main.cpp
00001 /* *****************************************************************
00002     MESQUITE -- The Mesh Quality Improvement Toolkit
00003
00004     Copyright 2004 Sandia Corporation and Argonne National
00005     Laboratory.  Under the terms of Contract DE-AC04-94AL85000
00006     with Sandia Corporation, the U.S. Government retains certain
00007     rights in this software.
00008
00009     This library is free software; you can redistribute it and/or
00010     modify it under the terms of the GNU Lesser General Public
00011     License as published by the Free Software Foundation; either
00012     version 2.1 of the License, or (at your option) any later version.
00013
00014     This library is distributed in the hope that it will be useful,
00015     but WITHOUT ANY WARRANTY; without even the implied warranty of
00016     MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00017     Lesser General Public License for more details.
00018
00019     You should have received a copy of the GNU Lesser General Public License
00020     (lgpl.txt) along with this library; if not, write to the Free Software
00021     Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA
00022
00023     [email protected], [email protected], [email protected],
00024     [email protected], [email protected], [email protected]
00025
00026   ***************************************************************** */
00027 // -*- Mode : c++; tab-width: 3; c-tab-always-indent: t; indent-tabs-mode: nil; c-basic-offset: 3
00028 // -*-
00029 //
00030 //   SUMMARY:
00031 //     USAGE:
00032 //
00033 // ORIG-DATE: 19-Feb-02 at 10:57:52
00034 //  LAST-MOD: 10-Feb-04 at 22:44:58 by Thomas Leurent
00035 //
00036 //
00037 // DESCRIPTION:
00038 // ============
00039 /*! \file main.cpp
00040
00041 describe main.cpp here
00042
00043  */
00044 // DESCRIP-END.
00045 //
00046
00047 // #define USE_IMESH
00048
00049 #include "Mesquite.hpp"
00050 #ifdef USE_IMESH
00051 #include "MsqIMesh.hpp"
00052 #else
00053 #include "MsqMOAB.hpp"
00054 #endif
00055 #include "MeshImpl.hpp"
00056 #include "MsqError.hpp"
00057 #include "InstructionQueue.hpp"
00058 #include "TerminationCriterion.hpp"
00059 #include "QualityAssessor.hpp"
00060 #include "PlanarDomain.hpp"
00061 #include "MeshWriter.hpp"
00062 #include "TestUtil.hpp"
00063
00064 // algorithms
00065 #include "IdealWeightInverseMeanRatio.hpp"
00066 #include "EdgeLengthQualityMetric.hpp"
00067 #include "LPtoPTemplate.hpp"
00068 #include "FeasibleNewton.hpp"
00069 #include "ConjugateGradient.hpp"
00070 #include "SmartLaplacianSmoother.hpp"
00071
00072 #include <iostream>
00073 using std::cerr;
00074 using std::cout;
00075 using std::endl;
00076
00077 #include "iBase.h"
00078
00079 using namespace MBMesquite;
00080
00081 std::string default_file_name = TestDir + "unittest/mesquite/3D/vtk/large_box_hex_1000.vtk";
00082
00083 void usage()
00084 {
00085     cout << "main [-N] [filename]" << endl;
00086     cout << "  -N : Use native representation instead of TSTT implementation\n";
00087     cout << "  If no file name is specified, will use \"" << default_file_name << '"' << endl;
00088     exit( 1 );
00089 }
00090
00091 // Construct a MeshTSTT from the file
00092 Mesh* get_imesh_mesh( const char* file_name );
00093
00094 // Construct a MeshImpl from the file
00095 Mesh* get_native_mesh( const char* file_name );
00096
00097 // Run FeasibleNewton solver
00098 int run_global_smoother( Mesh* mesh, MsqError& err );
00099
00100 // Run SmoothLaplacian solver
00101 int run_local_smoother( Mesh* mesh, MsqError& err );
00102
00103 int main( int argc, char* argv[] )
00104 {
00105     MBMesquite::MsqPrintError err( cout );
00106
00107     // command line arguments
00108     const char* file_name = 0;
00109     bool use_native = false, opts_done = false;
00110     for( int arg = 1; arg < argc; ++arg )
00111     {
00112         if( !opts_done && argv[arg][0] == '-' )
00113         {
00114             if( !strcmp( argv[arg], "-N" ) )
00115                 use_native = true;
00116             else if( !strcmp( argv[arg], "--" ) )
00117                 opts_done = true;
00118             else
00119                 usage();
00120         }
00121         else if( !file_name )
00122             file_name = argv[arg];
00123         else
00124             usage();
00125     }
00126     if( !file_name )
00127     {
00128         file_name = default_file_name.c_str();
00129         cout << "No file specified: using default: " << default_file_name << endl;
00130     }
00131
00132     // Try running a global smoother on the mesh
00133     Mesh* mesh = use_native ? get_native_mesh( file_name ) : get_imesh_mesh( file_name );
00134     if( !mesh )
00135     {
00136         std::cerr << "Failed to load input file.  Aborting." << std::endl;
00137         return 1;
00138     }
00139
00140     MeshWriter::write_vtk( mesh, "original.vtk", err );
00141     if( err ) return 1;
00142     cout << "Wrote \"original.vtk\"" << endl;
00143     run_global_smoother( mesh, err );
00144     if( err ) return 1;
00145
00146     // Try running a local smoother on the mesh
00147     mesh = use_native ? get_native_mesh( file_name ) : get_imesh_mesh( file_name );
00148     if( !mesh )
00149     {
00150         std::cerr << "Failed to load input file.  Aborting." << std::endl;
00151         return 1;
00152     }
00153
00154     run_local_smoother( mesh, err );
00155     if( err ) return 1;
00156
00157     return 0;
00158 }
00159
00160 int run_global_smoother( Mesh* mesh, MsqError& err )
00161 {
00162     double OF_value = 0.0001;
00163
00164     // creates an intruction queue
00165     InstructionQueue queue1;
00166
00167     // creates a mean ratio quality metric ...
00168     IdealWeightInverseMeanRatio* mean_ratio = new IdealWeightInverseMeanRatio( err );
00169     if( err ) return 1;
00170     mean_ratio->set_averaging_method( QualityMetric::SUM, err );
00171     if( err ) return 1;
00172
00173     // ... and builds an objective function with it
00174     LPtoPTemplate* obj_func = new LPtoPTemplate( mean_ratio, 1, err );
00175     if( err ) return 1;
00176
00177     // creates the feas newt optimization procedures
00178     FeasibleNewton* pass1 = new FeasibleNewton( obj_func );
00179     pass1->use_global_patch();
00180     if( err ) return 1;
00181
00182     QualityAssessor stop_qa( mean_ratio );
00183
00184     // **************Set stopping criterion****************
00185     TerminationCriterion tc_inner;
00186     tc_inner.add_absolute_vertex_movement( OF_value );
00187     if( err ) return 1;
00188     TerminationCriterion tc_outer;
00189     tc_outer.add_iteration_limit( 1 );
00190     pass1->set_inner_termination_criterion( &tc_inner );
00191     pass1->set_outer_termination_criterion( &tc_outer );
00192
00193     queue1.add_quality_assessor( &stop_qa, err );
00194     if( err ) return 1;
00195
00196     // adds 1 pass of pass1 to mesh_set1
00197     queue1.set_master_quality_improver( pass1, err );
00198     if( err ) return 1;
00199
00200     queue1.add_quality_assessor( &stop_qa, err );
00201     if( err ) return 1;
00202
00203     // launches optimization on mesh_set
00204     queue1.run_instructions( mesh, err );
00205     if( err ) return 1;
00206
00207     MeshWriter::write_vtk( mesh, "feasible-newton-result.vtk", err );
00208     if( err ) return 1;
00209     cout << "Wrote \"feasible-newton-result.vtk\"" << endl;
00210
00211     // print_timing_diagnostics( cout );
00212     return 0;
00213 }
00214
00215 int run_local_smoother( Mesh* mesh, MsqError& err )
00216 {
00217     double OF_value = 0.0001;
00218
00219     // creates an intruction queue
00220     InstructionQueue queue1;
00221
00222     // creates a mean ratio quality metric ...
00223     IdealWeightInverseMeanRatio* mean_ratio = new IdealWeightInverseMeanRatio( err );
00224     if( err ) return 1;
00225     mean_ratio->set_averaging_method( QualityMetric::SUM, err );
00226     if( err ) return 1;
00227
00228     // ... and builds an objective function with it
00229     LPtoPTemplate* obj_func = new LPtoPTemplate( mean_ratio, 1, err );
00230     if( err ) return 1;
00231
00232     // creates the smart laplacian optimization procedures
00233     SmartLaplacianSmoother* pass1 = new SmartLaplacianSmoother( obj_func );
00234
00235     QualityAssessor stop_qa( mean_ratio );
00236
00237     // **************Set stopping criterion****************
00238     TerminationCriterion tc_inner;
00239     tc_inner.add_absolute_vertex_movement( OF_value );
00240     TerminationCriterion tc_outer;
00241     tc_outer.add_iteration_limit( 1 );
00242     pass1->set_inner_termination_criterion( &tc_inner );
00243     pass1->set_outer_termination_criterion( &tc_outer );
00244
00245     queue1.add_quality_assessor( &stop_qa, err );
00246     if( err ) return 1;
00247
00248     // adds 1 pass of pass1 to mesh_set
00249     queue1.set_master_quality_improver( pass1, err );
00250     if( err ) return 1;
00251
00252     queue1.add_quality_assessor( &stop_qa, err );
00253     if( err ) return 1;
00254
00255     // launches optimization on mesh_set
00256     queue1.run_instructions( mesh, err );
00257     if( err ) return 1;
00258
00259     MeshWriter::write_vtk( mesh, "smart-laplacian-result.vtk", err );
00260     if( err ) return 1;
00261     cout << "Wrote \"smart-laplacian-result.vtk\"" << endl;
00262
00263     // print_timing_diagnostics( cout );
00264     return 0;
00265 }
00266
00267 Mesh* get_imesh_mesh( const char* file_name )
00268 {
00269 #ifdef USE_IMESH
00270     int ierr;
00271     iMesh_Instance imesh_mesh = 0;
00272     iMesh_newMesh( NULL, &imesh_mesh, &ierr, 0 );
00273     if( iBase_SUCCESS != ierr )
00274     {
00275         return 0;
00276     }
00277
00278     iBase_EntitySetHandle root_set;
00279     iMesh_getRootSet( imesh_mesh, &root_set, &ierr );
00280     if( iBase_SUCCESS != ierr )
00281     {
00282         iMesh_dtor( imesh_mesh, &ierr );
00283         return 0;
00284     }
00285
00286     iMesh_load( imesh_mesh, root_set, file_name, 0, &ierr, strlen( file_name ), 0 );
00287     if( iBase_SUCCESS != ierr )
00288     {
00289         std::cerr << file_name << ": failed to load file." << std::endl;
00290         iMesh_dtor( imesh_mesh, &ierr );
00291         return 0;
00292     }
00293
00294     iBase_TagHandle fixed_tag;
00295     iMesh_getTagHandle( imesh_mesh, "fixed", &fixed_tag, &ierr, strlen( "fixed" ) );
00296     if( iBase_SUCCESS != ierr )
00297     {
00298         iMesh_dtor( imesh_mesh, &ierr );
00299         return 0;
00300     }
00301
00302     MsqError err;
00303     Mesh* result = new MBMesquite::MsqIMesh( imesh_mesh, root_set, iBase_REGION, err, &fixed_tag );
00304     if( MSQ_CHKERR( err ) )
00305     {
00306         delete result;
00307         cerr << err << endl;
00308         return 0;
00309     }
00310
00311 #else
00312
00313     moab::Core* mb = new( std::nothrow ) moab::Core;
00314     if( NULL == mb ) return 0;
00315
00316     moab::ErrorCode rval;
00317     // This file is in the mesh files directory
00318     rval = mb->load_file( file_name );MB_CHK_SET_ERR_RET_VAL( rval, "Failed to read", 0 );
00319
00320     moab::Tag fixed_tag;
00321     rval = mb->tag_get_handle( "fixed", fixed_tag );MB_CHK_SET_ERR_RET_VAL( rval, "Failed to create fixed tag", 0 );
00322
00323     moab::EntityHandle root_set = 0;
00324     MsqError err;
00325     Mesh* result = new MBMesquite::MsqMOAB( mb, root_set, moab::MBHEX, err, &fixed_tag );
00326     if( MSQ_CHKERR( err ) )
00327     {
00328         delete result;
00329         cerr << err << endl;
00330         return 0;
00331     }
00332
00333 #endif
00334
00335     return result;
00336 }
00337
00338 Mesh* get_native_mesh( const char* file_name )
00339 {
00340     MsqError err;
00341     MeshImpl* mesh = new MeshImpl;
00342     if( !mesh )
00343     {
00344         cerr << "Failed during MeshImpl construction.\n";
00345         exit( 2 );
00346     }
00347     mesh->read_vtk( file_name, err );
00348     if( err )
00349     {
00350         cerr << err << endl;
00351         exit( 3 );
00352     }
00353
00354     return mesh;
00355 }
