iMesh.h File Reference
#include "iBase.h"
#include "iMesh_protos.h"
+ Include dependency graph for iMesh.h:
+ This graph shows which files directly or indirectly include this file:
Defines
#define IMESH_VERSION_MAJOR   ITAPS_VERSION_MAJOR
 Compile time version number digits.
#define IMESH_VERSION_MINOR   ITAPS_VERSION_MINOR
#define IMESH_VERSION_PATCH   ITAPS_VERSION_PATCH
#define IMESH_MAJOR_VERSION   IMESH_VERSION_MAJOR
 Maintain backward compatibility with old version symbol names.
#define IMESH_MINOR_VERSION   IMESH_VERSION_MINOR
#define IMESH_PATCH_VERSION   IMESH_VERSION_PATCH
#define IMESH_VERSION_GE(Maj, Min, Pat)   ITAPS_VERSION_GE( Maj, Min, Pat )
 Version Comparison.
#define IMESH_VERSION_STRING   ITAPS_VERSION_STRING_( iMesh )
 Compose string represention of the iMesh version number.
#define IMESH_VERSION_TAG   ITAPS_VERSION_TAG_( iMesh )
 Compose a symbol name derived from the current iMesh version number.
#define IMESH_NEW_MESH_NAME__(A, B, C)   A##_##B##_##C
 Define iMesh_newMesh symbol such that it depends on version number.
#define IMESH_NEW_MESH_NAME_(A, B, C)   IMESH_NEW_MESH_NAME__( A, B, C )
#define IMESH_NEW_MESH_NAME(A)   IMESH_NEW_MESH_NAME_( A, IMESH_VERSION_MAJOR, IMESH_VERSION_MINOR )
Typedefs
typedef struct
iMesh_Instance_Private *
iMesh_Instance
 iMesh instance
Enumerations
enum  iMesh_EntityTopology {
  iMesh_EntityTopology_MIN = 0, iMesh_POINT = iMesh_EntityTopology_MIN, iMesh_LINE_SEGMENT, iMesh_POLYGON,
  iMesh_TRIANGLE, iMesh_QUADRILATERAL, iMesh_POLYHEDRON, iMesh_TETRAHEDRON,
  iMesh_HEXAHEDRON, iMesh_PRISM, iMesh_PYRAMID, iMesh_SEPTAHEDRON,
  iMesh_ALL_TOPOLOGIES, iMesh_EntityTopology_MAX = iMesh_ALL_TOPOLOGIES
 Entity Topology. More...
Functions
void iMesh_getErrorType (iMesh_Instance instance, int *error_type)
 Get the error type returned from the last iMesh function.
void iMesh_getDescription (iMesh_Instance instance, char *descr, int descr_len)
 Get a description of the error returned from the last iMesh function.
void iMesh_newMesh (const char *options, iMesh_Instance *instance, int *err, int options_len)
 Construct a new iMesh instance.
void iMesh_dtor (iMesh_Instance instance, int *err)
 Destroy an iMesh instance.
void iMesh_load (iMesh_Instance instance, const iBase_EntitySetHandle entity_set_handle, const char *name, const char *options, int *err, int name_len, int options_len)
 Load a mesh from a file.
void iMesh_save (iMesh_Instance instance, const iBase_EntitySetHandle entity_set_handle, const char *name, const char *options, int *err, const int name_len, int options_len)
 Save a mesh to a file.
void iMesh_getRootSet (iMesh_Instance instance, iBase_EntitySetHandle *root_set, int *err)
 Get handle of the root set for this instance.
void iMesh_getGeometricDimension (iMesh_Instance instance, int *geom_dim, int *err)
 Get the geometric dimension of mesh represented in this instance.
void iMesh_setGeometricDimension (iMesh_Instance instance, int geom_dim, int *err)
 Set geometric dimension of vertex coordinates.
void iMesh_getDfltStorage (iMesh_Instance instance, int *order, int *err)
 Get the default storage order used by this implementation.
void iMesh_getAdjTable (iMesh_Instance instance, int **adjacency_table, int *adjacency_table_allocated, int *adjacency_table_size, int *err)
 Get the adjacency table for this implementation.
void iMesh_setAdjTable (iMesh_Instance instance, int *adjacency_table, int adjacency_table_size, int *err)
 Set the adjacency table as requested by the application.
void iMesh_getNumOfType (iMesh_Instance instance, const iBase_EntitySetHandle entity_set_handle, const int entity_type, int *num_type, int *err)
 Get the number of entities of specified type in the instance or set.
void iMesh_getNumOfTopo (iMesh_Instance instance, const iBase_EntitySetHandle entity_set_handle, const int entity_topology, int *num_topo, int *err)
 Get the number of entities of specified topology in instance or set.
void iMesh_optimize (iMesh_Instance instance, int *handles_invalidated, int *err)
 Permit implementation to 'optimize' the mesh instance.
void iMesh_getEntities (iMesh_Instance instance, const iBase_EntitySetHandle entity_set_handle, const int entity_type, const int entity_topology, iBase_EntityHandle **entity_handles, int *entity_handles_allocated, int *entity_handles_size, int *err)
 Get entities of specific type and/or topology in set or instance.
void iMesh_getVtxArrCoords (iMesh_Instance instance, const iBase_EntityHandle *vertex_handles, const int vertex_handles_size, const int storage_order, double **coords, int *coords_allocated, int *coords_size, int *err)
 Get coordinates of specified vertices.
void iMesh_initEntArrIter (iMesh_Instance instance, const iBase_EntitySetHandle entity_set_handle, const int requested_entity_type, const int requested_entity_topology, const int requested_array_size, const int resilient, iBase_EntityArrIterator *entArr_iterator, int *err)
 Initialize an array iterator over specified entity type, topology, and size.
void iMesh_getNextEntArrIter (iMesh_Instance instance, iBase_EntityArrIterator entArr_iterator, iBase_EntityHandle **entity_handles, int *entity_handles_allocated, int *entity_handles_size, int *has_data, int *err)
 Get entities contained in array iterator and increment iterator.
void iMesh_resetEntArrIter (iMesh_Instance instance, iBase_EntityArrIterator entArr_iterator, int *err)
 Reset the array iterator.
void iMesh_endEntArrIter (iMesh_Instance instance, iBase_EntityArrIterator entArr_iterator, int *err)
 Destroy the specified array iterator.
void iMesh_getEntArrTopo (iMesh_Instance instance, const iBase_EntityHandle *entity_handles, const int entity_handles_size, int **topology, int *topology_allocated, int *topology_size, int *err)
 Get the entity topology for the specified entities.
void iMesh_getEntArrType (iMesh_Instance instance, const iBase_EntityHandle *entity_handles, const int entity_handles_size, int **type, int *type_allocated, int *type_size, int *err)
 Get the entity type for the specified entities.
void iMesh_getEntArrAdj (iMesh_Instance instance, const iBase_EntityHandle *entity_handles, const int entity_handles_size, const int entity_type_requested, iBase_EntityHandle **adjacentEntityHandles, int *adjacentEntityHandles_allocated, int *adj_entity_handles_size, int **offset, int *offset_allocated, int *offset_size, int *err)
 Get entities of specified type adjacent to entities.
void iMesh_getEntArr2ndAdj (iMesh_Instance instance, iBase_EntityHandle const *entity_handles, int entity_handles_size, int bridge_entity_type, int requested_entity_type, iBase_EntityHandle **adj_entity_handles, int *adj_entity_handles_allocated, int *adj_entity_handles_size, int **offset, int *offset_allocated, int *offset_size, int *err)
 Get "2nd order" adjacencies to an array of entities.
void iMesh_getAdjEntIndices (iMesh_Instance instance, iBase_EntitySetHandle entity_set_handle, int entity_type_requester, int entity_topology_requester, int entity_type_requested, iBase_EntityHandle **entity_handles, int *entity_handles_allocated, int *entity_handles_size, iBase_EntityHandle **adj_entity_handles, int *adj_entity_handles_allocated, int *adj_entity_handles_size, int **adj_entity_indices, int *adj_entity_indices_allocated, int *adj_entity_indices_size, int **offset, int *offset_allocated, int *offset_size, int *err)
 Get indexed representation of mesh or subset of mesh.
void iMesh_createEntSet (iMesh_Instance instance, const int isList, iBase_EntitySetHandle *entity_set_created, int *err)
 Create an entity set.
void iMesh_destroyEntSet (iMesh_Instance instance, iBase_EntitySetHandle entity_set, int *err)
 Destroy an entity set.
void iMesh_isList (iMesh_Instance instance, const iBase_EntitySetHandle entity_set, int *is_list, int *err)
 Return whether a specified set is ordered or unordered.
void iMesh_getNumEntSets (iMesh_Instance instance, const iBase_EntitySetHandle entity_set_handle, const int num_hops, int *num_sets, int *err)
void iMesh_getEntSets (iMesh_Instance instance, const iBase_EntitySetHandle entity_set_handle, const int num_hops, iBase_EntitySetHandle **contained_set_handles, int *contained_set_handles_allocated, int *contained_set_handles_size, int *err)
void iMesh_addEntToSet (iMesh_Instance instance, iBase_EntityHandle entity_handle, iBase_EntitySetHandle entity_set, int *err)
 Add an entity to a set.
void iMesh_rmvEntFromSet (iMesh_Instance instance, iBase_EntityHandle entity_handle, iBase_EntitySetHandle entity_set, int *err)
 Remove an entity from a set.
void iMesh_addEntArrToSet (iMesh_Instance instance, const iBase_EntityHandle *entity_handles, int entity_handles_size, iBase_EntitySetHandle entity_set, int *err)
 Add an array of entities to a set.
void iMesh_rmvEntArrFromSet (iMesh_Instance instance, const iBase_EntityHandle *entity_handles, int entity_handles_size, iBase_EntitySetHandle entity_set, int *err)
 Remove an array of entities from a set.
void iMesh_addEntSet (iMesh_Instance instance, iBase_EntitySetHandle entity_set_to_add, iBase_EntitySetHandle entity_set_handle, int *err)
 Add an entity set to a set.
void iMesh_rmvEntSet (iMesh_Instance instance, iBase_EntitySetHandle entity_set_to_remove, iBase_EntitySetHandle entity_set_handle, int *err)
 Remove an entity set from a set.
void iMesh_isEntContained (iMesh_Instance instance, iBase_EntitySetHandle containing_entity_set, iBase_EntityHandle contained_entity, int *is_contained, int *err)
 Return whether an entity is contained in another set.
void iMesh_isEntArrContained (iMesh_Instance instance, iBase_EntitySetHandle containing_entity_set, const iBase_EntityHandle *entity_handles, int num_entity_handles, int **is_contained, int *is_contained_allocated, int *is_contained_size, int *err)
 Return whether entities are contained in a set.
void iMesh_isEntSetContained (iMesh_Instance instance, const iBase_EntitySetHandle containing_entity_set, const iBase_EntitySetHandle contained_entity_set, int *is_contained, int *err)
 Return whether an entity set is contained in another set.
void iMesh_addPrntChld (iMesh_Instance instance, iBase_EntitySetHandle parent_entity_set, iBase_EntitySetHandle child_entity_set, int *err)
 Add parent/child links between two sets.
void iMesh_rmvPrntChld (iMesh_Instance instance, iBase_EntitySetHandle parent_entity_set, iBase_EntitySetHandle child_entity_set, int *err)
 Remove parent/child links between two sets.
void iMesh_isChildOf (iMesh_Instance instance, const iBase_EntitySetHandle parent_entity_set, const iBase_EntitySetHandle child_entity_set, int *is_child, int *err)
 Return whether two sets are related by parent/child links.
void iMesh_getNumChld (iMesh_Instance instance, const iBase_EntitySetHandle entity_set, const int num_hops, int *num_child, int *err)
 Get the number of child sets linked from a specified set.
void iMesh_getNumPrnt (iMesh_Instance instance, const iBase_EntitySetHandle entity_set, const int num_hops, int *num_parent, int *err)
 Get the number of parent sets linked from a specified set.
void iMesh_getChldn (iMesh_Instance instance, const iBase_EntitySetHandle from_entity_set, const int num_hops, iBase_EntitySetHandle **entity_set_handles, int *entity_set_handles_allocated, int *entity_set_handles_size, int *err)
 Get the child sets linked from a specified set.
void iMesh_getPrnts (iMesh_Instance instance, const iBase_EntitySetHandle from_entity_set, const int num_hops, iBase_EntitySetHandle **entity_set_handles, int *entity_set_handles_allocated, int *entity_set_handles_size, int *err)
 Get the parent sets linked from a specified set.
void iMesh_setVtxArrCoords (iMesh_Instance instance, const iBase_EntityHandle *vertex_handles, const int vertex_handles_size, const int storage_order, const double *new_coords, const int new_coords_size, int *err)
 Set coordinates for an array of vertices.
void iMesh_createVtxArr (iMesh_Instance instance, const int num_verts, const int storage_order, const double *new_coords, const int new_coords_size, iBase_EntityHandle **new_vertex_handles, int *new_vertex_handles_allocated, int *new_vertex_handles_size, int *err)
 Create an array of new vertices at specified coordinates.
void iMesh_createEntArr (iMesh_Instance instance, const int new_entity_topology, const iBase_EntityHandle *lower_order_entity_handles, const int lower_order_entity_handles_size, iBase_EntityHandle **new_entity_handles, int *new_entity_handles_allocated, int *new_entity_handles_size, int **status, int *status_allocated, int *status_size, int *err)
 Create an array of new entities with specified lower-order topology.
void iMesh_deleteEntArr (iMesh_Instance instance, const iBase_EntityHandle *entity_handles, const int entity_handles_size, int *err)
 Delete specified entities.
void iMesh_createTag (iMesh_Instance instance, const char *tag_name, const int tag_size, const int tag_type, iBase_TagHandle *tag_handle, int *err, const int tag_name_len)
 Create a tag with specified name, size, and type.
void iMesh_destroyTag (iMesh_Instance instance, iBase_TagHandle tag_handle, const int forced, int *err)
 Destroy a tag.
void iMesh_getTagName (iMesh_Instance instance, const iBase_TagHandle tag_handle, char *name, int *err, int name_len)
 Get the name for a given tag handle.
void iMesh_getTagSizeValues (iMesh_Instance instance, const iBase_TagHandle tag_handle, int *tag_size, int *err)
 Get size of a tag in units of numbers of tag data type.
void iMesh_getTagSizeBytes (iMesh_Instance instance, const iBase_TagHandle tag_handle, int *tag_size, int *err)
 Get size of a tag in units of bytes.
void iMesh_getTagHandle (iMesh_Instance instance, const char *tag_name, iBase_TagHandle *tag_handle, int *err, int tag_name_len)
 Get a the handle of an existing tag with the specified name.
void iMesh_getTagType (iMesh_Instance instance, const iBase_TagHandle tag_handle, int *tag_type, int *err)
 Get the data type of the specified tag handle.
void iMesh_setEntSetData (iMesh_Instance instance, iBase_EntitySetHandle entity_set_handle, const iBase_TagHandle tag_handle, const void *tag_value, const int tag_value_size, int *err)
 Set a tag value of arbitrary type on an entity set.
void iMesh_setEntSetIntData (iMesh_Instance instance, iBase_EntitySetHandle entity_set, const iBase_TagHandle tag_handle, const int tag_value, int *err)
void iMesh_setEntSetDblData (iMesh_Instance instance, iBase_EntitySetHandle entity_set, const iBase_TagHandle tag_handle, const double tag_value, int *err)
void iMesh_setEntSetEHData (iMesh_Instance instance, iBase_EntitySetHandle entity_set, const iBase_TagHandle tag_handle, const iBase_EntityHandle tag_value, int *err)
void iMesh_setEntSetESHData (iMesh_Instance instance, iBase_EntitySetHandle entity_set, const iBase_TagHandle tag_handle, const iBase_EntitySetHandle tag_value, int *err)
 Set a tag value of entity set handle type on an.
void iMesh_getEntSetData (iMesh_Instance instance, const iBase_EntitySetHandle entity_set_handle, const iBase_TagHandle tag_handle, void *tag_value, int *tag_value_allocated, int *tag_value_size, int *err)
 Get the value of a tag of arbitrary type on an entity set.
void iMesh_getEntSetIntData (iMesh_Instance instance, const iBase_EntitySetHandle entity_set, const iBase_TagHandle tag_handle, int *out_data, int *err)
void iMesh_getEntSetDblData (iMesh_Instance instance, const iBase_EntitySetHandle entity_set, const iBase_TagHandle tag_handle, double *out_data, int *err)
void iMesh_getEntSetEHData (iMesh_Instance instance, const iBase_EntitySetHandle entity_set, const iBase_TagHandle tag_handle, iBase_EntityHandle *out_data, int *err)
void iMesh_getEntSetESHData (iMesh_Instance instance, const iBase_EntitySetHandle entity_set, const iBase_TagHandle tag_handle, iBase_EntitySetHandle *out_data, int *err)
 Get the value of a tag of entity set handle type on an.
void iMesh_getAllEntSetTags (iMesh_Instance instance, const iBase_EntitySetHandle entity_set_handle, iBase_TagHandle **tag_handles, int *tag_handles_allocated, int *tag_handles_size, int *err)
 Get all the tags associated with a specified entity set.
void iMesh_rmvEntSetTag (iMesh_Instance instance, iBase_EntitySetHandle entity_set_handle, const iBase_TagHandle tag_handle, int *err)
 Remove a tag value from an entity set.
void iMesh_setVtxCoord (iMesh_Instance instance, iBase_EntityHandle vertex_handle, const double x, const double y, const double z, int *err)
 Set coordinates for a vertex.
void iMesh_createVtx (iMesh_Instance instance, const double x, const double y, const double z, iBase_EntityHandle *new_vertex_handle, int *err)
 Create a new vertex at specified coordinates.
void iMesh_createEnt (iMesh_Instance instance, const int new_entity_topology, const iBase_EntityHandle *lower_order_entity_handles, const int lower_order_entity_handles_size, iBase_EntityHandle *new_entity_handle, int *status, int *err)
 Create a new entity with specified lower-order topology.
void iMesh_deleteEnt (iMesh_Instance instance, iBase_EntityHandle entity_handle, int *err)
 Delete specified entity.
void iMesh_getArrData (iMesh_Instance instance, const iBase_EntityHandle *entity_handles, const int entity_handles_size, const iBase_TagHandle tag_handle, void *tag_values, int *tag_values_allocated, int *tag_values_size, int *err)
 Get tag values of arbitrary type for an array of entities.
void iMesh_getIntArrData (iMesh_Instance instance, const iBase_EntityHandle *entity_handles, const int entity_handles_size, const iBase_TagHandle tag_handle, int **tag_values, int *tag_values_allocated, int *tag_values_size, int *err)
void iMesh_getDblArrData (iMesh_Instance instance, const iBase_EntityHandle *entity_handles, const int entity_handles_size, const iBase_TagHandle tag_handle, double **tag_values, int *tag_values_allocated, int *tag_values_size, int *err)
void iMesh_getEHArrData (iMesh_Instance instance, const iBase_EntityHandle *entity_handles, const int entity_handles_size, const iBase_TagHandle tag_handle, iBase_EntityHandle **tag_value, int *tag_value_allocated, int *tag_value_size, int *err)
void iMesh_getESHArrData (iMesh_Instance instance, const iBase_EntityHandle *entity_handles, const int entity_handles_size, const iBase_TagHandle tag_handle, iBase_EntitySetHandle **tag_value, int *tag_value_allocated, int *tag_value_size, int *err)
 Get tag values of entity set handle type for an array of.
void iMesh_setArrData (iMesh_Instance instance, const iBase_EntityHandle *entity_handles, const int entity_handles_size, const iBase_TagHandle tag_handle, const void *tag_values, const int tag_values_size, int *err)
 Set tag values of arbitrary type on an array of entities.
void iMesh_setIntArrData (iMesh_Instance instance, const iBase_EntityHandle *entity_handles, const int entity_handles_size, const iBase_TagHandle tag_handle, const int *tag_values, const int tag_values_size, int *err)
void iMesh_setDblArrData (iMesh_Instance instance, const iBase_EntityHandle *entity_handles, const int entity_handles_size, const iBase_TagHandle tag_handle, const double *tag_values, const int tag_values_size, int *err)
void iMesh_setEHArrData (iMesh_Instance instance, const iBase_EntityHandle *entity_handles, const int entity_handles_size, const iBase_TagHandle tag_handle, const iBase_EntityHandle *tag_values, const int tag_values_size, int *err)
void iMesh_setESHArrData (iMesh_Instance instance, const iBase_EntityHandle *entity_handles, const int entity_handles_size, const iBase_TagHandle tag_handle, const iBase_EntitySetHandle *tag_values, const int tag_values_size, int *err)
 Set tag values of entity set handle type on an array of.
void iMesh_rmvArrTag (iMesh_Instance instance, const iBase_EntityHandle *entity_handles, const int entity_handles_size, const iBase_TagHandle tag_handle, int *err)
 Remove a tag value from an array of entities.
void iMesh_getData (iMesh_Instance instance, const iBase_EntityHandle entity_handle, const iBase_TagHandle tag_handle, void *tag_value, int *tag_value_allocated, int *tag_value_size, int *err)
 Get the value of a tag of arbitrary type on an entity.
void iMesh_getIntData (iMesh_Instance instance, const iBase_EntityHandle entity_handle, const iBase_TagHandle tag_handle, int *out_data, int *err)
void iMesh_getDblData (iMesh_Instance instance, const iBase_EntityHandle entity_handle, const iBase_TagHandle tag_handle, double *out_data, int *err)
void iMesh_getEHData (iMesh_Instance instance, const iBase_EntityHandle entity_handle, const iBase_TagHandle tag_handle, iBase_EntityHandle *out_data, int *err)
void iMesh_getESHData (iMesh_Instance instance, const iBase_EntityHandle entity_handle, const iBase_TagHandle tag_handle, iBase_EntitySetHandle *out_data, int *err)
void iMesh_setData (iMesh_Instance instance, iBase_EntityHandle entity_handle, const iBase_TagHandle tag_handle, const void *tag_value, const int tag_value_size, int *err)
 Set a tag value of arbitrary type on an entity.
void iMesh_setIntData (iMesh_Instance instance, iBase_EntityHandle entity_handle, const iBase_TagHandle tag_handle, const int tag_value, int *err)
void iMesh_setDblData (iMesh_Instance instance, iBase_EntityHandle entity_handle, const iBase_TagHandle tag_handle, const double tag_value, int *err)
void iMesh_setEHData (iMesh_Instance instance, iBase_EntityHandle entity_handle, const iBase_TagHandle tag_handle, const iBase_EntityHandle tag_value, int *err)
void iMesh_setESHData (iMesh_Instance instance, iBase_EntityHandle entity_handle, const iBase_TagHandle tag_handle, const iBase_EntitySetHandle tag_value, int *err)
void iMesh_getAllTags (iMesh_Instance instance, const iBase_EntityHandle entity_handle, iBase_TagHandle **tag_handles, int *tag_handles_allocated, int *tag_handles_size, int *err)
 Get all the tags associated with a specified entity handle.
void iMesh_rmvTag (iMesh_Instance instance, iBase_EntityHandle entity_handle, const iBase_TagHandle tag_handle, int *err)
 Remove a tag value from an entity.
void iMesh_initEntIter (iMesh_Instance instance, const iBase_EntitySetHandle entity_set_handle, const int requested_entity_type, const int requested_entity_topology, const int resilient, iBase_EntityIterator *entity_iterator, int *err)
 Initialize an iterator over specified entity type, topology, and size.
void iMesh_getNextEntIter (iMesh_Instance instance, iBase_EntityIterator entity_iterator, iBase_EntityHandle *entity_handle, int *has_data, int *err)
 Get entity corresponding to an iterator and increment iterator.
void iMesh_resetEntIter (iMesh_Instance instance, iBase_EntityIterator entity_iterator, int *err)
 Reset the iterator.
void iMesh_endEntIter (iMesh_Instance instance, iBase_EntityIterator entity_iterator, int *err)
 Destroy the specified iterator.
void iMesh_getEntTopo (iMesh_Instance instance, const iBase_EntityHandle entity_handle, int *out_topo, int *err)
 Get the entity topology for the specified entity.
void iMesh_getEntType (iMesh_Instance instance, const iBase_EntityHandle entity_handle, int *out_type, int *err)
 Get the entity type for the specified entity.
void iMesh_getVtxCoord (iMesh_Instance instance, const iBase_EntityHandle vertex_handle, double *x, double *y, double *z, int *err)
 Get coordinates of specified vertex.
void iMesh_getEntAdj (iMesh_Instance instance, const iBase_EntityHandle entity_handle, const int entity_type_requested, iBase_EntityHandle **adj_entity_handles, int *adj_entity_handles_allocated, int *adj_entity_handles_size, int *err)
 Get entities of specified type adjacent to an entity.
void iMesh_getEnt2ndAdj (iMesh_Instance instance, iBase_EntityHandle entity_handle, int bridge_entity_type, int requested_entity_type, iBase_EntityHandle **adjacent_entities, int *adjacent_entities_allocated, int *adjacent_entities_size, int *err)
 Get "2nd order" adjacencies to an entity.
void iMesh_subtract (iMesh_Instance instance, const iBase_EntitySetHandle entity_set_1, const iBase_EntitySetHandle entity_set_2, iBase_EntitySetHandle *result_entity_set, int *err)
 Subtract contents of one entity set from another.
void iMesh_intersect (iMesh_Instance instance, const iBase_EntitySetHandle entity_set_1, const iBase_EntitySetHandle entity_set_2, iBase_EntitySetHandle *result_entity_set, int *err)
 Intersect contents of one entity set with another.
void iMesh_unite (iMesh_Instance instance, const iBase_EntitySetHandle entity_set_1, const iBase_EntitySetHandle entity_set_2, iBase_EntitySetHandle *result_entity_set, int *err)
 Unite contents of one entity set with another.
Define Documentation
VersionNumbers
Definition at line 48 of file iMesh.h.
Definition at line 49 of file iMesh.h.
Definition at line 110 of file iMesh.h.
#define IMESH_NEW_MESH_NAME_ (   A,
  B,
Definition at line 109 of file iMesh.h.
#define IMESH_NEW_MESH_NAME__ (   A,
  B,
)    A##_##B##_##C
VersionNumbers Note: We ran into problems with this as it influences or is influenced by fortran name mangling and so breaks fortran compilation. So, this is currently disabled.
Definition at line 108 of file iMesh.h.
Definition at line 50 of file iMesh.h.
#define IMESH_VERSION_GE (   Maj,
  Min,
  Pat
Version Comparison.
VersionNumbers Evaluates to true at CPP time if the version of iMesh currently being compiled is greater than or equal to the version specified.
Definition at line 66 of file iMesh.h.
VersionNumbers iMesh maintains a major, minor and patch digit in its version number. Technically speaking, there is not much practical value in patch digit for an interface specification. A patch release is typically only used for bug fix releases. Although it is rare, sometimes a bug fix necessitates an API change. So, we define a patch digit for iMesh.
Definition at line 35 of file iMesh.h.
Definition at line 36 of file iMesh.h.
Definition at line 37 of file iMesh.h.
VersionNumbers
Definition at line 76 of file iMesh.h.
VersionNumbers
Definition at line 87 of file iMesh.h.
Function Documentation
void iMesh_addEntArrToSet ( iMesh_Instance  instance,
const iBase_EntityHandle entity_handles,
int *  err
Parameters:
[in]instanceiMesh instance handle
[in]entity_handlesArray of entities being added
[in]entity_handles_sizeNumber of entities in entity_handles array
[in]entity_setPointer to the set being added to
[out]errReturned Error status (see iBase_ErrorType)
Definition at line 1022 of file iMesh_MOAB.cpp.
References CHKERR, CONST_HANDLE_ARRAY_PTR, ENTITY_HANDLE, ErrorCode, iBase_SUCCESS, MOABI, and RETURN.
    const EntityHandle* ents = CONST_HANDLE_ARRAY_PTR( entity_handles );
    ErrorCode result         = MOABI->add_entities( ENTITY_HANDLE( entity_set ), ents, entity_handles_size );
    CHKERR( result, "iMesh_addEntArrToSet:ERROR adding entities in EntitySet." );
    RETURN( iBase_SUCCESS );
void iMesh_addEntSet ( iMesh_Instance  instance,
int *  err
Add an entity set to a set (Cycles)
Parameters:
[in]entity_set_to_addThe entity set being added
[in]entity_set_handlePointer to the set being added to
Definition at line 1065 of file iMesh_MOAB.cpp.
References CHKERR, ENTITY_HANDLE, ERROR, ErrorCode, iBase_INVALID_ARGUMENT, iBase_SUCCESS, MOABI, and RETURN.
    if( !entity_set_to_add || !entity_set_handle )
        ERROR( iBase_INVALID_ARGUMENT, "iMesh_addEntSet: ERROR invalid argument" );
    EntityHandle to_add = ENTITY_HANDLE( entity_set_to_add );
    ErrorCode result    = MOABI->add_entities( ENTITY_HANDLE( entity_set_handle ), &to_add, 1 );
    CHKERR( result, "iMesh_addEntSet:ERROR adding entitysets." );
void iMesh_addEntToSet ( iMesh_Instance  instance,
int *  err
Parameters:
[in]entity_handleThe entity being added
Definition at line 1035 of file iMesh_MOAB.cpp.
References iMesh_addEntArrToSet.
    iMesh_addEntArrToSet( instance, &entity_handle, 1, entity_set, err );
void iMesh_addPrntChld ( iMesh_Instance  instance,
int *  err
ParentChildLinks Add parent/child links between two sets. Makes parent point to child and child point to parent. (Cycles)
Parameters:
[in]parent_entity_setPointer to parent set
[in]child_entity_setPointer to child set
Definition at line 1145 of file iMesh_MOAB.cpp.
References CHKERR, ENTITY_HANDLE, ERROR, ErrorCode, iBase_INVALID_ENTITYSET_HANDLE, iBase_SUCCESS, MB_ENTITY_NOT_FOUND, MOABI, and RETURN.
    ErrorCode result = MOABI->add_parent_child( ENTITY_HANDLE( parent_entity_set ), ENTITY_HANDLE( child_entity_set ) );
    if( result == MB_ENTITY_NOT_FOUND )
        ERROR( iBase_INVALID_ENTITYSET_HANDLE, "iMesh_addPrntChld: ERROR invalid entity set." );CHKERR( result, "iMesh_addPrntChld: ERROR addParentChild failed." );
void iMesh_createEntSet ( iMesh_Instance  instance,
const int  isList,
iBase_EntitySetHandle entity_set_created,
int *  err
Create an entity set, either ordered (isList=1) or unordered (isList=0). Unordered entity sets can contain a given entity or set only once.
An entity set in iMesh supports managing its contained members in one of two modes. When an entitiy set is first created, the caller is required to indicate which mode of membership the set will support. The two modes that are supported are a) order-preserving (isList=1) or b) duplicate-preventing (isList=0).
For order-preserving membership, the implementation will permit duplicate entities. However, the implementation will guarantee that the order in which entities are added to the set will be the same as the order in which they are queried by the various methods that return the entities of a set. This order preserving guarantee holds across removals. However, it does not hold across removals followed by re-additions of the previously removed entities. This kind of an entity set behaves like an STL vector or STL list and is created by setting isList=1 when creating an entity set.
For duplicate-preventing membership, the implementation will guarantee that duplicate entities are prevented. Any attempts to add duplicate entities to such a set will be detected, prevented and silently ignored by the implementation. This kind of entity set behaves like an STL set and is created by setting isList=0 when creating an entity set.
Finally, all of the above comments apply only to entity members of an entity set and do not apply to the entity set members. Order-preserving and duplicate preventing behavior for entity set members is unspecified. Each implementation may behave differently for entity set members. This design was chosen because we could not identify any use cases where order-preserving behavior for set members was necessary. However, if users encounter situations where such behavior is desirable or necessary, then the ITAPS development team can certainly consider adjusting the interface specification to support it.
Parameters:
[in]isListIf non-zero, an ordered list is created, otherwise an unordered set is created.
[out]entity_set_createdEntity set created by function
Definition at line 946 of file iMesh_MOAB.cpp.
References CHKERR, ErrorCode, iBase_SUCCESS, MESHSET_SET, MOABI, and RETURN.
    // create the entity set
    EntityHandle meshset;
    ErrorCode result;
    if( isList )
        result = MOABI->create_meshset( MESHSET_ORDERED, meshset );
    else
        result = MOABI->create_meshset( MESHSET_SET, meshset );
    CHKERR( result, "iMesh_createEntSet: ERROR creating a entityset instance" );
    // return EntitySet_Handle
    *entity_set_created = (iBase_EntitySetHandle)meshset;
void iMesh_createVtx ( iMesh_Instance  instance,
const double  x,
const double  y,
const double  z,
iBase_EntityHandle new_vertex_handle,
int *  err
VertexEntities Create a new vertex at specified coordinates.
Parameters:
[in]xx coordinate of new vertex
[in]yy coordinate of new vertex
[in]zz coordinate of new vertex
[out]new_vertex_handlePointer to new vertex handles returned from
Definition at line 1817 of file iMesh_MOAB.cpp.
References moab::dum, iBase_BLOCKED, iMesh_createVtxArr, and MOABI.
    int dum             = 1;
    const double xyz[3] = { x, y, z };
    int geom_dim;
    MOABI->get_dimension( geom_dim );
    iMesh_createVtxArr( instance, 1, iBase_BLOCKED, xyz, geom_dim, &new_vertex_handle, &dum, &dum, err );
void iMesh_createVtxArr ( iMesh_Instance  instance,
const double *  new_coords,
iBase_EntityHandle **  new_vertex_handles,
int *  new_vertex_handles_allocated,
int *  new_vertex_handles_size,
int *  err
VertexEntities Create an array of new vertices at specified coordinates. Value of storage_order must be either iBase_INTERLEAVED or iBase_BLOCKED.
Parameters:
[in]num_vertsNumber of new vertices to be created
[in]storage_orderStorage order of coordinates in new_coords array (see iBase_StorageOrder)
[in]new_coordsArray of coordinates of new vertices. Should be G*num_verts in length where G is geometric dimension of the mesh.
[in]new_coords_sizeNumber of coordinates in new_coords array, should
[in,out]new_vertex_handlesPointer to array of new vertex handles Array pointer, allocated and occupied sizes argument trio)
[in,out]new_vertex_handles_allocatedPointer to allocated size of
[out]new_vertex_handles_sizePointer to occupied size of
Definition at line 1325 of file iMesh_MOAB.cpp.
References ALLOC_CHECK_ARRAY, CHKERR, ERROR, ErrorCode, HANDLE_ARRAY_PTR, iBase_INTERLEAVED, iBase_INVALID_ARGUMENT, iBase_SUCCESS, KEEP_ARRAY, MOABI, and RETURN.
    int geom_dim;
    if( new_coords_size != geom_dim * num_verts )
        ERROR( iBase_INVALID_ARGUMENT, "iMesh_createVtxArr: Didn't get the right # coordinates." );
    // if there aren't any elements in the array, allocate it
    ALLOC_CHECK_ARRAY( new_vertex_handles, num_verts );
    // make the entities
    EntityHandle* new_verts = HANDLE_ARRAY_PTR( *new_vertex_handles );
    if( storage_order == iBase_INTERLEAVED )
        if( 3 == geom_dim )
            for( int i = 0; i < num_verts; i++ )
                ErrorCode result = MOABI->create_vertex( &new_coords[3 * i], new_verts[i] );CHKERR( result, "iMesh_createVtxArr: couldn't create vertex." );
        else
            double tmp[3] = { 0, 0, 0 };
                for( int j = 0; j < geom_dim; j++ )
                    tmp[j] = new_coords[geom_dim * i + j];
                ErrorCode result = MOABI->create_vertex( tmp, new_verts[i] );CHKERR( result, "iMesh_createVtxArr: couldn't create vertex." );
    else
                tmp[j] = new_coords[j * num_verts + i];
    KEEP_ARRAY( new_vertex_handles );
void iMesh_destroyEntSet ( iMesh_Instance  instance,
int *  err
Parameters:
[in]entity_setEntity set to be destroyed
Definition at line 967 of file iMesh_MOAB.cpp.
References CHKERR, ENTITY_HANDLE, ErrorCode, iBase_SUCCESS, MOABI, and RETURN.
    EntityHandle set = ENTITY_HANDLE( entity_set );
    ErrorCode result = MOABI->delete_entities( &set, 1 );CHKERR( result, "iMesh_destroyEntSet: couldn't delete the set." );
void iMesh_dtor ( iMesh_Instance  instance,
int *  err
Initialization
Parameters:
Definition at line 287 of file iMesh_MOAB.cpp.
References iBase_SUCCESS, and MBIMESHI.
    delete MBIMESHI;
    *err = iBase_SUCCESS;
void iMesh_endEntArrIter ( iMesh_Instance  instance,
int *  err
EntityIterators
Parameters:
[in]entArr_iteratorIterator which gets destroyed
Definition at line 550 of file iMesh_MOAB.cpp.
References iBase_SUCCESS, and RETURN.
    delete entArr_iterator;
void iMesh_endEntIter ( iMesh_Instance  instance,
int *  err
EntityIterators Destroy the specified iterator
Parameters:
[in]entity_iteratorIterator which gets destroyed
Definition at line 2277 of file iMesh_MOAB.cpp.
References iMesh_endEntArrIter.
    iMesh_endEntArrIter( instance, reinterpret_cast< iBase_EntityArrIterator >( entity_iterator ), err );
void iMesh_getAdjEntIndices ( iMesh_Instance  instance,
iBase_EntityHandle **  entity_handles,
int *  entity_handles_allocated,
int *  entity_handles_size,
iBase_EntityHandle **  adj_entity_handles,
int *  adj_entity_handles_allocated,
int *  adj_entity_handles_size,
int **  adj_entity_indices,
int *  adj_entity_indices_allocated,
int *  adj_entity_indices_size,
int **  offset,
int *  offset_allocated,
int *  offset_size,
int *  err
Adjacencies Given an entity set and optionally a type or topology, return:
  • The entities in the set of the specified type or topology
  • The entities adjacent to those entities with a specified type, as a list of unique handles.
  • For each entity in the first list, the adjacent entities, specified as indices into the second list.
Note 1: Because 'adjacent' as defined by the iMesh data model refers to those entities that bound another, the entities being queried here (in entity_set_handle arg) are NEVER ALSO returned in adj_entity_handles even if the entity_type_requested matches the entity type(s) in entity_set_handle. Note 2: The entities adjacent to the ith entity in entity_handles are found in adj_entity_handles running from offset[i] to offset[i+1]
  • 1. This implies that the offset_size will be entity_handles_size + 1. Note 3: This function will fail and return an error if the caller passes a combination of entity_type and entity_topology that are not consistent.
Parameters:
[in]entity_set_handleThe set of entities from which to query
[in]entity_type_requesterIf not iBase_ALL_TYPES, act only on the subset of entities contained in entity_set_handle of the specified type.
[in]entity_topology_requesterIf not iMesh_ALL_TOPOLOGIES, act only on the subset of entities contained in entity_set_handle of specified topology.
[in]entity_type_requestedThe type of the adjacent entities to return
[in,out]entity_handlesThe handles of the (non-struct) subset of the entities contained in entity_set_handle indicated by the optional type and topology filtering arguments. Array pointer, allocated and occupied sizes argument trio)
[in,out]entity_handles_allocatedAllocated size of entity_handles array
[out]entity_handles_sizeOccupied size of entity_handles array
[in,out]adj_entity_handlesThe union of the unique entities of type requested_entity_type adjacent to each entity in entity_handles. Note that the implicit INTERLEAVED storage order rule applies (see iBase_StorageOrder) Array pointer, allocated and occupied sizes argument trio)
[in,out]adj_entity_handles_allocatedAllocated size of adj_entity_handles array
[out]adj_entity_handles_sizeOccupied size of adj_entity_handles array
[in,out]adj_entity_indicesFor each entity in entity_handles, the adjacent entities of type entity_type_requested, specified as indices into adj_entity_handles. The values are concatenated into a single array in the order of the entity handles in entity_handles. Array pointer, allocated and occupied sizes argument trio)
[in,out]adj_entity_indices_allocatedAllocated size of adj_entity_indices array
[out]adj_entity_indices_sizeOccupied size of adj_entity_indices array
[in,out]offsetFor each entity in the corresponding position in entity_handles, the position in adj_entity_indices at which values for that entity are stored Array pointer, allocated and occupied sizes argument trio)
[in,out]offset_allocatedAllocated size of offset array
[out]offset_sizeOccipied size of offset array
Definition at line 799 of file iMesh_MOAB.cpp.
References iBase_BAD_ARRAY_DIMENSION, iBase_MEMORY_ALLOCATION_FAILED, iBase_SUCCESS, iMesh_getEntArrAdj, iMesh_getEntities, and size.
    const int allocated_entity_handles = ( *entity_handles_allocated == 0 );
    const int allocated_indices        = ( *adj_entity_indices_allocated == 0 );
    const int allocated_offset         = ( *offset_allocated == 0 );
    // get source entities
    iMesh_getEntities( instance, entity_set_handle, entity_type_requestor, entity_topology_requestor, entity_handles,
                       entity_handles_allocated, entity_handles_size, err );
    if( iBase_SUCCESS != *err ) return;
    // get adjacencies
    iBase_EntityHandle* all_adj_handles = 0;
    int size = 0, alloc = 0;
    iMesh_getEntArrAdj( instance, *entity_handles, *entity_handles_size, entity_type_requested, &all_adj_handles,
                        &alloc, &size, offset, offset_allocated, offset_size, err );
    if( *err != iBase_SUCCESS )
        if( allocated_entity_handles )
            free( *entity_handles );
            *entity_handles           = 0;
            *entity_handles_allocated = 0;
        return;
    // allocate or check size of adj_entity_indices
    *adj_entity_indices_size = size;
    if( allocated_indices )
        *adj_entity_indices = (int*)malloc( sizeof( iBase_EntityHandle ) * size );
        if( !*adj_entity_indices )
            *err = iBase_MEMORY_ALLOCATION_FAILED;
        else
            *adj_entity_indices_allocated = size;
    else if( *adj_entity_indices_allocated < size )
        *err = iBase_BAD_ARRAY_DIMENSION;
        free( all_adj_handles );
        if( allocated_offset )
            free( *offset );
            *offset           = 0;
            *offset_allocated = 0;
        return;
    // Now create an array of unique sorted handles from all_adj_handles.
    // We need to create a copy because we still need all_adj_handles.  We
    // will eventually need to copy the resulting unique list into
    // adj_entity_handles, so if adj_entity_handles is already allocated and
    // of sufficient size, use it rather than allocating another temporary.
    iBase_EntityHandle* unique_adj = 0;
    if( *adj_entity_handles_allocated >= size )
        unique_adj = *adj_entity_handles;
    else
        unique_adj = (iBase_EntityHandle*)malloc( sizeof( iBase_EntityHandle ) * size );
    std::copy( all_adj_handles, all_adj_handles + size, unique_adj );
    std::sort( unique_adj, unique_adj + size );
    *adj_entity_handles_size = std::unique( unique_adj, unique_adj + size ) - unique_adj;
    // If we created a temporary array for unique_adj rather than using
    // already allocated space in adj_entity_handles, allocate adj_entity_handles
    // and copy the unique handle list into it
    if( *adj_entity_handles != unique_adj )
        if( !*adj_entity_handles_allocated )
            *adj_entity_handles =
                (iBase_EntityHandle*)malloc( sizeof( iBase_EntityHandle ) * *adj_entity_handles_size );
            if( !*adj_entity_handles )
            else
                *adj_entity_handles_allocated = *adj_entity_handles_size;
        else if( *adj_entity_handles_allocated < *adj_entity_handles_size )
            free( unique_adj );
                free( *offset );
                *offset           = 0;
                free( *adj_entity_indices );
                *adj_entity_indices           = 0;
                *adj_entity_indices_allocated = 0;
            return;
        std::copy( unique_adj, unique_adj + *adj_entity_handles_size, *adj_entity_handles );
        free( unique_adj );
    // convert from adjacency list to indices into unique_adj
    for( int i = 0; i < *adj_entity_indices_size; ++i )
        ( *adj_entity_indices )[i] =
            std::lower_bound( unique_adj, unique_adj + *adj_entity_handles_size, all_adj_handles[i] ) - unique_adj;
void iMesh_getAdjTable ( iMesh_Instance  instance,
int **  adjacency_table,
int *  adjacency_table_allocated,
int *  adjacency_table_size,
int *  err
Adjacencies Get the adjacency table for this implementation. This table is a 4x4 array whose entries characterize how the implementation behaves when adjacent and intermediate entities are queried. Entry [i,j] (i=row, j=col, 0-based indexing) will have one of the values in the iBase_AdjacencyCost enumeration. Off-diagonal entres, i!=j, represents the relative cost of retrieving entities of dimension i adjacent to entities of dimension j. Diagonal entries, i==j, indicate whether or not handles to ALL entities of that dimension are obtainable from calls that return entity handles. This is always true by definition for i==j==0 as well as for i==j==2 in a 2D mesh and i==j==3 in a 3D mesh. However, diagonal entries [1,1] for a 2D mesh and both [1,1] and [2,2] for a 3D mesh indicate whether or not handles to ALL intermediate dimensioned entities (ALL edges in a 2D mesh or ALL edges and ALL faces in a 3D mesh) are obtainable from calls that return entity handles. A value of iBase_AVAILABLE for a diagonal entry indicates that handles are obtainable for ALL entities of that dimension while a value of iBase_UNAVAILABLE indicates that handles are not obtainable for ALL entities of that dimension.
Parameters:
[out]adjacency_tablePointer to array representing adjacency table Array pointer, allocated and occupied sizes argument trio)
[in,out]adjacency_table_allocatedPointer to allocated size of adjacency_table
[out]adjacency_table_sizePointer to occupied size of adjacency_table
Definition at line 381 of file iMesh_MOAB.cpp.
References ALLOC_CHECK_ARRAY_NOFAIL, iBase_SUCCESS, iMesh_getGeometricDimension, MBIMESHI, munge_adj_table(), and RETURN.
    int geom_dim;
    iMesh_getGeometricDimension( instance, &geom_dim, err );
    ALLOC_CHECK_ARRAY_NOFAIL( adjacency_table, 16 );
    memcpy( *adjacency_table, MBIMESHI->AdjTable, 16 * sizeof( int ) );
    munge_adj_table( *adjacency_table, geom_dim );
void iMesh_getChldn ( iMesh_Instance  instance,
const int  num_hops,
iBase_EntitySetHandle **  entity_set_handles,
int *  entity_set_handles_allocated,
int *  entity_set_handles_size,
int *  err
ParentChildLinks Get the child sets linked from a specified set.
Parameters:
[in]from_entity_setEntity set being queried
[in]num_hopsMaximum hops from entity_set_handle to child set, Indirection in Set-Inclusion and Parent-Child structures)
[in,out]entity_set_handlesPointer to array of child sets Array pointer, allocated and occupied sizes argument trio)
[in,out]entity_set_handles_allocatedPointer to allocated size of
[out]entity_set_handles_sizePointer to occupied size of
Definition at line 1223 of file iMesh_MOAB.cpp.
References ALLOC_CHECK_ARRAY_NOFAIL, children, CHKERR, ENTITY_HANDLE, ERROR, ErrorCode, HANDLE_ARRAY_PTR, iBase_INVALID_ENTITYSET_HANDLE, iBase_SUCCESS, MB_ENTITY_NOT_FOUND, MOABI, and RETURN.
    std::vector< EntityHandle > children;
    ErrorCode result = MOABI->get_child_meshsets( ENTITY_HANDLE( from_entity_set ), children, num_hops + 1 );
        ERROR( iBase_INVALID_ENTITYSET_HANDLE, "iMesh_getChldn: ERROR invalid entity set." );CHKERR( result, "ERROR getChildren failed." );
    ALLOC_CHECK_ARRAY_NOFAIL( entity_set_handles, children.size() );
    EntityHandle* ents = HANDLE_ARRAY_PTR( *entity_set_handles );
    // use a memcpy for efficiency
    memcpy( ents, &children[0], children.size() * sizeof( EntityHandle ) );
void iMesh_getData ( iMesh_Instance  instance,
void *  tag_value,
int *  tag_value_allocated,
int *  tag_value_size,
int *  err
Get the value of a tag of arbitrary type on an entity. Tag data is passed back as void*. tag_value_size specifies the size of the memory pointed to by tag_value in terms of bytes. Applications may use this function to get data of any type, not just iBase_BYTES. However, because this function supports arbitrary type, in all cases the size specified by tag_value_size is always in terms of bytes.
Parameters:
[in]entity_handleEntity on which tag is being set
[in]tag_handleTag being set on an entity
[in,out]tag_valuePointer to tag data array being queried Array pointer, allocated and occupied sizes argument trio)
[in,out]tag_value_allocatedPointer to tag data array allocated size
[out]tag_value_sizePointer to occupied size in bytes of tag data
Definition at line 2104 of file iMesh_MOAB.cpp.
References iMesh_getArrData.
    iMesh_getArrData( instance, &entity_handle, 1, tag_handle, tag_value, tag_value_allocated, tag_value_size, err );
void iMesh_getDblData ( iMesh_Instance  instance,
double *  out_data,
int *  err
Get the value of a tag of double type on an entity.
Parameters:
[out]out_dataPointer to tag value returned from function
Definition at line 2127 of file iMesh_MOAB.cpp.
References CHKTAGTYPE, iBase_DOUBLE, and iMesh_getArrData.
    CHKTAGTYPE( tag_handle, iBase_DOUBLE );
    void* val_ptr = out_data;
    int val_size  = sizeof( double );
    iMesh_getArrData( instance, &entity_handle, 1, tag_handle, &val_ptr, &val_size, &val_size, err );
void iMesh_getDescription ( iMesh_Instance  instance,
char *  descr,
int  descr_len
ErrorHandling
Parameters:
[in,out]descrPointer to a character string to be filled with a description of the error from the last iMesh function
[in]descr_lenLength of the character string pointed to by descr (String Length Arguments)
Definition at line 228 of file iMesh_MOAB.cpp.
References MBIMESHI, and MIN.
    if( instance == NULL )
        strcpy( descr, "iMesh_getDescription: Invalid instance" );
    else
        unsigned int len = MIN( strlen( MBIMESHI->lastErrorDescription ), static_cast< unsigned int >( descr_len ) );
        strncpy( descr, MBIMESHI->lastErrorDescription, len );
        descr[len] = '\0';
void iMesh_getDfltStorage ( iMesh_Instance  instance,
int *  order,
int *  err
Initialization Get the default storage order used by this implementation. Value returned is a member of the iBase_StorageOrder enumeration.
Parameters:
[out]orderPointer to storage order returned from function (
See also:
iBase_StorageOrder)
Parameters:
Definition at line 375 of file iMesh_MOAB.cpp.
References iBase_BLOCKED, iBase_SUCCESS, and RETURN.
void iMesh_getEHData ( iMesh_Instance  instance,
iBase_EntityHandle out_data,
int *  err
Get the value of a tag of entity handle type on an entity.
Parameters:
Definition at line 2139 of file iMesh_MOAB.cpp.
References CHKTAGTYPE, moab::dum, iBase_ENTITY_HANDLE, and iMesh_getArrData.
    CHKTAGTYPE( tag_handle, iBase_ENTITY_HANDLE );
    int dum       = sizeof( iBase_EntityHandle );
    iMesh_getArrData( instance, &entity_handle, 1, tag_handle, &val_ptr, &dum, &dum, err );
void iMesh_getEnt2ndAdj ( iMesh_Instance  instance,
iBase_EntityHandle **  adjacent_entities,
int *  adjacent_entities_allocated,
int *  adjacent_entities_size,
int *  err
Adjacencies Get "2nd order" adjacencies to an entity, that is, from an entity, through other entities of a specified "bridge" dimension, to other entities of another specified "to" dimension. Note 1: If the "bridge" dimension is the same as the "to" dimension or the dimension of the input entity, the output will be empty (and an error code of iBase_INVALID_ARGUMENT returned). This is consistent with the definition of adjacencies and the behavior of iMesh first adjacency calls. Note 2: An entity will never be returned as a second adjacency of itself, on the grounds that this is the most likely expectation of applications, and that it is easier for an application to add the original entity to the returned data than to find and remove it.
Parameters:
[in]entity_handleEntity from which adjacencies are requested
[in]bridge_entity_typeType of bridge entity for 2nd order adjacencies
[in]requested_entity_typeType of adjacent entities returned
[in,out]adjacent_entitiesAdjacent entities Array pointer, allocated and occupied sizes argument trio)
[in,out]adjacent_entities_allocatedAllocated size of returned array
[out]adjacent_entities_sizeOccupied size of returned array
Definition at line 2339 of file iMesh_MOAB.cpp.
References iMesh_getEntArr2ndAdj.
    int offsets[2];
    int* offsets_ptr = offsets;
    int offset_size, offset_allocated = 2;
    iMesh_getEntArr2ndAdj( instance, &entity_handle, 1, order_adjacent_key, requested_entity_type, adj_entities,
                           adj_entities_allocated, adj_entities_size, &offsets_ptr, &offset_allocated, &offset_size,
                           err );
void iMesh_getEntAdj ( iMesh_Instance  instance,
int *  err
Adjacencies Get entities of specified type adjacent to an entity. Specified type must be value in the iBase_EntityType enumeration.
Note 1: Because 'adjacent' as defined by the iMesh data model refers to those entities that bound another, the entity being queried here (in entity_handle arg) is NEVER ALSO returned in adj_entity_handles even if the entity_type_requested matches the entity type in entity_handle.
Parameters:
[in]entity_handleEntity handle being queried
[in]entity_type_requestedType of adjacent entities requested
[in,out]adj_entity_handlesPointer to array of adjacent entities Array pointer, allocated and occupied sizes argument trio)
[in,out]adj_entity_handles_allocatedPointer to allocated size of adj_entity_handles
[out]adj_entity_handles_sizePointer to occupied size of adj_entity_handles
Definition at line 2322 of file iMesh_MOAB.cpp.
References iMesh_getEntArrAdj.
    int offsets[2];
    iMesh_getEntArrAdj( instance, &entity_handle, 1, entity_type_requested, adj_entity_handles,
                        adj_entity_handles_allocated, adj_entity_handles_size, &offsets_ptr, &offset_allocated,
                        &offset_size, err );
void iMesh_getEntArr2ndAdj ( iMesh_Instance  instance,
iBase_EntityHandle const *  entity_handles,
int **  offset,
int *  offset_size,
int *  err
Adjacencies Get "2nd order" adjacencies to an array of entities, that is, from each entity, through other entities of a specified "bridge" dimension, to other entities of another specified "to" dimension. Note 1: If the "bridge" dimension is the same as the "to" dimension, the output will be empty (and an error code of iBase_INVALID_ARGUMENT returned). If the type of a particular entity matches the "bridge" dimension, there will be no entities returned for that input entity. This is consistent with the definition of adjacencies and the behavior of iMesh first adjacency calls. Note 2: An entity will never be returned as a second adjacency of itself, on the grounds that this is the most likely expectation of applications, and that it is easier for an application to add the original entity to the returned data than to find and remove it. Note 3: The entities adjacent to the ith entity in entity_handles are found in adj_entity_handles running from offset[i] to offset[i+1] - 1. This implies that the offset_size will be entity_handles_size + 1.
Parameters:
[in]entity_handlesEntities from which adjacencies are requested
[in]entity_handles_sizeNumber of entities whose adjacencies are requested
[in,out]adj_entity_handlesAdjacent entities. Note that the implicit INTERLEAVED storage order rule applies (see iBase_StorageOrder) Array pointer, allocated and occupied sizes argument trio)
[in,out]adj_entity_handles_allocatedAllocated size of returned array
[out]adj_entity_handles_sizeOccupied size of returned array
[in,out]offsetOffset[i] is offset into adj_entity_handles of 2nd order adjacencies of ith entity in entity_handles Array pointer, allocated and occupied sizes argument trio)
[out]offset_sizeOccupied size of offset array
Definition at line 731 of file iMesh_MOAB.cpp.
References ALLOC_CHECK_ARRAY, ALLOC_CHECK_ARRAY_NOFAIL, moab::Range::begin(), CHKENUM, CHKERR, moab::Range::end(), ERROR, ErrorCode, moab::MeshTopoUtil::get_bridge_adjacencies(), iBase_ALL_TYPES, iBase_INVALID_ARGUMENT, iBase_INVALID_ENTITY_TYPE, iBase_REGION, iBase_SUCCESS, iBase_VERTEX, KEEP_ARRAY, MB_SUCCESS, MOABI, RETURN, moab::Range::size(), and moab::TYPE_FROM_HANDLE().
    CHKENUM( bridge_entity_type, iBase_EntityType, iBase_INVALID_ENTITY_TYPE );
    CHKENUM( requested_entity_type, iBase_EntityType, iBase_INVALID_ENTITY_TYPE );
    ErrorCode result = MB_SUCCESS;
    ALLOC_CHECK_ARRAY( offset, entity_handles_size + 1 );
    const EntityHandle* entity_iter      = (const EntityHandle*)entity_handles;
    const EntityHandle* const entity_end = entity_iter + entity_handles_size;
    int* off_iter                        = *offset;
    int prev_off                         = 0;
    std::vector< EntityHandle > all_adj_ents;
    MeshTopoUtil mtu( MOABI );
    int min_bridge = iBase_VERTEX, max_bridge = iBase_REGION;
    int min_req = iBase_VERTEX, max_req = iBase_REGION;
    if( iBase_ALL_TYPES != bridge_entity_type ) min_bridge = max_bridge = bridge_entity_type;
    if( iBase_ALL_TYPES != requested_entity_type ) min_req = max_req = requested_entity_type;
    for( ; entity_iter != entity_end; ++entity_iter )
        *off_iter = prev_off;
        off_iter++;
        Range adj_ents;
        int source = CN::Dimension( TYPE_FROM_HANDLE( *entity_iter ) );
        for( int bridge = min_bridge; bridge <= max_bridge; ++bridge )
            if( source == bridge ) continue;
            for( int requested = min_req; requested <= max_req; ++requested )
                if( bridge == requested ) continue;
                result = mtu.get_bridge_adjacencies( *entity_iter, bridge, requested, adj_ents );CHKERR( result, "iMesh_getEntArr2ndAdj: trouble getting adjacency list." );
        std::copy( adj_ents.begin(), adj_ents.end(), std::back_inserter( all_adj_ents ) );
        prev_off += adj_ents.size();
    ALLOC_CHECK_ARRAY_NOFAIL( adj_entity_handles, all_adj_ents.size() );
    memcpy( *adj_entity_handles, &all_adj_ents[0], sizeof( EntityHandle ) * all_adj_ents.size() );
    KEEP_ARRAY( offset );
    // Return an error if the bridge and requested entity types are different
    if( iBase_ALL_TYPES != bridge_entity_type && bridge_entity_type == requested_entity_type )
        ERROR( iBase_INVALID_ARGUMENT, "iMesh_getEntArr2ndAdj: bridge and "
                                       "requested entity types must be different." );
    else
void iMesh_getEntArrAdj ( iMesh_Instance  instance,
iBase_EntityHandle **  adjacentEntityHandles,
int *  adjacentEntityHandles_allocated,
int **  offset,
int *  offset_size,
int *  err
Adjacencies Get entities of specified type adjacent to entities. Specified type must be value in the iBase_EntityType enumeration. offset(i) is index of first entity in adjacentEntityHandles array adjacent to entity_handles[i]. More precisely, the entities adjacent to the ith entity in entity_handles are found in adjacentEntityHandles running from offset[i] to offset[i+1] - 1. This implies that the offset_size will be entity_handles_size + 1.
Note 1: Because 'adjacent' as defined by the iMesh data model refers to those entities that bound another, the entities being queried here (in entity_handles arg) are NEVER ALSO returned in adjacentEntityHandles even if the entity_type_requested matches the entity type(s) in entity_handles.
Parameters:
[in]entity_handlesArray of entity handles being queried
[in,out]adjacentEntityHandlesPointer to array of adjacentEntityHandles Array pointer, allocated and occupied sizes argument trio) returned from function. Note that the implicit INTERLEAVED storage order rule applies (see iBase_StorageOrder)
[in,out]adjacentEntityHandles_allocatedPointer to allocated size of adjacentEntityHandles array
[out]adj_entity_handles_sizePointer to occupied size of adjacentEntityHandles array
[in,out]offsetPointer to array of offsets returned from function Array pointer, allocated and occupied sizes argument trio)
[in,out]offset_allocatedPointer to allocated size of offset array
[out]offset_sizePointer to occupied size of offset array
Definition at line 596 of file iMesh_MOAB.cpp.
References ALLOC_CHECK_ARRAY, dim, ERROR, ErrorCode, iBase_ALL_TYPES, iBase_BAD_ARRAY_SIZE, iBase_MEMORY_ALLOCATION_FAILED, iBase_SUCCESS, iBase_VERTEX, KEEP_ARRAY, MB_SUCCESS, MBPOLYHEDRON, MOABI, RETURN, moab::TYPE_FROM_HANDLE(), and smoab::UNION.
    int prev_off                         = 0;
    std::vector< EntityHandle > conn_storage;
    std::vector< EntityHandle > adj_ents;
    const EntityHandle* connect;
    int num_connect;
    EntityHandle* array;  // ptr to working array of result handles
    int array_alloc;      // allocated size of 'array'
    const bool allocated_array = !*adjacentEntityHandles_allocated || !*adjacentEntityHandles;
    if( allocated_array )
        array       = 0;
        array_alloc = 0;
    else
        array       = reinterpret_cast< EntityHandle* >( *adjacentEntityHandles );
        array_alloc = *adjacentEntityHandles_allocated;
        off_iter++;
        if( iBase_VERTEX == entity_type_requested && TYPE_FROM_HANDLE( *entity_iter ) != MBPOLYHEDRON )
            if( CN::Dimension( TYPE_FROM_HANDLE( *entity_iter ) ) == 0 ) continue;
            result = MOABI->get_connectivity( *entity_iter, connect, num_connect, false, &conn_storage );
            if( MB_SUCCESS != result )
                if( allocated_array ) free( array );
                ERROR( result, "iMesh_getEntArrAdj: trouble getting adjacency list." );
        else if( iBase_ALL_TYPES == entity_type_requested )
            adj_ents.clear();
            for( int dim = 0; dim < 4; ++dim )
                if( CN::Dimension( TYPE_FROM_HANDLE( *entity_iter ) ) == dim ) continue;
                result = MOABI->get_adjacencies( entity_iter, 1, dim, false, adj_ents, Interface::UNION );
            connect     = &adj_ents[0];
            num_connect = adj_ents.size();
        else
            if( CN::Dimension( TYPE_FROM_HANDLE( *entity_iter ) ) == entity_type_requested ) continue;
            adj_ents.clear();
            result = MOABI->get_adjacencies( entity_iter, 1, entity_type_requested, false, adj_ents );
        if( prev_off + num_connect <= array_alloc )
            std::copy( connect, connect + num_connect, array + prev_off );
        else if( allocated_array )
            // if array is not allocated yet, guess at initial size
            // as the number of adjacencies for the first entity times
            // the number of input entities.  This will result in a single
            // exact allocation if one input entity or typical queries
            // such as connectivity of a non-mixed mesh or regions adjacent
            // to faces.
            if( !array_alloc )
                array_alloc = entity_handles_size * num_connect;
            else
                array_alloc = std::max( array_alloc * 2, prev_off + num_connect );
            EntityHandle* new_array = (EntityHandle*)realloc( array, array_alloc * sizeof( EntityHandle ) );
            if( !new_array )
                free( array );
                RETURN( iBase_MEMORY_ALLOCATION_FAILED );
            else
                array = new_array;
        // else do nothing.  Will catch error later when comparing
        //  occupied to allocated sizes.  Continue here because
        //  must pass back required size.
        prev_off += num_connect;
    *adjacentEntityHandles_size = prev_off;
    if( *adjacentEntityHandles_size > array_alloc )
        RETURN( iBase_BAD_ARRAY_SIZE );
        *adjacentEntityHandles           = reinterpret_cast< iBase_EntityHandle* >( array );
        *adjacentEntityHandles_allocated = array_alloc;
void iMesh_getEntSetData ( iMesh_Instance  instance,
void *  tag_value,
int *  err
Get the value of a tag of arbitrary type on an entity set. Tag data is returned back as void*. tag_value_size specifies the size of the memory pointed to by tag_value in terms of bytes. Applications may use this function to get data of any type, not just iBase_BYTES. However because this function supports data of arbitrary type, in all cases the size specified by tag_value_size is always in terms of bytes.
Parameters:
[in]entity_set_handleEntity set on which tag is being set
[in]tag_handleTag being set on an entity set
[in,out]tag_value_allocatedPointer allocated size, in bytes, of tag_value array.
[out]tag_value_sizePointer to occupied size, in bytes, of tag_value array.
Definition at line 1694 of file iMesh_MOAB.cpp.
References ALLOC_CHECK_TAG_ARRAY, CHKERR, ENTITY_HANDLE, ErrorCode, iBase_SUCCESS, KEEP_ARRAY, MOABI, RETURN, and TAG_HANDLE.
    EntityHandle eh = ENTITY_HANDLE( entity_set_handle );
    Tag tag         = TAG_HANDLE( tag_handle );
    int tag_size;
    ErrorCode result = MOABI->tag_get_bytes( tag, tag_size );CHKERR( result, "iMesh_getEntSetData: couldn't get tag size." );
    ALLOC_CHECK_TAG_ARRAY( tag_value, tag_size );
    result = MOABI->tag_get_data( tag, &eh, 1, *static_cast< void** >( tag_value ) );
    CHKERR( result, "iMesh_getEntSetData didn't succeed." );
    KEEP_ARRAY( tag_value );
void iMesh_getEntSetDblData ( iMesh_Instance  instance,
double *  out_data,
int *  err
Get the value of a tag of double type on an entity set.
Parameters:
[in]entity_setEntity set on which tag is being set
Definition at line 1729 of file iMesh_MOAB.cpp.
References CHKTAGTYPE, iBase_DOUBLE, and iMesh_getEntSetData.
    void* tag_ptr = out_data;
    int tag_size  = sizeof( double );
    iMesh_getEntSetData( instance, entity_set, tag_handle, &tag_ptr, &tag_size, &tag_size, err );
void iMesh_getEntSetEHData ( iMesh_Instance  instance,
int *  err
Get the value of a tag of entity handle type on an entity set.
Parameters:
Definition at line 1741 of file iMesh_MOAB.cpp.
References CHKTAGTYPE, iBase_ENTITY_HANDLE, and iMesh_getEntSetData.
    int tag_size  = sizeof( EntityHandle );
void iMesh_getEntSetESHData ( iMesh_Instance  instance,
iBase_EntitySetHandle out_data,
int *  err
entity set Get the value of a tag of entity set handle type on an entity set.
Parameters:
Definition at line 1753 of file iMesh_MOAB.cpp.
References CHKTAGTYPE, iBase_ENTITY_SET_HANDLE, and iMesh_getEntSetData.
    CHKTAGTYPE( tag_handle, iBase_ENTITY_SET_HANDLE );
void iMesh_getEntSetIntData ( iMesh_Instance  instance,
int *  out_data,
int *  err
Get the value of a tag of integer type on an entity set.
Parameters:
Definition at line 1717 of file iMesh_MOAB.cpp.
References CHKTAGTYPE, iBase_INTEGER, and iMesh_getEntSetData.
    CHKTAGTYPE( tag_handle, iBase_INTEGER );
    int dum_size  = sizeof( int );
    iMesh_getEntSetData( instance, entity_set, tag_handle, &tag_ptr, &dum_size, &dum_size, err );
void iMesh_getEntSets ( iMesh_Instance  instance,
const int  num_hops,
iBase_EntitySetHandle **  contained_set_handles,
int *  contained_set_handles_allocated,
int *  contained_set_handles_size,
int *  err
Get the entity sets contained in a set or interface.
Parameters:
[in]entity_set_handleEntity set being queried
[in]num_hopsMaximum hops from entity_set_handle to contained set, not inclusive of the contained set Indirection in Set-Inclusion and Parent-Child structures)
[in,out]contained_set_handlesPointer to array of set handles returned Array pointer, allocated and occupied sizes argument trio)
[in,out]contained_set_handles_allocatedPointer to allocated length of
[out]contained_set_handles_sizePointer to occupied length of
Definition at line 1004 of file iMesh_MOAB.cpp.
References ALLOC_CHECK_ARRAY_NOFAIL, CHKERR, ENTITY_HANDLE, ErrorCode, iBase_SUCCESS, MOABI, and RETURN.
    std::vector< EntityHandle > sets;
    ErrorCode rval =
        MOABI->get_contained_meshsets( ENTITY_HANDLE( entity_set_handle ), sets, std::max( num_hops + 1, 0 ) );CHKERR( rval, "iMesh_entitysetGetEntitySets: problem getting entities by type." );
    ALLOC_CHECK_ARRAY_NOFAIL( contained_entset_handles, sets.size() );
    std::copy( sets.begin(), sets.end(), (EntityHandle*)*contained_entset_handles );
    *contained_entset_handles_size = sets.size();
void iMesh_getErrorType ( iMesh_Instance  instance,
int *  error_type
Get the error type returned from the last iMesh function.
ErrorHandling
Parameters:
[out]error_typeError type returned from last iMesh function (see iBase_ErrorType)
Definition at line 220 of file iMesh_MOAB.cpp.
References iBase_FAILURE, and MBIMESHI.
        *error_type = iBase_FAILURE;
    else
        *error_type = MBIMESHI->lastErrorType;
void iMesh_getESHData ( iMesh_Instance  instance,
int *  err
entity Get the value of a tag of entity set handle type on an entity.
Parameters:
Definition at line 2151 of file iMesh_MOAB.cpp.
References CHKTAGTYPE, moab::dum, iBase_ENTITY_SET_HANDLE, and iMesh_getArrData.
void iMesh_getGeometricDimension ( iMesh_Instance  instance,
int *  geom_dim,
int *  err
Get the geometric dimension of mesh represented in this instance.
Initialization
Parameters:
[out]geom_dimPointer to dimension returned from this function
Definition at line 362 of file iMesh_MOAB.cpp.
References iBase_SUCCESS, MOABI, and RETURN.
    MOABI->get_dimension( *geom_dim );
void iMesh_getIntData ( iMesh_Instance  instance,
int *  out_data,
int *  err
Get the value of a tag of integer type on an entity.
Parameters:
Definition at line 2115 of file iMesh_MOAB.cpp.
References CHKTAGTYPE, iBase_INTEGER, and iMesh_getArrData.
    int val_size  = sizeof( int );
void iMesh_getNextEntArrIter ( iMesh_Instance  instance,
iBase_EntityArrIterator  entArr_iterator,
int *  has_data,
int *  err
Get entities contained in array iterator and increment iterator.
EntityIterators Get the entities corresponding to an array iterator (e.g. dereference the array iterator), and increment the iterator. The dereferenced value(s) are returned in entity_handles. If the iterator is at the end of the iteration, the dereferenced value(s) are undefined and has_data will be returned with a value of zero. Otherwise, has_data will be returned with a non-zero value.
Method: getEntArrNextIter[]
Parameters:
[in]entArr_iteratorIterator being queried
[in,out]entity_handlesPointer to array of entity handles contained in current value of iterator Array pointer, allocated and occupied sizes argument trio)
[in,out]entity_handles_allocatedPointer to allocated size of entity_handles
[out]entity_handles_sizePointer to occupied size of entity_handles
[out]has_dataPointer to a flag indicating if the value(s) returned in entity_handles are valid. A non-zero value indicates the value(s) are valid. A zero value indicates the value(s) are NOT valid.
Definition at line 523 of file iMesh_MOAB.cpp.
References ALLOC_CHECK_ARRAY_NOFAIL, iBase_EntityArrIterator_Private::array_size(), iBase_EntityArrIterator_Private::get_entities(), iBase_SUCCESS, MOABI, and RETURN.
    // check the size of the destination array
    ALLOC_CHECK_ARRAY_NOFAIL( entity_handles, entArr_iterator->array_size() );
    entArr_iterator->get_entities( dynamic_cast< Core* >( MOABI ), (EntityHandle*)*entity_handles,
                                   *entity_handles_size );
    *has_data = ( *entity_handles_size != 0 );
void iMesh_getNextEntIter ( iMesh_Instance  instance,
int *  has_data,
int *  err
EntityIterators Get the entity corresponding to an iterator (that is, dereference the iterator), and increment the iterator. The dereferenced value is returned in 'entity_handle'. If the iterator is at the end of the iteration, the dereferenced value will be undefined and 'has_data' will have a value of zero. Otherwise, 'has_data' will have a non-zero value.
Parameters:
[in]entity_iteratorIterator being queried
[out]entity_handlePointer to an entity handle corresponding to the current value of iterator just prior to the call.
[out]has_dataPointer to a flag indicating if the value returned in entity_handle is valid. A non-zero value indicates the value is valid. A zero value indicates the value is NOT valid.
Definition at line 2259 of file iMesh_MOAB.cpp.
References iMesh_getNextEntArrIter.
    int eh_size = 1;
    iMesh_getNextEntArrIter( instance, reinterpret_cast< iBase_EntityArrIterator >( entity_iterator ), &entity_handle,
                             &eh_size, &eh_size, is_end, err );
void iMesh_getNumChld ( iMesh_Instance  instance,
const int  num_hops,
int *  num_child,
int *  err
ParentChildLinks Get the number of child sets linked from a specified set.
Parameters:
[in]entity_setEntity set being queried
[in]num_hopsMaximum hops from entity_set_handle to child set, not inclusive of the child set. Indirection in Set-Inclusion and Parent-Child structures)
[out]num_childPointer to number of children returned from function
Definition at line 1194 of file iMesh_MOAB.cpp.
    *num_child       = 0;
    ErrorCode result = MOABI->num_child_meshsets( ENTITY_HANDLE( entity_set ), num_child, num_hops + 1 );
        ERROR( iBase_INVALID_ENTITYSET_HANDLE, "iMesh_getNumChld: ERROR invalid entity set." );CHKERR( result, "iMesh_getNumChld: ERROR GetNumChildren failed." );
void iMesh_getNumEntSets ( iMesh_Instance  instance,
const int  num_hops,
int *  num_sets,
int *  err
Get the number of entity sets contained in a set or interface.
Parameters:
[in]num_hopsMaximum hops from entity_set_handle to contained set, not inclusive of the contained set. Indirection in Set-Inclusion and Parent-Child structures)
[out]num_setsPointer to the number of sets returned from function
Definition at line 992 of file iMesh_MOAB.cpp.
    ErrorCode rval =
        MOABI->num_contained_meshsets( ENTITY_HANDLE( entity_set_handle ), num_sets, std::max( 0, num_hops + 1 ) );CHKERR( rval, "iMesh_entitysetGetNumberEntitySets:ERROR getting number of entitysets." );
void iMesh_getNumOfTopo ( iMesh_Instance  instance,
const int  entity_topology,
int *  num_topo,
int *  err
Get the number of entities of specified topology in instance or set.
Get the number of entities with the specified topology in the instance or set. If entity set handle is root set, return information for instance, otherwise for set. Value of entity topology must be from the iMesh_EntityTopology enumeration. If iMesh_ALL_TOPOLOGIES is specified, total number of entities (excluding entity sets) is returned.
Parameters:
[in]entity_topologyTopology of entity requested
[out]num_topoPointer to number of entities, returned from function
Definition at line 423 of file iMesh_MOAB.cpp.
References iMesh_getNumOfTopoRec.
    iMesh_getNumOfTopoRec( instance, entity_set_handle, entity_topology, false, num_topo, err );
void iMesh_getNumOfType ( iMesh_Instance  instance,
const int  entity_type,
int *  num_type,
int *  err
Get the number of entities of specified type in the instance or set.
Get the number of entities with the specified type in the instance or set. If entity set handle is root set, return information for instance, otherwise for set. Value of entity type must be from the iBase_EntityType enumeration. If iBase_ALL_TYPES is specified, total number of entities (excluding entity sets) is returned.
Parameters:
[in]entity_typeType of entity requested
[out]num_typePointer to number of entities, returned from function
Definition at line 414 of file iMesh_MOAB.cpp.
References iMesh_getNumOfTypeRec.
    iMesh_getNumOfTypeRec( instance, entity_set_handle, entity_type, false, num_type, err );
void iMesh_getNumPrnt ( iMesh_Instance  instance,
const int  num_hops,
int *  num_parent,
int *  err
Get the number of parent sets linked from a specified set.
ParentChildLinks Get the number of parent sets linked from a specified set.
Parameters:
[in]num_hopsMaximum hops from entity_set_handle to parent set, not inclusive of the parent set. Indirection in Set-Inclusion and Parent-Child structures)
[out]num_parentPointer to number of parents returned from function
Definition at line 1209 of file iMesh_MOAB.cpp.
    *num_parent      = 0;
    ErrorCode result = MOABI->num_parent_meshsets( ENTITY_HANDLE( entity_set ), num_parent, num_hops + 1 );
        ERROR( iBase_INVALID_ENTITYSET_HANDLE, "iMesh_getNumPrnt: ERROR invalid entity set." );CHKERR( result, "iMesh_getNumPrnt: ERROR GetNumParents failed." );
void iMesh_getPrnts ( iMesh_Instance  instance,
const iBase_EntitySetHandle  from_entity_set,
const int  num_hops,
int *  err
Get the parent sets linked from a specified set.
ParentChildLinks Get the parent sets linked from a specified set.
Parameters:
[in]num_hopsMaximum hops from entity_set_handle to parent set, Indirection in Set-Inclusion and Parent-Child structures)
[in,out]entity_set_handlesPointer to array of parent sets Array pointer, allocated and occupied sizes argument trio)
Definition at line 1246 of file iMesh_MOAB.cpp.
References ALLOC_CHECK_ARRAY_NOFAIL, CHKERR, ENTITY_HANDLE, ERROR, ErrorCode, HANDLE_ARRAY_PTR, iBase_INVALID_ENTITYSET_HANDLE, iBase_SUCCESS, MB_ENTITY_NOT_FOUND, MOABI, and RETURN.
    std::vector< EntityHandle > parents;
    ErrorCode result = MOABI->get_parent_meshsets( ENTITY_HANDLE( from_entity_set ), parents, num_hops + 1 );
        ERROR( iBase_INVALID_ENTITYSET_HANDLE, "iMesh_getPrnts: ERROR invalid entity set." );CHKERR( result, "ERROR getParents failed." );
    ALLOC_CHECK_ARRAY_NOFAIL( entity_set_handles, parents.size() );
    memcpy( ents, &parents[0], parents.size() * sizeof( EntityHandle ) );
void iMesh_getRootSet ( iMesh_Instance  instance,
iBase_EntitySetHandle root_set,
int *  err
Get handle of the root set for this instance.
Initialization Get handle of the root set for this instance. All mesh entities in this instance can be accessed from this set.
Parameters:
[out]root_setPointer to set handle returned from function
Definition at line 355 of file iMesh_MOAB.cpp.
    *root_set = 0;
    // return CAST_TO_VOID(MOABI->get_root_set());
void iMesh_getVtxArrCoords ( iMesh_Instance  instance,
const iBase_EntityHandle vertex_handles,
const int  vertex_handles_size,
const int  storage_order,
double **  coords,
int *  coords_allocated,
int *  coords_size,
int *  err
Get coordinates of specified vertices.
VertexEntities Get coordinates of specified vertices. Coordinates are returned in the storage order indicated by the storage_order argument.
Parameters:
[in]vertex_handlesArray of mesh vertex handles whose coordinates are being requested
[in]vertex_handles_sizeNumber of vertices in vertex_handles array
[in]storage_orderRequested storage order of returned coordinates (see iBase_StorageOrder)
[in,out]coordsPointer to array of coordinates returned from function Array pointer, allocated and occupied sizes argument trio)
[in,out]coords_allocatedPointer to allocated size of coords array
[out]coords_sizePointer to occupied size of coords array
Definition at line 452 of file iMesh_MOAB.cpp.
References ALLOC_CHECK_ARRAY, CHKERR, CONST_HANDLE_ARRAY_PTR, ErrorCode, iBase_INTERLEAVED, iBase_SUCCESS, KEEP_ARRAY, MOABI, and RETURN.
    int geom_dim;
    // make sure we can hold them all
    ALLOC_CHECK_ARRAY( coords, geom_dim * vertex_handles_size );
    // now get all the coordinates
    // coords will come back interleaved by default
    ErrorCode result;
        if( 3 == geom_dim )
            result = MOABI->get_coords( CONST_HANDLE_ARRAY_PTR( vertex_handles ), vertex_handles_size, *coords );
        else
            std::vector< double > dum_coords( 3 * vertex_handles_size );
            result = MOABI->get_coords( CONST_HANDLE_ARRAY_PTR( vertex_handles ), vertex_handles_size, &dum_coords[0] );
            for( int i = 0; i < vertex_handles_size; i++ )
                    ( *coords )[geom_dim * i + j] = dum_coords[3 * i + j];
    else
        result = MOABI->get_coords( CONST_HANDLE_ARRAY_PTR( vertex_handles ), vertex_handles_size, &dum_coords[0] );CHKERR( result, "iMesh_getVtxArrCoords: problem getting vertex coords" );
                ( *coords )[i + vertex_handles_size * j] = dum_coords[3 * i + j];
    KEEP_ARRAY( coords );
void iMesh_getVtxCoord ( iMesh_Instance  instance,
double *  x,
double *  y,
double *  z,
int *  err
VertexEntities Get coordinates of specified vertex.
Parameters:
[in]vertex_handleMesh vertex being queried
[out]xPointer to x coordinate returned from function
[out]yPointer to y coordinate returned from function
[out]zPointer to z coordinate returned from function
Definition at line 2302 of file iMesh_MOAB.cpp.
References moab::dum, iBase_BLOCKED, iBase_SUCCESS, and iMesh_getVtxArrCoords.
    int order     = iBase_BLOCKED;
    double xyz[3] = { 0 }, *tmp_xyz = xyz;
    int dum = 3;
    iMesh_getVtxArrCoords( instance, &vertex_handle, 1, order, &tmp_xyz, &dum, &dum, err );
    if( iBase_SUCCESS == *err )
        *x = xyz[0];
        *y = xyz[1];
        *z = xyz[2];
void iMesh_initEntArrIter ( iMesh_Instance  instance,
const int  requested_array_size,
int *  err
Initialize an array iterator over specified entity type, topology, and size.
EntityIterators Initialize an array iterator over specified entity type, topology, and size, for a specified set or instance. Iterator returned can be used as input to functions returning entities for the iterator. If all entities of a specified type and/or topology are to be iterated, specify iBase_ALL_TYPES or iMesh_ALL_TOPOLOGIES, respectively. Specified type or topology must be a value in the iBase_EntityType or iMesh_EntityTopology enumerations, respectively.
Method: initEntArrIter[]
Parameters:
[in]entity_set_handleEntity set being iterated
[in]requested_entity_typeType of entity to iterate
[in]requested_entity_topologyTopology of entity to iterate
[in]requested_array_sizeSize of chunks of handles returned for each value of the iterator
[in]resilientIf zero, return a non-resilient iterator. Otherwise, a resilient iterator (Resilient and Non-Resilient Iterators)
[out]entArr_iteratorPointer to iterator returned from function
Definition at line 507 of file iMesh_MOAB.cpp.
References iMesh_initEntArrIterRec.
    iMesh_initEntArrIterRec( instance, entity_set_handle, requested_entity_type, requested_entity_topology,
                             requested_array_size, resilient, false, entArr_iterator, err );
void iMesh_initEntIter ( iMesh_Instance  instance,
int *  err
EntityIterators Initialize an iterator over specified entity type, topology, and size, for a specified set or instance. Iterator returned can be used as input to functions returning the entity for the iterator. If all entities of a specified type and/or topology are to be iterated, specify iBase_ALL_TYPES or iMesh_ALL_TOPOLOGIES, respectively. Specified type or topology must be a value in the iBase_EntityType or iMesh_EntityTopology enumerations, respectively.
Note: This function will fail and return an error if the caller passes a combination of entity_type and entity_topology that are not consistent.
Parameters:
[out]entity_iteratorPointer to iterator returned from function
Definition at line 2247 of file iMesh_MOAB.cpp.
    iMesh_initEntArrIterRec( instance, entity_set_handle, requested_entity_type, requested_entity_topology, 1,
                             resilient, false, reinterpret_cast< iBase_EntityArrIterator* >( entity_iterator ), err );
void iMesh_intersect ( iMesh_Instance  instance,
iBase_EntitySetHandle result_entity_set,
int *  err
EntitySetOperators Intersect contents of one entity set with another
Parameters:
[in]entity_set_1Entity set being intersected with another
[in]entity_set_2Entity set being intersected with another
[out]result_entity_setPointer to entity set returned from function
Definition at line 2404 of file iMesh_MOAB.cpp.
References CHKERR, entities, ENTITY_HANDLE, ERROR, ErrorCode, iBase_SUCCESS, iMesh_isList, MB_SUCCESS, MESHSET_SET, MOABI, and RETURN.
    EntityHandle temp_set;
    EntityHandle set1 = ENTITY_HANDLE( entity_set_1 ), set2 = ENTITY_HANDLE( entity_set_2 );
    int isList1 = 0, isList2 = 0;
    iMesh_isList( instance, entity_set_1, &isList1, err );
    if( *err != iBase_SUCCESS ) return;
    iMesh_isList( instance, entity_set_2, &isList2, err );
    ErrorCode result;
    if( isList1 && isList2 )
        result = MOABI->create_meshset( MESHSET_ORDERED, temp_set );
    else
        result = MOABI->create_meshset( MESHSET_SET, temp_set );
    if( MB_SUCCESS != result ) ERROR( result, "iMesh_intersect: couldn't create result set." );
    if( !entity_set_1 && !entity_set_2 )
        // intersecting the root set with itself, so get everything...
        Range entities;
        result = MOABI->get_entities_by_handle( 0, entities );
        if( MB_SUCCESS == result ) result = MOABI->add_entities( temp_set, entities );
        // ...but not the newly-created set!
        if( MB_SUCCESS == result ) result = MOABI->remove_entities( temp_set, &temp_set, 1 );
    else if( !entity_set_1 )
        result = MOABI->unite_meshset( temp_set, set2 );
    else if( !entity_set_2 )
        result = MOABI->unite_meshset( temp_set, set1 );
    else
            // ITAPS has very specific rules about the behavior of intersection on
            // list-type sets. Since MOAB doesn't (and likely will never) work
            // exactly this way, we implement our own algorithm here.
#ifdef MOAB_HAVE_UNORDERED_MAP
            typedef MOAB_UNORDERED_MAP_NS::unordered_map< EntityHandle, size_t > lookup_t;
#else
            typedef std::map< EntityHandle, size_t > lookup_t;
#endif
            // First, build a lookup table for the second set.
            lookup_t lookup;
                std::vector< EntityHandle > contents2;
                result = MOABI->get_entities_by_handle( set2, contents2 );CHKERR( result, "iMesh_intersect: ERROR intersect failed." );
                for( std::vector< EntityHandle >::iterator i = contents2.begin(); i != contents2.end(); ++i )
                    lookup_t::iterator j = lookup.find( *i );
#else
                    lookup_t::iterator j = lookup.lower_bound( *i );
#endif
                    if( j != lookup.end() && j->first == *i )
                        ++j->second;
                    else
                        lookup.insert( j, lookup_t::value_type( *i, 1 ) );
            // Then, iterate over the contents of the first set and check for
            // their existence in the second set.
            std::vector< EntityHandle > contents1;
            result = MOABI->get_entities_by_handle( set1, contents1 );CHKERR( result, "iMesh_intersect: ERROR intersect failed." );
            std::vector< EntityHandle >::iterator w = contents1.begin();
            for( std::vector< EntityHandle >::iterator i = contents1.begin(); i != contents1.end(); ++i )
                if( j != lookup.end() && j->second )
                    --j->second;
                    *w = *i;
                    ++w;
            result = MOABI->add_entities( temp_set, &contents1[0], w - contents1.begin() );
        else
            if( MB_SUCCESS == result ) result = MOABI->intersect_meshset( temp_set, set2 );
    *result_entity_set = (iBase_EntitySetHandle)temp_set;
void iMesh_isChildOf ( iMesh_Instance  instance,
const iBase_EntitySetHandle  parent_entity_set,
const iBase_EntitySetHandle  child_entity_set,
int *  is_child,
int *  err
Return whether two sets are related by parent/child links.
ParentChildLinks Return whether two sets are related (*is_child=1) or not (*is_child=0) by parent/child links
Parameters:
[out]is_childPointer to flag returned from function
Definition at line 1170 of file iMesh_MOAB.cpp.
References children, CHKERR, ENTITY_HANDLE, ERROR, ErrorCode, iBase_INVALID_ENTITYSET_HANDLE, iBase_SUCCESS, MB_ENTITY_NOT_FOUND, MOABI, and RETURN.
    if( !child_entity_set ) ERROR( iBase_INVALID_ENTITYSET_HANDLE, "iMesh_isChildOf: ERROR invalid entity set." );
    ErrorCode result = MOABI->get_child_meshsets( ENTITY_HANDLE( parent_entity_set ), children );
        ERROR( iBase_INVALID_ENTITYSET_HANDLE, "iMesh_rmvPrntChld: ERROR invalid entity set." );CHKERR( result, "iMesh_isChildOf: ERROR IsParentChildRelated failed." );
    if( std::find( children.begin(), children.end(), ENTITY_HANDLE( child_entity_set ) ) != children.end() )
        *is_child = true;
    else
        *is_child = false;
void iMesh_isEntArrContained ( iMesh_Instance  instance,
iBase_EntitySetHandle  containing_entity_set,
int  num_entity_handles,
int **  is_contained,
int *  is_contained_allocated,
int *  is_contained_size,
int *  err
Return whether entities are contained in a set.
Parameters:
[in]containing_entity_setEntity set being queried
[in]entity_handlesList of entities for which to check containment.
[in]num_entity_handlesSize of entity_handles array of entities to be checked.
[in,out]is_containedOne value for each input entity, 1 if contained in set, zero otherwise. Array pointer, allocated and occupied sizes argument trio)
[in,out]is_contained_allocatedAllocated size of is_contained array
[out]is_contained_sizeOccupied size of is_contained array
Definition at line 1106 of file iMesh_MOAB.cpp.
References ALLOC_CHECK_ARRAY_NOFAIL, ENTITY_HANDLE, iBase_SUCCESS, MOABI, and RETURN.
    EntityHandle set = ENTITY_HANDLE( containing_set );
    ALLOC_CHECK_ARRAY_NOFAIL( is_contained, num_entity_handles );
    *is_contained_size = num_entity_handles;
    if( containing_set )
        for( int i = 0; i < num_entity_handles; ++i )
            EntityHandle h       = ENTITY_HANDLE( entity_handles[i] );
            ( *is_contained )[i] = MOABI->contains_entities( set, &h, 1 );
    else
        std::fill( *is_contained, ( *is_contained ) + num_entity_handles, 1 );
void iMesh_isEntContained ( iMesh_Instance  instance,
iBase_EntityHandle  contained_entity,
int *  is_contained,
int *  err
Return whether an entity is contained in another set.
Return whether an entity is contained (*is_contained=1) or not contained (*is_contained=0) in another set
Parameters:
[in]contained_entityEntity potentially contained in containing_entity_set
[out]is_containedPointer to flag returned from function
Definition at line 1095 of file iMesh_MOAB.cpp.
References iMesh_isEntArrContained.
    int junk1 = 1, junk2 = 1;
    iMesh_isEntArrContained( instance, containing_entity_set, &contained_entity, 1, &is_contained, &junk1, &junk2,
                             err );
void iMesh_isEntSetContained ( iMesh_Instance  instance,
const iBase_EntitySetHandle  containing_entity_set,
const iBase_EntitySetHandle  contained_entity_set,
int *  is_contained,
int *  err
Return whether an entity set is contained in another set.
Return whether a set is contained (*is_contained=1) or not contained (*is_contained=0) in another set
Parameters:
[in]contained_entity_setEntity set potentially contained in containing_entity_set
Definition at line 1135 of file iMesh_MOAB.cpp.
References iMesh_isEntContained.
    iMesh_isEntContained( instance, containing_entity_set,
                          reinterpret_cast< iBase_EntityHandle >( contained_entity_set ), is_contained, err );
void iMesh_isList ( iMesh_Instance  instance,
const iBase_EntitySetHandle  entity_set,
int *  is_list,
int *  err
Return whether a specified set is ordered or unordered.
Return whether a specified set is ordered (*is_list=1) or unordered (*is_list=0)
Parameters:
[out]is_listPointer to flag returned from function
Definition at line 977 of file iMesh_MOAB.cpp.
    unsigned int options;
    ErrorCode result = MOABI->get_meshset_options( ENTITY_HANDLE( entity_set ), options );CHKERR( result, "iMesh_isList: couldn't query set." );
    if( options & MESHSET_ORDERED )
        *is_list = true;
    else
        *is_list = false;
void iMesh_load ( iMesh_Instance  instance,
const iBase_EntitySetHandle  entity_set_handle,
const char *  name,
const char *  options,
int *  err,
int  name_len,
int  options_len
Load a mesh from a file.
Initialization Load a mesh from a file. If entity set is specified, loaded mesh is added to that set; specify root set if that is not desired.
Parameters:
[in]instanceiMesh instance handle
[in]entity_set_handleSet to which loaded mesh will be added, otherwise root
[in]nameFile name from which mesh is to be loaded
[in]optionsPointer to implementation-specific options string (Option Strings)
[out]errReturned Error status (see iBase_ErrorType)
[in]name_lenLength of the file name character string (String Length Arguments)
[in]options_lenLength of the options character string (String Length Arguments)
Definition at line 293 of file iMesh_MOAB.cpp.
References CHKERR, create_int_ents(), eatwhitespace(), ErrorCode, filter_options(), iBase_SUCCESS, MBENTITYSET, MBIMESHI, MOABI, RETURN, and moab::subtract().
    // get filename, option & null-terminate
    std::string filename( name, name_len );
    eatwhitespace( filename );
    std::string opts = filter_options( options, options + options_len );
    Range orig_ents;
    ErrorCode result = MOABI->get_entities_by_handle( 0, orig_ents );CHKERR( result, "Internal error" );
    const EntityHandle* file_set = 0;
    if( handle != 0 /*root_set*/ )
        const iBase_EntitySetHandle* ptr = &handle;
        file_set                         = reinterpret_cast< const EntityHandle* >( ptr );
    result = MOABI->load_file( filename.c_str(), file_set, opts.c_str() );
    CHKERR( result, "iMesh_load:ERROR loading a mesh." );
    // create interior edges/faces if requested
    if( MBIMESHI->AdjTable[5] || MBIMESHI->AdjTable[10] )
        Range set_ents;
        result = MOABI->get_entities_by_handle( 0, set_ents );CHKERR( result, "" );
        Range sets;
        result = MOABI->get_entities_by_type( 0, MBENTITYSET, sets );CHKERR( result, "" );
        set_ents = subtract( set_ents, sets );
        set_ents = subtract( set_ents, orig_ents );
        result   = create_int_ents( MBIMESHI, set_ents, file_set );CHKERR( result, "" );
    RETURN( iBase_SUCCESS );
void iMesh_newMesh ( const char *  options,
int *  err,
int  options_len
Construct a new iMesh instance.
Initialization
Parameters:
[in]options_lenLength of the character string pointed to by options (String Length Arguments)
Definition at line 242 of file iMesh_MOAB.cpp.
References ErrorCode, filter_options(), iBase_FAILURE, iBase_SUCCESS, MB_NOT_IMPLEMENTED, MB_SUCCESS, and MBiMesh::set_last_error().
    std::string tmp_options = filter_options( options, options + options_len );
    FileOptions opts( tmp_options.c_str() );
    MBiMesh** mbi = reinterpret_cast< MBiMesh** >( instance );
    *mbi          = NULL;
    ErrorCode result = opts.get_null_option( "PARALLEL" );
#ifdef MOAB_HAVE_MPI
        int flag   = 1;
        int retval = MPI_Initialized( &flag );
        if( MPI_SUCCESS != retval || !flag )
            int argc    = 0;
            char** argv = NULL;
            // mpi not initialized yet - initialize here
            retval = MPI_Init( &argc, &argv );
            assert( MPI_SUCCESS == retval );
        *mbi = new( std::nothrow ) MBiMesh( NULL );
#else
        // mError->set_last_error( "PARALLEL option not valid, this instance"
        //                        " compiled for serial execution.\n" );
        *err = ( *mbi )->set_last_error( MB_NOT_IMPLEMENTED, "Not configured with parallel support" );
        return;
#endif
    else
    if( NULL == *mbi )
        *err = iBase_FAILURE;
        return;
void iMesh_optimize ( iMesh_Instance  instance,
int *  handles_invalidated,
int *  err
Permit implementation to 'optimize' the mesh instance.
MeshModification Its concievable that after a series of operations modifying the mesh instance, the implementation's internal representation of the mesh may include data and tie up memory resources that could be 'optimized' away. For example, if the implementation only marks removed entities for deletion but does not actually free up memory resources associated those entities, a call to this function gives the implementation the 'ok' to go ahead and free up such memory.
Depending on the implementation as well as the amount and kind of changes to the mesh that have been made prior to calling it, this call may be very expensive in time complexity. On the other hand, it is also perfectly acceptable that an implementation basically treat this operation as a no-op.
In any event, any entity, entity set, iterator or tag handle obtained prior to calling this method will may be invalidated as a result of this call. In that case, the caller must re-acquire handles after making this call. A return argument indicates if handles have been invalidated.
Parameters:
[out]handles_invalidatedReturned flag indicating if any handles the caller held before calling this function have been invalidated as a result of this call. A value of non-zero returned here indicates that any handles the caller had prior to this call must not be trusted and must be re-acquired by caller.
Definition at line 432 of file iMesh_MOAB.cpp.
    // TODO: implement this for real
    *handles_invalidated = 0;
void iMesh_resetEntArrIter ( iMesh_Instance  instance,
int *  err
Reset the array iterator.
EntityIterators
Method: resetEntArrIter[]
Parameters:
[in]entArr_iteratorIterator to reset
Definition at line 542 of file iMesh_MOAB.cpp.
References CHKERR, ErrorCode, iBase_SUCCESS, MOABI, iBase_EntityArrIterator_Private::reset(), and RETURN.
    ErrorCode result = entArr_iterator->reset( MOABI );CHKERR( result, "Re-query of iterator data for iMesh_resetEntArrIter failed" );
void iMesh_resetEntIter ( iMesh_Instance  instance,
iBase_EntityIterator  entity_iterator,
int *  err
Reset the iterator.
EntityIterators Reset the iterator
Parameters:
[in]entity_iteratorIterator to reset
Definition at line 2270 of file iMesh_MOAB.cpp.
References iMesh_resetEntArrIter.
    iMesh_resetEntArrIter( instance, reinterpret_cast< iBase_EntityArrIterator >( entity_iterator ), err );
void iMesh_rmvEntArrFromSet ( iMesh_Instance  instance,
const iBase_EntityHandle entity_handles,
int  entity_handles_size,
int *  err
Remove an array of entities from a set.
Parameters:
[in]entity_handlesArray of entities being remove
[in]entity_handles_sizeNumber of entities in entity_handles array
[in]entity_setPointer to the set being removed from
Definition at line 1043 of file iMesh_MOAB.cpp.
References CHKERR, CONST_HANDLE_ARRAY_PTR, ENTITY_HANDLE, ErrorCode, iBase_SUCCESS, MOABI, and RETURN.
    const EntityHandle* ents = CONST_HANDLE_ARRAY_PTR( entity_handles );
    ErrorCode result = MOABI->remove_entities( ENTITY_HANDLE( entity_set ), ents, entity_handles_size );
    CHKERR( result, "iMesh_rmvEntArrFromSet:ERROR removing entities in EntitySet." );
void iMesh_rmvEntFromSet ( iMesh_Instance  instance,
iBase_EntityHandle  entity_handle,
int *  err
Remove an entity from a set.
Parameters:
[in]entity_handleThe entity being removed
Definition at line 1057 of file iMesh_MOAB.cpp.
References iMesh_rmvEntArrFromSet.
    iMesh_rmvEntArrFromSet( instance, &entity_handle, 1, entity_set, err );
void iMesh_rmvEntSet ( iMesh_Instance  instance,
iBase_EntitySetHandle  entity_set_to_remove,
int *  err
Remove an entity set from a set.
Parameters:
[in]entity_set_to_removeThe entity set being removed
[in]entity_set_handlePointer to the set being removed from
Definition at line 1080 of file iMesh_MOAB.cpp.
References CHKERR, ENTITY_HANDLE, ERROR, ErrorCode, iBase_INVALID_ARGUMENT, iBase_SUCCESS, MOABI, and RETURN.
    if( !entity_set_to_remove || !entity_set_handle )
        ERROR( iBase_INVALID_ARGUMENT, "iMesh_rmvEntSet: ERROR invalid argument" );
    EntityHandle to_remove = ENTITY_HANDLE( entity_set_to_remove );
    ErrorCode result       = MOABI->remove_entities( ENTITY_HANDLE( entity_set_handle ), &to_remove, 1 );
    CHKERR( result, "iMesh_rmvEntSet:ERROR removing entitysets in EntitySet." );
void iMesh_rmvPrntChld ( iMesh_Instance  instance,
int *  err
Remove parent/child links between two sets.
ParentChildLinks Remove parent/child links between two sets.
Parameters:
[in]parent_entity_setPointer to parent set
[in]child_entity_setPointer to child set
Definition at line 1157 of file iMesh_MOAB.cpp.
References CHKERR, ENTITY_HANDLE, ERROR, ErrorCode, iBase_INVALID_ENTITYSET_HANDLE, iBase_SUCCESS, MB_ENTITY_NOT_FOUND, MOABI, and RETURN.
    ErrorCode result =
        MOABI->remove_parent_child( ENTITY_HANDLE( parent_entity_set ), ENTITY_HANDLE( child_entity_set ) );
    if( result == MB_ENTITY_NOT_FOUND )
        ERROR( iBase_INVALID_ENTITYSET_HANDLE, "iMesh_rmvPrntChld: ERROR invalid entity set." );CHKERR( result, "iMesh_rmvPrntChld: ERROR RemoveParentChild failed." );
void iMesh_save ( iMesh_Instance  instance,
const char *  name,
int *  err,
const int  name_len,
int  options_len
Save a mesh to a file.
Initialization Save a mesh to a file. If entity set is specified, save only the mesh contained in that set.
Parameters:
[in]entity_set_handleEntity set being saved
[in]nameFile name to which mesh is to be saved
Definition at line 335 of file iMesh_MOAB.cpp.
References CHKERR, eatwhitespace(), ENTITY_HANDLE, ErrorCode, filter_options(), iBase_SUCCESS, MOABI, and RETURN.
    // get filename & attempt to NULL-terminate
    EntityHandle set = ENTITY_HANDLE( handle );
    ErrorCode result = MOABI->write_file( filename.c_str(), NULL, opts.c_str(), &set, 1 );
    CHKERR( result, "iMesh_save:ERROR saving a mesh." );
void iMesh_setAdjTable ( iMesh_Instance  instance,
int *  adjacency_table,
int  adjacency_table_size,
int *  err
Set the adjacency table as requested by the application.
Adjacencies Set the adjacency table as requested by the application. See iMesh_getAdjTable for a description of the meaning of the entries in this table. This call to set the adjacency table allows an application to request how it would like an implementation to behave when adjacent and/or intermediate entities are queried. If the implementation is not able to accommodate the requested query behavior associated with ANY entry in the table, the call will fail and return an error of iBase_NOT_SUPPORTED. Otherwise, the implementation is able to accommodate the requested query behavior associated with ALL table entries and the call will succeed. In either case, however, the implementation will over-write the entries in the adjacency_table argument with the same values that would be obtained in a succeeding call to iMesh_getAdjTable.
Parameters:
[in,out]adjacency_tableArray representing adjacency table requested by application
[in]adjacency_table_sizeSize of adj table array
Definition at line 396 of file iMesh_MOAB.cpp.
References iBase_INVALID_ARGUMENT, iBase_SUCCESS, iMesh_getGeometricDimension, MBIMESHI, munge_adj_table(), and RETURN.
    if( 16 != adj_table_size )
        RETURN( iBase_INVALID_ARGUMENT );
    int geom_dim;
    memcpy( MBIMESHI->AdjTable, adj_table, 16 * sizeof( int ) );
    munge_adj_table( adj_table, geom_dim );
void iMesh_setData ( iMesh_Instance  instance,
const iBase_TagHandle  tag_handle,
const void *  tag_value,
const int  tag_value_size,
int *  err
Set a tag value of arbitrary type on an entity.
Set a tag value of arbitrary type on an entity. Tag data is passed as void*. tag_value_size specifies the size of the memory pointed to by tag_value in terms of bytes. Applications may use this function to set data of any type, not just iBase_BYTES. However, because this function supports data of arbitrary type, in all cases the size specified by tag_value_size is always in terms of bytes.
Parameters:
[in]tag_valuePointer to tag data being set on entity
[in]tag_value_sizeSize in bytes of tag data
Definition at line 2163 of file iMesh_MOAB.cpp.
References iMesh_setArrData.
    iMesh_setArrData( instance, &entity_handle, 1, tag_handle, tag_value, tag_value_size, err );
void iMesh_setDblData ( iMesh_Instance  instance,
const double  tag_value,
int *  err
Set a tag value of double type on an entity.
Parameters:
[in]tag_valueTag value being set on entity
Definition at line 2184 of file iMesh_MOAB.cpp.
References CHKTAGTYPE, iBase_DOUBLE, and iMesh_setArrData.
    iMesh_setArrData( instance, &entity_handle, 1, tag_handle, reinterpret_cast< const char* >( &tag_value ),
                      sizeof( double ), err );
void iMesh_setEHData ( iMesh_Instance  instance,
const iBase_EntityHandle  tag_value,
int *  err
Set a tag value of entity handle type on an entity.
Parameters:
Definition at line 2196 of file iMesh_MOAB.cpp.
References CHKTAGTYPE, iBase_ENTITY_HANDLE, and iMesh_setArrData.
                      sizeof( iBase_EntityHandle ), err );
void iMesh_setEntSetData ( iMesh_Instance  instance,
int *  err
Set a tag value of arbitrary type on an entity set.
Set a tag value of arbitrary type on an entity set. The tag data is passed as void*. tag_value_size specifies the size of the memory pointed to by tag_value in terms of bytes. Applications are free to use this function to set data of any type, not just iBase_BYTES. However, in all cases, the size specified by tag_value_size is always in terms of bytes.
Parameters:
[in]tag_valuePointer to tag data being set on entity set
Definition at line 1637 of file iMesh_MOAB.cpp.
References CHKERR, ENTITY_HANDLE, ErrorCode, iBase_SUCCESS, MOABI, RETURN, and TAG_HANDLE.
    ErrorCode result;
    EntityHandle set = ENTITY_HANDLE( entity_set_handle );
    result           = MOABI->tag_set_data( TAG_HANDLE( tag_handle ), &set, 1, tag_value );CHKERR( result, "iMesh_setEntSetData: error" );
void iMesh_setEntSetDblData ( iMesh_Instance  instance,
int *  err
Set a tag value of double type on an entity set.
Parameters:
[in]tag_valueTag value being set on entity set
Definition at line 1662 of file iMesh_MOAB.cpp.
References CHKTAGTYPE, iBase_DOUBLE, and iMesh_setEntSetData.
    iMesh_setEntSetData( instance, entity_set, tag_handle, &tag_value, sizeof( double ), err );
void iMesh_setEntSetEHData ( iMesh_Instance  instance,
int *  err
Set a tag value of entity handle type on an entity set.
Parameters:
Definition at line 1672 of file iMesh_MOAB.cpp.
References CHKNONEMPTY, CHKTAGTYPE, iBase_ENTITY_HANDLE, and iMesh_setEntSetData.
    // XXX: decide how best to handle validating entity handles as tag data
    CHKNONEMPTY();
    iMesh_setEntSetData( instance, entity_set, tag_handle, &tag_value, sizeof( iBase_EntityHandle ), err );
void iMesh_setEntSetESHData ( iMesh_Instance  instance,
const iBase_EntitySetHandle  tag_value,
int *  err
Set a tag value of entity set handle type on an.
entity set Set a tag value of entity set handle type on an entity set.
Parameters:
Definition at line 1684 of file iMesh_MOAB.cpp.
References CHKTAGTYPE, iBase_ENTITY_SET_HANDLE, and iMesh_setEntSetData.
    iMesh_setEntSetData( instance, entity_set, tag_handle, &tag_value, sizeof( iBase_EntitySetHandle ), err );
void iMesh_setEntSetIntData ( iMesh_Instance  instance,
const int  tag_value,
int *  err
Set a tag value of integer type on an entity set.
Parameters:
Definition at line 1652 of file iMesh_MOAB.cpp.
References CHKTAGTYPE, iBase_INTEGER, and iMesh_setEntSetData.
    iMesh_setEntSetData( instance, entity_set, tag_handle, &tag_value, sizeof( int ), err );
void iMesh_setESHData ( iMesh_Instance  instance,
int *  err
Set a tag value of entity set handle type on an entity.
Parameters:
Definition at line 2207 of file iMesh_MOAB.cpp.
References CHKTAGTYPE, iBase_ENTITY_SET_HANDLE, and iMesh_setArrData.
void iMesh_setGeometricDimension ( iMesh_Instance  instance,
int  geom_dim,
int *  err
Set geometric dimension of vertex coordinates.
Initialization Set the geometric dimension of the mesh. Note: An application should not expect this function to succeed unless the mesh instance is empty. An empty mesh instance is any mesh instance in which there are no vertex entities.
Parameters:
[in]geom_dimRequested geometric dimension.
Definition at line 368 of file iMesh_MOAB.cpp.
References CHKERR, ErrorCode, iBase_SUCCESS, MOABI, and RETURN.
    ErrorCode rval = MOABI->set_dimension( geom_dim );CHKERR( rval, "iMesh_setGeometricDimension: failed" );
void iMesh_setIntData ( iMesh_Instance  instance,
int *  err
Set a tag value of integer type on an entity.
Parameters:
Definition at line 2173 of file iMesh_MOAB.cpp.
References CHKTAGTYPE, iBase_INTEGER, and iMesh_setArrData.
void iMesh_setVtxArrCoords ( iMesh_Instance  instance,
const double *  new_coords,
const int  new_coords_size,
int *  err
Set coordinates for an array of vertices.
VertexEntities Set coordinates for an array of vertices. Specified storage order must be either iBase_INTERLEAVED or iBase_BLOCKED, and indicates order of x, y, and z coordinates in coordinate array.
Parameters:
[in]vertex_handlesArray of vertex handles
[in]vertex_handles_sizeNumber of vertex handles in array
[in]storage_orderStorage order of coordinates in coordinate array
[in]new_coordsCoordinate array
[in]new_coords_sizeSize of coordinate array; should be
Definition at line 1270 of file iMesh_MOAB.cpp.
References CHKENUM, CHKERR, CONST_HANDLE_ARRAY_PTR, ERROR, ErrorCode, iBase_INTERLEAVED, iBase_INVALID_ARGUMENT, iBase_SUCCESS, MB_SUCCESS, MOABI, and RETURN.
    CHKENUM( storage_order, iBase_StorageOrder, iBase_INVALID_ARGUMENT );
    int geom_dim;
    MOABI->get_dimension( geom_dim );
    if( new_coords_size != geom_dim * vertex_handles_size )
        ERROR( iBase_INVALID_ARGUMENT, "iMesh_setVtxArrCoords: Didn't get the right # coordinates." );
    ErrorCode result = MB_SUCCESS, tmp_result;
    if( storage_order == iBase_INTERLEAVED )
        if( 3 == geom_dim )
            result = MOABI->set_coords( CONST_HANDLE_ARRAY_PTR( vertex_handles ), vertex_handles_size, new_coords );
        else
            const EntityHandle* verts = CONST_HANDLE_ARRAY_PTR( vertex_handles );
            double dummy[3]           = { 0, 0, 0 };
                for( int j = 0; j < geom_dim; j++ )
                    dummy[j] = new_coords[geom_dim * i + j];
                tmp_result = MOABI->set_coords( &verts[i], 1, dummy );
                if( MB_SUCCESS != tmp_result ) result = tmp_result;
    else
                dummy[j] = new_coords[i + vertex_handles_size * j];
    CHKERR( result, "iMesh_setVtxArrCoords: problem setting coordinates." );
void iMesh_setVtxCoord ( iMesh_Instance  instance,
iBase_EntityHandle  vertex_handle,
const double  x,
const double  y,
const double  z,
int *  err
Set coordinates for a vertex.
VertexEntities Set coordinates for a vertex.
Parameters:
[in]vertex_handlevertex handle being set
[in]xx coordinate being set
[in]yy coordinate being set
[in]zz coordinate being set
Definition at line 1802 of file iMesh_MOAB.cpp.
References iBase_BLOCKED, iMesh_setVtxArrCoords, and MOABI.
    const double xyz[3] = { x, y, z };
    int geom_dim;
    iMesh_setVtxArrCoords( instance, &vertex_handle, 1, iBase_BLOCKED, xyz, geom_dim, err );
void iMesh_subtract ( iMesh_Instance  instance,
const iBase_EntitySetHandle  entity_set_1,
const iBase_EntitySetHandle  entity_set_2,
int *  err
Subtract contents of one entity set from another.
EntitySetOperators Subtract contents of one entity set from another
Parameters:
[in]entity_set_1Entity set from which other set is being subtracted
[in]entity_set_2Entity set being subtracted from other set
Definition at line 2357 of file iMesh_MOAB.cpp.
    ErrorCode result;
    else
    if( MB_SUCCESS != result ) ERROR( result, "iMesh_subtract: couldn't create result set." );
    // if the second set is the root set, the result is always the empty set
    if( entity_set_2 )
        if( !entity_set_1 )
            // subtracting from the root set, so get everything first...
            Range entities;
        else
        if( MB_SUCCESS == result ) result = MOABI->subtract_meshset( temp_set, set2 );
    CHKERR( result, "iMesh_subtract: ERROR subtract failed." );
void iMesh_unite ( iMesh_Instance  instance,
int *  err
Unite contents of one entity set with another.
EntitySetOperators
Parameters:
[in]entity_set_1Entity set being united with another
[in]entity_set_2Entity set being united with another
Definition at line 2510 of file iMesh_MOAB.cpp.
    ErrorCode result;
    else
    if( MB_SUCCESS != result ) ERROR( result, "iMesh_unite: couldn't create result set." );
    if( entity_set_1 && entity_set_2 )
        if( MB_SUCCESS == result ) result = MOABI->unite_meshset( temp_set, set2 );
    else
        // uniting with the root set, so get everything...
        Range entities;
    CHKERR( result, "iMesh_unite: ERROR unite failed." );
