cgma
00001 #include "FacetboolInterface.hpp" 00002 #include "FacetDataUtil.hpp" 00003 #include "FBDataUtil.hpp" 00004 #include "FBIntersect.hpp" 00005 #include "IntegerHash.hpp" 00006 #include "FacetBody.hpp" 00007 #include "BodySM.hpp" 00008 #include "Body.hpp" 00009 #include "FacetSurface.hpp" 00010 #include "FBDataUtil.hpp" 00011 #include "CubitPoint.hpp" 00012 #include "CubitPointData.hpp" 00013 #include "CubitFacetData.hpp" 00014 #include "FacetModifyEngine.hpp" 00015 #include "FacetQueryEngine.hpp" 00016 #include "FacetCurve.hpp" 00017 #include "CubitFacetEdge.hpp" 00018 #include "TDFacetboolData.hpp" 00019 #include "CurveFacetEvalTool.hpp" 00020 #include "FacetPoint.hpp" 00021 #include "FacetLump.hpp" 00022 #include "FacetShell.hpp" 00023 #include "CubitBox.hpp" 00024 #include "FBImprint.hpp" 00025 #include "GfxDebug.hpp" 00026 #include "ChollaEngine.hpp" 00027 00028 FacetboolInterface::FacetboolInterface() 00029 { 00030 00031 } 00032 00033 FacetboolInterface::~FacetboolInterface() 00034 { 00035 00036 } 00037 00038 //=============================================================================== 00039 // Function : webcut_FB 00040 // Member Type: PUBLIC 00041 // Description: webcut a FacetBody with a FacetBool cutter 00042 // Author : John Fowler 00043 // Date : 02/04 00044 //=============================================================================== 00045 CubitStatus FacetboolInterface::webcut_FB(BodySM *bodysm_ptr, 00046 std::vector<double>& cutter_verts, 00047 std::vector<int>& cutter_connections, 00048 bool cutter_is_plane, 00049 CubitBoolean delete_bodies, 00050 CubitBoolean &intersects, 00051 DLIList<BodySM*>& results_list) 00052 00053 { 00054 intersects = CUBIT_TRUE; 00055 DLIList<FacetSurface*> facet_surf_list; 00056 std::vector<double> body_verts; 00057 std::vector<int> body_connections, newbodyfacets; 00058 std::vector<int> newcutterfacets; 00059 std::vector<int> f_c_indices1; 00060 std::vector<FacetSurface *> fsurfarray; 00061 std::vector<FacetCurve *> fcurvearray; 00062 CubitStatus status; 00063 int mydebug = 0; 00064 FacetModifyEngine *fme = FacetModifyEngine::instance(); 00065 FacetBody *facet_body_ptr = CAST_TO(bodysm_ptr, FacetBody); 00066 00067 facet_body_ptr->get_surfaces(facet_surf_list); 00068 00069 status = facetbody_to_facetbool(facet_surf_list,body_verts, 00070 body_connections,&f_c_indices1, 00071 fsurfarray,fcurvearray); 00072 if( status == CUBIT_FAILURE ) 00073 return status; 00074 00075 FBIntersect intersector; 00076 intersector.set_classify_flag(true); 00077 if ( cutter_is_plane == true ) intersector.set_body2_planar(); 00078 00079 status = intersector.intersect(body_verts,body_connections, 00080 cutter_verts,cutter_connections, 00081 newbodyfacets,newcutterfacets, 00082 &f_c_indices1, 00083 0); 00084 if( status == CUBIT_FAILURE ) 00085 return status; 00086 00087 bool *surfs_in_intersection, *surfs_in_subtraction; 00088 bool *curves_in_intersection, *curves_in_subtraction; 00089 00090 surfs_in_intersection = new bool[1+fsurfarray.size()]; 00091 surfs_in_subtraction = new bool[1+fsurfarray.size()]; 00092 curves_in_intersection = new bool[1+fcurvearray.size()]; 00093 curves_in_subtraction = new bool[1+fcurvearray.size()]; 00094 unsigned int k; 00095 for ( k = 1; k < 1 + fsurfarray.size(); k++ ) 00096 surfs_in_subtraction[k] = surfs_in_intersection[k] = false; 00097 for ( k = 1; k < 1 + fcurvearray.size(); k++ ) 00098 curves_in_subtraction[k] = curves_in_intersection[k] = false; 00099 00100 status = intersector.get_persistent_entity_info(surfs_in_intersection, 00101 curves_in_intersection,surfs_in_subtraction, 00102 curves_in_subtraction,CUBIT_FB_INTERSECTION,1); 00103 if( status == CUBIT_FAILURE ) 00104 return status; 00105 00106 facet_surf_list.reset(); 00107 00108 std::vector<int> surfindex, surfindex2; 00109 std::vector<int> curveindex, curveindex2; 00110 std::vector<double> vertsout, vertsout2; 00111 std::vector<int> coordsout, coordsout2; 00112 00113 status = intersector.gather_by_boolean(vertsout,coordsout, 00114 &surfindex,&curveindex,0, 00115 CUBIT_FB_INTERSECTION); 00116 if( status == CUBIT_FAILURE ) 00117 return status; 00118 status = intersector.gather_by_boolean(vertsout2,coordsout2, 00119 &surfindex2,&curveindex2,0, 00120 CUBIT_FB_SUBTRACTION); 00121 if( status == CUBIT_FAILURE ) 00122 return status; 00123 00124 // If there were no intersections 00125 if ( (vertsout.size() == 0) || (coordsout.size() == 0) || 00126 (vertsout2.size() == 0) || (coordsout2.size() == 0) ) 00127 { 00128 intersects = CUBIT_FALSE; 00129 delete [] surfs_in_intersection; delete [] surfs_in_subtraction; 00130 delete [] curves_in_intersection; delete [] curves_in_subtraction; 00131 return CUBIT_SUCCESS; 00132 } 00133 00134 CubitPoint *new_point; 00135 std::vector<CubitPoint *> points; 00136 00137 for ( k = 0; k < vertsout.size(); k += 3 ) { 00138 new_point = (CubitPoint *) new CubitPointData( vertsout[k], 00139 vertsout[k+1], 00140 vertsout[k+2] ); 00141 points.push_back(new_point); 00142 } 00143 00144 DLIList <CubitFacet *>facet_list; 00145 DLIList <CubitPoint *>point_list; 00146 CubitFacet *facet_ptr; 00147 if(mydebug) 00148 GfxDebug::clear(); 00149 for ( k = 0; k < coordsout.size(); k += 3 ) 00150 { 00151 facet_ptr = new CubitFacetData( points[coordsout[k]], 00152 points[coordsout[k+1]], 00153 points[coordsout[k+2]] ); 00154 int cptr[3]; 00155 cptr[0] = curveindex[k]; 00156 cptr[1] = curveindex[k+1]; 00157 cptr[2] = curveindex[k+2]; 00158 TDFacetboolData::add_facetbool_facet( facet_ptr ); 00159 TDFacetboolData* td = TDFacetboolData::get(facet_ptr); 00160 td->set(surfindex[k/3],cptr[0],cptr[1],cptr[2],false, 00161 facet_ptr->is_backwards()); 00162 if(mydebug){ 00163 facet_ptr->debug_draw(CUBIT_YELLOW_INDEX); 00164 CubitVector tmp1 = points[coordsout[k]]->coordinates(); 00165 CubitVector tmp2 = points[coordsout[k+1]]->coordinates(); 00166 CubitVector tmp3 = points[coordsout[k+2]]->coordinates(); 00167 00168 if(cptr[0]){ 00169 GfxDebug::draw_line(tmp1, tmp2, CUBIT_WHITE_INDEX); 00170 } 00171 if(cptr[1]){ 00172 GfxDebug::draw_line(tmp2, tmp3, CUBIT_GREEN_INDEX); 00173 } 00174 if(cptr[2]){ 00175 GfxDebug::draw_line(tmp3, tmp1, CUBIT_BLUE_INDEX); 00176 } 00177 } 00178 facet_list.append( facet_ptr ); 00179 } 00180 if(mydebug){ 00181 GfxDebug::mouse_xforms(); 00182 } 00183 points.clear(); // clear out the points vector since we are through with it. 00184 00185 double feature_angle; 00186 int interp_order; 00187 CubitBoolean smooth_non_manifold, split_surfaces; 00188 BodySM *body_ptr, *body_ptr2; 00189 //determine if original body is a sheet body 00190 Body *tmp_body = CAST_TO(bodysm_ptr->topology_entity(), Body); 00191 bool is_sheet_body = false; 00192 if( tmp_body->is_sheet_body() ) 00193 is_sheet_body = true; 00194 00195 //mbrewer: This is not the best solution. For now, we are using 00196 // a no feature angle unless we are working with a sheet-body. For 00197 // sheet-bodies, however, we are not marking the vertices that 00198 // bound curves. Therefore, if we do not use a feature angle, curves 00199 // are not split correctly. The correct fix would be to mark 00200 // the vertices and maintain them through the webcut. 00201 if( is_sheet_body ) 00202 feature_angle = 135.0; 00203 else 00204 feature_angle = 0.0; 00205 interp_order = 0; 00206 smooth_non_manifold = CUBIT_TRUE; 00207 split_surfaces = CUBIT_FALSE; 00208 00209 { 00210 ChollaEngine *cholla_ptr = NULL; 00211 00212 status = fme->build_cholla_surfaces( facet_list, 00213 point_list, 00214 feature_angle, 00215 interp_order, 00216 smooth_non_manifold, 00217 split_surfaces, 00218 cholla_ptr ); 00219 if( status == CUBIT_FAILURE ) 00220 return status; 00221 00222 status = fme->finish_facet_Body( cholla_ptr, 00223 NULL, 00224 feature_angle, interp_order, 00225 body_ptr); 00226 if( status == CUBIT_FAILURE ) 00227 return status; 00228 00229 if ( cholla_ptr ) 00230 { 00231 cholla_ptr->delete_me(); 00232 delete cholla_ptr; 00233 } 00234 } 00235 DLIList<BodySM*> new_bodies; 00236 00237 status = separate_shells_into_bodies( body_ptr, is_sheet_body, new_bodies ); 00238 if( status == CUBIT_FAILURE ) 00239 return status; 00240 for(k=new_bodies.size(); k--;) 00241 results_list.append( new_bodies.get_and_step() ); 00242 00243 vertsout.clear(); 00244 coordsout.clear(); 00245 00246 facet_list.clean_out(); 00247 for ( k = 0; k < vertsout2.size(); k += 3 ) { 00248 new_point = (CubitPoint *) new CubitPointData( vertsout2[k], 00249 vertsout2[k+1], 00250 vertsout2[k+2] ); 00251 points.push_back(new_point); 00252 } 00253 for ( k = 0; k < coordsout2.size(); k += 3 ) { 00254 facet_ptr = new CubitFacetData( points[coordsout2[k]], 00255 points[coordsout2[k+1]], 00256 points[coordsout2[k+2]] ); 00257 int cptr[3]; 00258 cptr[0] = curveindex2[k]; 00259 cptr[1] = curveindex2[k+1]; 00260 cptr[2] = curveindex2[k+2]; 00261 TDFacetboolData::add_facetbool_facet( facet_ptr ); 00262 TDFacetboolData* td = TDFacetboolData::get(facet_ptr); 00263 td->set(surfindex2[k/3],cptr[0],cptr[1],cptr[2],false, 00264 facet_ptr->is_backwards()); 00265 if(mydebug){ 00266 CubitVector tmp1 = points[coordsout2[k]]->coordinates(); 00267 CubitVector tmp2 = points[coordsout2[k+1]]->coordinates(); 00268 CubitVector tmp3 = points[coordsout2[k+2]]->coordinates(); 00269 if(cptr[0]){ 00270 GfxDebug::draw_line(tmp1, tmp2, CUBIT_WHITE_INDEX); 00271 } 00272 if(cptr[1]){ 00273 GfxDebug::draw_line(tmp2, tmp3, CUBIT_GREEN_INDEX); 00274 } 00275 if(cptr[2]){ 00276 GfxDebug::draw_line(tmp3, tmp1, CUBIT_BLUE_INDEX); 00277 } 00278 } 00279 facet_list.append( facet_ptr ); 00280 } 00281 points.clear(); // clear out the points vector since we are through with it. 00282 00283 { 00284 ChollaEngine *cholla_ptr = NULL; 00285 00286 status = fme->build_cholla_surfaces( facet_list, 00287 point_list, 00288 feature_angle, 00289 interp_order, 00290 smooth_non_manifold, 00291 split_surfaces, 00292 cholla_ptr ); 00293 if( status == CUBIT_FAILURE ) 00294 return status; 00295 00296 status = fme->finish_facet_Body( cholla_ptr, 00297 NULL, 00298 feature_angle, interp_order, 00299 body_ptr2); 00300 if( status == CUBIT_FAILURE ) 00301 return status; 00302 if ( cholla_ptr ) 00303 { 00304 cholla_ptr->delete_me(); 00305 delete cholla_ptr; 00306 } 00307 } 00308 new_bodies.clean_out(); 00309 status = separate_shells_into_bodies( body_ptr2, is_sheet_body, new_bodies ); 00310 if( status == CUBIT_FAILURE ) 00311 return status; 00312 for(k=new_bodies.size(); k--;) 00313 results_list.append( new_bodies.get_and_step() ); 00314 00315 if ( delete_bodies == CUBIT_TRUE ) 00316 make_persistents_webcut(bodysm_ptr,body_ptr,body_ptr2,fsurfarray,fcurvearray, 00317 surfs_in_intersection,surfs_in_subtraction, 00318 curves_in_intersection,curves_in_subtraction); 00319 00320 vertsout2.clear(); 00321 coordsout2.clear(); 00322 00323 delete [] surfs_in_intersection; delete [] surfs_in_subtraction; 00324 delete [] curves_in_intersection; delete [] curves_in_subtraction; 00325 00326 return CUBIT_SUCCESS; 00327 } 00328 00329 CubitStatus FacetboolInterface::separate_lumps( BodySM *body_ptr, 00330 bool is_sheet_body) 00331 { 00332 //get all the shells in 'body_ptr' 00333 DLIList<FacetShell*> facet_shells; 00334 FacetBody *facet_body = CAST_TO( body_ptr, FacetBody ); 00335 facet_body->get_shells( facet_shells ); 00336 00337 // some shells here might contain more than one connected 00338 // patch of surfaces...which is illegal. Separate them into their own shells. 00339 bool created_shells = false; 00340 int k,i; 00341 for( k=facet_shells.size(); k--; ) 00342 { 00343 FacetShell *facet_shell = facet_shells.get_and_step(); 00344 DLIList<FacetSurface*> facet_surfs; 00345 facet_shell->get_surfaces( facet_surfs ); 00346 DLIList<FacetSurface*> connected_patch; 00347 int max_num_passes = facet_surfs.size(); 00348 int num_passes=0; //prevents infinite loop 00349 while( facet_surfs.size() && num_passes < max_num_passes ) 00350 { 00351 connected_patch.clean_out(); 00352 FacetQueryEngine::instance()->get_connected_patch( facet_surfs, connected_patch ); 00353 00354 if( num_passes == 0 ) 00355 { 00356 int kk; 00357 for( kk=connected_patch.size(); kk--; ) 00358 { 00359 FacetSurface *f_surf = connected_patch.get_and_step(); 00360 if( is_sheet_body ) 00361 f_surf->set_shell_sense( facet_shell, CUBIT_UNKNOWN ); 00362 else 00363 f_surf->set_shell_sense( facet_shell, CUBIT_FORWARD ); 00364 } 00365 } 00366 else //extract surfaces out of current shell and make them into their own shell 00367 { 00368 00369 facet_shell->disconnect_surfaces( connected_patch ); 00370 00371 DLIList<Surface*> tmp_surfs; 00372 CAST_LIST( connected_patch, tmp_surfs, Surface ); 00373 ShellSM *shellsm_ptr; 00374 FacetModifyEngine::instance()->make_facet_shell(tmp_surfs, shellsm_ptr); 00375 if ( shellsm_ptr == NULL ) 00376 { 00377 PRINT_ERROR("Problems building facet based shell entity.\n"); 00378 } 00379 else 00380 { 00381 FacetShell *tmp_shell = static_cast<FacetShell*>(shellsm_ptr); 00382 00383 int kk; 00384 //now for each surface, add sense wrt this new shell 00385 for( kk=tmp_surfs.size(); kk--;) 00386 { 00387 FacetSurface *tmp_facet_surf = CAST_TO(tmp_surfs.get_and_step(), FacetSurface); 00388 00389 //if it's not a sheet body, tag the surfs wrt the shell, FORWARD 00390 if( is_sheet_body ) 00391 tmp_facet_surf->set_shell_sense( tmp_shell, CUBIT_UNKNOWN ); 00392 else 00393 tmp_facet_surf->set_shell_sense( tmp_shell, CUBIT_FORWARD ); 00394 } 00395 00396 created_shells = true; 00397 FacetLump *facet_lump = static_cast<FacetLump*>( facet_shell->get_lump() ); 00398 facet_lump->add_shell( tmp_shell ); 00399 } 00400 } 00401 num_passes++; 00402 } 00403 } 00404 00405 bool created_lumps = false; 00406 DLIList<FacetShell*> void_shells; 00407 int number_regions = 0; 00408 if( created_shells ) 00409 { 00410 //determine which shells are regions and which are voids 00411 //get a point we know is outside the body 00412 CubitBox bbox; 00413 CubitVector centroid; 00414 double vol; 00415 facet_body->mass_properties( centroid, vol ); 00416 FacetQueryEngine::instance()->create_facet_bounding_box( facet_body, bbox ); 00417 CubitVector point_outside = 2*(bbox.maximum() - centroid); 00418 point_outside = centroid + point_outside; 00419 00420 facet_shells.clean_out(); 00421 facet_body->get_shells( facet_shells ); 00422 for( k=facet_shells.size(); k--; ) 00423 { 00424 FacetShell *facet_shell = facet_shells.get_and_step(); 00425 CubitPointContainment point_cont; 00426 point_cont = facet_shell->point_containment( point_outside ); 00427 00428 if( point_cont == CUBIT_PNT_OUTSIDE ) 00429 number_regions++; 00430 else if( point_cont == CUBIT_PNT_INSIDE ) 00431 void_shells.append( facet_shell ); 00432 00433 //is a region...if it is the second found region, should be 00434 //in its own lump 00435 if( number_regions>1 && point_cont == CUBIT_PNT_OUTSIDE ) 00436 { 00437 created_lumps = true; 00438 00439 //remove this shell from its current Lump 00440 FacetLump *tmp_lump = static_cast<FacetLump*>(facet_shell->get_lump()); 00441 tmp_lump->remove_shell( facet_shell ); 00442 00443 //make a new lump containing this shell 00444 Lump *new_lump; 00445 DLIList<ShellSM*> sm_shells; 00446 sm_shells.append( static_cast<ShellSM*>(facet_shell) ); 00447 FacetModifyEngine::instance()->make_facet_lump( sm_shells, new_lump ); 00448 00449 //add lump to body 00450 facet_body->add_lump( static_cast<FacetLump*>(new_lump) ); 00451 } 00452 } 00453 } 00454 00455 if( void_shells.size() && created_lumps ) 00456 { 00457 //the void shells are still in the original lump. We need to pair each 00458 //up with the region that encloses it 00459 00460 //make a list of all the region (non-void) shells in the body 00461 DLIList<FacetShell*> region_shells; 00462 facet_body->get_shells( region_shells ); 00463 for(k=void_shells.size(); k--;) 00464 { 00465 if( region_shells.move_to( void_shells.get_and_step() ) ) 00466 region_shells.change_to( NULL ); 00467 } 00468 region_shells.remove_all_with_value( NULL ); 00469 00470 //for each void lump...find the region that contains it 00471 for( k=void_shells.size(); k--; ) 00472 { 00473 FacetShell *void_shell = void_shells.get_and_step(); 00474 00475 //get a point on the void 00476 DLIList<FacetSurface*> tmp_surfs; 00477 void_shell->get_surfaces( tmp_surfs ); 00478 CubitVector point_on_shell; 00479 00480 DLIList<CubitFacet*> facet_list; 00481 tmp_surfs.get()->tris( facet_list ); 00482 00483 point_on_shell = facet_list.get()->center(); 00484 00485 //get the region that contains that point 00486 for( i=region_shells.size(); i--; ) 00487 { 00488 FacetShell *region_shell = region_shells.get_and_step(); 00489 00490 tmp_surfs.clean_out(); 00491 region_shell->get_surfaces( tmp_surfs ); 00492 00493 if( region_shell->point_containment( point_on_shell ) 00494 == CUBIT_PNT_INSIDE ) 00495 { 00496 //remove the void shell from it's lump 00497 FacetLump *tmp_lump = static_cast<FacetLump*>(void_shell->get_lump()); 00498 tmp_lump->remove_shell( void_shell ); 00499 00500 //add the void shell to the region's lump 00501 tmp_lump = static_cast<FacetLump*>(region_shell->get_lump()); 00502 tmp_lump->add_shell( void_shell ); 00503 break; 00504 } 00505 } 00506 } 00507 } 00508 return CUBIT_SUCCESS; 00509 } 00510 00511 CubitStatus FacetboolInterface::separate_shells_into_bodies(BodySM *body_ptr, 00512 bool is_sheet_body, 00513 DLIList<BodySM*> &new_bodies) 00514 { 00515 //first separate the body into its lumps 00516 if(!separate_lumps(body_ptr,is_sheet_body)) 00517 return CUBIT_FAILURE; 00518 00519 //split out each lump into it's own body 00520 DLIList<BodySM*> split_bodies; 00521 FacetModifyEngine::instance()->split_body( body_ptr, split_bodies); 00522 new_bodies += split_bodies; 00523 00524 return CUBIT_SUCCESS; 00525 } 00526 00527 CubitStatus FacetboolInterface::facetbody_to_facetbool( 00528 DLIList<FacetSurface*> &facet_surf_list, 00529 std::vector<double> &body_verts, 00530 std::vector<int> &body_connections, 00531 std::vector<int> *f_c_indices, 00532 std::vector<FacetSurface *>& fsurfarray, 00533 std::vector<FacetCurve *>& fcurvearray 00534 ) 00535 { 00536 CubitStatus status; 00537 int mydebug = 0; 00538 00539 if(mydebug){ 00540 GfxDebug::clear(); 00541 } 00542 int i, j, k, m, n, vtx[3], hashvalue, *hasharrayptr, hasharraysize, ifoundit; 00543 IntegerHash *hashobj; 00544 double xx, yy, zz, xval, yval, zval; 00545 FacetSurface *facet_surface; 00546 DLIList<CubitFacet*> facetlist; 00547 DLIList<CubitFacetEdge*> c_edgelist, f_edgelist; 00548 DLIList<FacetCurve *> curve_list; 00549 CubitPoint *point; 00550 CubitFacet *facet; 00551 FacetCurve *curve; 00552 CubitFacetEdge *c_edge, *edge; 00553 int numhashbins, c_index; 00554 00555 numhashbins = 101; 00556 status = CUBIT_SUCCESS; 00557 hashobj = new IntegerHash(numhashbins,20); 00558 00559 for ( i = 0; i < facet_surf_list.size(); i++ ) { 00560 facet_surface = facet_surf_list.get_and_step(); 00561 fsurfarray.push_back(facet_surface); 00562 facet_surface->get_my_facetedges(f_edgelist); 00563 for ( m = f_edgelist.size(); m > 0; m-- ) { 00564 edge = f_edgelist.get_and_step(); 00565 edge->set_flag(0); // Initialize edge flags. 00566 if(mydebug) 00567 edge->debug_draw(CUBIT_PINK_INDEX); 00568 } 00569 // Assume that each facet surf occurs only once, so there won't be 00570 // duplicates on fsarray. 00571 facetlist.clean_out(); 00572 facet_surface->tris(facetlist); 00573 curve_list.clean_out(); 00574 facet_surface->get_curves(curve_list); 00575 for ( m = 0; m < curve_list.size(); m++ ) { 00576 curve = curve_list.get_and_step(); 00577 c_index = findcurve(curve,fcurvearray); 00578 c_edgelist.clean_out(); 00579 curve->get_facets(c_edgelist); 00580 for ( n = c_edgelist.size(); n > 0; n-- ) { 00581 c_edge = c_edgelist.get_and_step(); 00582 c_edge->set_flag(c_index+1); 00583 if(mydebug) 00584 c_edge->debug_draw(CUBIT_RED_INDEX); 00585 00586 } 00587 } 00588 int efindex[3]; 00589 for ( j = facetlist.size(); j > 0; j-- ) { 00590 facet = facetlist.get_and_step(); 00591 for ( k = 0; k < 3; k++ ) { 00592 point = facet->point(k); 00593 edge = facet->edge(k); 00594 if(mydebug){ 00595 if(edge->get_flag()){ 00596 edge->debug_draw(CUBIT_WHITE_INDEX); 00597 } 00598 } 00599 efindex[k] = edge->get_flag(); 00600 xx = point->x(); 00601 yy = point->y(); 00602 zz = point->z(); 00603 // Get a vertex number. 00604 hashvalue = FBDataUtil::makeahashvaluefrom_coord(xx,yy,zz,numhashbins); 00605 hasharrayptr = hashobj->getHashBin(hashvalue,&hasharraysize); 00606 ifoundit = -1; 00607 for ( m = 0; m < hasharraysize; m++ ) { 00608 n = hasharrayptr[m]; 00609 xval = body_verts[3*n]; 00610 yval = body_verts[3*n+1]; 00611 zval = body_verts[3*n+2]; 00612 if ( ( fabs(xval-xx) < 1.e-6 ) && 00613 ( fabs(yval-yy) < 1.e-6 ) && 00614 ( fabs(zval-zz) < 1.e-6 ) ) { 00615 ifoundit = n; 00616 break; 00617 } 00618 } 00619 if ( ifoundit == -1 ) { 00620 ifoundit = body_verts.size()/3; 00621 body_verts.push_back(xx); 00622 body_verts.push_back(yy); 00623 body_verts.push_back(zz); 00624 hashobj->addtoHashList(hashvalue,ifoundit); 00625 } 00626 vtx[k] = ifoundit; 00627 } 00628 body_connections.push_back(vtx[0]); 00629 body_connections.push_back(vtx[1]); 00630 body_connections.push_back(vtx[2]); 00631 f_c_indices->push_back(i+1); // put the surface index for the facet 00632 f_c_indices->push_back(efindex[2]); // edge indices for the facet 00633 f_c_indices->push_back(efindex[0]); 00634 f_c_indices->push_back(efindex[1]); 00635 } 00636 } 00637 if(mydebug) 00638 GfxDebug::mouse_xforms(); 00639 delete hashobj; 00640 return status; 00641 00642 } 00643 00644 //=============================================================================== 00645 // Function : dofacetboolean 00646 // Member Type: PUBLIC 00647 // Description: do facetboolean operations on a list of bodies. 00648 // Author : John Fowler 00649 // Date : 02/04 00650 //=============================================================================== 00651 CubitStatus FacetboolInterface::dofacetboolean(DLIList<BodySM*>& body_list, 00652 BodySM*& newBody, 00653 bool keep_old, 00654 const CubitFacetboolOp op) 00655 { 00656 int k; 00657 BodySM *body_sm1, *body_sm2, *body_out; 00658 CubitStatus status = CUBIT_FAILURE; 00659 bool intersection_found = false; 00660 00661 body_sm1 = body_list.get_and_step(); 00662 00663 for ( k = body_list.size() - 1; k > 0; k-- ) { 00664 body_out =0; 00665 if(!body_sm1) 00666 body_sm1=body_list.get_and_step(); 00667 else{ 00668 body_sm2 = body_list.get_and_step(); 00669 status = dofacetboolean_2bodies(body_sm1,body_sm2,body_out,keep_old, 00670 intersection_found,op); 00671 if ( keep_old == false){ 00672 //if there was an intersection, we want to delete the two 00673 //original bodies if we are not keeping old. 00674 //Also, if we we were performing an INTERSECTION we 00675 //want to delete the two original bodies even if there was 00676 //no intersection between the two bodies (again if we 00677 //are not keeping originals). 00678 if(intersection_found == true || op == CUBIT_FB_INTERSECTION) { 00679 FacetQueryEngine::instance()-> 00680 delete_solid_model_entities(body_sm2); 00681 FacetQueryEngine::instance()-> 00682 delete_solid_model_entities(body_sm1); 00683 body_sm2=NULL; 00684 body_sm1=NULL; 00685 } 00686 //if we are not keeping old, we want to delete the second 00687 //body even if there was no intersection between the two 00688 //bodies (for a subtration). 00689 else if(op == CUBIT_FB_SUBTRACTION) { 00690 FacetQueryEngine::instance()-> 00691 delete_solid_model_entities(body_sm2); 00692 body_sm2=NULL; 00693 } 00694 } 00695 00696 if ( body_out ) body_sm1 = body_out; 00697 } 00698 } 00699 newBody = body_sm1; 00700 00701 return status; 00702 } 00703 00704 //=============================================================================== 00705 // Function : dofacetboolean_subtract 00706 // Member Type: PUBLIC 00707 // Description: do facetboolean subtract operations on a list of bodies. 00708 // Author : John Fowler 00709 // Date : 02/04 00710 //=============================================================================== 00711 CubitStatus FacetboolInterface::dofacetboolean_subtract(BodySM*& tool_body, 00712 DLIList<BodySM*>& from_bodies, 00713 DLIList<BodySM*>& new_bodies, 00714 bool keep_old, 00715 bool* to_be_deleted, 00716 const CubitFacetboolOp op) 00717 { 00718 int k; 00719 BodySM *body_sm2, *body_out; 00720 CubitStatus status = CUBIT_FAILURE; 00721 bool intersection_found = false; 00722 00723 for ( k = 0; k < from_bodies.size(); k++ ) { 00724 body_out = 0; 00725 body_sm2 = from_bodies.get_and_step(); 00726 status = dofacetboolean_2bodies(body_sm2,tool_body,body_out,keep_old, 00727 intersection_found,op); 00728 if ( (keep_old == false) && (intersection_found == true) ) { 00729 to_be_deleted[k] = true; 00730 } 00731 00732 if ( (status == CUBIT_SUCCESS) && (body_out) ) new_bodies.append(body_out); 00733 } 00734 00735 return status; 00736 } 00737 00738 CubitStatus FacetboolInterface::dofacetboolean_2bodies(BodySM*& body_in1, 00739 BodySM*& body_in2, 00740 BodySM*& body_out, 00741 bool keep_old, 00742 bool& intersection_found, 00743 const CubitFacetboolOp op) 00744 { 00745 00746 CubitStatus status; 00747 std::vector<double> body_verts; 00748 std::vector<double> body2_verts; 00749 std::vector<int> body_connections, newbodyfacets; 00750 std::vector<int> body2_connections, newbody2facets; 00751 std::vector<double> vertsout; 00752 std::vector<int> coordsout; 00753 std::vector<int> f_c_indices1; 00754 std::vector<int> f_c_indices2; 00755 std::vector<FacetSurface *> fsurfarray1, fsurfarray2; 00756 std::vector<FacetCurve *> fcurvearray1, fcurvearray2; 00757 std::vector<int> surfindex; 00758 std::vector<int> curveindex; 00759 00760 00761 DLIList <CubitFacet *>facet_list; 00762 DLIList <CubitPoint *>point_list; 00763 CubitPoint *new_point; 00764 CubitFacet *facet_ptr; 00765 std::vector<CubitPoint *> points; 00766 bool *surfs_in_intersection, *surfs_in_subtraction; 00767 bool *curves_in_intersection, *curves_in_subtraction; 00768 bool *surfs_in_intersection2, *surfs_in_subtraction2; 00769 bool *curves_in_intersection2, *curves_in_subtraction2; 00770 00771 status = CUBIT_SUCCESS; 00772 intersection_found = true; 00773 bool is_sheet_body = false; 00774 Body *tmp_body_1 = CAST_TO(body_in1->topology_entity(), Body); 00775 Body *tmp_body_2 = CAST_TO(body_in2->topology_entity(), Body); 00776 //try to figure out if we are using sheet bodies 00777 //if it is ambiguous, print a warning. 00778 if(tmp_body_1 && tmp_body_1->is_sheet_body()){ 00779 is_sheet_body = true; 00780 } 00781 else if(tmp_body_2 && tmp_body_2->is_sheet_body()){ 00782 is_sheet_body = true; 00783 } 00784 if(tmp_body_1 && tmp_body_2 && 00785 tmp_body_1->is_sheet_body() != tmp_body_2->is_sheet_body()) 00786 { 00787 PRINT_WARNING("Geometric boolean requested for a sheet body and a non-sheet body.\n"); 00788 } 00789 FacetBody *fbody_ptr; 00790 fbody_ptr = dynamic_cast<FacetBody *>(body_in1); 00791 DLIList<FacetSurface*> facet_surf_list; 00792 fbody_ptr->get_surfaces(facet_surf_list); 00793 00794 status = facetbody_to_facetbool(facet_surf_list,body_verts, 00795 body_connections,&f_c_indices1, 00796 fsurfarray1,fcurvearray1); 00797 facet_surf_list.clean_out(); 00798 00799 fbody_ptr = dynamic_cast<FacetBody *>(body_in2); 00800 fbody_ptr->get_surfaces(facet_surf_list); 00801 status = facetbody_to_facetbool(facet_surf_list,body2_verts, 00802 body2_connections,&f_c_indices2, 00803 fsurfarray2,fcurvearray2); 00804 facet_surf_list.clean_out(); 00805 00806 FBIntersect intersector; 00807 intersector.set_classify_flag(true); 00808 00809 status = intersector.intersect(body_verts,body_connections, 00810 body2_verts,body2_connections, 00811 newbodyfacets,newbody2facets, 00812 &f_c_indices1, 00813 &f_c_indices2); 00814 00815 std::vector<bool> is_body_1; 00816 status = intersector.gather_by_boolean(vertsout,coordsout, 00817 &surfindex,&curveindex,&is_body_1,op); 00818 00819 // If there were no intersections 00820 if ( (vertsout.size() == 0) || (coordsout.size() == 0)) { 00821 intersection_found = false; 00822 return CUBIT_SUCCESS; 00823 } 00824 // If there was no body_out, we are just checking if there was any 00825 // intersection. If we got this far, there was -- so return. 00826 if ( &body_out == 0 ) return CUBIT_SUCCESS; 00827 00828 surfs_in_intersection = new bool[1+fsurfarray1.size()]; 00829 surfs_in_subtraction = new bool[1+fsurfarray1.size()]; 00830 curves_in_intersection = new bool[1+fcurvearray1.size()]; 00831 curves_in_subtraction = new bool[1+fcurvearray1.size()]; 00832 surfs_in_intersection2 = new bool[1+fsurfarray2.size()]; 00833 surfs_in_subtraction2 = new bool[1+fsurfarray2.size()]; 00834 curves_in_intersection2 = new bool[1+fcurvearray2.size()]; 00835 curves_in_subtraction2 = new bool[1+fcurvearray2.size()]; 00836 00837 unsigned int k; 00838 for ( k = 1; k < 1 + fsurfarray1.size(); k++ ) { 00839 surfs_in_subtraction[k] = surfs_in_intersection[k] = false; 00840 } 00841 for ( k = 1; k < 1 + fcurvearray1.size(); k++ ) { 00842 curves_in_subtraction[k] = curves_in_intersection[k] = false; 00843 } 00844 00845 for ( k = 1; k < 1 + fsurfarray2.size(); k++ ) { 00846 surfs_in_subtraction2[k] = surfs_in_intersection2[k] = false; 00847 } 00848 for ( k = 1; k < 1 + fcurvearray2.size(); k++ ) { 00849 curves_in_subtraction2[k] = curves_in_intersection2[k] = false; 00850 } 00851 00852 status = intersector.get_persistent_entity_info(surfs_in_intersection, 00853 curves_in_intersection,surfs_in_subtraction, 00854 curves_in_subtraction,op,1); 00855 // If op == unite, the curves ans surfs that are undamaged are those 00856 // for which xxx_in_intereseciton = 0 false and xxx_in_subtraction == true 00857 00858 status = intersector.get_persistent_entity_info(surfs_in_intersection2, 00859 curves_in_intersection2,surfs_in_subtraction2, 00860 curves_in_subtraction2,op,2); 00861 00862 00863 for ( k = 0; k < vertsout.size(); k += 3 ) { 00864 new_point = (CubitPoint *) new CubitPointData( vertsout[k], 00865 vertsout[k+1], 00866 vertsout[k+2] ); 00867 points.push_back(new_point); 00868 } 00869 for ( k = 0; k < coordsout.size(); k += 3 ) { 00870 facet_ptr = new CubitFacetData( points[coordsout[k]], 00871 points[coordsout[k+1]], 00872 points[coordsout[k+2]] ); 00873 int cptr[3]; 00874 cptr[0] = curveindex[k]; 00875 cptr[1] = curveindex[k+1]; 00876 cptr[2] = curveindex[k+2]; 00877 TDFacetboolData::add_facetbool_facet( facet_ptr ); 00878 TDFacetboolData* td = TDFacetboolData::get(facet_ptr); 00879 td->set(surfindex[k/3],cptr[0],cptr[1],cptr[2],is_body_1[k/3], 00880 facet_ptr->is_backwards()); 00881 00882 facet_list.append( facet_ptr ); 00883 } 00884 points.clear(); // clear out the points vector since we are through with it. 00885 00886 FacetModifyEngine *fme = FacetModifyEngine::instance(); 00887 int interp_order; 00888 CubitBoolean smooth_non_manifold, split_surfaces; 00889 BodySM *body_ptr; 00890 interp_order = 0; 00891 smooth_non_manifold = CUBIT_TRUE; 00892 split_surfaces = CUBIT_FALSE; 00893 00894 { 00895 ChollaEngine *cholla_ptr = NULL; 00896 00897 status = fme->build_cholla_surfaces( facet_list, 00898 point_list, 00899 -1.0, 00900 interp_order, 00901 smooth_non_manifold, 00902 split_surfaces, 00903 cholla_ptr ); 00904 if( status == CUBIT_FAILURE ) 00905 return status; 00906 00907 status = fme->finish_facet_Body( cholla_ptr, 00908 NULL, 00909 -1.0, interp_order, 00910 body_ptr); 00911 if( status == CUBIT_FAILURE ) 00912 return status; 00913 if ( cholla_ptr ) 00914 { 00915 cholla_ptr->delete_me(); 00916 delete cholla_ptr; 00917 } 00918 } 00919 00920 if ( keep_old == false ) { 00921 make_persistents_boolean(body_in2,body_ptr,fsurfarray2,fcurvearray2, 00922 surfs_in_intersection2,surfs_in_subtraction2, 00923 curves_in_intersection2,curves_in_subtraction2,op,false); 00924 make_persistents_boolean(body_in1,body_ptr,fsurfarray1,fcurvearray1, 00925 surfs_in_intersection,surfs_in_subtraction, 00926 curves_in_intersection,curves_in_subtraction,op,true); 00927 00928 } 00929 00930 body_out = body_ptr; 00931 //separate the lumps in the "body_out", these will be converted to 00932 //separate volumes later in the code. 00933 status=separate_lumps(body_out,is_sheet_body); 00934 vertsout.clear(); 00935 coordsout.clear(); 00936 delete [] surfs_in_intersection; delete [] surfs_in_subtraction; 00937 delete [] curves_in_intersection; delete [] curves_in_subtraction; 00938 delete [] surfs_in_intersection2; delete [] surfs_in_subtraction2; 00939 delete [] curves_in_intersection2; delete [] curves_in_subtraction2; 00940 00941 return status; 00942 00943 } 00944 00945 int FacetboolInterface::findcurve(FacetCurve *curve, 00946 std::vector<FacetCurve *>& fcurvearray) 00947 { 00948 unsigned int i; 00949 00950 for ( i = 0; i < fcurvearray.size(); i++ ) { 00951 if ( fcurvearray[i] == curve ) { 00952 return i; 00953 } 00954 } 00955 fcurvearray.push_back(curve); 00956 00957 return fcurvearray.size() - 1; 00958 } 00959 00960 void FacetboolInterface::make_persistents_webcut(BodySM *body_in, 00961 BodySM *body_out1, 00962 BodySM *body_out2, 00963 std::vector<FacetSurface *>& fsurfarray, 00964 std::vector<FacetCurve *>& fcurvearray, 00965 bool *surfs_in_intersection, 00966 bool *surfs_in_subtraction, 00967 bool *curves_in_intersection, 00968 bool *curves_in_subtraction 00969 ) 00970 { 00971 unsigned int k, n; 00972 DLIList<CubitSimpleAttrib> csa_list; 00973 FacetBody *facet_body_in = CAST_TO(body_in, FacetBody); 00974 FacetBody *facet_body_out1; 00975 FacetBody *facet_body_out2; 00976 00977 facet_body_out1 = CAST_TO(body_out1, FacetBody); 00978 facet_body_out2 = CAST_TO(body_out2, FacetBody); 00979 00980 // Fix the curves. 00981 DLIList<FacetCurve*> fcurvelist, fcurvelist2; 00982 00983 facet_body_out1->get_curves(fcurvelist); 00984 facet_body_out2->get_curves(fcurvelist2); 00985 00986 for ( n = 1; n < 1 + fcurvearray.size(); n++ ) { 00987 if ( (curves_in_intersection[n] == true) && (curves_in_subtraction[n] == false) ) { 00988 make_persistent_curves(fcurvelist,fcurvearray,n); 00989 } else if ( (curves_in_intersection[n] == false) && 00990 (curves_in_subtraction[n] == true) ) { 00991 make_persistent_curves(fcurvelist2,fcurvearray,n); 00992 } 00993 } 00994 00995 00996 // Fix the surfaces 00997 DLIList<FacetSurface*> fsurfaceslist, fsurfaceslist2; 00998 facet_body_out1->get_surfaces(fsurfaceslist); 00999 facet_body_out2->get_surfaces(fsurfaceslist2); 01000 01001 for ( n = 1; n < 1 + fsurfarray.size(); n++ ) { 01002 if ( (surfs_in_intersection[n] == true) && (surfs_in_subtraction[n] == false) ) { 01003 make_persistent_surfaces(fsurfaceslist,fsurfarray,n); 01004 } else if ( (surfs_in_intersection[n] == false) && 01005 (surfs_in_subtraction[n] == true) ) { 01006 make_persistent_surfaces(fsurfaceslist2,fsurfarray,n); 01007 } 01008 } 01009 01010 // Fix the lumps. 01011 FacetLump *florig, *fl2; 01012 DLIList<FacetLump*> flumplist, flumplist2; 01013 facet_body_in->get_lumps(flumplist); 01014 facet_body_out1->get_lumps(flumplist2); 01015 florig = flumplist.get(); 01016 fl2 = flumplist2.get(); 01017 if ( florig->owner() ) { 01018 florig->owner()->swap_bridge(florig,fl2,false); 01019 florig->get_simple_attribute(csa_list); 01020 for ( k = csa_list.size(); k > 0; k-- ) { 01021 const CubitSimpleAttrib& csa = csa_list.get_and_step(); 01022 fl2->append_simple_attribute_virt(csa); 01023 } 01024 } 01025 // Fix the bodies. 01026 if ( facet_body_in->owner() ) { 01027 facet_body_in->owner()->swap_bridge(facet_body_in,facet_body_out1,false); 01028 facet_body_in->get_simple_attribute(csa_list); 01029 for ( k = csa_list.size(); k > 0; k-- ) { 01030 const CubitSimpleAttrib& csa = csa_list.get_and_step(); 01031 facet_body_out1->append_simple_attribute_virt(csa); 01032 } 01033 } 01034 01035 } 01036 01037 void FacetboolInterface::make_persistents_imprint(BodySM *body_in, 01038 BodySM *body_out1, 01039 std::vector<FacetSurface *>& fsurfarray, 01040 std::vector<FacetCurve *>& fcurvearray 01041 ) 01042 { 01043 DLIList<CubitSimpleAttrib> csa_list; 01044 FacetBody *facet_body_in = CAST_TO(body_in, FacetBody); 01045 FacetBody *facet_body_out1 = CAST_TO(body_out1, FacetBody); 01046 unsigned int n; 01047 01048 // Fix the curves. 01049 DLIList<FacetCurve*> fcurvelist; 01050 facet_body_out1->get_curves(fcurvelist); 01051 01052 for ( n = 1; n < 1 + fcurvearray.size(); n++ ) { 01053 make_persistent_curves(fcurvelist,fcurvearray,n,0); 01054 } 01055 01056 01057 // Fix the surfaces 01058 DLIList<FacetSurface*> fsurfaceslist; 01059 facet_body_out1->get_surfaces(fsurfaceslist); 01060 01061 for ( n = 1; n < 1 + fsurfarray.size(); n++ ) { 01062 make_persistent_surfaces(fsurfaceslist,fsurfarray,n,0); 01063 } 01064 01065 // Fix the lumps. 01066 FacetLump *florig, *fl2; 01067 DLIList<FacetLump*> flumplist, flumplist2; 01068 int k; 01069 01070 facet_body_in->get_lumps(flumplist); 01071 facet_body_out1->get_lumps(flumplist2); 01072 florig = flumplist.get(); 01073 fl2 = flumplist2.get(); 01074 if ( florig->owner() ) { 01075 florig->owner()->swap_bridge(florig,fl2,false); 01076 florig->get_simple_attribute(csa_list); 01077 for ( k = csa_list.size(); k > 0; k-- ) { 01078 const CubitSimpleAttrib& csa = csa_list.get_and_step(); 01079 fl2->append_simple_attribute_virt(csa); 01080 } 01081 } 01082 01083 // Fix the bodies. 01084 if ( facet_body_in->owner() ) { 01085 facet_body_in->owner()->swap_bridge(facet_body_in,facet_body_out1,false); 01086 facet_body_in->get_simple_attribute(csa_list); 01087 for ( k = csa_list.size(); k > 0; k-- ) { 01088 const CubitSimpleAttrib& csa = csa_list.get_and_step(); 01089 facet_body_out1->append_simple_attribute_virt(csa); 01090 } 01091 } 01092 01093 } 01094 01095 void FacetboolInterface::make_persistents_boolean(BodySM *body_in, 01096 BodySM *body_out1, 01097 std::vector<FacetSurface *>& fsurfarray, 01098 std::vector<FacetCurve *>& fcurvearray, 01099 bool *surfs_in_intersection, 01100 bool *surfs_in_subtraction, 01101 bool *curves_in_intersection, 01102 bool *curves_in_subtraction, 01103 const CubitFacetboolOp op, 01104 bool body_1 01105 ) 01106 { 01107 unsigned int n; 01108 DLIList<CubitSimpleAttrib> csa_list; 01109 FacetBody *facet_body_in = CAST_TO(body_in, FacetBody); 01110 FacetBody *facet_body_out1 = CAST_TO(body_out1, FacetBody); 01111 int which_parent; 01112 bool bvalue1 = false, bvalue2 = false; 01113 01114 if ( body_1 == true ) which_parent = 1; 01115 else which_parent = 2; 01116 01117 switch (op) { 01118 01119 case CUBIT_FB_UNION: 01120 bvalue1 = false; 01121 bvalue2 = true; 01122 break; 01123 case CUBIT_FB_INTERSECTION: 01124 bvalue2 = false; 01125 bvalue1 = true; 01126 break; 01127 case CUBIT_FB_SUBTRACTION: 01128 if ( body_1 == true ) { 01129 bvalue2 = false; 01130 bvalue1 = true; 01131 } else { 01132 bvalue1 = false; 01133 bvalue2 = true; 01134 } 01135 break; 01136 } 01137 // Fix the curves. 01138 DLIList<FacetCurve*> fcurvelist; 01139 facet_body_out1->get_curves(fcurvelist); 01140 01141 for ( n = 1; n < 1 + fcurvearray.size(); n++ ) { 01142 if ( (curves_in_intersection[n] == bvalue1) && 01143 (curves_in_subtraction[n] == bvalue2) ) { 01144 make_persistent_curves(fcurvelist,fcurvearray,n,which_parent); 01145 } 01146 } 01147 01148 01149 // Fix the surfaces 01150 DLIList<FacetSurface*> fsurfaceslist; 01151 facet_body_out1->get_surfaces(fsurfaceslist); 01152 01153 for ( n = 1; n < 1 + fsurfarray.size(); n++ ) { 01154 if ( (surfs_in_intersection[n] == bvalue1) && 01155 (surfs_in_subtraction[n] == bvalue2) ) { 01156 make_persistent_surfaces(fsurfaceslist,fsurfarray,n,which_parent); 01157 } 01158 } 01159 01160 if ( body_1 == true ) { 01161 // Fix the lumps. 01162 FacetLump *florig, *fl2; 01163 DLIList<FacetLump*> flumplist, flumplist2; 01164 int k; 01165 01166 facet_body_in->get_lumps(flumplist); 01167 facet_body_out1->get_lumps(flumplist2); 01168 florig = flumplist.get(); 01169 fl2 = flumplist2.get(); 01170 if ( florig->owner() ) { 01171 florig->owner()->swap_bridge(florig,fl2,false); 01172 florig->get_simple_attribute(csa_list); 01173 for ( k = csa_list.size(); k > 0; k-- ) { 01174 const CubitSimpleAttrib& csa = csa_list.get_and_step(); 01175 fl2->append_simple_attribute_virt(csa); 01176 } 01177 } 01178 01179 // Fix the bodies. 01180 if ( facet_body_in->owner() ) { 01181 facet_body_in->owner()->swap_bridge(facet_body_in,facet_body_out1,false); 01182 facet_body_in->get_simple_attribute(csa_list); 01183 for ( k = csa_list.size(); k > 0; k-- ) { 01184 const CubitSimpleAttrib& csa = csa_list.get_and_step(); 01185 facet_body_out1->append_simple_attribute_virt(csa); 01186 } 01187 } 01188 } 01189 01190 } 01191 01192 void FacetboolInterface::make_persistent_curves(DLIList<FacetCurve*> fcurvelist, 01193 std::vector<FacetCurve *>& fcurvearray, 01194 int n, 01195 int which_parent) 01196 { 01197 int k, m, jj; 01198 FacetCurve *fcurveorig, *fcurve2; 01199 int *marked3, index; 01200 bool ifoundit; 01201 FacetPoint *fpointorig, *fpoint2; 01202 DLIList<FacetPoint*> fpointlist, fpointlist2; 01203 CubitFacet *cfac; 01204 DLIList<CubitSimpleAttrib> csa_list; 01205 bool is_from_1, error; 01206 TDFacetboolData* tdf; 01207 01208 fcurveorig = fcurvearray[n-1]; 01209 ifoundit = false; 01210 for ( k = fcurvelist.size(); k > 0; k-- ) { 01211 fcurve2 = fcurvelist.get_and_step(); 01212 if ( fcurve2->owner() ) continue; // If owner is already set, skip it. 01213 CurveFacetEvalTool *evaltool = fcurve2->get_eval_tool(); 01214 DLIList<CubitFacetEdge*> edgelist; 01215 CubitFacetEdge *cfedge; 01216 evaltool->get_facets(edgelist); 01217 cfedge = edgelist.get(); 01218 cfac = cfedge->adj_facet(0); 01219 index = cfac->edge_index(cfedge); 01220 tdf = TDFacetboolData::get(cfac); 01221 if ( which_parent ) { 01222 is_from_1 = tdf->parent_is_body_1(); 01223 if ( ( (is_from_1 == true) && (which_parent == 2) ) || 01224 ( (is_from_1 == false) && (which_parent == 1) ) ) continue; 01225 } 01226 marked3 = tdf->get_edge_indices(cfac->is_backwards()); 01227 if ( marked3[(index+1)%3] == n ) ifoundit = true; 01228 else { 01229 cfac = cfedge->adj_facet(1); 01230 if (cfac) { 01231 index = cfac->edge_index(cfedge); 01232 tdf = TDFacetboolData::get(cfac); 01233 if ( which_parent ) { 01234 is_from_1 = tdf->parent_is_body_1(); 01235 if ( ( (is_from_1 == true) && (which_parent == 2) ) || 01236 ( (is_from_1 == false) && (which_parent == 1) ) ) continue; 01237 } 01238 marked3 = tdf->get_edge_indices(cfac->is_backwards()); 01239 if ( marked3[(index+1)%3] == n ) ifoundit = true; 01240 } 01241 } 01242 if ( ifoundit == true ) { 01243 fpointlist.clean_out(); 01244 fpointlist2.clean_out(); 01245 fcurveorig->get_points(fpointlist); 01246 fcurve2->get_points(fpointlist2); 01247 for ( jj = fpointlist.size(); jj > 0; jj-- ) { 01248 error = false; 01249 fpointorig = fpointlist.get_and_step(); 01250 fpoint2 = fpointlist2.get_and_step(); 01251 while ( fpoint2->coordinates() != fpointorig->coordinates() ) { 01252 if ( fpointlist2.is_at_beginning() == CUBIT_TRUE ) { 01253 // PRINT_WARNING("Unable to make point on curve persistent.\n"); 01254 error = true; 01255 break; 01256 } 01257 fpoint2 = fpointlist2.get_and_step(); 01258 } 01259 if ( error == true ) continue; 01260 if ( fpointorig->owner() && !(fpoint2->owner()) ) { 01261 fpointorig->owner()->swap_bridge(fpointorig,fpoint2,false); 01262 fpointorig->get_simple_attribute(csa_list); 01263 for ( m = csa_list.size(); m > 0; m-- ) { 01264 const CubitSimpleAttrib& csa = csa_list.get_and_step(); 01265 fpoint2->append_simple_attribute_virt(csa); 01266 } 01267 } 01268 } 01269 if ( fcurveorig->owner() != 0 ) 01270 fcurveorig->owner()->swap_bridge(fcurveorig,fcurve2,false); 01271 fcurveorig->get_simple_attribute(csa_list); 01272 for ( m = csa_list.size(); m > 0; m-- ) { 01273 const CubitSimpleAttrib& csa = csa_list.get_and_step(); 01274 fcurve2->append_simple_attribute_virt(csa); 01275 } 01276 break; 01277 } 01278 } 01279 } 01280 01281 void FacetboolInterface::make_persistent_surfaces(DLIList<FacetSurface*> fsurfaceslist, 01282 std::vector<FacetSurface *>& fsurfarray, 01283 int n, 01284 int which_parent) 01285 { 01286 DLIList<CubitSimpleAttrib> csa_list; 01287 int k, m; 01288 FacetSurface *fsorig, *fsurf2; 01289 bool is_from_1; 01290 01291 fsorig = fsurfarray[n-1]; 01292 for ( k = fsurfaceslist.size(); k > 0; k-- ) { 01293 fsurf2 = fsurfaceslist.get_and_step(); 01294 DLIList<CubitFacet*> facet_list2; 01295 fsurf2->tris(facet_list2); 01296 CubitFacet* facet2 = facet_list2.get(); 01297 TDFacetboolData* tdf = TDFacetboolData::get(facet2); 01298 if ( which_parent ) { 01299 is_from_1 = tdf->parent_is_body_1(); 01300 if ( ( (is_from_1 == true) && (which_parent == 2) ) || 01301 ( (is_from_1 == false) && (which_parent == 1) ) ) continue; 01302 } 01303 int marked2 = tdf->get_surf_index(); 01304 if ( marked2 == n ) { 01305 if ( fsorig->owner() != 0 ) 01306 fsorig->owner()->swap_bridge(fsorig,fsurf2,false); 01307 fsorig->get_simple_attribute(csa_list); 01308 for ( m = csa_list.size(); m > 0; m-- ) { 01309 const CubitSimpleAttrib& csa = csa_list.get_and_step(); 01310 fsurf2->append_simple_attribute_virt(csa); 01311 } 01312 break; 01313 } 01314 } 01315 } 01316 01317 CubitStatus FacetboolInterface::FB_imprint_with_curves(BodySM*& body_in, 01318 BodySM*& body_out, 01319 bool keep_old) 01320 { 01321 CubitStatus status; 01322 01323 FacetModifyEngine *fme = FacetModifyEngine::instance(); 01324 01325 FacetBody *fbody_ptr; 01326 fbody_ptr = dynamic_cast<FacetBody *>(body_in); 01327 DLIList<FacetSurface*> facet_surf_list; 01328 fbody_ptr->get_surfaces(facet_surf_list); 01329 std::vector<double> body_verts; 01330 std::vector<int> body_connections, newbodyfacets; 01331 std::vector<int> f_c_indices; 01332 std::vector<FacetSurface *> fsurfarray; 01333 std::vector<FacetCurve *> fcurvearray; 01334 std::vector<double> vertsout; 01335 std::vector<int> coordsout; 01336 std::vector<int> surfindex; 01337 std::vector<int> curveindex; 01338 01339 status = facetbody_to_facetbool(facet_surf_list,body_verts, 01340 body_connections,&f_c_indices, 01341 fsurfarray,fcurvearray); 01342 facet_surf_list.clean_out(); 01343 01344 FBImprint imprinter; 01345 01346 status = imprinter.imprint_body_curve(body_verts,body_connections, 01347 FB_imprint_edge_coords,FB_imprint_edges, 01348 FB_imprint_edge_bboxes,&f_c_indices); 01349 01350 status = imprinter.update_surfs_and_curves(vertsout,coordsout, 01351 &surfindex,&curveindex); 01352 DLIList <CubitFacet *>facet_list; 01353 DLIList <CubitPoint *>point_list; 01354 CubitPoint *new_point; 01355 CubitFacet *facet_ptr; 01356 std::vector<CubitPoint *> points; 01357 01358 unsigned int k; 01359 for ( k = 0; k < vertsout.size(); k += 3 ) { 01360 new_point = (CubitPoint *) new CubitPointData( vertsout[k], 01361 vertsout[k+1], 01362 vertsout[k+2] ); 01363 points.push_back(new_point); 01364 } 01365 for ( k = 0; k < coordsout.size(); k += 3 ) { 01366 facet_ptr = new CubitFacetData( points[coordsout[k]], 01367 points[coordsout[k+1]], 01368 points[coordsout[k+2]] ); 01369 int cptr[3]; 01370 cptr[0] = curveindex[k]; 01371 cptr[1] = curveindex[k+1]; 01372 cptr[2] = curveindex[k+2]; 01373 TDFacetboolData::add_facetbool_facet( facet_ptr ); 01374 TDFacetboolData* td = TDFacetboolData::get(facet_ptr); 01375 td->set(surfindex[k/3],cptr[0],cptr[1],cptr[2],false, 01376 facet_ptr->is_backwards()); 01377 01378 facet_list.append( facet_ptr ); 01379 } 01380 points.clear(); // clear out the points vector since we are through with it. 01381 01382 double feature_angle; 01383 int interp_order; 01384 CubitBoolean smooth_non_manifold, split_surfaces; 01385 feature_angle = 135.0; 01386 interp_order = 0; 01387 smooth_non_manifold = CUBIT_TRUE; 01388 split_surfaces = CUBIT_TRUE; 01389 01390 { 01391 ChollaEngine *cholla_ptr = NULL; 01392 01393 status = fme->build_cholla_surfaces( facet_list, 01394 point_list, 01395 feature_angle, 01396 interp_order, 01397 smooth_non_manifold, 01398 split_surfaces, 01399 cholla_ptr ); 01400 if( status == CUBIT_FAILURE ) 01401 return status; 01402 01403 status = fme->finish_facet_Body( cholla_ptr, 01404 NULL, 01405 feature_angle, interp_order, 01406 body_out); 01407 if( status == CUBIT_FAILURE ) 01408 return status; 01409 if ( cholla_ptr ) 01410 { 01411 cholla_ptr->delete_me(); 01412 delete cholla_ptr; 01413 } 01414 } 01415 01416 vertsout.clear(); 01417 coordsout.clear(); 01418 if ( keep_old == false ) { 01419 make_persistents_imprint(body_in,body_out,fsurfarray,fcurvearray); 01420 } 01421 01422 return status; 01423 01424 } 01425 01426 CubitStatus FacetboolInterface::dofacetboolean_2bodies_imprint(BodySM*& body_in1, 01427 BodySM*& body_in2, 01428 BodySM*& body_out1, 01429 BodySM*& body_out2, 01430 bool keep_old) 01431 { 01432 CubitStatus status; 01433 std::vector<double> body_verts; 01434 std::vector<double> body2_verts; 01435 std::vector<int> body_connections, newbodyfacets; 01436 std::vector<int> body2_connections, newbody2facets; 01437 std::vector<double> vertsout1, vertsout2; 01438 std::vector<int> coordsout1, coordsout2; 01439 std::vector<int> f_c_indices1; 01440 std::vector<int> f_c_indices2; 01441 std::vector<FacetSurface *> fsurfarray1, fsurfarray2; 01442 std::vector<FacetCurve *> fcurvearray1, fcurvearray2; 01443 std::vector<int> surfindex1, surfindex2; 01444 std::vector<int> curveindex1, curveindex2; 01445 01446 DLIList <CubitFacet *>facet_list; 01447 DLIList <CubitPoint *>point_list; 01448 CubitPoint *new_point; 01449 CubitFacet *facet_ptr; 01450 std::vector<CubitPoint *> points; 01451 01452 FacetModifyEngine *fme = FacetModifyEngine::instance(); 01453 bool is_sheet_body = false; 01454 Body *tmp_body_1 = CAST_TO(body_in1->topology_entity(), Body); 01455 Body *tmp_body_2 = CAST_TO(body_in2->topology_entity(), Body); 01456 if(tmp_body_1 && tmp_body_1->is_sheet_body()){ 01457 is_sheet_body = true; 01458 } 01459 else if(tmp_body_2 && tmp_body_2->is_sheet_body()){ 01460 is_sheet_body = true; 01461 } 01462 if(tmp_body_1->is_sheet_body() != tmp_body_2->is_sheet_body()) 01463 { 01464 PRINT_WARNING("Geometric boolean requested for a sheet body and a non-sheet body.\n"); 01465 } 01466 FacetBody *fbody_ptr; 01467 fbody_ptr = dynamic_cast<FacetBody *>(body_in1); 01468 DLIList<FacetSurface*> facet_surf_list; 01469 fbody_ptr->get_surfaces(facet_surf_list); 01470 01471 status = facetbody_to_facetbool(facet_surf_list,body_verts, 01472 body_connections,&f_c_indices1, 01473 fsurfarray1,fcurvearray1); 01474 facet_surf_list.clean_out(); 01475 01476 fbody_ptr = dynamic_cast<FacetBody *>(body_in2); 01477 fbody_ptr->get_surfaces(facet_surf_list); 01478 status = facetbody_to_facetbool(facet_surf_list,body2_verts, 01479 body2_connections,&f_c_indices2, 01480 fsurfarray2,fcurvearray2); 01481 facet_surf_list.clean_out(); 01482 01483 FBIntersect intersector; 01484 intersector.set_imprint(); 01485 status = intersector.intersect(body_verts,body_connections, 01486 body2_verts,body2_connections, 01487 newbodyfacets,newbody2facets, 01488 &f_c_indices1, 01489 &f_c_indices2); 01490 status = intersector.update_surfs_and_curves(vertsout1,coordsout1, 01491 &surfindex1,&curveindex1,1); 01492 status = intersector.update_surfs_and_curves(vertsout2,coordsout2, 01493 &surfindex2,&curveindex2,2); 01494 unsigned int k; 01495 for ( k = 0; k < vertsout1.size(); k += 3 ) { 01496 new_point = (CubitPoint *) new CubitPointData( vertsout1[k], 01497 vertsout1[k+1], 01498 vertsout1[k+2] ); 01499 points.push_back(new_point); 01500 } 01501 for ( k = 0; k < coordsout1.size(); k += 3 ) { 01502 facet_ptr = new CubitFacetData( points[coordsout1[k]], 01503 points[coordsout1[k+1]], 01504 points[coordsout1[k+2]] ); 01505 int cptr[3]; 01506 cptr[0] = curveindex1[k]; 01507 cptr[1] = curveindex1[k+1]; 01508 cptr[2] = curveindex1[k+2]; 01509 TDFacetboolData::add_facetbool_facet( facet_ptr ); 01510 TDFacetboolData* td = TDFacetboolData::get(facet_ptr); 01511 td->set(surfindex1[k/3],cptr[0],cptr[1],cptr[2],false, 01512 facet_ptr->is_backwards()); 01513 01514 facet_list.append( facet_ptr ); 01515 } 01516 points.clear(); // clear out the points vector since we are through with it. 01517 01518 double feature_angle; 01519 int interp_order; 01520 CubitBoolean smooth_non_manifold, split_surfaces; 01521 feature_angle = 135.0; 01522 interp_order = 0; 01523 smooth_non_manifold = CUBIT_TRUE; 01524 split_surfaces = CUBIT_FALSE; 01525 01526 { 01527 ChollaEngine *cholla_ptr = NULL; 01528 01529 status = fme->build_cholla_surfaces( facet_list, 01530 point_list, 01531 feature_angle, 01532 interp_order, 01533 smooth_non_manifold, 01534 split_surfaces, 01535 cholla_ptr ); 01536 if( status == CUBIT_FAILURE ) 01537 return status; 01538 01539 status = fme->finish_facet_Body( cholla_ptr, 01540 NULL, 01541 feature_angle, interp_order, 01542 body_out1); 01543 if( status == CUBIT_FAILURE ) 01544 return status; 01545 if ( cholla_ptr ) 01546 { 01547 cholla_ptr->delete_me(); 01548 delete cholla_ptr; 01549 } 01550 } 01551 vertsout1.clear(); 01552 coordsout1.clear(); 01553 01554 facet_list.clean_out(); 01555 for ( k = 0; k < vertsout2.size(); k += 3 ) { 01556 new_point = (CubitPoint *) new CubitPointData( vertsout2[k], 01557 vertsout2[k+1], 01558 vertsout2[k+2] ); 01559 points.push_back(new_point); 01560 } 01561 for ( k = 0; k < coordsout2.size(); k += 3 ) { 01562 facet_ptr = new CubitFacetData( points[coordsout2[k]], 01563 points[coordsout2[k+1]], 01564 points[coordsout2[k+2]] ); 01565 int cptr[3]; 01566 cptr[0] = curveindex2[k]; 01567 cptr[1] = curveindex2[k+1]; 01568 cptr[2] = curveindex2[k+2]; 01569 TDFacetboolData::add_facetbool_facet( facet_ptr ); 01570 TDFacetboolData* td = TDFacetboolData::get(facet_ptr); 01571 td->set(surfindex2[k/3],cptr[0],cptr[1],cptr[2],false, 01572 facet_ptr->is_backwards()); 01573 facet_list.append( facet_ptr ); 01574 } 01575 points.clear(); // clear out the points vector since we are through with it. 01576 01577 { 01578 ChollaEngine *cholla_ptr = NULL; 01579 01580 status = fme->build_cholla_surfaces( facet_list, 01581 point_list, 01582 feature_angle, 01583 interp_order, 01584 smooth_non_manifold, 01585 split_surfaces, 01586 cholla_ptr ); 01587 if( status == CUBIT_FAILURE ) 01588 return status; 01589 01590 status = fme->finish_facet_Body( cholla_ptr, 01591 NULL, 01592 feature_angle, interp_order, 01593 body_out2); 01594 if( status == CUBIT_FAILURE ) 01595 return status; 01596 if ( cholla_ptr ) 01597 { 01598 cholla_ptr->delete_me(); 01599 delete cholla_ptr; 01600 } 01601 } 01602 01603 if ( keep_old == false ) { 01604 make_persistents_imprint(body_in1,body_out1,fsurfarray1,fcurvearray1); 01605 make_persistents_imprint(body_in2,body_out2,fsurfarray2,fcurvearray2); 01606 } 01607 01608 //separate the lumps in the "body_out1" and "body_out2", these will 01609 //be converted to separate volumes later in the code. 01610 status=separate_lumps(body_out1, is_sheet_body); 01611 status=separate_lumps(body_out2, is_sheet_body); 01612 vertsout2.clear(); 01613 coordsout2.clear(); 01614 01615 return status; 01616 } 01617 01618 CubitStatus FacetboolInterface::make_FB_edge_list(DLIList<Curve*> &ref_edge_list) 01619 { 01620 CubitStatus success = CUBIT_SUCCESS; 01621 Curve *ref_edge_ptr; 01622 FacetCurve *cfcurve; 01623 CubitPoint *cfpoint; 01624 DLIList<CubitPoint *> cfpointlist; 01625 int i, j, lastvert, nextvert; 01626 CubitVector coords; 01627 01628 ref_edge_list.reset(); 01629 for( i = ref_edge_list.size(); i > 0; i-- ) 01630 { 01631 ref_edge_ptr = ref_edge_list.get_and_step(); 01632 cfcurve = CAST_TO( ref_edge_ptr, FacetCurve); 01633 cfpointlist.clean_out(); 01634 cfcurve->get_points(cfpointlist); 01635 cfpoint = cfpointlist.get_and_step(); 01636 coords = cfpoint->coordinates(); 01637 lastvert = find_coord(coords.x(),coords.y(),coords.z()); 01638 for ( j = cfpointlist.size()-1; j > 0; j-- ) { 01639 cfpoint = cfpointlist.get_and_step(); 01640 coords = cfpoint->coordinates(); 01641 nextvert = find_coord(coords.x(),coords.y(),coords.z()); 01642 01643 FB_Edge *FBedge = new FB_Edge(lastvert,nextvert,0,0,false); 01644 FSBoundingBox *bb = make_edge_bounding_box(lastvert,nextvert); 01645 lastvert = nextvert; 01646 FB_imprint_edges.push_back(FBedge); 01647 FB_imprint_edge_bboxes.push_back(bb); 01648 } 01649 } 01650 01651 return success; 01652 } 01653 01654 int FacetboolInterface::find_coord(double xx, double yy, double zz) 01655 { 01656 int value; 01657 unsigned int i; 01658 01659 value = -1; 01660 for ( i = 0; i < FB_imprint_edge_coords.size(); i++ ) { 01661 if ( (fabs(FB_imprint_edge_coords[i]->coord[0] - xx) < GEOMETRY_RESABS) && 01662 (fabs(FB_imprint_edge_coords[i]->coord[1] - yy) < GEOMETRY_RESABS) && 01663 (fabs(FB_imprint_edge_coords[i]->coord[2] - zz) < GEOMETRY_RESABS) ) { 01664 value = (int)i; 01665 break; 01666 } 01667 } 01668 if ( value == -1 ) { 01669 value = FB_imprint_edge_coords.size(); 01670 FB_Coord *FBcoord = new FB_Coord(xx,yy,zz); 01671 FB_imprint_edge_coords.push_back(FBcoord); 01672 } 01673 01674 return value; 01675 } 01676 01677 FSBoundingBox* FacetboolInterface::make_edge_bounding_box(int v0, int v1) 01678 { 01679 FSBoundingBox *bb; 01680 double xmin, ymin, zmin, xmax, ymax, zmax; 01681 01682 01683 xmin = ( FB_imprint_edge_coords[v0]->coord[0] < FB_imprint_edge_coords[v1]->coord[0] ) ? 01684 FB_imprint_edge_coords[v0]->coord[0] : FB_imprint_edge_coords[v1]->coord[0]; 01685 ymin = ( FB_imprint_edge_coords[v0]->coord[1] < FB_imprint_edge_coords[v1]->coord[1] ) ? 01686 FB_imprint_edge_coords[v0]->coord[1] : FB_imprint_edge_coords[v1]->coord[1]; 01687 zmin = ( FB_imprint_edge_coords[v0]->coord[2] < FB_imprint_edge_coords[v1]->coord[2] ) ? 01688 FB_imprint_edge_coords[v0]->coord[2] : FB_imprint_edge_coords[v1]->coord[2]; 01689 xmax = ( FB_imprint_edge_coords[v0]->coord[0] > FB_imprint_edge_coords[v1]->coord[0] ) ? 01690 FB_imprint_edge_coords[v0]->coord[0] : FB_imprint_edge_coords[v1]->coord[0]; 01691 ymax = ( FB_imprint_edge_coords[v0]->coord[1] > FB_imprint_edge_coords[v1]->coord[1] ) ? 01692 FB_imprint_edge_coords[v0]->coord[1] : FB_imprint_edge_coords[v1]->coord[1]; 01693 zmax = ( FB_imprint_edge_coords[v0]->coord[2] > FB_imprint_edge_coords[v1]->coord[2] ) ? 01694 FB_imprint_edge_coords[v0]->coord[2] : FB_imprint_edge_coords[v1]->coord[2]; 01695 if ( (xmax - xmin) < 2.0*GEOMETRY_RESABS ) { 01696 xmin -= GEOMETRY_RESABS; 01697 xmax += GEOMETRY_RESABS; 01698 } 01699 if ( (ymax - ymin) < 2.0*GEOMETRY_RESABS ) { 01700 ymin -= GEOMETRY_RESABS; 01701 ymax += GEOMETRY_RESABS; 01702 } 01703 if ( (zmax - zmin) < 2.0*GEOMETRY_RESABS ) { 01704 zmin -= GEOMETRY_RESABS; 01705 zmax += GEOMETRY_RESABS; 01706 } 01707 01708 bb = new FSBoundingBox(xmin, ymin, zmin, xmax, ymax, zmax); 01709 01710 return bb; 01711 01712 } 01713 01714 void FacetboolInterface::get_edge_list_bbox(CubitBox& edge_list_bbox) 01715 { 01716 unsigned int i; 01717 double min[3],max[3]; 01718 01719 min[0] = min[1] = min[2] = CUBIT_DBL_MAX - 1.0; 01720 max[0] = max[1] = max[2] = -CUBIT_DBL_MAX; 01721 01722 for ( i = 0; i < FB_imprint_edge_coords.size(); i++ ) { 01723 min[0] = ( min[0] < FB_imprint_edge_coords[i]->coord[0] ) ? min[0] : 01724 FB_imprint_edge_coords[i]->coord[0]; 01725 min[1] = ( min[1] < FB_imprint_edge_coords[i]->coord[1] ) ? min[1] : 01726 FB_imprint_edge_coords[i]->coord[1]; 01727 min[2] = ( min[2] < FB_imprint_edge_coords[i]->coord[2] ) ? min[2] : 01728 FB_imprint_edge_coords[i]->coord[2]; 01729 max[0] = ( max[0] > FB_imprint_edge_coords[i]->coord[0] ) ? max[0] : 01730 FB_imprint_edge_coords[i]->coord[0]; 01731 max[1] = ( max[1] > FB_imprint_edge_coords[i]->coord[1] ) ? max[1] : 01732 FB_imprint_edge_coords[i]->coord[1]; 01733 max[2] = ( max[2] > FB_imprint_edge_coords[i]->coord[2] ) ? max[2] : 01734 FB_imprint_edge_coords[i]->coord[2]; 01735 } 01736 if ( (max[0] - min[0]) < 2.0*GEOMETRY_RESABS ) { 01737 min[0] -= GEOMETRY_RESABS; 01738 max[0] += GEOMETRY_RESABS; 01739 } 01740 if ( (max[1] - min[1]) < 2.0*GEOMETRY_RESABS ) { 01741 min[1] -= GEOMETRY_RESABS; 01742 max[1] += GEOMETRY_RESABS; 01743 } 01744 if ( (max[2] - min[2]) < 2.0*GEOMETRY_RESABS ) { 01745 min[2] -= GEOMETRY_RESABS; 01746 max[2] += GEOMETRY_RESABS; 01747 } 01748 CubitBox box(min,max); 01749 edge_list_bbox = box; 01750 01751 } 01752 01753 01754
