restore_topo_geom_incl_test.cpp File Reference
#include "moab/Interface.hpp"
#include "TestUtil.hpp"
#include "moab/Core.hpp"
#include "moab/Types.hpp"
#include "MBTagConventions.hpp"
#include "moab/GeomTopoTool.hpp"
#include <iostream>
#include <map>
#include <set>
+ Include dependency graph for restore_topo_geom_incl_test.cpp:
Functions
bool check_tree (Interface *mbi, GeomTopoTool *GTT, std::map< int, std::set< int > > &ref_map)
ErrorCode get_all_handles (Interface *mbi)
Range get_children_by_dimension (Interface *mbi, EntityHandle parent, int desired_dimension)
void heappermute (Interface *mbi, int v[], int n, std::map< int, std::set< int > > ref_map, int len)
void swap (int *x, int *y)
void get_cube_info (int cube_id, std::vector< double > &scale, std::vector< double > &trans)
void test_two_cubes ()
void test_three_cubes ()
void test_four_cubes ()
ErrorCode build_cube (Interface *mbi, std::vector< double > scale_vec, std::vector< double > trans_vec, int object_id, EntityHandle &volume)
int main ()
Variables
Tag category_tag
Tag geom_tag
Tag name_tag
Tag obj_name_tag
Tag dim_tag
Tag id_tag
Function Documentation
ErrorCode build_cube ( Interface mbi,
int  object_id,
EntityHandle volume
Definition at line 29 of file restore_topo_geom_incl_test.cpp.
References moab::Interface::add_entities(), moab::Interface::add_parent_child(), category_tag, moab::Interface::create_element(), moab::Interface::create_meshset(), moab::Interface::create_vertex(), ErrorCode, geom_tag, GTT, id_tag, MB_CHK_ERR, MB_SUCCESS, MBTRI, MESHSET_SET, name_tag, obj_name_tag, SENSE_FORWARD, moab::GeomTopoTool::set_sense(), and moab::Interface::tag_set_data().
Referenced by heappermute().
    GeomTopoTool* GTT = new GeomTopoTool( mbi );
    ErrorCode rval;
    // Define a 1x1x1 cube centered at orgin
    // coordinates of each corner
    const double coords[] = { 0.5, -0.5, -0.5, 0.5, 0.5, -0.5, -0.5, 0.5, -0.5, -0.5, -0.5, -0.5,
                              0.5, -0.5, 0.5,  0.5, 0.5, 0.5,  -0.5, 0.5, 0.5,  -0.5, -0.5, 0.5 };
    // connectivity of 2 triangles per
    //  each face of the cube
    const int connectivity[] = {
        0, 3, 1, 3, 2, 1,  // -Z
        0, 1, 4, 5, 4, 1,  // +X
        1, 2, 6, 6, 5, 1,  // +Y
        6, 2, 3, 7, 6, 3,  // -X
        0, 4, 3, 7, 3, 4,  // -Y
        4, 5, 7, 5, 6, 7   // +Z
    // Create the geometry
    const int num_verts = 8;
    const int num_tris  = 12;
    EntityHandle verts[num_verts], tris[num_tris], surf;
    rval = mbi->create_meshset( MESHSET_SET, surf );MB_CHK_ERR( rval );
      // scale coords
      int i;
      double scaled_coords[24];
      for ( i = 0; i < num_verts; i++ )
          scaled_coords[3*i]   = coords[3*i]*scale_vec[0];
          scaled_coords[3*i+1] = coords[3*i+1]*scale_vec[1];
          scaled_coords[3*i+2] = coords[3*i+2]*scale_vec[2];
      // translate coords
      double trans_coords[24];
          trans_coords[3*i]   = scaled_coords[3*i] + trans_vec[0];
          trans_coords[3*i+1] = scaled_coords[3*i+1] + trans_vec[1];
          trans_coords[3*i+2] = scaled_coords[3*i+2] + trans_vec[2];
    // transform coords-- scale and translate
    for( int i = 0; i < num_verts; i++ )
        trans_coords[3 * i]     = coords[3 * i] * scale_vec[0] + trans_vec[0];
        trans_coords[3 * i + 1] = coords[3 * i + 1] * scale_vec[1] + trans_vec[1];
        trans_coords[3 * i + 2] = coords[3 * i + 2] * scale_vec[2] + trans_vec[2];
    // create vertices and add to meshset
    for( int i = 0; i < num_verts; ++i )
        rval = mbi->create_vertex( trans_coords + 3 * i, verts[i] );MB_CHK_ERR( rval );
        rval = mbi->add_entities( surf, &verts[i], 1 );MB_CHK_ERR( rval );
    // create triangles and add to meshset
    for( int i = 0; i < num_tris; ++i )
        const EntityHandle conn[] = { verts[connectivity[3 * i]], verts[connectivity[3 * i + 1]],
                                      verts[connectivity[3 * i + 2]] };
        rval                      = mbi->create_element( MBTRI, conn, 3, tris[i] );MB_CHK_ERR( rval );
        rval = mbi->add_entities( surf, &tris[i], 1 );MB_CHK_ERR( rval );
    // set name, id, geom, and category tags for SURFACE
    rval = mbi->tag_set_data( name_tag, &surf, 1, "Surface\0" );MB_CHK_ERR( rval );
    std::string object_name;
    rval = mbi->tag_set_data( obj_name_tag, &surf, 1, object_name.c_str() );MB_CHK_ERR( rval );
    rval = mbi->tag_set_data( id_tag, &surf, 1, &object_id );MB_CHK_ERR( rval );
    int two = 2;
    rval    = mbi->tag_set_data( geom_tag, &surf, 1, &( two ) );MB_CHK_ERR( rval );
    rval = mbi->tag_set_data( category_tag, &surf, 1, "Surface\0" );MB_CHK_ERR( rval );
    // create volume meshset associated with surface meshset
    // EntityHandle volume;
    rval = mbi->create_meshset( MESHSET_SET, volume );MB_CHK_ERR( rval );
    // set name, id, geom, and category tags for VOLUME
    rval = mbi->tag_set_data( name_tag, &volume, 1, "Volume\0" );MB_CHK_ERR( rval );
    rval = mbi->tag_set_data( id_tag, &volume, 1, &( object_id ) );MB_CHK_ERR( rval );
    int three = 3;
    rval      = mbi->tag_set_data( geom_tag, &volume, 1, &( three ) );MB_CHK_ERR( rval );
    rval = mbi->tag_set_data( category_tag, &volume, 1, "Volume\0" );MB_CHK_ERR( rval );
    // set surface as child of volume
    rval = mbi->add_parent_child( volume, surf );MB_CHK_ERR( rval );
    // set sense tag
    rval = GTT->set_sense( surf, volume, SENSE_FORWARD );MB_CHK_ERR( rval );
    delete GTT;
    return MB_SUCCESS;
bool check_tree ( Interface mbi,
GeomTopoTool GTT,
std::map< int, std::set< int > > &  ref_map
Definition at line 176 of file restore_topo_geom_incl_test.cpp.
References moab::Range::begin(), moab::Range::clear(), moab::Range::end(), ErrorCode, get_children_by_dimension(), moab::GeomTopoTool::get_gsets_by_dimension(), id_tag, MB_CHK_ERR, moab::Range::size(), and moab::Interface::tag_get_data().
    ErrorCode rval;
    int vol_id;
    std::set< int > test_set;
    Range vols;
    rval = GTT->get_gsets_by_dimension( 3, vols );
    if( ref_map.size() != vols.size() )
        return false;
    // go through volumes, create sets of children
    for( Range::iterator it = vols.begin(); it != vols.end(); ++it )
        // get vol id
        rval = mbi->tag_get_data( id_tag, &( *it ), 1, &vol_id );MB_CHK_ERR( rval );
        // check if test vol in ref map
        if( ref_map.find( vol_id ) == ref_map.end() )
            return false;
        // put range of child surfaces into set
        Range child_surfs;
        test_set.clear();
        child_surfs = get_children_by_dimension( mbi, *it, 2 );
        for( Range::iterator j = child_surfs.begin(); j != child_surfs.end(); ++j )
            int child_id;
            rval = mbi->tag_get_data( id_tag, &( *j ), 1, &child_id );MB_CHK_ERR( rval );
            test_set.insert( child_id );
        // compare sets
        if( test_set != ref_map[vol_id] )
            return false;
    return true;
Range get_children_by_dimension ( Interface mbi,
Definition at line 224 of file restore_topo_geom_incl_test.cpp.
References moab::Range::begin(), moab::Range::clear(), moab::Range::end(), ErrorCode, geom_tag, moab::Interface::get_child_meshsets(), moab::Range::insert(), MB_CHK_SET_ERR_RET_VAL, and moab::Interface::tag_get_data().
Referenced by check_tree().
    ErrorCode rval;
    Range all_children, desired_children;
    Range::iterator it;
    int actual_dimension;
    all_children.clear();
    rval = mbi->get_child_meshsets( parent, all_children );MB_CHK_SET_ERR_RET_VAL( rval, "Failed to get child meshsets", all_children );
    for( it = all_children.begin(); it != all_children.end(); ++it )
        rval = mbi->tag_get_data( geom_tag, &( *it ), 1, &actual_dimension );MB_CHK_SET_ERR_RET_VAL( rval, "Failed to get geom tag from child meshset", all_children );
        if( actual_dimension == desired_dimension )
            desired_children.insert( *it );
    return desired_children;
void get_cube_info ( int  cube_id,
std::vector< double > &  scale,
std::vector< double > &  trans
Definition at line 249 of file restore_topo_geom_incl_test.cpp.
    scale.clear();
    trans.clear();
    if( cube_id == 1 )
        scale.push_back( 1 );
        trans.push_back( 0 );
    if( cube_id == 2 )
        scale.push_back( 4 );
    if( cube_id == 3 )
        scale.push_back( 8 );
    if( cube_id == 4 )
        scale.push_back( 40 );
void heappermute ( Interface mbi,
int  v[],
int  n,
int  len
Definition at line 381 of file restore_topo_geom_incl_test.cpp.
References build_cube(), CHECK_EQUAL, check_tree(), moab::Range::clear(), moab::GeomTopoTool::construct_obb_trees(), moab::Interface::delete_mesh(), ErrorCode, get_cube_info(), GTT, moab::Range::insert(), MB_CHK_ERR_RET, moab::GeomTopoTool::restore_topology_from_geometric_inclusion(), and swap().
Referenced by test_four_cubes(), test_three_cubes(), and test_two_cubes().
    ErrorCode rval;
    std::vector< double > scale, trans;
    EntityHandle vol;
    Range flat_vols;
    if( n == 1 )
        // build cubes
        flat_vols.clear();
        for( int i = 0; i < len; i++ )
            get_cube_info( v[i], scale, trans );
            build_cube( mbi, scale, trans, v[i], vol );
            flat_vols.insert( vol );
        // construct the topology
        // first build obbs-- necessary for topology construction
        rval = GTT->construct_obb_trees();MB_CHK_ERR_RET( rval );
        rval = GTT->restore_topology_from_geometric_inclusion( flat_vols );MB_CHK_ERR_RET( rval );
        // test the topology
        bool result = check_tree( mbi, GTT, ref_map );
        CHECK_EQUAL( 1, result );
        delete GTT;
        // delete the geometry so new one can be built;
        rval = mbi->delete_mesh();MB_CHK_ERR_RET( rval );
    else
        for( int i = 0; i < n; i++ )
            heappermute( mbi, v, n - 1, ref_map, len );
            if( n % 2 == 1 )
                swap( &v[0], &v[n - 1] );
            else
                swap( &v[i], &v[n - 1] );
int main ( )
Definition at line 141 of file restore_topo_geom_incl_test.cpp.
References RUN_TEST, test_four_cubes(), test_three_cubes(), and test_two_cubes().
    int result = 0;
    result += RUN_TEST( test_two_cubes );
    result += RUN_TEST( test_three_cubes );
    result += RUN_TEST( test_four_cubes );
    return result;
void test_four_cubes ( )
Definition at line 350 of file restore_topo_geom_incl_test.cpp.
References ErrorCode, get_all_handles(), heappermute(), and MB_CHK_ERR_RET.
Referenced by main().
    ErrorCode rval;
    Interface* mbi = new Core();
    // get all handles (dimension, id, sense)
    rval = get_all_handles( mbi );MB_CHK_ERR_RET( rval );
    int len    = 4;
    int num[4] = { 1, 2, 3, 4 };
    // build reference map
    std::map< int, std::set< int > > ref_map;
    ref_map[1].insert( 1 );
    ref_map[2].insert( 2 );
    ref_map[2].insert( 1 );
    ref_map[3].insert( 3 );
    ref_map[3].insert( 2 );
    ref_map[4].insert( 4 );
    ref_map[4].insert( 3 );
    heappermute( mbi, num, len, ref_map, len );
    delete mbi;
void test_three_cubes ( )
Definition at line 322 of file restore_topo_geom_incl_test.cpp.
    ErrorCode rval;
    int len    = 3;
    int num[3] = { 1, 2, 3 };
    delete mbi;
void test_two_cubes ( )
Definition at line 295 of file restore_topo_geom_incl_test.cpp.
    ErrorCode rval;
    int len    = 2;
    int num[2] = { 1, 2 };
    delete mbi;
Variable Documentation
Definition at line 14 of file restore_topo_geom_incl_test.cpp.
Definition at line 17 of file restore_topo_geom_incl_test.cpp.
Definition at line 15 of file restore_topo_geom_incl_test.cpp.
Definition at line 16 of file restore_topo_geom_incl_test.cpp.
Referenced by build_cube(), and get_all_handles().
