MOAB
4.9.3pre
00001 // This file is part of Eigen, a lightweight C++ template library 00002 // for linear algebra. 00003 // 00004 // Copyright (C) 2008-2012 Gael Guennebaud <[email protected]> 00005 00006 /* 00007 00008 NOTE: thes functions vave been adapted from the LDL library: 00009 00010 LDL Copyright (c) 2005 by Timothy A. Davis. All Rights Reserved. 00011 00012 LDL License: 00013 00014 Your use or distribution of LDL or any modified version of 00015 LDL implies that you agree to this License. 00016 00017 This library is free software; you can redistribute it and/or 00018 modify it under the terms of the GNU Lesser General Public 00019 License as published by the Free Software Foundation; either 00020 version 2.1 of the License, or (at your option) any later version. 00021 00022 This library is distributed in the hope that it will be useful, 00023 but WITHOUT ANY WARRANTY; without even the implied warranty of 00024 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00025 Lesser General Public License for more details. 00026 00027 You should have received a copy of the GNU Lesser General Public 00028 License along with this library; if not, write to the Free Software 00029 Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 00030 USA 00031 00032 Permission is hereby granted to use or copy this program under the 00033 terms of the GNU LGPL, provided that the Copyright, this License, 00034 and the Availability of the original version is retained on all copies. 00035 User documentation of any code that uses this code or any modified 00036 version of this code must cite the Copyright, this License, the 00037 Availability note, and "Used by permission." Permission to modify 00038 the code and to distribute modified code is granted, provided the 00039 Copyright, this License, and the Availability note are retained, 00040 and a notice that the code was modified is included. 00041 */ 00042 00043 #include "../Core/util/NonMPL2.h" 00044 00045 #ifndef EIGEN_SIMPLICIAL_CHOLESKY_IMPL_H 00046 #define EIGEN_SIMPLICIAL_CHOLESKY_IMPL_H 00047 00048 namespace Eigen { 00049 00050 template<typename Derived> 00051 void SimplicialCholeskyBase<Derived>::analyzePattern_preordered(const CholMatrixType& ap, bool doLDLT) 00052 { 00053 const StorageIndex size = StorageIndex(ap.rows()); 00054 m_matrix.resize(size, size); 00055 m_parent.resize(size); 00056 m_nonZerosPerCol.resize(size); 00057 00058 ei_declare_aligned_stack_constructed_variable(StorageIndex, tags, size, 0); 00059 00060 for(StorageIndex k = 0; k < size; ++k) 00061 { 00062 /* L(k,:) pattern: all nodes reachable in etree from nz in A(0:k-1,k) */ 00063 m_parent[k] = -1; /* parent of k is not yet known */ 00064 tags[k] = k; /* mark node k as visited */ 00065 m_nonZerosPerCol[k] = 0; /* count of nonzeros in column k of L */ 00066 for(typename CholMatrixType::InnerIterator it(ap,k); it; ++it) 00067 { 00068 StorageIndex i = it.index(); 00069 if(i < k) 00070 { 00071 /* follow path from i to root of etree, stop at flagged node */ 00072 for(; tags[i] != k; i = m_parent[i]) 00073 { 00074 /* find parent of i if not yet determined */ 00075 if (m_parent[i] == -1) 00076 m_parent[i] = k; 00077 m_nonZerosPerCol[i]++; /* L (k,i) is nonzero */ 00078 tags[i] = k; /* mark i as visited */ 00079 } 00080 } 00081 } 00082 } 00083 00084 /* construct Lp index array from m_nonZerosPerCol column counts */ 00085 StorageIndex* Lp = m_matrix.outerIndexPtr(); 00086 Lp[0] = 0; 00087 for(StorageIndex k = 0; k < size; ++k) 00088 Lp[k+1] = Lp[k] + m_nonZerosPerCol[k] + (doLDLT ? 0 : 1); 00089 00090 m_matrix.resizeNonZeros(Lp[size]); 00091 00092 m_isInitialized = true; 00093 m_info = Success; 00094 m_analysisIsOk = true; 00095 m_factorizationIsOk = false; 00096 } 00097 00098 00099 template<typename Derived> 00100 template<bool DoLDLT> 00101 void SimplicialCholeskyBase<Derived>::factorize_preordered(const CholMatrixType& ap) 00102 { 00103 using std::sqrt; 00104 00105 eigen_assert(m_analysisIsOk && "You must first call analyzePattern()"); 00106 eigen_assert(ap.rows()==ap.cols()); 00107 eigen_assert(m_parent.size()==ap.rows()); 00108 eigen_assert(m_nonZerosPerCol.size()==ap.rows()); 00109 00110 const StorageIndex size = StorageIndex(ap.rows()); 00111 const StorageIndex* Lp = m_matrix.outerIndexPtr(); 00112 StorageIndex* Li = m_matrix.innerIndexPtr(); 00113 Scalar* Lx = m_matrix.valuePtr(); 00114 00115 ei_declare_aligned_stack_constructed_variable(Scalar, y, size, 0); 00116 ei_declare_aligned_stack_constructed_variable(StorageIndex, pattern, size, 0); 00117 ei_declare_aligned_stack_constructed_variable(StorageIndex, tags, size, 0); 00118 00119 bool ok = true; 00120 m_diag.resize(DoLDLT ? size : 0); 00121 00122 for(StorageIndex k = 0; k < size; ++k) 00123 { 00124 // compute nonzero pattern of kth row of L, in topological order 00125 y[k] = 0.0; // Y(0:k) is now all zero 00126 StorageIndex top = size; // stack for pattern is empty 00127 tags[k] = k; // mark node k as visited 00128 m_nonZerosPerCol[k] = 0; // count of nonzeros in column k of L 00129 for(typename CholMatrixType::InnerIterator it(ap,k); it; ++it) 00130 { 00131 StorageIndex i = it.index(); 00132 if(i <= k) 00133 { 00134 y[i] += numext::conj(it.value()); /* scatter A(i,k) into Y (sum duplicates) */ 00135 Index len; 00136 for(len = 0; tags[i] != k; i = m_parent[i]) 00137 { 00138 pattern[len++] = i; /* L(k,i) is nonzero */ 00139 tags[i] = k; /* mark i as visited */ 00140 } 00141 while(len > 0) 00142 pattern[--top] = pattern[--len]; 00143 } 00144 } 00145 00146 /* compute numerical values kth row of L (a sparse triangular solve) */ 00147 00148 RealScalar d = numext::real(y[k]) * m_shiftScale + m_shiftOffset; // get D(k,k), apply the shift function, and clear Y(k) 00149 y[k] = 0.0; 00150 for(; top < size; ++top) 00151 { 00152 Index i = pattern[top]; /* pattern[top:n-1] is pattern of L(:,k) */ 00153 Scalar yi = y[i]; /* get and clear Y(i) */ 00154 y[i] = 0.0; 00155 00156 /* the nonzero entry L(k,i) */ 00157 Scalar l_ki; 00158 if(DoLDLT) 00159 l_ki = yi / m_diag[i]; 00160 else 00161 yi = l_ki = yi / Lx[Lp[i]]; 00162 00163 Index p2 = Lp[i] + m_nonZerosPerCol[i]; 00164 Index p; 00165 for(p = Lp[i] + (DoLDLT ? 0 : 1); p < p2; ++p) 00166 y[Li[p]] -= numext::conj(Lx[p]) * yi; 00167 d -= numext::real(l_ki * numext::conj(yi)); 00168 Li[p] = k; /* store L(k,i) in column form of L */ 00169 Lx[p] = l_ki; 00170 ++m_nonZerosPerCol[i]; /* increment count of nonzeros in col i */ 00171 } 00172 if(DoLDLT) 00173 { 00174 m_diag[k] = d; 00175 if(d == RealScalar(0)) 00176 { 00177 ok = false; /* failure, D(k,k) is zero */ 00178 break; 00179 } 00180 } 00181 else 00182 { 00183 Index p = Lp[k] + m_nonZerosPerCol[k]++; 00184 Li[p] = k ; /* store L(k,k) = sqrt (d) in column k */ 00185 if(d <= RealScalar(0)) { 00186 ok = false; /* failure, matrix is not positive definite */ 00187 break; 00188 } 00189 Lx[p] = sqrt(d) ; 00190 } 00191 } 00192 00193 m_info = ok ? Success : NumericalIssue; 00194 m_factorizationIsOk = true; 00195 } 00196 00197 } // end namespace Eigen 00198 00199 #endif // EIGEN_SIMPLICIAL_CHOLESKY_IMPL_H
