cgma
SplitSurfaceVirtual Namespace Reference
Functions
CubitStatus split_surface_virtual (RefFace *ref_face_ptr, DLIList< CubitVector * > &locations, DLIList< DLIList< CubitVector * > * > &vec_lists)
CubitStatus split_surfaces_virtual (DLIList< RefFace * > &ref_face_list, int num_segs, double fraction, double distance, RefEdge *from_curve_ptr, DLIList< RefVertex * > &corner_vertex_list, DLIList< RefVertex * > &through_vertex_list, RefEdge *curve_dir_ptr, CubitBoolean preview_flg, CubitBoolean create_ref_edges_flg)
Function Documentation
CubitStatus SplitSurfaceVirtual::split_surface_virtual ( RefFace ref_face_ptr,
DLIList< CubitVector * > &  locations,
DLIList< DLIList< CubitVector * > * > &  vec_lists
Definition at line 29 of file SplitSurfaceVirtual.cpp.
  // find the splitting curves.
  SplitSurfaceTool sst;
  DLIList<Curve*> curve_list;
  CubitStatus err  = sst.calculate_split_curves( ref_face_ptr, locations,
                                             vec_lists, curve_list );
  GMem gmem;
  int  num_points;
  DLIList<CubitVector*> segments;
  // loop over all the curves
  int i;
  for (i = 0; i < curve_list.size(); i++)
    Curve* curve_ptr = curve_list.get_and_step();
    // get the curve facets
    err = curve_ptr->get_geometry_query_engine()->
                          get_graphics( curve_ptr, num_points, &gmem );
    // load the graphics points into a CubitVector for insert_curve
    --num_points;
    int j;
    for (j = 0; j < num_points; j++)
      const GPoint& p = gmem.point_list()[j];
      segments.append( new CubitVector( p.x, p.y, p.z ) );
  // add last point to the end of the list
  const GPoint& p = gmem.point_list()[num_points];
  segments.append( new CubitVector(p.x, p.y, p.z ) );
  // now partition the surface
  DLIList<RefEdge*> new_edges;
  RefFace* new_surf = PartitionTool::instance()->insert_edge( ref_face_ptr, segments,
        false, new_edges );
  //DLIList<Curve*> new_curves;
  //Surface* new_surf = PartitionEngine::instance().insert_curve( old_surf, segments, new_curves );
  // called routines allocate memory.  Clean up for them.
  while( curve_list.size() )
    delete curve_list.pop();
  //while( new_curves.size() )
  //  delete new_curves.pop();
  return CUBIT_SUCCESS;
CubitStatus SplitSurfaceVirtual::split_surfaces_virtual ( DLIList< RefFace * > &  ref_face_list,
int  num_segs,
double  fraction,
double  distance,
RefEdge from_curve_ptr,
DLIList< RefVertex * > &  corner_vertex_list,
DLIList< RefVertex * > &  through_vertex_list,
RefEdge curve_dir_ptr,
Definition at line 93 of file SplitSurfaceVirtual.cpp.
  // Get parent bodies - all surfs must be from same body
  int i;
  DLIList<Body*> old_body_list;
  RefFace *ref_face_ptr;
  ref_face_list.reset();
  for( i=ref_face_list.size(); i--; )
    ref_face_ptr = ref_face_list.get_and_step();
    DLIList<Body*> body_list;
    ref_face_ptr->bodies( body_list );
    old_body_list.merge_unique( body_list );
  if( old_body_list.size() > 1 )
    PRINT_ERROR( "This operation requires all surfaces to be from the same volume\n" );
    // Note: this restriction could be pretty easily lifted by sorting the
    //       input lists and calling the SplitSurfaceTool separately for each set of
    //       surfaces on each body.
    return CUBIT_FAILURE;
  //bad geom with no body -- dont try to imprint this...
  //quick and dirty fix by (aga@cat|1/7/04)
  if( old_body_list.size() < 1 )
    PRINT_ERROR( "A surface is not contained within a parent body.\n"
      "       It cannot be split.\n");
 /* KGM -- need this?
  // Check for virtual geometry
  if ( contains_intermediate_geometry(ref_face_list) )
    PRINT_ERROR("SPLITTING surfaces containing virtual geometry is not\n"
      "       allowed. Delete virtual geometry on these surfaces\n"
      "       before operation.\n" );
  // Make sure all surfaces are from same geometry engine
  DLIList<RefEntity*> ref_ent_list;
  CAST_LIST_TO_PARENT(ref_face_list, ref_ent_list);
  if ( !same_modify_engine(ref_ent_list, CUBIT_TRUE) )
    PRINT_ERROR("Performing SPLIT with surfaces containing geometry from\n"
      "different modeling engines is not allowed.\n"
      "Delete uncommon geometry on these surfaces before operation.\n\n");
  // get the splitting curves
  DLIList<DLIList<Curve*>*> curve_lists_list;
  CubitStatus err = sst.calculate_split_curves( ref_face_list, num_segs, fraction, distance,
                                                from_curve_ptr,corner_vertex_list,
                                                through_vertex_list, curve_dir_ptr,
                                                preview_flg, create_ref_edges_flg,
                                                false, curve_lists_list );
  GMem gmem;
  int  num_points;
  int k;
  for (k=0; k < curve_lists_list.size(); k++)
    DLIList<Curve*> *curve_list = curve_lists_list[k];
    int i;
    for (i = 0; i < curve_list->size(); i++)
      Curve* curve_ptr = curve_list->get_and_step();
      --num_points;
      int j;
  // Get the underlying surface (what if it is virtual does this still work?)
  //Surface *old_surf = ref_face_list[k]->get_surface_ptr(); KGM
  DLIList<RefFace*> new_faces;
  err = PartitionTool::instance()->insert_edge( ref_face_list,
                          segments, new_faces, new_edges);
  // insert_curve allocates memory.  Clean up.
    while( curve_list->size() )
      delete curve_list->pop();
