MOAB: Mesh Oriented datABase
(version 5.2.1)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2006 Sandia National Laboratories. Developed at the 00005 University of Wisconsin--Madison under SNL contract number 00006 624796. The U.S. Government and the University of Wisconsin 00007 retain certain rights to this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 (2006) kraftche@cae.wisc.edu 00024 00025 ***************************************************************** */ 00026 00027 /** \file AWQualityMetric.hpp 00028 * \brief 00029 * \author Jason Kraftcheck 00030 */ 00031 00032 #ifndef MSQ_TABS_QUALITY_METRIC_HPP 00033 #define MSQ_TABS_QUALITY_METRIC_HPP 00034 00035 #include "Mesquite.hpp" 00036 #include "TMPQualityMetric.hpp" 00037 #include "MsqMatrix.hpp" 00038 00039 namespace MBMesquite 00040 { 00041 00042 class AWMetric; 00043 00044 /**\brief Compare targets to mapping function Jacobian matrices 00045 * 00046 * A quality metric defined using 2D and 3D target metrics, 00047 * where the active (A) matrix compared to the target by 00048 * the underlying metrics is the Jacobian matrix of the 00049 * mapping function at a given sample point. For surface 00050 * elements, A is rotated to align the normal with W, such that 00051 * both matrices can be reduced from 3x2 to 2x2. 00052 */ 00053 class AWQualityMetric : public TMPQualityMetric 00054 { 00055 public: 00056 /** Used in tests and other templatized code */ 00057 typedef AWMetric MetricType; 00058 00059 /** 00060 *\param tc The target calculator 00061 *\param wc The weight calculator 00062 *\param target_metric The target metric to use 00063 */ 00064 AWQualityMetric( TargetCalculator* tc, WeightCalculator* wc, AWMetric* target_metric ) 00065 : TMPQualityMetric( tc, wc ), targetMetric( target_metric ) 00066 { 00067 } 00068 00069 /** 00070 *\param tc The target calculator 00071 *\param target_metric The target metric to use 00072 */ 00073 AWQualityMetric( TargetCalculator* tc, AWMetric* target_metric ) 00074 : TMPQualityMetric( tc, 0 ), targetMetric( target_metric ) 00075 { 00076 } 00077 00078 MESQUITE_EXPORT virtual std::string get_name() const; 00079 00080 MESQUITE_EXPORT virtual bool evaluate_with_gradient( PatchData& pd, size_t handle, double& value, 00081 std::vector< size_t >& indices, 00082 std::vector< Vector3D >& gradient, MsqError& err ); 00083 00084 MESQUITE_EXPORT virtual bool evaluate_with_Hessian_diagonal( PatchData& pd, size_t handle, double& value, 00085 std::vector< size_t >& indices, 00086 std::vector< Vector3D >& gradient, 00087 std::vector< SymMatrix3D >& Hessian_diagonal, 00088 MsqError& err ); 00089 00090 MESQUITE_EXPORT virtual bool evaluate_with_Hessian( PatchData& pd, size_t handle, double& value, 00091 std::vector< size_t >& indices, 00092 std::vector< Vector3D >& gradient, 00093 std::vector< Matrix3D >& Hessian, MsqError& err ); 00094 00095 AWMetric* get_target_metric() const 00096 { 00097 return targetMetric; 00098 } 00099 void set_target_metric( AWMetric* m ) 00100 { 00101 targetMetric = m; 00102 } 00103 00104 protected: 00105 MESQUITE_EXPORT virtual bool evaluate_internal( PatchData& pd, size_t handle, double& value, size_t* indices, 00106 size_t& num_indices, MsqError& err ); 00107 00108 private: 00109 AWMetric* targetMetric; 00110 }; 00111 00112 } // namespace MBMesquite 00113 00114 #endif
