MOAB
4.9.3pre
A conjugate gradient solver for sparse (or dense) self-adjoint problems. More...
#include <ConjugateGradient.h>
Public Types | |
| enum | { UpLo = _UpLo } |
| typedef _MatrixType | MatrixType |
| typedef MatrixType::Scalar | Scalar |
| typedef MatrixType::RealScalar | RealScalar |
| typedef _Preconditioner | Preconditioner |
Public Member Functions | |
| ConjugateGradient () | |
| template<typename MatrixDerived > | |
| ConjugateGradient (const EigenBase< MatrixDerived > &A) | |
| ~ConjugateGradient () | |
| template<typename Rhs , typename Dest > | |
| void | _solve_with_guess_impl (const Rhs &b, Dest &x) const |
| void | _solve_impl (const MatrixBase< Rhs > &b, Dest &x) const |
Private Types | |
| typedef IterativeSolverBase < ConjugateGradient > | Base |
This class allows to solve for A.x = b linear problems using an iterative conjugate gradient algorithm. The matrix A must be selfadjoint. The matrix A and the vectors x and b can be either dense or sparse.
| _MatrixType | the type of the matrix A, can be a dense or a sparse matrix. |
| _UpLo | the triangular part that will be used for the computations. It can be Lower, Upper, or Lower|Upper in which the full matrix entries will be considered. Default is Lower, best performance is Lower|Upper. |
| _Preconditioner | the type of the preconditioner. Default is DiagonalPreconditioner |
The maximal number of iterations and tolerance value can be controlled via the setMaxIterations() and setTolerance() methods. The defaults are the size of the problem for the maximal number of iterations and NumTraits<Scalar>::epsilon() for the tolerance.
The tolerance corresponds to the relative residual error: |Ax-b|/|b|
Performance: Even though the default value of _UpLo is Lower, significantly higher performance is achieved when using a complete matrix and Lower|Upper as the _UpLo template parameter. Moreover, in this case multi-threading can be exploited if the user code is compiled with OpenMP enabled. See TopicMultiThreading for details.
This class can be used as the direct solver classes. Here is a typical usage example:
int n = 10000; VectorXd x(n), b(n); SparseMatrix<double> A(n,n); // fill A and b ConjugateGradient<SparseMatrix<double>, Lower|Upper> cg; cg.compute(A); x = cg.solve(b); std::cout << "#iterations: " << cg.iterations() << std::endl; std::cout << "estimated error: " << cg.error() << std::endl; // update b, and solve again x = cg.solve(b);
By default the iterations start with x=0 as an initial guess of the solution. One can control the start using the solveWithGuess() method.
ConjugateGradient can also be used in a matrix-free context, see the following example .
Definition at line 157 of file ConjugateGradient.h.
typedef IterativeSolverBase<ConjugateGradient> Eigen::ConjugateGradient< _MatrixType, _UpLo, _Preconditioner >::Base [private] |
Reimplemented from Eigen::IterativeSolverBase< ConjugateGradient< _MatrixType, _UpLo, _Preconditioner > >.
Definition at line 159 of file ConjugateGradient.h.
| typedef _MatrixType Eigen::ConjugateGradient< _MatrixType, _UpLo, _Preconditioner >::MatrixType |
Definition at line 166 of file ConjugateGradient.h.
| typedef _Preconditioner Eigen::ConjugateGradient< _MatrixType, _UpLo, _Preconditioner >::Preconditioner |
Definition at line 169 of file ConjugateGradient.h.
| typedef MatrixType::RealScalar Eigen::ConjugateGradient< _MatrixType, _UpLo, _Preconditioner >::RealScalar |
Definition at line 168 of file ConjugateGradient.h.
| typedef MatrixType::Scalar Eigen::ConjugateGradient< _MatrixType, _UpLo, _Preconditioner >::Scalar |
Definition at line 167 of file ConjugateGradient.h.
| anonymous enum |
| Eigen::ConjugateGradient< _MatrixType, _UpLo, _Preconditioner >::ConjugateGradient | ( | ) | [inline] |
| Eigen::ConjugateGradient< _MatrixType, _UpLo, _Preconditioner >::ConjugateGradient | ( | const EigenBase< MatrixDerived > & | A | ) | [inline, explicit] |
Initialize the solver with matrix A for further Ax=b solving.
This constructor is a shortcut for the default constructor followed by a call to compute().
Definition at line 191 of file ConjugateGradient.h.
: Base(A.derived()) {}
| Eigen::ConjugateGradient< _MatrixType, _UpLo, _Preconditioner >::~ConjugateGradient | ( | ) | [inline] |
Definition at line 193 of file ConjugateGradient.h.
| void Eigen::ConjugateGradient< _MatrixType, _UpLo, _Preconditioner >::_solve_impl | ( | const MatrixBase< Rhs > & | b, |
| Dest & | x | ||
| ) | const [inline] |
Definition at line 233 of file ConjugateGradient.h.
x.setZero();
_solve_with_guess_impl(b.derived(),x);
| void Eigen::ConjugateGradient< _MatrixType, _UpLo, _Preconditioner >::_solve_with_guess_impl | ( | const Rhs & | b, |
| Dest & | x | ||
Definition at line 197 of file ConjugateGradient.h.
typedef typename Base::MatrixWrapper MatrixWrapper;
typedef typename Base::ActualMatrixType ActualMatrixType;
enum {
TransposeInput = (!MatrixWrapper::MatrixFree)
&& (UpLo==(Lower|Upper))
&& (!MatrixType::IsRowMajor)
&& (!NumTraits<Scalar>::IsComplex)
typedef typename internal::conditional<TransposeInput,Transpose<const ActualMatrixType>, ActualMatrixType const&>::type RowMajorWrapper;
EIGEN_STATIC_ASSERT(EIGEN_IMPLIES(MatrixWrapper::MatrixFree,UpLo==(Lower|Upper)),MATRIX_FREE_CONJUGATE_GRADIENT_IS_COMPATIBLE_WITH_UPPER_UNION_LOWER_MODE_ONLY);
typedef typename internal::conditional<UpLo==(Lower|Upper),
RowMajorWrapper,
typename MatrixWrapper::template ConstSelfAdjointViewReturnType<UpLo>::Type
>::type SelfAdjointWrapper;
m_iterations = Base::maxIterations();
m_error = Base::m_tolerance;
for(Index j=0; j<b.cols(); ++j)
typename Dest::ColXpr xj(x,j);
RowMajorWrapper row_mat(matrix());
internal::conjugate_gradient(SelfAdjointWrapper(row_mat), b.col(j), xj, Base::m_preconditioner, m_iterations, m_error);
m_isInitialized = true;
m_info = m_error <= Base::m_tolerance ? Success : NoConvergence;
