECK( "ERROR : getRootSet failed!" );
00507
00508     // set this tag to an integer on each entity; keep track of total sum
00509     int sum = 0, num = 0, dim;
00510     for( dim = 0; dim <= 3; dim++ )
00511     {
00512         SimpleArray< iBase_EntityHandle > gentity_handles;
00513         FBiGeom_getEntities( geom, root_set, dim, ARRAY_INOUT( gentity_handles ), &err );
00514         int num_ents = gentity_handles.size();
00515         std::vector< int > tag_vals( num_ents );
00516         for( int i = 0; i < num_ents; ++i )
00517         {
00518             tag_vals[i] = num;
00519             sum += num;
00520             ++num;
00521         }
00522
00523         FBiGeom_setArrData( geom, ARRAY_IN( gentity_handles ), this_tag, (char*)&tag_vals[0],
00524                             tag_vals.size() * sizeof( int ), &err );
00525         CHECK( "ERROR : can't set tag on entities" );
00526     }
00527
00528     // check tag values for entities now
00529     int get_sum = 0;
00530     for( dim = 0; dim <= 3; dim++ )
00531     {
00532         SimpleArray< iBase_EntityHandle > gentity_handles;
00533         FBiGeom_getEntities( geom, root_set, dim, ARRAY_INOUT( gentity_handles ), &err );
00534         int num_ents = gentity_handles.size();
00535
00536         SimpleArray< char > tag_vals;
00537         FBiGeom_getArrData( geom, ARRAY_IN( gentity_handles ), this_tag, (void**)tag_vals.ptr(), &tag_vals.capacity(),
00538                             &tag_vals.size(), &err );
00539         CHECK( "ERROR : can't get tag on entities" );
00540
00541         int* tag_ptr = (int*)( &tag_vals[0] );
00542         for( int i = 0; i < num_ents; ++i )
00543             get_sum += tag_ptr[i];
00544     }
00545
00546     if( get_sum != sum )
00547     {
00548         std::cerr << "ERROR: getData didn't return consistent results." << std::endl;
00549         return false;
00550     }
00551
00552     FBiGeom_destroyTag( geom, this_tag, true, &err );
00553     CHECK( "ERROR : couldn't delete tag." );
00554
00555     return true;
00556 }
00557
00558 /*!
00559  @test
00560  TSTT gentity sets test (just implemented parts for now)
00561  @li Check gentity sets
00562  */
00563 bool gentityset_test( FBiGeom_Instance geom, bool /*multiset*/, bool /*ordered*/ )
00564 {
00565     int num_type = 4;
00566     iBase_EntitySetHandle ges_array[4];
00567     int number_array[4];
00568     // int num_all_gentities_super = 0;
00569     int ent_type = iBase_VERTEX;
00570
00571     int err;
00572     iBase_EntitySetHandle root_set;
00573     FBiGeom_getRootSet( geom, &root_set, &err );
00574     CHECK( "ERROR : getRootSet failed!" );
00575
00576     // get the number of sets in the whole model
00577     int all_sets = 0;
00578     FBiGeom_getNumEntSets( geom, root_set, 0, &all_sets, &err );
00579     CHECK( "Problem getting the number of all gentity sets in whole model." );
00580
00581     // add gentities to entitysets by type
00582     for( ; ent_type < num_type; ent_type++ )
00583     {
00584         // initialize the entityset
00585         FBiGeom_createEntSet( geom, true, &ges_array[ent_type], &err );
00586         CHECK( "Problem creating entityset." );
00587
00588         // get entities by type in total "mesh"
00589         SimpleArray< iBase_EntityHandle > gentities;
00590         FBiGeom_getEntities( geom, root_set, ent_type, ARRAY_INOUT( gentities ), &err );
00591         CHECK( "Failed to get gentities by type in gentityset_test." );
00592
00593         // add gentities into gentity set
00594         FBiGeom_addEntArrToSet( geom, ARRAY_IN( gentities ), ges_array[ent_type], &err );
00595         CHECK( "Failed to add gentities in entityset_test." );
00596
00597         // Check to make sure entity set really has correct number of entities in it
00598         FBiGeom_getNumOfType( geom, ges_array[ent_type], ent_type, &number_array[ent_type], &err );
00599         CHECK( "Failed to get number of gentities by type in entityset_test." );
00600
00601         // compare the number of entities by type
00602         int num_type_gentity = gentities.size();
00603
00604         if( number_array[ent_type] != num_type_gentity )
00605         {
00606             std::cerr << "Number of gentities by type is not correct" << std::endl;
00607             return false;
00608         }
00609
00610         // add to number of all entities in super set
00611         // num_all_gentities_super += num_type_gentity;
00612     }
00613
00614     // make a super set having all entitysets
00615     iBase_EntitySetHandle super_set;
00616     FBiGeom_createEntSet( geom, true, &super_set, &err );
00617     CHECK( "Failed to create a super set in gentityset_test." );
00618
00619     for( int i = 0; i < num_type; i++ )
00620     {
00621         FBiGeom_addEntSet( geom, ges_array[i], super_set, &err );
00622         CHECK( "Failed to create a super set in gentityset_test." );
00623     }
00624
00625     //----------TEST BOOLEAN OPERATIONS----------------//
00626
00627     iBase_EntitySetHandle temp_ges1;
00628     FBiGeom_createEntSet( geom, true, &temp_ges1, &err );
00629     CHECK( "Failed to create a super set in gentityset_test." );
00630
00631     // Subtract
00632     // add all EDGEs and FACEs to temp_es1
00633     // get all EDGE entities
00634     SimpleArray< iBase_EntityHandle > gedges, gfaces, temp_gentities1;
00635     FBiGeom_getEntities( geom, ges_array[iBase_EDGE], iBase_EDGE, ARRAY_INOUT( gedges ), &err );
00636     CHECK( "Failed to get gedge gentities in gentityset_test." );
00637
00638     // add EDGEs to ges1
00639     FBiGeom_addEntArrToSet( geom, ARRAY_IN( gedges ), temp_ges1, &err );
00640     CHECK( "Failed to add gedge gentities in gentityset_test." );
00641
00642     // get all FACE gentities
00643     FBiGeom_getEntities( geom, ges_array[iBase_FACE], iBase_FACE, ARRAY_INOUT( gfaces ), &err );
00644     CHECK( "Failed to get gface gentities in gentityset_test." );
00645
00646     // add FACEs to es1
00647     FBiGeom_addEntArrToSet( geom, ARRAY_IN( gfaces ), temp_ges1, &err );
00648     CHECK( "Failed to add gface gentities in gentityset_test." );
00649
00650     // subtract EDGEs
00651     FBiGeom_subtract( geom, temp_ges1, ges_array[iBase_EDGE], &temp_ges1, &err );
00652     CHECK( "Failed to subtract gentitysets in gentityset_test." );
00653
00654     FBiGeom_getEntities( geom, temp_ges1, iBase_FACE, ARRAY_INOUT( temp_gentities1 ), &err );
00655     CHECK( "Failed to get gface gentities in gentityset_test." );
00656
00657     if( gfaces.size() != temp_gentities1.size() )
00658     {
00659         std::cerr << "Number of entitysets after subtraction not correct \
00660              in gentityset_test."
00661                   << std::endl;
00662         return false;
00663     }
00664
00665     // check there's nothing but gfaces in temp_ges1
00666     int num_gents;
00667     FBiGeom_getNumOfType( geom, temp_ges1, iBase_EDGE, &num_gents, &err );
00668     CHECK( "Failed to get dimensions of gentities in gentityset_test." );
00669     if( 0 != num_gents )
00670     {
00671         std::cerr << "Subtraction failed to remove all edges" << std::endl;
00672         return false;
00673     }
00674
00675     //------------Intersect------------
00676     //
00677
00678     // clean out the temp_ges1
00679     FBiGeom_rmvEntArrFromSet( geom, ARRAY_IN( gfaces ), temp_ges1, &err );
00680     CHECK( "Failed to remove gface gentities in gentityset_test." );
00681
00682     // check if it is really cleaned out
00683     FBiGeom_getNumOfType( geom, temp_ges1, iBase_FACE, &num_gents, &err );
00684     CHECK( "Failed to get number of gentities by type in gentityset_test." );
00685
00686     if( num_gents != 0 )
00687     {
00688         std::cerr << "failed to remove correctly." << std::endl;
00689         return false;
00690     }
00691
00692     // add EDGEs to temp ges1
00693     FBiGeom_addEntArrToSet( geom, ARRAY_IN( gedges ), temp_ges1, &err );
00694     CHECK( "Failed to add gedge gentities in gentityset_test." );
00695
00696     // add FACEs to temp ges1
00697     FBiGeom_addEntArrToSet( geom, ARRAY_IN( gfaces ), temp_ges1, &err );
00698     CHECK( "Failed to add gface gentities in gentityset_test." );
00699
00700     // intersect temp_ges1 with gedges set
00701     // temp_ges1 entityset is altered
00702     FBiGeom_intersect( geom, temp_ges1, ges_array[iBase_EDGE], &temp_ges1, &err );
00703     CHECK( "Failed to intersect in gentityset_test." );
00704
00705     // try to get FACEs, but there should be nothing but EDGE
00706     FBiGeom_getNumOfType( geom, temp_ges1, iBase_FACE, &num_gents, &err );
00707     CHECK( "Failed to get gface gentities in gentityset_test." );
00708
00709     if( num_gents != 0 )
00710     {
00711         std::cerr << "wrong number of gfaces." << std::endl;
00712         return false;
00713     }
00714
00715     //-------------Unite--------------
00716
00717     // get all regions
00718     iBase_EntitySetHandle temp_ges2;
00719     SimpleArray< iBase_EntityHandle > gregions;
00720
00721     FBiGeom_createEntSet( geom, true, &temp_ges2, &err );
00722     CHECK( "Failed to create a temp gentityset in gentityset_test." );
00723
00724     FBiGeom_getEntities( geom, ges_array[iBase_REGION], iBase_REGION, ARRAY_INOUT( gregions ), &err );
00725     CHECK( "Failed to get gregion gentities in gentityset_test." );
00726
00727     // add REGIONs to temp es2
00728     FBiGeom_addEntArrToSet( geom, ARRAY_IN( gregions ), temp_ges2, &err );
00729     CHECK( "Failed to add gregion gentities in gentityset_test." );
00730
00731     // unite temp_ges1 and temp_ges2
00732     // temp_ges1 gentityset is altered
00733     FBiGeom_unite( geom, temp_ges1, temp_ges2, &temp_ges1, &err );
00734     CHECK( "Failed to unite in gentityset_test." );
00735
00736     // perform the check
00737     FBiGeom_getNumOfType( geom, temp_ges1, iBase_REGION, &num_gents, &err );
00738     CHECK( "Failed to get number of gregion gentities by type in gentityset_test." );
00739
00740     if( num_gents != number_array[iBase_REGION] )
00741     {
00742         std::cerr << "different number of gregions in gentityset_test." << std::endl;
00743         return false;
00744     }
00745
00746     //--------Test parent/child stuff in entiysets-----------
00747
00748     // Add 2 sets as children to another
00749     iBase_EntitySetHandle parent_child;
00750     FBiGeom_createEntSet( geom, true, &parent_child, &err );
00751     CHECK( "Problem creating gentityset in gentityset_test." );
00752
00753     FBiGeom_addPrntChld( geom, ges_array[iBase_VERTEX], parent_child, &err );
00754     CHECK( "Problem add parent in gentityset_test." );
00755
00756     // check if parent is really added
00757     SimpleArray< iBase_EntitySetHandle > parents;
00758     FBiGeom_getPrnts( geom, parent_child, 1, ARRAY_INOUT( parents ), &err );
00759     CHECK( "Problem getting parents in gentityset_test." );
00760
00761     if( parents.size() != 1 )
00762     {
00763         std::cerr << "number of parents is not correct in gentityset_test." << std::endl;
00764         return false;
00765     }
00766
00767     // add parent and child
00768     // sidl::array<void*> parent_child_array = sidl::array<void*>::create1d(1);
00769     // int num_parent_child_array;
00770     // sidl::array<void*> temp_gedge_array = sidl::array<void*>::create1d(1);
00771     // int num_temp_gedge_array;
00772     // parent_child_array.set(0, parent_child);
00773     // temp_gedge_array.set(0, ges_array[TSTTG::EntityType_EDGE]);
00774     FBiGeom_addPrntChld( geom, ges_array[iBase_EDGE], parent_child, &err );
00775     CHECK( "Problem adding parent and child in gentityset_test." );
00776
00777     // sidl::array<void*> temp_gface_array = sidl::array<void*>::create1d(1);
00778     // int num_temp_gface_array;
00779     // temp_gface_array.set(0, ges_array[TSTTG::EntityType_FACE]);
00780     FBiGeom_addPrntChld( geom, parent_child, ges_array[iBase_FACE], &err );
00781     CHECK( "Problem adding parent and child in gentityset_test." );
00782
00783     // add child
00784     FBiGeom_addPrntChld( geom, parent_child, ges_array[iBase_REGION], &err );
00785     CHECK( "Problem adding child in gentityset_test." );
00786
00787     // get the number of parent gentitysets
00788     num_gents = -1;
00789     FBiGeom_getNumPrnt( geom, parent_child, 1, &num_gents, &err );
00790     CHECK( "Problem getting number of parents in gentityset_test." );
00791
00792     if( num_gents != 2 )
00793     {
00794         std::cerr << "number of parents is not correct in gentityset_test." << std::endl;
00795         return false;
00796     }
00797
00798     // get the number of child gentitysets
00799     num_gents = -1;
00800     FBiGeom_getNumChld( geom, parent_child, 1, &num_gents, &err );
00801     CHECK( "Problem getting number of children in gentityset_test." );
00802
00803     if( num_gents != 2 )
00804     {
00805         std::cerr << "number of children is not correct in gentityset_test." << std::endl;
00806         return false;
00807     }
00808
00809     SimpleArray< iBase_EntitySetHandle > children;
00810     FBiGeom_getChldn( geom, parent_child, 1, ARRAY_INOUT( children ), &err );
00811     CHECK( "Problem getting children in gentityset_test." );
00812
00813     if( children.size() != 2 )
00814     {
00815         std::cerr << "number of children is not correct in gentityset_test." << std::endl;
00816         return false;
00817     }
00818
00819     // remove children
00820     FBiGeom_rmvPrntChld( geom, parent_child, ges_array[iBase_FACE], &err );
00821     CHECK( "Problem removing parent child in gentityset_test." );
00822
00823     // get the number of child gentitysets
00824     FBiGeom_getNumChld( geom, parent_child, 1, &num_gents, &err );
00825     CHECK( "Problem getting number of children in gentityset_test." );
00826
00827     if( num_gents != 1 )
00828     {
00829         std::cerr << "number of children is not correct in gentityset_test." << std::endl;
00830         return false;
00831     }
00832
00833     // parent_child and ges_array[TSTTG::EntityType_EDGE] should be related
00834     int result = 0;
00835     FBiGeom_isChildOf( geom, ges_array[iBase_EDGE], parent_child, &result, &err );
00836     CHECK( "Problem checking relation in gentityset_test." );
00837     if( !result )
00838     {
00839         std::cerr << "parent_child and ges_array[TSTTG::EntityType_EDGE] should be related" << std::endl;
00840         return false;
00841     }
00842
00843     // ges_array[TSTTG::EntityType_FACE] and ges_array[TSTTG::REGION] are not related
00844     result = 2;
00845     FBiGeom_isChildOf( geom, ges_array[iBase_FACE], ges_array[iBase_REGION], &result, &err );
00846     if( result )
00847     {
00848         std::cerr << "ges_array[TSTTG::REGION] and ges_array[TSTTG::EntityType_FACE] should not be "
00849                      "related"
00850                   << std::endl;
00851         return false;
00852     }
00853
00854     //--------test modify and query functions-----------------------------
00855
00856     // check the number of gentity sets in whole mesh
00857     SimpleArray< iBase_EntitySetHandle > gentity_sets;
00858     FBiGeom_getEntSets( geom, root_set, 1, ARRAY_INOUT( gentity_sets ), &err );
00859     CHECK( "Problem to get all gentity sets in mesh." );
00860
00861     if( gentity_sets.size() != all_sets + 8 )
00862     {
00863         std::cerr << "the number of gentity sets in whole mesh should be 8 times of num_iter." << std::endl;
00864         return false;
00865     }
00866
00867     // get all gentity sets in super set
00868     SimpleArray< iBase_EntitySetHandle > ges_array1;
00869     FBiGeom_getEntSets( geom, super_set, 1, ARRAY_INOUT( ges_array1 ), &err );
00870     CHECK( "Problem to get gentity sets in super set." );
00871
00872     // get the number of gentity sets in super set
00873     int num_super;
00874     FBiGeom_getNumEntSets( geom, super_set, 1, &num_super, &err );
00875     CHECK( "Problem to get the number of all gentity sets in super set." );
00876
00877     // the number of gentity sets in super set should be same
00878     if( num_super != ges_array1.size() )
00879     {
00880         std::cerr << "the number of gentity sets in super set should be same." << std::endl;
00881         return false;
00882     }
00883
00884     // get all entities in super set
00885     SimpleArray< iBase_EntitySetHandle > all_gentities;
00886     FBiGeom_getEntSets( geom, super_set, 1, ARRAY_INOUT( all_gentities ), &err );
00887     CHECK( "Problem to get all gentities in super set." );
00888
00889     // compare the number of all gentities in super set
00890     // HJK : num_hops is not implemented
00891     // if (num_all_gentities_super != ARRAY_SIZE(all_gentities)) {
00892     // std::cerr << "number of all gentities in super set should be same." << std::endl;
00893     // success = false;
00894     //}
00895
00896     // test add, remove and get all entitiy sets using super set
00897     // check GetAllGentitysets works recursively and dosen't return
00898     // multi sets
00899     for( int k = 0; k < num_super; k++ )
00900     {
00901         // add gentity sets of super set to each gentity set of super set
00902         // make multiple child super sets
00903         iBase_EntitySetHandle ges_k = ges_array1[k];
00904
00905         for( int a = 0; a < ges_array1.size(); a++ )
00906         {
00907             FBiGeom_addEntSet( geom, ges_array1[a], ges_k, &err );
00908             CHECK( "Problem to add entity set." );
00909         }
00910
00911         // add super set to each entity set
00912         //    sidl::array<GentitysetHandle> superset_array
00913         //= sidl::array<GentitysetHandle>::create1d(1);
00914         // superset_array.set(0, super_set);
00915         // int num_superset_array;
00916
00917         FBiGeom_addEntSet( geom, super_set, ges_k, &err );
00918         CHECK( "Problem to add super set to gentitysets." );
00919
00920         // add one gentity sets multiple times
00921         // HJK: ??? how to deal this case?
00922         // sidl::array<GentitysetHandle> temp_array1
00923         //= sidl::array<GentitysetHandle>::create1d(1);
00924         // int num_temp_array1;
00925         // temp_array1.set(0, temp_ges1);
00926
00927         // for (int l = 0; l < 3; l++) {
00928         FBiGeom_addEntSet( geom, temp_ges1, ges_k, &err );
00929         CHECK( "Problem to add temp set to gentitysets." );
00930         //}
00931     }
00932
00933     return true;
00934 }
00935
00936 /*!
00937  @test
00938  TSTTG topology adjacencies Test
00939  @li Check topology information
00940  @li Check adjacency
00941  */
00942 // make each topological entity vectors, check their topology
00943 // types, get interior and exterior faces of model
00944 bool topology_adjacencies_test( FBiGeom_Instance geom )
00945 {
00946     int i, err;
00947     iBase_EntitySetHandle root_set;
00948     FBiGeom_getRootSet( geom, &root_set, &err );
00949     CHECK( "ERROR : getRootSet failed!" );
00950
00951     int top          = iBase_VERTEX;
00952     int num_test_top = iBase_ALL_TYPES;
00953     std::vector< std::vector< iBase_EntityHandle > > gentity_vectors( num_test_top );
00954
00955     // fill the vectors of each topology entities
00956     // like lines vector, polygon vector, triangle vector,
00957     // quadrilateral, polyhedrron, tet, hex, prism, pyramid,
00958     // septahedron vectors
00959     for( i = top; i < num_test_top; i++ )
00960     {
00961         SimpleArray< iBase_EntityHandle > gentities;
00962         FBiGeom_getEntities( geom, root_set, i, ARRAY_INOUT( gentities ), &err );
00963         CHECK( "Failed to get gentities in adjacencies_test." );
00964
00965         gentity_vectors[i].resize( gentities.size() );
00966         std::copy( gentities.begin(), gentities.end(), gentity_vectors[i].begin() );
00967     }
00968
00969     // check number of entities for each topology
00970     for( i = top; i < num_test_top; i++ )
00971     {
00972         int num_tops = 0;
00973         FBiGeom_getNumOfType( geom, root_set, i, &num_tops, &err );
00974         CHECK( "Failed to get number of gentities in adjacencies_test." );
00975
00976         if( static_cast< int >( gentity_vectors[i].size() ) != num_tops )
00977         {
00978             std::cerr << "Number of gentities doesn't agree with number returned for dimension " << i << std::endl;
00979             return false;
00980         }
00981     }
00982
00983     // check adjacencies in both directions
00984     std::vector< iBase_EntityHandle >::iterator vit;
00985     for( i = iBase_REGION; i >= iBase_VERTEX; i-- )
00986     {
00987         for( vit = gentity_vectors[i].begin(); vit != gentity_vectors[i].end(); ++vit )
00988         {
00989             iBase_EntityHandle this_gent = *vit;
00990
00991             // check downward adjacencies
00992             for( int j = iBase_VERTEX; j < i; j++ )
00993             {
00994
00995                 SimpleArray< iBase_EntityHandle > lower_ents;
00996                 FBiGeom_getEntAdj( geom, this_gent, j, ARRAY_INOUT( lower_ents ), &err );
00997                 CHECK( "Bi-directional adjacencies test failed." );
00998
00999                 // for each of them, make sure they are adjacent to the upward ones
01000                 int num_lower = lower_ents.size();
01001                 for( int k = 0; k < num_lower; k++ )
01002                 {
01003                     SimpleArray< iBase_EntityHandle > upper_ents;
01004                     FBiGeom_getEntAdj( geom, lower_ents[k], i, ARRAY_INOUT( upper_ents ), &err );
01005                     CHECK( "Bi-directional adjacencies test failed." );
01006                     if( std::find( upper_ents.begin(), upper_ents.end(), this_gent ) == upper_ents.end() )
01007                     {
01008                         std::cerr << "Didn't find lower-upper adjacency which was supposed to be "
01009                                      "there, dims = "
01010                                   << i << ", " << j << std::endl;
01011                         return false;
01012                     }
01013                 }
01014             }
01015         }
01016     }
01017
01018     return true;
01019 }
01020
01021 /*!
01022  @test
01023  FBiGeom_MOAB topology adjacencies Test
01024  @li Check topology information
01025  @li Check adjacency
01026  */
01027 // make each topological entity vectors, check their topology
01028 // types, get interior and exterior faces of model
01029 bool geometry_evaluation_test( FBiGeom_Instance geom )
01030 {
01031     int i, err;
01032     iBase_EntitySetHandle root_set;
01033     FBiGeom_getRootSet( geom, &root_set, &err );
01034     CHECK( "ERROR : getRootSet failed!" );
01035
01036     int top          = iBase_VERTEX;
01037     int num_test_top = iBase_ALL_TYPES;
01038     std::vector< std::vector< iBase_EntityHandle > > gentity_vectors( num_test_top );
01039
01040     // fill the vectors of each topology entities
01041     // like lines vector, polygon vector, triangle vector,
01042     // quadrilateral, polyhedrron, tet, hex, prism, pyramid,
01043     // septahedron vectors
01044     for( i = top; i < num_test_top; i++ )
01045     {
01046         SimpleArray< iBase_EntityHandle > gentities;
01047         FBiGeom_getEntities( geom, root_set, i, ARRAY_INOUT( gentities ), &err );
01048         CHECK( "Failed to get gentities in adjacencies_test." );
01049
01050         gentity_vectors[i].resize( gentities.size() );
01051         std::copy( gentities.begin(), gentities.end(), gentity_vectors[i].begin() );
01052     }
01053
01054     // check adjacencies in both directions
01055     double min[3], max[3], on[3];
01056     double near[3] = { .0, .0, .0 };
01057     std::vector< iBase_EntityHandle >::iterator vit;
01058     for( i = iBase_REGION; i >= iBase_VERTEX; i-- )
01059     {
01060         if( i != iBase_EDGE )
01061         {
01062             for( vit = gentity_vectors[i].begin(); vit != gentity_vectors[i].end(); ++vit )
01063             {
01064                 iBase_EntityHandle this_gent = *vit;
01065                 FBiGeom_getEntBoundBox( geom, this_gent, &min[0], &min[1], &min[2], &max[0], &max[1], &max[2], &err );
01066                 CHECK( "Failed to get bounding box of entity." );
01067
01068                 for( int j = 0; j < 3; j++ )
01069                     near[j] = ( min[j] + max[j] ) / 2;
01070                 FBiGeom_getEntClosestPt( geom, this_gent, near[0], near[1], near[2], &on[0], &on[1], &on[2], &err );
01071                 CHECK( "Failed to get closest point on entity." );
01072                 std::cout << " entity of type " << i << " closest point to \n  " << near[0] << " " << near[1] << " "
01073                           << near[2] << "\n  is " << on[0] << " " << on[1] << " " << on[2] << "\n";
01074             }
01075         }
01076     }
01077
01078     return true;
01079 }
01080 //
01081 //  test normals evaluations on the surface only
01082 bool normals_test( FBiGeom_Instance geom )
01083 {
01084     int i, err;
01085     iBase_EntitySetHandle root_set;
01086     FBiGeom_getRootSet( geom, &root_set, &err );
01087     CHECK( "ERROR : getRootSet failed!" );
01088
01089     int top          = iBase_VERTEX;
01090     int num_test_top = iBase_ALL_TYPES;
01091     std::vector< std::vector< iBase_EntityHandle > > gentity_vectors( num_test_top );
01092
01093     // fill the vectors of each topology entities
01094     // like lines vector, polygon vector, triangle vector,
01095     // quadrilateral, polyhedrron, tet, hex, prism, pyramid,
01096     // septahedron vectors
01097     for( i = top; i < num_test_top; i++ )
01098     {
01099         SimpleArray< iBase_EntityHandle > gentities;
01100         FBiGeom_getEntities( geom, root_set, i, ARRAY_INOUT( gentities ), &err );
01101         CHECK( "Failed to get gentities in adjacencies_test." );
01102
01103         gentity_vectors[i].resize( gentities.size() );
01104         std::copy( gentities.begin(), gentities.end(), gentity_vectors[i].begin() );
01105     }
01106
01107     // check adjacencies in both directions
01108     double min[3], max[3];
01109     double normal[3] = { .0, .0, .0 };
01110     std::vector< iBase_EntityHandle >::iterator vit;
01111     for( i = iBase_REGION; i > iBase_EDGE; i-- )
01112     {
01113         for( vit = gentity_vectors[i].begin(); vit != gentity_vectors[i].end(); ++vit )
01114         {
01115             iBase_EntityHandle this_gent = *vit;
01116             FBiGeom_getEntBoundBox( geom, this_gent, &min[0], &min[1], &min[2], &max[0], &max[1], &max[2], &err );
01117             CHECK( "Failed to get bounding box of entity." );
01118
01119             FBiGeom_getEntNrmlXYZ( geom, this_gent, ( max[0] + min[0] ) / 2, ( max[1] + min[1] ) / 2,
01120                                    ( max[2] + min[2] ) / 2, &normal[0], &normal[1], &normal[2], &err );
01121
01122             CHECK( "Failed to get normal to the closest point." );
01123             std::cout << " entity of type " << i << " closest normal to center:\n  " << normal[0] << " " << normal[1]
01124                       << " " << normal[2] << "\n";
01125         }
01126     }
01127
01128     return true;
01129 }
01130
01131 //  test normals evaluations on the surface only
01132 bool ray_test( FBiGeom_Instance geom )
01133 {
01134     int err;
01135     iBase_EntitySetHandle root_set;
01136     FBiGeom_getRootSet( geom, &root_set, &err );
01137     CHECK( "ERROR : getRootSet failed!" );
01138
01139     int top = iBase_FACE;
01140
01141     SimpleArray< iBase_EntityHandle > faces;
01142     FBiGeom_getEntities( geom, root_set, top, ARRAY_INOUT( faces ), &err );
01143     CHECK( "Failed to get gentities in adjacencies_test." );
01144
01145     // check only the first face
01146
01147     // check adjacencies in both directions
01148     double min[3], max[3];
01149
01150     iBase_EntityHandle first_face = faces[0];
01151
01152     FBiGeom_getEntBoundBox( geom, first_face, &min[0], &min[1], &min[2], &max[0], &max[1], &max[2], &err );
01153     CHECK( "Failed to get bounding box of entity." );
01154
01155     // assume that the ray shot from the bottom of the box (middle) is a pretty good candidate
01156     // in z direction
01157     double x = ( min[0] + max[0] ) / 2, y = ( min[1] + max[1] ) / 2, z = min[2];
01158     SimpleArray< iBase_EntityHandle > intersect_entity_handles;
01159     SimpleArray< double > intersect_coords;
01160     SimpleArray< double > param_coords;
01161     FBiGeom_getPntRayIntsct( geom, x, y, z,  // shot from
01162                              0., 0., 1.,     // direction
01163                              ARRAY_INOUT( intersect_entity_handles ), iBase_INTERLEAVED,
01164                              ARRAY_INOUT( intersect_coords ), ARRAY_INOUT( param_coords ), &err );
01165
01166     CHECK( "Failed to find ray intersections points " );
01167     for( int i = 0; i < intersect_entity_handles.size(); i++ )
01168     {
01169         int j;
01170         FBiGeom_getEntType( geom, intersect_entity_handles[i], &j, &err );
01171         CHECK( "Failed to get type of entity." );
01172
01173         std::cout << " entity of type " << j << " n: " << intersect_entity_handles[i] << "\n"
01174                   << intersect_coords[3 * i] << " " << intersect_coords[3 * i + 1] << " " << intersect_coords[3 * i + 2]
01175                   << "\n"
01176                   << " distance: " << param_coords[i] << "\n";
01177     }
01178
01179     return true;
01180 }
01181
01182 /*!
01183  @test
01184  TSTTG construct Test
01185  @li Check construction of geometry
01186  */
01187 bool construct_test( FBiGeom_Instance geom )
01188 {
01189     int err;
01190     iBase_EntityHandle new_body = 0;
01191
01192     // construct a cylinder, sweep it about an axis, and delete the result
01193     iBase_EntityHandle cyl = 0;
01194     FBiGeom_createCylinder( geom, 1.0, 1.0, 0.0, &cyl, &err );
01195     // Is the minor radius really supposed to be zero??? - JK
01196     CHECK( "Creating cylinder failed." );
01197
01198     // move it onto the y axis
01199     FBiGeom_moveEnt( geom, cyl, 0.0, 1.0, -0.5, &err );
01200     CHECK( "Problems moving surface." );
01201
01202     // get the surface with max z
01203     iBase_EntityHandle max_surf = 0;
01204     SimpleArray< iBase_EntityHandle > surfs;
01205     FBiGeom_getEntAdj( geom, cyl, iBase_FACE, ARRAY_INOUT( surfs ), &err );
01206     CHECK( "Problems getting max surf for rotation." );
01207
01208     SimpleArray< double > max_corn, min_corn;
01209     FBiGeom_getArrBoundBox( geom, ARRAY_IN( surfs ), iBase_INTERLEAVED, ARRAY_INOUT( min_corn ),
01210                             ARRAY_INOUT( max_corn ), &err );
01211     CHECK( "Problems getting max surf for rotation." );
01212     double dtol = 1.0e-6;
01213     for( int i = 0; i < surfs.size(); ++i )
01214     {
01215         if( ( max_corn[3 * i + 2] ) <= dtol && ( max_corn[3 * i + 2] ) >= -dtol && ( min_corn[3 * i + 2] ) <= dtol &&
01216             ( min_corn[3 * i + 2] ) >= -dtol )
01217         {
01218             max_surf = surfs[i];
01219             break;
01220         }
01221     }
01222
01223     if( 0 == max_surf )
01224     {
01225         std::cerr << "Couldn't find max surf for rotation." << std::endl;
01226         return false;
01227     }
01228
01229     // sweep it around the x axis
01230     FBiGeom_moveEnt( geom, cyl, 0.0, 1.0, 0.0, &err );
01231     CHECK( "Problems moving surface." );
01232
01233     FBiGeom_sweepEntAboutAxis( geom, max_surf, 360.0, 1.0, 0.0, 0.0, &new_body, &err );
01234     CHECK( "Problems sweeping surface about axis." );
01235
01236     // now delete
01237     FBiGeom_deleteEnt( geom, new_body, &err );
01238     CHECK( "Problems deleting cylinder or swept surface body." );
01239
01240     // if we got here, we were successful
01241     return true;
01242 }
01243
01244 static bool compare_box( const double* expected_min,
01245                          const double* expected_max,
01246                          const double* actual_min,
01247                          const double* actual_max )
01248 {
01249     bool same   = true;
01250     double dtol = 1.0e-6;
01251
01252     for( int i = 0; i < 3; ++i )
01253     {
01254         if( expected_min[i] < actual_min[i] - dtol || expected_min[i] * 10 > actual_min[i] ||
01255             expected_max[i] > actual_max[i] + dtol || expected_max[i] * 10 < actual_max[i] )
01256             same = false;
01257     }
01258     return same;
01259 }
01260
01261 bool primitives_test( FBiGeom_Instance geom )
01262 {
01263     int err;
01264     SimpleArray< iBase_EntityHandle > prims( 3 );
01265     iBase_EntityHandle prim;
01266
01267     FBiGeom_createBrick( geom, 1.0, 2.0, 3.0, &prim, &err );
01268     CHECK( "createBrick failed." );
01269     prims[0] = prim;
01270
01271     FBiGeom_createCylinder( geom, 1.0, 4.0, 2.0, &prim, &err );
01272     CHECK( "createCylinder failed." );
01273     prims[1] = prim;
01274
01275     FBiGeom_createTorus( geom, 2.0, 1.0, &prim, &err );
01276     CHECK( "createTorus failed." );
01277     prims[2] = prim;
01278
01279     // verify the bounding boxes for Acis based entities
01280     SimpleArray< double > max_corn, min_corn;
01281     FBiGeom_getArrBoundBox( geom, ARRAY_IN( prims ), iBase_INTERLEAVED, ARRAY_INOUT( min_corn ),
01282                             ARRAY_INOUT( max_corn ), &err );
01283
01284     double preset_min_corn[] =
01285         // min brick corner xyz
01286         { -0.5, -1.0, -1.5,
01287           // min cyl corner xyz
01288           -4.0, -2.0, -0.5,
01289           // min torus corner xyz
01290           -3.0, -3.0, -1.0 };
01291
01292     double preset_max_corn[] =
01293         // max brick corner xyz
01294         { 0.5, 1.0, 1.5,
01295           // max cyl corner xyz
01296           4.0, 2.0, 0.5,
01297           // max torus corner xyz
01298           3.0, 3.0, 1.0 };
01299
01300     if( !compare_box( preset_min_corn, preset_max_corn, &min_corn[0], &max_corn[0] ) )
01301     {
01302         std::cerr << "Box check failed for brick" << std::endl;
01303         return false;
01304     }
01305
01306     if( !compare_box( preset_min_corn + 3, preset_max_corn + 3, &min_corn[3], &max_corn[3] ) )
01307     {
01308         std::cerr << "Box check failed for cylinder" << std::endl;
01309         return false;
01310     }
01311
01312     if( !compare_box( preset_min_corn + 6, preset_max_corn + 6, &min_corn[6], &max_corn[6] ) )
01313     {
01314         std::cerr << "Box check failed for torus" << std::endl;
01315         return false;
01316     }
01317     // must have worked; delete the entities then return
01318     for( int i = 0; i < 3; ++i )
01319     {
01320         FBiGeom_deleteEnt( geom, prims[i], &err );
01321         CHECK( "Problems deleting primitive after boolean check." );
01322     }
01323
01324     return true;
01325 }
01326
01327 bool transforms_test( FBiGeom_Instance geom )
01328 {
01329     int err;
01330
01331     // construct a brick
01332     iBase_EntityHandle brick = 0;
01333     FBiGeom_createBrick( geom, 1.0, 2.0, 3.0, &brick, &err );
01334     CHECK( "Problems creating brick for transforms test." );
01335
01336     // move it, then test bounding box
01337     FBiGeom_moveEnt( geom, brick, 0.5, 1.0, 1.5, &err );
01338     CHECK( "Problems moving brick for transforms test." );
01339
01340     double bb_min[3], bb_max[3];
01341     FBiGeom_getEntBoundBox( geom, brick, bb_min, bb_min + 1, bb_min + 2, bb_max, bb_max + 1, bb_max + 2, &err );
01342     CHECK( "Problems getting bounding box after move." );
01343
01344     double dtol = 1.0e-6;
01345     if( ( bb_min[0] ) >= dtol || ( bb_min[0] ) <= -dtol || ( bb_min[1] ) >= dtol || ( bb_min[1] ) <= -dtol ||
01346         ( bb_min[2] ) >= dtol || ( bb_min[2] ) <= -dtol || ( bb_max[0] - 1 ) >= dtol || 1 - bb_max[0] >= dtol ||
01347         ( bb_max[1] - 2 ) >= dtol || 2 - bb_max[1] >= dtol || ( bb_max[2] - 3 ) >= dtol || 3 - bb_max[2] >= dtol )
01348     {
01349         std::cerr << "Wrong bounding box after move." << std::endl;
01350         return false;
01351     }
01352
01353     // now rotate it about +x, then test bounding box
01354     FBiGeom_rotateEnt( geom, brick, 90, 1.0, 0.0, 0.0, &err );
01355     CHECK( "Problems rotating brick for transforms test." );
01356
01357     FBiGeom_getEntBoundBox( geom, brick, bb_min, bb_min + 1, bb_min + 2, bb_max, bb_max + 1, bb_max + 2, &err );
01358     CHECK( "Problems getting bounding box after rotate." );
01359
01360     if( ( bb_min[0] ) >= dtol || -bb_min[0] >= dtol || ( bb_min[1] + 3 ) >= dtol || -( bb_min[1] + 3 ) >= dtol ||
01361         ( bb_min[2] ) >= dtol || -( bb_min[2] ) >= dtol || ( bb_max[0] - 1 ) >= dtol || 1 - bb_max[0] >= dtol ||
01362         ( bb_max[1] ) >= dtol || -( bb_max[1] ) >= dtol || ( bb_max[2] - 2 ) >= dtol || 2 - bb_max[2] >= dtol )
01363     {
01364         std::cerr << "Wrong bounding box after rotate." << std::endl;
01365         return false;
01366     }
01367
01368     // now reflect through y plane; should recover original bb
01369     FBiGeom_reflectEnt( geom, brick, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, &err );
01370     CHECK( "Problems reflecting brick for transforms test." );
01371
01372     FBiGeom_getEntBoundBox( geom, brick, bb_min, bb_min + 1, bb_min + 2, bb_max, bb_max + 1, bb_max + 2, &err );
01373     CHECK( "Problems getting bounding box after reflect." );
01374
01375     if( ( bb_min[0] ) >= dtol || -( bb_min[0] ) >= dtol || ( bb_min[1] ) >= dtol || ( bb_min[2] ) >= dtol ||
01376         -( bb_min[1] ) >= dtol || -( bb_min[2] ) >= dtol || ( bb_max[0] - 1 ) >= dtol || 1 - bb_max[0] >= dtol ||
01377         ( bb_max[1] - 3 ) >= dtol || 3 - bb_max[1] >= dtol || ( bb_max[2] - 2 ) >= dtol || 2 - bb_max[2] >= dtol )
01378     {
01379         std::cerr << "Wrong bounding box after reflect." << std::endl;
01380         return false;
01381     }
01382
01383     // must have worked; delete the entities then return
01384     FBiGeom_deleteEnt( geom, brick, &err );
01385     CHECK( "Problems deleting brick after transforms check." );
01386     return true;
01387 }
01388
01389 bool booleans_test( FBiGeom_Instance geom )
01390 {
01391     int err;
01392
01393     // construct a brick size 1, and a cylinder rad 0.25 height 2
01394     iBase_EntityHandle brick = 0, cyl = 0;
01395     FBiGeom_createBrick( geom, 1.0, 0.0, 0.0, &brick, &err );
01396     CHECK( "Problems creating brick for booleans test." );
01397     FBiGeom_createCylinder( geom, 1.0, 0.25, 0.0, &cyl, &err );
01398     CHECK( "Problems creating cylinder for booleans test." );
01399
01400     // subtract the cylinder from the brick
01401     iBase_EntityHandle subtract_result = 0;
01402     FBiGeom_subtractEnts( geom, brick, cyl, &subtract_result, &err );
01403     CHECK( "Problems subtracting for booleans subtract test." );
01404
01405     // section the brick
01406     iBase_EntityHandle section_result = 0;
01407     FBiGeom_sectionEnt( geom, subtract_result, 1.0, 0.0, 0.0, 0.25, true, &section_result, &err );
01408     CHECK( "Problems sectioning for booleans section test." );
01409
01410     // unite the section result with a new cylinder
01411     FBiGeom_createCylinder( geom, 1.0, 0.25, 0.0, &cyl, &err );
01412     CHECK( "Problems creating cylinder for unite test." );
01413     iBase_EntityHandle unite_results;
01414     iBase_EntityHandle unite_input[] = { section_result, cyl };
01415     FBiGeom_uniteEnts( geom, unite_input, 2, &unite_results, &err );
01416     CHECK( "Problems uniting for booleans unite test." );
01417
01418     FBiGeom_deleteEnt( geom, unite_results, &err );
01419     CHECK( "Problems deleting for booleans unite test." );
01420     return true;
01421 }
01422
01423 static int get_entities( FBiGeom_Instance geom,
01424                          int entity_type,
01425                          std::vector< iBase_EntityHandle >& entities_out,
01426                          iBase_TagHandle id_tag      = 0,
01427                          std::vector< int >* ids_out = 0 )
01428 {
01429     int err, num;
01430     iBase_EntitySetHandle root;
01431     FBiGeom_getRootSet( geom, &root, &err );
01432     if( iBase_SUCCESS != err ) return err;
01433     FBiGeom_getNumOfType( geom, root, entity_type, &num, &err );
01434     if( iBase_SUCCESS != err ) return err;
01435
01436     entities_out.resize( num );
01437     int junk1                    = entities_out.size(), junk2;
01438     iBase_EntityHandle* junk_ptr = &entities_out[0];
01439     ;
01440     FBiGeom_getEntities( geom, root, entity_type, &junk_ptr, &junk1, &junk2, &err );
01441     if( iBase_SUCCESS != err ) return err;
01442     assert( num == junk1 && num == junk2 );
01443
01444     if( !ids_out ) return iBase_SUCCESS;
01445
01446     ids_out->resize( num );
01447     int* int_ptr = &( *ids_out )[0];
01448     FBiGeom_getIntArrData( geom, &entities_out[0], num, id_tag, &int_ptr, &junk1, &junk2, &err );
01449     if( iBase_SUCCESS != err ) return err;
01450     assert( num == junk1 && num == junk2 );
01451
01452     return iBase_SUCCESS;
01453 }
01454
01455 static int check_firmness( FBiGeom_Instance geom,
01456                            const std::vector< iBase_EntityHandle >& entities,
01457                            const std::vector< int >& ids,
01458                            iBase_TagHandle firmness_tag,
01459                            const char* expected_value,
01460                            const char* ent_type_str )
01461 {
01462     const int firmness_size = 4;
01463     std::vector< char > firmness( firmness_size * entities.size() );
01464
01465     char* byte_ptr = &firmness[0];
01466     int err, junk1 = firmness.size(), junk2 = entities.size() * firmness_size;
01467     FBiGeom_getArrData( geom, &entities[0], entities.size(), firmness_tag, (void**)&byte_ptr, &junk1, &junk2, &err );
01468     if( iBase_SUCCESS != err ) return err;
01469
01470     bool all_correct = true;
01471     for( unsigned i = 0; i < entities.size(); ++i )
01472         if( std::string( &firmness[firmness_size * i], firmness_size ) != expected_value ) all_correct = false;
01473     if( !all_correct )
01474     {
01475         std::cout << "ERROR: Expected \"" << expected_value << "\" firmness "
01476                   << "for all " << ent_type_str << "." << std::endl;
01477         std::cout << "ID  Actual  " << std::endl;
01478         for( unsigned i = 0; i < entities.size(); ++i )
01479             std::cout << std::setw( 2 ) << ids[i] << "  " << std::string( &firmness[firmness_size * i], firmness_size )
01480                       << std::endl;
01481         return iBase_FAILURE;
01482     }
01483
01484     return iBase_SUCCESS;
01485 }
01486
01487 static int count_num_with_tag( FBiGeom_Instance geom,
01488                                const std::vector< iBase_EntityHandle >& ents,
01489                                iBase_TagHandle tag )
01490 {
01491     int err, bytes;
01492     FBiGeom_getTagSizeBytes( geom, tag, &bytes, &err );
01493     if( iBase_SUCCESS != err ) return -1;
01494     std::vector< char > data( bytes );
01495
01496     int success_count = 0;
01497     for( size_t i = 0; i < ents.size(); ++i )
01498     {
01499         char* ptr = &data[0];
01500         int junk1 = bytes, junk2;
01501         FBiGeom_getData( geom, ents[i], tag, (void**)&ptr, &junk1, &junk2, &err );
01502         if( iBase_TAG_NOT_FOUND == err ) continue;
01503         if( iBase_SUCCESS != err ) return -1;
01504         ++success_count;
01505     }
01506
01507     return success_count;
01508 }
01509
01510 bool mesh_size_test( FBiGeom_Instance geom )
01511 {
01512     const char* filename = STRINGIFY( SRCDIR ) "/size.sat";
01513     int err, junk1, junk2;
01514     bool result = true;
01515
01516     FBiGeom_deleteAll( geom, &err );
01517     CHECK( "" );
01518     FBiGeom_load( geom, filename, 0, &err, strlen( filename ), 0 );
01519     CHECK( "Failed to load input file: 'size.sat'" );
01520
01521     // get tag handles
01522     iBase_TagHandle interval, size, firmness, id;
01523     FBiGeom_getTagHandle( geom, "MESH_INTERVAL", &interval, &err, strlen( "MESH_INTERVAL" ) );
01524     CHECK( "FBiGeom_getTagHandle(\"MESH_INTERVAL\")" );
01525     FBiGeom_getTagHandle( geom, "MESH_SIZE", &size, &err, strlen( "MESH_SIZE" ) );
01526     CHECK( "FBiGeom_getTagHandle(\"MESH_SIZE\")" );
01527     FBiGeom_getTagHandle( geom, "SIZE_FIRMNESS", &firmness, &err, strlen( "SIZE_FIRMNESS" ) );
01528     CHECK( "FBiGeom_getTagHandle(\"SIZE_FIRMNESS\")" );
01529     FBiGeom_getTagHandle( geom, "GLOBAL_ID", &id, &err, strlen( "GLOBAL_ID" ) );
01530     CHECK( "FBiGeom_getTagHandle(\"GLOBAL_ID\")" );
01531
01532     // get entity lists
01533     std::vector< iBase_EntityHandle > verts, curves, surfs, vols;
01534     std::vector< int > vert_ids, curve_ids, surf_ids, vol_ids;
01535     err = get_entities( geom, iBase_VERTEX, verts, id, &vert_ids );
01536     CHECK( "" );
01537     err = get_entities( geom, iBase_EDGE, curves, id, &curve_ids );
01538     CHECK( "" );
01539     err = get_entities( geom, iBase_FACE, surfs, id, &surf_ids );
01540     CHECK( "" );
01541     err = get_entities( geom, iBase_REGION, vols, id, &vol_ids );
01542     CHECK( "" );
01543
01544     // expect interval count to be the same as ID for every curve
01545     std::vector< int > intervals( curves.size() );
01546     int* int_ptr = &intervals[0];
01547     junk1 = junk2 = curves.size();
01548     FBiGeom_getIntArrData( geom, &curves[0], curves.size(), interval, &int_ptr, &junk1, &junk2, &err );
01549     CHECK( "Failed to get intervals for curves" );
01550     if( intervals != curve_ids )
01551     {
01552         std::cout << "ERROR: Incorrect curve intervals for one or more curves." << std::endl;
01553         std::cout << "ID  Expected  Actual" << std::endl;
01554         for( unsigned i = 0; i < curves.size(); ++i )
01555             std::cout << std::setw( 2 ) << curve_ids[i] << "  " << std::setw( 8 ) << curve_ids[i] << "  "
01556                       << std::setw( 6 ) << intervals[i] << std::endl;
01557         result = false;
01558     }
01559
01560     // expect size to be the same as ID for every surface
01561     std::vector< double > sizes( surfs.size() );
01562     double* dbl_ptr = &sizes[0];
01563     junk1 = junk2 = surfs.size();
01564     FBiGeom_getDblArrData( geom, &surfs[0], surfs.size(), size, &dbl_ptr, &junk1, &junk2, &err );
01565     CHECK( "Failed to get sizes for surfaces" );
01566     bool all_correct = true;
01567     for( unsigned i = 0; i < surfs.size(); ++i )
01568         if( fabs( sizes[i] - (double)surf_ids[i] ) > 1e-8 ) all_correct = false;
01569     if( !all_correct )
01570     {
01571         std::cout << "ERROR: Incorrect mesh size for one or more surfaces." << std::endl;
01572         std::cout << "ID  Expected  Actual  " << std::endl;
01573         for( unsigned i = 0; i < surfs.size(); ++i )
01574             std::cout << std::setw( 2 ) << surf_ids[i] << "  " << std::setw( 8 ) << (double)surf_ids[i] << "  "
01575                       << std::setw( 8 ) << sizes[i] << std::endl;
01576         result = false;
01577     }
01578
01579     err = result ? iBase_SUCCESS : iBase_FAILURE;
01580     CHECK( "Invalid size or interval data" );
01581
01582     // expect "HARD" firmness on all curves
01583     err = check_firmness( geom, curves, curve_ids, firmness, "HARD", "curves" );
01584     CHECK( "Invalid curve firmness" );
01585     // expect "SOFT" firmness on all surfaces
01586     err = check_firmness( geom, surfs, surf_ids, firmness, "SOFT", "surfaces" );
01587     CHECK( "Invalid surface firmness" );
01588
01589     // expect no firmnes on other entities
01590     err = count_num_with_tag( geom, verts, firmness ) ? iBase_FAILURE : iBase_SUCCESS;
01591     CHECK( "Got firmness for vertex." );
01592     err = count_num_with_tag( geom, vols, firmness ) ? iBase_FAILURE : iBase_SUCCESS;
01593     CHECK( "Got firmness for volume." );
01594
01595     // expect no interval tag on any entities except curves
01596     err = count_num_with_tag( geom, verts, interval ) ? iBase_FAILURE : iBase_SUCCESS;
01597     CHECK( "Got interval count for vertex." );
01598     err = count_num_with_tag( geom, vols, interval ) ? iBase_FAILURE : iBase_SUCCESS;
01599     CHECK( "Got interval count for volume." );
01600
01601     // expect no size tag on any entities except surfaces
01602     // curves should have size of one of their parent surfaces
01603     err = count_num_with_tag( geom, verts, size ) ? iBase_FAILURE : iBase_SUCCESS;
01604     CHECK( "Got mesh size for vertex." );
01605     err = count_num_with_tag( geom, vols, size ) ? iBase_FAILURE : iBase_SUCCESS;
01606     CHECK( "Got mesh size for volume." );
01607
01608     return true;
01609 }
01610
01611 bool shutdown_test2( FBiGeom_Instance geom, std::string& /*engine_opt*/ )
01612 {
01613     int err;
01614
01615     // test shutdown2
01616     FBiGeom_dtor2( geom, &err );
01617     CHECK( "Interface destruction didn't work properly." );
01618
01619     //   FBiGeom_newGeom(engine_opt.c_str(), &geom, &err, engine_opt.length());
01620     //   CHECK( "Interface re-construction didn't work properly." );
01621     //
01622     //   FBiGeom_dtor(geom, &err);
01623     //   CHECK( "2nd Interface destruction didn't work properly." );
01624
01625     return true;
01626 }
01627
01628 bool save_entset_test( FBiGeom_Instance geom )
01629 {
01630     int err;
01631
01632 #ifdef FORCE_OCC
01633     std::string filename = "testout.brep";
01634 #elif defined( HAVE_ACIS )
01635     std::string filename = "testout.sat";
01636 #elif defined( HAVE_OCC )
01637     std::string filename = "testout.brep";
01638 #else
01639     std::string filename = "testout.sat";
01640 #endif
01641
01642     // initialize number of ents and sets to compare with later
01643     int num_ents_bef, num_sets_bef;
01644     iBase_EntitySetHandle root;
01645     FBiGeom_getRootSet( geom, &root, &err );
01646     CHECK( "Failed to get root set." );
01647     FBiGeom_getNumEntSets( geom, root, 1, &num_sets_bef, &err );
01648     CHECK( "Failed to get number of ent sets." );
01649     FBiGeom_getNumOfType( geom, root, iBase_REGION, &num_ents_bef, &err );
01650     CHECK( "Failed to get number of entities." );
01651
01652     // create set, and entity to add to set
01653     iBase_EntityHandle cyl;
01654     FBiGeom_createCylinder( geom, 1.0, 0.25, 0.0, &cyl, &err );
01655     CHECK( "Problems creating cylinder for save entset test." );
01656     iBase_EntitySetHandle seth;
01657     FBiGeom_createEntSet( geom, true, &seth, &err );
01658     CHECK( "Problems creating entity set for save entset test." );
01659
01660     // add the entity
01661     FBiGeom_addEntToSet( geom, cyl, seth, &err );
01662     CHECK( "Problems adding entity to set for save entset test." );
01663
01664     // save/restore the model, and see if the entity is there
01665     FBiGeom_save( geom, filename.c_str(), NULL, &err, filename.length(), 0 );
01666     CHECK( "Problems saving file for save entset test." );
01667
01668     FBiGeom_destroyEntSet( geom, seth, &err );
01669     CHECK( "Failed to destroy entity set." );
01670     FBiGeom_deleteEnt( geom, cyl, &err );
01671     CHECK( "Failed to destroy entity." );
01672
01673     // read the file back in
01674     FBiGeom_load( geom, filename.c_str(), NULL, &err, filename.length(), 0 );
01675     CHECK( "Problems reading file for save entset test." );
01676
01677     // check number of sets and entities
01678     int num_ents_aft, num_sets_aft;
01679     FBiGeom_getNumEntSets( geom, root, 1, &num_sets_aft, &err );
01680     CHECK( "Failed to get number of ent sets." );
01681     FBiGeom_getNumOfType( geom, root, iBase_REGION, &num_ents_aft, &err );
01682     CHECK( "Failed to get number of entities." );
01683     bool success = true;
01684     if( num_ents_aft != 2 * num_ents_bef + 1 )
01685     {
01686         print_error( "Failed to get the right number of entities.", iBase_FAILURE, geom, __FILE__, __LINE__ );
01687         success = false;
01688     }
01689     else if( num_sets_aft != 2 * num_sets_bef + 1 )
01690     {
01691         print_error( "Failed to get the right number of entity sets.", iBase_FAILURE, geom, __FILE__, __LINE__ );
01692         success = false;
01693     }
01694
01695     // otherwise, we succeeded
01696     return success;
01697 }
