MeshKit
1.0
00001 // ******************************************************************** 00002 // Patrick Shriwise 00003 // August 2013 00004 /* _curve_to_be_tested_for_watertightness_ 00005 vert1 X X vert1 00006 | | 00007 vert2 X | 00008 surf1 | | surf2 00009 | | 00010 vert3 X X vert2 00011 | | 00012 vert4 X X vert3 */ 00013 00014 // input: h5m filename, tolerance 00015 // output: watertight h5m 00016 00017 // make CXXFLAGS=-g for debug 00018 // make CXXFLAGS=-pg for profiling 00019 00020 #include <iostream> 00021 #include <sstream> 00022 #include <iomanip> // for setprecision 00023 #include <limits> // for min/max values 00024 #include <assert.h> 00025 #include <math.h> 00026 #include <time.h> 00027 #include <vector> 00028 00029 #include "moab/Core.hpp" 00030 #include "TagConventions.hpp" 00031 #include "moab/Range.hpp" 00032 #include "moab/Skinner.hpp" 00033 #include "moab/GeomTopoTool.hpp" 00034 00035 #include "meshkit/gen.hpp" 00036 #include "meshkit/arc.hpp" 00037 #include "meshkit/zip.hpp" 00038 #include "meshkit/cleanup.hpp" 00039 00040 00041 00042 const char GEOM_SENSE_2_TAG_NAME[] = "GEOM_SENSE_2"; 00043 const char GEOM_SENSE_N_ENTS_TAG_NAME[] = "GEOM_SENSE_N_ENTS"; 00044 const char GEOM_SENSE_N_SENSES_TAG_NAME[] = "GEOM_SENSE_N_SENSES"; 00045 00046 00047 using namespace moab; 00048 Interface *MBI(); 00049 00050 char* sense_printer( int sense){ 00051 00052 if ( sense == 1 ) return "FORWARD (1)"; 00053 if ( sense == -1 ) return "REVERSE (-1)"; 00054 if ( sense == 0 ) return "UNKNOWN (0)"; 00055 } 00056 00057 void moab_printer(ErrorCode error_code) 00058 { 00059 if ( error_code == MB_INDEX_OUT_OF_RANGE ) 00060 { 00061 std::cerr << "ERROR: MB_INDEX_OUT_OF_RANGE" << std::endl; 00062 } 00063 if ( error_code == MB_MEMORY_ALLOCATION_FAILED ) 00064 { 00065 std::cerr << "ERROR: MB_MEMORY_ALLOCATION_FAILED" << std::endl; 00066 } 00067 if ( error_code == MB_ENTITY_NOT_FOUND ) 00068 { 00069 std::cerr << "ERROR: MB_ENTITY_NOT_FOUND" << std::endl; 00070 } 00071 if ( error_code == MB_MULTIPLE_ENTITIES_FOUND ) 00072 { 00073 std::cerr << "ERROR: MB_MULTIPLE_ENTITIES_FOUND" << std::endl; 00074 } 00075 if ( error_code == MB_TAG_NOT_FOUND ) 00076 { 00077 std::cerr << "ERROR: MB_TAG_NOT_FOUND" << std::endl; 00078 } 00079 if ( error_code == MB_FILE_DOES_NOT_EXIST ) 00080 { 00081 std::cerr << "ERROR: MB_FILE_DOES_NOT_EXIST" << std::endl; 00082 } 00083 if ( error_code == MB_FILE_WRITE_ERROR ) 00084 { 00085 std::cerr << "ERROR: MB_FILE_WRITE_ERROR" << std::endl; 00086 } 00087 if ( error_code == MB_ALREADY_ALLOCATED ) 00088 { 00089 std::cerr << "ERROR: MB_ALREADY_ALLOCATED" << std::endl; 00090 } 00091 if ( error_code == MB_VARIABLE_DATA_LENGTH ) 00092 { 00093 std::cerr << "ERROR: MB_VARIABLE_DATA_LENGTH" << std::endl; 00094 } 00095 if ( error_code == MB_INVALID_SIZE ) 00096 { 00097 std::cerr << "ERROR: MB_INVALID_SIZE" << std::endl; 00098 } 00099 if ( error_code == MB_UNSUPPORTED_OPERATION ) 00100 { 00101 std::cerr << "ERROR: MB_UNSUPPORTED_OPERATION" << std::endl; 00102 } 00103 if ( error_code == MB_UNHANDLED_OPTION ) 00104 { 00105 std::cerr << "ERROR: MB_UNHANDLED_OPTION" << std::endl; 00106 } 00107 if ( error_code == MB_FAILURE ) 00108 { 00109 std::cerr << "ERROR: MB_FAILURE" << std::endl; 00110 } 00111 return; 00112 } 00113 00114 00115 ErrorCode get_geom_size_before_sealing( const Range geom_sets[], 00116 const Tag geom_tag, 00117 const Tag size_tag, 00118 bool verbose ) { 00119 ErrorCode rval; 00120 for(int dim=1; dim <= 3 ; dim++) { 00121 std::cout << "dim = " << dim << std::endl; 00122 for(Range::iterator i=geom_sets[dim].begin(); i!=geom_sets[dim].end(); i++) { 00123 double size = 0; 00124 //std::cout << "*i =" << *i << std::endl; 00125 //std::cout << "geom_tag =" << geom_tag << std::endl; 00126 //std::cout << "size =" << size << std::endl; 00127 00128 00129 rval = gen::measure( *i, geom_tag, size, false, verbose ); 00130 if(gen::error(MB_SUCCESS!=rval,"could not measure")) return rval; 00131 rval = MBI()->tag_set_data( size_tag, &(*i), 1, &size ); 00132 if(gen::error(MB_SUCCESS!=rval,"could not set size tag")) return rval; 00133 00134 //std::cout << "*i =" << *i << std::endl; 00135 //std::cout << "geom_tag =" << geom_tag << std::endl; 00136 //std::cout << "size =" << size << std::endl; 00137 00138 } 00139 } 00140 return MB_SUCCESS; 00141 } 00142 00143 ErrorCode get_senses(EntityHandle entity, 00144 std::vector<EntityHandle> &wrt_entities, std::vector<int> &senses) 00145 { 00146 // 00147 // the question here is: the wrt_entities is supplied or not? 00148 // I assume not, we will obtain it !! 00149 int edim = 1; 00150 00151 if (-1 == edim) 00152 return MB_FAILURE;// not geometry entity 00153 00154 ErrorCode rval; 00155 wrt_entities.clear(); 00156 senses.clear(); 00157 00158 if (1 == edim)// edge 00159 { 00160 00161 const void *dum_ptr; 00162 int num_ents; 00163 unsigned flags = MB_TAG_SPARSE; 00164 00165 Tag senseNEntsTag; 00166 rval = MBI() -> tag_get_handle(GEOM_SENSE_N_ENTS_TAG_NAME, 0 , MB_TYPE_HANDLE, senseNEntsTag, flags); 00167 if (gen::error(MB_SUCCESS!=rval, "could not get ent sense handles")) return rval; 00168 rval = MBI()->tag_get_by_ptr(senseNEntsTag, &entity, 1, &dum_ptr, &num_ents); 00169 if (gen::error(MB_SUCCESS!=rval, "could not get ent sense data")) return rval; 00170 const EntityHandle *ents_data = static_cast<const EntityHandle*> (dum_ptr); 00171 std::copy(ents_data, ents_data + num_ents, std::back_inserter(wrt_entities)); 00172 00173 Tag senseNSensesTag; 00174 rval = MBI()->tag_get_handle(GEOM_SENSE_N_SENSES_TAG_NAME, 0 , MB_TYPE_INTEGER, senseNSensesTag, flags); 00175 if (gen::error(MB_SUCCESS!=rval, "could not get senses handle")) return rval; 00176 rval = MBI()->tag_get_by_ptr(senseNSensesTag, &entity, 1, &dum_ptr, 00177 &num_ents); 00178 if (gen::error(MB_SUCCESS!=rval, "could not get senses data")) return rval; 00179 00180 const int *senses_data = static_cast<const int*> (dum_ptr); 00181 std::copy(senses_data, senses_data + num_ents, std::back_inserter(senses)); 00182 00183 }/* else // face in volume, edim == 2 00184 { 00185 00186 EntityHandle sense_data[2] = { 0, 0 }; 00187 rval = MBI()->tag_get_data(GEOM_SENSE_2_TAG_NAME, &entity, 1, sense_data); 00188 if (MB_SUCCESS != rval) 00189 return rval; 00190 if (sense_data[0] != 0 && sense_data[1] == sense_data[0]) { 00191 wrt_entities.push_back(sense_data[0]); 00192 senses.push_back(0);// both 00193 } else { 00194 if (sense_data[0] != 0) { 00195 wrt_entities.push_back(sense_data[0]); 00196 senses.push_back(1); 00197 } 00198 if (sense_data[1] != 0) { 00199 wrt_entities.push_back(sense_data[1]); 00200 senses.push_back(-1); 00201 } 00202 00203 } 00204 00205 } 00206 */ 00207 // filter the results with the sets that are in the model at this time 00208 // this was introduced because extracting some sets (e.g. neumann set, with mbconvert) 00209 // from a model would leave some sense tags not defined correctly 00210 // also, the geom ent set really needs to be part of the current model set 00211 /* 00212 unsigned int currentSize =0; 00213 00214 for (unsigned int index=0; index<wrt_entities.size(); index++) 00215 { 00216 EntityHandle wrt_ent=wrt_entities[index]; 00217 if (wrt_ent ) 00218 { 00219 if (MBI()->contains_entities(modelSet, &wrt_ent, 1)) 00220 { 00221 wrt_entities[currentSize] = wrt_entities[index]; 00222 senses[currentSize] = senses[index]; 00223 currentSize++; 00224 } 00225 } 00226 } 00227 wrt_entities.resize(currentSize); 00228 senses.resize(currentSize); 00229 // 00230 */ 00231 return MB_SUCCESS; 00232 } 00233 int main(int argc, char **argv) { 00234 00235 // ****************************************************************** 00236 // Load the h5m file and create tags. 00237 // ****************************************************************** 00238 00239 clock_t start_time = clock(); 00240 const bool debug = false; 00241 const bool check_geom_size = true; 00242 bool verbose = true; 00243 00244 // check input args 00245 if( 2 > argc || 3 < argc ) 00246 { 00247 std::cout << "To zip a faceted h5m file:" << std::endl; 00248 std::cout << "$ ./make_watertight <input_file.h5m>" << std::endl; 00249 std::cout << "To facet and zip an ACIS file using the default facet tolerance:" << std::endl; 00250 std::cout << "$ ./make_watertight <input_file.sat>" << std::endl; 00251 std::cout << "To facet and zip an ACIS file using a specified facet tolerance:" << std::endl; 00252 std::cout << "$ ./make_watertight <input_file.sat> <facet_tolerance>" << std::endl; 00253 return MB_FAILURE; 00254 } 00255 00256 // The root name does not have an extension 00257 std::string input_name = argv[1]; 00258 std::string root_name = argv[1]; 00259 int len = root_name.length(); 00260 root_name.erase(len - 4); 00261 bool is_acis; 00262 00263 // load the input file 00264 ErrorCode result, rval; 00265 EntityHandle input_set; 00266 00267 rval = MBI()->create_meshset( MESHSET_SET, input_set ); 00268 00269 if(gen::error(MB_SUCCESS!=rval,"failed to create_meshset")) 00270 { 00271 return rval; 00272 } 00273 00274 std::cout << "Loading input file..." << std::endl; 00275 00276 // If reading an h5m file, the facet tolerance has already been determined. 00277 // Read the facet_tol from the file_set. There should only be one input 00278 // argument. 00279 00280 if(std::string::npos!=input_name.find("h5m") && (2==argc)) 00281 { 00282 rval = MBI()->load_file( input_name.c_str(), &input_set ); 00283 if(gen::error(MB_SUCCESS!=rval,"failed to load_file 0")) 00284 { 00285 return rval; 00286 } 00287 00288 is_acis = false; 00289 00290 // If reading a sat file, the facet toleance will default to 1e-3 if it is 00291 // not specified. If the user does not specify a facet_tol, default to 1e-3. 00292 // This is the same as what ReadCGM uses. 00293 } 00294 00295 /* 00296 // recreate to only perform these operations on h5m meshes 00297 else if(std::string::npos!=input_name.find("sat") && 00298 ((2==argc) || (3==argc)) ) 00299 { 00300 double facet_tol; 00301 if(3 == argc) 00302 { 00303 facet_tol = atof(argv[2]); 00304 } 00305 else 00306 { 00307 facet_tol = 1e-3; 00308 } 00309 00310 std::string options; 00311 options += "FACET_DISTANCE_TOLERANCE="; 00312 std::stringstream facet_tol_ss; 00313 facet_tol_ss << facet_tol; 00314 options += facet_tol_ss.str(); 00315 if(debug) std::cout << " options=" << options << std::endl; 00316 rval = MBI()->load_file( input_name.c_str(), &input_set, options.c_str() ); 00317 if(gen::error(MB_SUCCESS!=rval,"failed to load_file 1")) return rval; 00318 00319 // write an HDF5 file of facets with known tolerance 00320 std::string facet_tol_filename = root_name + "_" + facet_tol_ss.str() + ".h5m"; 00321 rval = MBI()->write_mesh( facet_tol_filename.c_str() ); 00322 if(gen::error(MB_SUCCESS!=rval,"failed to write_mesh 0")) return rval; 00323 is_acis = true; 00324 } 00325 else 00326 { 00327 std::cout << "incorrect input arguments" << std::endl; 00328 return MB_FAILURE; 00329 } 00330 //not required if only doing this with h5m files 00331 */ 00332 00333 // create tags 00334 clock_t load_time = clock(); 00335 Tag geom_tag, id_tag, normal_tag, merge_tag, faceting_tol_tag, 00336 geometry_resabs_tag, size_tag, orig_curve_tag; 00337 00338 result = MBI()->tag_get_handle( GEOM_DIMENSION_TAG_NAME, 1, 00339 MB_TYPE_INTEGER, geom_tag, MB_TAG_DENSE|MB_TAG_CREAT ); 00340 assert( MB_SUCCESS == result ); 00341 if ( result != MB_SUCCESS ) 00342 { 00343 moab_printer(result); 00344 } 00345 result = MBI()->tag_get_handle( GLOBAL_ID_TAG_NAME, 1, 00346 MB_TYPE_INTEGER, id_tag, MB_TAG_DENSE|MB_TAG_CREAT); 00347 assert( MB_SUCCESS == result ); 00348 if ( result != MB_SUCCESS ) 00349 { 00350 moab_printer(result); 00351 } 00352 result = MBI()->tag_get_handle( "NORMAL", sizeof(MBCartVect), MB_TYPE_OPAQUE, 00353 normal_tag, MB_TAG_DENSE|MB_TAG_CREAT); 00354 assert( MB_SUCCESS == result ); 00355 if ( result != MB_SUCCESS ) 00356 { 00357 moab_printer(result); 00358 } 00359 result = MBI()->tag_get_handle( "MERGE", 1, MB_TYPE_HANDLE, 00360 merge_tag, MB_TAG_SPARSE|MB_TAG_CREAT ); 00361 assert( MB_SUCCESS == result ); 00362 if ( result != MB_SUCCESS ) 00363 { 00364 moab_printer(result); 00365 } 00366 result = MBI()->tag_get_handle( "FACETING_TOL", 1, MB_TYPE_DOUBLE, 00367 faceting_tol_tag , MB_TAG_SPARSE|MB_TAG_CREAT ); 00368 assert( MB_SUCCESS == result ); 00369 if ( result != MB_SUCCESS ) 00370 { 00371 moab_printer(result); 00372 } 00373 result = MBI()->tag_get_handle( "GEOMETRY_RESABS", 1, MB_TYPE_DOUBLE, 00374 geometry_resabs_tag, MB_TAG_SPARSE|MB_TAG_CREAT ); 00375 assert( MB_SUCCESS == result ); 00376 if ( result != MB_SUCCESS ) 00377 { 00378 moab_printer(result); 00379 } 00380 result = MBI()->tag_get_handle( "GEOM_SIZE", 1, MB_TYPE_DOUBLE, 00381 size_tag, MB_TAG_DENSE|MB_TAG_CREAT ); 00382 assert( (MB_SUCCESS == result) ); 00383 if ( result != MB_SUCCESS ) 00384 { 00385 moab_printer(result); 00386 } 00387 int true_int = 1; 00388 result = MBI()->tag_get_handle( "ORIG_CURVE", 1, 00389 MB_TYPE_INTEGER, orig_curve_tag, MB_TAG_DENSE|MB_TAG_CREAT, &true_int ); 00390 assert( MB_SUCCESS == result ); 00391 if ( result != MB_SUCCESS ) 00392 { 00393 moab_printer(result); 00394 } 00395 // PROBLEM: MOAB is not consistent with file_set behavior. The tag may not be 00396 // on the file_set. 00397 Range file_set; 00398 result = MBI()->get_entities_by_type_and_tag( 0, MBENTITYSET, &faceting_tol_tag, 00399 NULL, 1, file_set ); 00400 00401 if(gen::error(MB_SUCCESS!=result,"could not get faceting_tol_tag")) 00402 { 00403 return result; 00404 } 00405 00406 gen::error(file_set.empty(),"file set not found"); 00407 00408 if(gen::error(1!=file_set.size(),"Refacet with newer version of ReadCGM.")) 00409 { 00410 return MB_FAILURE; 00411 } 00412 00413 double facet_tol, sme_resabs_tol=1e-6; 00414 result = MBI()->tag_get_data( faceting_tol_tag, &file_set.front(), 1, 00415 &facet_tol ); 00416 assert(MB_SUCCESS == result); 00417 result = MBI()->tag_get_data( geometry_resabs_tag, &file_set.front(), 1, 00418 &sme_resabs_tol ); 00419 if(MB_SUCCESS != result) 00420 { 00421 std::cout << "absolute tolerance could not be read from file" << std::endl; 00422 } 00423 00424 // In practice, use 2*facet_tol because we are always comparing 2 faceted 00425 // entities. If instead we were comparing a faceted entity and a geometric 00426 // entitiy, then 1*facet_tol is correct. 00427 00428 const double SME_RESABS_TOL = sme_resabs_tol; // from ACIS through CGM 00429 const double FACET_TOL = facet_tol; // specified by user when faceting cad 00430 std::cout << " faceting tolerance=" << facet_tol << " cm" << std::endl; 00431 std::cout << " absolute tolerance=" << sme_resabs_tol << " cm" << std::endl; 00432 00433 // get all geometry sets 00434 00435 00436 // get all geometry sets 00437 Range geom_sets[4]; 00438 for(unsigned dim=0; dim<4; dim++) 00439 { 00440 void *val[] = {&dim}; 00441 result = MBI()->get_entities_by_type_and_tag( 0, MBENTITYSET, &geom_tag, 00442 val, 1, geom_sets[dim] ); 00443 std::cout << "Get entities by type and tag" << std::endl; 00444 00445 assert(MB_SUCCESS == result); 00446 00447 // make sure that sets TRACK membership and curves are ordered 00448 // MESHSET_TRACK_OWNER=0x1, MESHSET_SET=0x2, MESHSET_ORDERED=0x4 00449 for(Range::iterator i=geom_sets[dim].begin(); i!=geom_sets[dim].end(); i++) 00450 { 00451 unsigned int options; 00452 result = MBI()->get_meshset_options(*i, options ); 00453 assert(MB_SUCCESS == result); 00454 00455 // if options are wrong change them 00456 if(dim==1) 00457 { 00458 if( !(MESHSET_TRACK_OWNER&options) || !(MESHSET_ORDERED&options) ) 00459 { 00460 result = MBI()->set_meshset_options(*i, MESHSET_TRACK_OWNER|MESHSET_ORDERED); 00461 assert(MB_SUCCESS == result); 00462 } 00463 } 00464 else 00465 { 00466 if( !(MESHSET_TRACK_OWNER&options) ) 00467 { 00468 result = MBI()->set_meshset_options(*i, MESHSET_TRACK_OWNER); 00469 assert(MB_SUCCESS == result); 00470 } 00471 } 00472 } 00473 } 00474 00475 std::cout << "I am here" << std::endl; 00476 00477 // this could be related to when there are sat files rather than mesh? 00478 // If desired, find each entity's size before sealing. 00480 if(check_geom_size) 00481 { 00482 std::cout << "I am checking the geometry size" << std::endl; 00483 result = get_geom_size_before_sealing( geom_sets, geom_tag, size_tag, verbose ); 00484 if(gen::error(MB_SUCCESS!=result,"measuring geom size failed")) 00485 { 00486 return result; 00487 } 00488 } 00489 00490 //*/ 00491 00492 std::cout << "Get entity count before sealing" << std::endl; 00493 // Get entity count before sealing. 00494 int orig_n_tris; 00495 result = MBI()->get_number_entities_by_type( 0, MBTRI, orig_n_tris ); 00496 std::cout << result << std::endl; 00497 00498 assert(MB_SUCCESS == result); 00499 00500 std::cout << "==================================" << std::endl; 00501 std::cout << " Input faceted geometry contains: " << std::endl; 00502 std::cout << "==================================" << std::endl; 00503 00504 std::cout << geom_sets[3].size() << " volumes, " 00505 << geom_sets[2].size() << " surfaces, " << geom_sets[1].size() 00506 << " curves, " << orig_n_tris << " triangles, and " 00507 << geom_sets[0].size() << " vertices" << std::endl; 00508 00509 std::cout << "==================================" << std::endl; 00510 00511 00512 /* 00513 //Print all geometry entities 00514 std::cout << "Surfaces" << std::endl; 00515 for (unsigned int index=0; index < geom_sets[2].size(); index++) 00516 { 00517 std::cout << "surface handle = " << geom_sets[2][index] << std::endl; 00518 std::cout << "surface id = " << gen::geom_id_by_handle(geom_sets[2][index]) << std::endl; 00519 } 00520 00521 std::cout << "Curves" << std::endl; 00522 for (unsigned int index=0; index < geom_sets[1].size(); index++) 00523 { 00524 std::cout << "curve handle = " << geom_sets[1][index] << std::endl; 00525 std::cout << "curve id = " << gen::geom_id_by_handle(geom_sets[1][index]) << std::endl; 00526 } 00527 00528 std::cout << "Volumes" << std::endl; 00529 for (unsigned int index=0; index < geom_sets[3].size(); index++) 00530 { 00531 std::cout << "volume handle = " << geom_sets[3][index] << std::endl; 00532 std::cout << "volume id = " << gen::geom_id_by_handle(geom_sets[3][index]) << std::endl; 00533 } 00534 */ 00535 00536 00537 // Get all curve senses 00538 std::cout << "=====================================" << std::endl; 00539 std::cout << " CURVE SENSES " << std::endl; 00540 std::cout << "=====================================" << std::endl; 00541 00542 GeomTopoTool gt(MBI(), false); 00543 00544 for( unsigned int i=0; i<geom_sets[1].size(); i++) 00545 { 00546 EntityHandle curve = geom_sets[1][i]; 00547 std::vector<EntityHandle> surfs; 00548 std::vector<int> senses; 00549 rval = gt.get_senses( curve, surfs, senses); 00550 if(gen::error(MB_SUCCESS!=result,"could not get curve senses")) return result; 00551 std::cout << "Number of senses for curve " << gen::geom_id_by_handle(curve) << " = " << senses.size() << std::endl; 00552 for (unsigned int index=0; index<senses.size() ; index++) 00553 { 00554 std::cout << "surf = " << gen::geom_id_by_handle(surfs[index]) << std::endl; 00555 std::cout << "sense = " << sense_printer( senses[index] ) << std::endl; 00556 } 00557 std::cout << std::endl; 00558 } 00559 00560 00561 00562 //Get all surface senses 00563 00564 std::cout << "=====================================" << std::endl; 00565 std::cout << " SURFACE SENSES " << std::endl; 00566 std::cout << "=====================================" << std::endl; 00567 00568 00569 for( unsigned int i=0; i<geom_sets[2].size(); i++) 00570 { 00571 EntityHandle surf = geom_sets[2][i]; 00572 std::vector<EntityHandle> vols; 00573 std::vector<int> surf_senses; 00574 rval = gt.get_senses( surf, vols, surf_senses); 00575 if(gen::error(MB_SUCCESS!=result,"could not get surface senses")) return result; 00576 std::cout << "Number of senses for surface " << gen::geom_id_by_handle(surf) << " = " << surf_senses.size() << std::endl; 00577 for (unsigned int index=0; index<surf_senses.size() ; index++) 00578 { 00579 std::cout << "vol = " << gen::geom_id_by_handle(vols[index]) << std::endl; 00580 std::cout << "sense = " << sense_printer( surf_senses[index] ) << std::endl; 00581 } 00582 std::cout << std::endl; 00583 } 00584 00585 // Print all Vertex Coordinates 00586 00587 std::cout << "=====================================" << std::endl; 00588 std::cout << " Vertex Coordinates " << std::endl; 00589 std::cout << "=====================================" << std::endl; 00590 00591 Range verts; 00592 rval = MBI()->get_entities_by_type(0, MBVERTEX, verts); 00593 if(gen::error(MB_SUCCESS!=result,"could not get vertex handles")) return result; 00594 double x[geom_sets[0].size()]; 00595 double y[geom_sets[0].size()]; 00596 double z[geom_sets[0].size()]; 00597 00598 00599 rval = MBI()-> get_coords( verts, &x[0], &y[0], &z[0]); 00600 if(gen::error(MB_SUCCESS!=result,"could not get coordinates of the vertices")) return result; 00601 00602 00603 int j=0; 00604 for (Range::const_iterator i = verts.begin(); i!=verts.end(); i++) 00605 { 00606 00607 std::cout << "Vertex ID = " << *i << std::endl; 00608 std::cout << "X = " << x[j] << std::endl; 00609 std::cout << "Y = " << y[j] << std::endl; 00610 std::cout << "Z = " << z[j] << std::endl; 00611 00612 j++; 00613 00614 } 00615 } 00616 //==========EOL=============// 00617 00618 Interface *MBI() { 00619 static Core instance; 00620 return &instance; 00621 }
