cgma
CubitAttrib.hpp
00001 //- Class:          CubitAttrib
00002 //- Owner:          Greg Nielson
00003 //- Description:    pure virtual base class from which all the specific
00004 //-                 cubit attributes are derived.
00005 //- Checked By:
00006 //- Version:
00007
00008 #ifndef CUBIT_ATTRIB_HPP
00009 #define CUBIT_ATTRIB_HPP
00010
00011 #include "CubitString.hpp"
00012 #include "CubitDefines.h"
00013 #include "CubitVector.hpp"
00014
00015 #include "CubitAttribManager.hpp"
00016 #include "CGMApp.hpp"
00017 #include "CGMGeomConfigure.h"
00018 #include "CubitSimpleAttrib.hpp"
00019
00020 class RefEntity;
00021 template <class X> class DLIList;
00022 class CubitSimpleAttrib;
00023 class CubitAttribUser;
00024
00025 // this enum used to index static arrays; first attribute must start at 0,
00026 // last attribute must be CA_LAST_CA (some static arrays dimensioned using
00027 // this item)
00028 /*
00029 enum CubitAttributeType {
00030     CA_UNDEFINED = -1,
00031     CA_MERGE_PARTNER = 0, // must be 0!!!
00032     CA_ENTITY_NAME,
00033     CA_GROUP,
00034     CA_ENTITY_ID,
00035 //    CA_PARTITION_VG,
00036 //    CA_COMPOSITE_VG,
00037 //    CA_VIRTUAL_VG,
00038     CA_UNIQUE_ID,
00039     CA_DEFERRED_ATTRIB,
00040     CA_MESH_INTERVAL,
00041     CA_MESH_RELATIVE_LENGTH,
00042     CA_GENESIS_ENTITY,
00043     CA_MESH_SCHEME,
00044     CA_SMOOTH_SCHEME,
00045     CA_VERTEX_TYPE,
00046     CA_MESH_CONTAINER,
00047     CA_BODIES,
00048     CA_ENTITY_COLOR,
00049 #ifdef CAT
00050     CA_VERTEX_FORCE,
00051     CA_SURFACE_FORCE,
00052     CA_CURVE_FORCE,
00053     CA_VERTEX_DISPLACEMENT,
00054     CA_SURFACE_DISPLACEMENT,
00055     CA_CURVE_DISPLACEMENT,
00056     CA_VOLUME_DISPLACEMENT,
00057     CA_SURFACE_PRESSURE,
00058     CA_CURVE_PRESSURE,
00059     CA_SURFACE_TEMPERATURE,
00060     CA_CURVE_TEMPERATURE,
00061     CA_VERTEX_TEMPERATURE,
00062     CA_SURFACE_HEATFLUX,
00063     CA_CURVE_HEATFLUX,
00064     CA_SURFACE_CONVECTION,
00065     CA_CURVE_CONVECTION,
00066     CA_SURFACE_CONTACT,
00067     CA_CURVE_CONTACT,
00068 #endif
00069     CA_MERGE_STATUS,
00070     CA_LAST_CA // must be last item!!!
00071 };
00072 */
00073 class CubitAttrib;
00074
00075 class CUBIT_GEOM_EXPORT CubitAttribFactory
00076 {
00077 public:
00078   friend class CubitAttrib;
00079
00080 protected:
00081   CubitAttribFactory() {};
00082
00083   virtual ~CubitAttribFactory() {};
00084
00085 private:
00086   virtual CubitAttrib *create_cubit_attrib(const int attrib_type,
00087                                            RefEntity *entity) = 0;
00088
00089   virtual CubitAttrib *create_cubit_attrib(CubitSimpleAttrib *csa_ptr,
00090                                            RefEntity *entity) = 0;
00091 };
00092
00093 class CUBIT_GEOM_EXPORT CubitAttrib
00094 {
00095 public:
00096
00097   CubitAttrib(RefEntity *attrib_owner);
00098     //- bare constructor
00099
00100   virtual ~CubitAttrib();
00101     //- destructor
00102
00103 //  static CubitAttrib *create_cubit_attrib(const int attrib_type,
00104 //                                          RefEntity *entity);
00105     //- create a cubit attribute of the specified type and pass it back
00106
00107 //  static CubitAttrib *create_cubit_attrib(CubitSimpleAttrib *csa_ptr,
00108 //                                          RefEntity *entity);
00109     //- create a cubit attribute from a CSA and pass it back
00110
00111     //HEADER-: get/set functions
00112
00113   RefEntity* attrib_owner() {return attribOwnerEntity;}
00114   void attrib_owner(RefEntity* new_attrib_owner)
00115     {attribOwnerEntity = new_attrib_owner;}
00116     //- get/set the attrib owner
00117
00118   CubitBoolean has_actuated() {return hasActuated;}
00119   void has_actuated(CubitBoolean set_has_actuated)
00120     { hasActuated = set_has_actuated;}
00121     //- get/set hasActuated
00122
00123   CubitBoolean has_updated() {return hasUpdated;}
00124   void has_updated(CubitBoolean set_has_updated)
00125     { hasUpdated = set_has_updated;}
00126     //- get/set hasUpdated
00127
00128   virtual CubitBoolean has_written() const;
00129   virtual void has_written(CubitBoolean set_has_written);
00130     //- get/set hasWritten
00131
00132   void delete_attrib(CubitBoolean set_remove) {deleteAttrib = set_remove;}
00133   CubitBoolean delete_attrib() {return deleteAttrib;}
00134     //- get/set the deleteAttrib flag
00135
00136   CubitAttrib* next_attrib() {return nextAttrib;}
00137   CubitStatus set_next_attrib(CubitAttrib* next_attrib_ptr);
00138     //- get/set the next attribute in the chain
00139
00140 //  static CubitStatus auto_create_attribs(CubitAttribUser *cau);
00141     //- create attribs whose auto update flag is set
00142
00143 //  static CubitStatus auto_update_attribs(CubitAttribUser *cau);
00144     //- create attribs whose auto update flag is set
00145
00146 //  static void auto_actuate_flag(int attrib_type, CubitBoolean value);
00147 //  static CubitBoolean auto_actuate_flag(int attrib_type);
00148 //  static void auto_update_flag(int attrib_type, CubitBoolean value);
00149 //  static CubitBoolean auto_update_flag(int attrib_type);
00150 //  static void auto_write_flag(int attrib_type, CubitBoolean value);
00151 //  static CubitBoolean auto_write_flag(int attrib_type);
00152 //  static void auto_read_flag(int attrib_type, CubitBoolean value);
00153 //  static CubitBoolean auto_read_flag(int attrib_type);
00154     //- get/set actuate, update, write, and read flags, static versions
00155
00156 //  static CubitBoolean* auto_read_flag_ptr(int attrib_type);
00157 //  static CubitBoolean* auto_actuate_flag_ptr(int attrib_type);
00158 //  static CubitBoolean* auto_update_flag_ptr(int attrib_type);
00159 //  static CubitBoolean* auto_write_flag_ptr(int attrib_type);
00160       //- get array ptr for actuate, update, write, and read flags, static versions
00161
00162 //  static void auto_flag(int flag);
00163 //  static int auto_flag();
00164     //- get/set all attribute flags
00165   //- returns -1, 0 or 1.
00166
00167   void auto_actuate_flag(CubitBoolean value);
00168   CubitBoolean auto_actuate_flag();
00169   void auto_update_flag(CubitBoolean value);
00170   CubitBoolean auto_update_flag();
00171   void auto_write_flag(CubitBoolean value);
00172   CubitBoolean auto_write_flag();
00173   void auto_read_flag(CubitBoolean value);
00174   CubitBoolean auto_read_flag();
00175     //- get/set actuate, update, write, and read flags, non-static versions
00176
00177   CubitBoolean actuate_in_constructor();
00178     //- return value of actuateInConstructor for this attribute type
00179
00180   CubitBoolean actuate_after_geom_changes();
00181     //- return value of actuateAfterGeomChanges for this attribute type
00182
00183 //  static CubitBoolean overwrite_flag() {return overwriteFlag;}
00184 //  static void overwrite_flag(CubitBoolean flag) {overwriteFlag = flag;}
00185     //- get/set overwriteFlag
00186
00187   virtual CubitSimpleAttrib cubit_simple_attrib() = 0;
00188     //- return a cubitSimpleAttrib for this CA
00189
00190   virtual CubitStatus actuate() = 0;
00191     //- actuate this attrib
00192
00193   virtual CubitStatus actuate_list(DLIList<RefEntity*>);
00194     //- actuate this attrib on each of the entities passed in
00195
00196   virtual CubitStatus update() = 0;
00197     //- update this attrib
00198
00199   virtual CubitStatus reset() = 0;
00200     //- reset any lists or other info in this attribute
00201
00202   virtual CubitSimpleAttrib split_owner();
00203     //- split this attrib; pass back a new simple attrib if desired
00204
00205   virtual void merge_owner(CubitAttrib *deletable_ca_ptr);
00206     //- merge this attrib with deletable_ca_ptr (keep this)
00207
00208   virtual void transf_owner(const CubitVector &matrow1,
00209                             const CubitVector &matrow2,
00210                             const CubitVector &matrow3,
00211                             const CubitVector &translate_vec,
00212                             const double scale_factor);
00213     //- transform this attrib with the data passed in
00214
00215     virtual int int_attrib_type() = 0;
00216     //- return the enumerated type of attribute
00217
00218   const char *att_internal_name() {
00219     return CGMApp::instance()->attrib_manager()->att_internal_name( int_attrib_type() );
00220   }
00221     //- return the internal name of this attribute
00222
00223 //  static const char *att_internal_name(CubitAttributeType attrib_type) {
00224 //    return (attrib_type < 0 || attrib_type > CA_LAST_CA)
00225 //          ? NULL : attInternalNames[attrib_type];
00226 //  }
00227     //- return the internal name of this CA given the enumerated attribute type
00228
00229 //  static const char *att_name(CubitAttributeType attrib_type) {
00230 //    return (attrib_type < 0 || attrib_type > CA_LAST_CA)
00231 //          ? NULL : attTypeNames[attrib_type];
00232 //  }
00233     //- return the internal name of this CA given the enumerated attribute type
00234
00235 //  static CubitAttributeType attrib_type(const char* name);
00236     //- Converts a string to the corresponding int
00237
00238 //  static CubitAttributeType attrib_type_from_internal_name(const char* name);
00239     //- Converts an "internal name" string to the corresponding int
00240
00241 //  static CubitAttributeType attrib_type(CubitSimpleAttrib *csa_ptr);
00242     //- returns the type given a simple attribute
00243
00244 //  static int equivalent(CubitAttrib* first_attrib_ptr,
00245 //                        CubitAttrib* second_attrib_ptr);
00246     //- return true if the two ca's are equivalent
00247
00248   int equivalent(const CubitSimpleAttrib& csa_ptr);
00249     //- return true if the csa and this are equivalent
00250
00251 //  static CubitBoolean attrib_exists(int attrib_type, CubitBoolean print = CUBIT_TRUE);
00252     //- find if the attrib exists, and print some details
00253
00254   virtual void print();
00255     //- print some details about this attrib
00256
00257 //  static CubitStatus import_actuate(DLIList<RefEntity*> &entity_list);
00258     //- given a Body list, actuates first the merge partner attribute
00259     //- on all entities in the list, then actuates all other types of
00260     //- attributes
00261
00262 //  static void set_cubit_attrib_factory(CubitAttribFactory *factory)
00263 //    {cubitAttribFactory = factory;}
00264     //- user-provided attribute factory
00265
00266 //  static int number_of_attributes();
00267     //- Returns number of defined attributes
00268
00269 //  static void clear_attrib_importeds();
00270     //- clear the attribImported array
00271
00272 //  static void report_attrib_importeds();
00273     //- print info on the attribImported array
00274
00275 protected:
00276
00277   virtual void remove_attribute();
00278   //- Removes 'this' attribute
00279   virtual void add_attribute();
00280   //- and adds a new one with the changed data.
00281
00282   CubitBoolean hasActuated;
00283     //- flag telling whether this CA has actuated
00284
00285   CubitBoolean hasUpdated;
00286     //- flag telling whether this CA has updated
00287
00288   CubitBoolean hasWritten;
00289     //- flag telling whether this CA has a corresponding geometry attribute
00290     //- (on the geometric entity assoc'd with the owner)
00291
00292   CubitBoolean deleteAttrib;
00293     //- flag telling whether this CA should be deleted
00294
00295   RefEntity* attribOwnerEntity;
00296     //- ref entity to which this CA is associated
00297
00298   CubitAttrib* nextAttrib;
00299     //- next attribute in the chain
00300
00301 //   static const char* attTypeNames[];
00302     //- names of attribute types
00303
00304 //   static const char* attInternalNames[];
00305     //- names of attributes, used in acis files; can't be the same as
00306     //- attTypeNames because those have to be user-recognizable and can
00307     //- be multiple words (e.g. "entity name")
00308
00309 //  static CubitBoolean autoActuateFlag[CA_LAST_CA];
00310 //  static CubitBoolean autoUpdateFlag[CA_LAST_CA];
00311 //  static CubitBoolean autoWriteFlag[CA_LAST_CA];
00312 //  static CubitBoolean autoReadFlag[CA_LAST_CA];
00313 //  static CubitBoolean actuateInConstructor[CA_LAST_CA];
00314 //  static CubitBoolean actuateAfterGeomChanges[CA_LAST_CA];
00315     //- auto flags for each type of CA
00316
00317 //  static bool attribImported[CA_LAST_CA];
00318     //- static flag used in import type reporting
00319
00320 //  static CubitBoolean overwriteFlag;
00321     //- if CUBIT_TRUE, any attribute can overwrite default files
00322     //- (used for mesh container attribute default filenames)
00323
00324 private:
00325
00326 //  static CubitAttribFactory *cubitAttribFactory;
00327     //- application-provided attribute factory
00328
00329 };
00330
00331 // static versions
00332 //inline CubitBoolean CubitAttrib::auto_actuate_flag(int attrib_type)
00333 //{return autoActuateFlag[attrib_type];}
00334
00335 //inline CubitBoolean CubitAttrib::auto_update_flag(int attrib_type)
00336 //{return autoUpdateFlag[attrib_type];}
00337
00338 //inline CubitBoolean CubitAttrib::auto_write_flag(int attrib_type)
00339 //{return autoWriteFlag[attrib_type];}
00340
00341 //inline CubitBoolean CubitAttrib::auto_read_flag(int attrib_type)
00342 //{return autoReadFlag[attrib_type];}
00343
00344 //inline CubitBoolean* CubitAttrib::auto_read_flag_ptr(int attrib_type)
00345 //{return &autoReadFlag[attrib_type];}
00346
00347 //inline CubitBoolean* CubitAttrib::auto_actuate_flag_ptr(int attrib_type)
00348 //{return &autoActuateFlag[attrib_type];}
00349
00350 //inline CubitBoolean* CubitAttrib::auto_update_flag_ptr(int attrib_type)
00351 //{return &autoUpdateFlag[attrib_type];}
00352
00353 //inline CubitBoolean* CubitAttrib::auto_write_flag_ptr(int attrib_type)
00354 //{return &autoWriteFlag[attrib_type];}
00355
00356 // non-static versions
00357 inline void CubitAttrib::auto_actuate_flag(CubitBoolean value)
00358 {
00359   CGMApp::instance()->attrib_manager()->set_auto_actuate_flag(int_attrib_type(), value);
00360 }
00361
00362 inline CubitBoolean CubitAttrib::auto_actuate_flag()
00363 {
00364   return CGMApp::instance()->attrib_manager()->auto_actuate_flag(int_attrib_type());
00365 }
00366
00367 inline CubitBoolean CubitAttrib::actuate_in_constructor()
00368 {
00369   return CGMApp::instance()->attrib_manager()->actuate_in_constructor(int_attrib_type());
00370 }
00371     //- get/set actuate, update, write, and read flags, non-static versions
00372
00373 inline CubitBoolean CubitAttrib::actuate_after_geom_changes()
00374 {
00375   return CGMApp::instance()->attrib_manager()->actuate_after_geom_changes(int_attrib_type());
00376 }
00377     //- get/set actuate, update, write, and read flags, non-static versions
00378
00379 inline CubitStatus CubitAttrib::set_next_attrib(CubitAttrib* next_attrib_ptr)
00380 {
00381   nextAttrib = next_attrib_ptr;
00382   return CUBIT_SUCCESS;
00383 }
00384
00385 inline CubitSimpleAttrib CubitAttrib::split_owner()
00386 {
00387     //- split this attrib; pass back a new simple attrib if desired
00388
00389     // by default, get rid of this attribute and don't copy to new entity
00390   deleteAttrib = CUBIT_TRUE;
00391   return CubitSimpleAttrib();
00392 }
00393
00394 inline void CubitAttrib::merge_owner(CubitAttrib *)
00395 {
00396     //- merge this attrib with deletable_ca_ptr (keep this)
00397
00398     // by default, get rid of this attribute
00399   deleteAttrib = CUBIT_TRUE;
00400   return;
00401 }
00402
00403 inline void CubitAttrib::transf_owner(const CubitVector &,
00404                                       const CubitVector &,
00405                                       const CubitVector &,
00406                                       const CubitVector &,
00407                                       const double)
00408 {
00409     //- by default, do nothing
00410 }
00411
00412 //inline int CubitAttrib::number_of_attributes()
00413 //{return CA_LAST_CA;}
00414
00415 #endif
00416
