MeshKit
1.0
00001 00007 #include "meshkit/MKCore.hpp" 00008 #include "meshkit/FBiGeom.hpp" 00009 #include "meshkit/SizingFunction.hpp" 00010 #include "meshkit/ModelEnt.hpp" 00011 00012 using namespace MeshKit; 00013 00014 MKCore * mk; 00015 bool save_mesh = false; 00016 bool quadMesh = true; 00017 double mesh_size = 0.3; 00018 std::string file_name; //="shell.h5m"; 00019 std::string output_file; //="output.h5m"; 00020 00021 #include "TestUtil.hpp" 00022 00023 void meshFB(); 00024 00025 int main(int argc, char **argv) 00026 { 00027 // start up a new iGeom engine, based on moab 00028 /*moab::Interface * mb = new moab::Core(); 00029 iGeom * fbiGeom = new FBiGeom(mb); // true means smooth 00030 MKCore mk(fbiGeom, mb); // iMesh, iRel, will be constructed*/ 00031 00032 file_name = TestDir + "/" + "shell.h5m";// default test file 00033 output_file = "output.h5m"; 00034 if (argc < 4) { 00035 { 00036 std::cout << "Usage : filename < q, t > <mesh_size> \n"; 00037 std::cout << "use default options: " << file_name << " " << output_file << 00038 (quadMesh ? " q " : " t " ) << mesh_size << "\n"; 00039 } 00040 } 00041 else 00042 { 00043 file_name = argv[1]; 00044 output_file = argv[2]; 00045 if (!strcmp(argv[3], "t")) 00046 quadMesh = false; 00047 mesh_size = atof(argv[4]); 00048 save_mesh = true; 00049 } 00050 00051 int num_fail = 0; 00052 num_fail += RUN_TEST(meshFB); 00053 00054 return num_fail; 00055 } 00056 void meshFB() 00057 { 00058 mk = new MKCore; 00059 // just for debugging 00060 FBiGeom * fbiGeom = new FBiGeom(); // true for smooth, false for linear 00061 unsigned int ix = mk->add_igeom_instance(fbiGeom); 00062 00063 // this will do the reading of the moab db in memory 00064 00065 //this also will do heavy stuff, like smoothing 00066 // we do not want to do it in the constructor 00067 // this should also populate ModelEnts in MKCore 00068 std::string opts( "SMOOTH;"); 00069 mk->load_geometry(file_name.c_str(), opts.c_str(), ix, 0, -1, false, true); 00070 /*fbiGeom->load(file_name.c_str(), opts.c_str()); 00071 00072 mk->populate_model_ents(ix, 0, -1, true);*/ 00073 00074 moab::Range tris; 00075 moab::ErrorCode rval = mk->moab_instance()->get_entities_by_dimension( 00076 (moab::EntityHandle)fbiGeom->getRootSet() , 2, 00077 tris, /*recursive*/ true); 00078 00079 int nbInitial = tris.size(); 00080 tris.clear(); 00081 // initial number of triangles 00082 std::cout << nbInitial << " initial elements in the model" << std::endl; 00083 //fbiGeom->Init(); 00084 00085 // get the surface model ents 00086 MEntVector surfs; 00087 mk->get_entities_by_dimension(2, surfs); 00088 00089 // create surface mesher for them, either quad or tri mesher 00090 if (quadMesh) 00091 mk->construct_meshop("CAMALPaver", surfs); 00092 else 00093 mk->construct_meshop("CAMALTriAdvance", surfs); 00094 00095 00096 // just for debugging 00097 mk->print_graph(); 00098 00099 // size the mesh 00100 SizingFunction *sf = new SizingFunction(mk, -1, mesh_size); 00101 for (unsigned int i = 0; i < surfs.size(); i++) 00102 surfs[i]->sizing_function_index(sf->core_index()); 00103 00104 // now mesh them 00105 mk->setup_and_execute(); 00106 00107 std::cout<<" after execute:\n"; 00108 // just for debugging 00109 mk->print_graph(); 00110 00111 // report the number of triangles generated 00112 // put it in a new set in moab 00113 00114 rval = mk->moab_instance()->get_entities_by_dimension(0, 2, tris); 00115 CHECK_EQUAL(moab::MB_SUCCESS, rval); 00116 std::string elem =(quadMesh? " quads ": " triangles"); 00117 std::cout << tris.size() - nbInitial << elem << " generated." << std::endl; 00118 00119 delete fbiGeom;// this will trigger also deletion of FBEngine tags, etc 00120 00121 if (save_mesh) { 00122 // output mesh for surfaces (implicitly for edges too, as edges are children of surface sets) 00123 mk->save_mesh_from_model_ents(output_file.c_str(), surfs); 00124 } 00125 // delete the model ents too, unload geometry 00126 00127 delete mk; 00128 }
