Mesh Oriented datABase
(version 5.4.1)
Functions | |
| void | iMesh_getEntities (iMesh_Instance instance, const iBase_EntitySetHandle entity_set_handle, const int entity_type, const int entity_topology, iBase_EntityHandle **entity_handles, int *entity_handles_allocated, int *entity_handles_size, int *err) |
| Get entities of specific type and/or topology in set or instance. | |
| void | iMesh_getEntArrTopo (iMesh_Instance instance, const iBase_EntityHandle *entity_handles, const int entity_handles_size, int **topology, int *topology_allocated, int *topology_size, int *err) |
| Get the entity topology for the specified entities. | |
| void | iMesh_getEntArrType (iMesh_Instance instance, const iBase_EntityHandle *entity_handles, const int entity_handles_size, int **type, int *type_allocated, int *type_size, int *err) |
| Get the entity type for the specified entities. | |
| void | iMesh_createEntArr (iMesh_Instance instance, const int new_entity_topology, const iBase_EntityHandle *lower_order_entity_handles, const int lower_order_entity_handles_size, iBase_EntityHandle **new_entity_handles, int *new_entity_handles_allocated, int *new_entity_handles_size, int **status, int *status_allocated, int *status_size, int *err) |
| Create an array of new entities with specified lower-order topology. | |
| void | iMesh_deleteEntArr (iMesh_Instance instance, const iBase_EntityHandle *entity_handles, const int entity_handles_size, int *err) |
| Delete specified entities. | |
| void | iMesh_createEnt (iMesh_Instance instance, const int new_entity_topology, const iBase_EntityHandle *lower_order_entity_handles, const int lower_order_entity_handles_size, iBase_EntityHandle *new_entity_handle, int *status, int *err) |
| Create a new entity with specified lower-order topology. | |
| void | iMesh_deleteEnt (iMesh_Instance instance, iBase_EntityHandle entity_handle, int *err) |
| Delete specified entity. | |
| void | iMesh_getEntTopo (iMesh_Instance instance, const iBase_EntityHandle entity_handle, int *out_topo, int *err) |
| Get the entity topology for the specified entity. | |
| void | iMesh_getEntType (iMesh_Instance instance, const iBase_EntityHandle entity_handle, int *out_type, int *err) |
| Get the entity type for the specified entity. | |
Entities iMesh
| void iMesh_createEnt | ( | iMesh_Instance | instance, |
| const int | new_entity_topology, | ||
| const iBase_EntityHandle * | lower_order_entity_handles, | ||
| const int | lower_order_entity_handles_size, | ||
| iBase_EntityHandle * | new_entity_handle, | ||
| int * | status, | ||
| int * | err | ||
Create a new entity with specified lower-order topology. Specified new_entity_topology must be value in iMesh_EntityTopology enumeration. Value returned as status must be a value in the iBase_CreationStatus enumeration.
| [in] | instance | iMesh instance handle |
| [in] | new_entity_topology | Topology of created entity |
| [in] | lower_order_entity_handles | Array of lower order entity handles to be used to construct new entity. |
| [in] | lower_order_entity_handles_size | Number of entities in lower_order_entity_handles array |
| [out] | new_entity_handle | Pointer to new entity handle returned from |
| [out] | status | Pointer to creation status returned from function (see iBase_CreationStatus) |
| [out] | err | Returned Error status (see iBase_ErrorType) |
Definition at line 1831 of file iMesh_MOAB.cpp.
References CONST_HANDLE_ARRAY_PTR, create_int_ents(), ERROR, ErrorCode, iBase_CREATION_FAILED, iBase_INVALID_ENTITY_COUNT, iBase_NEW, iBase_SUCCESS, moab::Range::insert(), MB_SUCCESS, mb_topology_table, MBIMESHI, MOABI, and RETURN.
if( 0 == lower_order_entity_handles_size )
ERROR( iBase_INVALID_ENTITY_COUNT, "iMesh_createEnt: need more than zero lower order entities." );
// call directly to allow creation of higher-order entities
// directly from connectivity
EntityType this_type = mb_topology_table[new_entity_topology];
EntityHandle tmp_ent;
ErrorCode result = MOABI->create_element( this_type, CONST_HANDLE_ARRAY_PTR( lower_order_entity_handles ),
lower_order_entity_handles_size, tmp_ent );
if( MB_SUCCESS == result )
*new_entity_handle = reinterpret_cast< iBase_EntityHandle >( tmp_ent );
*status = iBase_NEW;
if( MBIMESHI->AdjTable[5] || MBIMESHI->AdjTable[10] )
Range set_ents;
set_ents.insert( tmp_ent );
create_int_ents( MBIMESHI, set_ents );
RETURN( iBase_SUCCESS );
else
*new_entity_handle = 0;
*status = iBase_CREATION_FAILED;
ERROR( result, "iMesh_createEnt: couldn't create entity" );
| void iMesh_createEntArr | ( | iMesh_Instance | instance, |
| iBase_EntityHandle ** | new_entity_handles, | ||
| int * | new_entity_handles_allocated, | ||
| int * | new_entity_handles_size, | ||
| int ** | status, | ||
| int * | status_allocated, | ||
| int * | status_size, | ||
| int * | err | ||
Create an array of new entities with specified lower-order topology. Specified new_entity_topology must be value in iMesh_EntityTopology enumeration. Values return in status array must be values in the iBase_CreationStatus enumeration.
| [in] | lower_order_entity_handles | Array of lower order entity handles to be used to construct new entities |
| [in,out] | new_entity_handles | Pointer to array of new_entity_handles Array pointer, allocated and occupied sizes argument trio) |
| [in,out] | new_entity_handles_allocated | Pointer to allocated size of |
| [out] | new_entity_handles_size | Pointer to occupied size of |
| [in,out] | status | Pointer to array of creation status returned from Array pointer, allocated and occupied sizes argument trio) (see iBase_CreationStatus) |
| [in,out] | status_allocated | Pointer to allocated size of status array |
| [out] | status_size | Pointer to occupied size of status array |
Definition at line 1384 of file iMesh_MOAB.cpp.
References ALLOC_CHECK_ARRAY_NOFAIL, CHKERR, CONST_HANDLE_ARRAY_PTR, create_int_ents(), ERROR, ErrorCode, HANDLE_ARRAY_PTR, iBase_CREATION_FAILED, iBase_INVALID_ARGUMENT, iBase_INVALID_ENTITY_COUNT, iBase_NEW, iBase_SUCCESS, iMesh_POINT, iMesh_SEPTAHEDRON, MB_SUCCESS, mb_topology_table, MBIMESHI, MBVERTEX, MOABI, and RETURN.
// for now, throw an error if lower order entity handles aren't vertices
if( iMesh_POINT > new_entity_topology || iMesh_SEPTAHEDRON < new_entity_topology )
ERROR( iBase_INVALID_ARGUMENT, "iMesh_createEntArr: invalid topology." );
int num_ents = 0, num_verts;
const EntityHandle* lower_ents;
if( MBVERTEX != this_type )
num_verts = CN::VerticesPerEntity( this_type );
num_ents = lower_order_entity_handles_size / num_verts;
lower_ents = CONST_HANDLE_ARRAY_PTR( lower_order_entity_handles );
// check that we have the right number of lower order entity handles
if( lower_order_entity_handles_size % CN::VerticesPerEntity( this_type ) != 0 )
ERROR( iBase_INVALID_ENTITY_COUNT, "iMesh_createEntArr: wrong # vertices for this entity type." );
else
ERROR( iBase_INVALID_ARGUMENT, "iMesh_createEntArr: can't create vertices with this "
"function, use createVtxArr instead." );
if( num_ents == 0 )
ERROR( iBase_INVALID_ENTITY_COUNT, "iMesh_createEntArr: called to create 0 entities." );
// if there aren't any elements in the array, allocate it
// This function is poorly defined. We have to return allocated
// arrays even if we fail.
ALLOC_CHECK_ARRAY_NOFAIL( new_entity_handles, num_ents );
ALLOC_CHECK_ARRAY_NOFAIL( status, num_ents );
// make the entities
EntityHandle* new_ents = HANDLE_ARRAY_PTR( *new_entity_handles );
ErrorCode tmp_result, result = MB_SUCCESS;
for( int i = 0; i < num_ents; i++ )
tmp_result = MOABI->create_element( this_type, lower_ents, num_verts, new_ents[i] );
if( MB_SUCCESS != tmp_result )
( *status )[i] = iBase_CREATION_FAILED;
result = tmp_result;
else
( *status )[i] = iBase_NEW;
lower_ents += num_verts;
CHKERR( result, "iMesh_createEntArr: couldn't create one of the entities." );
*new_entity_handles_size = num_ents;
*status_size = num_ents;
Range set_ents;
std::copy( HANDLE_ARRAY_PTR( *new_entity_handles ),
HANDLE_ARRAY_PTR( *new_entity_handles ) + *new_entity_handles_size, range_inserter( set_ents ) );
result = create_int_ents( MBIMESHI, set_ents );CHKERR( result, "" );
| void iMesh_deleteEnt | ( | iMesh_Instance | instance, |
| iBase_EntityHandle | entity_handle, | ||
| int * | err | ||
| [in] | entity_handle | Entity to be deleted |
Definition at line 1872 of file iMesh_MOAB.cpp.
References iMesh_deleteEntArr.
iMesh_deleteEntArr( instance, &entity_handle, 1, err );
| void iMesh_deleteEntArr | ( | iMesh_Instance | instance, |
| const iBase_EntityHandle * | entity_handles, | ||
| const int | entity_handles_size, | ||
| int * | err | ||
| [in] | entity_handles | Array of entity handles to be deleted |
| [in] | entity_handles_size | Number of entities in array to be deleted |
Definition at line 1468 of file iMesh_MOAB.cpp.
References CHKERR, CONST_HANDLE_ARRAY_PTR, ErrorCode, iBase_SUCCESS, MOABI, and RETURN.
if( 0 == entity_handles_size )
ErrorCode result = MOABI->delete_entities( CONST_HANDLE_ARRAY_PTR( entity_handles ), entity_handles_size );CHKERR( result, "iMesh_deleteEntArr: trouble deleting entities." );
| void iMesh_getEntArrTopo | ( | iMesh_Instance | instance, |
| int ** | topology, | ||
| int * | topology_allocated, | ||
| int * | topology_size, | ||
| int * | err | ||
Get the entity topology for the specified entities. Topologies returned are values in the iMesh_EntityTopology enumeration.
| [in] | entity_handles | Array of entity handles being queried |
| [in] | entity_handles_size | Number of entities in entity_handles array |
| [in,out] | topology | Pointer to array of entity topologies returned Array pointer, allocated and occupied sizes argument trio) |
| [in,out] | topology_allocated | Pointer to allocated size of topology array |
| [out] | topology_size | Pointer to occupied size of topology array |
Definition at line 558 of file iMesh_MOAB.cpp.
References ALLOC_CHECK_ARRAY_NOFAIL, ENTITY_HANDLE, iBase_SUCCESS, MOABI, RETURN, and tstt_topology_table.
// go through each entity and look up its type
ALLOC_CHECK_ARRAY_NOFAIL( topology, entity_handles_size );
for( int i = 0; i < entity_handles_size; i++ )
( *topology )[i] = tstt_topology_table[MOABI->type_from_handle( ENTITY_HANDLE( entity_handles[i] ) )];
*topology_size = entity_handles_size;
| void iMesh_getEntArrType | ( | iMesh_Instance | instance, |
| int ** | type, | ||
| int * | type_allocated, | ||
| int * | type_size, | ||
| int * | err | ||
Get the entity type for the specified entities. Types returned are values in the iBase_EntityType enumeration.
| [in,out] | type | Pointer to array of types returned from function Array pointer, allocated and occupied sizes argument trio) |
| [in,out] | type_allocated | Pointer to allocated size of type array |
| [out] | type_size | Pointer to occupied size of type array |
Definition at line 577 of file iMesh_MOAB.cpp.
References ALLOC_CHECK_ARRAY_NOFAIL, ENTITY_HANDLE, iBase_SUCCESS, MOABI, RETURN, and tstt_type_table.
ALLOC_CHECK_ARRAY_NOFAIL( etype, entity_handles_size );
( *etype )[i] = tstt_type_table[MOABI->type_from_handle( ENTITY_HANDLE( entity_handles[i] ) )];
*etype_size = entity_handles_size;
| void iMesh_getEntities | ( | iMesh_Instance | instance, |
| const iBase_EntitySetHandle | entity_set_handle, | ||
| const int | entity_type, | ||
| const int | entity_topology, | ||
| iBase_EntityHandle ** | entity_handles, | ||
| int * | entity_handles_allocated, | ||
| int * | entity_handles_size, | ||
| int * | err | ||
Get entities of specific type and/or topology in set or instance. All entities of a given type or topology are requested by specifying iBase_ALL_TOPOLOGIES or iBase_ALL_TYPES, respectively. Specified type or topology must be a value in the iBase_EntityType or iBase_EntityTopology enumeration, respectively.
| [in] | entity_set_handle | Entity set being queried |
| [in] | entity_type | Type of entities being requested |
| [in] | entity_topology | Topology of entities being requested |
| [in,out] | entity_handles | Pointer to array of entity handles returned Array pointer, allocated and occupied sizes argument trio) |
| [in,out] | entity_handles_allocated | Pointer to allocated size of entity_handles array |
| [out] | entity_handles_size | Pointer to occupied size of entity_handles array |
Definition at line 439 of file iMesh_MOAB.cpp.
References iMesh_getEntitiesRec.
iMesh_getEntitiesRec( instance, entity_set_handle, entity_type, entity_topology, false, entity_handles,
entity_handles_allocated, entity_handles_size, err );
| void iMesh_getEntTopo | ( | iMesh_Instance | instance, |
| const iBase_EntityHandle | entity_handle, | ||
| int * | out_topo, | ||
| int * | err | ||
Get the entity topology for the specified entity. Topology returned is a value in the iMesh_EntityTopology enumeration.
| [in] | entity_handle | Entity handle being queried |
| [out] | out_topo | Pointer to entity topology returned from function |
Definition at line 2284 of file iMesh_MOAB.cpp.
References ENTITY_HANDLE, iBase_SUCCESS, MOABI, RETURN, and tstt_topology_table.
*out_topo = tstt_topology_table[MOABI->type_from_handle( ENTITY_HANDLE( entity_handle ) )];
| void iMesh_getEntType | ( | iMesh_Instance | instance, |
| int * | out_type, | ||
| int * | err | ||
Get the entity type for the specified entity. Type returned is a value in the iBase_EntityType enumeration.
| [out] | out_type | Pointer to entity type returned from function |
Definition at line 2293 of file iMesh_MOAB.cpp.
References ENTITY_HANDLE, iBase_SUCCESS, MOABI, RETURN, and tstt_type_table.
*out_type = tstt_type_table[MOABI->type_from_handle( ENTITY_HANDLE( entity_handle ) )];
