UntangleBetaTest Class Reference
+ Inheritance diagram for UntangleBetaTest:
+ Collaboration diagram for UntangleBetaTest:
Public Member Functions
 UntangleBetaTest ()
void test_supported_types ()
void test_ideal_element_eval ()
void test_inverted_elements ()
void test_degenerate_elements ()
void test_get_evaluations ()
void test_get_element_indices ()
void test_get_fixed_indices ()
void test_eval_with_indices ()
void test_location_invariant ()
void test_orient_invariant ()
Private Member Functions
 CPPUNIT_TEST_SUITE (UntangleBetaTest)
 CPPUNIT_TEST (test_supported_types)
 CPPUNIT_TEST (test_ideal_element_eval)
 CPPUNIT_TEST (test_inverted_elements)
 CPPUNIT_TEST (test_degenerate_elements)
 CPPUNIT_TEST (test_get_evaluations)
 CPPUNIT_TEST (test_get_element_indices)
 CPPUNIT_TEST (test_get_fixed_indices)
 CPPUNIT_TEST (test_eval_with_indices)
 CPPUNIT_TEST (test_location_invariant)
 CPPUNIT_TEST (test_orient_invariant)
 CPPUNIT_TEST_SUITE_END ()
Private Attributes
UntangleBetaQualityMetric mMetric
QualityMetricTester tester
Detailed Description
Definition at line 41 of file UntangleBetaTest.cpp.
Member Function Documentation
Definition at line 127 of file UntangleBetaTest.cpp.
References ASSERT_NO_ERROR, MBMesquite::HEXAHEDRON, mMetric, MBMesquite::PRISM, MBMesquite::PYRAMID, MBMesquite::QUADRILATERAL, MBMesquite::TETRAHEDRON, MBMesquite::TRIANGLE, and value().
        MsqPrintError err( std::cout );
        double value;
        PatchData pd;
        char val_str[128];
        tester.get_zero_element( TRIANGLE, pd );
        mMetric.evaluate( pd, 0, value, err );
        ASSERT_NO_ERROR( err );
        sprintf( val_str, "value: %f", value );
        CPPUNIT_ASSERT_MESSAGE( val_str, value > 1e-6 );
        tester.get_zero_element( QUADRILATERAL, pd );
        tester.get_zero_element( TETRAHEDRON, pd );
        tester.get_zero_element( HEXAHEDRON, pd );
        tester.get_zero_element( PRISM, pd );
        tester.get_zero_element( PYRAMID, pd );
Definition at line 176 of file UntangleBetaTest.cpp.
References mMetric.
Definition at line 171 of file UntangleBetaTest.cpp.
References mMetric.
Definition at line 181 of file UntangleBetaTest.cpp.
References mMetric.
Definition at line 83 of file UntangleBetaTest.cpp.
        double value;
        PatchData pd;
        char val_str[128];
        tester.get_inverted_element( TRIANGLE, pd );
        tester.get_inverted_element( QUADRILATERAL, pd );
        tester.get_inverted_element( TETRAHEDRON, pd );
        tester.get_inverted_element( HEXAHEDRON, pd );
        tester.get_inverted_element( PRISM, pd );
        tester.get_inverted_element( PYRAMID, pd );
Definition at line 198 of file UntangleBetaTest.cpp.
References mMetric.
Definition at line 68 of file UntangleBetaTest.cpp.
References mMetric.
Member Data Documentation
List of all members.
