MOAB: Mesh Oriented datABase
(version 5.4.0)
00001 /* ***************************************************************** 00002 MESQUITE -- The Mesh Quality Improvement Toolkit 00003 00004 Copyright 2006 Sandia National Laboratories. Developed at the 00005 University of Wisconsin--Madison under SNL contract number 00006 624796. The U.S. Government and the University of Wisconsin 00007 retian certain rights to this software. 00008 00009 This library is free software; you can redistribute it and/or 00010 modify it under the terms of the GNU Lesser General Public 00011 License as published by the Free Software Foundation; either 00012 version 2.1 of the License, or (at your option) any later version. 00013 00014 This library is distributed in the hope that it will be useful, 00015 but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 Lesser General Public License for more details. 00018 00019 You should have received a copy of the GNU Lesser General Public License 00020 (lgpl.txt) along with this library; if not, write to the Free Software 00021 Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 00023 (2006) kraftche@cae.wisc.edu 00024 00025 ***************************************************************** */ 00026 00027 /** \file UntangleBetaTest.cpp 00028 * \brief unit tests for UntangleBetaQualityMetric 00029 * \author Jason Kraftcheck 00030 */ 00031 00032 #include "Mesquite.hpp" 00033 #include "UntangleBetaQualityMetric.hpp" 00034 #include "cppunit/extensions/HelperMacros.h" 00035 #include "QualityMetricTester.hpp" 00036 #include "PatchData.hpp" 00037 #include "UnitUtil.hpp" 00038 00039 using namespace MBMesquite; 00040 00041 class UntangleBetaTest : public CppUnit::TestFixture 00042 { 00043 private: 00044 CPPUNIT_TEST_SUITE( UntangleBetaTest ); 00045 00046 CPPUNIT_TEST( test_supported_types ); 00047 CPPUNIT_TEST( test_ideal_element_eval ); 00048 CPPUNIT_TEST( test_inverted_elements ); 00049 CPPUNIT_TEST( test_degenerate_elements ); 00050 CPPUNIT_TEST( test_get_evaluations ); 00051 CPPUNIT_TEST( test_get_element_indices ); 00052 CPPUNIT_TEST( test_get_fixed_indices ); 00053 CPPUNIT_TEST( test_eval_with_indices ); 00054 CPPUNIT_TEST( test_location_invariant ); 00055 CPPUNIT_TEST( test_orient_invariant ); 00056 00057 CPPUNIT_TEST_SUITE_END(); 00058 00059 UntangleBetaQualityMetric mMetric; 00060 QualityMetricTester tester; 00061 00062 public: 00063 UntangleBetaTest() : tester( QualityMetricTester::ALL_FE_EXCEPT_SEPTAHEDRON ) 00064 { 00065 tester.ideal_pyramid_base_equals_height( true ); 00066 } 00067 00068 void test_supported_types() 00069 { 00070 tester.test_supported_element_types( &mMetric ); 00071 } 00072 00073 void test_ideal_element_eval() 00074 { 00075 tester.test_evaluate_unit_edge_element( &mMetric, TRIANGLE, 0.0 ); 00076 tester.test_evaluate_unit_edge_element( &mMetric, QUADRILATERAL, 0.0 ); 00077 tester.test_evaluate_unit_edge_element( &mMetric, TETRAHEDRON, 0.0 ); 00078 tester.test_evaluate_unit_edge_element( &mMetric, HEXAHEDRON, 0.0 ); 00079 tester.test_evaluate_unit_edge_element( &mMetric, PRISM, 0.0 ); 00080 tester.test_evaluate_unit_edge_element( &mMetric, PYRAMID, 0.0 ); 00081 } 00082 00083 void test_inverted_elements() 00084 { 00085 MsqPrintError err( std::cout ); 00086 double value; 00087 PatchData pd; 00088 char val_str[128]; 00089 00090 tester.get_inverted_element( TRIANGLE, pd ); 00091 mMetric.evaluate( pd, 0, value, err ); 00092 ASSERT_NO_ERROR( err ); 00093 sprintf( val_str, "value: %f", value ); 00094 CPPUNIT_ASSERT_MESSAGE( val_str, value > 1e-6 ); 00095 00096 tester.get_inverted_element( QUADRILATERAL, pd ); 00097 mMetric.evaluate( pd, 0, value, err ); 00098 ASSERT_NO_ERROR( err ); 00099 sprintf( val_str, "value: %f", value ); 00100 CPPUNIT_ASSERT_MESSAGE( val_str, value > 1e-6 ); 00101 00102 tester.get_inverted_element( TETRAHEDRON, pd ); 00103 mMetric.evaluate( pd, 0, value, err ); 00104 ASSERT_NO_ERROR( err ); 00105 sprintf( val_str, "value: %f", value ); 00106 CPPUNIT_ASSERT_MESSAGE( val_str, value > 1e-6 ); 00107 00108 tester.get_inverted_element( HEXAHEDRON, pd ); 00109 mMetric.evaluate( pd, 0, value, err ); 00110 ASSERT_NO_ERROR( err ); 00111 sprintf( val_str, "value: %f", value ); 00112 CPPUNIT_ASSERT_MESSAGE( val_str, value > 1e-6 ); 00113 00114 tester.get_inverted_element( PRISM, pd ); 00115 mMetric.evaluate( pd, 0, value, err ); 00116 ASSERT_NO_ERROR( err ); 00117 sprintf( val_str, "value: %f", value ); 00118 CPPUNIT_ASSERT_MESSAGE( val_str, value > 1e-6 ); 00119 00120 tester.get_inverted_element( PYRAMID, pd ); 00121 mMetric.evaluate( pd, 0, value, err ); 00122 ASSERT_NO_ERROR( err ); 00123 sprintf( val_str, "value: %f", value ); 00124 CPPUNIT_ASSERT_MESSAGE( val_str, value > 1e-6 ); 00125 } 00126 00127 void test_degenerate_elements() 00128 { 00129 MsqPrintError err( std::cout ); 00130 double value; 00131 PatchData pd; 00132 char val_str[128]; 00133 00134 tester.get_zero_element( TRIANGLE, pd ); 00135 mMetric.evaluate( pd, 0, value, err ); 00136 ASSERT_NO_ERROR( err ); 00137 sprintf( val_str, "value: %f", value ); 00138 CPPUNIT_ASSERT_MESSAGE( val_str, value > 1e-6 ); 00139 00140 tester.get_zero_element( QUADRILATERAL, pd ); 00141 mMetric.evaluate( pd, 0, value, err ); 00142 ASSERT_NO_ERROR( err ); 00143 sprintf( val_str, "value: %f", value ); 00144 CPPUNIT_ASSERT_MESSAGE( val_str, value > 1e-6 ); 00145 00146 tester.get_zero_element( TETRAHEDRON, pd ); 00147 mMetric.evaluate( pd, 0, value, err ); 00148 ASSERT_NO_ERROR( err ); 00149 sprintf( val_str, "value: %f", value ); 00150 CPPUNIT_ASSERT_MESSAGE( val_str, value > 1e-6 ); 00151 00152 tester.get_zero_element( HEXAHEDRON, pd ); 00153 mMetric.evaluate( pd, 0, value, err ); 00154 ASSERT_NO_ERROR( err ); 00155 sprintf( val_str, "value: %f", value ); 00156 CPPUNIT_ASSERT_MESSAGE( val_str, value > 1e-6 ); 00157 00158 tester.get_zero_element( PRISM, pd ); 00159 mMetric.evaluate( pd, 0, value, err ); 00160 ASSERT_NO_ERROR( err ); 00161 sprintf( val_str, "value: %f", value ); 00162 CPPUNIT_ASSERT_MESSAGE( val_str, value > 1e-6 ); 00163 00164 tester.get_zero_element( PYRAMID, pd ); 00165 mMetric.evaluate( pd, 0, value, err ); 00166 ASSERT_NO_ERROR( err ); 00167 sprintf( val_str, "value: %f", value ); 00168 CPPUNIT_ASSERT_MESSAGE( val_str, value > 1e-6 ); 00169 } 00170 00171 void test_get_evaluations() 00172 { 00173 tester.test_get_element_evaluations( &mMetric ); 00174 } 00175 00176 void test_get_element_indices() 00177 { 00178 tester.test_get_element_indices( &mMetric ); 00179 } 00180 00181 void test_get_fixed_indices() 00182 { 00183 tester.test_get_indices_fixed( &mMetric ); 00184 } 00185 00186 void test_eval_with_indices() 00187 { 00188 tester.compare_eval_and_eval_with_indices( &mMetric ); 00189 } 00190 00191 void test_location_invariant() 00192 { 00193 tester.test_location_invariant( &mMetric, true ); 00194 tester.test_grad_location_invariant( &mMetric, true ); 00195 tester.test_hessian_location_invariant( &mMetric, true ); 00196 } 00197 00198 void test_orient_invariant() 00199 { 00200 tester.test_orient_invariant( &mMetric, true ); 00201 tester.test_grad_orient_invariant( &mMetric, true ); 00202 } 00203 }; 00204 00205 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION( UntangleBetaTest, "UntangleBetaTest" ); 00206 CPPUNIT_TEST_SUITE_NAMED_REGISTRATION( UntangleBetaTest, "Unit" );
