cgma
FacetLump.cpp
00001 //-------------------------------------------------------------------------
00002 // Filename      : FacetLump.cpp
00003 //
00004 // Purpose       :
00005 //
00006 // Creator       : David White
00007 //
00008 // Creation Date : 7/18/2000
00009 //
00010 //-------------------------------------------------------------------------
00011
00012 // ********** BEGIN STANDARD INCLUDES      **********
00013 #include <assert.h>
00014 // ********** END STANDARD INCLUDES        **********
00015
00016
00017 // ********** BEGIN CUBIT INCLUDES         **********
00018 #include "FacetQueryEngine.hpp"
00019 #include "FacetLump.hpp"
00020 #include "CastTo.hpp"
00021 #include "Surface.hpp"
00022 #include "DLIList.hpp"
00023 #include "CubitFacet.hpp"
00024 #include "CubitPoint.hpp"
00025 #include "CubitVector.hpp"
00026 #include "CubitString.hpp"
00027 #include "ShellSM.hpp"
00028 #include "BodySM.hpp"
00029 #include "Body.hpp"
00030
00031 #include "FacetBody.hpp"
00032 #include "FacetShell.hpp"
00033 #include "FacetSurface.hpp"
00034 #include "FacetLoop.hpp"
00035 #include "FacetCoEdge.hpp"
00036 #include "FacetCurve.hpp"
00037 #include "FacetPoint.hpp"
00038
00039 // ********** END CUBIT INCLUDES           **********
00040
00041 // ********** BEGIN FORWARD DECLARATIONS   **********
00042 class RefVolume;
00043 // ********** END FORWARD DECLARATIONS     **********
00044
00045 // ********** BEGIN STATIC DECLARATIONS    **********
00046 // ********** END STATIC DECLARATIONS      **********
00047
00048 // ********** BEGIN PUBLIC FUNCTIONS       **********
00049
00050 //-------------------------------------------------------------------------
00051 // Purpose       : The constructor with a pointer to the owning shells and body.
00052 //
00053 // Special Notes :
00054 //
00055 //-------------------------------------------------------------------------
00056 FacetLump::FacetLump(DLIList<ShellSM*> &shells,
00057                      BodySM *body_ptr )
00058 {
00059   myBodyPtr = body_ptr;
00060   myShells += shells;
00061 }
00062
00063
00064 FacetLump::~FacetLump()
00065 {}
00066
00067 //-------------------------------------------------------------------------
00068 // Purpose       : The purpose of this function is to append a
00069 //                 attribute to the GE. The name is attached to the
00070 //                 underlying solid model entity this one points to.
00071 //
00072 //
00073 // Special Notes :
00074 //
00075 // Creator       : Malcolm J. Panthaki
00076 //
00077 // Creation Date : 11/21/96
00078 //-------------------------------------------------------------------------
00079 void FacetLump::append_simple_attribute_virt(const CubitSimpleAttrib &csa)
00080   { attribSet.append_attribute(csa); }
00081
00082 //-------------------------------------------------------------------------
00083 // Purpose       : The purpose of this function is to remove a simple
00084 //                 attribute attached to this geometry entity. The name is
00085 //                 removed from the underlying BODY this points to.
00086 //
00087 // Special Notes :
00088 //
00089 // Creator       : David R. White
00090 //
00091 // Creation Date : 03/18/97
00092 //-------------------------------------------------------------------------
00093 void FacetLump::remove_simple_attribute_virt(const CubitSimpleAttrib &csa )
00094   { attribSet.remove_attribute(csa); }
00095
00096 //-------------------------------------------------------------------------
00097 // Purpose       : The purpose of this function is to remove all simple
00098 //                 attributes attached to this geometry entity.  Also
00099 //                 removes lingering GTC attributes.
00100 //
00101 //
00102 // Special Notes :
00103 //
00104 // Creator       : Greg Nielson
00105 //
00106 // Creation Date : 07/10/98
00107 //-------------------------------------------------------------------------
00108 void FacetLump::remove_all_simple_attribute_virt()
00109 { attribSet.remove_all_attributes(); }
00110
00111 //-------------------------------------------------------------------------
00112 // Purpose       : The purpose of this function is to get the
00113 //                 attributes attached to this geometry entity. The name is
00114 //                 attached to the underlying BODY this points to.
00115 //
00116 // Special Notes :
00117 //
00118 //-------------------------------------------------------------------------
00119 CubitStatus FacetLump::get_simple_attribute(DLIList<CubitSimpleAttrib>& csa_list)
00120   { return attribSet.get_attributes( csa_list ); }
00121
00122 CubitStatus FacetLump::get_simple_attribute( const CubitString& name,
00123                                         DLIList<CubitSimpleAttrib>& csa_list )
00124   { return attribSet.get_attributes( name, csa_list ); }
00125
00126 CubitStatus FacetLump::save_attribs( FILE *file_ptr )
00127   { return attribSet.save_attributes( file_ptr ); }
00128
00129 CubitStatus FacetLump::restore_attribs( FILE *file_ptr, unsigned int endian )
00130   { return attribSet.restore_attributes( file_ptr, endian ); }
00131
00132
00133
00134
00135 //-------------------------------------------------------------------------
00136 // Purpose       : Get the bounding box of the object.
00137 //
00138 // Special Notes :
00139 //
00140 //-------------------------------------------------------------------------
00141 CubitBox FacetLump::bounding_box() const
00142 {
00143   CubitBox my_box, temp_box;
00144   DLIList<FacetSurface*> surfaces;
00145   int ii;
00146   const_cast<FacetLump*>(this)->get_surfaces(surfaces);
00147   if (surfaces.size() > 0)
00148   {
00149     Surface* surface = surfaces.get_and_step();
00150     my_box = surface->bounding_box();
00151     for ( ii = surfaces.size(); ii > 1; ii-- )
00152     {
00153       surface = surfaces.get_and_step();
00154       temp_box = surface->bounding_box();
00155         //unite the boxes..
00156       my_box |= temp_box;
00157     }
00158   }
00159   return my_box;
00160 }
00161
00162 //-------------------------------------------------------------------------
00163 // Purpose       : Get geometry modeling engine: FacetGeometryEngine
00164 //
00165 // Special Notes :
00166 //
00167 //-------------------------------------------------------------------------
00168 GeometryQueryEngine*
00169                  FacetLump::get_geometry_query_engine() const
00170 {
00171    return FacetQueryEngine::instance();
00172 }
00173
00174 //-------------------------------------------------------------------------
00175 // Purpose       : Returns the volume of the Lump
00176 //
00177 // Special Notes :
00178 //
00179 // Creator       :
00180 //
00181 // Creation Date :
00182 //-------------------------------------------------------------------------
00183 double FacetLump::measure()
00184 {
00185   DLIList<CubitFacet*> bounding_facets;
00186   DLIList<CubitPoint*> bounding_points;
00187   DLIList<FacetSurface*> surfaces;
00188   Surface *curr_surface;
00189   FacetSurface *facet_surface;
00190     //if this is a sheet body... return 0.0
00191
00192     //Body *tmp_body = CAST_TO(myBodyPtr->topology_entity(), Body);
00193   if( is_sheet() )
00194     return 0.0;
00195
00196   int ii;
00197   get_surfaces(surfaces);
00198   if (surfaces.size() > 0)
00199   {
00200     for ( ii = surfaces.size(); ii > 0; ii-- )
00201     {
00202       curr_surface = surfaces.get_and_step();
00203       facet_surface = CAST_TO(curr_surface, FacetSurface);
00204       if ( facet_surface == NULL )
00205       {
00206         PRINT_ERROR("Facet lump has surfaces that aren't facets?");
00207         return 1;
00208       }
00209       facet_surface->get_my_facets(bounding_facets, bounding_points);
00210     }
00211   }
00212   double volume, curr_facet_area, summation = 0.0;
00213   CubitFacet *curr_facet;
00214   CubitVector normal_of_curr_facet, vector_of_point;
00215   CubitPoint *point_1, *point_2, *point_3;
00216
00217   for( int jj = bounding_facets.size(); jj > 0; jj-- )
00218   {
00219     curr_facet = bounding_facets.get_and_step();
00220     curr_facet_area = curr_facet->area();  // Current facet's area
00221
00222     normal_of_curr_facet = curr_facet->normal(); // Current facet's normal
00223
00224     curr_facet->points(point_1, point_2, point_3); // Current facet's points
00225
00226     vector_of_point = point_1->coordinates(); // One point's vector
00227
00228     summation += ( double(vector_of_point % normal_of_curr_facet) * curr_facet_area);
00229   }
00230
00231   volume = summation / 3;
00232
00233   return volume;
00234 }
00235 void FacetLump::get_parents_virt(DLIList<TopologyBridge*> &bodies)
00236 {
00237   if (myBodyPtr != NULL )
00238     bodies.append_unique(myBodyPtr);
00239 }
00240
00241 void FacetLump::get_children_virt(DLIList<TopologyBridge*> &shellsms)
00242 {
00243   int ii;
00244   for ( ii = myShells.size(); ii > 0; ii-- )
00245   {
00246     shellsms.append_unique(myShells.get_and_step());
00247   }
00248 }
00249
00250 void FacetLump::get_bodies( DLIList<FacetBody*>& result_list )
00251 {
00252   FacetBody* body = dynamic_cast<FacetBody*>(myBodyPtr);
00253   if (body)
00254     result_list.append(body);
00255 }
00256
00257 void FacetLump::get_shells( DLIList<FacetShell*>& result_list )
00258 {
00259   myShells.reset();
00260   for ( int i = 0; i < myShells.size(); i++ )
00261     if ( FacetShell* shell = dynamic_cast<FacetShell*>(myShells.next(i)) )
00262       result_list.append(shell);
00263 }
00264
00265 void FacetLump::get_surfaces( DLIList<FacetSurface*>& result_list )
00266 {
00267   DLIList<FacetShell*> shell_list;
00268   DLIList<FacetSurface*> tmp_list;
00269   get_shells(shell_list);
00270   shell_list.reset();
00271   for ( int i = 0; i < shell_list.size(); i++ )
00272   {
00273     tmp_list.clean_out();
00274     shell_list.next(i)->get_surfaces( tmp_list );
00275     result_list.merge_unique( tmp_list );
00276   }
00277 }
00278
00279
00280 void FacetLump::get_coedges( DLIList<FacetCoEdge*>& result_list )
00281 {
00282   DLIList<FacetSurface*> surface_list;
00283   get_surfaces( surface_list );
00284   surface_list.reset();
00285   for ( int i = 0; i < surface_list.size(); i++ )
00286     surface_list.next(i)->get_coedges( result_list );
00287 }
00288
00289 void FacetLump::get_curves( DLIList<FacetCurve*>& result_list )
00290 {
00291   DLIList<FacetCoEdge*> coedge_list;
00292   get_coedges( coedge_list );
00293   coedge_list.reset();
00294   for ( int i = coedge_list.size(); i--; )
00295   {
00296     FacetCoEdge* coedge = coedge_list.get_and_step();
00297     FacetCurve* curve = dynamic_cast<FacetCurve*>(coedge->curve());
00298     if (curve)
00299       result_list.append_unique(curve);
00300   }
00301 }
00302
00303
00304 void FacetLump::add_shell( FacetShell *shell )
00305 {
00306     ShellSM* sm_ptr;
00307     sm_ptr = dynamic_cast<ShellSM*>(shell);
00308
00309     if( sm_ptr )
00310       myShells.append( sm_ptr );
00311
00312     shell->add_lump( this );
00313 }
00314
00315 void FacetLump::remove_shell( FacetShell *shell )
00316 {
00317     ShellSM* sm_ptr;
00318     sm_ptr = dynamic_cast<ShellSM*>(shell);
00319
00320     if( sm_ptr )
00321       myShells.remove( sm_ptr );
00322
00323     shell->remove_lump();
00324 }
00325
00326 //-------------------------------------------------------------------------
00327 // Purpose       : Tear down topology
00328 //
00329 // Special Notes :
00330 //
00331 // Creator       : Jason Kraftcheck
00332 //
00333 // Creation Date : 09/29/03
00334 //-------------------------------------------------------------------------
00335 void FacetLump::disconnect_all_shells()
00336 {
00337   myShells.reset();
00338   for (int i = myShells.size(); i--; )
00339   {
00340     ShellSM* sm_ptr = myShells.get_and_step();
00341     FacetShell* shell = dynamic_cast<FacetShell*>(sm_ptr);
00342     if (shell)
00343     {
00344       assert(shell->get_lump() == this);
00345       shell->remove_lump();
00346     }
00347   }
00348   myShells.clean_out();
00349 }
00350
00351 //-------------------------------------------------------------------------
00352 // Purpose       : Calculate centroid
00353 //
00354 // Special Notes :
00355 //
00356 // Creator       : Jason Kraftcheck
00357 //
00358 // Creation Date : 05/12/04
00359 //-------------------------------------------------------------------------
00360 #include "GfxDebug.hpp"
00361 CubitStatus FacetLump::mass_properties( CubitVector& centroid, double& volume )
00362 {
00363   int i;
00364
00365   DLIList<FacetShell*> shells( myShells.size() );
00366   CAST_LIST( myShells, shells, FacetShell );
00367   assert( myShells.size() == shells.size() );
00368
00369   DLIList<FacetSurface*> surfaces;
00370   DLIList<FacetShell*> surf_shells;
00371   get_surfaces( surfaces );
00372
00373   DLIList<CubitFacet*> facets, surf_facets;
00374   DLIList<CubitPoint*> junk;
00375   DLIList<CubitSense> senses;
00376   for (i = surfaces.size(); i--; )
00377   {
00378     FacetSurface* surf = surfaces.step_and_get();
00379     surf_shells.clean_out();
00380     surf->get_shells( surf_shells );
00381     surf_shells.intersect( shells );
00382     assert( surf_shells.size() );
00383     CubitSense sense = surf->get_shell_sense( surf_shells.get() );
00384     if (surf_shells.size() == 1 && CUBIT_UNKNOWN != sense)
00385     {
00386       surf_facets.clean_out();
00387       junk.clean_out();
00388       surf->get_my_facets( surf_facets, junk );
00389       facets += surf_facets;
00390
00391       for (int j = surf_facets.size(); j--; )
00392         senses.append(sense);
00393     }
00394   }
00395
00396   const CubitVector p0 = bounding_box().center();
00397   CubitVector p1, p2, p3, normal;
00398   centroid.set( 0.0, 0.0, 0.0 );
00399   volume = 0.0;
00400
00401   facets.reset();
00402   senses.reset();
00403   for (i = facets.size(); i--; )
00404   {
00405     CubitFacet* facet = facets.get_and_step();
00406     CubitSense sense = senses.get_and_step();
00407     p1 = facet->point(0)->coordinates();
00408     p2 = facet->point(1)->coordinates();
00409     p3 = facet->point(2)->coordinates();
00410     normal = (p3 - p1) * (p2 - p1);
00411
00412     double two_area = normal.length();
00413     if (two_area > CUBIT_RESABS )
00414     {
00415       if (CUBIT_REVERSED == sense)
00416         normal = -normal;
00417
00418       normal /= two_area;
00419
00420       double height = normal % (p0 - p1);
00421       double vol = two_area * height;
00422
00423       volume += vol;
00424       centroid += vol * (p0 + p1 + p2 + p3);
00425     }
00426   }
00427
00428   if (volume > CUBIT_RESABS)
00429     centroid /= 4.0 * volume;
00430   volume /= 6.0;
00431   return CUBIT_SUCCESS;
00432 }
00433
00434 CubitPointContainment FacetLump::point_containment( const CubitVector &point,
00435   double tolerance )
00436 {
00437   CubitPointContainment pc_value;
00438   FacetShell *facet_shell;
00439
00440   int i;
00441   for(i=myShells.size(); i--;)
00442   {
00443     facet_shell = dynamic_cast<FacetShell*>(myShells.get_and_step());
00444     pc_value = facet_shell->point_containment( point, tolerance );
00445     if( pc_value == CUBIT_PNT_OUTSIDE )
00446       return CUBIT_PNT_OUTSIDE;
00447     else if( pc_value == CUBIT_PNT_BOUNDARY )
00448       return CUBIT_PNT_BOUNDARY;
00449   }
00450
00451   return CUBIT_PNT_INSIDE;
00452
00453 }
00454
00455 //Determine whether this lump is really a sheet (that is, sheet-body).
00456 CubitBoolean FacetLump::is_sheet( )
00457 {
00458   FacetShell *facet_shell;
00459   int i;
00460     //if any of the shells are sheets, the body is assume to be a sheet
00461     // for our purposes...
00462   for(i=myShells.size(); i--;)
00463   {
00464     facet_shell = dynamic_cast<FacetShell*>(myShells.get_and_step());
00465     if(facet_shell->is_sheet()){
00466       return CUBIT_TRUE;
00467     }
00468   }
00469   return CUBIT_FALSE;
00470 }
00471
