cgma
00001 //------------------------------------------------------------------------- 00002 // Filename : CompositeLoop.hpp 00003 // 00004 // Purpose : LoopSM used by composite geometry 00005 // 00006 // Special Notes : 00007 // 00008 // Creator : Jason Kraftcheck 00009 // 00010 // Creation Date : 01/11/02 00011 //------------------------------------------------------------------------- 00012 00013 #ifndef COMPOSITE_LOOP_HPP 00014 #define COMPOSITE_LOOP_HPP 00015 00016 #include "LoopSM.hpp" 00017 #include "CompositeCoEdge.hpp" 00018 00019 class CompositeSurface; 00020 00021 class CompositeLoop : public LoopSM 00022 { 00023 friend class CompositeSurface; 00024 public: 00025 00026 CompositeLoop(); 00027 virtual ~CompositeLoop(); 00028 00029 CompositeSurface* get_surface() const; 00030 CompositeLoop* next_loop() const; 00031 00032 CompositeCoEdge* first_coedge( ) const; 00033 CompositeCoEdge* next_coedge( CompositeCoEdge* after_this ) const; 00034 CompositeCoEdge* prev_coedge( CompositeCoEdge* before_this ) const; 00035 int num_coedges() const; 00036 00037 CubitStatus insert_after( CompositeCoEdge* coedge, CompositeCoEdge* after ); 00038 CubitStatus insert_before( CompositeCoEdge* coedge, CompositeCoEdge* before ); 00039 CubitStatus remove( CompositeCoEdge* coedge ); 00040 CubitStatus remove_all_coedges( DLIList<CompositeCoEdge*>* removed = 0); 00041 00042 void get_parents_virt( DLIList<TopologyBridge*>& parents ); 00043 void get_children_virt( DLIList<TopologyBridge*>& children ); 00044 GeometryQueryEngine* get_geometry_query_engine() const; 00045 int layer() const { return COMPOSITE_LAYER; } 00046 00047 virtual LoopType loop_type() ; 00048 virtual CubitBoolean is_external() ; 00049 //R CubitBoolean 00050 //R- CUBIT_TRUE/CUBIT_FALSE 00051 //- Returns CUBIT_TRUE if the Loop is an external Loop and CUBIT_FALSE 00052 //- otherwise. 00053 00054 void append_simple_attribute_virt( const CubitSimpleAttrib& ); 00055 void remove_simple_attribute_virt( const CubitSimpleAttrib& ); 00056 void remove_all_simple_attribute_virt(); 00057 CubitStatus get_simple_attribute( DLIList<CubitSimpleAttrib>& ); 00058 CubitStatus get_simple_attribute( const CubitString& name, 00059 DLIList<CubitSimpleAttrib>& attrib_list ); 00060 00061 // reverse the direction of the loop 00062 // if b_reverse_coedges is true, the function will also reverse the coedges 00063 // but if b_reverse_coedges is false, the caller needs to make sure coedges 00064 // get reversed properly 00065 void reverse(bool b_reverse_coedges); 00066 00067 void print_debug_info( const char* line_prefix = 0 ); 00068 00069 private: 00070 00071 CompositeSurface* mySurface; 00072 CompositeCoEdge* myCoedge; 00073 CompositeLoop* loopNext; 00074 int numCoedges; 00075 }; 00076 00077 inline CompositeSurface* CompositeLoop::get_surface() const 00078 { return mySurface; } 00079 00080 inline CompositeLoop* CompositeLoop::next_loop() const 00081 { return loopNext; } 00082 00083 inline CompositeCoEdge* CompositeLoop::first_coedge( ) const 00084 { return myCoedge; } 00085 00086 inline int CompositeLoop::num_coedges() const 00087 { return numCoedges; } 00088 00089 inline CompositeCoEdge* CompositeLoop::next_coedge( CompositeCoEdge* prev ) const 00090 { return prev->myLoop == this ? prev->nextCoedge : 0; } 00091 00092 inline CompositeCoEdge* CompositeLoop::prev_coedge( CompositeCoEdge* next ) const 00093 { return next->myLoop == this ? next->prevCoedge : 0; } 00094 00095 00096 #endif
