moab::AdjSides< CORNERS >::Side Struct Reference
Public Member Functions
bool skin () const
 Side (const EntityHandle *array, int idx, EntityHandle adj, unsigned short)
 Side (const EntityHandle *array, int idx, EntityHandle adj, unsigned short, const short *indices)
bool operator== (const Side &other) const
template<>
template<>
template<>
Public Attributes
EntityHandle handles [CORNERS-1]
 side vertices, except for implicit one
EntityHandle adj_elem
 element that this is a side of, or zero
Detailed Description
template<unsigned CORNERS>
struct moab::AdjSides< CORNERS >::Side
This struct is used to for a reduced representation of element "sides" adjacent to a give vertex. As such, it a) does not store the initial vertex that all sides are adjacent to b) orders the remaining vertices in a specific way for fast comparison.
For edge elements, only the opposite vertex is stored. For triangle elements, only the other two vertices are stored, and they are stored with the smaller of those two handles first. For quad elements, only the other three vertices are stored. They are stored such that the vertex opposite the implicit (not stored) vertex is always in slot 1. The other two vertices (in slots 0 and 2) are ordered such that the handle of the one in slot 0 is smaller than the handle in slot 2.
For each side, the adj_elem field is used to store the element that it is a side of as long as the element is considered to be on the skin. The adj_elem field is cleared (set to zero) to indicate that this side is no longer considered to be on the skin (and is the side of more than one element.)
Definition at line 1168 of file Skinner.cpp.
moab::AdjSides< CORNERS >::Side::Side ( const EntityHandle array,
int  idx,
EntityHandle  adj,
unsigned  short
) [inline]
construct from connectivity of side
Parameters:
arrayThe connectivity of the element side.
idxThe index of the implicit vertex (contained in all sides in the list.)
adjThe element that this is a side of.
Definition at line 1183 of file Skinner.cpp.
References moab::AdjSides< CORNERS >::Side::handles, and swap().
        : adj_elem( adj )
            switch( CORNERS )
                case 3:
                    handles[1] = array[( idx + 2 ) % CORNERS];
                    // fall through
                case 2:
                    if( 3 == CORNERS ) handles[1] = array[( idx + 2 ) % CORNERS];
                    if( 2 <= CORNERS ) handles[0] = array[( idx + 1 ) % CORNERS];
                    break;
                default:
                    assert( false );
                    break;
            if( CORNERS == 3 && handles[1] > handles[0] ) std::swap( handles[0], handles[1] );
int  idx,
EntityHandle  adj,
unsigned  short,
const short *  indices
) [inline]
construct from connectivity of parent element
Parameters:
arrayThe connectivity of the parent element
idxThe index of the implicit vertex (contained in all sides in the list.) This is an index into 'indices', not 'array'.
indicesThe indices into 'array' at which the vertices representing the side occur.
Definition at line 1210 of file Skinner.cpp.
            : adj_elem( adj )
            switch( CORNERS )
                case 3:
                    handles[1] = array[indices[( idx + 2 ) % CORNERS]];
                    // fall through
                case 2:
                    if( 3 == CORNERS ) handles[1] = array[indices[( idx + 2 ) % CORNERS]];
                    if( 2 <= CORNERS ) handles[0] = array[indices[( idx + 1 ) % CORNERS]];
                    break;
                default:
                    assert( false );
                    break;
template<>
moab::AdjSides::Side< 4 >::Side ( const EntityHandle array,
int  idx,
EntityHandle  adj,
unsigned  short
Parameters:
Definition at line 1378 of file Skinner.cpp.
        : adj_elem( adj )
    const unsigned int CORNERS = 4;
    handles[2]                 = array[( idx + 3 ) % CORNERS];
    if( handles[2] > handles[0] ) std::swap( handles[0], handles[2] );
template<>
int  idx,
EntityHandle  adj,
unsigned  short,
Parameters:
Definition at line 1397 of file Skinner.cpp.
    : adj_elem( adj )
    handles[2]                 = array[indices[( idx + 3 ) % CORNERS]];
Member Function Documentation
bool moab::AdjSides< CORNERS >::Side::operator== ( const Side other) const [inline]
Definition at line 1231 of file Skinner.cpp.
References moab::AdjSides< CORNERS >::Side::handles.
            switch( CORNERS )
                case 3:
                    return handles[0] == other.handles[0] && handles[1] == other.handles[1];
                case 2:
                    return handles[0] == other.handles[0];
                default:
                    assert( false );
                    return false;
template<>
bool moab::AdjSides::Side< 4 >::operator== ( const Side other) const
Definition at line 1410 of file Skinner.cpp.
    return handles[0] == other.handles[0] && handles[1] == other.handles[1] && handles[2] == other.handles[2];
bool moab::AdjSides< CORNERS >::Side::skin ( ) const [inline]
Definition at line 1172 of file Skinner.cpp.
References moab::AdjSides< CORNERS >::Side::adj_elem.
            return 0 != adj_elem;
Member Data Documentation
EntityHandle moab::AdjSides< CORNERS >::Side::adj_elem
Definition at line 1171 of file Skinner.cpp.
Referenced by moab::AdjSides< CORNERS >::Side::skin().
EntityHandle moab::AdjSides< CORNERS >::Side::handles[CORNERS-1]
Definition at line 1170 of file Skinner.cpp.
Referenced by moab::AdjSides< CORNERS >::Side::operator==(), and moab::AdjSides< CORNERS >::Side::Side().
List of all members.
The documentation for this struct was generated from the following file:
