cgma
00001 //------------------------------------------------------------------------- 00002 // Filename : CompositeBody.cpp 00003 // 00004 // Purpose : Composite of BodySMs 00005 // 00006 // Special Notes : 00007 // 00008 // Creator : Jason Kraftcheck 00009 // 00010 // Creation Date : 01/11/02 00011 //------------------------------------------------------------------------- 00012 00013 #include "DLIList.hpp" 00014 #include "CompositeBody.hpp" 00015 #include "CompositeLump.hpp" 00016 #include "VirtualQueryEngine.hpp" 00017 #include "CompositeEngine.hpp" 00018 00019 CompositeBody::CompositeBody() 00020 : firstLump(0) 00021 { 00022 } 00023 00024 CompositeBody::~CompositeBody() 00025 { 00026 int i; 00027 00028 for( i = 0; i < realBodies.size(); i++ ) 00029 if( realBodies[i]->owner() == this ) 00030 realBodies[i]->owner(0); 00031 00032 while( firstLump ) 00033 remove( firstLump ); 00034 } 00035 00036 00037 CompositeLump* CompositeBody::next_lump( CompositeLump* prev ) const 00038 { 00039 return prev ? prev->nextLump : firstLump; 00040 } 00041 00042 CubitStatus CompositeBody::add( CompositeLump* lump ) 00043 { 00044 if( lump->myBody != 0 ) 00045 return CUBIT_FAILURE; 00046 00047 lump->myBody = this; 00048 lump->nextLump = firstLump; 00049 firstLump = lump; 00050 return CUBIT_SUCCESS; 00051 } 00052 00053 CubitStatus CompositeBody::remove( CompositeLump* lump ) 00054 { 00055 if( lump->myBody != this ) 00056 return CUBIT_FAILURE; 00057 00058 if( firstLump == lump ) 00059 { 00060 firstLump = lump->nextLump; 00061 } 00062 else 00063 { 00064 CompositeLump* prev = firstLump; 00065 while( prev && prev->nextLump != lump ) 00066 prev = prev->nextLump; 00067 assert( prev != NULL ); 00068 00069 prev->nextLump = lump->nextLump; 00070 } 00071 00072 lump->myBody = 0; 00073 lump->nextLump = 0; 00074 return CUBIT_SUCCESS; 00075 } 00076 00077 CubitStatus CompositeBody::add( BodySM* body ) 00078 { 00079 if( index_of( body ) >= 0 ) 00080 return CUBIT_FAILURE; 00081 00082 if( body->owner() ) 00083 body->owner()->swap_bridge( body, this, false ); 00084 body->owner(this); 00085 00086 realBodies.push( body ); 00087 return CUBIT_SUCCESS; 00088 } 00089 00090 CubitStatus CompositeBody::remove( BodySM* body ) 00091 { return remove_body( index_of( body ) ); } 00092 00093 CubitStatus CompositeBody::remove_body( int index ) 00094 { 00095 if( index < 0 ) return CUBIT_FAILURE; 00096 00097 if( realBodies[index]->owner() == this ) 00098 realBodies[index]->owner(0); 00099 realBodies.remove(index); 00100 return CUBIT_SUCCESS; 00101 } 00102 /* 00103 CubitStatus CompositeBody::move( const CubitVector& offset ) 00104 { 00105 int i; 00106 for (i = 0; i < realBodies.size(); i++) 00107 if (CUBIT_SUCCESS != realBodies[i]->move( offset )) 00108 break; 00109 00110 if (i == realBodies.size()) 00111 return CUBIT_SUCCESS; 00112 00113 for (int j = 0; j < i; j++) 00114 realBodies[j]->move( -offset ); 00115 return CUBIT_FAILURE; 00116 } 00117 00118 00119 CubitStatus CompositeBody::rotate( const CubitVector& axis, double angle ) 00120 { 00121 int i; 00122 for (i = 0; i < realBodies.size(); i++) 00123 if (CUBIT_SUCCESS != realBodies[i]->rotate( axis, angle )) 00124 break; 00125 00126 if (i == realBodies.size()) 00127 return CUBIT_SUCCESS; 00128 00129 for (int j = 0; j < i; j++) 00130 realBodies[j]->rotate( axis, -angle ); 00131 return CUBIT_FAILURE; 00132 } 00133 00134 CubitStatus CompositeBody::scale( double factor ) 00135 { 00136 int i; 00137 for (i = 0; i < realBodies.size(); i++) 00138 if (CUBIT_SUCCESS != realBodies[i]->scale( factor )) 00139 break; 00140 00141 if (i == realBodies.size()) 00142 return CUBIT_SUCCESS; 00143 00144 for (int j = 0; j < i; j++) 00145 realBodies[j]->scale( 1.0/factor ); 00146 return CUBIT_FAILURE; 00147 } 00148 00149 CubitStatus CompositeBody::scale( const CubitVector& factors ) 00150 { 00151 int i; 00152 for (i = 0; i < realBodies.size(); i++) 00153 if (CUBIT_SUCCESS != realBodies[i]->scale( factors )) 00154 break; 00155 00156 if (i == realBodies.size()) 00157 return CUBIT_SUCCESS; 00158 00159 const CubitVector unscale( 1.0/factors.x(), 1.0/factors.y(), 1.0/factors.z() ); 00160 for (int j = 0; j < i; j++) 00161 realBodies[j]->scale( unscale ); 00162 return CUBIT_FAILURE; 00163 } 00164 00165 00166 CubitStatus CompositeBody::reflect( const CubitVector& axis ) 00167 { 00168 int i; 00169 for (i = 0; i < realBodies.size(); i++) 00170 if (CUBIT_SUCCESS != realBodies[i]->reflect( axis )) 00171 break; 00172 00173 if (i == realBodies.size()) 00174 return CUBIT_SUCCESS; 00175 00176 for (int j = 0; j < i; j++) 00177 realBodies[j]->reflect( axis ); 00178 return CUBIT_FAILURE; 00179 } 00180 00181 00182 CubitStatus CompositeBody::restore() 00183 { return CUBIT_FAILURE; } 00184 00185 CubitStatus CompositeBody::reverse() 00186 { return CUBIT_FAILURE; } 00187 */ 00188 CubitStatus CompositeBody::get_transforms( CubitTransformMatrix& ) 00189 { return CUBIT_FAILURE; } 00190 00191 void CompositeBody::get_parents_virt( DLIList<TopologyBridge*>& ) 00192 { } 00193 00194 void CompositeBody::get_children_virt( DLIList<TopologyBridge*>& children ) 00195 { 00196 for( CompositeLump* lump = firstLump; lump; lump = lump->nextLump ) 00197 children.append( lump ); 00198 } 00199 00200 00201 //------------------------------------------------------------------------- 00202 // Purpose : Get CompositeEngine 00203 // 00204 // Special Notes : 00205 // 00206 // Creator : Jason Kraftcheck 00207 // 00208 // Creation Date : 01/11/02 00209 //------------------------------------------------------------------------- 00210 GeometryQueryEngine* CompositeBody::get_geometry_query_engine() const 00211 { return VirtualQueryEngine::instance(); } 00212 00213 00214 CubitStatus CompositeBody::remove_bridge( TopologyBridge* bridge ) 00215 { 00216 int i; 00217 for (i = realBodies.size() - 1; i >= 0 && realBodies[i] != bridge; --i); 00218 if (i < 0) 00219 return CUBIT_FAILURE; 00220 00221 assert( bridge->owner() == this ); 00222 bridge->owner( 0 ); 00223 realBodies.remove( i ); 00224 00225 if (realBodies.size() == 0) 00226 CompositeEngine::instance().notify_deactivated( this ); 00227 00228 return CUBIT_SUCCESS; 00229 } 00230 00231 00232 CubitStatus CompositeBody::swap_bridge( TopologyBridge* old_tb, 00233 TopologyBridge* new_tb, 00234 bool ) 00235 { 00236 if( new_tb->owner() ) 00237 return CUBIT_FAILURE; 00238 00239 BodySM* new_body = dynamic_cast<BodySM*>(new_tb); 00240 BodySM* old_body = dynamic_cast<BodySM*>(old_tb); 00241 int index = realBodies.find( old_body ); 00242 if( index >= 0 && new_body != 0 && realBodies.find(new_body) < 0 ) 00243 { 00244 if( old_body->owner() == this ) 00245 old_body->owner(0); 00246 new_body->owner(this); 00247 realBodies[index] = new_body; 00248 return CUBIT_SUCCESS; 00249 } 00250 00251 return CUBIT_FAILURE; 00252 } 00253 00254 CubitBoolean CompositeBody::contains_bridge( TopologyBridge* bridge ) const 00255 { 00256 return index_of(dynamic_cast<BodySM*>(bridge)) < 0 ? CUBIT_FALSE : CUBIT_TRUE; 00257 } 00258 00259 void CompositeBody::notify_reversed( TopologyBridge* ) 00260 { assert(0); } 00261 00262 //------------------------------------------------------------------------- 00263 // Purpose : Attribute functions 00264 // 00265 // Special Notes : 00266 // 00267 // Creator : Jason Kraftcheck 00268 // 00269 // Creation Date : 01/11/02 00270 //------------------------------------------------------------------------- 00271 void CompositeBody::append_simple_attribute_virt( const CubitSimpleAttrib& ) 00272 { } 00273 void CompositeBody::remove_simple_attribute_virt( const CubitSimpleAttrib& ) 00274 { } 00275 void CompositeBody::remove_all_simple_attribute_virt() 00276 { } 00277 CubitStatus CompositeBody::get_simple_attribute( DLIList<CubitSimpleAttrib>& ) 00278 { return CUBIT_FAILURE; } 00279 CubitStatus CompositeBody::get_simple_attribute( 00280 const CubitString& , DLIList<CubitSimpleAttrib>& ) 00281 { return CUBIT_FAILURE; } 00282 00283 //------------------------------------------------------------------------- 00284 // Purpose : 00285 // 00286 // Special Notes : 00287 // 00288 // Creator : Jason Kraftcheck 00289 // 00290 // Creation Date : 05/10/04 00291 //------------------------------------------------------------------------- 00292 CubitPointContainment CompositeBody::point_containment( const CubitVector& pos, double tolerance ) 00293 { 00294 int inside = 0; 00295 int boundary = 0; 00296 00297 for (int i = 0; i < realBodies.size(); ++i) 00298 { 00299 switch( realBodies[i]->point_containment( pos, tolerance ) ) 00300 { 00301 case CUBIT_PNT_BOUNDARY: 00302 boundary++; 00303 break; 00304 case CUBIT_PNT_INSIDE: 00305 inside++; 00306 break; 00307 case CUBIT_PNT_OUTSIDE: 00308 break; 00309 default: 00310 return CUBIT_PNT_UNKNOWN; 00311 } 00312 } 00313 00314 if (inside) 00315 return CUBIT_PNT_INSIDE; 00316 else if (boundary > 1) 00317 return CUBIT_PNT_INSIDE; 00318 else if (boundary) 00319 return CUBIT_PNT_BOUNDARY; 00320 else 00321 return CUBIT_PNT_OUTSIDE; 00322 } 00323 00324 //------------------------------------------------------------------------- 00325 // Purpose : 00326 // 00327 // Special Notes : 00328 // 00329 // Creator : Jason Kraftcheck 00330 // 00331 // Creation Date : 05/10/04 00332 //------------------------------------------------------------------------- 00333 CubitStatus CompositeBody::mass_properties( CubitVector& result, 00334 double& volume ) 00335 { 00336 double vol; 00337 CubitVector centroid; 00338 result.set( 0.0, 0.0, 0.0 ); 00339 volume = 0; 00340 00341 for (int i = 0; i < realBodies.size(); ++i) 00342 { 00343 if (CUBIT_FAILURE == realBodies[i]->mass_properties( centroid, vol )) 00344 return CUBIT_FAILURE; 00345 00346 result += vol * centroid; 00347 volume += vol; 00348 } 00349 00350 if (volume > CUBIT_RESABS) 00351 result /= volume; 00352 return CUBIT_SUCCESS; 00353 } 00354 00355 //------------------------------------------------------------------------- 00356 // Purpose : Combine 00357 // 00358 // Special Notes : 00359 // 00360 // Creator : Jason Kraftcheck 00361 // 00362 // Creation Date : 06/11/04 00363 //------------------------------------------------------------------------- 00364 void CompositeBody::combine( CompositeBody* other ) 00365 { 00366 int oldsize = realBodies.size(); 00367 realBodies.size( oldsize + other->realBodies.size() ); 00368 for (int i = 0; i < other->realBodies.size(); i++) 00369 { 00370 BodySM* bod = other->realBodies[i]; 00371 realBodies[i+oldsize] = bod; 00372 bod->owner(this); 00373 } 00374 other->realBodies.size(0); 00375 } 00376
