cgma
CompositeSurface.hpp
00001 //-------------------------------------------------------------------------
00002 // Filename      : CompositeSurface.hpp
00003 //
00004 // Purpose       : A class for composited surface geometry
00005 //
00006 // Special Notes :
00007 //
00008 // Creator       : Jason Kraftcheck
00009 //
00010 // Creation Date : 03/10/98
00011 //
00012 // Owner         : Jason Kraftcheck
00013 //-------------------------------------------------------------------------
00014
00015 #ifndef COMPOSITE_SURFACE_HPP
00016 #define COMPOSITE_SURFACE_HPP
00017
00018 #include "VGDefines.h"
00019 #include "CompositeGeom.hpp"
00020 #include "Surface.hpp"
00021 #include "TBOwner.hpp"
00022 #include "HiddenEntitySet.hpp"
00023 #include "CompositeLoop.hpp"
00024 #include "CompositeCoSurf.hpp"
00025
00026 class CompositeCoSurf;
00027 class CompositeEngine;
00028 class CompositePoint;
00029 class CompositeCurve;
00030 class CompositeShell;
00031 class CompositeLump;
00032 class CompSurfFacets;
00033 class GMem;
00034
00035 class CompositeSurface: public Surface, public TBOwner
00036 {
00037   friend class CompositeEngine;
00038
00039 public:
00040   CompositeSurface( Surface* surf_ptr );
00041   CompositeSurface( CompositeGeom* geom_ptr );
00042   //- Constructor
00043
00044   virtual ~CompositeSurface();
00045   //- Destructor
00046
00047   //CubitStatus add( Surface* surface, CubitSense relative_sense );
00048   //CubitStatus remove( Surface* surface );
00049   void get_ignored_surfs(DLIList<Surface*> &surfs);
00050   int num_surfs() const;
00051   int index_of( Surface* surface ) const;
00052   void update();
00053   Surface* get_surface( int index ) const;
00054   CubitSense get_sense( int index ) const;
00055   Surface* remove_surface( int index );
00056   void ignore_surface(int surface_id);
00057   void ignore_surface(Surface *surf);
00058   void unignore_surface(int surface_id);
00059   CompositeLoop* first_loop() const;
00060   CompositeLoop* next_loop( CompositeLoop* after_this = 0 ) const;
00061   CubitStatus add( CompositeLoop* loop );
00062   CubitStatus remove( CompositeLoop* loop );
00063
00064   CubitStatus add( CompositeCoSurf* cosurf );
00065   CubitStatus remove( CompositeCoSurf* cosurf );
00066
00067   CompositeCoSurf* next_co_surface( CompositeCoSurf* prev = 0 ) const;
00068
00069   CompositeCoSurf* find_first( CompositeShell* shell ) const;
00070     // Get the first CoSurface connecting this surface w/ the passed shell
00071   CompositeCoSurf* find_first( CompositeLump* lump ) const;
00072     // Get the first CoSurface connecting this surface w/ a
00073     // shell owned by the passed volume
00074   CompositeCoSurf* find_next( CompositeCoSurf* cosurf ) const;
00075     // Get the next CoSurface after the passed CoSurface and
00076     // with the same Shell as the passed CoSurface.
00077
00078   void get_curves( DLIList<CompositeCurve*>& curves );
00079
00080   HiddenEntitySet& hidden_entities();
00081   bool has_hidden_entities() const;
00082
00083   CompositeSurface* split( VGArray<int>& indices_to_move );
00084   CubitStatus combine( CompositeSurface* dead_surface );
00085
00086   CubitStatus stitch( CompositeSurface* stitch_partner );
00087   CompositeSurface* unstitch( );
00088   CompositeSurface* get_stitch_partner() const
00089     { return stitchPartner; }
00090
00091
00092   /************************************************
00093    **** Methods Inhereted from GeometryEntity *****
00094    ************************************************/
00095   CubitBox bounding_box() const;
00096   double measure();
00097   GeometryQueryEngine* get_geometry_query_engine() const;
00098   GeometryType geometry_type();
00099
00100
00101   /************************************************
00102    ******** Methods Inhereted from TBOwner ********
00103    ************************************************/
00104   CubitStatus remove_bridge( TopologyBridge* bridge );
00105   CubitStatus swap_bridge( TopologyBridge* old_tb, TopologyBridge* new_tb,
00106                            bool reversed );
00107   CubitBoolean contains_bridge( TopologyBridge* bridge ) const;
00108   void notify_reversed( TopologyBridge* bridge );
00109   void notify_split( TopologyBridge* new_bridge, TopologyBridge* old_bridge );
00110   void notify_topology_modified( TopologyBridge* bridge );
00111
00112   /************************************************
00113    **** Methods Inhereted from TopologyBridge *****
00114    ************************************************/
00115   void append_simple_attribute_virt( const CubitSimpleAttrib& simple_attrib_ptr );
00116   void remove_simple_attribute_virt( const CubitSimpleAttrib& simple_attrib_ptr );
00117   void remove_all_simple_attribute_virt();
00118   CubitStatus get_simple_attribute( DLIList<CubitSimpleAttrib>& attrib_list );
00119   CubitStatus get_simple_attribute( const CubitString& name,
00120                                     DLIList<CubitSimpleAttrib>& attrib_list );
00121
00122
00123   void get_parents_virt( DLIList<TopologyBridge*>& parents );
00124   void get_children_virt( DLIList<TopologyBridge*>& children );
00125   int layer() const { return COMPOSITE_LAYER; }
00126
00127   /**********************************************************
00128    **** Methods Inhereted from Surface, and implemented *****
00129    **********************************************************/
00130   virtual CubitSense get_shell_sense( ShellSM* shell_ptr ) const;
00131
00132   virtual void closest_point_trimmed( CubitVector from_point,
00133                                       CubitVector& result );
00134   virtual CubitStatus get_point_normal( CubitVector& origin,
00135                                         CubitVector& normal );
00136
00137   virtual CubitStatus closest_point_uv_guess(
00138       CubitVector const& location,
00139       double &u, double &v,
00140       CubitVector* closest_location = NULL,
00141       CubitVector* unit_normal = NULL );
00142
00143   virtual CubitStatus evaluate( double u, double v,
00144                                 CubitVector *position,
00145                                 CubitVector *normal,
00146                                 CubitVector *curvature1,
00147                                 CubitVector *curvature2 );
00148
00149   virtual CubitStatus get_projected_distance_on_surface( CubitVector *pos1,
00150                                                          CubitVector *pos2,
00151                                                          double &distance );
00152
00153   virtual CubitStatus closest_point( CubitVector const& location,
00154                                      CubitVector* closest_location = NULL,
00155                                      CubitVector* unit_normal = NULL,
00156                                      CubitVector* curvature1 = NULL,
00157                                      CubitVector* curvature2 = NULL );
00158
00159   virtual CubitStatus closest_point_along_vector(CubitVector& from_point,
00160                                          CubitVector& along_vector,
00161                                          CubitVector& point_on_surface);
00162
00163   virtual CubitStatus principal_curvatures( CubitVector const& location,
00164                                             double& curvature_1,
00165                                             double& curvature_2,
00166                                             CubitVector* closest_location );
00167   virtual CubitBoolean is_parametric();
00168   virtual CubitBoolean is_position_on(CubitVector& position);
00169   virtual CubitPointContainment point_containment( const CubitVector &point );
00170   virtual CubitPointContainment point_containment( double u, double v );
00171 //  virtual CubitPointContainment point_containment( CubitVector &point,
00172 //                                                   double u, double v );
00173   virtual CubitSense get_geometry_sense();
00174   virtual void reverse_sense();
00175
00176
00177   /**************************************************************
00178    **** Methods Inhereted from Surface, and not implemented *****
00179    **************************************************************/
00180   virtual CubitVector position_from_u_v( double u, double v );
00181   virtual CubitStatus u_v_from_position( CubitVector const& position,
00182                                          double& u, double& v,
00183                                          CubitVector* closest_point );
00184   virtual CubitBoolean is_periodic();
00185   virtual CubitBoolean is_periodic_in_U( double& period );
00186   virtual CubitBoolean is_periodic_in_V( double& period );
00187   virtual CubitBoolean is_singular_in_U( double u_value );
00188   virtual CubitBoolean is_singular_in_V( double v_value );
00189   virtual CubitBoolean is_closed_in_U();
00190   virtual CubitBoolean is_closed_in_V();
00191   virtual CubitStatus uv_derivitives( double u, double v,
00192                                       CubitVector& du,
00193                                       CubitVector& dv );
00194   virtual CubitBoolean get_param_range_U( double& lower, double& upper );
00195   virtual CubitBoolean get_param_range_V( double& lower, double& upper );
00196
00197   virtual CubitStatus get_sphere_params( CubitVector &center,
00198                                          double &radius ) const;
00199     //- Only valid for spherical surfaces
00200     //O center
00201     //O- The center of the sphere
00202     //O radius
00203     //O- The radius of the sphere
00204
00205   virtual CubitStatus get_cone_params( CubitVector &center,
00206                                        CubitVector &normal,
00207                                        CubitVector &major_axis,
00208                                        double &radius_ratio,
00209                                        double &sine_angle,
00210                                        double &cos_angle ) const;
00211     //- Only valid for conical surfaces.  Cylinders are a special case of conicals.
00212     //O center
00213     //O-
00214     //O normal
00215     //O-
00216     //O major_axis
00217     //O-
00218     //O radius_ratio
00219     //O-
00220     //O sine_angle
00221     //O-
00222     //O cos_angle
00223     //O-
00224
00225     virtual CubitStatus get_torus_params( CubitVector &center,
00226                                         CubitVector &normal,
00227                                         double &major_radius,
00228                                         double &minor_radius ) const;
00229     //- Only valid for torus surfaces.
00230     //O center
00231     //O-
00232     //O normal
00233     //O-
00234     //O major_radius
00235     //O-
00236     //O minor_radius
00237     //O-
00238
00239   virtual CubitStatus get_nurb_params( bool &rational,
00240                                        int &degree_u,
00241                                        int &degree_v,
00242                                        int &num_cntrl_pts_u,
00243                                        int &num_cntrl_pts_v,
00244                                        DLIList<CubitVector> &cntrl_pts,
00245                                        DLIList<double> &weights,
00246                                        DLIList<double> &u_knots,
00247                                        DLIList<double> &v_knots ) const;
00248   //- Only valid for nurbs surfaces
00249   //O rational
00250   //O-   True if the nurb is rational
00251   //O degree_u
00252   //O-   The degree of the nurb in the u direction
00253   //O degree_v
00254   //O-   The degree of the nurb in the v direction
00255   //O num_cntrl_pts_u
00256   //O-   Number of control points in the u direction
00257   //O num_cntrl_pts_v
00258   //O-   Number of control points in the v direction
00259   //O cntrl_pts
00260   //O-   The control points stored as
00261   //O-           cntrl_pts[0                ] = pt[u=0][v=0]
00262   //O-           cntrl_pts[1                ] = pt[u=1][v=0]
00263   //O-               ...
00264   //O-           cntrl_pts[num_cntrl_pts_u-1] = pt[u=?][v=0]
00265   //O-           cntrl_pts[num_cntrl_pts_u  ] = pt[u=0][v=1]
00266   //O-               ...
00267   //O weights
00268   //O-   If rational, weights for each control point, stored in the same
00269   //O-   order as the control points.  No weights are returned if
00270   //O-   rational == false
00271   //O u_knots
00272   //O-   knot vector in the u direction
00273   //O v_knots
00274   //O-   knot vector in the v direction
00275
00276   void get_hidden_curves( DLIList<Curve*>& curves );
00277
00278   void print_debug_info( const char* line_prefix = 0, bool brief = false );
00279
00280   int closest_underlying_surface( const CubitVector& position );
00281
00282   static void print_cpt_stats();
00283   static void reset_cpt_stats();
00284
00285   void read_attributes() { compGeom->read_attributes(); }
00286   void write_attributes() { compGeom->write_attributes(); }
00287
00288
00289   CubitStatus get_graphics( GMem& gmem );
00290
00291   // handles transformation of composite surface
00292   // child loops, coedges, etc. must be handled separately
00293   void notify_transformed();
00294
00295 protected:
00296
00297   void update_facet_tool();
00298   void update_facets_to_ignore();
00299   CubitStatus closest_trimmed( int underlying_surface,
00300                                const CubitVector& position,
00301                                CubitVector& result );
00302
00303   void update_modified( Surface* modified_surface,
00304                         DLIList<CompositeCurve*>& new_curves );
00305   void update_modified();
00306   bool     is_dead_coedge( CompositeCoEdge* coedge );
00307   void remove_dead_coedge( CompositeCoEdge* coedge );
00308
00309 private:
00310   int HadBridgeRemoved;
00311
00312   DLIList<Surface*> surfacesToIgnore;
00313
00314     // these have no implementation, just private delcarations
00315     // to prevent the compiler from generating default implementations
00316   CompositeSurface& operator=(const CompositeSurface&);
00317   CompositeSurface(const CompositeSurface&);
00318
00319   CompositeGeom *compGeom;
00320   CompositeSurface *stitchPartner;
00321
00322   CompositeCoSurf* firstCoSurf;
00323
00324   CompositeLoop* firstLoop;
00325
00326   HiddenEntitySet* hiddenSet;
00327
00328   CompSurfFacets* facetTool;
00329 };
00330
00331
00332 inline Surface* CompositeSurface::get_surface( int index )  const
00333   { return dynamic_cast<Surface*>(compGeom->entity(index)); }
00334
00335 inline CubitSense CompositeSurface::get_sense( int index ) const
00336   { return compGeom->sense(index); }
00337
00338 inline int CompositeSurface::num_surfs() const
00339   { return compGeom->num_entities(); }
00340
00341 inline int CompositeSurface::index_of( Surface* surf ) const
00342   { return compGeom->index_of( surf ); }
00343
00344 inline void CompositeSurface::update()
00345   { compGeom->update_cached_data(); }
00346 inline CompositeLoop* CompositeSurface::first_loop( ) const
00347   { return firstLoop; }
00348
00349 inline CompositeLoop* CompositeSurface::next_loop( CompositeLoop* loop ) const
00350   { return !loop ? firstLoop : loop->mySurface == this ? loop->loopNext : 0; }
00351
00352 inline CompositeCoSurf* CompositeSurface::next_co_surface( CompositeCoSurf* prev ) const
00353   { return prev ? prev->surfaceNext : firstCoSurf; }
00354
00355 inline HiddenEntitySet& CompositeSurface::hidden_entities()
00356 {
00357   if( !hiddenSet )
00358     hiddenSet = new HiddenEntitySet(this);
00359   return *hiddenSet;
00360 }
00361
00362
00363 #endif
00364
