cgma
00001 #include <iostream> 00002 #include <fstream> 00003 #include <string> 00004 00005 #include "InitCGMA.hpp" 00006 #include "GeometryModifyTool.hpp" 00007 #include "GeometryQueryTool.hpp" 00008 #include "Body.hpp" 00009 #include "CGMApp.hpp" 00010 #include "CubitAttribManager.hpp" 00011 #include "CAEntityId.hpp" 00012 #include "CubitCompat.hpp" 00013 00014 #include <stdio.h> 00015 #include <stdlib.h> 00016 00017 #if defined (TEST_OCC) 00018 # define ENGINE "OCC" 00019 # define FORMAT "OCC" 00020 #elif defined (TEST_FACET) 00021 # define ENGINE "FACET" 00022 # define FORMAT "FACET" 00023 #else 00024 # error "Which engine to test?" 00025 #endif 00026 00027 #define ASSERT(A) if (!(A)) failed(#A,__FILE__,__LINE__) 00028 CubitBoolean is_files_same(std::string filename1, 00029 std::string filename2); 00030 00031 void failed( const char* A, const char* FILE, int LINE ) 00032 { 00033 printf( "Condition failed at %s:%d : %s\n", FILE, LINE, A ); 00034 abort(); 00035 } 00036 00037 int main() 00038 { 00039 CubitStatus s = InitCGMA::initialize_cgma( ENGINE ); 00040 ASSERT(s); 00041 00042 // actuate CA_BODIES attribute and turn on auto flag 00043 CGMApp::instance()->attrib_manager()->register_attrib_type(CA_ENTITY_ID, "id", "ENTITY_ID", 00044 CAEntityId_creator, CUBIT_TRUE, 00045 CUBIT_TRUE, CUBIT_TRUE, CUBIT_TRUE, 00046 CUBIT_TRUE, CUBIT_FALSE); 00047 CGMApp::instance()->attrib_manager()->auto_flag(CUBIT_TRUE); 00048 00049 // make 2 bricks 00050 int n = 2; 00051 Body** bricks = new Body*[n]; 00052 DLIList<RefEntity*> export_list; 00053 for (int i = 0; i < n; i++) { 00054 bricks[i] = GeometryModifyTool::instance()->brick( 1, 1, 1 ); 00055 ASSERT(bricks[i]); 00056 DLIList<Body*> bods; 00057 bods.append(bricks[i]); 00058 s = GeometryQueryTool::instance()->translate( bods, CubitVector(i,0,0) ); 00059 ASSERT(s); 00060 export_list.append( bricks[i] ); 00061 } 00062 00063 // export as file 00064 // int junk; 00065 const char * filename = "bricks2.occ"; 00066 const CubitString cubit_version="13.1"; 00067 const char * filetype = "OCC"; 00068 int num_ents_exported=0; 00069 s = CubitCompat_export_solid_model( export_list, filename, filetype, 00070 num_ents_exported, cubit_version); 00071 ASSERT(s); 00072 00073 //check that the two single volume bodys' attributes are exported as SINGLELUMP% 00074 std::ifstream Myfile; 00075 std::string line; 00076 std::string search = "SINGLELUMP%"; 00077 Myfile.open ("bricks2.occ"); 00078 int found = 0; 00079 size_t offset; 00080 if(Myfile.is_open()) 00081 { 00082 while(!Myfile.eof()) 00083 { 00084 getline(Myfile,line); 00085 if ((offset = line.find(search, 0)) != std::string::npos) 00086 found ++; 00087 } 00088 Myfile.close(); 00089 } 00090 00091 assert (found == 2); 00092 00093 filename = "bricks22.occ"; 00094 num_ents_exported = 0; 00095 s = CubitCompat_export_solid_model( export_list, filename, filetype, 00096 num_ents_exported, cubit_version); 00097 ASSERT(s); 00098 00099 //check that the two single volume bodys' attributes are exported as SINGLELUMP% 00100 Myfile.open ("bricks22.occ"); 00101 found = 0; 00102 if(Myfile.is_open()) 00103 { 00104 while(!Myfile.eof()) 00105 { 00106 getline(Myfile,line); 00107 if ((offset = line.find(search, 0)) != std::string::npos) 00108 found ++; 00109 } 00110 Myfile.close(); 00111 } 00112 00113 assert (found == 2); 00114 00115 // delete geometry 00116 GeometryQueryTool::instance()->delete_geometry(); 00117 remove(filename); 00118 00119 // import it again 00120 DLIList<RefEntity*> import_list; 00121 filename = "bricks2.occ"; 00122 s = CubitCompat_import_solid_model( filename, filetype); 00123 ASSERT(s); 00124 00125 // check imported entity has tool data actuated by attributes 00126 DLIList<RefEntity*> body_entity_list; 00127 s = GeometryQueryTool::instance()->ref_entity_list("body", body_entity_list, CUBIT_FALSE); 00128 body_entity_list.reset(); 00129 assert ((int)body_entity_list.size() == 2); 00130 00131 export_list.clean_out(); 00132 export_list.append(CAST_TO(body_entity_list.get_and_step(), Body)); 00133 export_list.append(CAST_TO(body_entity_list.get_and_step(), Body)); 00134 const char * filename2 = "bricks23.occ"; 00135 s = CubitCompat_export_solid_model( export_list, filename2, filetype, 00136 num_ents_exported, cubit_version); 00137 ASSERT(s); 00138 00139 ASSERT(is_files_same("bricks2.occ", "bricks23.occ")); 00140 remove(filename); 00141 remove(filename2); 00142 return 0; 00143 } 00144 00145 CubitBoolean is_files_same(std::string filename1, 00146 std::string filename2) 00147 { 00148 FILE *fp1, *fp2; 00149 char ch1, ch2; 00150 CubitBoolean same = false; 00151 /* open first file */ 00152 const char* file1 = filename1.c_str(); 00153 const char* file2 = filename2.c_str(); 00154 if((fp1 = fopen(file1, "rb"))==NULL) { 00155 printf("Cannot open first file.\n"); 00156 exit(false); 00157 } 00158 00159 /* open second file */ 00160 if((fp2 = fopen(file2, "rb"))==NULL) { 00161 printf("Cannot open second file.\n"); 00162 exit(false); 00163 } 00164 00165 /* compare the files */ 00166 while(!feof(fp1)) { 00167 ch1 = fgetc(fp1); 00168 if(ferror(fp1)) { 00169 printf("Error reading first file.\n"); 00170 exit(false); 00171 } 00172 ch2 = fgetc(fp2); 00173 if(ferror(fp2)) { 00174 printf("Error reading second file.\n"); 00175 exit(false); 00176 } 00177 if(ch1 != ch2) { 00178 return same; 00179 } 00180 } 00181 00182 if(fclose( fp1 ) == EOF) { 00183 printf("Error closing first file.\n"); 00184 exit(false); 00185 } 00186 00187 if(fclose( fp2 ) == EOF) { 00188 printf("Error closing second file.\n"); 00189 exit(false); 00190 } 00191 return true; 00192 } 00193
