cgma
RemoveBlends Namespace Reference
Functions
CubitStatus remove_blend (RefFace *ref_face, DLIList< CubitVector > &locations, DLIList< RefFace * > &composite_faces)
CubitStatus remove_blends (DLIList< RefFace * > &ref_face_list, int num_segs, double fraction, double distance, RefEdge *from_curve_ptr, DLIList< RefVertex * > &corner_vertex_list, DLIList< RefVertex * > &through_vertex_list, RefEdge *curve_dir_ptr, CubitBoolean preview_flg, DLIList< CubitVector * > &locations, DLIList< RefFace * > &composite_faces)
Function Documentation
CubitStatus RemoveBlends::remove_blend ( RefFace ref_face,
DLIList< CubitVector > &  locations,
DLIList< RefFace * > &  composite_faces
Definition at line 29 of file RemoveBlends.cpp.
   CubitStatus result = CUBIT_SUCCESS;
   int i;
   locations.reset();
   RefFace* the_face = ref_face;
   if (the_face && VirtualQueryEngine::is_virtual(the_face))
      PRINT_WARNING ("Can not collapse a virtual surface.\n");
      return CUBIT_FAILURE;
   // Find the curve to split along.
   SplitSurfaceTool                sst;
   DLIList<DLIList<CubitVector*>*> vec_lists;
   DLIList<Curve*>                 curve_list;
   DLIList<CubitVector*> *vec_list = new DLIList<CubitVector*>;
   vec_list->append( new CubitVector( locations.get_and_step() ) );
   vec_lists.append( vec_list );
   sst.calculate_split_curves(the_face, vec_lists, curve_list);
   //int num_segs = 2;
   //double fraction =.5;
   //double distance = -1.;
   //RefEdge* from_curve_ptr = 0;
   //DLIList<RefVertex*> corner_vertex_list;
   //DLIList<RefVertex*> through_vertex_list;
   //RefEdge *curve_dir_ptr = 0;
   //CubitBoolean preview_flg = false;
   //CubitBoolean create_ref_edges_flg = false;
   //CubitBoolean just_curves_flg = false;
   //DLIList<DLIList<Curve*>*> curve_lists_list;
//   sst.calculate_split_curves(ref_face_list, num_segs, fraction, distance,
//                          from_curve_ptr, corner_vertex_list, through_vertex_list,
//                          curve_dir_ptr,
//                          preview_flg, create_ref_edges_flg, just_curves_flg,
//                          curve_lists_list );
   //partition the_face
   DLIList<RefEdge*> new_edges;
   DLIList<RefFace*> result_faces;
   result = PartitionTool::instance()->
          partition_face_by_curves( the_face, curve_list, result_faces, CUBIT_TRUE, &new_edges );
   // clean up curves
   while (curve_list.size())
     Curve* curve = curve_list.pop();
     if (curve)
       GeometryQueryEngine* gqe = curve->get_geometry_query_engine();
       gqe->delete_solid_model_entities(curve);
   if( result == CUBIT_FAILURE )
      PRINT_ERROR("Failed to partition surface %d into 2 distinct pieces\n", the_face->id());
      return result;
   // We MUST clean up an ambiguous partition.
   if (new_edges.size() > 1)
      PRINT_ERROR("Attempted to partition surface %d more than 2 parts,\n"
                    "Ambiguous surface collapse. Collapse failed.\n",
                    the_face->id());
      DLIList<RefFace*> orig_faces;
      PartitionTool::instance()->unpartitionAll(result_faces, orig_faces);
      DLIList<RefEdge*> edges, edge_results;
      edges.clean_out();
      // We started out with one face, we should the same face back
      assert( the_face == orig_faces.next(0) );
      the_face->ref_edges( edges );
      // Do a quick sort to find the PartitionCurves
      for ( i = edges.size(); i--; )
        if ( !dynamic_cast<PartitionCurve*>(edges.step_and_get()->get_curve_ptr()))
          edges.change_to(0);
      edges.remove_all_with_value(0);
      // Now remove the partitioned edges
      // TODO: what if we are collapsing with an adjacent partitioned surface.
      // What happens to the partitioned edges?
      if ( edges.size() )
        PartitionTool::instance()->unpartitionAll(edges, edge_results);
   if (result_faces.size() < 2)
      PRINT_WARNING("Surface %d has been improperly partitioned,\n"
                    the_face->id());
      return result;
   //if(new_face == the_face)
   //   new_face = GeometryQueryTool::instance()->get_last_ref_face ();
   new_edges.clean_out();
   //Re-composite surfaces
   DLIList<RefFace*> composite_result_faces;
   DLIList<RefFace*> remaining_faces;
   DLIList<RefFace*> surf_list;
   DLIList<int> id_list;
   RefFace*  face_to_composite = NULL;
   RefFace*  temp_face = NULL;
   RefFace*  second_face = NULL;
   RefFace*  composite_face = NULL;
   int  num_common_edge1, num_common_edge2;
   int  size;
   int  composite_count = 0;
   while (0 < (composite_faces.size() + remaining_faces.size()))
      if(composite_count == 2)
        break;
      size = composite_faces.size();
      if( size > 0)
        composite_faces.reset();
        face_to_composite = composite_faces.get();
        composite_faces.remove(face_to_composite);
      else
        remaining_faces.reset();
        face_to_composite = remaining_faces.get();
        remaining_faces.remove(face_to_composite);
      if (NULL != second_face)
         num_common_edge1 = second_face->common_ref_edges(face_to_composite,
                                                       new_edges);
         if (num_common_edge1 == 0)
           continue;
         if (NULL == composite_face)
           num_common_edge2 = 0;
         else
           num_common_edge2 = composite_face->
                   common_ref_edges(face_to_composite, new_edges);
      else
         if (NULL == result_faces[0])
           num_common_edge1 = 0;
         else
            num_common_edge1 = result_faces[0]->common_ref_edges(face_to_composite,
                                                       new_edges);
         if(NULL == result_faces[1])
         else
            num_common_edge2 = result_faces[1]->common_ref_edges(face_to_composite,
                                                          new_edges);
      if (num_common_edge1 == 0 && num_common_edge2 == 0)
         continue;
      else if(num_common_edge1 == 0 || num_common_edge2 == 0 || size == 0)
         surf_list.clean_out();
            surf_list.append(second_face);
         else if (num_common_edge2 == 0 || size == 0)
            temp_face = result_faces[0];
            second_face = result_faces[1];
            surf_list.append(temp_face);
         else
            temp_face = result_faces[1];
            second_face = result_faces[0];
         surf_list.append(face_to_composite);
         // composite the surfaces together
         CompositeTool::instance()->composite(surf_list, composite_result_faces);
         composite_count++;
         if( composite_result_faces.size() > 0 )
            DLIList<RefEdge*> surface_edges, new_edge_list;
            remaining_faces.clean_out();
            for(  i = 0; i < composite_result_faces.size(); i++)
               // now composite together the edges of the new surface
               surface_edges.clean_out();
               composite_result_faces.get_and_step()->ref_edges( surface_edges );
               new_edge_list.clean_out();
               CompositeTool::instance()->composite( surface_edges, new_edge_list);
               // keep the lists coherent
               composite_face = composite_result_faces.pop();
               composite_faces.remove(composite_face);
               id_list.append( composite_face->id() );
         else
            PRINT_ERROR("Composite surface %d and surface %d failed.\n",
                temp_face->id(), face_to_composite->id());
      else
         remaining_faces.append(face_to_composite);
   if (id_list.size() > 0)
      CubitUtil::list_entity_ids("Created composite surfaces ", id_list );
   return result;
CubitStatus RemoveBlends::remove_blends ( DLIList< RefFace * > &  ref_face_list,
int  num_segs,
double  fraction,
double  distance,
RefEdge from_curve_ptr,
DLIList< RefVertex * > &  corner_vertex_list,
DLIList< RefVertex * > &  through_vertex_list,
RefEdge curve_dir_ptr,
DLIList< CubitVector * > &  locations,
Definition at line 270 of file RemoveBlends.cpp.
   int i;
   if (ref_face_list.size() <= 1)
      PRINT_WARNING ("Must specify a chain of surfaces.\n");
   locations.reset();
   // check and make sure that we aren't splitting virtual surfaces (yet)
   for (i = 0; i < ref_face_list.size(); i++)
     RefFace* the_face = ref_face_list.get_and_step();
   DLIList<Curve*>*                curve_list;
   vec_list->append( new CubitVector( *locations.get_and_step() ) );
                          curve_dir_ptr,
                          curve_lists_list );
   RefFace* the_face;
     // get the face and the curves that split this face
     curve_list = curve_lists_list.get_and_step();
            partition_face_by_curves( the_face, *curve_list, result_faces, CUBIT_FALSE, &new_edges );
        return result;
        PRINT_WARNING("Surface %d has been partitioned into more than 2 parts,\n"
                      "Ambiguous surface collapse.\n",
                      the_face->id());
        return result;
     int  size;
          break;
        if( size > 0)
        else
                                                         new_edges);
             continue;
           else
        else
           else
                                                         new_edges);
           else
                                                            new_edges);
           continue;
           else
           composite_count++;
   return result;
