MOAB
4.9.3pre
A sparse direct supernodal Cholesky (LLT) factorization and solver based on the PaStiX library. More...
#include <PaStiXSupport.h>
Public Types | |
| enum | { UpLo = _UpLo } |
| typedef _MatrixType | MatrixType |
| typedef PastixBase< PastixLDLT < MatrixType, _UpLo > > | Base |
| typedef Base::ColSpMatrix | ColSpMatrix |
Public Member Functions | |
| PastixLDLT () | |
| PastixLDLT (const MatrixType &matrix) | |
| void | compute (const MatrixType &matrix) |
| void | analyzePattern (const MatrixType &matrix) |
| void | factorize (const MatrixType &matrix) |
Protected Member Functions | |
| void | init () |
| void | grabMatrix (const MatrixType &matrix, ColSpMatrix &out) |
This class is used to solve the linear systems A.X = B via a LDL^T supernodal Cholesky factorization available in the PaStiX library. The matrix A should be symmetric and positive definite WARNING Selfadjoint complex matrices are not supported in the current version of PaStiX The vectors or matrices X and B can be either dense or sparse
| MatrixType | the type of the sparse matrix A, it must be a SparseMatrix<> |
| UpLo | The part of the matrix to use : Lower or Upper. The default is Lower as required by PaStiX |
Definition at line 608 of file PaStiXSupport.h.
| typedef PastixBase<PastixLDLT<MatrixType, _UpLo> > Eigen::PastixLDLT< _MatrixType, _UpLo >::Base |
Reimplemented from Eigen::PastixBase< PastixLDLT< _MatrixType, _UpLo > >.
Definition at line 612 of file PaStiXSupport.h.
| typedef Base::ColSpMatrix Eigen::PastixLDLT< _MatrixType, _UpLo >::ColSpMatrix |
Definition at line 613 of file PaStiXSupport.h.
| typedef _MatrixType Eigen::PastixLDLT< _MatrixType, _UpLo >::MatrixType |
Definition at line 611 of file PaStiXSupport.h.
| anonymous enum |
| Eigen::PastixLDLT< _MatrixType, _UpLo >::PastixLDLT | ( | ) | [inline] |
Definition at line 617 of file PaStiXSupport.h.
| Eigen::PastixLDLT< _MatrixType, _UpLo >::PastixLDLT | ( | const MatrixType & | matrix | ) | [inline, explicit] |
Definition at line 622 of file PaStiXSupport.h.
| void Eigen::PastixLDLT< _MatrixType, _UpLo >::analyzePattern | ( | const MatrixType & | matrix | ) | [inline] |
Compute the LDL^T symbolic factorization of matrix using its sparsity pattern The result of this operation can be used with successive matrices having the same pattern as matrix
Definition at line 642 of file PaStiXSupport.h.
ColSpMatrix temp;
grabMatrix(matrix, temp);
Base::analyzePattern(temp);
| void Eigen::PastixLDLT< _MatrixType, _UpLo >::compute | ( | const MatrixType & | matrix | ) | [inline] |
Compute the L and D factors of the LDL^T factorization of matrix
Definition at line 631 of file PaStiXSupport.h.
ColSpMatrix temp;
Base::compute(temp);
| void Eigen::PastixLDLT< _MatrixType, _UpLo >::factorize | ( | const MatrixType & | matrix | ) | [inline] |
Compute the LDL^T supernodal numerical factorization of matrix
Definition at line 651 of file PaStiXSupport.h.
ColSpMatrix temp;
Base::factorize(temp);
| void Eigen::PastixLDLT< _MatrixType, _UpLo >::grabMatrix | ( | const MatrixType & | matrix, |
| ColSpMatrix & | out | ||
| ) | [inline, protected] |
Definition at line 667 of file PaStiXSupport.h.
// Pastix supports only lower, column-major matrices
out.resize(matrix.rows(), matrix.cols());
out.template selfadjointView<Lower>() = matrix.template selfadjointView<UpLo>();
internal::c_to_fortran_numbering(out);
| void Eigen::PastixLDLT< _MatrixType, _UpLo >::init | ( | ) | [inline, protected] |
Definition at line 661 of file PaStiXSupport.h.
