MOAB: Mesh Oriented datABase
(version 5.4.0)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2007 Sandia National Laboratories. Developed at the 00005 University of Wisconsin--Madison under SNL contract number 00006 624796. The U.S. Government and the University of Wisconsin 00007 retain certain rights to this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 (2007) kraftche@cae.wisc.edu 00024 00025 ***************************************************************** */ 00026 00027 /** \file TargetMetricUtil.hpp 00028 * \brief A collection of utility code used by QualtiyMetrics 00029 * composed of TMP Target Metrics 00030 * \author Jason Kraftcheck 00031 */ 00032 00033 #ifndef MSQ_TARGET_METRIC_UTIL_HPP 00034 #define MSQ_TARGET_METRIC_UTIL_HPP 00035 00036 #include "Mesquite.hpp" 00037 #include "SymMatrix3D.hpp" 00038 #include <vector> 00039 #include <cassert> 00040 00041 namespace MBMesquite 00042 { 00043 00044 template < unsigned R, unsigned C > 00045 class MsqMatrix; 00046 template < unsigned C > 00047 class MsqVector; 00048 class PatchData; 00049 class MsqError; 00050 class Vector3D; 00051 class Matrix3D; 00052 00053 /**\brief Calculate R and Z such that \f$W\prime = Z^{-1} W\f$ and 00054 * \f$A\prime = (RZ)^{-1} A\f$ 00055 * 00056 * Calculate the matrices required to transform the active and target 00057 * matrices from the 3x2 surface domain to a 2x2 2D domain. 00058 *\param A Input: Element Jacobian matrix. 00059 *\param W_32 Input: Target Jacobian matrix. 00060 *\param W_22 Output: 2D Target matrix. 00061 *\param RZ Output: Product of R and Z needed to calculate the 2D 00062 * element matrix. 00063 */ 00064 void surface_to_2d( const MsqMatrix< 3, 2 >& A, 00065 const MsqMatrix< 3, 2 >& W_32, 00066 MsqMatrix< 2, 2 >& W_22, 00067 MsqMatrix< 3, 2 >& RZ ); 00068 /* 00069 void surface_to_2d( const MsqMatrix<3,2>& A_in, 00070 const MsqMatrix<3,2>& W_in, 00071 MsqMatrix<2,2>& A_out, 00072 MsqMatrix<2,2>& W_out ); 00073 */ 00074 void get_sample_pt_evaluations( PatchData& pd, std::vector< size_t >& handles, bool free, MsqError& err ); 00075 00076 void get_elem_sample_points( PatchData& pd, size_t elem, std::vector< size_t >& handles, MsqError& err ); 00077 00078 /**\brief Calculate gradient from derivatives of mapping function terms 00079 * and derivatives of target metric. */ 00080 template < int DIM > 00081 inline void gradient( size_t num_free_verts, 00082 const MsqVector< DIM >* dNdxi, 00083 const MsqMatrix< 3, DIM >& dmdA, 00084 std::vector< Vector3D >& grad ) 00085 { 00086 grad.clear(); 00087 grad.resize( num_free_verts, Vector3D( 0, 0, 0 ) ); 00088 for( size_t i = 0; i < num_free_verts; ++i ) 00089 grad[i] = Vector3D( ( dmdA * dNdxi[i] ).data() ); 00090 } 00091 00092 /**\brief Calculate Hessian from derivatives of mapping function terms 00093 * and derivatives of target metric. */ 00094 template < int DIM, typename MAT > 00095 inline void hessian( size_t num_free_verts, 00096 const MsqVector< DIM >* dNdxi, 00097 const MsqMatrix< DIM, DIM >* d2mdA2, 00098 MAT* hess ) 00099 { 00100 MsqMatrix< 1, DIM > tmp[DIM][DIM]; 00101 size_t h = 0; // index of current Hessian block 00102 00103 for( size_t i = 0; i < num_free_verts; ++i ) 00104 { 00105 00106 // Populate TMP with vector-matrix procucts common 00107 // to terms of this Hessian row. 00108 const MsqMatrix< 1, DIM >& gi = transpose( dNdxi[i] ); 00109 switch( DIM ) 00110 { 00111 case 3: 00112 tmp[0][2] = gi * d2mdA2[2]; 00113 tmp[1][2] = gi * d2mdA2[4]; 00114 tmp[2][0] = gi * transpose( d2mdA2[2] ); 00115 tmp[2][1] = gi * transpose( d2mdA2[4] ); 00116 tmp[2][2] = gi * d2mdA2[5]; 00117 case 2: 00118 tmp[0][1] = gi * d2mdA2[1]; 00119 tmp[1][0] = gi * transpose( d2mdA2[1] ); 00120 tmp[1][1] = gi * d2mdA2[DIM]; 00121 case 1: 00122 tmp[0][0] = gi * d2mdA2[0]; 00123 case 0: 00124 break; 00125 default: 00126 assert( false ); 00127 } 00128 00129 // Calculate Hessian diagonal block 00130 MAT& H = hess[h++]; 00131 switch( DIM ) 00132 { 00133 case 3: 00134 H( 0, 2 ) = H( 2, 0 ) = tmp[0][2] * transpose( gi ); 00135 H( 1, 2 ) = H( 2, 1 ) = tmp[1][2] * transpose( gi ); 00136 H( 2, 2 ) = tmp[2][2] * transpose( gi ); 00137 case 2: 00138 H( 0, 1 ) = H( 1, 0 ) = tmp[0][1] * transpose( gi ); 00139 H( 1, 1 ) = tmp[1][1] * transpose( gi ); 00140 case 1: 00141 H( 0, 0 ) = tmp[0][0] * transpose( gi ); 00142 case 0: 00143 break; 00144 default: 00145 assert( false ); 00146 } 00147 00148 // Calculate remainder of Hessian row 00149 for( size_t j = i + 1; j < num_free_verts; ++j ) 00150 { 00151 MAT& HH = hess[h++]; 00152 const MsqMatrix< DIM, 1 >& gj = dNdxi[j]; 00153 switch( DIM ) 00154 { 00155 case 3: 00156 HH( 0, 2 ) = tmp[0][2] * gj; 00157 HH( 1, 2 ) = tmp[1][2] * gj; 00158 HH( 2, 0 ) = tmp[2][0] * gj; 00159 HH( 2, 1 ) = tmp[2][1] * gj; 00160 HH( 2, 2 ) = tmp[2][2] * gj; 00161 case 2: 00162 HH( 0, 1 ) = tmp[0][1] * gj; 00163 HH( 1, 0 ) = tmp[1][0] * gj; 00164 HH( 1, 1 ) = tmp[1][1] * gj; 00165 case 1: 00166 HH( 0, 0 ) = tmp[0][0] * gj; 00167 case 0: 00168 break; 00169 default: 00170 assert( false ); 00171 } 00172 } 00173 } 00174 } 00175 00176 /**\brief Calculate Hessian from derivatives of mapping function terms 00177 * and derivatives of target metric. */ 00178 template < int DIM > 00179 inline void hessian_diagonal( size_t num_free_verts, 00180 const MsqVector< DIM >* dNdxi, 00181 const MsqMatrix< DIM, DIM >* d2mdA2, 00182 SymMatrix3D* diagonal ) 00183 { 00184 for( size_t i = 0; i < num_free_verts; ++i ) 00185 { 00186 SymMatrix3D& H = diagonal[i]; 00187 for( unsigned j = 0; j < ( ( DIM ) * ( DIM + 1 ) / 2 ); ++j ) 00188 H[j] = transpose( dNdxi[i] ) * d2mdA2[j] * dNdxi[i]; 00189 } 00190 } 00191 00192 #ifdef PRINT_INFO 00193 template < int R, int C > 00194 inline void write_vect( char n, const MsqMatrix< R, C >& M ) 00195 { 00196 std::cout << " " << n << ':'; 00197 for( int c = 0; c < C; ++c ) 00198 { 00199 std::cout << '['; 00200 for( int r = 0; r < R; ++r ) 00201 std::cout << M( r, c ) << ' '; 00202 std::cout << ']'; 00203 } 00204 std::cout << std::endl; 00205 } 00206 00207 template < int D > 00208 inline void print_info( size_t elem, 00209 Sample sample, 00210 const MsqMatrix< 3, D >& A, 00211 const MsqMatrix< 3, D >& W, 00212 const MsqMatrix< D, D >& T ) 00213 { 00214 std::cout << "Elem " << elem << " Dim " << sample.dimension << " Num " << sample.number << " :" << std::endl; 00215 write_vect< 3, D >( 'A', A ); 00216 write_vect< 3, D >( 'W', W ); 00217 write_vect< D, D >( 'T', T ); 00218 } 00219 #endif 00220 00221 } // namespace MBMesquite 00222 00223 #endif
